CONFIG_HOTPLUG is going away as an option so __devexit is no
longer needed.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Cc: Peter Korsgaard <jacmet@sunsite.dk>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Acked-by: Felipe Balbi <balbi@ti.com>
Cc: Li Yang <leoli@freescale.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Wan ZongShun <mcuos.com@gmail.com>
Cc: Ben Dooks <ben-linux@fluff.org>
Cc: Kukjin Kim <kgene.kim@samsung.com>
CONFIG_HOTPLUG is going away as an option so __devinitconst is no
longer needed.
CONFIG_HOTPLUG is going away as an option so __devinitdata is no
longer needed.
CONFIG_HOTPLUG is going away as an option so __devinit is no longer
needed.
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Cc: Geoff Levand <geoff@infradead.org>
Cc: Olav Kongas <ok@artecdesign.ee>
Cc: Lennert Buytenhek <kernel@wantstofly.org>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer
needed.
Acked-by: Peter Korsgaard <jacmet@sunsite.dk>
Remove conditional code based on CONFIG_HOTPLUG being false. It's
always on now in preparation of it going away as an option.
This resolves a conflict with these files:
drivers/usb/early/ehci-dbgp.c
drivers/usb/host/ehci-ls1x.c
drivers/usb/host/ohci-xls.c
drivers/usb/musb/ux500.c
Merge misc fixes from Andrew Morton.
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (12 patches)
revert "mm: fix-up zone present pages"
tmpfs: change final i_blocks BUG to WARNING
tmpfs: fix shmem_getpage_gfp() VM_BUG_ON
mm: highmem: don't treat PKMAP_ADDR(LAST_PKMAP) as a highmem address
mm: revert "mm: vmscan: scale number of pages reclaimed by reclaim/compaction based on failures"
rapidio: fix kernel-doc warnings
swapfile: fix name leak in swapoff
memcg: fix hotplugged memory zone oops
mips, arc: fix build failure
memcg: oom: fix totalpages calculation for memory.swappiness==0
mm: fix build warning for uninitialized value
mm: add anon_vma_lock to validate_mm()
Fix rapidio kernel-doc warnings:
Warning(drivers/rapidio/rio.c:415): No description found for parameter 'local'
Warning(drivers/rapidio/rio.c:415): Excess function parameter 'lstart' description in 'rio_map_inb_region'
Warning(include/linux/rio.h:290): No description found for parameter 'switches'
Warning(include/linux/rio.h:290): No description found for parameter 'destid_table'
Cc: Matt Porter <mporter@kernel.crashing.org>
Acked-by: Alexandre Bounine <alexandre.bounine@idt.com>
Pull networking updates from David Miller:
1) tx_filtered/ps_tx_buf queues need to be accessed with the SKB queue
lock, from Arik Nemtsov.
2) Don't call 802.11 driver's filter configure method until it's
actually open, from Felix Fietkau.
3) Use ieee80211_free_txskb otherwise we leak control information.
From Johannes Berg.
4) Fix memory leak in bluetooth UUID removal,f rom Johan Hedberg.
5) The shift mask trick doesn't work properly when 'optname' is out of
range in do_ip_setsockopt(). Use a straightforward switch statement
instead, the compiler emits essentially the same code but without
the missing range check. From Xi Wang.
6) Fix when we call tcp_replace_ts_recent() otherwise we can
erroneously accept a too-high tsval. From Eric Dumazet.
7) VXLAN bug fixes, mostly to do with VLAN header length handling, from
Alexander Duyck.
8) Missing return value initialization for IPV6_MINHOPCOUNT socket
option handling. From Hannes Frederic.
9) Fix regression in tasklet handling in jme/ksz884x/xilinx drivers,
from Xiaotian Feng.
10) At smsc911x driver init time, we don't know if the chip is in word
swap mode or not. However we do need to wait for the control
register's ready bit to be set before we program any other part of
the chip. Adjust the wait loop to account for this. From Kamlakant
Patel.
11) Revert erroneous MDIO bus unregister change to mdio-bitbang.c
12) Fix memory leak in /proc/net/sctp/, from Tommi Rantala.
13) tilegx driver registers IRQ with NULL name, oops, from Simon Marchi.
14) TCP metrics hash table kzalloc() based allocation can fail, back
down to using vmalloc() if it does. From Eric Dumazet.
15) Fix packet steering out-of-order delivery regression, from Tom
Herbert.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (40 commits)
net-rps: Fix brokeness causing OOO packets
tcp: handle tcp_net_metrics_init() order-5 memory allocation failures
batman-adv: process broadcast packets in BLA earlier
batman-adv: don't add TEMP clients belonging to other backbone nodes
batman-adv: correctly pass the client flag on tt_response
batman-adv: fix tt_global_entries flags update
tilegx: request_irq with a non-null device name
net: correct check in dev_addr_del()
tcp: fix retransmission in repair mode
sctp: fix /proc/net/sctp/ memory leak
Revert "drivers/net/phy/mdio-bitbang.c: Call mdiobus_unregister before mdiobus_free"
net/smsc911x: Fix ready check in cases where WORD_SWAP is needed
drivers/net: fix tasklet misuse issue
ipv4/ip_vti.c: VTI fix post-decryption forwarding
brcmfmac: fix typo in CONFIG_BRCMISCAN
vxlan: Update hard_header_len based on lowerdev when instantiating VXLAN
vxlan: fix a typo.
ipv6: setsockopt(IPIPPROTO_IPV6, IPV6_MINHOPCOUNT) forgot to set return value
doc/net: Fix typo in netdev-features.txt
vxlan: Fix error that was resulting in VXLAN MTU size being 10 bytes too large
Pull ARM SoC fixes from Olof Johansson:
"We've been sitting on this longer than we meant to due to travel and
other activities, but the number of patches is luckily not that high.
Biggest changes are from a batch of OMAP bugfixes, but there are a few
for the broader set of SoCs too (bcm2835, pxa, highbank, tegra, at91
and i.MX).
The OMAP patches contain some fixes for MUSB/PHY on omap4 which ends
up being a bit on the large side but needed for legacy (non-DT)
platforms. Beyond that there are a handful of hwmod/pm changes.
So, fairly noncontroversial stuff all in all, and as usual around this
time the fixes are well targeted at specific problems."
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: imx: ehci: fix host power mask bit
ARM i.MX: fix error-valued pointer dereference in clk_register_gate2()
ARM: at91/usbh: fix overcurrent gpio setup
ARM: at91/AT91SAM9G45: fix crypto peripherals irq issue due to sparse irq support
ARM: boot: Fix usage of kecho
ARM: OMAP: ocp2scp: create omap device for ocp2scp
ARM: OMAP4: add _dev_attr_ to ocp2scp for representing usb_phy
drivers: bus: ocp2scp: add pdata support
irqchip: irq-bcm2835: Add terminating entry for of_device_id table
ARM: highbank: retry wfi on reset request
ARM: OMAP4: PM: fix regulator name for VDD_MPU
ARM: OMAP4: hwmod data: do not enable or reset the McPDM during kernel init
ARM: OMAP2+: hwmod: add flag to prevent hwmod code from touching IP block during init
ARM: dt: tegra: fix length of pad control and mux registers
ARM: OMAP: hwmod: wait for sysreset complete after enabling hwmod
ARM: OMAP2+: clockdomain: Fix OMAP4 ISS clk domain to support only SWSUP
ARM: pxa/spitz_pm: Fix hang when resuming from STR
ARM: pxa: hx4700: Fix backlight PWM device number
ARM: OMAP2+: PM: add missing newline to VC warning message
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless into for-davem
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid
Pull HID fix from Jiri Kosina:
"This has a build fix for architectures where memcmp() is macro, from
Jiri Slaby"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid:
HID: microsoft: do not use compound literal - fix build
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB fixes from Greg Kroah-Hartman:
"Here are some USB fixes for the 3.7 tree.
Nothing huge here, just a number of tiny bugfixes resolving issues
that have been found, and two reverts of patches that were found to
have caused problems.
All of these have been in linux-next already.
Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>"
* tag 'usb-3.7-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb:
Revert "USB/host: Cleanup unneccessary irq disable code"
USB: option: add Alcatel X220/X500D USB IDs
USB: option: add Novatel E362 and Dell Wireless 5800 USB IDs
USB: keyspan: fix typo causing GPF on open
USB: fix build with XEN and EARLY_PRINTK_DBGP enabled but USB_SUPPORT disabled
USB: usb_wwan: fix bulk-urb allocation
usb: otg: Fix build errors if USB_MUSB_OMAP2PLUS is selected as module
usb: musb: ux500: fix 'musbid' undeclared error in ux500_remove()
Revert "usb: musb: use DMA mode 1 whenever possible"
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull TTY fixes from Greg Kroah-Hartman:
"Here are two TTY driver fixes for 3.7-rc5.
They resolve a bug in the hvc driver that has been reported, and fix a
problem with the list of device ids in the max310x serial driver.
Both have been in linux-next for a while.
* tag 'tty-3.7-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty:
tty: serial: max310x: Add terminating entry for spi_device_id table
TTY: hvc_console, fix port reference count going to zero prematurely
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging tree fix from Greg Kroah-Hartman:
"Here is a single patch, a revert of an android driver patch, that
resolves a bug that has been reported in the Android alarm driver.
* tag 'staging-3.7-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging:
Revert "Staging: Android alarm: IOCTL command encoding fix"
fixes
From Sascha Hauer <s.hauer@pengutronix.de>:
ARM i.MX fixes for 3.7-rc
* tag 'imx-fixes-rc' of git://git.pengutronix.de/git/imx/linux-2.6:
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux
Pull s390 patches from Martin Schwidefsky:
"Some more bug fixes and a config change.
The signal bug is nasty, if the clock_gettime vdso function is
interrupted by a signal while in access-register-mode we end up with
an endless signal loop until the signal stack is full. The config
change is for aligned struct pages, gives us 8% improvement with
hackbench."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux:
s390/3215: fix tty close handling
s390/mm: have 16 byte aligned struct pages
s390/gup: fix access_ok() usage in __get_user_pages_fast()
s390/gup: add missing TASK_SIZE check to get_user_pages_fast()
s390/topology: fix core id vs physical package id mix-up
s390/signal: set correct address space control
Pull drm fixes from Dave Airlie:
"All pretty normal: one TTM oops fix, one radeon, a few intel and a
vmwgfx fix."
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux:
drm/ttm: remove unneeded preempt_disable/enable
ttm: Clear the ttm page allocated from high memory zone correctly
vmwgfx: return an -EFAULT if copy_to_user() fails
drm/radeon: fix logic error in atombios_encoders.c
drm/i915: do not ignore eDP bpc settings from vbt
drm/i915/sdvo: clean up connectors on intel_sdvo_init() failures
drm/i915/crt: fix DPMS standby and suspend mode handling
commit 392142 moved event buffer allocation out of dwc3_core_init() but
event buffer allocation uses the cached copy of hwparams to determine
the number of event buffers and the caching is done in dwc3_core_init.
So moved dwc3_cache_hwparams function before dwc3_alloc_event_buffers so
that dwc3_alloc_event_buffers sees the correct number of event buffers.
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
This patch simply makes the tilegx net driver call request_irq with a
non-null name. It makes the output in /proc/interrupts more obvious, but
also helps tools that don't expect to find null there.
Signed-off-by: Simon Marchi <simon.marchi@polymtl.ca>
Acked-by: Chris Metcalf <cmetcalf@tilera.com>
The old parameter "port" is useless for phy notify, as one usb
phy is only for one usb port. New parameter "speed" stands for
the device's speed which is on the port, this "speed" parameter
is needed at some platforms which will do some phy operations
according to device's speed.
Signed-off-by: Peter Chen <peter.chen@freescale.com>
Tested-by: Mike Thompson <mpthompson@gmail.com>
At commit 925aa46ba963a4da6d8ee6ab1d04a02ffa8db62b, Richard Zhao
<richard.zhao@freescale.com> adds the phy notification callback
when port change occurs. In fact, this phy notification should
be added according to below rules:
1. Only set HW_USBPHY_CTRL.ENHOSTDISCONDETECT
during high speed host mode.
2. Do not set HW_USBPHY_CTRL.ENHOSTDISCONDETECT
during the reset and speed negotiation period.
3. Do not set HW_USBPHY_CTRL.ENHOSTDISCONDETECT
during host suspend/resume sequence.
Please refer: i.mx23RM(page: 413) for below rules.
http://www.freescale.com/files/dsp/doc/ref_manual/IMX23RM.pdf
Freescale i.MX SoC, i.mx23, i.mx28 and i.mx6(i.mx6SL does not
need to follow the 3rd rule) need to follow above rules.
Current code set connect notification (HW_USBPHY_CTRL.ENHOSTDISCONDETECT)
at hub_port_connect_change, it conflicts with above the 2th rule.
The correct notification setting method should be:
1. Set connect notify after the second bus reset.
2. Set disconnect notify after disconnection.
As phy is working, re-init phy may cause unexpected results
The real reason causes mx23 fail are:
- Calling mxs_phy_hw_init(mxs_phy) again at connection
- Error connect/disconnect nodity at hub.c
The coming patch will fix above two problems, Mike Thompson
tested his hardware works OK after commented out this delay
setting.
This reverts commit 363366cf61c544ea476f3d220f43a95cb03014f5.
Some devices (ex Nokia C7) simply don't respond at all when data is sent
to some of their USB interfaces. The data gets stuck in the TTYs queue
and sits there until close(2), which them blocks because closing_wait
defaults to 30 seconds (even though the fd is O_NONBLOCK). This is
rarely desired. Implement the standard mechanism to adjust closing_wait
and let applications handle it how they want to.
See also 02303f73373aa1da19dbec510ec5a4e2576f9610 for usb_wwan.c.
Signed-off-by: Dan Williams <dcbw@redhat.com>
Cc: stable <stable@vger.kernel.org>
Acked-by: Oliver Neukum <oneukum@suse.de>
Tested-by: Aleksander Morgado <aleksander@gnu.org>
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a
while now and is almost always enabled by default. As agreed during the
Linux kernel summit, remove it from any "depends on" lines in Kconfigs.
It looks like I've run into some inconsistency in the USB stack behavior.
The USB stack maintains, among others, two states for the attach
USB device: authorized and owned. Authorization state is accessible to
the user space code through correspondent sysfs files, the ownership
can be set by claiming the hub's port with ioctl call. Both state may
be set before the device is attached, by access the hub settings. When
the new device is attached, both authorization and ownership prevent
the kernel USB stack from setting the newly attached device
configuration, but when the device is authorized, the ownership state
is ignored. It looks like ignoring the ownership state on
authorization make the stack behavior inconsistent; it also prevents
the user space code from completely overriding configuration
selection, important for implementing workarounds for bugs in the
device configuration selection.
The following patch makes the stack behavior more consistent, by
moving ownership test into usb_choose_configuration - the later
function is used both by generic_probe and usb_authorize_device
Signed-off-by: Joseph Hindin <hindin@gmail.com>
git://people.freedesktop.org/~danvet/drm-intel into drm-fixes
Daniel writes:
Just a few small things to fix regressions, somehow all patches from Jani:
- Fix dpms confusion about which platforms support intermediate modes on
vga.
- Revert the "ignore vbt for eDP bpc" patch, it breaks machines. This will
annoy mbp retina owners again, but windows machines seem to _really_
depend upon this. We can try to quirk the mbp retinas again in 3.8 and
backport the patch.
- Fix connector leaks when the sdvo setup failed, resulted in an OOPS
later on when trying to probe that connector (with it's encoder kfree'd
already).
* 'drm-intel-fixes' of git://people.freedesktop.org/~danvet/drm-intel:
into drm-fixes
Just a single radeon fix from Alex.
* 'drm-fixes-3.7' of git://people.freedesktop.org/~agd5f/linux:
It is unnecessary to disable preemption explicitly while calling
copy_highpage(). Because copy_highpage() will do it again through
kmap_atomic/kunmap_atomic.
Reviewed-by: Thomas Hellstrom <thellstrom@vmware.com>
The TTM page can be allocated from high memory. In such case it is
wrong to use the page_address(page) as the virtual address for the high memory
page.
bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=50241
Signed-off-by: Zhao Yakui <yakui.zhao@intel.com>
Cc: stable@vger.kernel.org
copy_to_user() returns the number of bytes remaining to be copied, but
we want to return a negative error code here. I fixed a couple of these
last year, but I missed this one.
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging
Pill i2c fixes from Jean Delvare.
Well, "fixes".. The biggest patch here is actually Jan marking Wolfram
Sang as the main i2c subsystem maintainer, with Jan staying on as the PC
controller maintainer.
* 'i2c-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging:
i2c-mux-pinctrl: Fix probe error path
MAINTAINERS: i2c: 7 years, this is it
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator
Pull regulator fixes from Mark Brown:
"A few fixes for teardown issues that will be rarely seen, plus a fix
for a silly bug in regulator_is_supported_voltage() which shows how
often the answer to the question should be false.
The supported voltage commit is very new as I just edited to add a Cc
to stable, the code itself has been in -next."
* tag 'regulator-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator:
regulator: fix voltage check in regulator_is_supported_voltage()
regulator: core: Avoid deadlock when regulator_register fails
Regulator: core: Unregister when gpio request fails.
The 3215 console always has the RAW3215_FIXED flag set, which causes
raw3215_shutdown() not to wait for outstanding I/O requests if an attached
tty gets closed.
The flag however can be simply removed, so we can guarantee that all requests
belonging to the tty have been processed when the tty is closed.
However the tasklet that belongs to the 3215 device may be scheduled even if
there is no tty attached anymore, since we have a race between console and tty
processing.
Thefore unconditional tty_wakekup() in raw3215_wakeup() can cause the following
NULL pointer dereference:
3.465368 Unable to handle kernel pointer dereference at virtual kernel address (null)
3.465448 Oops: 0004 #1 SMP
3.465454 Modules linked in:
3.465459 CPU: 1 Not tainted 3.6.0 #1
3.465462 Process swapper/1 (pid: 0, task: 000000003ffa4428, ksp: 000000003ffb7ce0)
3.465466 Krnl PSW : 0404100180000000 0000000000162f86 (__wake_up+0x46/0xb8)
3.465480 R:0 T:1 IO:0 EX:0 Key:0 M:1 W:0 P:0 AS:0 CC:1 PM:0 EA:3
Krnl GPRS: fffffffffffffffe 0000000000000000 0000000000000160 0000000000000001
3.465492 0000000000000001 0000000000000004 0000000000000004 000000000096b490
3.465499 0000000000000001 0000000000000100 0000000000000001 0000000000000001
3.465506 070000003fc87d60 0000000000000160 000000003fc87d68 000000003fc87d00
3.465526 Krnl Code: 0000000000162f76: e3c0f0a80004 lg %r12,168(%r15)
0000000000162f7c: 58000370 l %r0,880
#0000000000162f80: c007ffffffff00 xilf %r0,4294967295
>0000000000162f86: ba102000 cs %r1,%r0,0(%r2)
0000000000162f8a: 1211 ltr %r1,%r1
0000000000162f8c: a774002f brc 7,162fea
0000000000162f90: b904002d lgr %r2,%r13
0000000000162f94: b904003a lgr %r3,%r10
3.465597 Call Trace:
3.465599 (<0400000000000000> 0x400000000000000)
3.465602 <000000000048c77e> raw3215_wakeup+0x2e/0x40
3.465607 <0000000000134d66> tasklet_action+0x96/0x168
3.465612 <000000000013423c> __do_softirq+0xd8/0x21c
3.465615 <0000000000134678> irq_exit+0xa8/0xac
3.465617 <000000000046c232> do_IRQ+0x182/0x248
3.465621 <00000000005c8296> io_return+0x0/0x8
3.465625 <00000000005c7cac> vtime_stop_cpu+0x4c/0xb8
3.465629 (<0000000000194e06> tick_nohz_idle_enter+0x4e/0x74)
3.465633 <0000000000104760> cpu_idle+0x170/0x184
3.465636 <00000000005b5182> smp_start_secondary+0xd6/0xe0
3.465641 <00000000005c86be> restart_int_handler+0x56/0x6c
3.465643 <0000000000000000> 0x0
3.465645 Last Breaking-Event-Address:
3.465647 <0000000000403136> tty_wakeup+0x46/0x98
3.465652
3.465654 Kernel panic - not syncing: Fatal exception in interrupt
01: HCPGIR450W CP entered; disabled wait PSW 00020001 80000000 00000000 0010F63C
The easiest solution is simply to check if tty is NULL in the tasklet.
If it is NULL nothing is to do (no tty attached), otherwise tty_wakeup()
can be called, since we hold a reference to the tty.
This is not nice... but it is a small patch and it works.
Fixes:
https://bugzilla.kernel.org/show_bug.cgi?id=50431
Reported-by: David Binderman <dcb314@hotmail.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
Reviewed-by: Michel Dänzer <michel.daenzer@amd.com>
mdiobus_free"
This reverts commit aa731872f7d33dcb8b54dad0cfb82d4e4d195d7e.
As pointed out by Ben Hutchings, this change is not correct.
mdiobus_unregister() can't be called if the bus isn't registered yet,
however this change can result in situations which cause that to
happen.
Part of the confusion here revolves around the fact that the
callers of this module control registration/unregistration,
rather than the module itself.
The chip ready check added by the commit 3ac3546e [Always wait for
the chip to be ready] does not work when the register read/write
is word swapped. This check has been added before the WORD_SWAP
register is programmed, so we need to check for swapped register
value as well.
Bit 16 is marked as RESERVED in SMSC datasheet, Steve Glendinning
<steve@shawell.net> checked with SMSC and wrote:
The chip architects have concluded we should be reading PMT_CTRL
until we see any of bits 0, 8, 16 or 24 set. Then we should read
BYTE_TEST to check the byte order is correct (as we already do).
The rationale behind this is that some of the chip variants have
word order swapping features too, so the READY bit could actually
be in any of the 4 possible locations. The architects have confirmed
that if any of these 4 positions is set the chip is ready. The other
3 locations will either never be set or can only go high after READY
does (so also indicate the device is ready).
This change will check for the READY bit at the 16th position. We do
not check the other two cases (bit 8 and 24) since the driver does not
support byte-swapped register read/write.
Signed-off-by: Kamlakant Patel <kamlakant.patel@broadcom.com>
In commit 175c0dff, drivers uses tasklet_kill to avoid put disabled tasklet
on the tasklet vec. But some of the drivers uses tasklet_init & tasklet_disable
in the driver init code, then tasklet_enable when it is opened. This makes
tasklet_enable on a killed tasklet and make ksoftirqd crazy then. Normally,
drivers should use tasklet_init/tasklet_kill on device open/remove, and use
tasklet_disable/tasklet_enable on device suspend/resume.
Reported-by: Peter Wu <lekensteyn@gmail.com>
Tested-by: Peter Wu <lekensteyn@gmail.com>
Signed-off-by: Xiaotian Feng <dannyfeng@tencent.com>
Cc: netdev@vger.kernel.org
'regulator/fix/supp-volt' into tmp
regulator_is_supported_voltage() should return true only if the voltage
of fixed/constant regulator is between min_uV and max_uV.
The spi_device_id table is supposed to be zero-terminated.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
Commit bdb498c20040 "TTY: hvc_console, add tty install" took the port
refcounting out of hvc_open()/hvc_close(), but failed to remove the
kref_put() and tty_kref_put() calls in hvc_hangup() that were there to
remove the extra references that hvc_open() had taken.
The result was that doing a vhangup() when the current terminal was
a hvc_console, then closing the current terminal, would end up calling
destroy_hvc_struct() and making the port disappear entirely. This
meant that Fedora 17 systems would boot up but then not display the
login prompt on the console, and attempts to open /dev/hvc0 would
give a "No such device" error.
This fixes it by removing the extra kref_put() and tty_kref_put() calls.
Acked-by: Jiri Slaby <jslaby@suse.cz>
To facilitate upcoming cleanup in twl stack.
No functional changes.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
since commit b4036cc (usb: gadget: add
isochronous support to gadget zero), g_zero
has learned about isochronous transfers, which
allows us to use usbtest.ko to exercise
isochronous pipes.
All we need to do to enable that functionality
on usbtest.ko, is set the "iso" to 1 on
struct usbtest_info
Signed-off-by: Boyan Nedeltchev <boyan@ti.com>
This patch frees SPEAr ehci/ohci drivers from tension of freeing resources :)
devm_* derivatives of multiple routines are used while allocating resources,
which would be freed automatically by kernel.
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
We used to get clk using con-id, but now we have device struct available for
these devices as they are probed using DT. And so must get clk using dev-id.
Signed-off-by: Amardeep Rai <amardeep.rai-ext@st.com>
Since commit c73cee7 (USB: EHCI: remove ehci_port_power() routine), the
'ehci' variable is no longer used, so remove it and fix the following
build warning:
drivers/usb/host/ehci-mxc.c:41:19: warning: unused variable 'ehci' [-Wunused-variable]
Test for tegra and hcd in tegra_ehci_remove() look like potential
NULL pointer dereference, but in fact those tests are not needed,
so remove these pointless tests entirely.
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
