path: root/drivers
2010-09-27Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: (28 commits) ARM: 6411/1: vexpress: set RAM latencies to 1 cycle for PL310 on ct-ca9x4 tile ARM: 6409/1: davinci: map sram using MT_MEMORY_NONCACHED instead of MT_DEVICE ARM: 6408/1: omap: Map only available sram memory ARM: 6407/1: mmu: Setup MT_MEMORY and MT_MEMORY_NONCACHED L1 entries ARM: pxa: remove pr_<level> uses of KERN_<level> ARM: pxa168fb: clear enable bit when not active ARM: pxa: fix cpu_is_pxa*() not expanding to zero when not configured ARM: pxa168: fix corrected reset vector ARM: pxa: Use PIO for PI2C communication on Palm27x ARM: pxa: Fix Vpac270 gpio_power for MMC ARM: 6401/1: plug a race in the alignment trap handler ARM: 6406/1: at91sam9g45: fix i2c bus speed leds: leds-ns2: fix locking ARM: dove: fix __io() definition to use bus based offset dmaengine: fix interrupt clearing for mv_xor ARM: kirkwood: Unbreak PCIe I/O port ARM: Fix build error when using KCONFIG_CONFIG ARM: 6383/1: Implement phys_mem_access_prot() to avoid attributes aliasing ARM: 6400/1: at91: fix arch_gettimeoffset fallout ARM: 6398/1: add proc info for ARM11MPCore/Cortex-A9 from ARM ...
2010-09-27Merge branch 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/bp/bpLinus Torvalds
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp: amd64_edac: Fix driver module removal
2010-09-27Merge branch 'drm-intel-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ickle/drm-intel * 'drm-intel-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/ickle/drm-intel: drm/i915/sdvo: Handle unsupported GET_SUPPORTED_ENHANCEMENTS gracefully drm/i915/sdvo: Cleanup connector on error path drm/i915: Fix 945GM regression in e259befd
2010-09-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: mmc: sdhci-s3c: fix NULL ptr access in sdhci_s3c_remove mmc: sdhci-s3c: fix incorrect spinlock usage after merge mmc: MAINTAINERS: add myself as MMC maintainer
2010-09-27Merge branch 'urgent' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6 * 'urgent' of git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6: pcmcia: pd6729: Fix error path pcmcia: preserve configuration information if request_io fails partly
2010-09-27Merge git://git.infradead.org/iommu-2.6Linus Torvalds
* git://git.infradead.org/iommu-2.6: intel-iommu: Use symbolic values instead of magic numbers in Lenovo w/a intel-iommu: Abort IOMMU setup for igfx if BIOS gave no shadow GTT space
2010-09-27amd64_edac: Fix driver module removalBorislav Petkov
f4347553b30ec66530bfe63c84530afea3803396 removed the edac polling mechanism in favor of using a notifier chain for conveying MCE information to edac. However, the module removal path didn't test whether the driver had setup the polling function workqueue at all and the rmmod process was hanging in the kernel at try_to_del_timer_sync() in the cancel_delayed_work() path, trying to cancel an uninitialized work struct. Fix that by adding a balancing check to the workqueue removal path. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2010-09-26mmc: sdhci-s3c: fix NULL ptr access in sdhci_s3c_removeMarek Szyprowski
If not all clocks have been defined in platform data, the driver will cause a null pointer dereference when it is removed. This patch fixes this issue. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2010-09-26mmc: sdhci-s3c: fix incorrect spinlock usage after mergeMarek Szyprowski
In the commit f522886e202a34a2191dd5d471b3c4d46410a9a0 a merge conflict in the sdhci-s3c driver been fixed. However the fix used incorrect spinlock operation - it caused a race with sdhci interrupt service. The correct way to solve it is to use spin_lock_irqsave/irqrestore() calls. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2010-09-26pcmcia: pd6729: Fix error pathRahul Ruikar
In error return path call pci_disable_device() which was enabled earlier. Signed-off-by: Rahul Ruikar <rahul.ruikar@gmail.com> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2010-09-25Merge branch 'fix' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6
2010-09-24Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging: x86/hwmon: pkgtemp has no dependency on PCI MAINTAINERS: Update hwmon entry x86/hwmon: register alternate sibling upon CPU removal x86/hwmon: fix initialization of pkgtemp x86/hwmon: fix initialization of coretemp x86/hwmon: don't leak device attribute file from pkgtemp_probe() and pkgtemp_remove() x86/hwmon: avoid deadlock on CPU removal in pkgtemp x86/hwmon: fix module init for hotplug-but-no-device-found case hwmon: (lis3) Fix Oops with NULL platform data
2010-09-25ARM: pxa168fb: clear enable bit when not activeHaojian Zhuang
While fb isn't active, we should clear CFG_GRA_ENA bit. The existing code can't clear this bit. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Acked-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-09-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: USB: update Kconfig help text for CONFIG_USB_SUSPEND usb: musb: gadget: restart request on clearing endpoint halt usb: musb: host: Issue a memory barrier before starting DMA usb: musb: gadget: fix dma length in txstate usb: musb: gadget: complete request only if data is transfered over usb: musb: gadget: fix DMA length for OUT transfer usb: musb: gadget: enable autoclear for OUT transfer in both DMA 0 and DMA 1 usb: musb: gadget: fix bulk IN infinit hangs in double buffer case usb: musb: gadget: fix kernel panic if using out ep with FIFO_TXRX style USB: fix bug in initialization of interface minor numbers
2010-09-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6: Staging: ti-st: remove st_get_plat_device
2010-09-24Merge branch 'drm-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: vgaarb: trivial fix drm: radeon cleanup fixes... drm: fix trivial coding errors drm: ttm sparse fixes. drm/nouveau: fix panels using straps-based mode detection drm/ttm: Clear the ghost cpu_writers flag on ttm_buffer_object_transfer. drm/radeon: don't allow device to be opened if powered down
2010-09-24x86/hwmon: pkgtemp has no dependency on PCIJan Beulich
Other than coretemp, from which this code was apparently derived, there is no PCI specific code in this driver. Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2010-09-24x86/hwmon: register alternate sibling upon CPU removalJan Beulich
Just like pkgtemp registers another core of the same package when one gets removed, coretemp should register another hyperthread (if available) in that situation. As pointed out in the patch fixing the respective code in pkgtemp, the list protectng mutex must be dropped before calling coretemp_device_add(), and due to the restructured loop (including an explicit return) the "safe" variant of the list iterator isn't needed anymore. Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: Rudolf Marek <r.marek@assembler.cz> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2010-09-24x86/hwmon: fix initialization of pkgtempJan Beulich
Feature availability should also be checked in the hotplug code path. Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2010-09-24x86/hwmon: fix initialization of coretempJan Beulich
Using cpuid_eax() to determine feature availability on other than the current CPU is invalid. And feature availability should also be checked in the hotplug code path. Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: Rudolf Marek <r.marek@assembler.cz> Cc: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2010-09-24x86/hwmon: don't leak device attribute file from pkgtemp_probe() and ↵Jan Beulich
pkgtemp_remove() While apparently inherited from coretemp source, this particular error handling cleanup and exit path wasn't copied properly (or perhaps got discarded intermediately and not re-added properly later). Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> (added device file removal in pkgtemp_remove)
2010-09-24x86/hwmon: avoid deadlock on CPU removal in pkgtempJan Beulich
pkgtemp_device_remove(), holding the list protecting mutex, calls pkgtemp_device_add(), which itself wants to acquire the same mutex. Holding the mutex over the entire loop body in pkgtemp_device_remove() isn't really necessary, as long as the loop gets exited after processing the matched CPU. Once exiting the loop after removing an eventual match, there's no need for using the "safe" list iterator anymore. Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2010-09-24x86/hwmon: fix module init for hotplug-but-no-device-found caseJan Beulich
In commit 0dca94baeab4a1a514841b0a4c8e3a51dfb4d5ae the call to platform_driver_unregister() was made conditional upon !HOTPLUG_CPU, but the return value from coretemp_init() was left to indicate an error. This isn't correct, as the negative return value indicates to the module loader that initialization failed, which isn't intended here and results in dangling pointers. Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: Chen Gong <gong.chen@linux.intel.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2010-09-24hwmon: (lis3) Fix Oops with NULL platform dataTakashi Iwai
The recent addition of threaded irq handler causes a NULL dereference when used with hp_accel driver, which has NULL pdata. Acked-by: Samu Onkalo <samu.p.onkalo@nokia.com> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2010-09-24USB: update Kconfig help text for CONFIG_USB_SUSPENDAlan Stern
This patch (as1429) updates the Kconfig help text for CONFIG_USB_SUSPEND. The power/level file is now deprecated; we should tell people to use power/control instead. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-24usb: musb: gadget: restart request on clearing endpoint haltSergei Shtylyov
Commit 46034dca515bc4ddca0399ae58106d1f5f0d809f (USB: musb_gadget_ep0: stop abusing musb_gadget_set_halt()) forgot to restart a queued request after clearing the endpoint halt feature. This results in a couple of USB resets while enumerating the file-backed storage gadget due to CSW packet not being sent for the MODE SENSE(10) command. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: stable@kernel.org Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-24usb: musb: host: Issue a memory barrier before starting DMASantosh Shilimkar
This patch fixes the issue which was observed while transfering a large file ( > 20MB) over USB (OMAP MUSB controller acts as USB host) to an attached USB thumb drive. It was found that CDB field of CBW packet was set to 0x0. This was due to missing a barrier before DMA engine starts transfer. This buffer is allocated using dma_alloc_coherent which gives non-cacheble but bufferable memory and hence needed a write memory barrier to flush the write buffer. More info on this thread is here: http://www.spinics.net/lists/linux-omap/msg33987.html Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Signed-off-by: Maulik Mankad <x0082077@ti.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-24usb: musb: gadget: fix dma length in txstateMing Lei
DMA length should not go beyond the availabe space of request buffer, so fix it. Also set max_len of cppi dma channel as max size of int type, so make musb dma handling happier. Signed-off-by: Ming Lei <tom.leiming@gmail.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: Anand Gadiyar <gadiyar@ti.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-24usb: musb: gadget: complete request only if data is transfered overMing Lei
Complete the current request only if the data transfer is over. Signed-off-by: Ming Lei <tom.leiming@gmail.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: Anand Gadiyar <gadiyar@ti.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-24usb: musb: gadget: fix DMA length for OUT transferMing Lei
DMA length should not go beyond the availabe space of request buffer, so fix it. Signed-off-by: Ming Lei <tom.leiming@gmail.com> Acked-by: Anand Gadiyar <gadiyar@ti.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: Anand Gadiyar <gadiyar@ti.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-24usb: musb: gadget: enable autoclear for OUT transfer in both DMA 0 and DMA 1Ming Lei
This patch fixes one bugs of OUT transfer in double buffer case: -the current code only enable autoclear for dma mode 1, and not for dma mode 0 Without this patch, test #5 of usbtest can't be passed if we configure musb as g_zero and use fifo mode 3 to enable double buffer mode. With this patch and the following patch(fix dma length), on my beagle B5, test#5(queued bulk out) may go beyond 18Mbyte/s(seems dma mode 0 is quicker in double buffer case) if musb is configured as g_zero and fifo mode 3 is taken, follows the test command: #./testusb -D DEV_NAME -c 1024 -t 5 -s 32768 -g 8 [1] Also I have tested this patch can't make g_ether broken. [1],source of testusb : tools/usb/testusb.c under linux kernel; Signed-off-by: Ming Lei <tom.leiming@gmail.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: Anand Gadiyar <gadiyar@ti.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-24usb: musb: gadget: fix bulk IN infinit hangs in double buffer caseMing Lei
This patch fixes one infinite hang of bulk IN transfer in double buffer case, the hang can be observed easily by test #6 of usbtest if musb is configured as g_zero and fifo mode 3 is taken to enable double fifo. In fact, the patch only removes the check for non-empty fifo before loading data from new request into fifo since the check is not correct: -in double buffer case, fifo may accommodate more than one packet, even though it has contained one packet already and is non-empty -since last DMA is completed before calling musb_g_tx, it is sure that fifo may accommodate at least one packet Without applying the patch, new requst enqueued from .complte may not have a chance to be loaded into fifo, then will never be completed and cause infinite hangs. With the patch, on my beagle B5, test#6(queued bulk in) can be passed and test result may go beyond 33Mbyte/s if musb is configured as g_zero and fifo mode 3 is taken, follows the test command: #testusb -D DEV_NAME -c 1024 -t 6 -s 32768 -g 8 [1] [1], -source of testusb : tools/usb/testusb.c under linux kernel; Signed-off-by: Ming Lei <tom.leiming@gmail.com> Acked-by: Anand Gadiyar <gadiyar@ti.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: Anand Gadiyar <gadiyar@ti.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-24usb: musb: gadget: fix kernel panic if using out ep with FIFO_TXRX styleMing Lei
For shared fifo hw endpoint(with FIFO_TXRX style), only ep_in field of musb_hw_ep is intialized in musb_g_init_endpoints, and ep_out is not initialized, but musb_g_rx and rxstate may access ep_out field of musb_hw_ep by the method below: musb_ep = &musb->endpoints[epnum].ep_out which can cause the kernel panic[1] below, this patch fixes the issue by getting 'musb_ep' from '&musb->endpoints[epnum].ep_in' for shared fifo endpoint. [1], kernel panic [root@OMAP3EVM /]# musb_interrupt 1583: ** IRQ peripheral usb0008 tx0000 rx4000 musb_stage0_irq 460: <== Power=f0, DevCtl=99, int_usb=0x8 musb_g_rx 772: <== (null), rxcsr 4007 ffffffe8 musb_g_rx 786: iso overrun on ffffffe8 Unable to handle kernel NULL pointer dereference at virtual address 00000008 pgd = c0004000 [00000008] *pgd=00000000 Internal error: Oops: 17 [#1] PREEMPT last sysfs file: /sys/devices/platform/musb_hdrc/usb1/usb_device/usbdev1.1/dev Modules linked in: g_zero CPU: 0 Tainted: G W (2.6.35-rc6-gkh-wl+ #92) PC is at musb_g_rx+0xfc/0x2ec LR is at vprintk+0x3f4/0x458 pc : [<c02c07a4>] lr : [<c006ccb0>] psr: 20000193 sp : c760bd78 ip : c03c9d70 fp : c760bdbc r10: 00000000 r9 : fa0ab1e0 r8 : 0000000e r7 : c7e80158 r6 : ffffffe8 r5 : 00000001 r4 : 00004003 r3 : 00010003 r2 : c760bcd8 r1 : c03cd030 r0 : 0000002e Flags: nzCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment kernel Control: 10c5387d Table: 8778c019 DAC: 00000017 Process kmemleak (pid: 421, stack limit = 0xc760a2e8) Stack: (0xc760bd78 to 0xc760c000) bd60: ffffffe8 c04b1b58 bd80: ffffffe8 c7c01ac0 00000000 c7e80d24 c0084238 00000001 00000001 c7e80158 bda0: 0000000e 00000008 00000099 000000f0 c760be04 c760bdc0 c02bcd68 c02c06b4 bdc0: 00000099 00000008 00004000 c760bdd8 c03cc4f8 00000000 00000002 c7e80158 bde0: c7d2e300 60000193 c760a000 0000005c 00000000 00000000 c760be24 c760be08 be00: c02bcecc c02bc1ac c7d2e300 c7d2e300 0000005c c760a000 c760be54 c760be28 be20: c00ad698 c02bce6c 00000000 c7d2e300 c067c258 0000005c c067c294 00000001 be40: c760a000 00000000 c760be74 c760be58 c00af984 c00ad5fc 0000005c 00000000 be60: 00000000 00000002 c760be8c c760be78 c0039080 c00af8d0 ffffffff fa200000 be80: c760beec c760be90 c0039b6c c003900c 00000001 00000000 c7d1e240 00000000 bea0: 00000000 c068bae8 00000000 60000013 00000001 00000000 00000000 c760beec bec0: c0064ecc c760bed8 c00ff7d0 c003a0a8 60000013 ffffffff 00000000 c068bae8 bee0: c760bf24 c760bef0 c00ff7d0 c0064ec4 00000001 00000000 c00ff700 00000000 bf00: c0087f00 00000000 60000013 c0d76a70 c0e23795 00000001 c760bf4c c760bf28 bf20: c00ffdd8 c00ff70c c068bb08 c068bae8 60000013 c0100938 c068bb30 00000000 bf40: c760bf84 c760bf50 c010014c c00ffd84 00000001 00000000 c010000c 00012c00 bf60: c7c33f04 00012c00 c7c33f04 00000000 c0100938 00000000 c760bf9c c760bf88 bf80: c01009a8 c0100018 c760bfa8 c7c33f04 c760bff4 c760bfa0 c0088000 c0100944 bfa0: c760bf98 00000000 00000000 00000001 dead4ead ffffffff ffffffff c08ba2bc bfc0: 00000000 c049e7fa 00000000 c0087f70 c760bfd0 c760bfd0 c7c33f04 c0087f70 bfe0: c006f5e8 00000013 00000000 c760bff8 c006f5e8 c0087f7c 7f0004ff df2000ff Backtrace: [<c02c06a8>] (musb_g_rx+0x0/0x2ec) from [<c02bcd68>] (musb_interrupt+0xbc8/0xcc0) [<c02bc1a0>] (musb_interrupt+0x0/0xcc0) from [<c02bcecc>] (generic_interrupt+0x6c/0x84) [<c02bce60>] (generic_interrupt+0x0/0x84) from [<c00ad698>] (handle_IRQ_event+0xa8/0x1ec) r7:c760a000 r6:0000005c r5:c7d2e300 r4:c7d2e300 [<c00ad5f0>] (handle_IRQ_event+0x0/0x1ec) from [<c00af984>] (handle_level_irq+0xc0/0x13c) [<c00af8c4>] (handle_level_irq+0x0/0x13c) from [<c0039080>] (asm_do_IRQ+0x80/0xa0) r7:00000002 r6:00000000 r5:00000000 r4:0000005c [<c0039000>] (asm_do_IRQ+0x0/0xa0) from [<c0039b6c>] (__irq_svc+0x4c/0xb4) Exception stack(0xc760be90 to 0xc760bed8) be80: 00000001 00000000 c7d1e240 00000000 bea0: 00000000 c068bae8 00000000 60000013 00000001 00000000 00000000 c760beec bec0: c0064ecc c760bed8 c00ff7d0 c003a0a8 60000013 ffffffff r5:fa200000 r4:ffffffff [<c0064eb8>] (sub_preempt_count+0x0/0x100) from [<c00ff7d0>] (find_and_get_object+0xd0/0x110) r5:c068bae8 r4:00000000 [<c00ff700>] (find_and_get_object+0x0/0x110) from [<c00ffdd8>] (scan_block+0x60/0x104) r8:00000001 r7:c0e23795 r6:c0d76a70 r5:60000013 r4:00000000 [<c00ffd78>] (scan_block+0x0/0x104) from [<c010014c>] (kmemleak_scan+0x140/0x484) [<c010000c>] (kmemleak_scan+0x0/0x484) from [<c01009a8>] (kmemleak_scan_thread+0x70/0xcc) r8:00000000 r7:c0100938 r6:00000000 r5:c7c33f04 r4:00012c00 [<c0100938>] (kmemleak_scan_thread+0x0/0xcc) from [<c0088000>] (kthread+0x90/0x98) r5:c7c33f04 r4:c760bfa8 [<c0087f70>] (kthread+0x0/0x98) from [<c006f5e8>] (do_exit+0x0/0x684) r7:00000013 r6:c006f5e8 r5:c0087f70 r4:c7c33f04 Code: e3002312 e58d6000 e2833e16 eb0422d5 (e5963020) ---[ end trace f3d5e96f75c297b7 ]--- Signed-off-by: Ming Lei <tom.leiming@gmail.com> Reviewed-by: Sergei Shtylyov <sshtylyov@mvista.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: Anand Gadiyar <gadiyar@ti.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: stable <stable@kernel.org> Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-24USB: fix bug in initialization of interface minor numbersAlan Stern
Recent changes in the usbhid layer exposed a bug in usbcore. If CONFIG_USB_DYNAMIC_MINORS is enabled then an interface may be assigned a minor number of 0. However interfaces that aren't registered as USB class devices also have their minor number set to 0, during initialization. As a result usb_find_interface() may return the wrong interface, leading to a crash. This patch (as1418) fixes the problem by initializing every interface's minor number to -1. It also cleans up the usb_register_dev() function, which besides being somewhat awkwardly written, does not unwind completely on all its error paths. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Tested-by: Philip J. Turmel <philip@turmel.org> Tested-by: Gabriel Craciunescu <nix.or.die@googlemail.com> Tested-by: Alex Riesen <raa.lkml@gmail.com> Tested-by: Matthias Bayer <jackdachef@gmail.com> CC: Jiri Kosina <jkosina@suse.cz> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-24Staging: ti-st: remove st_get_plat_devicePavan Savoy
In order to support multiple ST platform devices, a new symbol 'st_get_plat_device' earlier needed to be exported by the arch/XX/brd-XX.c file which intends to add the ST platform device. On removing this dependency, now inside ST driver maintain the array of ST platform devices that would be registered. As of now let id=0, as and when we end up having such platforms where mutliple ST devices can exist, id would come from protocol drivers (BT, FM and GPS) as to on which platform device they want to register to. Signed-off-by: Pavan Savoy <pavan_savoy@ti.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Anca Emanuel <anca.emanuel@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-09-24vgaarb: trivial fixDaniel J Blueman
Correct function being needlessly visible outside compilation unit when the only users are internal. Signed-off-by: Daniel J Blueman <daniel.blueman@gmail.com> Reviewed-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-09-24drm: radeon cleanup fixes...Daniel J Blueman
Fix string interpreted as trigraph and typo. Signed-off-by: Daniel J Blueman <daniel.blueman@gmail.com> Reviewed-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-09-24drm: fix trivial coding errorsDaniel J Blueman
Correct function storage class, and correct assignment type. Signed-off-by: Daniel J Blueman <daniel.blueman@gmail.com> Reviewed-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-09-24drm: ttm sparse fixes.Daniel J Blueman
Correct allocation flags type and function prototype for ANSI C compliance. [airlied: whitespace fixed] Signed-off-by: Daniel J Blueman <daniel.blueman@gmail.com> Reviewed-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-09-24drm/nouveau: fix panels using straps-based mode detectionBen Skeggs
nouveau_bios_fp_mode() zeroes the mode struct before filling in relevant entries. This nukes the mode id initialised by drm_mode_create(), and causes warnings from idr when we try to remove the mode. Signed-off-by: Ben Skeggs <bskeggs@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-09-23thinkpad-acpi: avoid keymap pitfallHenrique de Moraes Holschuh
Change the code so that it will use the correct size for keymap entries. Do it in a way that makes it harder to screw it up in the future. Reported-by: Jaime Velasco Juan <jsagarribay@gmail.com> Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2010-09-23drm/i915/sdvo: Handle unsupported GET_SUPPORTED_ENHANCEMENTS gracefullyChris Wilson
In the event that the external chipset doesn't implement the GET_SUPPORTED_ENHANCEMENTS commands, gracefully treat it as having no enhancments rather than bailing. Reported-and-tested-by: Woody Suwalski <terraluna977@gmail.com> Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=18342 Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2010-09-23drm/i915/sdvo: Cleanup connector on error pathChris Wilson
We weren't unlinking the freed connector from the drm lists, and so hit some use-after-free if we failed to initialise the connector. Reported-and-tested-by: Woody Suwalski <terraluna977@gmail.com> Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=18342 Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2010-09-23Merge branch 'for-rmk' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/nico/orion
2010-09-23drm/i915: Fix 945GM regression in e259befdChris Wilson
A minor typo caused a single fence register to be incorrectly programmed, resulting in occassional tiling corruption. Reported-and-tested-by: Hans de Bruin <bruinjm@xs4all.nl> Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=18962 Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: stable@kernel.org
2010-09-22ipmi: fix hardcoded ipmi device exit path warningYinghai Lu
When modprobe.conf has options ipmi_si type="kcs" ports=0xCA2 regspacings="4" ipmi_si can be loaded properly, but when try to unload it get: Sep 20 15:00:27 xx abrt: Kerneloops: Reported 1 kernel oopses to Abrt Sep 20 15:00:27 xx abrtd: Directory 'kerneloops-1285020027-1' creation detected Sep 20 15:00:27 xx abrtd: New crash /var/spool/abrt/kerneloops-1285020027-1, processing Sep 20 15:01:09 xx kernel: ------------[ cut here ]------------ Sep 20 15:01:09 xx kernel: WARNING: at drivers/base/driver.c:262 driver_unregister+0x8a/0xa0() Sep 20 15:01:09 xx kernel: Hardware name: Sun Fire x4800 Sep 20 15:01:09 xx kernel: Unexpected driver unregister! Sep 20 15:01:09 xx kernel: Modules linked in: ipmi_si(-) ipmi_msghandler ip6table_filter ip6_tables ebtable_nat ebtables ipt_MASQUERADE iptable_nat nf_nat bridge stp llc autofs4 sunrpc cpufreq_ondemand acpi_cpufreq freq_table mperf xt_physdev be2iscsi iscsi_boot_sysfs bnx2i cnic uio cxgb3i iw_cxgb3 cxgb3 mdio ib_iser rdma_cm ib_cm iw_cm ib_sa ib_mad ib_core ib_addr ipv6 iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi dm_mirror dm_region_hash dm_log dm_mod vhost_net macvtap macvlan tun kvm_intel kvm uinput sg ses enclosure ahci libahci pcspkr i2c_i801 i2c_core iTCO_wdt iTCO_vendor_support igb dca i7core_edac edac_core ext3 jbd mbcache sd_mod crc_t10dif megaraid_sas [last unloaded: ipmi_devintf] Sep 20 15:01:09 xx kernel: Pid: 10625, comm: modprobe Tainted: G W 2.6.36-rc5-tip+ #6 Sep 20 15:01:09 xx kernel: Call Trace: Sep 20 15:01:09 xx kernel: [<ffffffff810600df>] warn_slowpath_common+0x7f/0xc0 Sep 20 15:01:09 xx kernel: [<ffffffff810601d6>] warn_slowpath_fmt+0x46/0x50 Sep 20 15:01:09 xx kernel: [<ffffffff812ff60a>] driver_unregister+0x8a/0xa0 Sep 20 15:01:09 xx kernel: [<ffffffff812ae112>] pnp_unregister_driver+0x12/0x20 Sep 20 15:01:09 xx kernel: [<ffffffffa01d0327>] cleanup_ipmi_si+0x3c/0xa7 [ipmi_si] Sep 20 15:01:09 xx kernel: [<ffffffff81099a60>] sys_delete_module+0x1a0/0x270 Sep 20 15:01:09 xx kernel: [<ffffffff814b7070>] ? do_page_fault+0x150/0x320 Sep 20 15:01:09 xx kernel: [<ffffffff8100b072>] system_call_fastpath+0x16/0x1b Sep 20 15:01:09 xx kernel: ---[ end trace 0d1967161adcee0d ]--- We need to check if ipmi_pnp_driver is loaded before we try to unload it. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Cc: Corey Minyard <minyard@acm.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-22rtc: s3c: balance state changes of wakeup flagVladimir Zapolskiy
This change resolves a problem about unbalanced calls of enable_irq_wakeup() and disable_irq_wakeup() for alarm interrupt. Bug reproduction: root@eb600:~# echo 0 > /sys/class/rtc/rtc0/wakealarm WARNING: at kernel/irq/manage.c:361 set_irq_wake+0x7c/0xe4() Unbalanced IRQ 46 wake disable Modules linked in: [<c0025708>] (unwind_backtrace+0x0/0xd8) from [<c003358c>] (warn_slowpath_common+0x44/0x5c) [<c003358c>] (warn_slowpath_common+0x44/0x5c) from [<c00335dc>] (warn_slowpath_fmt+0x24/0x30) [<c00335dc>] (warn_slowpath_fmt+0x24/0x30) from [<c0058c20>] (set_irq_wake+0x7c/0xe4) [<c0058c20>] (set_irq_wake+0x7c/0xe4) from [<c01b5e80>] (s3c_rtc_setalarm+0xa8/0xb8) [<c01b5e80>] (s3c_rtc_setalarm+0xa8/0xb8) from [<c01b47a0>] (rtc_set_alarm+0x60/0x74) [<c01b47a0>] (rtc_set_alarm+0x60/0x74) from [<c01b5a98>] (rtc_sysfs_set_wakealarm+0xc8/0xd8) [<c01b5a98>] (rtc_sysfs_set_wakealarm+0xc8/0xd8) from [<c01891ec>] (dev_attr_store+0x20/0x24) [<c01891ec>] (dev_attr_store+0x20/0x24) from [<c00be934>] (sysfs_write_file+0x104/0x13c) [<c00be934>] (sysfs_write_file+0x104/0x13c) from [<c0080e7c>] (vfs_write+0xb0/0x158) [<c0080e7c>] (vfs_write+0xb0/0x158) from [<c0080fcc>] (sys_write+0x3c/0x68) [<c0080fcc>] (sys_write+0x3c/0x68) from [<c0020ec0>] (ret_fast_syscall+0x0/0x28) Signed-off-by: Vladimir Zapolskiy <vzapolskiy@gmail.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Ben Dooks <ben@fluff.org.uk> Cc: Atul Dahiya <atul.dahiya@samsung.com> Cc: Taekgyun Ko <taeggyun.ko@samsung.com> Cc: Kukjin Kim <kgene.kim@samsung.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-22drivers/pci/intel-iommu.c: fix build with older gcc'sAndrew Morton
drivers/pci/intel-iommu.c: In function `__iommu_calculate_agaw': drivers/pci/intel-iommu.c:437: sorry, unimplemented: inlining failed in call to 'width_to_agaw': function body not available drivers/pci/intel-iommu.c:445: sorry, unimplemented: called from here Move the offending function (and its siblings) to top-of-file, remove the forward declaration. Addresses https://bugzilla.kernel.org/show_bug.cgi?id=17441 Reported-by: Martin Mokrejs <mmokrejs@ribosome.natur.cuni.cz> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-22drivers/video/sis/sis_main.c: prevent reading uninitialized stack memoryDan Rosenberg
The FBIOGET_VBLANK device ioctl allows unprivileged users to read 16 bytes of uninitialized stack memory, because the "reserved" member of the fb_vblank struct declared on the stack is not altered or zeroed before being copied back to the user. This patch takes care of it. Signed-off-by: Dan Rosenberg <dan.j.rosenberg@gmail.com> Cc: Thomas Winischhofer <thomas@winischhofer.net> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-22fbcon: fix lockdep warning from fbcon_deinit()Jarek Poplawski
Fix the lockdep warning: [ 13.657164] INFO: trying to register non-static key. [ 13.657169] the code is fine but needs lockdep annotation. [ 13.657171] turning off the locking correctness validator. [ 13.657177] Pid: 622, comm: modprobe Not tainted 2.6.36-rc3c #8 [ 13.657180] Call Trace: [ 13.657194] [<c13002c8>] ? printk+0x18/0x20 [ 13.657202] [<c1056cf6>] register_lock_class+0x336/0x350 [ 13.657208] [<c1058bf9>] __lock_acquire+0x449/0x1180 [ 13.657215] [<c1059997>] lock_acquire+0x67/0x80 [ 13.657222] [<c1042bf1>] ? __cancel_work_timer+0x51/0x230 [ 13.657227] [<c1042c23>] __cancel_work_timer+0x83/0x230 [ 13.657231] [<c1042bf1>] ? __cancel_work_timer+0x51/0x230 [ 13.657236] [<c10582b2>] ? mark_held_locks+0x62/0x80 [ 13.657243] [<c10b3a2f>] ? kfree+0x7f/0xe0 [ 13.657248] [<c105853c>] ? trace_hardirqs_on_caller+0x11c/0x160 [ 13.657253] [<c105858b>] ? trace_hardirqs_on+0xb/0x10 [ 13.657259] [<c117f4cd>] ? fbcon_deinit+0x16d/0x1e0 [ 13.657263] [<c117f4cd>] ? fbcon_deinit+0x16d/0x1e0 [ 13.657268] [<c1042dea>] cancel_work_sync+0xa/0x10 [ 13.657272] [<c117f444>] fbcon_deinit+0xe4/0x1e0 ... The warning is caused by trying to cancel an uninitialized work from fbcon_exit(). Fix it by adding a check for queue.func, similarly to other places in this code. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
