viafb: replace inb/outb
This patch replaces occurences of inb/outb with via_write_reg and
via_write_reg_mask where this is possible to improve code
readability.
Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
viafb: move some modesetting functions to a seperate file
This patch moves the modesetting functions which are already cleaned up
to a seperate file.
Just the beginning to bring some structure in this mess.
viafb: unify modesetting functions
This patch unifies some cleaned up modesetting functions to prepare for
moving them to an extra file. This includes make them use via_io and
changing there names to reflect that they do not depend on anything
framebuffer specific.
The camera engine captures to framebuffer memory, so we need to set some
aside for that purpose. There is no proper memory allocator for fbmem;
instead, accel.c just trims some space off the top. Alas, without creating
that proper memory allocator, the only way to make this work is to hack it
into the same bit of code in accel.c. The allocation must happen *after*
the others (some code, including user-space XV stuff, makes assumptions on
where the cursor space is), and before the rest of the framebuffer is set
up.
Cc: ScottFang@viatech.com.cn
Cc: JosephChan@via.com.tw
Cc: Harald Welte <laforge@gnumonks.org>
Acked-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
This code provides a minimal amount of access to the DMA engine as
needed by the camera driver. VX855 only; it's guaranteed not to work
on other chipsets, so it won't try.
The viafb device shares a single interrupt control register among several
distinct subunits. This adds a simple layer for management of that
register.
The code was ugly and didn't check whether i2c operations were succeeding;
make it a little better.
The camera driver will need this to look up a specific adapter.
If an adapter has been configured for GPIO (or off), we should not try to
use it as an I2C port.
Another step toward making this thing a real multifunction device driver.
Also add low-level locking to the i2c driver.
This patch puts redesigned versions of the basic io functions that
are used overall the driver in an extra header. It is prefixed with
via_ as no framebuffer dependend stuff is in there. They were inlined
as they are really simple which reduced the module size about 2.5%.
The parameter order of read and write was fixed as it really doesn't
make sense to change the order as they are parts of the same address
and not source and destination.
Wrapper which use the new functions were added to hw.h to replicate
the old interface and avoid changing all old code.
[jc: added one comment]
This is a simple gpiolib driver giving access to the GPIO lines in the
VIA framebuffer system. A simple mechanism exists for switching lines
between GPIO and I2C, but it's only compile-time for now.
This patch moves data of interest into a new viafb_dev structure which
describes the device as a whole; the idea here is to create a separation
between what all devices may need and what the framebuffer device in
particular needs.
I've also made some small steps toward thinning out the global.h mess.
The first step toward turning viafb into a multifunction driver. This
patch creates a new via-core.c file which serves as the main PCI driver;
everything else comes below that. Some work has been done to rationalize
the i2c drivers in this new scheme.
...otherwise it seems we run into conflicts with shadowy other users which
don't expect to see i2c taking control of ports it never used to do
anything with.
Reported-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
[jc: no signoff, added my own]
Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
This patch changes the way how the various I2C busses are used internally
inside the viafb driver: Previosuly, only a single i2c_adapter was created,
even though two different hardware I2C busses are accessed: A structure member
in a global variable was modified to indicate the bus to be used.
Now, all existing hardware busses are registered with the i2c core, and the
viafb_i2c_{read,write}byte[s]() function take the adapter number as function
call parameter, rather than referring to the global structure member.
[jc: even more painful merge with mainline changes ->2.6.34]
[jc: painful merge with OLPC changes]
Signed-off-by: Harald Welte <HaraldWelte@viatech.com>
[jc: extensive merge conflict fixes]
Signed-off-by: Chris Ball <cjb@laptop.org>
This patch is a painful merge of change
a90bab567ece3e915d0ccd55ab00c9bb333fa8c0 (viafb: Add support for 2D
accelerated framebuffer on VX800/VX855) in the OLPC tree, originally by
Harald Welte. Harald's changelog read:
The VX800/VX820 and the VX855/VX875 chipsets have a different 2D
acceleration engine called "M1". The M1 engine has some subtle
(and some not-so-subtle) differences to the previous engines, so
support for accelerated framebuffer on those chipsets was disabled
so far.
This merge tries to preserve Harald's changes in the framework of the
much-changed 2.6.34 viafb code.
This will help us for the upcoming support for 2D acceleration using
the M1 engine.
[jc: fixed merge conflicts]
As suggested by Florian: make both mode-setting paths use the same code.
Commit c3e25673843153ea75fda79a47cf12f10a25ca37 (viafb: 2D engine rewrite)
changed the setting of the GEMODE register so that the reserved bits are no
longer preserved. Fix that; at the same time, move this code to its own
function and restore the use of symbolic constants.
This was part of Harald's "make viafb a first-class citizen using
pci_driver" patch, but somehow got dropped when that patch went into
mainline.
This patch alters viafb to use the proper Linux in-kernel API to access
PCI configuration space, rather than poking at I/O ports by itself.
The current code executed from module_init() in viafb does not have
proper error checking and [partial] resoure release paths in case
an error happens half way through driver initialization.
This patch adresses the most obvious of those issues, such as a
leftover i2c bus if module_init (and thus module load) fails.
[jc: also restored -ENOMEM return on ioremap() fail]
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging
* 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging:
hwmon: (asc7621) Add X58 entry in Kconfig
hwmon: (w83793) Saving negative errors in unsigned
hwmon: (coretemp) Add missing newline to dev_warn() message
hwmon: (coretemp) Fix cpu model output
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev
* 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev:
pata_via: fix VT6410/6415/6330 detection issue
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (33 commits)
r8169: offical fix for CVE-2009-4537 (overlength frame DMAs)
ipv6: Don't drop cache route entry unless timer actually expired.
tulip: Add missing parens.
r8169: fix broken register writes
pcnet_cs: add new id
bonding: fix broken multicast with round-robin mode
drivers/net: Fix continuation lines
e1000: do not modify tx_queue_len on link speed change
net: ipmr/ip6mr: prevent out-of-bounds vif_table access
ixgbe: Do not run all Diagnostic offline tests when VFs are active
igb: use correct bits to identify if managability is enabled
benet: Fix compile warnnings in drivers/net/benet/be_ethtool.c
net: Add MSG_WAITFORONE flag to recvmmsg
e1000e: do not modify tx_queue_len on link speed change
igbvf: do not modify tx_queue_len on link speed change
ipv4: Restart rt_intern_hash after emergency rebuild (v2)
ipv4: Cleanup struct net dereference in rt_intern_hash
net: fix netlink address dumping in IPv4/IPv6
tulip: Fix null dereference in uli526x_rx_packet()
gianfar: fix undo of reserve()
Official patch to fix the r8169 frame length check error.
Based on this initial thread:
http://marc.info/?l=linux-netdev&m=126202972828626&w=1
This is the official patch to fix the frame length problems in the r8169
driver. As noted in the previous thread, while this patch incurs a performance
hit on the driver, its possible to improve performance dynamically by updating
the mtu and rx_copybreak values at runtime to return performance to what it was
for those NICS which are unaffected by the ideosyncracy (if there are any).
Summary:
A while back Eric submitted a patch for r8169 in which the proper
allocated frame size was written to RXMaxSize to prevent the NIC from dmaing too
much data. This was done in commit fdd7b4c3302c93f6833e338903ea77245eb510b4. A
long time prior to that however, Francois posted
126fa4b9ca5d9d7cb7d46f779ad3bd3631ca387c, which expiclitly disabled the MaxSize
setting due to the fact that the hardware behaved in odd ways when overlong
frames were received on NIC's supported by this driver. This was mentioned in a
security conference recently:
http://events.ccc.de/congress/2009/Fahrplan//events/3596.en.html
It seems that if we can't enable frame size filtering, then, as Eric correctly
noticed, we can find ourselves DMA-ing too much data to a buffer, causing
corruption. As a result is seems that we are forced to allocate a frame which
is ready to handle a maximally sized receive.
This obviously has performance issues with it, so to mitigate that issue, this
patch does two things:
1) Raises the copybreak value to the frame allocation size, which should force
appropriately sized packets to get allocated on rx, rather than a full new 16k
buffer.
2) This patch only disables frame filtering initially (i.e., during the NIC
open), changing the MTU results in ring buffer allocation of a size in relation
to the new mtu (along with a warning indicating that this is dangerous).
Because of item (2), individuals who can't cope with the performance hit (or can
otherwise filter frames to prevent the bug), or who have hardware they are sure
is unaffected by this issue, can manually lower the copybreak and reset the mtu
such that performance is restored easily.
Signed-off-by: Neil Horman <nhorman@redhat.com>
Intel X58 have asc7621a chip. So added X58 entry in Kconfig for asc7621.
Also arranged existing models in ascending order.
Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
"ret" is used to store the return value for watchdog_trigger() and it
should be signed for the error handling to work.
Acked-by: Hans de Goede <hdegoede@redhat.com>
Add missing newline to dev_warn() message string. This is more of an issue
with older kernels that don't automatically add a newline if it was missing
from the end of the previous line.
Signed-off-by: Dean Nelson <dnelson@redhat.com>
Cc: stable@kernel.org
Avoid hex and decimal confusion when printing out the cpu model.
Signed-off-by: Prarit Bhargava <prarit@redhat.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/ide-2.6:
Revert "ide: skip probe if there are no devices on the port (v2)"
Revert "via82cxxx: workaround h/w bugs"
FC disable is bit 3 of the txmac ctl register, but commit 6720949d5562
("Staging: et131x: Kil the txmac type") accidentally changed the code to
set bit 2 instead.
Signed-off-by: Nick Bowler <nbowler@draconx.ca>
This reverts commit a20b2a44eca52818ef52a94959480b7e6ea2f528.
As requested by David Fries. This makes CDROMs which are slave drives
on a ribbon without a master disappear and causes other similar kinds
of badness.
As reported by Stephen Rothwell.
drivers/net/tulip/uli526x.c: In function 'uli526x_rx_packet':
drivers/net/tulip/uli526x.c:861: warning: assignment makes pointer from integer without a cast
When using VT6410/6415/6330 chips on some VIA's platforms, the HDD
connection to VT6410/6415/6330 cannot be detected.
It is because the driver detects wrong via_isa_bridge ID, and then
causes this issue to happen.
Signed-off-by: Joseph Chan <josephchan@via.com.tw>
This is quite similar to b39fe41f481d20c201012e4483e76c203802dda7
though said registers are not even documented as 64-bit registers
- as opposed to the initial TxDescStartAddress ones - but as single
bytes which must be combined into 32 bits at the MMIO read/write
level before being merged into a 64 bit logical entity.
Credits go to Ben Hutchings <ben@decadent.org.uk> for the MAR
registers (aka "multicast is broken for ages on ARM) and to
Timo Teräs <timo.teras@iki.fi> for the MAC registers.
Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
pcnet_cs:
*add new id (Allied Telesis LM33-PCM-T Lan&Modem multifunction card)
*use PROD_ID for LA-PCM.(because LA-PCM and LM33-PCM-T use the same MANF_ID).
Signed-off-by: Ken Kawasaki <ken_kawasaki@spring.nifty.jp>
Round-robin (mode 0) does nothing to ensure that any multicast traffic
originally destined for the host will continue to arrive at the host when
the link that sent the IGMP join or membership report goes down. One of
the benefits of absolute round-robin transmit.
Keeping track of subscribed multicast groups for each slave did not seem
like a good use of resources, so I decided to simply send on the
curr_active slave of the bond (typically the first enslaved device that
is up). This makes failover management simple as IGMP membership
reports only need to be sent when the curr_active_slave changes. I
tested this patch and it appears to work as expected.
Originally reported by Lon Hohberger <lhh@redhat.com>.
Signed-off-by: Andy Gospodarek <andy@greyhouse.net>
CC: Lon Hohberger <lhh@redhat.com>
CC: Jay Vosburgh <fubar@us.ibm.com>
Signed-off-by: Jay Vosburgh <fubar@us.ibm.com>
Previously the driver tweaked txqueuelen to avoid false Tx hang reports
seen at half duplex. This had the effect of overriding user set values
on link change/reset. Testing shows that adjusting only the timeout
factor is sufficient to prevent Tx hang reports at half duplex.
This patch removes all instances of tx_queue_len in the driver.
Based on e1000e patch by Franco Fichtner <franco@lastsummer.de>
CC: Franco Fichtner <franco@lastsummer.de>
Signed-off-by: Emil Tantilov <emil.s.tantilov@intel.com>
Acked-by: Jesse Brandeburg <jesse.brandeburg@intel.com>
When running the offline diagnostic tests check to see if any VFs are
online. If so then only run the link test. This is necessary because
the VFs running in guest VMs aren't aware of when the PF is taken
offline for a diagnostic test. Also put a message to the system log
telling the system administrator to take the VFs offline manually if
(s)he wants to run a full diagnostic. Return 1 on each of the tests
not run to alert the user of the condition.
Signed-off-by: Greg Rose <gregory.v.rose@intel.com>
igb was previously checking the wrong bits in the MANC register to determine
if managability was enabled. As a result it was incorrectly powering down and
resetting the phy when it didn't need to.
Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com>
Fix the following warnings:
be_ethtool.c:493: warning: integer constant is too large for 'long' type
Signed-off-by: Zhitong Wang <zhitong.wangzt@alibaba-inc.com>
Acked-by: Ajit Khaparde <ajitk@serverengines.com>
This reverts commit f931a5d5785d7b7c44871bd7ad2762e29dfddf29.
It causes regressions for some users.
Previously the driver tweaked txqueuelen to avoid false Tx hang reports seen at half duplex.
This had the effect of overriding user set values on link change/reset. Testing shows that
adjusting only the timeout factor is sufficient to prevent Tx hang reports at half duplex.
Originally reported and patched by Franco Fichtner
