path: root/drivers
2010-07-30Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: cyber2000fb: fix console in truecolor modes cyber2000fb: fix machine hang on module load SA1111: Eliminate use after free ARM: Fix Versatile/Realview/VExpress MMC card detection sense ARM: 6279/1: highmem: fix SMP preemption bug in kmap_high_l1_vipt ARM: Add barriers to io{read,write}{8,16,32} accessors as well ARM: 6273/1: Add barriers to the I/O accessors if ARM_DMA_MEM_BUFFERABLE ARM: 6272/1: Convert L2x0 to use the IO relaxed operations ARM: 6271/1: Introduce *_relaxed() I/O accessors ARM: 6275/1: ux500: don't use writeb() in uncompress.h ARM: 6270/1: clean files in arch/arm/boot/compressed/ ARM: Fix csum_partial_copy_from_user()
2010-07-30Merge branch 'drm-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: drm/edid: Fix the HDTV hack sync adjustment drm/radeon/kms: fix radeon mid power profile reporting
2010-07-30cyber2000fb: fix console in truecolor modesOndrej Zary
Return value was not set to 0 in setcolreg() with truecolor modes. This causes fb_set_cmap() to abort after first color, resulting in blank palette - and blank console in 24bpp and 32bpp modes. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-30cyber2000fb: fix machine hang on module loadOndrej Zary
I was testing two CyberPro 2000 based PCI cards on x86 and the machine always hanged completely when the cyber2000fb module was loaded. It seems that the card hangs when some registers are accessed too quickly after writing RAMDAC control register. With this patch, both card work. Add delay after RAMDAC control register write to prevent hangs on module load. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-30ARM: Fix Versatile/Realview/VExpress MMC card detection senseRussell King
The MMC card detection sense has become really confused with negations at various levels, leading to some platforms not detecting inserted cards. Fix this by converting everything to positive logic throughout, thereby getting rid of these negations. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-29drm/edid: Fix the HDTV hack sync adjustmentAdam Jackson
We're adjusting horizontal timings only here, moving vsync was just a slavish translation of a typo in the X server. Signed-off-by: Adam Jackson <ajax@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-07-29drm/radeon/kms: fix radeon mid power profile reportingDaniel J Blueman
Fix incorrectly reporting 'default' power profile, when it is set to 'mid'. Signed-off-by: Daniel J Blueman <daniel.blueman@gmail.com> Reviewed-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-07-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6: [SCSI] ibmvscsi: Fix oops when an interrupt is pending during probe [SCSI] zfcp: Update status read mempool [SCSI] zfcp: Do not wait for SBALs on stopped queue [SCSI] zfcp: Fix check whether unchained ct_els is possible [SCSI] ipr: fix resource path display and formatting
2010-07-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lrg/voltage-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lrg/voltage-2.6: davinci: da850/omap-l138 evm: account for DEFDCDC{2,3} being tied high regulator: tps6507x: allow driver to use DEFDCDC{2,3}_HIGH register wm8350-regulator: fix wm8350_register_regulator error handling ab3100: fix off-by-one value range checking for voltage selector
2010-07-28regulator: tps6507x: allow driver to use DEFDCDC{2,3}_HIGH registerAnuj Aggarwal
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> In TPS6507x, depending on the status of DEFDCDC{2,3} pin either DEFDCDC{2,3}_LOW or DEFDCDC{2,3}_HIGH register needs to be read or programmed to change the output voltage. The current driver assumes DEFDCDC{2,3} pins are always tied low and thus operates only on DEFDCDC{2,3}_LOW register. This need not always be the case (as is found on OMAP-L138 EVM). Unfortunately, software cannot read the status of DEFDCDC{2,3} pins. So, this information is passed through platform data depending on how the board is wired. Signed-off-by: Anuj Aggarwal <anuj.aggarwal@ti.com> Signed-off-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-07-27gpio: fix spurious printk when freeing a gpioJon Povey
When freeing a gpio that has not been exported, gpio_unexport() prints a debug message when it should just fall through silently. Example spurious message: gpio_unexport: gpio0 status -22 Signed-off-by: Jon Povey <jon.povey@racelogic.co.uk> Cc: David Brownell <david-b@pacbell.net> Acked-by: Uwe Kleine-K?nig <u.kleine-koenig@pengutronix.de> Cc: Gregory Bean <gbean@codeaurora.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-07-27edac: mpc85xx: fix coldplug/hotplug module autoloadingAnton Vorontsov
The MPC85xx EDAC driver is missing module device aliases, so the driver won't load automatically on boot. This patch fixes the issue by adding proper MODULE_DEVICE_TABLE() macros. Signed-off-by: Anton Vorontsov <avorontsov@mvista.com> Cc: Doug Thompson <dougthompson@xmission.com> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Dave Jiang <djiang@mvista.com> Cc: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-07-27drivers/rtc/rtc-rx8581.c: fix setdatetimeRudolf Marek
Fix the logic while writing new date/time to the chip. The driver incorrectly wrote back register values to different registers and even with wrong mask. The patch adds clearing of the VLF register, which should be cleared if all date/time values are set. Signed-off-by: Rudolf Marek <rudolf.marek@sysgo.com> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Cc: Martyn Welch <martyn.welch@gefanuc.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-07-27[SCSI] ibmvscsi: Fix oops when an interrupt is pending during probeAnton Blanchard
A driver needs to be ready to take an interrupt as soon as it registers an interrupt handler. I noticed the following oops when testing kdump: ipr: IBM Power RAID SCSI Device Driver version: 2.5.0 (February 11, 2010) ibmvscsi 30000002: SRP_VERSION: 16.a ibmvscsi 30000002: SRP_VERSION: 16.a Unable to handle kernel paging request for data at address 0x00000000 ... pc: c000000004085e34: .tasklet_action+0xf4/0x1dc ... c000000004086fe4 .__do_softirq+0x16c/0x2c0 c00000000403138c .call_do_softirq+0x14/0x24 c00000000400ee14 .do_softirq+0xa0/0x104 c00000000408690c .irq_exit+0x70/0xd0 c00000000400f190 .do_IRQ+0x214/0x2a8 c000000004004804 hardware_interrupt_entry+0x1c/0x98 --- Exception: 501 (Hardware Interrupt) at c00000000400c544 .raw_local_irq_restore+0x48/0x54 c00000000465d2a8 ._raw_spin_unlock_irqrestore+0x74/0xa0 c0000000040e7f00 .__setup_irq+0x2ec/0x3f0 c0000000040e8198 .request_threaded_irq+0x194/0x22c c00000000446d854 .rpavscsi_init_crq_queue+0x284/0x3f0 c00000000446c764 .ibmvscsi_probe+0x688/0x710 c00000000402903c .vio_bus_probe+0x37c/0x3e4 c000000004403f10 .driver_probe_device+0xec/0x1b8 c000000004404088 .__driver_attach+0xac/0xf4 c000000004403184 .bus_for_each_dev+0x98/0x104 c000000004403c98 .driver_attach+0x40/0x60 c0000000044026f0 .bus_add_driver+0x154/0x324 c0000000044045d0 .driver_register+0xe8/0x1ac c00000000402b2a8 .vio_register_driver+0x54/0x74 c000000004933ea4 .ibmvscsi_module_init+0x80/0xc0 c000000004009834 .do_one_initcall+0x98/0x1d8 c0000000049005b4 .kernel_init+0x27c/0x33c c000000004031550 .kernel_thread+0x54/0x70 srp_task needs to be setup before request_irq. The patch below fixes the oops. Signed-off-by: Anton Blanchard <anton@samba.org> Acked-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-07-27Merge git://git.infradead.org/users/cbou/battery-2.6.35Linus Torvalds
* git://git.infradead.org/users/cbou/battery-2.6.35: ds2782_battery: Rename get_current to fix build failure / name conflict
2010-07-27Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: s2io: fixing DBG_PRINT() macro ath9k: fix dma direction for map/unmap in ath_rx_tasklet net: dev_forward_skb should call nf_reset net sched: fix race in mirred device removal tun: avoid BUG, dump packet on GSO errors bonding: set device in RLB ARP packet handler wimax/i2400m: Add PID & VID for Intel WiMAX 6250 ipv6: Don't add routes to ipv6 disabled interfaces. net: Fix skb_copy_expand() handling of ->csum_start net: Fix corruption of skb csum field in pskb_expand_head() of net/core/skbuff.c macvtap: Limit packet queue length ixgbe/igb: catch invalid VF settings bnx2x: Advance a module version bnx2x: Protect statistics ramrod and sequence number bnx2x: Protect a SM state change wireless: use netif_rx_ni in ieee80211_send_layer2_update
2010-07-27wm8350-regulator: fix wm8350_register_regulator error handlingAxel Lin
In the case of platform_device_add() fail, we should call platform_device_put() instead of platform_device_del() Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-07-27ab3100: fix off-by-one value range checking for voltage selectorAxel Lin
We use voltage selector as an array index for typ_voltages. Thus the valid range for voltage selector should be 0..voltages_len-1. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-07-26s2io: fixing DBG_PRINT() macroBreno Leitao
Patch 9e39f7c5b311a306977c5471f9e2ce4c456aa038 changed the DBG_PRINT() macro and the if clause was wrongly changed. It means that currently all the DBG_PRINT are being printed, flooding the kernel log buffer with things like: s2io: eth6: Next block at: c0000000b9c90000 s2io: eth6: In Neterion Tx routine Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com> Acked-by: Sreenivasa Honnur <Sreenivasa.Honnur@neterion.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-26Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq: [CPUFREQ] powernow-k8: Limit Pstate transition latency check [CPUFREQ] Fix PCC driver error path [CPUFREQ] fix double freeing in error path of pcc-cpufreq [CPUFREQ] pcc driver should check for pcch method before calling _OSC [CPUFREQ] fix memory leak in cpufreq_add_dev [CPUFREQ] revert "[CPUFREQ] remove rwsem lock from CPUFREQ_GOV_STOP call (second call site)"
2010-07-26Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linus: MIPS: Set io_map_base for several PCI bridges lacking it MIPS: Alchemy: Define eth platform devices in the correct order MIPS: BCM63xx: Prevent second enet registration on BCM6338 MIPS: Quit using undefined behavior of ADDU in 64-bit atomic operations. MIPS: N32: Define getdents64. MIPS: MTX-1: Fix PCI on the MeshCube and related boards MIPS: Make init_vdso a subsys_initcall. MIPS: "Fix" useless 'init_vdso successfully' message. MIPS: PowerTV: Move register setup to before reading registers. SOUND: Au1000: Fix section mismatch VIDEO: Au1100fb: Fix section mismatch VIDEO: PMAGB-B: Fix section mismatch VIDEO: PMAG-BA: Fix section mismatch NET: declance: Fix section mismatches VIDEO. gbefb: Fix section mismatches.
2010-07-26drm/i915: make sure we shut off the panel in eDP configsJesse Barnes
Fix error from the last pull request. Making sure we shut the panel off is more correct and saves power. Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-07-26Merge branch 'master' of ↵David S. Miller
2010-07-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: USB: musb: tusb6010: fix compile error with n8x0_defconfig USB: FTDI: Add support for the RT System VX-7 radio programming cable USB: add quirk for Broadcom BT dongle USB: usb-storage: fix initializations of urb fields USB: xhci: Set Mult field in endpoint context correctly. USB: sisusbvga: Fix for USB 3.0 USB: adds Artisman USB dongle to list of quirky devices USB: xhci: Set EP0 dequeue ptr after reset of configured device. USB: Fix USB3.0 Port Speed Downgrade after port reset USB: xHCI: Fix another bug in link TRB activation change. USB: option: Add support for AMOI Skypephone S2 USB: New PIDs for Qualcomm gobi 2000 (qcserial) USB: ftdi_sio: support for Signalyzer tools based on FTDI chips USB: s3c2410_udc: be aware of connected gadget driver USB: Expose vendor-specific ACM channel on Nokia 5230 USB: Add PID for Sierra 250U to drivers/usb/serial/sierra.c USB: option: add support for 1da5:4518
2010-07-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: serial: fix rs485 for atmel_serial on avr32
2010-07-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/anholt/drm-intel * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/anholt/drm-intel: drm/i915: add pipe A force quirks to i915 driver drm/i915: Fix panel fitting regression since 734b4157 drm/i915: fix deadlock in fb teardown drm/i915: don't free non-existent compressed llb on ILK+ agp/intel: Use the correct mask to detect i830 aperture size. drm/i915: disable FBC when more than one pipe is active drm/i915: Use the correct scanout alignment for fbcon. drm/i915: make sure eDP panel is turned on drm/i915: add PANEL_UNLOCK_REGS definition drm/i915: Make G4X-style PLL search more permissive drm/i915: Clear any existing dither mode prior to enabling spatial dithering drm/i915: handle shared framebuffers when flipping drm/i915: Explosion following OOM in do_execbuffer. gpu/drm/i915: Add a blacklist to omit modeset on LID open
2010-07-26[CPUFREQ] fix memory leak in cpufreq_add_devXiaotian Feng
We didn't free policy->related_cpus in error path err_unlock_policy. This is catched by following kmemleak report: unreferenced object 0xffff88022a0b96d0 (size 512): comm "modprobe", pid 886, jiffies 4294689177 (age 780.694s) hex dump (first 32 bytes): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ backtrace: [<ffffffff8111ebe5>] create_object+0x186/0x281 [<ffffffff814fad4f>] kmemleak_alloc+0x60/0xa7 [<ffffffff8111127a>] kmem_cache_alloc_node_notrace+0x120/0x142 [<ffffffff81262e4f>] alloc_cpumask_var_node+0x2c/0xd7 [<ffffffff81262f0b>] alloc_cpumask_var+0x11/0x13 [<ffffffff81262f1c>] zalloc_cpumask_var+0xf/0x11 [<ffffffff8140fac0>] cpufreq_add_dev+0x11f/0x547 [<ffffffff81334bda>] sysdev_driver_register+0xc2/0x11d [<ffffffff8140e334>] cpufreq_register_driver+0xcb/0x1b8 [<ffffffffa032e040>] 0xffffffffa032e040 [<ffffffff810021ba>] do_one_initcall+0x5e/0x15c [<ffffffff81087f94>] sys_init_module+0xa6/0x1e6 [<ffffffff81009bc2>] system_call_fastpath+0x16/0x1b [<ffffffffffffffff>] 0xffffffffffffffff Signed-off-by: Xiaotian Feng <dfeng@redhat.com> Cc: Thomas Renninger <trenn@suse.de> Cc: Prarit Bhargava <prarit@redhat.com> Signed-off-by: Dave Jones <davej@redhat.com>
2010-07-26[CPUFREQ] revert "[CPUFREQ] remove rwsem lock from CPUFREQ_GOV_STOP call ↵Andrej Gelenberg
(second call site)" 395913d0b1db37092ea3d9d69b832183b1dd84c5 ("[CPUFREQ] remove rwsem lock from CPUFREQ_GOV_STOP call (second call site)") is not needed, because there is no rwsem lock in cpufreq_ondemand and cpufreq_conservative anymore. Lock should not be released until the work done. Addresses https://bugzilla.kernel.org/show_bug.cgi?id=1594 Signed-off-by: Andrej Gelenberg <andrej.gelenberg@udo.edu> Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Signed-off-by: Dave Jones <davej@redhat.com>
2010-07-26USB: musb: tusb6010: fix compile error with n8x0_defconfigFelipe Balbi
Drop the unnecessary empty stubs in tusb6010.c and avoid a compile error when building kernel for n8x0. Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-26USB: FTDI: Add support for the RT System VX-7 radio programming cableCorey Minyard
RT Systems has put out bunch of ham radio cables based on the FT232RL chip. Each cable type has a unique PID, this adds one for the Yaesu VX-7 radios. Signed-off-by: Corey Minyard <minyard@acm.org> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-26USB: add quirk for Broadcom BT dongleOliver Neukum
This device needs to be reset when resuming Signed-off-by: Oliver Neukum <oneukum@suse.de> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-26USB: usb-storage: fix initializations of urb fieldsBob Copeland
Commit 0ede76fcec5415ef82a423a95120286895822e2d, "USB: remove uses of URB_NO_SETUP_DMA_MAP" introduced a regression by inadvertantly removing initialization of the transfer flags. This caused initialization failures in the ums-karma driver. Fix the regression by zeroing it. While at it, as Alan Stern points out, the initializers for actual_length and status are handled by the core and error_count only matters for isochronous urbs, so they don't need to be set here. Remove them. Signed-off-by: Bob Copeland <me@bobcopeland.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-26USB: xhci: Set Mult field in endpoint context correctly.Sarah Sharp
The bmAttributes field of the SuperSpeed Endpoint Companion Descriptor has different meanings, depending on the endpoint type. If the endpoint is isochronous, the bmAttributes field is the maximum number of packets within a service interval that this endpoint supports. If the endpoint is bulk, it's the number of stream IDs this endpoint supports. Only set the Mult field of the xHCI endpoint context using the bmAttributes field if the endpoint is isochronous, and the device is a SuperSpeed device. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-26USB: sisusbvga: Fix for USB 3.0Oliver Neukum
Super speed is also fast enough to let sisusbvga operate. Therefor expand the checks. Signed-off-by: Oliver Neukum <oneukum@suse.de> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-26USB: adds Artisman USB dongle to list of quirky devicesPaul Mortier
When an attempt is made to read the interface strings of the Artisman Watchdog USB dongle (idVendor:idProduct 04b4:0526) an error is written to the dmesg log (uhci_result_common: failed with status 440000) and the dongle resets itself, resulting in a disconnect/reconnect loop. Adding the dongle to the list of devices in quirks.c, with the same quirk Alan Stern's previous patch for the Saitek Cyborg Gold 3D joystick, stops the device from resetting and allows it to be used with no problems. Signed-off-by: Paul Mortier <mortier@btinternet.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-26USB: xhci: Set EP0 dequeue ptr after reset of configured device.Sarah Sharp
When a configured device is reset, the control endpoint's ring is reused. If control transfers to the device were issued before the device is reset, the dequeue pointer will be somewhere in the middle of the ring. If the device is then issued an address with the set address command, the xHCI driver must provide a valid input context for control endpoint zero. The original code would give the hardware the original input context, which had a dequeue pointer set to the top of the ring. This would cause the host to re-execute any control transfers until it reached the ring's enqueue pointer. When issuing a set address command for a device that has just been configured and then reset, use the control endpoint's enqueue pointer as the hardware's dequeue pointer. Assumption: All control transfers will be completed or cancelled before the set address command is issued to the device. If there are any outstanding control transfers, this code will not work. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-26USB: Fix USB3.0 Port Speed Downgrade after port resetSarah Sharp
Without this fix, a USB 3.0 port is downgraded to full speed after a port reset of a configured device. The USB 3.0 terminations will be disabled permanently, and USB 3.0 devices will always enumerate as full speed devices, until the host controller is unplugged (if it is an ExpressCard) or the computer is rebooted. Fajun Chen traced this traced the speed downgrade issue to the port reset and the interpretation of port status in USB hub driver code. The hub code was not testing for the port being a SuperSpeed port, and it fell through to the else case of Full Speed. The following patch adds SuperSpeed mapping from the port status, and fixes the speed downgrade issue. Reported-by: Fajun Chen <fajun.chen@seagate.com> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-26USB: xHCI: Fix another bug in link TRB activation change.Sarah Sharp
Commit 6c12db90f19727c76990e7f4801c67a148b30111 also seems to have introduced a bug that is triggered when the command ring is about to wrap. The inc_enq() function will not have moved the enqueue pointer past the link TRB. It is supposed to be moved past the link TRB in prepare_ring(), which should be called before a TD is enqueued. However, the queue_command() function never calls the prepare_ring() function because prepare_ring() is only supposed to be used for endpoint rings. That means the enqueue pointer will not be moved past the link TRB, and will get overwritten. The fix is to make queue_command() call prepare_ring() with a fake endpoint status (set to running). Then the enqueue pointer will get moved past the link TRB. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-26USB: option: Add support for AMOI Skypephone S2Dennis Jansen
usbserial: Add AMOI Skypephone S2 support. This patch adds support for the AMOI Skypephone S2 to the usbserial module. Tested-by: Dennis Jansen <Dennis.Jansen@web.de> Signed-off-by: Dennis Jansen <Dennis.Jansen@web.de> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-26USB: New PIDs for Qualcomm gobi 2000 (qcserial)Andrew Bird
Adds support for the Generic Qualcomm Gobi 2000 WWAN UMTS/CDMA modem Signed-off-by: Andrew Bird <ajb@spheresytems.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-26USB: ftdi_sio: support for Signalyzer tools based on FTDI chipsColin Leitner
ftdi_sio: support for Signalyzer tools based on FTDI chips This patch adds support for the Xverve Signalyzers. Signed-off-by: Colin Leitner <colin.leitner@googlemail.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-26USB: s3c2410_udc: be aware of connected gadget driverVladimir Zapolskiy
To escape from data abort in interrupt handler, it is required to check for a connected gadget before delivering control requests. The change fixes the following panic, which occurs with no loaded gadget driver and input USB_REQ_GET_DESCRIPTOR request: Kernel panic - not syncing: Fatal exception in interrupt [<c0025874>] (unwind_backtrace+0x0/0xd8) from [<c0253f14>] (panic+0x40/0x110) [<c0253f14>] (panic+0x40/0x110) from [<c002470c>] (die+0x154/0x180) [<c002470c>] (die+0x154/0x180) from [<c0026448>] (__do_kernel_fault+0x64/0x74) [<c0026448>] (__do_kernel_fault+0x64/0x74) from [<c0026610>] (do_page_fault+0x1b8/0x1cc) [<c0026610>] (do_page_fault+0x1b8/0x1cc) from [<c00202d4>] (do_DataAbort+0x34/0x94) [<c00202d4>] (do_DataAbort+0x34/0x94) from [<c0020a60>] (__dabt_svc+0x40/0x60) Exception stack(0xc0327ea8 to 0xc0327ef0) 7ea0: bf0026b0 c0327ef0 c0327ee4 00000000 bf002590 00000093 7ec0: 00000001 bf0026b0 bf002990 00000000 00000008 0000143d 00003f00 c0327ef0 7ee0: bf001364 bf001360 20000093 ffffffff [<c0020a60>] (__dabt_svc+0x40/0x60) from [<bf001360>] (s3c2410_udc_irq+0x5b8/0x778 [s3c2410_udc]) [<bf001360>] (s3c2410_udc_irq+0x5b8/0x778 [s3c2410_udc]) from [<c0058aa0>] (handle_IRQ_event+0x3c/0x104) [<c0058aa0>] (handle_IRQ_event+0x3c/0x104) from [<c005a428>] (handle_edge_irq+0x12c/0x164) [<c005a428>] (handle_edge_irq+0x12c/0x164) from [<c0020068>] (asm_do_IRQ+0x68/0x88) [<c0020068>] (asm_do_IRQ+0x68/0x88) from [<c0020aa4>] (__irq_svc+0x24/0xa0) Signed-off-by: Vladimir Zapolskiy <vzapolskiy@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-26USB: Expose vendor-specific ACM channel on Nokia 5230Przemo Firszt
Nokia S60 phones expose two ACM channels. The first is a modem, the second is 'vendor-specific' but is treated as a serial device at the S60 end, so we want to expose it on Linux too. Signed-off-by: Przemo Firszt <przemo@firszt.eu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-26USB: Add PID for Sierra 250U to drivers/usb/serial/sierra.caugust huber
Add VID/PID for Sierra Wireless 250U USB dongle to sierra.c Allows use of 3G radio only Signed-off-by: August Huber <gus@pbx.org> Cc: Elina Pasheva <epasheva@sierrawireless.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-26USB: option: add support for 1da5:4518Ömer Sezgin Ugurlu
Signed-off-by: Omer Sezgin Ugurlu <omer.ugurlu@a-kent.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-26drm/i915: add pipe A force quirks to i915 driverJesse Barnes
Ported over from the old UMS list. Unfortunately they're still necessary especially on older laptop platforms. Fixes https://bugs.freedesktop.org/show_bug.cgi?id=22126. Tested-by: Xavier <shiningxc@gmail.com> Tested-by: Diego Escalante Urrelo <diegoe@gnome.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Eric Anholt <eric@anholt.net>
2010-07-26drm/i915: Fix panel fitting regression since 734b4157Chris Wilson
The crtc mode fixup is run after the encoders adjust the mode to fit on their output, so don't reset the mode! Fixes: Bug 29057 - display corruption under 800x600 on netbook (1024x600) with 'Full Aspect' scaling https://bugs.freedesktop.org/show_bug.cgi?id=29057 Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Tested-by: Xun Fang <xunx.fang@intel.com> Signed-off-by: Eric Anholt <eric@anholt.net>
2010-07-26serial: fix rs485 for atmel_serial on avr32Peter Huewe
This patch fixes a build failure [1-4] in the atmel_serial code introduced by patch the patch ARM: 6092/1: atmel_serial: support for RS485 communications (e8faff7330a3501eafc9bfe5f4f15af444be29f5) The build failure was caused by missing struct field and missing defines for the avr32 board - the patch fixes this. [1] http://kisskb.ellerman.id.au/kisskb/buildresult/2575242/ - first failure in linux-next, may 11th [2] http://kisskb.ellerman.id.au/kisskb/buildresult/2816418/ - still exists as of today [3] http://kisskb.ellerman.id.au/kisskb/buildresult/2617511/ - first failure in Linus' tree - May 20th - did really no one notice this?! [4] http://kisskb.ellerman.id.au/kisskb/buildresult/2813956/ - still exists in Linus' tree as of today Signed-off-by: Peter Huewe <peterhuewe@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-26ath9k: fix dma direction for map/unmap in ath_rx_taskletMing Lei
For edma, we should use DMA_BIDIRECTIONAL, or else use DMA_FROM_DEVICE. This is found to address "BUG at arch/x86/mm/physaddr.c:5" as described here: http://lkml.org/lkml/2010/7/14/21 Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-07-26drm/i915: fix deadlock in fb teardownJesse Barnes
At module unload time we'll tear down the fbdev state. We do so under the struct mutex, so we shouldn't try to use the unlocked variant of the GEM object unreference function or we may deadlock. Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Eric Anholt <eric@anholt.net>
