iwl_full_rxon_required is used only in
iwl-agn-rxon.c. Move it there and mark it
static.
Signed-off-by: Meenakshi Venkataraman <meenakshi.venkataraman@intel.com>
Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
iwl_check_rxon_cmd is used only in
static.
iwl_set_rxon_hwcrypto is used only in
static.
iwl_send_rxon_timing is used only in
iwl-agn-rxon.c, move it there and mark it
static.
This is used only in one file, move it there
and make it static.
This variable holds the ucode currently
running on the device; which is determined by
op_mode, so move this parameter there.
Also, the name of the variable is a bit
misleading, so rename it to cur_ucode.
Error log reporting does not belong to the
transport layer, but to the op_mode loading
the ucode, as it is the entity which knows
about the ucode loaded, and what the error
information means.
Move device logging pointers from the
transport layer to op_mode.
With this change, transport layer only
reports an error to the op_mode, which will
figure out what to do with the error. This
causes the driver to now dump out error logs
when the command queue is stuck as well.
Also, move the debugfs entry for event logs
out of the transport layer and into op_mode.
iwl_nic_error is used in iwl-agn.c only, move
it there and make it static.
In the process, make iwlagn_fw_error
a non-static function, as it is used
by more than one file.
No other component is accessing it any more,
so it can move to the correct place in priv.
The queue mapping is not only dynamic, it
is also dependent on the uCode, as we can
already see today with the dual-mode and
non-dual-mode being different.
Move the queue mapping out of the transport
layer and let the higher layer manage it.
Part of the transport configuration is how
to set up the queues.
As idle is just a deep powersave mode for
the device, it will easily scan while idle
since that turns off powersave.
This reduces the number of commands sent
to the device when scanning.
This is not (no longer?) used by any device
so just remove it.
This is used only by 2000 class devices, but
they all use it so remove the configuration
parameter and hard-code the programming.
There's no device using this mechanism.
It talks about treating different uCode APIs
as different pieces of hardware which really
isn't how we handle things.
A whole bunch of messages, even some recent ones,
didn't include a trailing newline so add it.
The calibration results all come in while we're
waiting for the calibration complete notification.
As a consequence, there's no need to install a
global RX handler for them, we can use the newly
extended notification wait framework for this and
make the code easier to follow.
It is now quite explicit that we are processing
the calibration results while waiting for the
complete notification, before this was implicit
and developers had to know this to understand why
we wait for the calibration complete notification
and what happens while we wait.
Sometimes, for example when we ask the uCode
for calibration, we wait for the "complete"
response while we also need the results that
are sent in other, interim, notifications.
Currently we handle this by installing an RX
handler globally, but that isn't needed as
this is the only time we want to use these
notifications.
So in order to be able to simplify at least
future code that does the same, extend the
notification wait framework to allow you to
wait for multiple commands and decide based
on the command whether the wait finished.
While at it, also fix a race that can then
become relevant -- if the wait function has
returned true once it shouldn't be called
again, today this can happen due to races
between the triggering and the wakeup.
The flow handler (hardware) can put multiple
frames into a single RX buffer. To handle
this, walk the RX buffer and check if there
are multiple valid packets in it.
To let the upper layer handle this correctly
introduce rxb_offset() which is needed when
we pass pages to mac80211 -- we need to know
the offset into the page there.
Also change the page handling scheme to use
refcounting. Anyone who needs a page will
"steal" it, which marks it as having been
used & refcounts it. The RX handler then has
to free its own reference and must not reuse
the page.
Finally, do not set the bit asking the FH to
give us each packet in a single buffer. This
really enables the feature.
get rid of un-needed parameter
Change-Id: I992741e7382a3dbced7f8413bf1d5f301029d576
Add iwl_phy_db structure and API.
Signed-off-by: David Spinadel <david.spinadel@intel.com>
The current version of rtlwifi for USB operations uses kmalloc to
acquire a 32-bit buffer for each read of the device. When
_usb_read_sync() is called with the rcu_lock held, the result is
a "sleeping function called from invalid context" BUG. This is
reported for two cases in https://bugzilla.kernel.org/show_bug.cgi?id=42775.
The first case has the lock originating from within rtlwifi and could
be fixed by rearranging the locking; however, the second originates from
within mac80211. The kmalloc() call is removed from _usb_read_sync()
by creating a ring buffer pointer in the private area and
allocating the buffer data in the probe routine.
Cc: Stable <stable@vger.kernel.org> [This version good for 3.3+ - different patch for 3.2 - 2.6.39]
With 9-letter driver names phy's number was truncated
to two characters, which caused warnings when creating
sysfs entries for leds on systems with multiple devices.
Signed-off-by: Jakub Kicinski <kubakici@wp.pl>
Reviewed-by: Stanislaw Gruszka <sgruszka@redhat.com>
Acked-by: Gertjan van Wingerde <gwingerde@gmail.com>
Use a temporary to make the code a bit neater.
Use the normal kernel facilities and use %pM
to print the all zero mac address.
Remove unnecessary line continuation.
Acked-by: Larry.Finger@lwfinger.net
Drivers that load firmware from their probe routine have problems with
the latest versions of udev as they get timeouts while waiting for user
space to start. The problem is fixed by using request_firmware_nowait()
and delaying the start of mac80211 until the firmware is loaded.
To prevent the possibility of the driver being unloaded while the
firmware loading callback is still active, a completion queue entry
is used.
Also, to simplify the firmware loading procedure, this patch removes
the old, unofficial and confusing fallback firmware names. However,
they are still supported! So any user - who is still using them -
is hereby advised to link/rename their old firmware filenames:
isl3890usb to isl3886usb
isl3887usb_bare to isl3887usb
Signed-off-by: Christian Lamparter <chunkeey@googlemail.com>
p54_unregister_common may now be called by the backend
driver's remove routine, even if the ieee80211_hw device
struct was never successfully registered.
In this handler LOW_RSSI and HIGH_RSSI events are subscribed
to FW using provided threshold value so that FW will monitor
connection quality and trigger any of these events.
Driver will notify cfg80211 about connection quality based on
inputs from FW and provided hysteresis.
Signed-off-by: Amitkumar Karwar <akarwar@marvell.com>
Signed-off-by: Yogesh Ashok Powar <yogeshp@marvell.com>
Signed-off-by: Bing Zhao <bzhao@marvell.com>
This patch adds the support for updating average signal information
in dump_station().
1) The wrapper function mwifiex_get_signal_info() is unnecessary.
2) As noise and signal vaules in private structure already get
modified, we don't need to explicitly pass
"struct mwifiex_ds_get_signal" to get it filled.
This enables user to dump station information using
"iw dev <devname> station dump" command.
During wiphy registration signal_type is initialized to
CFG80211_SIGNAL_TYPE_MBM. So convert signal strength from dBm to
mBm. Also, the value is absolute. Make it negative before
sending to cfg80211.
Signed-off-by: Rajkumar Manoharan <rmanohar@qca.qualcomm.com>
Since some of the HT code pre-dates 802.11n-2009
some names are wrong. The one that bothers me most
is that "HT operation" is called "HT information"
in our code and that causes confusion.
Rename "HT information" to "HT operation" and also
the control_chan field to primary_chan to match
the name used in the spec.
Acked-by: Bing Zhao <bzhao@marvell.com>
In the experiment with Azimuth ADEPT-n testbed where the APs transmit
power was reduced to 25% and the signal strength was futher attenuated
by 20dB and induced a path loss of ~7dB, the station was reporting
beacon losses and the following issue were observed.
* rx clear is stuck at low for more than 300ms
* dcu chain and complete state is stuck at one of the hang signature
This patch triggers the hang detection logic that recovers the chip
from any of the above conditions. As the issue was originally reported
in ChromeOs with AR9382 chips, this detection logic is enabled only for
AR9380/2 chips.
Cc: Paul Stewart <pstew@google.com>
Reported-by: Gary Morain <gmorain@google.com>
This patch improves ANI operations by switching among the immunity
levels based on PHY errors and beacon rssi which will adjust receiver
desensitizing parameters. The changes are
* Configure the Weak Signal Detection based on current immunity value.
* At highest OFDM immunity level poor performance was observed with
strong interference. By tuning the FIR step and spur immunity levels
and not changing any weak signal detection thresholds at any level
helped to improve the performance.
* ANI took long time to recover back to lower immunity levels on heavy
data load. As the listen time got reset to zero before reaching to
the 5x of aniperiod, the immunity level is not lowering back even
without any interference. This patch fix that.
Cc: Susinder Gulasekaran <susinder@qca.qualcomm.com>
Signed-off-by: Suresh Chandrasekaran <csuresh@qca.qualcomm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless
Pull networking fixes from David Miller:
1) Name string overrun fix in gianfar driver from Joe Perches.
2) VHOST bug fixes from Michael S. Tsirkin and Nadav Har'El
3) Fix dependencies on xt_LOG netfilter module, from Pablo Neira Ayuso.
4) Fix RCU locking in xt_CT, also from Pablo Neira Ayuso.
5) Add a parameter to skb_add_rx_frag() so we can fix the truesize
adjustments in the drivers that use it. The individual drivers
aren't fixed by this commit, but will be dealt with using follow-on
commits. From Eric Dumazet.
6) Add some device IDs to qmi_wwan driver, from Andrew Bird.
7) Fix a potential rcu_read_lock() imbalancein rt6_fill_node(). From
Eric Dumazet.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net:
net: fix a potential rcu_read_lock() imbalance in rt6_fill_node()
net: add a truesize parameter to skb_add_rx_frag()
gianfar: Fix possible overrun and simplify interrupt name field creation
USB: qmi_wwan: Add ZTE (Vodafone) K3570-Z and K3571-Z net interfaces
USB: option: Ignore ZTE (Vodafone) K3570/71 net interfaces
USB: qmi_wwan: Add ZTE (Vodafone) K3565-Z and K4505-Z net interfaces
qlcnic: Bug fix for LRO
netfilter: nf_conntrack: permanently attach timeout policy to conntrack
netfilter: xt_CT: fix assignation of the generic protocol tracker
netfilter: xt_CT: missing rcu_read_lock section in timeout assignment
netfilter: cttimeout: fix dependency with l4protocol conntrack module
netfilter: xt_LOG: use CONFIG_IP6_NF_IPTABLES instead of CONFIG_IPV6
vhost: fix release path lockdep checks
vhost: don't forget to schedule()
tools/virtio: stub out strong barriers
tools/virtio: add linux/hrtimer.h stub
tools/virtio: add linux/module.h stub
Pull "ARM: device tree work" from Arnd Bergmann:
"Most of these patches convert code from using static platform data to
describing the hardware in the device tree. This is only the first
half of the changes for v3.4 because a lot of patches for this topic
came in the last week before the merge window.
Signed-off-by: Arnd Bergmann <arnd@arndb.de>"
Fix up trivial conflicts in arch/arm/mach-vexpress/{Kconfig,core.h}
* tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (86 commits)
Document: devicetree: add OF documents for arch-mmp
ARM: dts: append DTS file of pxa168
ARM: mmp: append OF support on pxa168
ARM: mmp: enable rtc clk in pxa168
i2c: pxa: add OF support
serial: pxa: add OF support
arm/dts: mt_ventoux: very basic support for TeeJet Mt.Ventoux board
ARM: OMAP2+: Remove extra ifdefs for board-generic
ARM: OMAP2+: Fix build error when only ARCH_OMAP2/3 or 4 is selected
ASoC: DT: Add digital microphone binding to PAZ00 board.
ARM: dt: Add ARM PMU to tegra*.dtsi
ARM: at91: at91sam9x5cm/dt: add leds support
ARM: at91: usb_a9g20/dt: add gpio-keys support
ARM: at91: at91sam9m10g45ek/dt: add gpio-keys support
ARM: at91: at91sam9m10g45ek/dt: add leds support
ARM: at91: usb_a9g20/dt: add leds support
ARM: at91/pio: add new PIO3 features
ARM: at91: add sam9_smc.o to at91sam9x5 build
ARM: at91/tc/clocksource: Add 32 bit variant to Timer Counter
ARM: at91/tc: add device tree support to atmel_tclib
Pull "ARM: driver specific updates" from Arnd Bergmann:
"These are all specific to some driver. They are typically the
platform side of a change in the drivers directory, such as adding a
new driver or extending the interface to the platform. In cases where
there is no maintainer for the driver, or the maintainer prefers to
have the platform changes in the same branch as the driver changes,
the patches to the drivers are included as well.
A much smaller set of driver updates that depend on other branches
getting merged first will be sent later.
The new export of tegra_chip_uid conflicts with other changes in
fuse.c. In rtc-sa1100.c, the global removal of IRQF_DISABLED
conflicts with the cleanup of the interrupt handling of that driver.
Fixed up aforementioned trivial conflicts.
* tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (94 commits)
ARM: SAMSUNG: change the name from s3c-sdhci to exynos4-sdhci
mmc: sdhci-s3c: add platform data for the second capability
ARM: SAMSUNG: support the second capability for samsung-soc
ARM: EXYNOS: add support DMA for EXYNOS4X12 SoC
ARM: EXYNOS: Add apb_pclk clkdev entry for mdma1
ARM: EXYNOS: Enable MDMA driver
regulator: Remove bq24022 regulator driver
rtc: sa1100: add OF support
pxa: magician/hx4700: Convert to gpio-regulator from bq24022
ARM: OMAP3+: SmartReflex: fix error handling
ARM: OMAP3+: SmartReflex: fix the use of debugfs_create_* API
ARM: OMAP3+: SmartReflex: micro-optimization for sanity check
ARM: OMAP3+: SmartReflex: misc cleanups
ARM: OMAP3+: SmartReflex: move late_initcall() closer to its argument
ARM: OMAP3+: SmartReflex: add missing platform_set_drvdata()
ARM: OMAP3+: hwmod: add SmartReflex IRQs
ARM: OMAP3+: SmartReflex: clear ERRCONFIG_VPBOUNDINTST only on a need
ARM: OMAP3+: SmartReflex: Fix status masking in ERRCONFIG register
ARM: OMAP3+: SmartReflex: Add a shutdown hook
ARM: OMAP3+: SmartReflex Class3: disable errorgen before disable VP
arch/arm/mach-tegra/Makefile
arch/arm/mach-tegra/fuse.c
drivers/rtc/rtc-sa1100.c
Pull "remoteproc/rpmsg: new subsystem" from Arnd Bergmann:
"This new subsystem provides a common way to talk to secondary
processors on an SoC, e.g. a DSP, GPU or service processor, using
virtio as the transport. In the long run, it should replace a few
dozen vendor specific ways to do the same thing, which all never made
it into the upstream kernel. There is a broad agreement that rpmsg is
the way to go here and several vendors have started working on
replacing their own subsystems.
Two branches each add one virtio protocol number. Fortunately the
numbers were agreed upon in advance, so there are only context
changes.
Fixed up trivial protocol number conflict due to the mentioned additions
next to each other.
* tag 'rpmsg' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (32 commits)
remoteproc: cleanup resource table parsing paths
remoteproc: remove the hardcoded vring alignment
remoteproc/omap: remove the mbox_callback limitation
remoteproc: remove the single rpmsg vdev limitation
remoteproc: safer boot/shutdown order
remoteproc: remoteproc_rpmsg -> remoteproc_virtio
remoteproc: resource table overhaul
rpmsg: fix build warning when dma_addr_t is 64-bit
rpmsg: fix published buffer length in rpmsg_recv_done
rpmsg: validate incoming message length before propagating
rpmsg: fix name service endpoint leak
remoteproc/omap: two Kconfig fixes
remoteproc: make sure we're parsing a 32bit firmware
remoteproc: s/big switch/lookup table/
remoteproc: bail out if firmware has different endianess
remoteproc: don't use virtio's weak barriers
rpmsg: rename virtqueue_add_buf_gfp to virtqueue_add_buf
rpmsg: depend on EXPERIMENTAL
remoteproc: depend on EXPERIMENTAL
rpmsg: add Kconfig menu
include/linux/virtio_ids.h
Pull "ARM: board specific updates" from Arnd Bergmann/Olof Johansson:
"These changes are all specific to one board only. We're trying to
keep the number of board files low, but generally board level updates
are ok on platforms that are working on moving towards DT based
probing, which will eventually lead to removing them.
The board-ams-delta.c board file gets a conflict between the removal
of ams_delta_config and the addition of a lot of other data. The
Kconfig file has two changes in the same line, and in exynos, the
power domain cleanup conflicts with the addition of the image sensor
device.
[olof: Amended a fix for a mismerge to board-omap4panda.c]
Signed-off-by: Olof Johansson <olof@lixom.net>"
Fixed up some fairly trivial conflicts manually.
* tag 'boards' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (82 commits)
i.MX35-PDK: Add Camera support
ARM : mx35: 3ds-board: add framebuffer device
pxa/hx4700: Remove pcmcia platform_device structure
ARM: pxa/hx4700: Reduce sleep mode battery discharge by 35%
ARM: pxa/hx4700: Remove unwanted request for GPIO105
ARM: EXYNOS: support Exynos4210-bus Devfreq driver on Nuri board
ARM: EXYNOS: Register JPEG on nuri
ARM: EXYNOS: Register JPEG on universal_c210
ARM: S5PV210: Enable JPEG on SMDKV210
ARM: S5PV210: Add JPEG board definition
ARM: EXYNOS: Enable JPEG on Origen
ARM: EXYNOS: Enable JPEG on SMDKV310
ARM: EXYNOS: Add __init attribute to universal_camera_init()
ARM: EXYNOS: Add __init attribute to nuri_camera_init()
ARM: S5PV210: Enable FIMC on SMDKC110
ARM: S5PV210: Enable FIMC on SMDKV210
ARM: S5PV210: Enable MFC on SMDKC110
ARM: S5PV210: Enable MFC on SMDKV210
ARM: EXYNOS: Enable G2D on SMDKV310
ARM: tegra: update defconfig
Pull "ARM: timer cleanup work" from Arnd Bergmann:
"These are split out from the generic soc and driver updates because
there was a lot of conflicting work by multiple people. Marc Zyngier
worked on simplifying the "localtimer" interfaces, and some of the
platforms are touching the same code as they move to device tree based
booting.
* tag 'timer' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (61 commits)
ARM: tegra: select USB_ULPI if USB is selected
arm/tegra: pcie: fix return value of function
ARM: ux500: fix compilation after local timer rework
ARM: shmobile: remove additional __io() macro use
ARM: local timers: make the runtime registration interface mandatory
ARM: local timers: convert MSM to runtime registration interface
ARM: local timers: convert exynos to runtime registration interface
ARM: smp_twd: remove old local timer interface
ARM: imx6q: convert to twd_local_timer_register() interface
ARM: highbank: convert to twd_local_timer_register() interface
ARM: ux500: convert to twd_local_timer_register() interface
ARM: shmobile: convert to twd_local_timer_register() interface
ARM: tegra: convert to twd_local_timer_register() interface
ARM: plat-versatile: convert to twd_local_timer_register() interface
ARM: OMAP4: convert to twd_local_timer_register() interface
ARM: smp_twd: add device tree support
ARM: smp_twd: add runtime registration support
ARM: local timers: introduce a new registration interface
ARM: smp_twd: make local_timer_stop a symbol instead of a #define
ARM: mach-shmobile: default to no earlytimer
Pull "ARM: global cleanups" from Arnd Bergmann:
"Quite a bit of code gets removed, and some stuff moved around, mostly
the old samsung s3c24xx stuff. There should be no functional changes
in this series otherwise. Some cleanups have dependencies on other
arm-soc branches and will be sent in the second round.
Fixed up trivial conflicts mainly due to #include's being changes on
both sides.
* tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (121 commits)
ep93xx: Remove unnecessary includes of ep93xx-regs.h
ep93xx: Move EP93XX_SYSCON defines to SoC private header
ep93xx: Move crunch code to mach-ep93xx directory
ep93xx: Make syscon access functions private to SoC
ep93xx: Configure GPIO ports in core code
ep93xx: Move peripheral defines to local SoC header
ep93xx: Convert the watchdog driver into a platform device.
ep93xx: Use ioremap for backlight driver
ep93xx: Move GPIO defines to gpio-ep93xx.h
ep93xx: Don't use system controller defines in audio drivers
ep93xx: Move PHYS_BASE defines to local SoC header file
ARM: EXYNOS: Add clock register addresses for EXYNOS4X12 bus devfreq driver
ARM: EXYNOS: add clock registers for exynos4x12-cpufreq
PM / devfreq: update the name of EXYNOS clock registers that were omitted
ARM: EXYNOS: change the prefix S5P_ to EXYNOS4_ for clock
ARM: EXYNOS: use static declaration on regarding clock
ARM: EXYNOS: replace clock.c for other new EXYNOS SoCs
ARM: OMAP2+: Fix build error after merge
ARM: S3C24XX: remove call to s3c24xx_setup_clocks
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into next/boards
The asoc branch that was already merged into v3.4 contains some
board-level changes that conflict with patches we already have
here, so pull in that branch to resolve the conflicts.
arch/arm/mach-imx/mach-imx27_visstrim_m10.c
arch/arm/mach-omap2/board-omap4panda.c
[olof: Amended fix for mismerge as reported by Kevin Hilman]
In https://bugzilla.redhat.com/show_bug.cgi?id=770207, slowdowns of driver
rtl8192ce are reported. One fix (commit a9b89e2) has already been applied,
and it helped, but the maximum RX speed would still drop to 1 Mbps. As in
the previous fix, the initial gain was determined to be the problem; however,
the problem arises from a setting of the gain when scans are started.
Driver rtl8192de also has the same code structure - this one is fixed as well.
Reported-and-Tested-by: Ivan Pesin <ivan.pesin@gmail.com>
Another good catch from Jakub Kicinski. This patch fixes my
recent commit: ed61e2b02027935520d1be884fac0b2ffce8379a
"rt2x00: rt2800usb: rework txdone code"
We should reread status register only when nobody else start already
reading status i.e. test_and_set_bit(TX_STATUS_READING, flags) return 0.
Reported-by: Jakub Kicinski <moorray@wp.pl>
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
This is fix for my current commit
We should schedule txdone work on timeout, otherwise if newer get
tx status from hardware, we will never report tx status to mac80211
and eventually never wakeup tx queue.
commit 0d95521ea7 (ath9k: use split rx buffers to get rid of order-1 skb
allocations) added in memory leak in error path.
sc->rx.frag should be cleared after the pskb_expand_head() call, or else
we jump to requeue_drop_frag and leak an skb.
Cc: Jouni Malinen <jouni@qca.qualcomm.com>
Cc: Felix Fietkau <nbd@openwrt.org>
Cc: John W. Linville <linville@tuxdriver.com>
Cc: Trond Wuellner <trond@chromium.org>
Cc: Grant Grundler <grundler@chromium.org>
Cc: Paul Stewart <pstew@chromium.org>
