path: root/drivers
2008-02-14Introduce path_put()Jan Blunck
* Add path_put() functions for releasing a reference to the dentry and vfsmount of a struct path in the right order * Switch from path_release(nd) to path_put(&nd->path) * Rename dput_path() to path_put_conditional() [akpm@linux-foundation.org: fix cifs] Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Acked-by: Christoph Hellwig <hch@lst.de> Cc: <linux-fsdevel@vger.kernel.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14Embed a struct path into struct nameidata instead of nd->{dentry,mnt}Jan Blunck
This is the central patch of a cleanup series. In most cases there is no good reason why someone would want to use a dentry for itself. This series reflects that fact and embeds a struct path into nameidata. Together with the other patches of this series - it enforced the correct order of getting/releasing the reference count on <dentry,vfsmount> pairs - it prepares the VFS for stacking support since it is essential to have a struct path in every place where the stack can be traversed - it reduces the overall code size: without patch series: text data bss dec hex filename 5321639 858418 715768 6895825 6938d1 vmlinux with patch series: text data bss dec hex filename 5320026 858418 715768 6894212 693284 vmlinux This patch: Switch from nd->{dentry,mnt} to nd->path.{dentry,mnt} everywhere. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix cifs] [akpm@linux-foundation.org: fix smack] Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14Dont touch fs_struct in driversJan Blunck
The sound drivers and the pnpbios core test for current->root != NULL. This test seems to be unnecessary since we always have rootfs mounted before initializing the drivers. Signed-off-by: Jan Blunck <jblunck@suse.de> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Jaroslav Kysela <perex@suse.cz> Acked-by: Takashi Iwai <tiwai@suse.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14Fix compile of swim3 as moduleTony Breeds
The current pmac32_defconfig fails to build with the following error: Building modules, stage 2. ERROR: "check_media_bay" [drivers/block/swim3.ko] undefined! WARNING: modpost: Found 23 section mismatch(es). To see full details build your kernel with: 'make CONFIG_DEBUG_SECTION_MISMATCH=y' make[2]: *** [__modpost] Error 1 This patch fixes that. Signed-off-by: Tony Breeds <tony@bakeyournoodle.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Acked-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Josh Boyer <jwboyer@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6: [SCSI] gdth: update deprecated pci_find_device [SCSI] gdth: scan for scsi devices [SCSI] sym53c416: fix module parameters [SCSI] lpfc 8.2.5 : Update lpfc driver version to 8.2.5 [SCSI] lpfc 8.2.5 : Fix buffer leaks [SCSI] lpfc 8.2.5 : Miscellaneous discovery Fixes [SCSI] lpfc 8.2.5 : Add MSI-X single message support [SCSI] lpfc 8.2.5 : Miscellaneous Fixes [SCSI] lpfc 8.2.5 : Correct ndlp referencing issues [SCSI] update SG_ALL to avoid causing chaining [SCSI] aic94xx: fix ABORT_TASK define conflict [SCSI] fas216: Use scsi_eh API for REQUEST_SENSE invocation [SCSI] ses: fix memory leaks [SCSI] aacraid: informational sysfs value corrections [SCSI] mpt fusion: Request I/O resources only when required [SCSI] aacraid: ignore adapter reset check polarity [SCSI] aacraid: add optional MSI support [SCSI] mpt fusion: Avoid racing when mptsas and mptcl module are loaded in parallel [SCSI] MegaRAID driver management char device moved to misc [SCSI] advansys: fix overrun_buf aligned bug
2008-02-13pcmcia: ipwireless depends on NETDEVICESPaul Mundt
ipwireless (added by 099dc4fb62653f6019d78db55fba7a18ef02d65b) is clearly a net device: drivers/built-in.o: In function `ipwireless_ppp_start_xmit': /home/pmundt/devel/git/sh-2.6.25/drivers/char/pcmcia/ipwireless/network.c:165: undefined reference to `skb_under_panic' /home/pmundt/devel/git/sh-2.6.25/drivers/char/pcmcia/ipwireless/network.c:165: undefined reference to `kfree_skb' drivers/built-in.o: In function `ipwireless_network_packet_received': /home/pmundt/devel/git/sh-2.6.25/drivers/char/pcmcia/ipwireless/network.c:377: undefined reference to `__alloc_skb' /home/pmundt/devel/git/sh-2.6.25/drivers/char/pcmcia/ipwireless/network.c:377: undefined reference to `skb_over_panic' drivers/built-in.o: In function `ppp_shutdown_interface': /home/pmundt/devel/git/sh-2.6.25/drivers/net/ppp_generic.c:2517: undefined reference to `unregister_netdev' /home/pmundt/devel/git/sh-2.6.25/drivers/net/ppp_generic.c:2517: undefined reference to `free_netdev' [ ... and many more ... ] select strikes again. ipwireless selects PPP which in turn tries to select SLHC, both of which are technically "protected" by an if NETDEVICES in drivers/net/Kconfig. This leads to .config hilarity, with net suddenly ending up in the SCSI menu: # # SCSI device support # # CONFIG_SCSI_DMA is not set # CONFIG_SCSI_NETLINK is not set CONFIG_PPP=y # CONFIG_PHONE is not set Curiously the SLHC select from PPP doesn't seem to happen, as there's no CONFIG_SLHC=y (only CONFIG_PPP=y gets set) -- Kconfig bug? Caught with a randconfig. Signed-off-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13parport: section fixupDavid Brownell
Fix section warning for parport_ECP_supported(); it's called from a routine exported to modules, so it can't be removed with __devinit section pruning. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13Final removal of FASTCALL()/fastcallHarvey Harrison
All users are gone, remove definitions and comments referring to them. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13acpi: fix acpi_os_read_pci_configuration() misuse of raw_pci_read()Linus Torvalds
The raw_pci_read() interface (as the raw_pci_ops->read() before it) unconditionally fills in a 32-bit integer return value regardless of the size of the operation requested. So claiming to take a "void *" is wrong, as is passing in a pointer to just a byte variable. Noticed by pageexec when enabling -fstack-protector (which needs other patches too to actually work, but that's a separate issue). Acked-by: Len Brown <len.brown@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13drivers/memstick/host/tifm_ms.c breakageAl Viro
writel(sock + ...) that should've been writel(sock->addr + ...) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13dm-raid1 breakage on 64bitAl Viro
test_and_set_bit() on address of uint32_t is a Bad Idea(tm)... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13wmi: (!x & y) strikes againAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Carlos Corbacho <carlos@strangeworlds.co.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13[SCSI] gdth: update deprecated pci_find_deviceSergio Luis
Fix compilation warning in gdth.c, which was using the deprecated pci_find_device. drivers/scsi/gdth.c:645: warning: 'pci_find_device' is deprecated (declared at include/linux/pci.h:495) Changing it to use pci_get_device, instead. Signed-off-by: Sergio Luis <sergio@larces.uece.br> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-13[SCSI] gdth: scan for scsi devicesBoaz Harrosh
The patch: "gdth: switch to modern scsi host registration" missed one simple fact when moving a way from scsi_module.c. That is to call scsi_scan_host() on the probed host. With this the gdth driver from 2.6.24 is again able to see drives and boot. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Tested-by: Joerg Dorchain <joerg@dorchain.net> Tested-by: Stefan Priebe <s.priebe@allied-internet.ag> Tested-by: Jon Chelton <jchelton@ffpglobal.com> Cc: Stable Tree <stable@kernel.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-12[SCSI] sym53c416: fix module parametersJames Bottomley
It looks like there's been a bug in the module parameter setup forever. The upshot doesn't really matter, because even if no parameters are ever set, we just call sym53c416_setup() three times, but the zero values in the arrays eventually cause nothing to happen. Unfortunately gcc has started to notice this now too: drivers/scsi/sym53c416.c: In function 'sym53c416_detect': drivers/scsi/sym53c416.c:624: warning: the address of 'sym53c416' will always evaluate as 'true' drivers/scsi/sym53c416.c:630: warning: the address of 'sym53c416_1' will always evaluate as 'true' drivers/scsi/sym53c416.c:636: warning: the address of 'sym53c416_2' will always evaluate as 'true' drivers/scsi/sym53c416.c:642: warning: the address of 'sym53c416_3' will always evaluate as 'true' So fix this longstanding bug to keep gcc quiet. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-11WMI: initialize wmi_blocks.list even if ACPI is disabledLinus Torvalds
Even if we don't want to register the WMI driver, we should initialize the wmi_blocks list to be empty, since we don't want the wmi helper functions to oops just because that basic list has not even been set up. With this, "find_guid()" will happily return "not found" rather than oopsing all over the place, and the callers will then just automatically return false or AE_NOT_FOUND as appropriate. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-11Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: mlx4_core: Fix build break (missing include)
2008-02-11Merge branch 'upstream-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev: sata_mv: platform driver allocs dma without create pata_ninja32: setup changes pata_legacy: typo fix pata_amd: Note in the module description it handles Nvidia sata_mv: fix loop with last port libata: ignore deverr on SETXFER if mode is configured pata_via: fix SATA cable detection on cx700
2008-02-11[SCSI] lpfc 8.2.5 : Update lpfc driver version to 8.2.5James Smart
Update lpfc driver version to 8.2.5 Signed-off-by: James Smart <james.smart@emulex.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-11[SCSI] lpfc 8.2.5 : Fix buffer leaksJames Smart
Fix buffer leaks: - HBQ dma buffer leak at dma_pool_destroy when unloading driver - Fix missing buffer free in slow ring buffer handling Signed-off-by: James Smart <james.smart@emulex.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-11[SCSI] lpfc 8.2.5 : Miscellaneous discovery FixesJames Smart
Miscellaneous discovery fixes: - Flush RSCN buffers on vports when reseting HBA. - Fix incorrect FLOGI after vport reg failed - Fix a potential fabric ELS race condition - Fix handling of failed PLOGI command under high lip rates - Fix FDISC handling - Fix debug logging for npiv handling Signed-off-by: James Smart <james.smart@emulex.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-11[SCSI] lpfc 8.2.5 : Add MSI-X single message supportJames Smart
2008-02-11[SCSI] lpfc 8.2.5 : Miscellaneous FixesJames Smart
Miscellaneous fixes: - Fix ERRATT flag which was overlapping - Allow RESTART mbx commands through when stopped. - Accept incoming PLOGI when connected to an N_Port. - Fix NPort to NPort pt2pt problems: ADISC and reg_vpi issues - Fix vport unloading error that erroneously cleaned up RSCN buffers - Fix memory leak during repeated unloads - in mbox handling - Fix link bounce vs FLOGI race conditions Signed-off-by: James Smart <james.smart@emulex.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-11[SCSI] lpfc 8.2.5 : Correct ndlp referencing issuesJames Smart
Correct ndlp referencing issues: - Fix ndlp kref issues due to race conditions between threads - Fix cancel els delay retry event which missed an ndlp reference count Signed-off-by: James Smart <james.smart@emulex.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-11mlx4_core: Fix build break (missing include)Olof Johansson
Commit 313abe55 ("mlx4_core: For 64-bit systems, vmap() kernel queue buffers") caused this to pop up on powerpc allyesconfig, looks like a missing include file: drivers/net/mlx4/alloc.c: In function 'mlx4_buf_alloc': drivers/net/mlx4/alloc.c:162: error: implicit declaration of function 'vmap' drivers/net/mlx4/alloc.c:162: error: 'VM_MAP' undeclared (first use in this function) drivers/net/mlx4/alloc.c:162: error: (Each undeclared identifier is reported only once drivers/net/mlx4/alloc.c:162: error: for each function it appears in.) drivers/net/mlx4/alloc.c:162: warning: assignment makes pointer from integer without a cast drivers/net/mlx4/alloc.c: In function 'mlx4_buf_free': drivers/net/mlx4/alloc.c:187: error: implicit declaration of function 'vunmap' Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-02-11[SCSI] aic94xx: fix ABORT_TASK define conflictBoaz Harrosh
include/scsi/scsi.h as a definition: #define ABORT_TASK 0x0d on the other hand drivers/scsi/aic94xx/aic94xx_sas.h has: #define ABORT_TASK 0x03 rename the latter to SCB_ABORT_TASK Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-11sata_mv: platform driver allocs dma without createByron Bradley
When the sata_mv driver is used as a platform driver, mv_create_dma_pools() is never called so it fails when trying to alloc in mv_pool_start(). Signed-off-by: Byron Bradley <byron.bbradley@gmail.com> Acked-by: Mark Lord <mlord@pobox.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-11pata_ninja32: setup changesAlan Cox
Forcibly set more of the configuration at init time. This seems to fix at least one problem reported. We don't know what most of these bits do, but we do know what windows stuffs there. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-11pata_legacy: typo fixAlan Cox
2008-02-11pata_amd: Note in the module description it handles NvidiaAlan Cox
This has confused a few people so fix it Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-11sata_mv: fix loop with last portYinghai Lu
commit f351b2d638c3cb0b95adde3549b7bfaf3f991dfa sata_mv: Support SoC controllers cause panic: scsi 4:0:0:0: Direct-Access ATA HITACHI HDS7225S V44O PQ: 0 ANSI: 5 sd 4:0:0:0: [sde] 488390625 512-byte hardware sectors (250056 MB) sd 4:0:0:0: [sde] Write Protect is off sd 4:0:0:0: [sde] Mode Sense: 00 3a 00 00 sd 4:0:0:0: [sde] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA sd 4:0:0:0: [sde] 488390625 512-byte hardware sectors (250056 MB) sd 4:0:0:0: [sde] Write Protect is off sd 4:0:0:0: [sde] Mode Sense: 00 3a 00 00 sd 4:0:0:0: [sde] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA sde:<1>BUG: unable to handle kernel NULL pointer dereference at 000000000000001a IP: [<ffffffff806262c7>] mv_interrupt+0x21c/0x4cc PGD 0 Oops: 0000 [1] SMP CPU 3 Modules linked in: Pid: 0, comm: swapper Not tainted 2.6.24-smp-08636-g0afc2ed-dirty #26 RIP: 0010:[<ffffffff806262c7>] [<ffffffff806262c7>] mv_interrupt+0x21c/0x4cc RSP: 0000:ffff8102050bbec8 EFLAGS: 00010297 RAX: 0000000000000008 RBX: 0000000000000000 RCX: 0000000000000003 RDX: 0000000000008000 RSI: 0000000000000286 RDI: ffff8102035180e0 RBP: 0000000000000001 R08: 0000000000000003 R09: ffff8102036613e0 R10: 0000000000000002 R11: ffffffff8061474c R12: ffff8102035bf828 R13: 0000000000000008 R14: ffff81020348ece8 R15: ffffc20002cb2000 FS: 0000000000000000(0000) GS:ffff810405025700(0000) knlGS:0000000000000000 CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b CR2: 000000000000001a CR3: 0000000000201000 CR4: 00000000000006e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process swapper (pid: 0, threadinfo ffff810405094000, task ffff8102050b28c0) Stack: 000000010000000c 0002040000220400 0000001100000002 ffff81020348eda8 0000000000000001 ffff8102035f2cc0 0000000000000000 0000000000000000 0000000000000018 0000000000000000 0000000000000000 ffffffff80269ee8 Call Trace: <IRQ> [<ffffffff80269ee8>] ? handle_IRQ_event+0x25/0x53 [<ffffffff8026b393>] ? handle_fasteoi_irq+0x90/0xc8 [<ffffffff802218e2>] ? do_IRQ+0xf1/0x15f [<ffffffff8021df24>] ? default_idle+0x0/0x55 [<ffffffff8021f361>] ? ret_from_intr+0x0/0xa <EOI> [<ffffffff8023010c>] ? lapic_next_event+0x0/0xa [<ffffffff8021df55>] ? default_idle+0x31/0x55 [<ffffffff8021df50>] ? default_idle+0x2c/0x55 [<ffffffff8021df24>] ? default_idle+0x0/0x55 [<ffffffff8021e00b>] ? cpu_idle+0x92/0xb8 Code: 41 14 85 c0 89 44 24 14 0f 84 9d 02 00 00 f7 d0 01 d6 41 89 d5 89 41 14 8b 41 14 89 34 24 e9 7e 02 00 00 49 63 c5 49 8b 5c c6 48 <f6> 43 1a 80 4c 8b a3 20 37 00 00 0f 85 62 02 00 00 31 c9 41 83 RIP [<ffffffff806262c7>] mv_interrupt+0x21c/0x4cc RSP <ffff8102050bbec8> CR2: 000000000000001a ---[ end trace 2583b5f7a5350584 ]--- Kernel panic - not syncing: Aiee, killing interrupt handler! last_port already include port0 base. this patch change use last_port directly, and move pp assignment later. Signed-off-by: Yinghai Lu <yinghai.lu@sun.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-11libata: ignore deverr on SETXFER if mode is configuredTejun Heo
Some controllers (VIA CX700) raise device error on SETXFER even after mode configuration succeeded. Update ata_dev_set_mode() such that device error is ignored if transfer mode is configured correctly. To implement this, device is revalidated even after device error on SETXFER. This fixes kernel bugzilla bug 8563. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-11pata_via: fix SATA cable detection on cx700Tejun Heo
The first port of cx700 is SATA. Fix cable detection. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-11[SCSI] fas216: Use scsi_eh API for REQUEST_SENSE invocationBoaz Harrosh
Use new scsi_eh_prep/restor_cmnd() for synchronous REQUEST_SENSE invocation. This also converts the driver to the new accessor based scatterlist implementation. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Tested-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-11[SCSI] ses: fix memory leaksYinghai Lu
fix leaking with scomp leaking when failing. Also free page10 on driver removal and remove one extra space. Signed-off-by: Yinghai Lu <yinghai.lu@sun.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-11[SCSI] aacraid: informational sysfs value correctionsSalyzyn, Mark
Some sysfs problems reported. The serial number on late model controllers was truncated. Non-DASD devices (tapes and CDROMs) were showing up as JBOD in the level report on the physical channel. Signed-off-by: Mark Salyzyn <aacraid@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-11[SCSI] mpt fusion: Request I/O resources only when requiredPrakash, Sathya
This patch modifies the I/O resource allocation behavior of FUSION driver. The current version of driver allocates the I/O resources even if they are not required and this creates trouble in low resource environments. This driver now uses pci_enable_device_mem/pci_enable_device functions to differentiate the resource allocations. Signed-off-by: Sathya Prakash <sathya.prakash@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-11[SCSI] aacraid: ignore adapter reset check polaritySalyzyn, Mark
The Adapter's Ignore Reset flag and insmod parameter boolean polarity is incorrect in the driver. Signed-off-by: Mark Salyzyn <aacraid@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-11[SCSI] aacraid: add optional MSI supportSalyzyn, Mark
Added support for MSI utilizing the aacraid.msi=1 parameter. This patch adds some localized or like-minded janitor fixes. Since the default is disabled, there is no impact on the code paths unless the customer wishes to experiment with the MSI performance. Signed-off-by: Mark Salyzyn <aacraid@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-11[SCSI] mpt fusion: Avoid racing when mptsas and mptcl module are loaded in ↵Prakash, Sathya
parallel This patch sets the IOC pointer in drvrdata of pcidev before adding the IOC into the list of IOCs. Without this patch the driver oops when the mptsas and mptctl modules are loaded in parallel. Signed-off-by: Sathya Prakash <sathya.prakash@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-11[SCSI] MegaRAID driver management char device moved to miscThomas Horsten
The MegaRAID driver's common management module (megaraid_mm.c) creates a char device used by the management tool "megarc" from LSI Logic (and possibly other management tools). In 2.6 with udev, this device doesn't get created because it is not registered in sysfs. I first fixed this by registering a class "megaraid_mm", but realized that this should probably be moved to misc devices, instead of taking up a char major. This is because only 1 device is used, even if there are multiple adapters - the minor is never used (the adapter info is in the ioctl block sent to the driver, not detected based on the minor number as one might think). So it is a complete waste to have an entire major taken by this. So it now uses a misc device which I named "megadev0" (the name that megarc expects), and has a dynamic minor (previoulsy a dynamic major was used). I have tested this on my own system with the megarc tool, and it works just as fine as before (only now the device gets created correctly by udev). Acked-by: "Patro, Sumant" <Sumant.Patro@lsi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-11[SCSI] advansys: fix overrun_buf aligned bugFUJITA Tomonori
struct asc_dvc_var needs overrun buffer to be placed on an 8 byte boundary. advansys defines struct asc_dvc_var: struct asc_dvc_var { ... uchar overrun_buf[ASC_OVERRUN_BSIZE] __aligned(8); The problem is that struct asc_dvc_var is placed on shost->hostdata. So if the hostdata is not on an 8 byte boundary, the advansys crashes. The hostdata is placed on a sizeof(unsigned long) boundary so the 8 byte boundary is not garanteed with x86_32. With 2.6.23 and 2.6.24, the hostdata is on an 8 byte boundary by chance, but with the current git, it's not. This patch removes overrun_buf static array and use kzalloc. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-11ide: remove stale comment from ide-lib.cBartlomiej Zolnierkiewicz
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-11ide: fix comment in init_irq()Bartlomiej Zolnierkiewicz
APUS support is gone... Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-11ide: ide_init_port() bugfixBartlomiej Zolnierkiewicz
On Sunday 10 February 2008, Atsushi Nemoto wrote: > On Sun, 06 Jan 2008 18:03:10 +0100, Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> wrote: > > + /* reset DMA masks only for SFF-style DMA controllers */ > > + if ((d->host_flags && IDE_HFLAG_NO_DMA) == 0 && hwif->dma_base == 0) > > + hwif->swdma_mask = hwif->mwdma_mask = hwif->ultra_mask = 0; > > It might be too late, but "host_flags && IDE_HFLAGS_NO_DMA" seems > wrong for me. Fix regression caused by commmit c413b9b94d9a8e7548cc4b2e04b7df0439ce76fd ("ide: add struct ide_port_info instances to legacy host drivers"). Reported-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-11ide-disk: fix flush requests (take 2)Bartlomiej Zolnierkiewicz
commit 813a0eb233ee67d7166241a8b389b6a76f2247f9 Author: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Date: Fri Jan 25 22:17:10 2008 +0100 ide: switch idedisk_prepare_flush() to use REQ_TYPE_ATA_TASKFILE requests ... broke flush requests. Allocating IDE command structure on the stack for flush requests is not a very brilliant idea: - idedisk_prepare_flush() only prepares the request and it doesn't wait for it to be completed - there are can be multiple flush requests queued in the queue Fix the problem (per hints from James Bottomley) by: - dynamically allocating ide_task_t instance using kmalloc(..., GFP_ATOMIC) - adding new taskfile flag (IDE_TFLAG_DYN) - calling kfree() in ide_end_drive_command() if IDE_TFLAG_DYN is set (while at it rename 'args' to 'task' and fix whitespace damage) [ This will be fixed properly before 2.6.25 but this bug is rather critical and the proper solution requires some more work + testing. ] Thanks to Sebastian Siewior and Christoph Hellwig for reporting the problem and testing patches (extra thanks to Sebastian for bisecting it to the guilty commmit). Tested-by: Sebastian Siewior <ide-bug@ml.breakpoint.cc> Cc: Christoph Hellwig <hch@infradead.org> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Tejun Heo <htejun@gmail.com> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-11ide: introduce CONFIG_BLK_DEV_IDEDMA_SFF optionSergei Shtylyov
Introduce new option CONFIG_BLK_DEV_IDEDMA_SFF for non-PCI SFF-8038i compatible bus mastering IDE controllers (which there are a few known), thus fixing a hack made for Palmchip BK3710 controller... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Anton Salnikov <asalnikov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-11bast-ide: build fixBartlomiej Zolnierkiewicz
On Saturday 09 February 2008, Adrian Bunk wrote: > Commit 9e016a719209d95338e314b46c3012cc7feaaeec causes the following > compile error: > > <-- snip --> > > ... > CC drivers/ide/arm/bast-ide.o > /home/bunk/linux/kernel-2.6/git/linux-2.6/drivers/ide/arm/bast-ide.c: In function 'bastide_register': > /home/bunk/linux/kernel-2.6/git/linux-2.6/drivers/ide/arm/bast-ide.c:31: error: 'hwif' redeclared as different kind of symbol > /home/bunk/linux/kernel-2.6/git/linux-2.6/drivers/ide/arm/bast-ide.c:29: error: previous definition of 'hwif' was here > make[4]: *** [drivers/ide/arm/bast-ide.o] Error 1 > > <-- snip --> Remove 'ide_hwif_t **hwif' argument from bastide_register() (together with write-only ifs[]). Cc: Adrian Bunk <bunk@kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-11ide-tape: remove never executed codeBartlomiej Zolnierkiewicz
rq->cmd[0] is never set to REQ_IDETAPE_READ_BUFFER so remove REQ_IDETAPE_READ_BUFFER handling from idetape_create_write_cmd() and the define itself. Then remove no longer used idetape_create_read_buffer_cmd() and IDETAPE_RETRIEVE_FAULTY_BLOCK define. There should be no functional changes caused by this patch. Cc: Borislav Petkov <petkovbb@gmail.com> Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-02-11ide: fix ide/legacy/gayle.c compilationAdrian Bunk
Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
