path: root/drivers
2011-04-22Merge branch 'tty-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: tty/n_gsm: fix bug in CRC calculation for gsm1 mode serial/imx: read cts state only after acking cts change irq parport_pc.c: correctly release the requested region for the IT887x
2011-04-21Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: ide: unexport DISK_EVENT_MEDIA_CHANGE for ide-gd and ide-cd block: don't propagate unlisted DISK_EVENTs to userland elevator: check for ELEVATOR_INSERT_SORT_MERGE in !elvpriv case too
2011-04-21ide: unexport DISK_EVENT_MEDIA_CHANGE for ide-gd and ide-cdTejun Heo
check_events() implementations in both ide-gd and ide-cd are inadequate for in-kernel event polling. Both generate media change events continuously when certain conditions are met causing infinite event loop between the driver and userland event handler. As disk event now supports suppression of unlisted events, simply de-listing DISK_EVENT_MEDIA_CHANGE from disk->events resolves the problem. Internal handling around media revalidation will behave the same while userland will fall back to userland event polling after detecting the device doesn't support disk events. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Jens Axboe <jaxboe@fusionio.com> Acked-by: "David S. Miller" <davem@davemloft.net> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-04-21raid5: fix build error, sector_t usageRandy Dunlap
Change <sectors> from unsigned long long to sector_t. This matches its source field. ERROR: "__udivdi3" [drivers/md/raid456.ko] undefined! Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: virtio: console: Enable call to hvc_remove() on console port remove virtio_pci: Prevent double-free of pci regions after device hot-unplug virtio: Decrement avail idx on buffer detach
2011-04-21Merge branch 'drm-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: agp: fix arbitrary kernel memory writes agp: fix OOM and buffer overflow drm/radeon/kms: fix IH writeback on r6xx+ on big endian machines
2011-04-21Merge branch 'drm-intel-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/keithp/linux-2.6 * 'drm-intel-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/keithp/linux-2.6: drm/i915: Initialise g4x watermarks for disabled pipes drm/i915: Sanitize the output registers after resume drm/i915/tv: Fix modeset flickering introduced in 7f58aabc3 drm/i915/tv: Only poll for TV connections drm/i915/tv: Remember the detected TV type
2011-04-21Merge git://git.infradead.org/iommu-2.6Linus Torvalds
* git://git.infradead.org/iommu-2.6: intel_iommu: disable all VT-d PMRs when TXT launched intel-iommu: Fix get_domain_for_dev() error path intel-iommu: Unlink domain from iommu intel-iommu: Fix use after release during device attach
2011-04-21virtio: console: Enable call to hvc_remove() on console port removeAmit Shah
This call was disabled as hot-unplugging one virtconsole port led to another virtconsole port freezing. Upon testing it again, this now works, so enable it. In addition, a bug was found in qemu wherein removing a port of one type caused the guest output from another port to stop working. I doubt it was just this bug that caused it (since disabling the hvc_remove() call did allow other ports to continue working), but since it's all solved now, we're fine with hot-unplugging of virtconsole ports. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-04-21virtio_pci: Prevent double-free of pci regions after device hot-unplugAmit Shah
In the case where a virtio-console port is in use (opened by a program) and a virtio-console device is removed, the port is kept around but all the virtio-related state is assumed to be gone. When the port is finally released (close() called), we call device_destroy() on the port's device. This results in the parent device's structures to be freed as well. This includes the PCI regions for the virtio-console PCI device. Once this is done, however, virtio_pci_release_dev() kicks in, as the last ref to the virtio device is now gone, and attempts to do pci_iounmap(pci_dev, vp_dev->ioaddr); pci_release_regions(pci_dev); pci_disable_device(pci_dev); which results in a double-free warning. Move the code that releases regions, etc., to the virtio_pci_remove() function, and all that's now left in release_dev is the final freeing of the vp_dev. Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-04-21virtio: Decrement avail idx on buffer detachAmit Shah
When detaching a buffer from a vq, the avail.idx value should be decremented as well. This was noticed by hot-unplugging a virtio console port and then plugging in a new one on the same number (re-using the vqs which were just 'disowned'). qemu reported 'Guest moved used index from 0 to 256' when any IO was attempted on the new port. CC: stable@kernel.org Reported-by: juzhang <juzhang@redhat.com> Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-04-21intel_iommu: disable all VT-d PMRs when TXT launchedJoseph Cihula
Intel VT-d Protected Memory Regions (PMRs) are supposed to be disabled, on each VT-d engine, after DMA remapping is enabled on the engines. This is because the behavior of having both enabled is not deterministic and because, if TXT has been used to launch the kernel, the PMRs may be programmed to cover memory regions that will be used for DMA. Under some circumstances (certain quirks detected, lack of multiple devices, etc.), the current code does not set up DMA remapping on some VT-d engines. In such cases it also skips disabling the PMRs. This causes failures when the kernel is launched with TXT (most often this occurs on the graphics engine and results in colored vertical bars on the display). This patch detects when the kernel has been launched with TXT and then disables the PMRs on all VT-d engines. In some cases where the reason that remapping is not being enabled is due to possible ACPI DMAR table errors, the VT-d engine addresses may not be correct and thus not able to be safely programmed even to disable PMRs. Because part of the TXT launch process is the verification of these addresses, it will always be safe to disable PMRs if the TXT launch has succeeded and hence only doing this in such cases. Signed-off-by: Joseph Cihula <joseph.cihula@intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-04-21agp: fix arbitrary kernel memory writesVasiliy Kulikov
pg_start is copied from userspace on AGPIOC_BIND and AGPIOC_UNBIND ioctl cmds of agp_ioctl() and passed to agpioc_bind_wrap(). As said in the comment, (pg_start + mem->page_count) may wrap in case of AGPIOC_BIND, and it is not checked at all in case of AGPIOC_UNBIND. As a result, user with sufficient privileges (usually "video" group) may generate either local DoS or privilege escalation. Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-04-21agp: fix OOM and buffer overflowVasiliy Kulikov
page_count is copied from userspace. agp_allocate_memory() tries to check whether this number is too big, but doesn't take into account the wrap case. Also agp_create_user_memory() doesn't check whether alloc_size is calculated from num_agp_pages variable without overflow. This may lead to allocation of too small buffer with following buffer overflow. Another problem in agp code is not addressed in the patch - kernel memory exhaustion (AGPIOC_RESERVE and AGPIOC_ALLOCATE ioctls). It is not checked whether requested pid is a pid of the caller (no check in agpioc_reserve_wrap()). Each allocation is limited to 16KB, though, there is no per-process limit. This might lead to OOM situation, which is not even solved in case of the caller death by OOM killer - the memory is allocated for another (faked) process. Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-04-20Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging: hwmon: (max34440) Add driver documentation hwmon: (max16064) Add driver documentation hwmon: (max8688) Add driver documentation hwmon: (pmbus) Documentation updates hwmon: (smm665) Fix spelling error in driver documentation hwmon: (pmbus) Removed unused variable from struct pmbus_data hwmon: Add submitting-patches checklist to documentation
2011-04-20Merge branch 'for-linus' of git://neil.brown.name/mdLinus Torvalds
* 'for-linus' of git://neil.brown.name/md: md: Update documentation for sync_min and sync_max entries md: Cleanup after raid45->raid0 takeover md: Fix dev_sectors on takeover from raid0 to raid4/5 md/raid5: remove setting of ->queue_lock
2011-04-20Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: block: Remove the extra check in queue_requests_store block, blk-sysfs: Fix an err return path in blk_register_queue() block: remove stale kerneldoc member from __blk_run_queue() block: get rid of QUEUE_FLAG_REENTER cfq-iosched: read_lock() does not always imply rcu_read_lock() block: kill blk_flush_plug_list() export
2011-04-20md: Cleanup after raid45->raid0 takeoverKrzysztof Wojcik
Problem: After raid4->raid0 takeover operation, another takeover operation (e.g raid0->raid10) results "kernel oops". Root cause: Variables 'degraded' in mddev structure is not cleared on raid45->raid0 takeover. This patch reset this variable. Signed-off-by: Krzysztof Wojcik <krzysztof.wojcik@intel.com> Signed-off-by: NeilBrown <neilb@suse.de>
2011-04-20md: Fix dev_sectors on takeover from raid0 to raid4/5NeilBrown
A raid0 array doesn't set 'dev_sectors' as each device might contribute a different number of sectors. So when converting to a RAID4 or RAID5 we need to set dev_sectors as they need the number. We have already verified that in fact all devices do contribute the same number of sectors, so use that number. Signed-off-by: NeilBrown <neilb@suse.de>
2011-04-20md/raid5: remove setting of ->queue_lockNeilBrown
We previously needed to set ->queue_lock to match the raid5 device_lock so we could safely use queue_flag_* operations (e.g. for plugging). which test the ->queue_lock is in fact locked. However that need has completely gone away and is unlikely to come back to remove this now-pointless setting. Signed-off-by: NeilBrown <neilb@suse.de>
2011-04-19Merge branch 'drm-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: drm/radeon/kms: pll tweaks for r7xx drm/nouveau: fix allocation of notifier object drm/nouveau: fix notifier memory corruption bug drm/nouveau: fix pinning of notifier block drm/nouveau: populate ttm_alloced with false, when it's not drm/nouveau: fix nv30 pcie boards drm/nouveau: split ramin_lock into two locks, one hardirq safe drm/radeon/kms: adjust evergreen display watermark setup drm/radeon/kms: add connectors even if i2c fails drm/radeon/kms: fix bad shift in atom iio table parser
2011-04-20drm/radeon/kms: fix IH writeback on r6xx+ on big endian machinesCédric Cano
agd5f: fix commit message. Signed-off-by: Cedric Cano <ccano@interfaceconcept.com> Reviewed-by: Michel Dänzer <michel@daenzer.net> Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-04-20drm/radeon/kms: pll tweaks for r7xxAlex Deucher
Prefer min m to max p only on pre-r7xx asics. Fixes: https://bugs.freedesktop.org/show_bug.cgi?id=36197 Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Cc: stable@kernel.org Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-04-19tty/n_gsm: fix bug in CRC calculation for gsm1 modeMikhail Kshevetskiy
Problem description: gsm_queue() calculate a CRC for arrived frames. As a last step of CRC calculation it call gsm->fcs = gsm_fcs_add(gsm->fcs, gsm->received_fcs); This work perfectly for the case of GSM0 mode as gsm->received_fcs contain the last piece of data required to generate final CRC. gsm->received_fcs is not used for GSM1 mode. Thus we put an additional byte to CRC calculation. As result we get a wrong CRC and reject incoming frame. Signed-off-by: Mikhail Kshevetskiy <mikhail.kshevetskiy@gmail.com> Acked-by: Alan Cox <alan@linux.intel.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-19serial/imx: read cts state only after acking cts change irqUwe Kleine-König
If cts changes between reading the level at the cts input (USR1_RTSS) and acking the irq (USR1_RTSD) the last edge doesn't generate an irq and uart_handle_cts_change is called with a outdated value for cts. The race was introduced by commit ceca629 ([ARM] 2971/1: i.MX uart handle rts irq) Reported-by: Arwed Springer <Arwed.Springer@de.trumpf.com> Tested-by: Arwed Springer <Arwed.Springer@de.trumpf.com> Cc: stable@kernel.org # 2.6.14+ Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-19parport_pc.c: correctly release the requested region for the IT887xNiels de Vos
Replace release_resource() by release_region() and also fix the inconsistency in the size of the requested/released region. The size of the resource should be 32, not 0x8 like it was corrected in commit e7c310c36e5fdf1b83a459e5db167bfbd86137db already. CC: linux-serial@vger.kernel.org Reported-by: Julia Lawall <julia@diku.dk> Signed-off-by: Niels de Vos <ndevos@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-20drm/nouveau: fix allocation of notifier objectMarcin Slusarz
Commit 73412c3854c877e5f37ad944ee8977addde4d35a ("drm/nouveau: allocate kernel's notifier object at end of block") intended to align end of notifier block to page boundary, but start of block was miscalculated to be off by -16 bytes. Fix it. Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Ben Skeggs <bskeggs@redhat.com> Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2011-04-20drm/nouveau: fix notifier memory corruption bugMarcin Slusarz
nouveau_bo_wr32 expects offset to be in words, but we pass value in bytes, so after commit 73412c3854c877e5f37ad944ee8977addde4d35a ("drm/nouveau: allocate kernel's notifier object at end of block") we started to overwrite some memory after notifier buffer object (previously m2mf_ntfy was always 0, so it didn't matter it was a value in bytes). Reported-by: Dominik Brodowski <linux@dominikbrodowski.net> Reported-by: Nigel Cunningham <lkml@nigelcunningham.com.au> Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Ben Skeggs <bskeggs@redhat.com> Cc: Pekka Paalanen <pq@iki.fi> Cc: stable@kernel.org [2.6.38] Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2011-04-20drm/nouveau: fix pinning of notifier blockBen Skeggs
Problem introduced with commit 6ba9a68317781537d6184d3fdb2d0f20c97da3a4 Reported-by: Bob Gleitsmann <rjgleits@bellsouth.net> Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2011-04-20drm/nouveau: populate ttm_alloced with false, when it's notBen Skeggs
Caught with kmemcheck on unrelated business. Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2011-04-20drm/nouveau: fix nv30 pcie boardsBen Skeggs
Wasn't aware they even existed, apparently they do! They're actually AGP chips with a bridge as far as I can tell, which puts them in the same boat as nv40/nv45. Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2011-04-20drm/nouveau: split ramin_lock into two locks, one hardirq safeBen Skeggs
Fixes a possible lock ordering reversal between context_switch_lock and ramin_lock. Signed-off-by: Ben Skeggs <bskeggs@redhat.com> Reviewed-by: Francisco Jerez <currojerez@riseup.net>
2011-04-19Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (51 commits) netfilter: ipset: Fix the order of listing of sets ip6_pol_route panic: Do not allow VLAN on loopback bnx2x: Fix port identification problem r8169: add Realtek as maintainer. ip: ip_options_compile() resilient to NULL skb route bna: fix memory leak during RX path cleanup bna: fix for clean fw re-initialization usbnet: Fix up 'FLAG_POINTTOPOINT' and 'FLAG_MULTI_PACKET' overlaps. iwlegacy: fix tx_power initialization Revert "tcp: disallow bind() to reuse addr/port" qlcnic: limit skb frags for non tso packet net: can: mscan: fix build breakage in mpc5xxx_can netfilter: ipset: set match and SET target fixes netfilter: ipset: bitmap:ip,mac type requires "src" for MAC sctp: fix oops while removed transport still using as retran path sctp: fix oops when updating retransmit path with DEBUG on net: Disable NETIF_F_TSO_ECN when TSO is disabled net: Disable all TSO features when SG is disabled sfc: Use rmb() to ensure reads occur in order ieee802154: Remove hacked CFLAGS in net/ieee802154/Makefile ...
2011-04-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: PCI: pci-label: Fix build failure when CONFIG_NLS is set to 'm' by allmodconfig
2011-04-19Merge branch 'timer-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timer-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: RTC: rtc-omap: Fix a leak of the IRQ during init failure posix clocks: Replace mutex with reader/writer semaphore
2011-04-19Revert "[media] V4L: videobuf, don't use dma addr as physical"Linus Torvalds
This reverts commit 35d9f510b67b10338161aba6229d4f55b4000f5b. Quoth Jiri Slaby: "It fixes mmap when IOMMU is used on x86 only, but breaks architectures like ARM or PPC where virt_to_phys(dma_alloc_coherent) doesn't work. We need there dma_mmap_coherent or similar (the trickery what snd_pcm_default_mmap does but in some saner way). But this cannot be done at this phase." Requested-by: Jiri Slaby <jslaby@suse.cz> Cc: Russell King - ARM Linux <linux@arm.linux.org.uk> Cc: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-19hwmon: (pmbus) Removed unused variable from struct pmbus_dataGuenter Roeck
struct pmbus_data included an unused variable named status_bits. Remove it. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Reviewed-by: Tom Grennan <tom.grennan@ericsson.com>
2011-04-19block: get rid of QUEUE_FLAG_REENTERJens Axboe
We are currently using this flag to check whether it's safe to call into ->request_fn(). If it is set, we punt to kblockd. But we get a lot of false positives and excessive punts to kblockd, which hurts performance. The only real abuser of this infrastructure is SCSI. So export the async queue run and convert SCSI over to use that. There's room for improvement in that SCSI need not always use the async call, but this fixes our performance issue and they can fix that up in due time. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-04-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: xen-kbdfront - fix mouse getting stuck after save/restore Input: estimate number of events per packet Input: evdev - indicate buffer overrun with SYN_DROPPED Input: document event types and codes and their intended use Input: add KEY_IMAGES specifically for AL Image Browser Input: twl4030_keypad - fix potential NULL dereference in twl4030_kp_probe() Input: h3600_ts - fix error handling at connect Input: twl4030_keypad - avoid potential NULL-pointer dereference
2011-04-18Input: xen-kbdfront - fix mouse getting stuck after save/restoreIgor Mammedov
Mouse gets "stuck" after restore of PV guest but buttons are in working condition. If driver has been configured for ABS coordinates at start it will get XENKBD_TYPE_POS events and then suddenly after restore it'll start getting XENKBD_TYPE_MOTION events, that will be dropped later and they won't get into user-space. Regression was introduced by hunk 5 and 6 of 5ea5254aa0ad269cfbd2875c973ef25ab5b5e9db ("Input: xen-kbdfront - advertise either absolute or relative coordinates"). Driver on restore should ask xen for request-abs-pointer again if it is available. So restore parts that did it before 5ea5254. Acked-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: Igor Mammedov <imammedo@redhat.com> [v1: Expanded the commit description] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-04-18Input: estimate number of events per packetJeff Brown
Calculate a default based on the number of ABS axes, REL axes, and MT slots for the device during input device registration. Signed-off-by: Jeff Brown <jeffbrown@android.com> Reviewed-by: Henrik Rydberg <rydberg@euromail.se> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-04-18block: add blk_run_queue_asyncChristoph Hellwig
Instead of overloading __blk_run_queue to force an offload to kblockd add a new blk_run_queue_async helper to do it explicitly. I've kept the blk_queue_stopped check for now, but I suspect it's not needed as the check we do when the workqueue items runs should be enough. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-04-18RTC: rtc-omap: Fix a leak of the IRQ during init failureAxel Lin
In omap_rtc_probe error path, free_irq() was using NULL rather than the driver data as the data pointer so free_irq() wouldn't have matched. Signed-off-by: Axel Lin <axel.lin@gmail.com> Cc: "George G. Davis" <gdavis@mvista.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: rtc-linux@googlegroups.com Link: http://lkml.kernel.org/r/%3C1303005778.2889.2.camel%40phoenix%3E Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-04-18md: fix up raid1/raid10 unplugging.NeilBrown
We just need to make sure that an unplug event wakes up the md thread, which is exactly what mddev_check_plugged does. Also remove some plug-related code that is no longer needed. Signed-off-by: NeilBrown <neilb@suse.de>
2011-04-18md: incorporate new plugging into raid5.NeilBrown
In raid5 plugging is used for 2 things: 1/ collecting writes that require a bitmap update 2/ collecting writes in the hope that we can create full stripes - or at least more-full. We now release these different sets of stripes when plug_cnt is zero. Also in make_request, we call mddev_check_plug to hopefully increase plug_cnt, and wake up the thread at the end if plugging wasn't achieved for some reason. Signed-off-by: NeilBrown <neilb@suse.de>
2011-04-18md: provide generic support for handling unplug callbacks.NeilBrown
When an md device adds a request to a queue, it can call mddev_check_plugged. If this succeeds then we know that the md thread will be woken up shortly, and ->plug_cnt will be non-zero until then, so some processing can be delayed. If it fails, then no unplug callback is expected and the make_request function needs to do whatever is required to make the request happen. Signed-off-by: NeilBrown <neilb@suse.de>
2011-04-18md - remove old plugging code.NeilBrown
md has some plugging infrastructure for RAID5 to use because the normal plugging infrastructure required a 'request_queue', and when called from dm, RAID5 doesn't have one of those available. This relied on the ->unplug_fn callback which doesn't exist any more. So remove all of that code, both in md and raid5. Subsequent patches with restore the plugging functionality. Signed-off-by: NeilBrown <neilb@suse.de>
2011-04-18md/dm - remove remains of plug_fn callback.NeilBrown
Now that unplugging is done differently, the unplug_fn callback is never called, so it can be completely discarded. Signed-off-by: NeilBrown <neilb@suse.de>
2011-04-18md: use new plugging interface for RAID IO.NeilBrown
md/raid submits a lot of IO from the various raid threads. So adding start/finish plug calls to those so that some plugging happens. Signed-off-by: NeilBrown <neilb@suse.de>
2011-04-17ip6_pol_route panic: Do not allow VLAN on loopbackKrishna Kumar
Several tests in the ipv6 routing code check IFF_LOOPBACK, and allowing stacking such as VLAN'ing on top of loopback results in a netdevice which reports IFF_LOOPBACK but really isn't the loopback device. Instead of spamming the ipv6 routing code with even more special tests, simply disallow VLAN over loopback. The result of this patch is: # modprobe 8021q # vconfig add lo 43 ERROR: trying to add VLAN #43 to IF -:lo:- error: Operation not supported Signed-off-by: Krishna Kumar <krkumar2@in.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
