of_device is currently just an #define alias to platform_device until it
gets removed entirely. This patch removes references to it from the
include directories and the core drivers/of code.
There is an unlikely chance of this situation is occurring, but it is
easy to protect against. If a matching entry cannot be found in the
of_match_table, then don't bind the driver.
Both of_bus_type and of_platform_bus_type are just #define aliases
for the platform bus. This patch removes all references to them and
switches to the of_register_platform_driver()/of_unregister_platform_driver()
API for registering.
Subsequent patches will convert each user of of_register_platform_driver()
into plain platform_drivers without the of_platform_driver shim. At which
point the of_register_platform_driver()/of_unregister_platform_driver()
functions can be removed.
of_platform_bus was being used in the same manner as the platform_bus.
The only difference being that of_platform_bus devices are generated
from data in the device tree, and platform_bus devices are usually
statically allocated in platform code. Having them separate causes
the problem of device drivers having to be registered twice if it
was possible for the same device to appear on either bus.
This patch removes of_platform_bus_type and registers all of_platform
bus devices and drivers on the platform bus instead. A previous patch
made the of_device structure an alias for the platform_device structure,
and a shim is used to adapt of_platform_drivers to the platform bus.
After all of of_platform_bus drivers are converted to be normal platform
drivers, the shim code can be removed.
As part of the merge between platform bus and of_platform bus, add the
ability to do of-style matching to the platform bus.
CC: Michal Simek <monstr@monstr.eu>
CC: Grant Likely <grant.likely@secretlab.ca>
CC: Benjamin Herrenschmidt <benh@kernel.crashing.org>
CC: Stephen Rothwell <sfr@canb.auug.org.au>
CC: linux-kernel@vger.kernel.org
CC: microblaze-uclinux@itee.uq.edu.au
CC: linuxppc-dev@ozlabs.org
CC: devicetree-discuss@lists.ozlabs.org
arch/sparc/kernel/prom_64.c
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: synaptics - relax capability ID checks on newer hardware
Input: twl40300-keypad - fix handling of "all ground" rows
Input: gamecon - reference correct pad in gc_psx_command()
Input: gamecon - reference correct input device in NES mode
Input: w90p910_keypad - change platfrom driver name to 'nuc900-kpi'
Input: i8042 - add Gigabyte Spring Peak to dmi_noloop_table
Input: qt2160 - rename kconfig symbol name
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6:
drm/radeon/kms: add quirk to make HP DV5000 laptop resume
drm/radeon/kms: fix RADEON_INFO_CRTC_FROM_ID info ioctl
Fix ttm_page_alloc.c build breakage
drm/radeon/kms: fix legacy LVDS dpms sequence
drm/radeon/kms: drop taking lock around crtc lookup.
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6:
crypto: talitos - fix bug in sg_copy_end_to_buffer
git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb:
sysrq,kdb: Use __handle_sysrq() for kdb's sysrq function
debug_core,kdb: fix kgdb_connected bit set in the wrong place
Fix merge regression from external kdb to upstream kdb
repair gdbstub to match the gdbserial protocol specification
kdb: break out of kdb_ll() when command is terminated
Fixes:
https://bugs.freedesktop.org/show_bug.cgi?id=29062
Reported-by: Andres Cimmarusti <acimmarusti@gmail.com>
Signed-off-by: Alex Deucher <alexdeucher@gmail.com>
Older firmwares fixed the middle byte of the Synaptics capabilities
query to 0x47, but starting with firmware 7.5 the middle byte
represents submodel ID, sometimes also called "dash number".
Reported-and-tested-by: Miroslav Šulc <fordfrog@gmail.com>
The kdb code should not toggle the sysrq state in case an end user
wants to try and resume the normal kernel execution.
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Return the crtc_id, not the counter value. They are not
necessarily the same.
Cc: Jerome Glisse <glisse@freedesktop.org>
The commit 1e8655f87333def92bb8215b423adc65403b08a5
drm/ttm: Fix build on architectures without AGP
looks at TTM_HAS_AGP before it has been set in ttm_bo_driver.h
Move the conditional inclusion of <asm/agp.h> *after* we have included
ttm_bo_driver.h
Signed-of-by: Tony Luck <tony.luck@intel.com>
Add delay after turning off the LVDS encoder.
Fixes:
https://bugzilla.kernel.org/show_bug.cgi?id=16389
Tested-by: Jan Kreuzer <kontrollator@gmx.de>
Cc: stable@kernel.org
We only add/remove crtcs at driver load, you cannot remove when
the GPU is running a CS packet since the fd is open, when
GPU hotplugging on radeons actually is needed all this locking
needs a review and I've started re-working kms core locking to deal
with this better. But for now avoid long delays in CS processing when
hotplug detect is happening in a different thread.
this fixes a regression introduced with hotplug detection.
git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6
* 'urgent' of git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6:
pcmcia: fix 'driver ... did not release config properly' warning
git://git.kernel.org/pub/scm/linux/kernel/git/dgc/xfsdev
* 'shrinker' of git://git.kernel.org/pub/scm/linux/kernel/git/dgc/xfsdev:
mm: add context argument to shrinker callback to remaining shrinkers
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6:
math-emu: correct test for downshifting fraction in _FP_FROM_INT()
perf: Add DWARF register lookup for sparc
MAINTAINERS: Add SBUS driver path to sparc entry.
drivers/sbus: Remove unnecessary casts of private_data
sparc: remove homegrown L1_CACHE_ALIGN macro
sparc64: fix the build error due to smp_kgdb_capture_client()
sparc64: Fix maybe_change_configuration() PCR setting.
arch/sparc/kernel: Eliminate what looks like a NULL pointer dereference
sparc64: Update defconfig.
sunsu: Fix use after free in su_remove().
sunserial: Don't call add_preferred_console() when console= is specified.
sparc32: Kill none_mask, it's bogus.
Pointed out by Lucas who found the new one in a comment in
setup_percpu.c. And then I fixed the others that I grepped
for.
Reported-by: Lucas <canolucas@gmail.com>
Up to 2.6.34 pcmcia_release_irq() reset p_dev->_irq to 0 after releasing
the irq. The IRQ is now released in pcmcia_disable_device(), however
p_dev->_irq is not reset, triggering a warning in pcmcia_device_remove().
Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
Add the shrinkers missed in the first conversion of the API in
commit 7f8275d0d660c146de6ee3017e1e2e594c49e820 ("mm: add context argument to
shrinker callback").
Signed-off-by: Dave Chinner <dchinner@redhat.com>
The Nokia RX51 board code (arch/arm/mach-omap2/board-rx51-peripherals.c)
defines a key map for the matrix keypad keyboard. The hardware seems to
use all of the 8 rows and 8 columns of the keypad, although not all
possible locations are used.
The TWL4030 supports keypads with at most 8 rows and 8 columns. Most keys
are defined with a row and column number between 0 and 7, except
KEY(0xff, 2, KEY_F9),
KEY(0xff, 4, KEY_F10),
KEY(0xff, 5, KEY_F11),
which represent keycodes that should be emitted when entire row is
connected to the ground. since the driver handles this case as if we
had an extra column in the key matrix. Unfortunately we do not allocate
enough space and end up owerwriting some random memory.
Reported-and-tested-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Otherwise we won't see any events from the gamepad.
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=16408
Reported-and-tested-by: Eugene Yudin <eugene.yudin@gmail.com>
We moved input devices from 'struct gc' to individial pads (struct
gc-pad), but gc_nes_process_packet() was still trying to use old
ones and crashing.
drm/r600: fix possible NULL pointer derefernce
drm/radeon/kms: add quirk for ASUS HD 3600 board
include/linux/vgaarb.h: add missing part of include guard
drm/nouveau: Fix crashes during fbcon init on single head cards.
drm/nouveau: fix pcirom vbios shadow breakage from acpi rom patch
drm/radeon/kms: fix shared ddc harder
drm/i915: enable low power render writes on GEN3 hardware.
drm/i915: Define MI_ARB_STATE bits
vmwgfx: return -EFAULT if copy_to_user fails
fb: handle allocation failure in alloc_apertures()
drm: radeon: check kzalloc() result
drm/radeon/kms: fix gtt MC base alignment on rs4xx/rs690/rs740 asics
drm/radeon/kms: fix possible mis-detection of sideport on rs690/rs740
drm/radeon/kms: fix legacy tv-out pal mode
Reported-by: Alexander Y. Fomichev <git.user@gmail.com>
Connector is actually DVI rather than HDMI.
Reported-by: trapDoor <trapdoor6@gmail.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (24 commits)
bridge: Partially disable netpoll support
tcp: fix crash in tcp_xmit_retransmit_queue
IPv6: fix CoA check in RH2 input handler (mip6_rthdr_input())
ibmveth: lost IRQ while closing/opening device leads to service loss
rt2x00: Fix lockdep warning in rt2x00lib_probe_dev()
vhost: avoid pr_err on condition guest can trigger
ipmr: Don't leak memory if fib lookup fails.
vhost-net: avoid flush under lock
net: fix problem in reading sock TX queue
net/core: neighbour update Oops
net: skb_tx_hash() fix relative to skb_orphan_try()
rfs: call sock_rps_record_flow() in tcp_splice_read()
xfrm: do not assume that template resolving always returns xfrms
hostap_pci: set dev->base_addr during probe
axnet_cs: use spin_lock_irqsave in ax_interrupt
dsa: Fix Kconfig dependencies.
act_nat: not all of the ICMP packets need an IP header payload
r8169: incorrect identifier for a 8168dp
Phonet: fix skb leak in pipe endpoint accept()
Bluetooth: Update sec_level/auth_type for already existing connections
System will crash sooner or later once the memory with the code of the
s3c-sdhci.ko module is reused for something else. I really have no idea
how the lack of remove function went unnoticed into the mainline code.
Cc: <stable@kernel.org>
My Collabora address is no longer enabled - update the MODULE_AUTHOR
fields of drivers to my current email address.
Signed-off-by: Andres Salomon <dilinger@queued.net>
Simply add a proper ID into the device table.
Signed-off-by: Anton Vorontsov <avorontsov@mvista.com>
Cc: Doug Thompson <dougthompson@xmission.com>
Cc: Peter Tyser <ptyser@xes-inc.com>
Cc: Dave Jiang <djiang@mvista.com>
Cc: Kumar Gala <galak@kernel.crashing.org>
Since commit 5753c082f66eca5be81f6bda85c1718c5eea6ada ("powerpc/85xx:
Kconfig cleanup"), there is no MPC85xx Kconfig symbol anymore, so the
driver became non-selectable.
This patch fixes the issue by switching to PPC_85xx symbol.
this fixes a regression since the fbcon rework.
Signed-off-by: Francisco Jerez <currojerez@riseup.net>
Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
On nv50 it became impossible to attempt a PCI ROM shadow of the VBIOS,
which will break some setups.
This patch also removes the different ordering of shadow methods for
pre-nv50 chipsets. The reason for the different ordering was paranoia,
but it should hopefully be OK to try shadowing PRAMIN first.
This fixes a regression caused by b2ea4aa67bfd084834edd070e0a4a47857d6db59
due to the way shared ddc with multiple digital connectors was handled.
You generally have two cases where DDC lines are shared:
- HDMI + VGA
- HDMI + DVI-D
HDMI + VGA is easy to deal with because you can check the EDID for the
to see if the attached monitor is digital. A shared DDC line with two
digital connectors is more complex. You can't use the hdmi bits in the
EDID since they may not be there with DVI<->HDMI adapters. In this case
all we can do is check the HPD pins to see which is connected as we have
no way of knowing using the EDID.
Reported-by: trapdoor6@gmail.com
* git://git.infradead.org/users/cbou/battery-2.6.35:
ds2782_battery: Fix ds2782_get_capacity return value
A lot of 945GMs have had stability issues for a long time, this manifested as X hangs, blitter engine hangs, and lots of crashes.
one such report is at:
https://bugs.freedesktop.org/show_bug.cgi?id=20560
along with numerous distro bugzillas.
This only took a week of digging and hair ripping to figure out.
Tracked down and tested on a 945GM Lenovo T60,
previously running
x11perf -copypixwin500
or
x11perf -copywinpix500
repeatedly would cause the GPU to wedge within 4 or 5 tries, with random busy bits set.
After this patch no hangs were observed.
cc: stable@kernel.org
The i915 memory arbiter has a register full of configuration
bits which are currently not defined in the driver header file.
Signed-off-by: Keith Packard <keithp@keithp.com>
copy_to_user() returns the number of bytes remaining to be copied, but
we want to return a negative error code. This gets copied to user
space.
If kzalloc() fails exit with -ENOMEM.
Signed-off-by: Kulikov Vasiliy <segooon@gmail.com>
Make inclusion of <asm/agp.h> conditional on TTM_HAS_AGP. The use
of the functions declared in it is already conditional.
Reported-by: Geert Stappers <stappers@stappers.nl>
Tested-by: Geert Stappers <stappers@stappers.nl>
The name of platfrom device was changed and we need to make driver's
name match in order for it to bind to the device.
Signed-off-by: Wan ZongShun <mcuos.com@gmail.com>
Gigabyte "Spring Peak" notebook indicates wrong chassis-type, tripping up
i8042 and breaking the touchpad. Add this model to i8042_dmi_noloop_table[]
to resolve.
BugLink: https://bugs.launchpad.net/bugs/580664
Signed-off-by: Kamal Mostafa <kamal@canonical.com>
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6:
[S390] cio: fix potential overflow in chpid descriptor
[S390] add missing device put
[S390] dasd: use correct label location for diag fba disks
- fix reversing of command/sub arguments
- fix a crash if the i2c interface is called before the device is found
Signed-off-by: Sreedhara DS <sreedhara.ds@intel.com>
Signed-off-by: Alan Cox <alan@linux.intel.com>
The length filed in the chsc response block (if valid)
has a value of n*(sizeof(chp_desc))+8 (for the response
block header). When we memcopied from the response block
to the actual descriptor we copied 8 bytes too much.
The bug was not revealed since the descriptor is embedded
in struct channel_path.
Since we only write one descriptor at a time ignore the
length value and use sizeof(*desc).
Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com>
The dasd_alias_show function does not return a device reference
in case the device is an alias.
Signed-off-by: Stefan Haberland <stefan.haberland@de.ibm.com>
