path: root/drivers
2008-07-25gpio: max732x driverEric Miao
This adds a driver supporting a family of I2C port expanders from Maxim, which includes the MAX7319 and MAX7320-7327 chips. [dbrownell@users.sourceforge.net: minor fixes] Signed-off-by: Jack Ren <jack.ren@marvell.com> Signed-off-by: Eric Miao <eric.miao@marvell.com> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25gpiolib: allow user-selectionMichael Buesch
This patch adds functionality to the gpio-lib subsystem to make it possible to enable the gpio-lib code even if the architecture code didn't request to get it built in. The archtitecture code does still need to implement the gpiolib accessor functions in its asm/gpio.h file. This patch adds the implementations for x86 and PPC. With these changes it is possible to run generic GPIO expansion cards on every architecture that implements the trivial wrapper functions. Support for more architectures can easily be added. Signed-off-by: Michael Buesch <mb@bu3sch.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: David Brownell <david-b@pacbell.net> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Jean Delvare <khali@linux-fr.org> Cc: Samuel Ortiz <sameo@openedhand.com> Cc: Kumar Gala <galak@gate.crashing.org> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25gpio: add bt8xxgpio driverMichael Buesch
This adds the bt8xxgpio driver. The purpose of the bt8xxgpio driver is to export all of the 24 GPIO pins available on Brooktree 8xx chips to the kernel GPIO infrastructure. This makes it possible to use a physically modified BT8xx card as cheap digital GPIO card. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Michael Buesch <mb@bu3sch.de> Cc: David Brownell <david-b@pacbell.net> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25gpio: mcp23s08 handles multiple chips per chipselectDavid Brownell
Teach the mcp23s08 driver about a curious feature of these chips: up to four of them can share the same chipselect, with the SPI signals wired in parallel, by matching two bits in the first protocol byte against two address lines on the chip. This is handled by three software changes: * Platform data now holds an array of per-chip structs, not just one chip's address and pullup configuration. * Probe() and remove() now use another level of structure, wrapping an instance of the original structure for each mcp23s08 chip sharing that chipselect. * The HAEN bit is set, so that the hardware address bits can no longer be ignored (boot firmware may not have enabled them). The "one struct per chip" preserves the guts of the current code, but platform_data will need minor changes. OLD: /* incorrect "slave" ID may not have mattered */ .slave = 3, .pullups = BIT(3) | BIT(1) | BIT(0), NEW: /* slave address _must_ match chip's wiring */ .chip[3] = { .is_present = true, .pullups = BIT(3) | BIT(1) | BIT(0), }, There's no change in how things _behave_ for spi_device nodes with a single mcp23s08 chip. New multi-chip configurations assign GPIOs in sequence, without holes. The spi_device just resembles a bigger controller, but internally it has multiple gpio_chip instances. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25gpio: sysfs interfaceDavid Brownell
This adds a simple sysfs interface for GPIOs. /sys/class/gpio /export ... asks the kernel to export a GPIO to userspace /unexport ... to return a GPIO to the kernel /gpioN ... for each exported GPIO #N /value ... always readable, writes fail for input GPIOs /direction ... r/w as: in, out (default low); write high, low /gpiochipN ... for each gpiochip; #N is its first GPIO /base ... (r/o) same as N /label ... (r/o) descriptive, not necessarily unique /ngpio ... (r/o) number of GPIOs; numbered N .. N+(ngpio - 1) GPIOs claimed by kernel code may be exported by its owner using a new gpio_export() call, which should be most useful for driver debugging. Such exports may optionally be done without a "direction" attribute. Userspace may ask to take over a GPIO by writing to a sysfs control file, helping to cope with incomplete board support or other "one-off" requirements that don't merit full kernel support: echo 23 > /sys/class/gpio/export ... will gpio_request(23, "sysfs") and gpio_export(23); use /sys/class/gpio/gpio-23/direction to (re)configure it, when that GPIO can be used as both input and output. echo 23 > /sys/class/gpio/unexport ... will gpio_free(23), when it was exported as above The extra D-space footprint is a few hundred bytes, except for the sysfs resources associated with each exported GPIO. The additional I-space footprint is about two thirds of the current size of gpiolib (!). Since no /dev node creation is involved, no "udev" support is needed. Related changes: * This adds a device pointer to "struct gpio_chip". When GPIO providers initialize that, sysfs gpio class devices become children of that device instead of being "virtual" devices. * The (few) gpio_chip providers which have such a device node have been updated. * Some gpio_chip drivers also needed to update their module "owner" field ... for which missing kerneldoc was added. * Some gpio_chips don't support input GPIOs. Those GPIOs are now flagged appropriately when the chip is registered. Based on previous patches, and discussion both on and off LKML. A Documentation/ABI/testing/sysfs-gpio update is ready to submit once this merges to mainline. [akpm@linux-foundation.org: a few maintenance build fixes] Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> Cc: Greg KH <greg@kroah.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25mfd: sm501 fix gpio number calculation for upper bankBen Dooks
The sm501_gpio_pin2nr() routine returns the wrong values for gpios in the upper bank. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25mfd: sm501 build fixes when CONFIG_MFD_SM501_GPIO unsetBen Dooks
Fix the build problems if CONFIG_MFD_SM501_GPIO is not set, which is generally when there is no gpiolib support available as currently happens on x86 when building PCI SM501. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Tested-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25sm501: fixes for akpms comments on gpiolib additionBen Dooks
Fixup the comments from the patch that added the gpiolib support from Andrew Morton. These include spotting some missing frees on error or release, and changing a memcpy for a type-safe assingment. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25sm501: gpio I2C supportBen Dooks
Add support for adding the GPIO based I2C resources. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Cc: Arnaud Patard <apatard@mandriva.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25sm501: gpio dynamic registration for PCI devicesArnaud Patard
The SM501 PCI card requires a dyanmic gpio allocation as the number of cards is not known at compile time. Fixup the platform data and registration to deal with this. Acked-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Arnaud Patard <apatard@mandriva.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25sm501: add gpiolib supportBen Dooks
Add support for exporting the GPIOs on the SM501 via gpiolib. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Cc: Arnaud Patard <apatard@mandriva.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25sm501: add power control callbackBen Dooks
Add callback to get or set the power control if the device has the sleep connected to some form of GPIO. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Cc: Arnaud Patard <apatard@mandriva.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25Rename WARN() to WARNING() to clear the namespaceArjan van de Ven
We want to use WARN() as a variant of WARN_ON(), however a few drivers are using WARN() internally. This patch renames these to WARNING() to avoid the namespace clash. A few cases were defining but not using the thing, for those cases I just deleted the definition. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Greg KH <greg@kroah.com> Cc: Karsten Keil <kkeil@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25drivers/misc/hpilo.c needs CONFIG_PCIAndrew Morton
m68k allmodconfig: drivers/misc/hpilo.c: In function 'ilo_ccb_close': drivers/misc/hpilo.c:225: error: implicit declaration of function 'pci_free_consistent' drivers/misc/hpilo.c: In function 'ilo_ccb_open': drivers/misc/hpilo.c:244: error: implicit declaration of function 'pci_alloc_consistent' drivers/misc/hpilo.c:245: warning: assignment makes pointer from integer without a cast Cc: David Altobelli <david.altobelli@hp.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25parport: fix platform driver hotplug/coldplugKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf (platform: prefix MODALIAS with "platform:"), the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable parport platform drivers, to re-enable auto loading. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Greg KH <greg@kroah.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Acked-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25mfd: fix platform driver hotplug/coldplugKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf (platform: prefix MODALIAS with "platform:"), the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the MFD platform drivers, to re-enable auto loading. [dbrownell@users.sourceforge.net: one was missing] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Greg KH <greg@kroah.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25drivers/power: fix platform driver hotplug/coldplugKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf ("platform: prefix MODALIAS with "platform:"), the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable "power" drivers drivers, to re-enable auto loading. [dbrownell@users.sourceforge.net: one was missing] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Greg KH <greg@kroah.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25misc: add HP WMI laptop extras driverMatthew Garrett
This driver adds support for reading and configuring certain information on modern HP laptops with WMI BIOS interfaces. It supports enabling and disabling the ambient light sensor, querying attached displays and hard drive temperature, sending events on docking and querying the state of the dock and toggling the state of the wifi, bluetooth and wwan hardware via rfkill. It also makes the little "(i)" button work on machines that send that via WMI rather than via the keyboard controller. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25remove some more tipar bitsAdrian Bunk
Some bits were missed when the tipar driver was removed. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25mfd: don't use memzeroAndrew Morton
For it doesn't exist on i386. Cc: Ian Molton <spyro@f2s.com> Cc: Dmitry Baryshkov <dbaryshkov@gmail.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25char/xilinx_hwicap/xilinx_hwicap.c: Removed duplicated includeHuang Weiyi
Removed duplicated include file <linux/version.h> in char/xilinx_hwicap/xilinx_hwicap.c. Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25Undo duplicate "m68k: drivers/input/serio/hp_sdc.c needs <linux/semaphore.h>"Linus Torvalds
Both commits 0f17e4c796e89d1f69f13b653aba60e6ccfb8ae0 ("Add missing semaphore.h includes") and 4933d07531711e399d8d578036aa9fc1be2f9b20 ("m68k: drivers/input/serio/hp_sdc.c needs <linux/semaphore.h>") added a We only really need one ;) Reported-by: Huang Weiyi <weiyi.huang@gmail.com> Requested-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25virtio: Add transport feature handling stub for virtio_ring.Rusty Russell
To prepare for virtio_ring transport feature bits, hook in a call in all the users to manipulate them. This currently just clears all the bits, since it doesn't understand any features. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-07-25virtio: Rename set_features to finalize_featuresRusty Russell
Rather than explicitly handing the features to the lower-level, we just hand the virtio_device and have it set the features. This make it clear that it has the chance to manipulate the features of the device at this point (and that all feature negotiation is already done). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-07-25virtio: Formally reserve bits 28-31 to be 'transport' features.Rusty Russell
We assign feature bits as required, but it makes sense to reserve some for the particular transport, rather than the particular device. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-07-25s390: use virtio_console for KVM on s390Christian Borntraeger
This patch enables virtio_console as the default console on kvm for s390. We currently use the same notify hack as lguest for early console output. I will try to address this for lguest and s390 later. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-07-25virtio: console as a config optionChristian Borntraeger
I also added a small Kconfig change that allows the user to specify the virtio console in menuconfig. (Fixes to export symbols from Stephen Rothwell <sfr@canb.auug.org.au>) (Fixes for CONFIG_VIRTIO_CONSOLE=y vs CONFIG_VIRTIO=m from Christian himself) Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Stephen Rothwell <sfr@canb.auug.org.au>
2008-07-25virtio_console: use virtqueue notification for hvc_consoleChristian Borntraeger
This patch exploits the new notifier callbacks of the hvc_console. We can use the virtio callbacks instead of the polling code. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-07-25hvc_console: rework setup to replace irq functions with callbacksChristian Borntraeger
This patch tries to change hvc_console to not use request_irq/free_irq if the backend does not use irqs. This allows virtio_console to use hvc_console without having a linker reference to request_irq/free_irq. In addition, together with patch 2/3 it improves the performance for virtio console input. (an earlier version of this patch was tested by Yajin on lguest) The irq specific code is moved to hvc_irq.c and selected by the drivers that use irqs (System p, System i, XEN). I replaced "int irq" with the opaque "int data". The request_irq and free_irq calls are replaced with notifier_add and notifier_del. I have also changed the code a bit to call the notifier_add and notifier_del inside the spinlock area as the callbacks are found via hp->ops. Changes since last version: o remove ifdef o reintroduce "irq_requested" as "notified" o cleanups, sparse.. I did not move the timer based polling into a separate polling scheme. I played with several variants, but it seems we need to sleep/schedule in a thread even for irq based consoles, as there are throttleing and buffer size constraints. I also kept hvc_struct defined in hvc_console.h so that hvc_irq.c can access the irq_requested element. Feedback is appreciated. virtio_console is currently the only available console for kvm on s390. I plan to push this change as soon as all affected parties agree on it. I would love to get test results from System p, Xen etc. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-07-25virtio_blk: check for hardsector size from hostChristian Borntraeger
Currently virtio_blk assumes a 512 byte hard sector size. This can cause trouble / performance issues if the backing has a different block size (like a file on an ext3 file system formatted with 4k block size or a dasd). Lets add a feature flag that tells the guest to use a different hard sector size than 512 byte. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-07-25virtio: Use bus_type probe and remove methodsMark McLoughlin
Hook up to the probe() and remove() methods in bus_type rather than device_driver. The latter has been preferred since 2.6.16. Signed-off-by: Mark McLoughlin <markmc@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-07-25virtio: don't always force a notification when ring is fullRusty Russell
We force notification when the ring is full, even if the host has indicated it doesn't want to know. This seemed like a good idea at the time: if we fill the transmit ring, we should tell the host immediately. Unfortunately this logic also applies to the receiving ring, which is refilled constantly. We should introduce real notification thesholds to replace this logic. Meanwhile, removing the logic altogether breaks the heuristics which KVM uses, so we use a hack: only notify if there are outgoing parts of the new buffer. Here are the number of exits with lguest's crappy network implementation: Before: network xmit 7859051 recv 236420 After: network xmit 7858610 recv 118136 Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-07-25virtio: Recycle unused recv buffer pages for large skbs in net driverRusty Russell
If we hack the virtio_net driver to always allocate full-sized (64k+) skbuffs, the driver slows down (lguest numbers): Time to receive 1GB (small buffers): 10.85 seconds Time to receive 1GB (64k+ buffers): 24.75 seconds Of course, large buffers use up more space in the ring, so we increase that from 128 to 2048: Time to receive 1GB (64k+ buffers, 2k ring): 16.61 seconds If we recycle pages rather than using alloc_page/free_page: Time to receive 1GB (64k+ buffers, 2k ring, recycle pages): 10.81 seconds This demonstrates that with efficient allocation, we don't need to have a separate "small buffer" queue. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-07-25virtio net: Allow receiving SG packetsHerbert Xu
Finally this patch lets virtio_net receive GSO packets in addition to sending them. This can definitely be optimised for the non-GSO case. For comparison the Xen approach stores one page in each skb and uses subsequent skb's pages to construct an SG skb instead of preallocating the maximum amount of pages per skb. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (added feature bits)
2008-07-25virtio net: Add ethtool ops for SG/GSOHerbert Xu
This patch adds some basic ethtool operations to virtio_net so I could test SG without GSO (which was really useful because TSO turned out to be buggy :) Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (remove MTU setting)
2008-07-25virtio: fix virtio_net xmit of freed skb bugMark McLoughlin
On Mon, 2008-05-26 at 17:42 +1000, Rusty Russell wrote: > If we fail to transmit a packet, we assume the queue is full and put > the skb into last_xmit_skb. However, if more space frees up before we > xmit it, we loop, and the result can be transmitting the same skb twice. > > Fix is simple: set skb to NULL if we've used it in some way, and check > before sending. ... > diff -r 564237b31993 drivers/net/virtio_net.c > --- a/drivers/net/virtio_net.c Mon May 19 12:22:00 2008 +1000 > +++ b/drivers/net/virtio_net.c Mon May 19 12:24:58 2008 +1000 > @@ -287,21 +287,25 @@ again: > free_old_xmit_skbs(vi); > > /* If we has a buffer left over from last time, send it now. */ > - if (vi->last_xmit_skb) { > + if (unlikely(vi->last_xmit_skb)) { > if (xmit_skb(vi, vi->last_xmit_skb) != 0) { > /* Drop this skb: we only queue one. */ > vi->dev->stats.tx_dropped++; > kfree_skb(skb); > + skb = NULL; > goto stop_queue; > } > vi->last_xmit_skb = NULL; With this, may drop an skb and then later in the function discover that we could have sent it after all. Poor wee skb :) How about the incremental patch below? Cheers, Mark. Subject: [PATCH] virtio_net: Delay dropping tx skbs Currently we drop the skb in start_xmit() if we have a queued buffer and fail to transmit it. However, if we delay dropping it until we've stopped the queue and enabled the tx notification callback, then there is a chance space might become available for it. Signed-off-by: Mark McLoughlin <markmc@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-07-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6: (76 commits) ide: use proper printk() KERN_* levels in ide-probe.c ide: fix for EATA SCSI HBA in ATA emulating mode ide: remove stale comments from drivers/ide/Makefile ide: enable local IRQs in all handlers for TASKFILE_NO_DATA data phase ide-scsi: remove kmalloced struct request ht6560b: remove old history ht6560b: update email address ide-cd: fix oops when using growisofs gayle: release resources on ide_host_add() failure palm_bk3710: add UltraDMA/100 support ide: trivial sparse annotations ide: ide-tape.c sparse annotations and unaligned access removal ide: drop 'name' parameter from ->init_chipset method ide: prefix messages from IDE PCI host drivers by driver name it821x: remove DECLARE_ITE_DEV() macro it8213: remove DECLARE_ITE_DEV() macro ide: include PCI device name in messages from IDE PCI host drivers ide: remove <asm/ide.h> for some archs ide-generic: remove ide_default_{io_base,irq}() inlines (take 3) ide-generic: is no longer needed on ppc32 ...
2008-07-24Merge branch 'release-2.6.27' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-acpi-2.6 * 'release-2.6.27' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-acpi-2.6: acpi: fix crash in core ACPI code, triggered by CONFIG_ACPI_PCI_SLOT=y ACPI: thinkpad-acpi: don't misdetect in get_thinkpad_model_data() on -ENOMEM ACPI: thinkpad-acpi: bump up version to 0.21 ACPI: thinkpad-acpi: add bluetooth and WWAN rfkill support ACPI: thinkpad-acpi: WLSW overrides other rfkill switches ACPI: thinkpad-acpi: prepare for bluetooth and wwan rfkill support ACPI: thinkpad-acpi: consolidate wlsw notification function ACPI: thinkpad-acpi: minor refactor on radio switch init Revert "ACPI: don't walk tables if ACPI was disabled" Revert "dock: bay: Don't call acpi_walk_namespace() when ACPI is disabled." Revert "Fix FADT parsing" ACPI : Set FAN device to correct state in boot phase ACPI: Ignore _BQC object when registering backlight device ACPI: stop complaints about interrupt link End Tags and blank IRQ descriptors
2008-07-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: PCI: fixup sparse endianness warnings in proc.c PCI PM: make more PCI PM core functionality available to drivers PCI/DMAR: don't assume presence of RMRRs PCI hotplug: fix error path in pci_slot's register_slot
2008-07-24ide: use proper printk() KERN_* levels in ide-probe.cBartlomiej Zolnierkiewicz
While at it: - fixup printk() messages in save_match() and hwif_init(). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-24ide: fix for EATA SCSI HBA in ATA emulating modeBartlomiej Zolnierkiewicz
IDE probing code used to skip devices attached to EATA SCSI HBA in ATA emulating mode but because of warm-plug support port I/O resources are no longer freed if no devices are detected on a port and the decision about the driver to use is left up to the user. Remove no longer valid EATA SCSI HBA quirk from do_identify(). Noticed-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-24ide: remove stale comments from drivers/ide/MakefileBartlomiej Zolnierkiewicz
2008-07-24ide: enable local IRQs in all handlers for TASKFILE_NO_DATA data phaseBartlomiej Zolnierkiewicz
It is already done by task_no_data_intr() and there is no reason not to do it in other TASKFILE_NO_DATA data phase handlers. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-24ide-scsi: remove kmalloced struct requestFUJITA Tomonori
This converts ide-scsi to use blk_get/put_request instead of kmalloc/kfree. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-24ht6560b: remove old historyJan Evert van Grootheest
Remove the ancient version history. Git does a better job. From: Jan Evert van Grootheest <j.e.van.grootheest@caiway.nl> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-24ht6560b: update email addressJan Evert van Grootheest
Update email address. From: Jan Evert van Grootheest <j.e.van.grootheest@caiway.nl> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-24ide-cd: fix oops when using growisofsJens Axboe
cdrom_read_capacity() will blindly return the capacity from the device without sanity-checking it. This later causes code in fs/buffer.c to oops. Fix this by checking that the device is telling us sensible things. From: Jens Axboe <jens.axboe@oracle.com> Cc: Michael Buesch <mb@bu3sch.de> Cc: Jan Kara <jack@suse.cz> Cc: Arnd Bergmann <arnd@arndb.de> Cc: <stable@kernel.org> Cc: Borislav Petkov <petkovbb@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> [bart: print device name instead of driver name] Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> [harvey: blocklen is a big-endian value] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-24gayle: release resources on ide_host_add() failureBartlomiej Zolnierkiewicz
"gayle: reserve memory resources at once" patch temporary removed freeing of resources on failure (to ease convertion to ide_host_add() interface). This patch fixes it. Thanks to Geert for noticing the issue. Noticed-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-24palm_bk3710: add UltraDMA/100 supportSergei Shtylyov
This controller supports UltraDMA up to mode 5 but it should be clocked with at least twice the data strobe frequency, so enable mode 5 for 100+ MHz IDECLK. While at it, start passing the correct device to clk_get() -- it worked anyway but WTF? :-/ Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-24ide: trivial sparse annotationsHarvey Harrison
