path: root/drivers
2011-03-22backlight: add backlight typeMatthew Garrett
There may be multiple ways of controlling the backlight on a given machine. Allow drivers to expose the type of interface they are providing, making it possible for userspace to make appropriate policy decisions. Signed-off-by: Matthew Garrett <mjg@redhat.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Chris Wilson <chris@chris-wilson.co.uk> Cc: David Airlie <airlied@linux.ie> Cc: Alex Deucher <alexdeucher@gmail.com> Cc: Ben Skeggs <bskeggs@redhat.com> Cc: Zhang Rui <rui.zhang@intel.com> Cc: Len Brown <lenb@kernel.org> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22drivers/leds/leds-lp5523.c: world-writable engine* sysfs filesVasiliy Kulikov
Don't allow everybody to change LED settings. Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22drivers/leds/leds-lp5521.c: world-writable sysfs engine* filesVasiliy Kulikov
2011-03-22drivers/vidfeo/backlight: ld9040 amoled driver supportDonghwa Lee
Add a ld9040 amoled panel driver. Signed-off-by: Donghwa Lee <dh09.lee@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Inki Dae <inki.dae@samsung.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22leds: make *struct gpio_led_platform_data.leds constUwe Kleine-König
And fix a typo. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: Lars-Peter Clausen <lars@metafoo.de> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22leds: add driver for LM3530 ALSShreshtha Kumar Sahu
Simple backlight driver for National Semiconductor LM3530. Presently only manual mode is supported, PWM and ALS support to be added. Signed-off-by: Shreshtha Kumar Sahu <shreshthakumar.sahu@stericsson.com> Cc: Linus Walleij <linus.walleij@stericsson.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22leds: convert bd2802 driver to dev_pm_opsMark Brown
There is a move to deprecate bus-specific PM operations and move to using dev_pm_ops instead in order to reduce the amount of boilerplate code in buses and facilitiate updates to the PM core. Do this move for the bs2802 driver. [akpm@linux-foundation.org: fix warnings] Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Kim Kyuwon <q1.kim@samsung.com> Cc: Kim Kyuwon <chammoru@gmail.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-clientLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: rbd: use watch/notify for changes in rbd header libceph: add lingering request and watch/notify event framework rbd: update email address in Documentation ceph: rename dentry_release -> d_release, fix comment ceph: add request to the tail of unsafe write list ceph: remove request from unsafe list if it is canceled/timed out ceph: move readahead default to fs/ceph from libceph ceph: add ino32 mount option ceph: update common header files ceph: remove debugfs debug cruft libceph: fix osd request queuing on osdmap updates ceph: preserve I_COMPLETE across rename libceph: Fix base64-decoding when input ends in newline.
2011-03-22tty: stop using "delayed_work" in the tty layerLinus Torvalds
Using delayed-work for tty flip buffers ends up causing us to wait for the next tick to complete some actions. That's usually not all that noticeable, but for certain latency-critical workloads it ends up being totally unacceptable. As an extreme case of this, passing a token back-and-forth over a pty will take two ticks per iteration, so even just a thousand iterations will take 8 seconds assuming a common 250Hz configuration. Avoiding the whole delayed work issue brings that ping-pong test-case down to 0.009s on my machine. In more practical terms, this latency has been a performance problem for things like dive computer simulators (simulating the serial interface using the ptys) and for other environments (Alan mentions a CP/M emulator). Reported-by: Jef Driesen <jefdriesen@telenet.be> Acked-by: Greg KH <gregkh@suse.de> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22rbd: use watch/notify for changes in rbd headerYehuda Sadeh
Send notifications when we change the rbd header (e.g. create a snapshot) and wait for such notifications. This allows synchronizing the snapshot creation between different rbd clients/rools. Signed-off-by: Yehuda Sadeh <yehuda@hq.newdream.net> Signed-off-by: Sage Weil <sage@newdream.net>
2011-03-22Merge branch 'for-linus/2639/i2c-2' of git://git.fluff.org/bjdooks/linuxLinus Torvalds
* 'for-linus/2639/i2c-2' of git://git.fluff.org/bjdooks/linux: i2c-pxa2xx: Don't clear isr bits too early i2c-pxa2xx: Fix register offsets i2c-pxa2xx: pass of_node from platform driver to adapter and publish i2c-pxa2xx: check timeout correctly i2c-pxa2xx: add support for shared IRQ handler i2c-pxa2xx: Add PCI support for PXA I2C controller ARM: pxa2xx: reorganize I2C files i2c-pxa2xx: use dynamic register layout i2c-mxs: set controller to pio queue mode after reset i2c-eg20t: support new device OKI SEMICONDUCTOR ML7213 IOH i2c/busses: Add support for Diolan U2C-12 USB-I2C adapter
2011-03-22sd: Fail discard requests when logical block provisioning has been disabledMartin K. Petersen
Ensure that we kill discard requests after logical block provisioning has been disabled in sysfs. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (33 commits) IPVS: Use global mutex in ip_vs_app.c ipvs: fix a typo in __ip_vs_control_init() veth: Fix the byte counters net ipv6: Fix duplicate /proc/sys/net/ipv6/neigh directory entries. macvlan: Fix use after free of struct macvlan_port. net: fix incorrect spelling in drop monitor protocol can: c_can: Do basic c_can configuration _before_ enabling the interrupts net/appletalk: fix atalk_release use after free ipx: fix ipx_release() snmp: SNMP_UPD_PO_STATS_BH() always called from softirq l2tp: fix possible oops on l2tp_eth module unload xfrm: Fix initialize repl field of struct xfrm_state netfilter: ipt_CLUSTERIP: fix buffer overflow netfilter: xtables: fix reentrancy netfilter: ipset: fix checking the type revision at create command netfilter: ipset: fix address ranges at hash:*port* types niu: Rename NIU parent platform device name to fix conflict. r8169: fix a bug in rtl8169_init_phy() bonding: fix a typo in a comment ftmac100: use resource_size() ...
2011-03-21veth: Fix the byte countersEric W. Biederman
Commit 44540960 "veth: move loopback logic to common location" introduced a bug in the packet counters. I don't understand why that happened as it is not explained in the comments and the mut check in dev_forward_skb retains the assumption that skb->len is the total length of the packet. I just measured this emperically by setting up a veth pair between two noop network namespaces setting and attempting a telnet connection between the two. I saw three packets in each direction and the byte counters were exactly 14*3 = 42 bytes high in each direction. I got the actual packet lengths with tcpdump. So remove the extra ETH_HLEN from the veth byte count totals. Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-21macvlan: Fix use after free of struct macvlan_port.Eric W. Biederman
When the macvlan driver was extended to call unregisgter_netdevice_queue in 23289a37e2b127dfc4de1313fba15bb4c9f0cd5b, a use after free of struct macvlan_port was introduced. The code in dellink relied on unregister_netdevice actually unregistering the net device so it would be safe to free macvlan_port. Since unregister_netdevice_queue can just queue up the unregister instead of performing the unregiser immediately we free the macvlan_port too soon and then the code in macvlan_stop removes the macaddress for the set of macaddress to listen for and uses memory that has already been freed. To fix this add a reference count to track when it is safe to free the macvlan_port and move the call of macvlan_port_destroy into macvlan_uninit which is guaranteed to be called after the final macvlan_port_close. Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-21can: c_can: Do basic c_can configuration _before_ enabling the interruptsJan Altenberg
I ran into some trouble while testing the SocketCAN driver for the BOSCH C_CAN controller. The interface is not correctly initialized, if I put some CAN traffic on the line, _while_ the interface is being started (which means: the interface doesn't come up correcty, if there's some RX traffic while doing 'ifconfig can0 up'). The current implementation enables the controller interrupts _before_ doing the basic c_can configuration. I think, this should be done the other way round. The patch below fixes things for me. Signed-off-by: Jan Altenberg <jan@linutronix.de> Acked-by: Kurt Van Dijck <kurt.van.dijck@eia.be> Acked-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-21i2c-pxa2xx: Don't clear isr bits too earlyVasily Khoruzhick
isr is passed later into i2c_pxa_irq_txempty and i2c_pxa_irq_rxfull and they may use some other bits than irq sources. Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-03-21Merge branches 'for-2639/i2c/i2c-ce4100-v6', 'for-2639/i2c/i2c-eg20t-v3' and ↵Ben Dooks
'for-2639/i2c/i2c-imx' into for-linus/2639/i2c-2
2011-03-21Reduce sequential pointer derefs in scsi_error.c and reduce size as wellJesper Juhl
This patch reduces the number of sequential pointer derefs in drivers/scsi/scsi_error.c This has been submitted a number of times over a couple of years. I believe this version adresses all comments it has gathered over time. Please apply or reject with a reason. The benefits are: - makes the code easier to read. Lots of sequential derefs of the same pointers is not easy on the eye. - theoretically at least, just dereferencing the pointers once can allow the compiler to generally slightly faster code, so in theory this could also be a micro speed optimization. - reduces size of object file (tiny effect: on x86-64, in at least one configuration, the text size decreased from 9439 bytes to 9400) - removes some pointless (mostly trailing) whitespace. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-21matroxfb: remove incorrect Matrox G200eV supportGary Hade
Remove incorrect Matrox G200eV support that was previously added by commit e3a1938805d2e81b27d3d348788644f3bad004f2 A serious issue with the incorrect G200eV support that reproduces on the Matrox G200eV equipped IBM x3650 M2 is the total lack of text (login banner, login prompt, etc) on the console when X is not running and total lack of text on all of the virtual consoles after X is started. Any concerns that the incorrect code (upstream since October 2008) has been successfully used on non-IBM G200eV equipped system(s) appear to be unwarranted. In addition to the serious/non-intermittent nature of issues that have been spotted on IBM systems, complete removal of the incorrect code is clearly supported by the following Matrox (Yannick Heneault) provided input: "It impossible that this patch should have work on a system. The patch only declare the G200eV as a regular G200 which is not case. Many registers are different, including at least the PLL programming sequence. If the G200eV is programmed like a regular G200, it will not display anything." v1 - Initial patch that removed the incorrect code for _all_ G200eV equipped systems. v2 - Darrick Wong provided patch that blacklisted the incorrect code on G200eV equipped IBM systems leaving it enabled on all G200eV equipped non-IBM systems. v3 - Same code changes included with v1 plus additional justification for complete removal of the incorrect code. Signed-off-by: Gary Hade <garyhade@us.ibm.com> Cc: Darrick J. Wong <djwong@us.ibm.com> Cc: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Petr Vandrovec <vandrove@vc.cvut.cz> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Yannick Heneault <yannick_heneault@matrox.com> Cc: Christian Toutant <ctoutant@matrox.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-21Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: hwmon: (ads1015) Make gain and datarate configurable hwmon: (ads1015) Drop dynamic attribute group hwmon: Add support for Texas Instruments ADS1015 hwmon: New driver for SMSC SCH5627 hwmon: (abituguru*) Update my email address hwmon: (lm75) Speed up detection hwmon: (lm75) Add detection of the National Semiconductor LM75A hp_accel: Fix driver name Move lis3lv02d drivers to drivers/misc Move hp_accel to drivers/platform/x86 Let Kconfig handle lis3lv02d dependencies hwmon: (sht15) Fix integer overflow in humidity calculation hwmon: (sht15) Spelling fix hwmon: (w83795) Document pin mapping
2011-03-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6: firewire: core: ignore link-active bit of new nodes, fix device recognition firewire: sbp2: revert obsolete 'fix stall with "Unsolicited response"' firewire: core: increase default SPLIT_TIMEOUT value firewire: ohci: Misleading kfree in ohci.c::pci_probe/remove firewire: ohci: omit IntEvent.busReset check rom AT queueing firewire: ohci: prevent starting of iso contexts with empty queue firewire: ohci: prevent iso completion callbacks after context stop firewire: core: rename some variables firewire: nosy: should work on Power Mac G4 PCI too firewire: core: fix card->reset_jiffies overflow firewire: cdev: remove unneeded reference firewire: cdev: always wait for outbound transactions to complete firewire: cdev: remove unneeded idr_find() from complete_transaction() firewire: ohci: log dead DMA contexts
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/parisc-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/parisc-2.6: [PARISC] Convert to new irq_chip functions [PARISC] fix per-cpu flag problem in the cpu affinity checkers [PARISC] fix vmap flush/invalidate eliminate special FLUSH flag from page table parisc: flush pages through tmpalias space
2011-03-21hwmon: (ads1015) Make gain and datarate configurableDirk Eibach
Configuration for ads1015 gain and datarate is possible via devicetree or platform data. This is a followup patch to previous ads1015 patches on Jean Delvares tree. Signed-off-by: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-03-21hwmon: (ads1015) Drop dynamic attribute groupJean Delvare
It is cheaper to handle attributes individually. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Dirk Eibach <eibach@gdsys.de>
2011-03-21hwmon: Add support for Texas Instruments ADS1015Dirk Eibach
2011-03-21hwmon: New driver for SMSC SCH5627Hans de Goede
SMSC SCH5627 Super I/O chips include complete hardware monitoring capabilities. They can monitor up to 5 voltages, 4 fans and 8 temperatures. The hardware monitoring part of the SMSC SCH5627 is accessed by talking through an embedded microcontroller. An application note describing the protocol for communicating with the microcontroller is available upon request. Please mail me if you want a copy. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-03-21hwmon: (abituguru*) Update my email addressHans de Goede
2011-03-21hwmon: (lm75) Speed up detectionJean Delvare
Make the LM75/LM75A device detection faster: * Don't read the current temperature value when we don't use it. * Check for unused bits in the configuration register as soon as we have read its value. * Don't use word reads, not all devices support this, and some which don't misbehave when you try. * Check for cycling register values every 40 register addresses instead of every 8, it's 5 times faster and just as efficient. Some of these improvements come straight from the user-space sensors-detect script, so both detection routines are in line now. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Len Sorensen <lsorense@csclub.uwaterloo.ca> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-03-21hwmon: (lm75) Add detection of the National Semiconductor LM75ALen Sorensen
Add support for detection of the National Semiconductor LM75A using the ID register value. Signed-off-by: Len Sorensen <lsorense@csclub.uwaterloo.ca> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2011-03-21hp_accel: Fix driver nameJean Delvare
I suspect that the "lis3lv02d" driver name is a legacy from before the split into several modules. Use a specific name for the hp_accel driver, for better error messages and easier investigation of issues. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com> Acked-by: Eric Piel <eric.piel@tremplin-utc.net> Acked-by: Jonathan Cameron <jic23@cam.ac.uk> Tested-by: Eric Piel <eric.piel@tremplin-utc.net> Tested-by: Takashi Iwai <tiwai@suse.de>
2011-03-21Move lis3lv02d drivers to drivers/miscJean Delvare
The lis3lv02d drivers aren't hardware monitoring drivers, so the don't belong to drivers/hwmon. Move them to drivers/misc, short of a better home. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com> Acked-by: Eric Piel <eric.piel@tremplin-utc.net> Acked-by: Jonathan Cameron <jic23@cam.ac.uk> Tested-by: Eric Piel <eric.piel@tremplin-utc.net> Tested-by: Takashi Iwai <tiwai@suse.de>
2011-03-21Move hp_accel to drivers/platform/x86Jean Delvare
The hp_accel driver isn't a hardware monitoring driver, so it doesn't belong to drivers/hwmon. Move it to drivers/platform/x86, assuming HP doesn't ship non-x86 laptops. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com> Acked-by: Eric Piel <eric.piel@tremplin-utc.net> Acked-by: Jonathan Cameron <jic23@cam.ac.uk> Tested-by: Eric Piel <eric.piel@tremplin-utc.net> Tested-by: Takashi Iwai <tiwai@suse.de>
2011-03-21Let Kconfig handle lis3lv02d dependenciesJean Delvare
The dependencies between the various lis3lv02d drivers make it impossible to split them to different directories, while we really want to do this. Move handling of dependencies from Makefile to Kconfig, to make the move possible at all. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com> Acked-by: Eric Piel <eric.piel@tremplin-utc.net> Acked-by: Jonathan Cameron <jic23@cam.ac.uk> Tested-by: Eric Piel <eric.piel@tremplin-utc.net> Tested-by: Takashi Iwai <tiwai@suse.de>
2011-03-21hwmon: (sht15) Fix integer overflow in humidity calculationVivien Didelot
An integer overflow occurs in the calculation of RHlinear when the relative humidity is greater than around 30%. The consequence is a subtle (but noticeable) error in the resulting humidity measurement. Signed-off-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com> Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: stable@kernel.org Cc: Jonathan Cameron <jic23@cam.ac.uk>
2011-03-21hwmon: (sht15) Spelling fixJustin P. Mattock
Remove one too many "n" in a word. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Acked-by: Jean Delvare <khali@linux-fr.org>
2011-03-21i2c-pxa2xx: Fix register offsetsVasily Khoruzhick
Fix regression that was introduced by dynamic register layout. Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-03-21i2c-pxa2xx: pass of_node from platform driver to adapter and publishSebastian Andrzej Siewior
the of_node will auto-publish devices which are added to the device tree. Commit 925bb9c6 aka ("of/i2c: Fix module load order issue caused by of_i2c.c) moved the of_i2c_register_devices() function from the i2c core back to the drivers. This patch does the same thing for the pxa driver. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-03-21i2c-pxa2xx: check timeout correctlySebastian Andrzej Siewior
timeout here maybe 0 if the event occured and a task with a higher priority stole the cpu and we were sleeping longer than the timeout value we specified. In case of a real timeout I changed the error code to I2C_RETRY so we retry the transfer. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-03-21i2c-pxa2xx: add support for shared IRQ handlerSebastian Andrzej Siewior
Sodaville has three of them on a single IRQ. IRQF_DISABLED is removed because it is a NOP allready and scheduled for removal. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-03-21i2c-pxa2xx: Add PCI support for PXA I2C controllerSebastian Andrzej Siewior
The Sodaville I2C controller is almost the same as found on PXA2xx. The difference: - the register are at a different offset - no slave support The PCI probe code adds three platform devices which are probed then by the platform code. The X86 part also adds dummy clock defines because we don't have HW clock support. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-03-21ARM: pxa2xx: reorganize I2C filesSebastian Andrzej Siewior
This patch moves the platform data definition from arch/arm/plat-pxa/include/plat/i2c.h to include/linux/i2c/pxa-i2c.h so it can be accessed from x86 the same way as on ARM. This change should make no functional change to the PXA code. The move is verified by building the following defconfigs: cm_x2xx_defconfig corgi_defconfig em_x270_defconfig ezx_defconfig imote2_defconfig pxa3xx_defconfig spitz_defconfig zeus_defconfig raumfeld_defconfig magician_defconfig mmp2_defconfig pxa168_defconfig pxa910_defconfig Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-03-21i2c-pxa2xx: use dynamic register layoutSebastian Andrzej Siewior
This will prepare the driver to handle register layouts where certain registers are not available at all. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-03-20Merge branch 'trivial' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (25 commits) video: change to new flag variable scsi: change to new flag variable rtc: change to new flag variable rapidio: change to new flag variable pps: change to new flag variable net: change to new flag variable misc: change to new flag variable message: change to new flag variable memstick: change to new flag variable isdn: change to new flag variable ieee802154: change to new flag variable ide: change to new flag variable hwmon: change to new flag variable dma: change to new flag variable char: change to new flag variable fs: change to new flag variable xtensa: change to new flag variable um: change to new flag variables s390: change to new flag variable mips: change to new flag variable ... Fix up trivial conflict in drivers/hwmon/Makefile
2011-03-20Merge branch 'i2c-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging * 'i2c-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: i2c-i801: SMBus patch for Intel DH89xxCC DeviceIDs i2c: Drop i2c_adapter.id i2c: Deprecate i2c_driver.attach_adapter and .detach_adapter i2c-dev: Use standard bus notification mechanism i2c: Export i2c_for_each_dev i2c: Get rid of <linux/i2c-id.h> i2c: Minor fixes to upgrading-clients document i2c: make i2c_get_adapter prototype clearer i2c: Fix typo in instantiating-devices document i2c-boardinfo: Fix typo in comment
2011-03-20r8169: fix a bug in rtl8169_init_phy()Eric Dumazet
commit 54405cde7624 (r8169: support control of advertising.) introduced a bug in rtl8169_init_phy() Reported-and-tested-by: Piotr Hosowicz <piotr@hosowicz.com> Reported-and-tested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by:: Oliver Neukum <oliver@neukum.org> Cc: Francois Romieu <romieu@fr.zoreil.com> Tested-by: Anca Emanuel <anca.emanuel@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-20i2c-mxs: set controller to pio queue mode after resetSascha Hauer
mxs_reset_block() clears the PIO_QUEUE_MODE bit. So we have to set it again after a controller reset. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-03-20Merge branch 'for-2639/i2c/i2c-u2c12' into for-linus/2639/i2c-12Ben Dooks
2011-03-20Merge branch 'vhost-net-next' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost
2011-03-20firewire: core: ignore link-active bit of new nodes, fix device recognitionStefan Richter
Like the older ieee1394 core driver, firewire-core skipped scanning of any new node whose PHY sent a self ID without "link active" bit. If a device had this bit off mistakenly, it meant that it was inaccessible to kernel drivers with the old IEEE 1394 driver stack but could still be accessed by userspace drivers through the raw1394 interface. But with firewire-core, userspace drivers don't get to see such buggy devices anymore. This is effectively a driver regression since this device bug is otherwise harmless. We now attempt to scan all devices, even repeaters that don't have a link or powered-down devices that have everything but their PHY shut down when plugged in. This results in futile repeated scanning attempts in case of such devices that really don't have an active link, but this doesn't hurt since recent workqueue infrastructure lets us run more concurrent scanning jobs than we can shake a stick at. This should fix accessibility of Focusrite Saffire PRO 26 I/O: http://sourceforge.net/mailarchive/forum.php?thread_name=20110314215622.5c751bb0%40stein&forum_name=ffado-user Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
