git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (57 commits)
regulator: Fix 88pm8607.c printk format warning
input: Add support for Qualcomm PMIC8XXX power key
input: Add Qualcomm pm8xxx keypad controller driver
mfd: Add omap-usbhs runtime PM support
mfd: Fix ASIC3 SD Host Controller Configuration size
mfd: Fix omap_usbhs_alloc_children error handling
mfd: Fix omap usbhs crash when rmmoding ehci or ohci
mfd: Add ASIC3 LED support
leds: Add ASIC3 LED support
mfd: Update twl4030-code maintainer e-mail address
mfd: Correct the name and bitmask for ab8500-gpadc BTempPullUp
mfd: Add manual ab8500-gpadc batt temp activation for AB8500 3.0
mfd: Provide ab8500-core enumerators for chip cuts
mfd: Check twl4030-power remove script error condition after i2cwrite
mfd: Fix twl6030 irq definitions
mfd: Add phoenix lite (twl6025) support to twl6030
mfd: Avoid to use constraint name in 88pm860x regulator driver
mfd: Remove checking on max8925 regulator[0]
mfd: Remove unused parameter from 88pm860x API
mfd: Avoid to allocate 88pm860x static platform data
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband:
RDMA/cma: Save PID of ID's owner
RDMA/cma: Add support for netlink statistics export
RDMA/cma: Pass QP type into rdma_create_id()
RDMA: Update exported headers list
RDMA/cma: Export enum cma_state in <rdma/rdma_cm.h>
RDMA/nes: Add a check for strict_strtoul()
RDMA/cxgb3: Don't post zero-byte read if endpoint is going away
RDMA/cxgb4: Use completion objects for event blocking
IB/srp: Fix integer -> pointer cast warnings
IB: Add devnode methods to cm_class and umad_class
IB/mad: Return EPROTONOSUPPORT when an RDMA device lacks the QP required
IB/uverbs: Add devnode method to set path/mode
RDMA/ucma: Add .nodename/.mode to tell userspace where to create device node
RDMA: Add netlink infrastructure
RDMA: Add error handling to ib_core_init()
* 'spi/next' of git://git.secretlab.ca/git/linux-2.6:
spi/amba-pl022: work in polling or interrupt mode if pl022_dma_probe fails
spi/spi_s3c24xx: Use spi_bitbang_stop instead of spi_unregister_master in s3c24xx_spi_remove
spi/spi_nuc900: Use spi_bitbang_stop instead of spi_unregister_master in nuc900_spi_remove
spi/spi_tegra: use spi_unregister_master() instead of spi_master_put()
spi/spi_sh: use spi_unregister_master instead of spi_master_put in remove path
spi: Use void pointers for data in simple SPI I/O operations
spi/pl022: use cpu_relax in the busy loop
spi/pl022: mark driver non-experimental
spi/pl022: timeout on polled transfer v2
spi/dw_spi: improve the interrupt mode with the batch ops
spi/dw_spi: change poll mode transfer from byte ops to batch ops
spi/dw_spi: remove the un-necessary flush()
spi/dw_spi: unify the low level read/write routines
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6
* 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (33 commits)
OMAP3: PM: Boot message is not an error, and not helpful, remove it
OMAP3: cpuidle: change the power domains modes determination logic
OMAP3: cpuidle: code rework for improved readability
OMAP3: cpuidle: re-organize the C-states data
OMAP3: clean-up mach specific cpuidle data structures
OMAP3 cpuidle: remove useless SDP specific timings
usb: otg: OMAP4430: Powerdown the internal PHY when USB is disabled
usb: otg: OMAP4430: Fixing the omap4430_phy_init function
usb: musb: am35x: fix compile error when building am35x
usb: musb: OMAP4430: Power down the PHY during board init
omap: drop board-igep0030.c
omap: igep0020: add support for IGEP3
omap: igep0020: minor refactoring
omap: igep0020: name refactoring for future merge with IGEP3
omap: Remove support for omap2evm
arm: omap2plus: GPIO cleanup
omap: musb: introduce default board config
omap: move detection of NAND CS to common-board-devices
omap: use common initialization for PMIC i2c bus
omap: consolidate touch screen initialization among different boards
git://git.kernel.org/pub/scm/linux/kernel/git/djm/tmem
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/djm/tmem:
xen: cleancache shim to Xen Transcendent Memory
ocfs2: add cleancache support
ext4: add cleancache support
btrfs: add cleancache support
ext3: add cleancache support
mm/fs: add hooks to support cleancache
mm: cleancache core ops functions and config
fs: add field to superblock to support cleancache
mm/fs: cleancache documentation
Fix up trivial conflict in fs/btrfs/extent_io.c due to includes
Fix printk format warning (seen on x86_64) and change to unsigned
output format:
drivers/regulator/88pm8607.c:417: warning: format '%d' expects type 'int', but argument 3 has type 'resource_size_t'
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Add support for PMIC8XXX power key driven over dedicated
KYPD_PWR_N pin.
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Signed-off-by: Trilok Soni <tsoni@codeaurora.org>
Signed-off-by: Anirudh Ghayal <aghayal@codeaurora.org>
Add Qualcomm PMIC8XXX based keypad controller driver
supporting upto 18x8 matrix configuration.
Acked-by: Dmitry Torokhov <dtor@mail.ru>
The usbhs core driver does not enable/disable the interface and
functional clocks; These clocks are handled by hwmod and runtime pm,
hence insted of the clock enable/disable, the runtime pm APIS are
used. however,the port clocks and tll clocks are handled
by the usbhs core.
Signed-off-by: Keshava Munegowda <keshava_mgowda@ti.com>
The size of the TC6380AF SD Host Controller Configuration area is 0x200 bytes (assuming registers are aligned on 32-bit boundaries), not 0x400 bytes. Source: Toshiba TC6380AF Specification sections 4.2 and 4.3.1
Signed-off-by: Paul Parsons <lost.distance@yahoo.com>
1. Return proper error if omap_usbhs_alloc_child fails
2. In the case of goto err_ehci, we should call platform_device_unregister(ehci)
instead of platform_device_put(ehci) because we have already added the
platform device to device hierarchy.
Tested-by: Keshava Munegowda <keshava_mgowda@ti.com>
Acked-by: Felipe Balbi <balbi@ti.com>
The disabling of clocks and freeing GPIO are changed
to fix the occurrence of the crash of rmmod of ehci and ohci
drivers. The GPIOs should be freed after the spin locks are
unlocked.
Cc: stable@kernel.org
Add LED support for the HTC ASIC3. Underlying support is provided by the mfd/asic3 and leds/leds-asic3 drivers. An example configuration is provided by the pxa/hx4700 platform.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
The bitmask for enabling the BatTemp pull-up was wrong and
is corrected. The name is also changed to be inline with
the AB8500 register description
Signed-off-by: Johan Palsson <johan.palsson@stericsson.com>
Reviewed-by: Mattias Wallin <mattias.wallin@stericsson.com>
In AB8500 3.0 the pull-up supplying the NTC must be manually activated.
Add enumerators to chip version detection logic.
Signed-off-by: Kalle Komierowski <karl.komierowski@stericsson.com>
Reviewed-by: Johan Palsson <johan.palsson@stericsson.com>
Reviewed-by: Daniel Willerud <daniel.willerud@stericsson.com>
Reviewed-by: Jonas Aberg <jonas.aberg@stericsson.com>
Since functionality in MFD cells may need to be adjusted according to
chip revision, let's enumerate them and keep track of them.
Fixing the error condition check in twl4030 remove script function.
Due to some typo in commit ID: 11a441ce82d6ffecfd39b324024de0cd630b36c1
Signed-off-by: Lesly A M <leslyam@ti.com>
The charger fault IRQs from the twl will in future patches be handled
by a seperate IRQ handler in the charger driver than the general charger
IRQ. Give them different IRQ numbers now to allow the charger driver to
be merged in the future.
Signed-off-by: Graeme Gregory <gg@slimlogic.co.uk>
Phoenix Lite is based on the twl6030 family of PMICs. It has mostly the
same feature set of twl6030 but with small changes. The codec block has
also been removed. It also has a new charger block and new features in
its ADC block. VUSB handling also differs.
Reviewed-by: Mark Brown <broonie@opensource.wolfsonicro.com>
Avoid to use constraint name in regulator driver. So use regulator id is used
instead in platform driver.
Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com>
Cc: Liam Girdwood <lrg@slimlogic.co.uk>
Since regulator[0] is always checking in mfd driver, it results in
registration failure without regulator[0].
Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
i2c_client parameter isn't used in some functions. Just remove it.
Maybe multiple PMIC devices are installed into one board. Static variable
can only make driver logic mess. So remove these variable, and use
platform data from platform driver instead.
Enable rtc function in 88pm860x PMIC.
Cc: Alessandro Zummo <a.zummo@towertech.it>
Force to enable i2c as power up/down sequence. Otherwise, SD/LDO can't
be enabled or disabled via accessing i2c bus.
Avoid to get platform_data from parent device. Get it from mfd cell
device instead.
Acked-by: Anton Vorontsov <cbou@mail.ru>
In the current code, every time we set a TPS6586x GPIO pin,
the tps6586x_gpio_set function is resetting all other GPIO pins.
We need to update the right GPIOxOUT bit of the GPIOSET2 register instead
of overriding the full value.
Tested by setting sequentially GPIO2 and GPIO3 and verifying the
pins voltage.
Change-Id: I560edde146c5425cce37432c4ee91569eea5adcf
Signed-off-by: Vincent Palatin <vpalatin@chromium.org>
Add support for the irq controller in Qualcomm 8xxx pmic. The 8xxx
interrupt controller provides control for gpio and mpp configured as
interrupts in addition to other subdevice interrupts. The interrupt
controller also provides a way to read the real time status of an
interrupt. This real time status is the only way one can get the
input values of gpio and mpp lines.
Signed-off-by: Abhijeet Dharmapurikar <adharmap@codeaurora.org>
Add support for the Qualcomm PM8921 PMIC chip. The core driver
will communicate with the PMIC chip via the MSM SSBI bus.
PCF50633_ADC and PCF50633_GPIO depends on MFD_PCF50633.
Thus group NXP PCF50633* drivers together.
Group TPSxxxxx power management chips together and sort in alphabetical order.
This change makes it easier for users to find config options.
Added API to get the TWL5030 Si version from the IDCODE register.
It is used for enabling the workaround for TWL erratum 27.
Cc: Nishanth Menon <nm@ti.com>
Cc: David Derrick <dderrick@ti.com>
Modifying the macro name Main_Ref to all caps(MAIN_REF).
Suggested by Nishanth Menon <nm@ti.com>
Correcting the if condition check for printing the warning,
if wakeup script is not updated before updating the sleep script.
Since the flag 'order' is set to '1' while updating the wakeup script
for P1P2, the condition checking for printing the warning should be
if(!order) (ie: print the warning if wakeup script is not updated before
updating the sleep script)
WARNING: vmlinux.o(.devinit.text+0x6c4): Section mismatch in reference
from the function device_onkey_init() to the (unknown reference)
.init.data:(unknown)
The function __devinit device_onkey_init() references a (unknown reference)
__initdata (unknown).
If (unknown) is only used by device_onkey_init then annotate (unknown)
with a matching annotation.
It's caused by using __initdata on mfd cell resources. Replace __initdata
with __devinitdata.
Remove the unused variable "u16 val" of wl1273-core.c.
Signed-off-by: Wanlong Gao <wanlong.gao@gmail.com>
The fact that we can't actually raise any interrupts doesn't stop us
setting up the IRQs we're exporting. While this isn't actually going
to do anything it allows us to proceed further through device setup
during board bringup and avoids issues with the MFD core not letting
us suppress the configuration of IRQ resources.
Allow the GPIO mode of WM831x devices to be configured using platform data.
Users may provide a table of GPIO register values in gpio_defaults[]. In
order to allow 0 to be set explicitly out of range values are accepted and
masked off, with a WM831X_GPIO_CONFIGURE define provided to set an out of
range value.
This can be used to configure higher numbered GPIOs or override values set
in OTP for GPIOs configured using OTP.
With the addition of a platform device mfd_cell pointer, MFD drivers
can go back to passing platform data back to their sub drivers.
This allows for an mfd_cell->mfd_data removal and thus keep the
sub drivers MFD agnostic. This is mostly needed for non MFD aware
sub drivers.
Acked-by: Liam Girdwood <lrg@ti.com>
sub drivers.
can go back to passing platform back to their sub drivers.
sub drivers.
Cc: Miguel Aguilar <miguel.aguilar@ridgerun.com>
Cc: Mark Brown <broonie@opensource.wolfsonmicro.com>
sub drivers.
Cc: Richard Purdie <rpurdie@rpsys.net>
Acked-by: Haojian Zhuang <haojian.zhuang@marvell.com>
sub drivers.
Cc: Linus Walleij <linus.walleij@linaro.org>
sub drivers.
Cc: Peter Ujfalusi <peter.ujfalusi@nokia.com>
Cc: Dmitry Torokhov <dtor@mail.ru>
sub drivers.
Cc: Ira W. Snyder <iws@ovro.caltech.edu>
Cc: Wolfgang Grandegger <wg@grandegger.com>
Cc: Grant Likely <grant.likely@secretlab.ca>
sub drivers.
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
sub drivers.
Cc: Wim Van Sebroeck <wim@iguana.be>
Cc: Florian Fainelli <florian@openwrt.org>
With the addition of a device platform mfd_cell pointer, MFD drivers
sub drivers.
Acked-by: Richard Röjfors <richard.rojfors@pelagicore.com>
