path: root/drivers
2010-10-26Merge branch 'pm-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6 * 'pm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6: PM / Runtime: fix recursive locking warning of lockdep from rpm_resume()
2010-10-26Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (53 commits) ACPI: install ACPI table handler before any dynamic tables being loaded ACPI / PM: Blacklist another machine that needs acpi_sleep=nonvs ACPI: Page based coalescing of I/O remappings optimization ACPI: Convert simple locking to RCU based locking ACPI: Pre-map 'system event' related register blocks ACPI: Add interfaces for ioremapping/iounmapping ACPI registers ACPI: Maintain a list of ACPI memory mapped I/O remappings ACPI: Fix ioremap size for MMIO reads and writes ACPI / Battery: Return -ENODEV for unknown values in get_property() ACPI / PM: Fix reference counting of power resources Subject: [PATCH] ACPICA: Fix Scope() op in module level code ACPI battery: support percentage battery remaining capacity ACPI: Make Embedded Controller command timeout delay configurable ACPI dock: move some functions to .init.text ACPI: thermal: remove unused limit code ACPI: static sleep_states[] and acpi_gts_bfs_check ACPI: remove dead code ACPI: delete dedicated MAINTAINERS entries for ACPI EC and BATTERY drivers ACPI: Only processor needs CPU_IDLE ACPICA: Update version to 20101013 ...
2010-10-26Merge branch 'idle-release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6 * 'idle-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6: intel_idle: do not use the LAPIC timer for ATOM C2 intel_idle: add initial Sandy Bridge support acpi_idle: delete bogus data from cpuidle_state.power_usage intel_idle: delete bogus data from cpuidle_state.power_usage intel_idle: simplify test for leave_mm()
2010-10-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tileLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: arch/tile: convert a BUG_ON to BUILD_BUG_ON arch/tile: make ptrace() work properly for TILE-Gx COMPAT mode arch/tile: support new info op generated by compiler arch/tile: minor whitespace/naming changes for string support files arch/tile: enable single-step support for TILE-Gx arch/tile: parameterize system PLs to support KVM port arch/tile: add Tilera's <arch/sim.h> header as an open-source header arch/tile: Bomb C99 comments to C89 comments in tile's <arch/sim_def.h> arch/tile: prevent corrupt top frame from causing backtracer runaway arch/tile: various top-level Makefile cleanups arch/tile: change lower bound on syscall error return to -4095 arch/tile: properly export __mb_incoherent for modules arch/tile: provide a definition of MAP_STACK kmemleak: add TILE to the list of supported architectures. char: hvc: check for error case arch/tile: Add a warning if we try to allocate too much vmalloc memory. arch/tile: update some comments to clarify register usage. arch/tile: use better "punctuation" for VMSPLIT_3_5G and friends arch/tile: Use <asm-generic/syscalls.h> tile: replace some BUG_ON checks with BUILD_BUG_ON checks
2010-10-26misc devices: do not enable by defaultBorislav Petkov
Do not enable this Kconfig menu by default since it contains devices not present on the majority of systems. This is becoming a pain and a waste of time especially when doing a bunch of kernel builds on different systems daily and have to answer "make oldconfig" prompts for strange devices. Signed-off-by: Borislav Petkov <bp@alien8.de> Acked-by: Mike Frysinger <vapier@gentoo.org> Cc: Michael Hennerich <michael.hennerich@analog.com> Cc: Andres Salomon <dilinger@collabora.co.uk> Cc: Jean Delvare <khali@linux-fr.org> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26drivers/misc/apds9802als.c: add runtime PM supportHong Liu
Update the driver for the needed runtime power features. Remove the old user controlled power functions. [akpm@linux-foundation.org: put PM code under CONFIG_PM] Signed-off-by: Hong Liu <hong.liu@intel.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26drivers/misc/apds9802als.c: ALS drivers for the apds9802alsanantha
This adds support for the ADPS9802ALS sensor. Cleanup by Alan Cox - move mutexes to cover more things - report I/O errors back to user space - report range and values in LUX Signed-off-by: Anantha Narayanan <anantha.narayanan@intel.com> [The 4K and 64K in the hw spec actually means 4095 (12bit) and 65535 (16bit).] Signed-off-by: Hong Liu <hong.liu@intel.com> [Updated to match the ALS light API interface convention from Samu] Signed-off-by: Alan Cox <alan@linux.intel.com> Acked-by: Jonathan Cameron <jic23@cam.ac.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26pca953x: pca953x driver fixes for x86 mrstAlek Du
Our Moorestown platform has two max7315 chips which is covered by pca953x i2c gpio driver. A while ago this driver got updated with nested irq thread support, and it broke the compatibity with "request_irq". For example, the gpio_keys.c driver can not work with this driver now. This patch fixes the issue by switching to generic_handle_irq. Also fix the irq_base issue: irq_base == 0 is valid, and a "-1" value should mean invalid. IRQ 0 is not a valid IRQ, irq_base of 0 is valid. Signed-off-by: Alek Du <alek.du@intel.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26drivers/misc/isl29020.c: ambient light sensorKalhan Trisal
The LS driver will read the latest Lux measurement based upon the light brightness and will report the LUX output through sysfs interface. This hardware isn't quite the same as the ISL29003 so has a different driver. [akpm@linux-foundation.org: put PM code under #ifdef CONFIG_PM] Signed-off-by: Kalhan Trisal <kalhan.trisal@intel.com> [Runtime power management support added] Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> [Fixes to runtime PM] Signed-off-by: Liu Hong <hong.liu@intel.com> [Cleanups and added checks for I2C errors, reworked the API to match the saner one agreed for other sensors] Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26lkdtm: prefix enum constantsNamhyung Kim
Prefix cname and ctype constants with CN/CT_. This is especially for the conflict on BUG which causes a build break if arch defines it as a inline function, i.e. MIPS. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: Ankita Garg <ankita@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26drivers/misc: driver for APDS990X ALS and proximity sensorsSamu Onkalo
This is a driver for Avago APDS990X combined ALS and proximity sensor. Interface is sysfs based. The driver uses interrupts to provide new data. The driver supports pm_runtime and regulator frameworks. See Documentation/misc-devices/apds990x.txt for details Signed-off-by: Samu Onkalo <samu.p.onkalo@nokia.com> Acked-by: Jonathan Cameron <jic23@cam.ac.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26drivers/misc: driver for bh1770glc / sfh7770 ALS and proximity sensorSamu Onkalo
This is a driver for ROHM BH1770GLC and OSRAM SFH7770 combined ALS and proximity sensor. Interface is sysfs based. The driver uses interrupts to provide new data. The driver supports pm_runtime and regulator frameworks. See Documentation/misc-devices/bh1770glc.txt for details Signed-off-by: Samu Onkalo <samu.p.onkalo@nokia.com> Acked-by: Jonathan Cameron <jic23@cam.ac.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26ad525x_dpot: use correct rdac channel for ad5251/ad5252steven miao
The ad5251/ad5252 devices have rdac1 and rdac3, but no rdac0. So make sure we use the right channels so userspace gets correct data and not just garbage. Signed-off-by: steven miao <realmz6@gmail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Michael Hennerich <michael.hennerich@analog.com> Cc: Chris Verges <chrisv@cyberswitching.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26drivers/misc/ad525x_dpot.c: new featuresMichael Hennerich
Add support for AD5270, AD5271, AD5272, AD5274 digital potentiometers. Add 20-TP feature for AD5291 and AD5292 parts, and update feature list. AD5291 rdac read back must be shifted by two. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Chris Verges <chrisv@cyberswitching.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26drivers/misc/ad525x_dpot.c: fix part name typos in definesMichael Hennerich
There is no runtime effect by this change. It frees up namespace for defines erroneously used. This is required to actually support devices requiring the namespace, added with "drivers/misc/ad525x_dpot.c: new features". All defines touched have the same value defined, after the change. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Chris Verges <chrisv@cyberswitching.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26drivers/misc/phantom.c: add missing warning messages in phantom_probe()Rahul Ruikar
phantom_probe() can fail in many places. Add missing warning messages in pci_enable_device() and pci_request_regions(). Signed-off-by: Rahul Ruikar <rahul.ruikar@gmail.com> Cc: Jiri Slaby <jirislaby@gmail.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26workqueues: s/ON_STACK/ONSTACK/Andrew Morton
Silly though it is, completions and wait_queue_heads use foo_ONSTACK (COMPLETION_INITIALIZER_ONSTACK, DECLARE_COMPLETION_ONSTACK, __WAIT_QUEUE_HEAD_INIT_ONSTACK and DECLARE_WAIT_QUEUE_HEAD_ONSTACK) so I guess workqueues should do the same thing. s/INIT_WORK_ON_STACK/INIT_WORK_ONSTACK/ s/INIT_DELAYED_WORK_ON_STACK/INIT_DELAYED_WORK_ONSTACK/ Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26replace nested max/min macros with {max,min}3 macroHagen Paul Pfeifer
Use the new {max,min}3 macros to save some cycles and bytes on the stack. This patch substitutes trivial nested macros with their counterpart. Signed-off-by: Hagen Paul Pfeifer <hagen@jauu.net> Cc: Joe Perches <joe@perches.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Hartley Sweeten <hsweeten@visionengravers.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: Roland Dreier <rolandd@cisco.com> Cc: Sean Hefty <sean.hefty@intel.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26drivers/char/hpet.c: fix information leak to userlandVasiliy Kulikov
Structure info is copied to userland with some padding fields unitialized. It leads to leaking of stack memory. [akpm@linux-foundation.org: remove now-unneeded zeroing of info->hi_ireqfreq] Signed-off-by: Vasiliy Kulikov <segooon@gmail.com> Cc: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26hpet: fix style problemsJaswinder Singh Rajput
Fix the following style problems: WARNING: Use #include <linux/uaccess.h> instead of <asm/uaccess.h> WARNING: Use #include <linux/io.h> instead of <asm/io.h> ERROR: code indent should use tabs where possible ERROR: do not initialise statics to 0 or NULL Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Cc: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26hpet: fix unwanted interrupt due to stale irq status bitClemens Ladisch
Jaswinder Singh Rajput wrote: > By executing Documentation/timers/hpet_example.c > > for polling, I requested for 3 iterations but it seems iteration work > for only 2 as first expired time is always very small. > > # ./hpet_example poll /dev/hpet 10 3 > -hpet: executing poll > hpet_poll: info.hi_flags 0x0 > hpet_poll: expired time = 0x13 > hpet_poll: revents = 0x1 > hpet_poll: data 0x1 > hpet_poll: expired time = 0x1868c > hpet_poll: revents = 0x1 > hpet_poll: data 0x1 > hpet_poll: expired time = 0x18645 > hpet_poll: revents = 0x1 > hpet_poll: data 0x1 Clearing the HPET interrupt enable bit disables interrupt generation but does not disable the timer, so the interrupt status bit will still be set when the timer elapses. If another interrupt arrives before the timer has been correctly programmed (due to some other device on the same interrupt line, or CONFIG_DEBUG_SHIRQ), this results in an extra unwanted interrupt event because the status bit is likely to be set from comparator matches that happened before the device was opened. Therefore, we have to ensure that the interrupt status bit is and stays cleared until we actually program the timer. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Reported-by: Jaswinder Singh Rajput <jaswinderlinux@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: john stultz <johnstul@us.ibm.com> Cc: Bob Picco <bpicco@redhat.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26hpet: unmap unused I/O spaceJiri Slaby
When the initialization code in hpet finds a memory resource and does not find an IRQ, it does not unmap the memory resource previously mapped. There are buggy BIOSes which report resources exactly like this and what is worse the memory region bases point to normal RAM. This normally would not matter since the space is not touched. But when PAT is turned on, ioremap causes the page to be uncached and sets this bit in page->flags. Then when the page is about to be used by the allocator, it is reported as: BUG: Bad page state in process md5sum pfn:3ed00 page:ffffea0000dbd800 count:0 mapcount:0 mapping:(null) index:0x0 page flags: 0x20000001000000(uncached) Pid: 7956, comm: md5sum Not tainted 2.6.34-12-desktop #1 Call Trace: [<ffffffff810df851>] bad_page+0xb1/0x100 [<ffffffff810dfa45>] prep_new_page+0x1a5/0x1c0 [<ffffffff810dfe01>] get_page_from_freelist+0x3a1/0x640 [<ffffffff810e01af>] __alloc_pages_nodemask+0x10f/0x6b0 ... In this particular case: 1) HPET returns 3ed00000 as memory region base, but it is not in reserved ranges reported by the BIOS (excerpt): BIOS-e820: 0000000000100000 - 00000000af6cf000 (usable) BIOS-e820: 00000000af6cf000 - 00000000afdcf000 (reserved) 2) there is no IRQ resource reported by HPET method. On the other hand, the Intel HPET specs (1.0a) says (3.2.5.1): _CRS ( // Report 1K of memory consumed by this Timer Block memory range consumed // Optional: only used if BIOS allocates Interrupts [1] IRQs consumed ) [1] For case where Timer Block is configured to consume IRQ0/IRQ8 AND Legacy 8254/Legacy RTC hardware still exists, the device objects associated with 8254 & RTC devices should not report IRQ0/IRQ8 as "consumed resources". So in theory we should check whether if it is the case and use those interrupts instead. Anyway the address reported by the BIOS here is bogus, so non-presence of IRQ doesn't mean the "optional" part in point 2). Since I got no reply previously, fix this by simply unmapping the space when IRQ is not found and memory region was mapped previously. It would be probably more safe to walk the resources again and unmap appropriately depending on type. But as we now use only ioremap for both 2 memory resource types, it is not necessarily needed right now. Addresses https://bugzilla.novell.com/show_bug.cgi?id=629908 Reported-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: Jiri Slaby <jslaby@suse.cz> Acked-by: Clemens Ladisch <clemens@ladisch.de> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26mm: stack based kmap_atomic()Peter Zijlstra
Keep the current interface but ignore the KM_type and use a stack based approach. The advantage is that we get rid of crappy code like: #define __KM_PTE \ (in_nmi() ? KM_NMI_PTE : \ in_irq() ? KM_IRQ_PTE : \ KM_PTE0) and in general can stop worrying about what context we're in and what kmap slots might be appropriate for that. The downside is that FRV kmap_atomic() gets more expensive. For now we use a CPP trick suggested by Andrew: #define kmap_atomic(page, args...) __kmap_atomic(page) to avoid having to touch all kmap_atomic() users in a single patch. [ not compiled on: - mn10300: the arch doesn't actually build with highmem to begin with ] [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix up drivers/gpu/drm/i915/intel_overlay.c] Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Chris Metcalf <cmetcalf@tilera.com> Cc: David Howells <dhowells@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Miller <davem@davemloft.net> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Dave Airlie <airlied@linux.ie> Cc: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26mm: strictly nested kmap_atomic()Peter Zijlstra
Ensure kmap_atomic() usage is strictly nested Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Reviewed-by: Rik van Riel <riel@redhat.com> Acked-by: Chris Metcalf <cmetcalf@tilera.com> Cc: David Howells <dhowells@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Miller <davem@davemloft.net> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26writeback: add /sys/devices/system/node/<node>/vmstatMichael Rubin
For NUMA node systems it is important to have visibility in memory characteristics. Two of the /proc/vmstat values "nr_written" and "nr_dirtied" are added here. # cat /sys/devices/system/node/node20/vmstat nr_written 0 nr_dirtied 0 Signed-off-by: Michael Rubin <mrubin@google.com> Reviewed-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Dave Chinner <david@fromorbit.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26ipmi: proper spinlock initializationEric Dumazet
Unloading ipmi module can trigger following error. (if CONFIG_DEBUG_SPINLOCK=y) [ 9633.779590] BUG: spinlock bad magic on CPU#1, rmmod/7170 [ 9633.779606] lock: f41f5414, .magic: 00000000, .owner: <none>/-1, .owner_cpu: 0 [ 9633.779626] Pid: 7170, comm: rmmod Not tainted 2.6.36-rc7-11474-gb71eb1e-dirty #328 [ 9633.779644] Call Trace: [ 9633.779657] [<c13921cc>] ? printk+0x18/0x1c [ 9633.779672] [<c11a1f33>] spin_bug+0xa3/0xf0 [ 9633.779685] [<c11a1ffd>] do_raw_spin_lock+0x7d/0x160 [ 9633.779702] [<c1131537>] ? release_sysfs_dirent+0x47/0xb0 [ 9633.779718] [<c1131b78>] ? sysfs_addrm_finish+0xa8/0xd0 [ 9633.779734] [<c1394bac>] _raw_spin_lock_irqsave+0xc/0x20 [ 9633.779752] [<f99d93da>] cleanup_one_si+0x6a/0x200 [ipmi_si] [ 9633.779768] [<c11305b2>] ? sysfs_hash_and_remove+0x72/0x80 [ 9633.779786] [<f99dcf26>] ipmi_pnp_remove+0xd/0xf [ipmi_si] [ 9633.779802] [<c11f622b>] pnp_device_remove+0x1b/0x40 Fix this by initializing spinlocks in a smi_info_alloc() helper function, right after memory allocation and clearing. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: David Miller <davem@davemloft.net> Cc: Yinghai Lu <yinghai@kernel.org> Acked-by: Corey Minyard <cminyard@mvista.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26drivers/misc/ad525x_dpot.c: fix typo in spi write16 and write24 transfer countsMichael Hennerich
This is a bug fix. Some SPI connected devices using 16/24 bit accesses, previously failed, now work. This typo slipped in after testing, during some restructuring. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Chris Verges <chrisv@cyberswitching.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26sgi-xp: incoming XPC channel messages can come in after the channel's ↵Robin Holt
partition structures have been torn down Under some workloads, some channel messages have been observed being delayed on the sending side past the point where the receiving side has been able to tear down its partition structures. This condition is already detected in xpc_handle_activate_IRQ_uv(), but that information is not given to xpc_handle_activate_mq_msg_uv(). As a result, xpc_handle_activate_mq_msg_uv() assumes the structures still exist and references them, causing a NULL-pointer deref. Signed-off-by: Robin Holt <holt@sgi.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26intel_idle: do not use the LAPIC timer for ATOM C2Len Brown
If we use the LAPIC timer during ATOM C2 on some nvidia chisets, the system stalls. https://bugzilla.kernel.org/show_bug.cgi?id=21032 Signed-off-by: Len Brown <len.brown@intel.com>
2010-10-26Merge branch 'misc' into releaseLen Brown
2010-10-26Merge branch 'acpi-mmio' into releaseLen Brown
Conflicts: drivers/acpi/osl.c Signed-off-by: Len Brown <len.brown@intel.com>
2010-10-26Merge git://git.infradead.org/battery-2.6Linus Torvalds
* git://git.infradead.org/battery-2.6: power_supply: Makefile cleanup bq27x00_battery: Add missing kfree(di->bus) in bq27x00_battery_remove() power_supply: Introduce maximum current property power_supply: Add types for USB chargers ds2782_battery: Fix units power_supply: Add driver for TWL4030/TPS65950 BCI charger bq20z75: Add support for more power supply properties wm831x_power: Add missing kfree(wm831x_power) in wm831x_power_remove() jz4740-battery: Add missing kfree(jz_battery) in jz_battery_remove() ds2760_battery: Add missing kfree(di) in ds2760_battery_remove() olpc_battery: Fix endian neutral breakage for s16 values ds2760_battery: Fix W1 and W1_SLAVE_DS2760 dependency pcf50633-charger: Add missing sysfs_remove_group() power_supply: Add driver for TI BQ20Z75 gas gauge IC wm831x_power: Remove duplicate chg mask omap: rx51: Add support for USB chargers power_supply: Add isp1704 charger detection driver
2010-10-26Merge branch 'linux_next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/i7core * 'linux_next' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/i7core: (34 commits) i7core_edac: return -ENODEV when devices were already probed i7core_edac: properly terminate pci_dev_table i7core_edac: Avoid PCI refcount to reach zero on successive load/reload i7core_edac: Fix refcount error at PCI devices i7core_edac: it is safe to i7core_unregister_mci() when mci=NULL i7core_edac: Fix an oops at i7core probe i7core_edac: Remove unused member channels in i7core_pvt i7core_edac: Remove unused arg csrow from get_dimm_config i7core_edac: Reduce args of i7core_register_mci i7core_edac: Introduce i7core_unregister_mci i7core_edac: Use saved pointers i7core_edac: Check probe counter in i7core_remove i7core_edac: Call pci_dev_put() when alloc_i7core_dev() failed i7core_edac: Fix error path of i7core_register_mci i7core_edac: Fix order of lines in i7core_register_mci i7core_edac: Always do get/put for all devices i7core_edac: Introduce i7core_pci_ctl_create/release i7core_edac: Introduce free_i7core_dev i7core_edac: Introduce alloc_i7core_dev i7core_edac: Reduce args of i7core_get_onedevice ...
2010-10-26Merge branch 'for_linus' of git://github.com/at91linux/linux-2.6-at91Linus Torvalds
* 'for_linus' of git://github.com/at91linux/linux-2.6-at91: AT91: rtc: enable built-in RTC in Kconfig for at91sam9g45 family at91/atmel-mci: inclusion of sd/mmc driver in at91sam9g45 chip and board AT91: pm: make sure that r0 is 0 when dealing with cache operations AT91: pm: use plain cpu_do_idle() for "wait for interrupt" AT91: reset: extend alternate reset procedure to several chips AT91: reset routine cleanup, remove not needed icache flush AT91: trivial: align comment of at91sam9g20_reset with one more tab AT91: Fix AT91SAM9G20 reset as per the errata in the data sheet AT91: add board support for Pcontrol_G20
2010-10-26Merge branch 'for-linus' of git://gitorious.org/linux-omap-dss2/linuxLinus Torvalds
* 'for-linus' of git://gitorious.org/linux-omap-dss2/linux: OMAP: DSS2: don't power off a panel twice OMAP: DSS2: OMAPFB: Allow usage of def_vrfb only for omap2,3 OMAP: DSS2: OMAPFB: make VRFB depends on OMAP2,3 OMAP: DSS2: OMAPFB: Allow FB_OMAP2 to build without VRFB arm/omap: simplify conditional OMAP: DSS2: DSI: Remove extra iounmap in error path OMAP: DSS2: Use dss_features framework on DSS2 code OMAP: DSS2: Introduce dss_features files video/omap: remove mux.h include ARM: omap/fb: move get_fbmem_region() to .init.text ARM: omap/fb: move omapfb_reserve_sram to .init.text ARM: omap/fb: move omap_init_fb to .init.text OMAP: DSS2: OMAPFB: swap front and back porches for both hsync and vsync OMAP: DSS2: make filter coefficient tables human readable OMAP: DSS2: Add SPI dependency to Kconfig of ACX565AKM panel
2010-10-26Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq: [CPUFREQ]: x86, cpufreq: Mark longrun_get_policy with __cpuinit. [CPUFREQ] add sampling_down_factor tunable to improve ondemand performance [CPUFREQ] arch/x86/kernel/cpu/cpufreq: Fix unsigned return type [CPUFREQ] drivers/cpufreq: Adjust confusing if indentation
2010-10-26AT91: rtc: enable built-in RTC in Kconfig for at91sam9g45 familyNicolas Ferre
Enable built-in RTC IP in Kconfig and modify comments and help messages. RTT as RTC is still available but should not be selected in common case. Reported-by: Yegor Yefremov <yegor_sub1@visionsystems.de> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2010-10-26at91/atmel-mci: inclusion of sd/mmc driver in at91sam9g45 chip and boardNicolas Ferre
This adds the support of atmel-mci sd/mmc driver in at91sam9g45 devices and board files. This also configures the DMA controller slave interface for at_hdmac dmaengine driver. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2010-10-26ACPI: install ACPI table handler before any dynamic tables being loadedZhang Rui
ACPI table sysfs I/F is broken by commit 78f1699659963fff97975df44db6d5dbe7218e55 Author: Alex Chiang <achiang@hp.com> Date: Sun Dec 20 12:19:09 2009 -0700 ACPI: processor: call _PDC early because dynamic SSDT tables may be loaded in _PDC, before installing the ACPI table handler. As a result, the sysfs I/F of these dynamic tables are located at /sys/firmware/acpi/tables instead of /sys/firmware/acpi/tables/dynamic, which is not true. Invoke acpi_sysfs_init() before acpi_early_processor_set_pdc(), so that the table handler is installed before any dynamic tables loaded. https://bugzilla.kernel.org/show_bug.cgi?id=21142 CC: Dennis Jansen <dennis.jansen@web.de> CC: Alex Chiang <achiang@hp.com> Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-10-25Merge branch 'for-next' of git://android.git.kernel.org/kernel/tegraLinus Torvalds
* 'for-next' of git://android.git.kernel.org/kernel/tegra: spi: tegra: fix error setting on timeout spi: add spi_tegra driver tegra: harmony: enable PCI Express tegra: add PCI Express support tegra: add PCI Express clocks [ARM] tegra: Add APB DMA support [ARM] tegra: Add cpufreq support [ARM] tegra: common: Update common clock init table [ARM] tegra: clock: Add dvfs support, bug fixes, and cleanups [ARM] tegra: Add support for reading fuses [ARM] tegra: gpio: Add suspend and wake support [ARM] tegra: pinmux: add safe values, move tegra2, add suspend [ARM] tegra: add suspend and mirror irqs to legacy controller [ARM] tegra: Add legacy irq support [ARM] tegra: update iomap
2010-10-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin: Blackfin: fix inverted anomaly 05000481 logic Blackfin: drop unused irq_panic()/DEBUG_ICACHE_CHECK Blackfin: ppi/spi/twi headers: add missing __BFP undef Blackfin: update defconfigs Blackfin: bfin_twi.h: start a common TWI header netdev: bfin_mac: push settings to platform resources
2010-10-25ACPI / PM: Blacklist another machine that needs acpi_sleep=nonvsRafael J. Wysocki
Sony Vaio VPCEB1Z1E is reported to require acpi_sleep=nonvs for suspend/resume to work on it correctly, so blacklist it. Reported-by: Emanuele Bigiarini <pulmro@gmail.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2010-10-25spi: tegra: fix error setting on timeoutErik Gilling
avoids derefencing an uninitialized pointer Change-Id: Icf528441ae481e9f6f5ddc0be32c7c217fa49701 Signed-off-by: Erik Gilling <konkers@android.com>
2010-10-25Merge branch 'next' of git://git.monstr.eu/linux-2.6-microblazeLinus Torvalds
* 'next' of git://git.monstr.eu/linux-2.6-microblaze: (42 commits) microblaze: Fix build with make 3.82 fbdev/xilinxfb: Microblaze driver support microblaze: Support C optimized lib functions for little-endian microblaze: Separate library optimized functions microblaze: Support timer on AXI lite microblaze: Add support for little-endian Microblaze microblaze: KGDB little endian support microblaze: Add PVR for endians plus detection net: emaclite: Add support for little-endian platforms microblaze: trivial: Add comment for AXI pvr microblaze: pci-common cleanup microblaze: Support early console on uart16550 microblaze: Do not compile early console support for uartlite if is disabled microblaze: Setup early console dynamically microblaze: Rename all uartlite early printk functions microblaze: remove early printk uarlite console dependency from header microblaze: Remove additional compatible properties microblaze: Remove hardcoded asm instraction for PVR loading microblaze: Use static const char * const where possible microblaze: Define VMALLOC_START/END ...
2010-10-25Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging: (24 commits) hwmon: lis3: Release resources in case of failure hwmon: lis3: Short explanations of platform data fields hwmon: lis3: Enhance lis3 selftest with IRQ line test hwmon: lis3: use block read to access data registers hwmon: lis3: Adjust fuzziness for 8 bit device hwmon: lis3: New parameters to platform data hwmon: lis3: restore axis enabled bits hwmon: lis3: Power on corrections hwmon: lis3: Update coordinates at polled device open hwmon: lis3: Cleanup interrupt handling hwmon: lis3: regulator control hwmon: lis3: pm_runtime support Kirkwood: add fan support for Network Space Max v2 hwmon: add generic GPIO fan driver hwmon: (coretemp) fix reading of microcode revision (v2) hwmon: ({core, pkg, via-cpu}temp) remove unnecessary CONFIG_HOTPLUG_CPU ifdefs hwmon: (pkgtemp) align driver initialization style with coretemp hwmon: LTC4261 Hardware monitoring driver hwmon: (lis3) add axes module parameter for custom axis-mapping hwmon: (hp_accel) Add HP Mini 510x family support ...
2010-10-25hwmon: lis3: Release resources in case of failureSamu Onkalo
If lis3lv02d_init_device fails, HW resources were not released properly. In case of failure call release_resources if available. Signed-off-by: Samu Onkalo <samu.p.onkalo@nokia.com> Acked-by: Eric Piel <eric.piel@tremplin-utc.net> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2010-10-25hwmon: lis3: Enhance lis3 selftest with IRQ line testSamu Onkalo
Configure chip to data ready mode in selftest and count received interrupts to see that interrupt line(s) are working. Signed-off-by: Samu Onkalo <samu.p.onkalo@nokia.com> Acked-by: Eric Piel <eric.piel@tremplin-utc.net> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2010-10-25hwmon: lis3: use block read to access data registersSamu Onkalo
Add optional blockread function to interface driver. If available the chip driver uses it for data register access. For 12 bit device it reads 6 bytes to get 3*16bit data. For 8 bit device it reads out 5 bytes since every second byte is dummy. This optimizes bus usage and reduces number of operations and interrupts needed for one data update. Signed-off-by: Samu Onkalo <samu.p.onkalo@nokia.com> Acked-by: Jonathan Cameron <jic23@cam.ac.uk> Acked-by: Eric Piel <eric.piel@tremplin-utc.net> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2010-10-25hwmon: lis3: Adjust fuzziness for 8 bit deviceSamu Onkalo
Default fuziness is set smaller for 8 device. In 12 bit device LSB is quite close to 1 mg (mg = 1 / 1000 of earth gravity). In 8bit device LSB is about 18 mg. Set fuziness to 1 for 8 bit device. Signed-off-by: Samu Onkalo <samu.p.onkalo@nokia.com> Acked-by: Eric Piel <eric.piel@tremplin-utc.net> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2010-10-25hwmon: lis3: New parameters to platform dataSamu Onkalo
Added default output data rate setting to platform data. If default rate is 0, reset default value is used. Added control for duration via platform data. Added possibility to configure interrupts to trig on both rising and falling edge. The lis3 WU unit can be configured quite many ways and with some configurations it is quite handy to get coordinate refresh when some event trigs and when it reason goes away. Signed-off-by: Samu Onkalo <samu.p.onkalo@nokia.com> Acked-by: Jonathan Cameron <jic23@cam.ac.uk> Acked-by: Eric Piel <eric.piel@tremplin-utc.net> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
