path: root/drivers
2009-11-02tg3 / broadcom: Add APD support for GPHYsMatt Carlson
This patch adds an RXC auto power-down feature to the code that supports the gphys. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02tg3 / broadcom: Add code to disable rxc refclkMatt Carlson
The 5785 does not use the RXC reference clock. Turning it off is desirable as it saves power. By default, the 50610 enables the RXC reference clock and the 50610M disables it. Presumably this is one of the reasons why the hardware architect chose one over the other. Adding a "rx reference clock disable" flag is not the ideal way to describe the option, as it would force the MAC using a 50610M to set the flag. Ideally we want the flags to represent opt-in behavior that deviates from hardware defaults. Furthermore, the lack of a "disable" flag implies that the requester wants the rx reference clock enabled, which doesn't necessarily follow. By presenting the option as a passive statement (rx reference clock unused) rather than a command, I hope to convey an opt-in option to disable the rx reference clock that falls back to hardware defaults if not set. A secondary benefit of this is that it keeps the intelligence about phy defaults in the broadcom module where it belongs and allows the broadcom module more latitude should a bug arise. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02tg3 / broadcom: Refine AC131 APD supportMatt Carlson
Auto power-down (APD) support is a power-saving feature. It should be selectively enabled since it might expose MAC bugs. This patch changes the code to enable APD only if the PHY_BRCM_AUTO_PWRDWN_ENABLE flag is set. The tg3 driver was changed to set this bit. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02tg3 / broadcom: Add PHY_BRCM_CLEAR_RGMII_MODE flagMatt Carlson
Broadcom 50610M parts changed the default definitions of the RGMII mode shadow register. The 5785 needs the RGMII mode selection bits [4:3] cleared. The default value of the remaining bits in this register are zero. Rather than unnecessarily burn an extra bit in the dev_flags member in an attempt to enumerate all possible combinations, this patch take a more course grained approach and labels the option as "clear all bits". Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02broadcom: Consolidate dev_flags definitionsMatt Carlson
This patch moves all the dev_flags enumerations outside the broadcom.c file to include/linux/brcmphy.h. The existing flags were not used yet and have been re-enumerated to avoid conflicts. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02tg3: Add 50610M phy ID for 5785Matt Carlson
This patch adds the 50610M phy ID for 5785. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02broadcom: Fix slow link problemMatt Carlson
When a 50610 or 50610M is paired against particular remote partners, link is slow to come up. This patch works around the problem. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02broadcom: Isolate phy dsp accessesMatt Carlson
This patch consolidates the code that requires the SMDSP clock to be enabled into a single function that (hopefully) makes the dependency obvious. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02tg3: Extend loopback test timeoutMatt Carlson
This patch extends the loopback test timeout from 250 usec to 350 usec. When the 5785 is paired against an AC131 phy, the older timeout is just a little too close to the expected performance based on timings. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02tg3: 5785: Set port mode to MII when link downMatt Carlson
This patch sets the port mode to MII when the link is down for the 5785. Setting the port mode to MII instead of GMII saves power. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02tg3: Add AC131 power down supportMatt Carlson
The AC131 does not respect the power down bit (bit 11) of the MII Control Register (reg 0x0). Instead, software is required to put the phy into standby power down mode through the shadow register set. This patch implements support for the AC131 standby power down mode. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02tg3: Improve 5785 PCIe performanceMatt Carlson
This patch improves 5785 performance by allowing the write DMA engine to request larger DMA burst sizes than it otherwise would. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02tg3: Add more PCI DMA map error checkingMatt Carlson
This patch adds code to check the status of pci_map_single() before allowing rx buffers to be used. It also converts the pci_map_single() call in tg3_run_loopback() to use skb_dma_map() instead. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02tg3: Prevent a PCIe tx glitchMatt Carlson
This patch prevents a PCIe tx glitch by allowing the transmitter to go to a low power state. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02tg3: Convert PHY_ADDR => TG3_PHY_MII_ADDRMatt Carlson
This patch renames the PHY_ADDR preprocessor definition. The following patch will identify a new member on the MDIO bus, so we want this preprocessor definition to be a little more descriptive. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02tg3: Fix disappearing 57780 devicesMatt Carlson
Under certain power saving conditions, 57780 asic rev devices might disappear from the system. The fix is to disallow the PCIe PLL from powering down. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02tg3: Fix 5906 transmit hangsMatt Carlson
The 5906 has trouble with fragments that are less than 8 bytes in size. This patch works around the problem by pivoting the 5906's transmit routine to tg3_start_xmit_dma_bug() and introducing a new SHORT_DMA_BUG flag that enables code to detect and react to the problematic condition. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02tg3: Assign flags to fixes in start_xmit_dma_bugMatt Carlson
This patch adds a flag for each bug workaround in tg3_start_xmit_dma_bug(). This is prep work for the following patch. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Reviewed-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02qlge: Change naming on vlan API.Ron Mercer
Change name on vlan_rx_add, kill, register to match other driver API. Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02qlge: Add ethtool self-test.Ron Mercer
2009-11-01pppoe: RCU locking in get_item_by_addr()Eric Dumazet
Use dev_get_by_name_rcu() instead of dev_get_by_name(), to avoid touching device refcount in hotpath. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-01ifb: RCU locking avoids touching dev refcountEric Dumazet
Avoids touching dev refcount in hotpath Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-01NET:KS8695: add API for get rx interrupt bitFigo.zhang
1. Add API Add k8695_get_rx_enable_bit() for get Rx interrupt enable/status bit. 2. add some comment or document about some functions and variables. 3. update driver version to "1.02" 4. add napi_enable() and napi_disable() in open/close file method. Signed-off-by: Figo.zhang <figo1802@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-30bond: Get the rtnl_link_ops support correctEric W. Biederman
- Don't call rtnl_link_unregister if rtnl_link_register fails - Set .priv_size so we aren't stomping on uninitialized memory when we use netdev_priv, on bond devices created with ip link add type bond. Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-30bond: Add support for multiple network namespacesEric W. Biederman
2009-10-30bond: Implement a basic set of rtnl link opsEric W. Biederman
This implements a basic set of rtnl link ops and takes advantage of the fact that rtnl_link_unregister kills all of the surviving devices to all us to kill bond_free_all. A module alias is added so ip link add can pull in the bonding module. Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-30bond: Simplify bond device destructionEric W. Biederman
Manually inline the code from bond_deinit to bond_uninit. bond_uninit is the only caller and it is short. Move the call of bond_release_all from the netdev notifier into bond_uninit. The call site is effectively the same and performing the call explicitly allows all the paths for destroying a bonding device to behave the same way. Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-30bond: Simplify bond_create.Eric W. Biederman
Stop calling dev_get_by_name to see if the bond device already exists. register_netdevice already does that. Stop calling bond_deinit if register_netdevice fails as bond_uninit is guaranteed to be called if bond_init succeeds. Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-30bond: Simply bond sysfs group creationEric W. Biederman
This patch delegates the work of creating the sysfs groups to the netdev layer and ultimately to the device layer. This closes races between uevents. Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-30veth: Fix veth_dellink methodEric Dumazet
In commit 23289a37e2b127dfc4de1313fba15bb4c9f0cd5b (net: add a list_head parameter to dellink() method), I forgot to actually use this parameter in veth_dellink. I remember feeling a bit uncomfortable about veth_close(), because it does : netif_carrier_off(dev); netif_carrier_off(priv->peer); Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29convert kaweth to use usb_reset_configuration()Oliver Neukum
For USB 3.0 it is necessary that all drivers use the standard API to reset a configuration. This removes a home-grown implementation. Signed-off-by: Oliver Neukum <oliver@neukum.org> Hi David, please take this for the next merge window. Regards Oliver Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29sky2: version 1.26Stephen Hemminger
Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29sky2: 88E8059 supportStephen Hemminger
Tentative support for newer Marvell hardware including the Yukon-2 Optima chip. Do not have hatdware to test this yet, code is based on vendor driver. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29sky2: workarounds for Yukon-2 supremeStephen Hemminger
Changes related to support of Yukon supreme chip. Don't have this chip version to test on, these are reverse engineered from the vendor (GPL) driver. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29sky2: fix receive pause thresholdsStephen Hemminger
Program the receive pause thresholds differently depending on chip version. This cloned from from the vendor (GPL) driver. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29sky2: add register definitions for new chipsStephen Hemminger
This adds infrastructure for the newer chip versions and workarounds. Extracted from the vendor (GPL) driver. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29sky2: add SK-9E21M device idStephen Hemminger
This is a new ID that just showed up in latest vendor driver. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29sfc: Enable heuristic selection between page and skb RX buffersBen Hutchings
Now that we can tell whether GRO is being applied, this heuristic is effective once more. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29sfc: Feed GRO result into RX allocation policy and interrupt moderationBen Hutchings
When GRO is successfully merging received packets, we should allocate raw page buffers rather than skbs that will be discarded by GRO. Otherwise, we should allocate skbs. GRO also benefits from higher interrupt moderation, so increase the score for mergeable RX packets. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
2009-10-29atm: Cleanup redundant tests on unsignedroel kluin
The variables are unsigned so the `< 0' test always fails, the other part of the test catches wrapped values. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29gigaset: convert strcmp chain to table lookupTilman Schmidt
Replace the sequence of strcmp calls for interpreting ZSAU parameter strings by a table of known strings and lookup loop to improve readability. Impact: readability improvement, no functional change Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29gigaset: checkpatch cleanup of ev-layer.cTilman Schmidt
On more step towards the holy grail of checkpatch.pl silence. Impact: cosmetic Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29bas_gigaset: checkpatch cleanupTilman Schmidt
On the quest for the holy grail of checkpatch.pl silence. Impact: cosmetic Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29ser_gigaset: checkpatch cleanupTilman Schmidt
Duly uglified as demanded by checkpatch.pl. Impact: cosmetic Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29gigaset: checkpatch cleanupTilman Schmidt
Dum sanctis checkpatch.pl'ae legibus obsequimur. Impact: cosmetic Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29usb_gigaset: code cleanupTilman Schmidt
Reorganize the code of the Gigaset M10x driver to make it more readable, less redundant, better aligned to the style of other parts of the driver, and cause fewer checkpatch.pl complaints. Impact: code reorganization, no functional change Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29gigaset: fix bad assumptions about CAPI skbuffsTilman Schmidt
The CAPI interface incorrectly assumed that CAPI messages would always start at the beginning of the data buffer: fix by treating DATA_B3 messages as the link layer header to their payload data. This fix changes the way acknowledgement information is propagated through the hardware specific modules and thereby impacts the ISDN4Linux variant of the driver, too. Also some assumptions about methods not being called from interrupt context turned out to be unwarranted; fix by using dev_kfree_skb_any() wherever non-interrupt context isn't guaranteed. Impact: bugfix Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29gigaset: fix format string typo in CAPI dial commandTilman Schmidt
A missing dot lead to garbage characters being included in the dial command generated from a CAPI CONNECT_REQ message, which interestingly enough worked anyway, illustrating the resilience of the device. Impact: bugfix Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: David S. Miller <davem@davemloft.net>
