Pull networking updates from David Miller:
1) Make syn floods consume significantly less resources by
a) Not pre-COW'ing routing metrics for SYN/ACKs
b) Mirroring the device queue mapping of the SYN for the SYN/ACK
reply.
Both from Eric Dumazet.
2) Fix calculation errors in Byte Queue Limiting, from Hiroaki SHIMODA.
3) Validate the length requested when building a paged SKB for a
socket, so we don't overrun the page vector accidently. From Jason
Wang.
4) When netlabel is disabled, we abort all IP option processing when we
see a CIPSO option. This isn't the right thing to do, we should
simply skip over it and continue processing the remaining options
(if any). Fix from Paul Moore.
5) SRIOV fixes for the mellanox driver from Jack orgenstein and Marcel
Apfelbaum.
6) 8139cp enables the receiver before the ring address is properly
programmed, which potentially lets the device crap over random
memory. Fix from Jason Wang.
7) e1000/e1000e fixes for i217 RST handling, and an improper buffer
address reference in jumbo RX frame processing from Bruce Allan and
Sebastian Andrzej Siewior, respectively.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net:
fec_mpc52xx: fix timestamp filtering
mcs7830: Implement link state detection
e1000e: fix Rapid Start Technology support for i217
e1000: look into the page instead of skb->data for e1000_tbi_adjust_stats()
r8169: call netif_napi_del at errpaths and at driver unload
tcp: reflect SYN queue_mapping into SYNACK packets
tcp: do not create inetpeer on SYNACK message
8139cp/8139too: terminate the eeprom access with the right opmode
8139cp: set ring address before enabling receiver
cipso: handle CIPSO options correctly when NetLabel is disabled
net: sock: validate data_len before allocating skb in sock_alloc_send_pskb()
bql: Avoid possible inconsistent calculation.
bql: Avoid unneeded limit decrement.
bql: Fix POSDIFF() to integer overflow aware.
net/mlx4_core: Fix obscure mlx4_cmd_box parameter in QUERY_DEV_CAP
net/mlx4_core: Check port out-of-range before using in mlx4_slave_cap
net/mlx4_core: Fixes for VF / Guest startup flow
net/mlx4_en: Fix improper use of "port" parameter in mlx4_en_event
net/mlx4_core: Fix number of EQs used in ICM initialisation
net/mlx4_core: Fix the slave_id out-of-range test in mlx4_eq_int
This reverts the tty layer change to use per-tty locking, because it's
not correct yet, and fixing it will require some more deep surgery.
The main revert is d29f3ef39be4 ("tty_lock: Localise the lock"), but
there are several smaller commits that built upon it, they also get
reverted here. The list of reverted commits is:
fde86d310886 - tty: add lockdep annotations
8f6576ad476b - tty: fix ldisc lock inversion trace
d3ca8b64b97e - pty: Fix lock inversion
b1d679afd766 - tty: drop the pty lock during hangup
abcefe5fc357 - tty/amiserial: Add missing argument for tty_unlock()
fd11b42e3598 - cris: fix missing tty arg in wait_event_interruptible_tty call
d29f3ef39be4 - tty_lock: Localise the lock
The revert had a trivial conflict in the 68360serial.c staging driver
that got removed in the meantime.
skb_defer_rx_timestamp was called with a freshly allocated skb but must
be called with rskb instead.
Signed-off-by: Stephan Gatzka <stephan@gatzka.org>
Cc: stable <stable@vger.kernel.org>
Acked-by: Richard Cochran <richardcochran@gmail.com>
Add .status callback that detects link state changes.
Tested with MCS7832CV-AA chip (9710:7830, identified as rev.C by the driver).
Fixes https://bugzilla.kernel.org/show_bug.cgi?id=28532
Signed-off-by: Ondrej Zary <linux@rainbow-software.org>
The definition of I217_PROXY_CTRL must use the BM_PHY_REG() macro instead
of the PHY_REG() macro for PHY page 800 register 70 since it is for a PHY
register greater than the maximum allowed by the latter macro, and fix a
typo setting the I217_MEMPWR register in e1000_suspend_workarounds_ich8lan.
Also for clarity, rename a few defines as bit definitions instead of masks.
Signed-off-by: Bruce Allan <bruce.w.allan@intel.com>
Tested-by: Aaron Brown <aaron.f.brown@intel.com>
This is another fixup where the data is not transfered into buffer
addressed by skb->data but into a page.
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Pull fbdev updates from Florian Tobias Schandinat:
- driver for AUO-K1900 and AUO-K1901 epaper controller
- large updates for OMAP (e.g. decouple HDMI audio and video)
- some updates for Exynos and SH Mobile
- various other small fixes and cleanups
* tag 'fbdev-updates-for-3.5' of git://github.com/schandinat/linux-2.6: (130 commits)
video: bfin_adv7393fb: Fix cleanup code
video: exynos_dp: reduce delay time when configuring video setting
video: exynos_dp: move sw reset prioir to enabling sw defined function
video: exynos_dp: use devm_ functions
fb: handle NULL pointers in framebuffer release
OMAPDSS: HDMI: OMAP4: Update IRQ flags for the HPD IRQ request
OMAPDSS: Apply VENC timings even if panel is disabled
OMAPDSS: VENC/DISPC: Delay dividing Y resolution for managers connected to VENC
OMAPDSS: DISPC: Support rotation through TILER
OMAPDSS: VRFB: remove compiler warnings when CONFIG_BUG=n
OMAPFB: remove compiler warnings when CONFIG_BUG=n
OMAPDSS: remove compiler warnings when CONFIG_BUG=n
OMAPDSS: DISPC: fix usage of dispc_ovl_set_accu_uv
OMAPDSS: use DSI_FIFO_BUG workaround only for manual update displays
OMAPDSS: DSI: Support command mode interleaving during video mode blanking periods
OMAPDSS: DISPC: Update Accumulator configuration for chroma plane
drivers/video: fsl-diu-fb: don't initialize the THRESHOLDS registers
video: exynos mipi dsi: support reverse panel type
video: exynos mipi dsi: Properly interpret the interrupt source flags
video: exynos mipi dsi: Avoid races in probe()
Pull mtd update from David Woodhouse:
- More robust parsing especially of xattr data in JFFS2
- Updates to mxc_nand and gpmi drivers to support new boards and device tree
- Improve consistency of information about ECC strength in NAND devices
- Clean up partition handling of plat_nand
- Support NAND drivers without dedicated access to OOB area
- BCH hardware ECC support for OMAP
- Other fixes and cleanups, and a few new device IDs
Fixed trivial conflict in drivers/mtd/nand/gpmi-nand/gpmi-nand.c due to
added include files next to each other.
* tag 'for-linus-3.5-20120601' of git://git.infradead.org/linux-mtd: (75 commits)
mtd: mxc_nand: move ecc strengh setup before nand_scan_tail
mtd: block2mtd: fix recursive call of mtd_writev
mtd: gpmi-nand: define ecc.strength
mtd: of_parts: fix breakage in Kconfig
mtd: nand: fix scan_read_raw_oob
mtd: docg3 fix in-middle of blocks reads
mtd: cfi_cmdset_0002: Slight cleanup of fixup messages
mtd: add fixup for S29NS512P NOR flash.
jffs2: allow to complete xattr integrity check on first GC scan
jffs2: allow to discriminate between recoverable and non-recoverable errors
mtd: nand: omap: add support for hardware BCH ecc
ARM: OMAP3: gpmc: add BCH ecc api and modes
mtd: nand: check the return code of 'read_oob/read_oob_raw'
mtd: nand: remove 'sndcmd' parameter of 'read_oob/read_oob_raw'
mtd: m25p80: Add support for Winbond W25Q80BW
jffs2: get rid of jffs2_sync_super
jffs2: remove unnecessary GC pass on sync
jffs2: remove unnecessary GC pass on umount
jffs2: remove lock_super
mtd: gpmi: add gpmi support for mx6q
Pull x86 platform driver updates from Matthew Garrett:
"Some significant improvements for the Sony driver on newer machines,
but other than that mostly just minor fixes and a patch to remove the
broken rfkill code from the Dell driver."
* 'for_linus' of git://cavan.codon.org.uk/platform-drivers-x86: (35 commits)
apple-gmux: Fix up the suspend/resume patch
dell-laptop: Remove rfkill code
toshiba_acpi: Fix mis-merge
dell-laptop: Add touchpad led support for Dell V3450
acer-wmi: add 3 laptops to video backlight vendor mode quirk table
sony-laptop: add touchpad enable/disable function
sony-laptop: add missing Fn key combos for 0x100 handlers
sony-laptop: add support for more WWAN modems
sony-laptop: new keyboard backlight handle
sony-laptop: add high speed battery charging function
sony-laptop: support automatic resume on lid open
sony-laptop: adjust error handling in finding SNC handles
sony-laptop: add thermal profiles support
sony-laptop: support battery care functions
sony-laptop: additional debug statements
sony-laptop: improve SNC initialization and acpi notify callback code
sony-laptop: use kstrtoul to parse sysfs values
sony-laptop: generalise ACPI calls into SNC functions
sony-laptop: fix return path when no ACPI buffer is allocated
sony-laptop: use soft rfkill status stored in hw
Pull arm fixes for ux500 mismerge mishap from Arnd Bergmann:
"The device tree conversion for arm/ux500 in 3.5 turns out to be
incomplete because of a mismerge done by Linus Walleij that I failed
to notice early enough and that Lee Jones as the original author of
those patches did not manage to fix during the -next cycle. While we
originally to get a much larger set of ux500 device tree enablement
patches merged, this did not happen in time.
After some discussion at Linaro Connect conference this week, Lee has
been able to do damage control and provide a series to put the broken
platform back into usable shape for both DT and non-DT based booting.
This series has not been part of linux-next and is based on top of the
current state of the upstream kernel rather than an -rc, but this is
the best we could manage given the earlier breakage."
* 'ux500/hickup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: ux500: Enable probing of pinctrl through Device Tree
ARM: ux500: Add support for ab8500 regulators into the Device Tree
ARM: ux500: Provide regulator support for SMSC911x via Device Tree
ARM: ux500: Allow PRCMU regulator to be probed during a DT enabled boot
ARM: ux500: Apply db8500-prcmu regulator information to db8500 Device Tree
ARM: ux500: Only initialise STE's UIBs on boards which support them
ARM: ux500: Disable platform setup of the ab8500 when DT is enabled
ARM: ux500: Use correct format for dynamic IRQ assignment
ARM: ux500: Re-enable SMSC911x platform code registration during non-DT boots
ARM: ux500: PRCMU related configuration and layout corrections for Device Tree
ARM: ux500: Remove DB8500 PRCMU platform registration when DT is enabled
ARM: ux500: Disable SMSC911x platform code registration when DT is enabled
ARM: ux500: New DT:ed u8500_init_devices for one-by-one device enablement
ARM: ux500: New DT:ed snowball_platform_devs for one-by-one device enablement
pinctrl-nomadik: Allow Device Tree driver probing
when register_netdev fails, the init'ed NAPIs by netif_napi_add must be
deleted with netif_napi_del, and also when driver unloads, it should
delete the NAPI before unregistering netdevice using unregister_netdev.
Signed-off-by: Devendra Naga <devendra.aaru@gmail.com>
Pull drm fixes from Dave Airlie:
"A bunch of fixes:
- vmware memory corruption
- ttm spinlock balance
- cirrus/mgag200 work in the presence of efifb
and finally Alex and Jerome managed to track down a magic set of bits
that on certain rv740 and evergreen cards allow the correct use of the
complete set of render backends, this makes the cards operate
correctly in a number of scenarios we had issues in before, it also
manages to boost speed on benchmarks my large amounts on these
specific gpus."
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux:
drm/edid: Make the header fixup threshold tunable
drm/radeon: fix regression in UMS CS ioctl
drm/vmwgfx: Fix nasty write past alloced memory area
drm/ttm: Fix spinlock imbalance
drm/radeon: fixup tiling group size and backendmap on r6xx-r9xx (v4)
drm/radeon: fix HD6790, HD6570 backend programming
drm/radeon: properly program gart on rv740, juniper, cypress, barts, hemlock
drm/radeon: fix bank information in tiling config
drm/mgag200: kick off conflicting framebuffers earlier.
drm/cirrus: kick out conflicting framebuffers earlier
cirrus: avoid crash if driver fails to load
Since commit 6a918bade9dab40aaef80559bd1169c69e8d69cb, the mxc_nand driver
fails with:
Driver must set ecc.strength when using hardware ECC
This is because nand_scan_tail checks for correct ecc strength
settings, so we must set them up before nand_scan_tail.
Cc: stable@vger.kernel.org [3.4+]
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
The 'mtd_writev' interface calls the function assigned
to the '_write' field of a given mtd device if that is
not NULL. The block2mtd driver sets the '_writev' field
to the 'mtd_writev' function itself and thus causes a
endless loop.
This is caused by 1dbebd32562b3c2caeca35960e5cb00bfcc12900
(mtd: harmonize mtd_writev usage).
Remove the assignment from the block2mtd driver to fix the
issue.
Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
Cc: stable@kernel.org [3.3+]
Fix an issue which was introduced by the recent addition of ecc.strength.
The ecc.strength wasn't set in gpmi-nand, resulting in the following crash:
[ 2.550000] kernel BUG at drivers/mtd/nand/nand_base.c:3347!
[ 2.550000] [<c020841c>] (nand_scan_tail+0x328/0x650) from [<c02f68e0>] (gpmi_nand_probe+0x43c/0x5a4)
[ 2.550000] [<c02f68e0>] (gpmi_nand_probe+0x43c/0x5a4) from [<c01f6618>] (platform_drv_probe+0x14/0x18)
[ 2.550000] [<c01f6618>] (platform_drv_probe+0x14/0x18) from [<c01f55b0>] (driver_probe_device+0x74/0x1fc)
[ 2.550000] [<c01f55b0>] (driver_probe_device+0x74/0x1fc) from [<c01f57cc>] (__driver_attach+0x94/0x98)
[ 2.550000] [<c01f57cc>] (__driver_attach+0x94/0x98) from [<c01f3d40>] (bus_for_each_dev+0x50/0x80)
[ 2.550000] [<c01f3d40>] (bus_for_each_dev+0x50/0x80) from [<c01f4e18>] (bus_add_driver+0x188/0x25c)
[ 2.550000] [<c01f4e18>] (bus_add_driver+0x188/0x25c) from [<c01f5a70>] (driver_register+0x78/0x138)
[ 2.550000] [<c01f5a70>] (driver_register+0x78/0x138) from [<c043dc7c>] (gpmi_nand_init+0xc/0x30)
[ 2.550000] [<c043dc7c>] (gpmi_nand_init+0xc/0x30) from [<c0008824>] (do_one_initcall+0x108/0x17c)
[ 2.550000] [<c0008824>] (do_one_initcall+0x108/0x17c) from [<c042a8b8>] (kernel_init+0xfc/0x1bc)
[ 2.550000] [<c042a8b8>] (kernel_init+0xfc/0x1bc) from [<c000fab4>] (kernel_thread_exit+0x0/0x8)
I incorporated the wrong version of the suspend/resume patch for gmux,
and so lost David Woodhouse's fix to leave the backlight level unchanged
over suspend/resume. This fixes it up to v2.
MTD_OF_PARTS and the default setting is not working due to using 'Y'
instead of 'y', introduced in commit
d6137badeff1ef64b4e0092ec249ebdeaeb3ff37. This made our board, and
possibly other boards using DTS defined partitions and not having
CONFIG_MTD_OF_PARTS=y defined in the defconfig, fail to mount root.
Signed-off-by: Frank Svendsboe <frank.svendsboe@gmail.com>
Cc: stable@kernel.org [3.2+]
Currently, we terminate the eeprom access through clearing the CS by:
RTL_W8 (Cfg9346, ~EE_CS); or writeb (~EE_CS, ee_addr);
This would left the eeprom into "Config. Register Write Enable:"
state which is not expcted as the highest two bits were set to
0x11 ( expected is the "Normal" mode (0x00)). Solving this by write
0x0 instead of ~EE_CS when terminating the eeprom access.
Signed-off-by: Jason Wang <jasowang@redhat.com>
Currently, we enable the receiver before setting the ring address which could
lead the card DMA into unexpected areas. Solving this by set the ring address
before enabling the receiver.
btw. I find and test this in qemu as I didn't have a 8139cp card in hand. please
review it carefully.
Pull vfs changes from Al Viro.
"A lot of misc stuff. The obvious groups:
* Miklos' atomic_open series; kills the damn abuse of
->d_revalidate() by NFS, which was the major stumbling block for
all work in that area.
* ripping security_file_mmap() and dealing with deadlocks in the
area; sanitizing the neighborhood of vm_mmap()/vm_munmap() in
general.
* ->encode_fh() switched to saner API; insane fake dentry in
mm/cleancache.c gone.
* assorted annotations in fs (endianness, __user)
* parts of Artem's ->s_dirty work (jff2 and reiserfs parts)
* ->update_time() work from Josef.
* other bits and pieces all over the place.
Normally it would've been in two or three pull requests, but
signal.git stuff had eaten a lot of time during this cycle ;-/"
Fix up trivial conflicts in Documentation/filesystems/vfs.txt (the
'truncate_range' inode method was removed by the VM changes, the VFS
update adds an 'update_time()' method), and in fs/btrfs/ulist.[ch] (due
to sparse fix added twice, with other changes nearby).
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (95 commits)
nfs: don't open in ->d_revalidate
vfs: retry last component if opening stale dentry
vfs: nameidata_to_filp(): don't throw away file on error
vfs: nameidata_to_filp(): inline __dentry_open()
vfs: do_dentry_open(): don't put filp
vfs: split __dentry_open()
vfs: do_last() common post lookup
vfs: do_last(): add audit_inode before open
vfs: do_last(): only return EISDIR for O_CREAT
vfs: do_last(): check LOOKUP_DIRECTORY
vfs: do_last(): make ENOENT exit RCU safe
vfs: make follow_link check RCU safe
vfs: do_last(): use inode variable
vfs: do_last(): inline walk_component()
vfs: do_last(): make exit RCU safe
vfs: split do_lookup()
Btrfs: move over to use ->update_time
fs: introduce inode operation ->update_time
reiserfs: get rid of resierfs_sync_super
reiserfs: mark the superblock as dirty a bit later
The interface just doesn't work on some machines, and Dell haven't been
able to tell us either which machines those are or what we should be
doing instead. This would be fine, except it results in userspace ending
up confused and general sadness. So let's just rip it out for now.
6 bytes seems to be a reasonable default so far, but for the desperate
it's worth exposing this.
[airlied: change include to module.h for this]
Bugzilla: https://bugzilla.redhat.com/582559
Signed-off-by: Adam Jackson <ajax@redhat.com>
radeon_cs_parser_init is called by both the legacy UMS
CS ioctl and the KMS CS ioctl. Protect KMS specific
pieces of the code by checking that rdev is not NULL.
Reported-by: Michael Burian <michael.burian@sbg.at>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
Reviewed-by: Jerome Glisse <jglisse@redhat.com>
Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com>
Reviewed-by: Jakob Bornecrantz <jakob@vmware.com>
This imbalance may cause hangs when TTM is trying to swap out a buffer
that is already on the delayed delete list.
Tiling group size is always 256bits on r6xx/r7xx/r8xx/9xx. Also fix and
simplify render backend map. This now properly sets up the backend map
on r6xx-9xx which should improve 3D performance.
Vadim benchmarked also:
Some benchmarks on juniper (5750), fullscreen 1920x1080,
first result - kernel 3.4.0+ (fb21affa), second - with these patches:
Lightsmark: 91 fps => 123 fps +35%
Doom3: 74 fps => 101 fps +36%
Signed-off-by: Jerome Glisse <jglisse@redhat.com>
I managed to screw up the various backlight changes and ended up memsetting
the props structure after it had already been populated. This should fix it.
Without this bit sets we get broken rendering and
lockups.
fglrx sets this bit.
Bugs that should be fixed by this patch :
https://bugs.freedesktop.org/show_bug.cgi?id=49792
https://bugzilla.kernel.org/show_bug.cgi?id=43207
https://bugs.freedesktop.org/show_bug.cgi?id=39282
Acked-by: Alex Deucher <alexander.deucher@amd.com>
Need to program an additional VM register. This doesn't not currently
cause any problems, but allows us to program the proper backend
map in a subsequent patch which should improve performance on these
asics.
While there are cards with more than 8 mem banks, the max
number of banks from a tiling perspective is 8, so cap
the tiling config at 8 banks.
Fixes:
https://bugs.freedesktop.org/show_bug.cgi?id=43448
It appears grub2 can pass framebuffer info via efifb, so
we need to kick it off earlier to reserve the vram allocation.
(just a fixup same as for cirrus)
It appears that grub2 will pass framebuffer info via EFI,
this causes the vram reserve to fail, so kick out efifb
earlier before cirrus loads.
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=826983
Merge misc patches from Andrew Morton:
- the "misc" tree - stuff from all over the map
- checkpatch updates
- fatfs
- kmod changes
- procfs
- cpumask
- UML
- kexec
- mqueue
- rapidio
- pidns
- some checkpoint-restore feature work. Reluctantly. Most of it
delayed a release. I'm still rather worried that we don't have a
clear roadmap to completion for this work.
* emailed from Andrew Morton <akpm@linux-foundation.org>: (78 patches)
kconfig: update compression algorithm info
c/r: prctl: add ability to set new mm_struct::exe_file
c/r: prctl: extend PR_SET_MM to set up more mm_struct entries
c/r: procfs: add arg_start/end, env_start/end and exit_code members to /proc/$pid/stat
syscalls, x86: add __NR_kcmp syscall
fs, proc: introduce /proc/<pid>/task/<tid>/children entry
sysctl: make kernel.ns_last_pid control dependent on CHECKPOINT_RESTORE
aio/vfs: cleanup of rw_copy_check_uvector() and compat_rw_copy_check_uvector()
eventfd: change int to __u64 in eventfd_signal()
fs/nls: add Apple NLS
pidns: make killed children autoreap
pidns: use task_active_pid_ns in do_notify_parent
rapidio/tsi721: add DMA engine support
rapidio: add DMA engine support for RIO data transfers
ipc/mqueue: add rbtree node caching support
tools/selftests: add mq_perf_tests
ipc/mqueue: strengthen checks on mqueue creation
ipc/mqueue: correct mq_attr_ok test
ipc/mqueue: improve performance of send/recv
selftests: add mq_open_tests
Pull drm prime mmap/vmap code from Dave Airlie:
"As mentioned previously these are the extra bits of drm that relied on
the dma-buf pull to work, the first three just stub out the mmap
interface, and the next set provide vmap export to i915/radeon/nouveau
and vmap import to udl."
* 'drm-prime-vmap' of git://people.freedesktop.org/~airlied/linux:
radeon: add radeon prime vmap support.
nouveau: add vmap support to nouveau prime support
udl: support vmapping imported dma-bufs
i915: add dma-buf vmap support for exporting vmapped buffer
radeon: add stub dma-buf mmap functionality
nouveau: add stub dma-buf mmap functionality.
i915: add stub dma-buf mmap callback.
Adds support for DMA Engine API into Tsi721 mport driver.
Includes following changes for Tsi721 driver:
- Modifies BDMA register offset definitions to support per-channel handling
- Separates BDMA channel reserved for RIO Maintenance requests
- Adds DMA Engine callback routines
Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: Vinod Koul <vinod.koul@intel.com>
Cc: Li Yang <leoli@freescale.com>
Cc: Matt Porter <mporter@kernel.crashing.org>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Adds DMA Engine framework support into RapidIO subsystem.
Uses DMA Engine DMA_SLAVE interface to generate data transfers to/from
remote RapidIO target devices.
Introduces RapidIO-specific wrapper for prep_slave_sg() interface with an
extra parameter to pass target specific information.
Uses scatterlist to describe local data buffer. Address flat data buffer
on a remote side.
Acked-by: Vinod Koul <vinod.koul@linux.intel.com>
This driver uses PCI_CLASS_REVISION instead of PCI_REVISION_ID, so it
wasn't converted by 44c10138fd4bbc ("PCI: Change all drivers to use
pci_device->revision").
In one case, it even reads PCI revision ID without using it -- that code
is now removed...
Acked-by: "Nandigama, Nagalakshmi" <Nagalakshmi.Nandigama@lsi.com>
Cc: Eric Moore <eric.moore@lsi.com>
Acked-by: Auke Kok <auke-jan.h.kok@intel.com>
Cc: Greg KH <greg@kroah.com>
This patch adds a fixed regulator for use by the SMSC911x Ethernet
chip driver into the db8500 Device Tree. It also references other
regulators required by the same device.
Signed-off-by: Lee Jones <lee.jones@linaro.org>
The Nomadik GPIO controller now relies on Nomadik pinctrl, however
the pinctrl driver is not currently started by any ux500 platform.
This is requred or GPIOs do not work at all.
The "!mlx4_is_slave" is totally confusing. Fix with
constant MLX4_CMD_NATIVE, which is the intended behavior.
Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
Reviewed-by: Or Gerlitz <ogerlitz@mellanox.com>
The range check was performed after using the port number.
Reverse this to prevent a potential array overflow.
- pass the following parameters:
- firmware version (added QUERY_FW paravirtualization for that)
- disable Blueflame on slaves. KVM disables write combining on guests,
and we get better performance without BF in this case. (This requires
QUERY_DEV_CAP paravirtualization, also in this commit)
- max qp rdma as destination
- get rid of a chunk of "if (0)" dead code
Port is used as an array index before we know if that is proper.
For example, in the catas event case, port is zero; however,
the port index should lie in the range (1..2).
Fix this by using 'port' only in the events where it is of interest.
Test for port out of range in the default (unhandled event) case,
and do not output a message if it is not an ethernet port.
In SRIOV mode, the number of EQs used when computing the total ICM size
was incorrect.
To fix this, we do the following:
1. We add a new structure to mlx4_dev, mlx4_phys_caps, to contain physical HCA
capabilities. The PPF uses the phys capabilities when it computes things
like ICM size.
The dev_caps structure will then contain the paravirtualized values, making
bookkeeping much easier in SRIOV mode. We add a structure rather than a
single parameter because there will be other fields in the phys_caps.
The first field we add to the mlx4_phys_caps structure is num_phys_eqs.
2. In INIT_HCA, when running in SRIOV mode, the "log_num_eqs" parameter
passed to the FW is the number of EQs per VF/PF; each function (PF or VF)
has this number of EQs available.
However, the total number of EQs which must be allowed for in the ICM is
(1 << log_num_eqs) * (#VFs + #PFs). Rather than compute this quantity,
we allocate ICM space for 1024 EQs (which is the device maximum
number of EQs, and which is the value we place in the mlx4_phys_caps structure).
For INIT_HCA, however, we use the per-function number of EQs as described
above.
Signed-off-by: Marcel Apfelbaum <marcela@dev.mellanox.co.il>
Ths fixes the comparison in the FLR (Function Level Reset) event case.
Pull battery updates from Anton Vorontsov:
"A bunch of fixes for v3.5, nothing extraordinary."
* tag 'for-v3.5' of git://git.infradead.org/battery-2.6: (27 commits)
smb347-charger: Include missing <linux/err.h>
smb347-charger: Clean up battery attributes
max17042_battery: Add support for max17047/50 chip
sbs-battery.c: Capacity attr = remaining relative capacity
isp1704_charger: Use after free on probe error
ds2781_battery: Use DS2781_PARAM_EEPROM_SIZE and DS2781_USER_EEPROM_SIZE
power_supply: Fix a typo in BATTERY_DS2781 Kconfig entry
charger-manager: Provide cm_notify_event function for in-kernel use
charger-manager: Poll battery health in normal state
smb347-charger: Convert to regmap API
smb347-charger: Move IRQ enabling to the end of probe
smb347-charger: Rename few functions to match better what they are doing
smb347-charger: Convert to use module_i2c_driver()
smb347_charger: Cleanup power supply registration code in probe
ab8500: Clean up probe routines
ab8500_fg: Harden platform data check
ab8500_btemp: Harden platform data check
ab8500_charger: Harden platform data check
MAINTAINERS: Fix 'F' entry for the power supply class
max17042_battery: Handle irq request failure case
Pull final round of SCSI updates from James Bottomley:
"This is primarily another round of driver updates (bnx2fc, qla2xxx,
qla4xxx) including the target mode driver for qla2xxx. We've also got
a couple of regression fixes (async scanning, broken this merge window
and a fix to a long standing break in the scsi_wait_scan module)."
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (45 commits)
[SCSI] fix scsi_wait_scan
[SCSI] fix async probe regression
[SCSI] be2iscsi: fix dma free size mismatch regression
[SCSI] qla4xxx: Update driver version to 5.02.00-k17
[SCSI] qla4xxx: Capture minidump for ISP82XX on firmware failure
[SCSI] qla4xxx: Add change_queue_depth API support
[SCSI] qla4xxx: Fix clear ddb mbx command failure issue.
[SCSI] qla4xxx: Fix kernel panic during discovery logout.
[SCSI] qla4xxx: Correct early completion of pending mbox.
[SCSI] fcoe, bnx2fc, libfcoe: SW FCoE and bnx2fc use FCoE Syfs
[SCSI] libfcoe: Add fcoe_sysfs
[SCSI] bnx2fc: Allocate fcoe_ctlr with bnx2fc_interface, not as a member
[SCSI] fcoe: Allocate fcoe_ctlr with fcoe_interface, not as a member
[SCSI] Fix dm-multipath starvation when scsi host is busy
[SCSI] ufs: fix potential NULL pointer dereferencing error in ufshcd_prove.
[SCSI] qla2xxx: don't free pool that wasn't allocated
[SCSI] mptfusion: unlock on error in mpt_config()
[SCSI] tcm_qla2xxx: Add >= 24xx series fabric module for target-core
[SCSI] qla2xxx: Add LLD target-mode infrastructure for >= 24xx series
[SCSI] Revert "qla2xxx: During loopdown perform Diagnostic loopback."
Pull follow-up block updates from Jens Axboe:
"Includes the fix from Eric to resolve the infinite loop in looking up
or creating an IO context for an exiting task.
Also a bunch of mtip32xx patches. Fairly trivial stuff. It's fairly
new though, but no point in keeping it out of the tree until 3.6 imho.
I've thrown it through basic testing locally as well, works fine. The
one contentious part is the patch that Greg complained about (sysfs
file with multiple values, should be a debugfs file), which is
perfectly valid, but not a regression from what the file contains now.
That will be fixed up separately."
* 'for-linus' of git://git.kernel.dk/linux-block:
block: avoid infinite loop in get_task_io_context()
mtip32xx: Changes to sysfs entries
mtip32xx: Convert macro definitions for flag bits to enum
mtip32xx: minor performance tweak
mtip32xx: Fix to support more than one sector in exec_drive_command()
mtip32xx: Use plain spinlock for 'cmd_issue_lock'
mtip32xx: Set block queue boundary variables
mtip32xx: Fix to handle TFE for PIO(IOCTL/internal) commands
mtip32xx: Change HDIO_GET_IDENTITY to return stored data
mtip32xx: Set custom timeouts for PIO commands
mtip32xx: fix clearing an incorrect register in mtip_init_port
tty_lock_pair() do the right thing to avoid deadlocks, but should
instruct LOCKDEP of this to avoid a splat.
Add Dell Vostro 3450 quirk to support touchpad LED.
CC: Mariusz Fik <fisiu@opensuse.org>
Signed-off-by: AceLan Kao <acelan.kao@canonical.com>
