path: root/drivers
2010-06-03i2c: Remove all i2c_set_clientdata(client, NULL) in driversWolfram Sang
I2C drivers can use the clientdata-pointer to point to private data. As I2C devices are not really unregistered, but merely detached from their driver, it used to be the drivers obligation to clear this pointer during remove() or a failed probe(). As a couple of drivers forgot to do this, it was agreed that it was cleaner if the i2c-core does this clearance when appropriate, as there is no guarantee for the lifetime of the clientdata-pointer after remove() anyhow. This feature was added to the core with commit e4a7b9b04de15f6b63da5ccdd373ffa3057a3681 to fix the faulty drivers. As there is no need anymore to clear the clientdata-pointer, remove all current occurrences in the drivers to simplify the code and prevent confusion. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Richard Purdie <rpurdie@linux.intel.com> Acked-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-06-03i2c/busses: Move two drivers to embedded sectionWolfram Sang
And fix a typo while we are here Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-06-03i2c: Rename i2c_check_addr to i2c_check_addr_busyJean Delvare
Otherwise it's not clear what it is checking. Also move the function to save a forward declaration. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-06-03i2c: Document reserved I2C addressesJean Delvare
Move strict I2C address validity check to a single function, and document the reserved I2C addresses there. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Hans Verkuil <hverkuil@xs4all.nl>
2010-06-03i2c: Check for address validity on client registrationJean Delvare
Do basic address validity checks when a client is being registered. We already had checks in place for devices which are being detected, but not for devices which are simply instantiated. This is a very basic check. We don't want to do strict checking here because some devices are known to infringe the I2C address constraints (e.g. IR receivers at 7-bit address 0x7a while this value is supposedly reserved for 10-bit addresses.) So we assume the caller knows what it is doing. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Matthieu Castet <castet.matthieu@free.fr>
2010-06-03i2c: Share the I2C device presence detection codeJean Delvare
Use the same I2C device presence detection code for legacy and new device detection functions. This is more consistent and makes the code smaller. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Matthieu Castet <castet.matthieu@free.fr>
2010-06-01Merge branch 'drm-intel-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/anholt/drm-intel * 'drm-intel-next' of git://git.kernel.org/pub/scm/linux/kernel/git/anholt/drm-intel: (41 commits) drm/i915: add HAS_BSD check to i915_getparam drm/i915: Honor sync polarity from VBT panel timing descriptors drm/i915: Unmask interrupt for render engine on Sandybridge drm/i915: Fix PIPE_CONTROL command on Sandybridge drm/i915: Fix up address spaces in slow_kernel_write() drm/i915: Use non-atomic kmap for slow copy paths drm/i915: Avoid moving from CPU domain during pwrite drm/i915: Cleanup after failed initialization of ringbuffers drm/i915: Reject bind_to_gtt() early if object > aperture drm/i915: Check error code whilst moving buffer to GTT domain. drm/i915: Remove spurious warning "Failure to install fence" drm/i915: Rebind bo if currently bound with incorrect alignment. drm/i915: Include pitch in set_base debug statement. drm/i915: Only print "nothing to do" debug message as required. drm/i915: Propagate error from unbinding an unfenceable object. drm/i915: Avoid nesting of domain changes when setting display plane drm/i915: Hold the spinlock whilst resetting unpin_work along error path drm/i915: Only print an message if there was an error drm/i915: Clean up leftover bits from hws move to ring structure. drm/i915: Add CxSR support on Pineview DDR3 ...
2010-06-01drm/i915: add HAS_BSD check to i915_getparamZou Nan hai
This will let userland only try to use the new media decode functionality when the appropriate kernel is present. Signed-off-by: Zou Nan hai <nanhai.zou@intel.com> Signed-off-by: Eric Anholt <eric@anholt.net>
2010-06-01drm/i915: Honor sync polarity from VBT panel timing descriptorsAdam Jackson
I'm actually kind of shocked that it works at all otherwise. Signed-off-by: Adam Jackson <ajax@redhat.com> Signed-off-by: Eric Anholt <eric@anholt.net>
2010-06-01intel_scu_ipc: Length fixAlan Cox
Commands with data must set the length in the message. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-06-01drivers/isdn/hardware/mISDN: Use GFP_ATOMIC when a lock is heldJulia Lawall
The function inittiger is only called from nj_init_card, where a lock is held. The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @gfp exists@ identifier fn; position p; @@ fn(...) { ... when != spin_unlock_irqrestore when any GFP_KERNEL@p ... when any } @locked@ identifier gfp.fn; @@ spin_lock_irqsave(...) ... when != spin_unlock_irqrestore fn(...) @depends on locked@ position gfp.p; @@ - GFP_KERNEL@p + GFP_ATOMIC // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-01ksz884x: Add missing validate_addr hookDenis Kirjanov
Add missing validate_addr hook Signed-off-by: Denis Kirjanov <dkirjanov@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-01ksz884x: convert to netdev_tx_tDenis Kirjanov
Convert TX hook to netdev_tx_t type Signed-off-by: Denis Kirjanov <dkirjanov@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-01virtio-net: pass gfp to add_bufMichael S. Tsirkin
virtio-net bounces buffer allocations off to a thread if it can't allocate buffers from the atomic pool. However, if posting buffers still requires atomic buffers, this is unlikely to succeed. Fix by passing in the proper gfp_t parameter. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-01be2net: convert hdr.timeout in be_cmd_loopback_test() to le32Sathya Perla
The current code fails on ppc as hdr.timeout is not being converted to le32. Signed-off-by: Sathya Perla <sathyap@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-01can: mpc5xxx_can.c: Fix build failureAnatolij Gustschin
Fixes build error caused by the OF device_node pointer being moved into struct device. Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Wolfgang Grandegger <wg@grandegger.com> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-31greth: Fix build after OF device conversions.David S. Miller
2010-05-31Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
2010-05-30Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (47 commits) mfd: Rename twl5031 sih modules mfd: Storage class for timberdale should be before const qualifier mfd: Remove unneeded and dangerous clearing of clientdata mfd: New AB8500 driver gpio: Fix inverted rdc321x gpio data out registers mfd: Change rdc321x resources flags to IORESOURCE_IO mfd: Move pcf50633 irq related functions to its own file. mfd: Use threaded irq for pcf50633 mfd: pcf50633-adc: Fix potential race in pcf50633_adc_sync_read mfd: Fix pcf50633 bitfield logic in interrupt handler gpio: rdc321x needs to select MFD_CORE mfd: Use menuconfig for quicker config editing ARM: AB3550 board configuration and irq for U300 mfd: AB3550 core driver mfd: AB3100 register access change to abx500 API mfd: Renamed ab3100.h to abx500.h gpio: Add TC35892 GPIO driver mfd: Add Toshiba's TC35892 MFD core mfd: Delay to mask tsc irq in max8925 mfd: Remove incorrect wm8350 kfree ...
2010-05-30Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: DMAENGINE: DMA40 U8500 platform configuration DMA: PL330: Add dma api driver
2010-05-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: IB/qib: Remove DCA support until feature is finished IB/qib: Use a single txselect module parameter for serdes tuning IB/qib: Don't rely on (undefined) order of function parameter evaluation IB/ucm: Use memdup_user() IB/qib: Fix undefined symbol error when CONFIG_PCI_MSI=n
2010-05-30Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: quota: Convert quota statistics to generic percpu_counter ext3 uses rb_node = NULL; to zero rb_root. quota: Fixup dquot_transfer reiserfs: Fix resuming of quotas on remount read-write pohmelfs: Remove dead quota code ufs: Remove dead quota code udf: Remove dead quota code quota: rename default quotactl methods to dquot_ quota: explicitly set ->dq_op and ->s_qcop quota: drop remount argument to ->quota_on and ->quota_off quota: move unmount handling into the filesystem quota: kill the vfs_dq_off and vfs_dq_quota_on_remount wrappers quota: move remount handling into the filesystem ocfs2: Fix use after free on remount read-only Fix up conflicts in fs/ext4/super.c and fs/ufs/file.c
2010-05-30rapidio: fix new kernel-doc warningsRandy Dunlap
Fix a bunch of new rapidio kernel-doc warnings: Warning(include/linux/rio.h:123): No description found for parameter 'comp_tag' Warning(include/linux/rio.h:123): No description found for parameter 'phys_efptr' Warning(include/linux/rio.h:123): No description found for parameter 'em_efptr' Warning(include/linux/rio.h:123): No description found for parameter 'pwcback' Warning(include/linux/rio.h:247): No description found for parameter 'set_domain' Warning(include/linux/rio.h:247): No description found for parameter 'get_domain' Warning(drivers/rapidio/rio-scan.c:1133): No description found for parameter 'rdev' Warning(drivers/rapidio/rio-scan.c:1133): Excess function parameter 'port' description in 'rio_init_em' Warning(drivers/rapidio/rio.c:349): No description found for parameter 'rdev' Warning(drivers/rapidio/rio.c:349): Excess function parameter 'mport' description in 'rio_request_inb_pwrite' Warning(drivers/rapidio/rio.c:393): No description found for parameter 'port' Warning(drivers/rapidio/rio.c:393): No description found for parameter 'local' Warning(drivers/rapidio/rio.c:393): No description found for parameter 'destid' Warning(drivers/rapidio/rio.c:393): No description found for parameter 'hopcount' Warning(drivers/rapidio/rio.c:393): Excess function parameter 'rdev' description in 'rio_mport_get_physefb' Warning(drivers/rapidio/rio.c:845): Excess function parameter 'local' description in 'rio_std_route_clr_table' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Alexandre Bounine <alexandre.bounine@idt.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-29be2net: remove superfluous externsDan Carpenter
This fixes some sparse warnings: drivers/net/benet/be_cmds.c:1503:12: warning: function 'be_cmd_enable_magic_wol' with external linkage has definition drivers/net/benet/be_cmds.c:1668:12: warning: function 'be_cmd_get_seeprom_data' with external linkage has definition Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Sarveshwar Bandi <sarveshwarb@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-29be2net: add unlock on error pathDan Carpenter
The unlock accidentally got removed from the error path in dd131e76e5: "be2net: Bug fix to avoid disabling bottom half during firmware upgrade." Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Sarveshwar Bandi <sarveshwarb@serverengines.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-29drivers/isdn/hardware/mISDN: Add missing spin_unlockJulia Lawall
Add a spin_unlock missing on the error path. The return value of write_reg seems to be completely ignored, so it seems that the lock should be released in every case. The semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression E1; @@ * spin_lock(E1,...); <+... when != E1 if (...) { ... when != E1 * return ...; } ...+> * spin_unlock(E1,...); // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-29fs_enet: Adjust BDs after tx errorMark Ware
This patch fixes an occasional transmit lockup in the mac-fcc which occurs after a tx error. The test scenario had the local port set to autoneg and the other end fixed at 100FD, resulting in a large number of late collisions. According to the MPC8280RM 30.10.1.3 (also 8272RM 29.10.1.3), after a tx error occurs, TBPTR may sometimes point beyond BDs still marked as ready. This patch walks back through the BDs and points TBPTR to the earliest one marked as ready. Tested on a custom board with a MPC8280. Signed-off-by: Mark Ware <mware@elphinstone.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-28Merge branch 'master' of ↵David S. Miller
2010-05-28Merge branch 'drm-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: drm/radeon: fix the r100/r200 ums block 0 page fix
2010-05-28Merge branch 'idle-release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6 * 'idle-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6: intel_idle: native hardware cpuidle driver for latest Intel processors ACPI: acpi_idle: touch TS_POLLING only in the non-MWAIT case acpi_pad: uses MONITOR/MWAIT, so it doesn't need to clear TS_POLLING sched: clarify commment for TS_POLLING ACPI: allow a native cpuidle driver to displace ACPI cpuidle: make cpuidle_curr_driver static cpuidle: add cpuidle_unregister_driver() error check cpuidle: fail to register if !CONFIG_CPU_IDLE
2010-05-28Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (27 commits) ACPI: Don't let acpi_pad needlessly mark TSC unstable drivers/acpi/sleep.h: Checkpatch cleanup ACPI: Minor cleanup eliminating redundant PMTIMER_TICKS to NS conversion ACPI: delete unused c-state promotion/demotion data strucutures ACPI: video: fix acpi_backlight=video ACPI: EC: Use kmemdup drivers/acpi: use kasprintf ACPI, APEI, EINJ injection parameters support Add x64 support to debugfs ACPI, APEI, Use ERST for persistent storage of MCE ACPI, APEI, Error Record Serialization Table (ERST) support ACPI, APEI, Generic Hardware Error Source memory error support ACPI, APEI, UEFI Common Platform Error Record (CPER) header Unified UUID/GUID definition ACPI Hardware Error Device (PNP0C33) support ACPI, APEI, PCIE AER, use general HEST table parsing in AER firmware_first setup ACPI, APEI, Document for APEI ACPI, APEI, EINJ support ACPI, APEI, HEST table parsing ACPI, APEI, APEI supporting infrastructure ...
2010-05-29drm/radeon: fix the r100/r200 ums block 0 page fixDave Airlie
airlied -> brown paper bag. I blame Hi-5 or the Wiggles for lowering my IQ, move the fix inside some brackets instead of breaking everything in site. Cc: stable@kernel.org Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-05-28Merge branch 'ht-delete-2.6.35' into releaseLen Brown
2010-05-28Merge branch 'misc-2.6.35' into releaseLen Brown
2010-05-28Merge branches 'video' and 'video-edid' into releaseLen Brown
2010-05-28Merge branch 'acpi_enable' into releaseLen Brown
2010-05-28Merge branch 'bjorn-pci-root-v4-2.6.35' into releaseLen Brown
2010-05-28ACPI: Don't let acpi_pad needlessly mark TSC unstableVenkatesh Pallipadi
acpi pad driver kind of aggressively marks TSC as unstable at init time, on mwait capable and non X86_FEATURE_NONSTOP_TSC systems. This is irrespective of whether pad driver is ever going to be used on the system or deep C-states are supported/used. This will affect every user who just happens to compile in (or get a kernel version which compiles in) acpi pad driver. Move mark_tsc_unstable() out of init to the actual idle invocation path of the pad driver. There is also another bug/missing_feature in the code that it does not support 'always running apic timer' and switches to broadcast mode unconditionally. Shaohua, can you take a look at that please. Signed-off-by: Venkatesh Pallipadi <venki@google.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-05-28drivers/acpi/sleep.h: Checkpatch cleanupAndrea Gelmini
drivers/acpi/sleep.h:3: WARNING: space prohibited between function name and open parenthesis '(' Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net> Signed-off-by: Len Brown <len.brown@intel.com>
2010-05-28ACPI: Minor cleanup eliminating redundant PMTIMER_TICKS to NS conversionVenkatesh Pallipadi
acpi_enter_[simple,bm] does idle timing in ns, convert it to timeval, then to us, then to pmtimer_ticks and then back to ns. This patch changes things to idle timing in ns, convert it to us, and then to pmtimer_ticks. Just saves an imul along this path, but makes the code cleaner. Signed-off-by: Venkatesh Pallipadi <venki@google.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-05-28intel_idle: native hardware cpuidle driver for latest Intel processorsLen Brown
This EXPERIMENTAL driver supersedes acpi_idle on Intel Atom Processors, Intel Core i3/i5/i7 Processors and associated Intel Xeon processors. It does not support the Intel Core2 processor or earlier. For kernels configured with ACPI, CONFIG_INTEL_IDLE=y allows intel_idle to probe before the ACPI processor driver. Booting with "intel_idle.max_cstate=0" disables intel_idle and the system will fall back on ACPI's "acpi_idle". Typical Linux distributions load ACPI processor module early, making CONFIG_INTEL_IDLE=m not easily useful on ACPI platforms. intel_idle probes all processors at module_init time. Processors that are hot-added later will be limited to using C1 in idle. Signed-off-by: Len Brown <len.brown@intel.com>
2010-05-28drm/i915: Unmask interrupt for render engine on SandybridgeZhenyu Wang
With splitted engines on Sandybridge, each engine has its own interrupt control as well. This unmasks the interrupt to properly enable pipe control notify event for render engine. Signed-off-by: Zhenyu Wang <zhenyuw@linux.intel.com> Signed-off-by: Eric Anholt <eric@anholt.net>
2010-05-28drm/i915: Fix PIPE_CONTROL command on SandybridgeZhenyu Wang
Sandybridge(Gen6) has new format for PIPE_CONTROL command, the flush and post-op control are in dword 1 now. This changes command length field for difference between Ironlake and Sandybridge. I tried to test this with noop request and issue PIPE_CONTROL command for each sequence and track notify interrupts, which seems work fine. Hopefully we don't need workaround like on Ironlake for Sandybridge. Signed-off-by: Zhenyu Wang <zhenyuw@linux.intel.com> Signed-off-by: Eric Anholt <eric@anholt.net>
2010-05-28drm/i915: Fix up address spaces in slow_kernel_write()Chris Wilson
Since we now get_user_pages() outside of the mutex prior to performing the copy, we kmap() the page inside the copy routine and so need to perform an ordinary memcpy() and not copy_from_user(). Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Eric Anholt <eric@anholt.net>
2010-05-28drm/i915: Use non-atomic kmap for slow copy pathsChris Wilson
As we do not have a requirement to be atomic and avoid sleeping whilst performing the slow copy for shmem based pread and pwrite, we can use kmap instead, thus simplifying the code. Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Eric Anholt <eric@anholt.net>
2010-05-28drm/i915: Avoid moving from CPU domain during pwriteChris Wilson
We can avoid an early clflush when pwriting if we use the current CPU write domain rather than moving the object to the GTT domain for the purposes of the pwrite. This has the advantage of not flushing the presumably hot data that we want to upload into the bo, and of ascribing the clflush to the execution when profiling. Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Eric Anholt <eric@anholt.net>
2010-05-28drm/i915: Cleanup after failed initialization of ringbuffersChris Wilson
The callers expect us to cleanup any partially initialised structures before reporting the error. Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Eric Anholt <eric@anholt.net>
2010-05-28ACPI: acpi_idle: touch TS_POLLING only in the non-MWAIT caseLen Brown
commit d306ebc28649b89877a22158fe0076f06cc46f60 (ACPI: Be in TS_POLLING state during mwait based C-state entry) fixed an important power & performance issue where ACPI c2 and c3 C-states were clearing TS_POLLING even when using MWAIT (ACPI_STATE_FFH). That bug had been causing us to receive redundant scheduling interrups when we had already been woken up by MONITOR/MWAIT. Following up on that... In the MWAIT case, we don't have to subsequently check need_resched(), as that c heck was there for the TS_POLLING-clearing case. Note that not only does the cpuidle calling function already check need_resched() before calling us, the low-level entry into monitor/mwait calls it twice -- guaranteeing that a write to the trigger address can not go un-noticed. Also, in this case, we don't have to set TS_POLLING when we wake, because we never cleared it. Signed-off-by: Len Brown <len.brown@intel.com> Acked-by: Venkatesh Pallipadi <venki@google.com>
2010-05-28ssb: fix NULL ptr deref when pcihost_wrapper is usedChristoph Fritz
Ethernet driver b44 does register ssb by it's pcihost_wrapper and doesn't set ssb_chipcommon. A check on this value introduced with commit d53cdbb94a52a920d5420ed64d986c3523a56743 and ea2db495f92ad2cf3301623e60cb95b4062bc484 triggers: BUG: unable to handle kernel NULL pointer dereference at 00000010 IP: [<c1266c36>] ssb_is_sprom_available+0x16/0x30 Signed-off-by: Christoph Fritz <chf.fritz@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-05-28drm/i915: Reject bind_to_gtt() early if object > apertureChris Wilson
If the object is bigger than the entire aperture, reject it early before evicting everything in a vain attempt to find space. v2: Use E2BIG as suggested by Owain G. Ainsworth. Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: stable@kernel.org Signed-off-by: Eric Anholt <eric@anholt.net>
