path: root/drivers
2011-03-18Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: PCI: label: remove #include of ACPI header to avoid warnings PCI: label: Fix compilation error when CONFIG_ACPI is unset PCI: pre-allocate additional resources to devices only after successful allocation of essential resources. PCI: introduce reset_resource() PCI: data structure agnostic free list function PCI: refactor io size calculation code PCI: do not create quirk I/O regions below PCIBIOS_MIN_IO for ICH PCI hotplug: acpiphp: set current_state to D0 in register_slot PCI: Export ACPI _DSM provided firmware instance number and string name to sysfs PCI: add more checking to ICH region quirks PCI: aer-inject: Override PCIe AER Mask Registers PCI: fix tlan build when CONFIG_PCI is not enabled PCI: remove quirk for pre-production systems PCI: Avoid potential NULL pointer dereference in pci_scan_bridge PCI/lpc: irq and pci_ids patch for Intel DH89xxCC DeviceIDs PCI: sysfs: Fix failure path for addition of "vpd" attribute
2011-03-18Merge branch 'spi/next' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'spi/next' of git://git.secretlab.ca/git/linux-2.6: (34 commits) spi/dw_spi: move dw_spi.h into drivers/spi spi/dw_spi: Fix missing header gpio/langwell: Clear edge bit before handling gpio/langwell: Simplify demux loop gpio/langwell: Convert irq name space gpio/langwell: Fix broken irq_eoi change. gpio; Make Intel chipset gpio drivers depend on x86 gpio/cs5535-gpio: Fix section mismatch spi/rtc-{ds1390,ds3234,m41t94}: Use spi_get_drvdata() for SPI devices spi/davinci: Support DMA transfers larger than 65535 words spi/davinci: Use correct length parameter to dma_map_single calls gpio: Use __devexit at necessary places gpio: add MODULE_DEVICE_TABLE to pch_gpio and ml_ioh_gpio gpio/mcp23s08: support mcp23s17 variant of_mmc_spi: add card detect irq support spi/omap_mcspi: catch xfers of non-multiple SPI word size spi/omap_mcspi: Off-by-one error in finding the right divisor gpio/pca953x: Fix wrong pointer type spi/pl022: rid dangling labels spi: add support for SuperH SPI ...
2011-03-18Merge branch 'linux-next' of git://git.infradead.org/ubifs-2.6Linus Torvalds
* 'linux-next' of git://git.infradead.org/ubifs-2.6: (25 commits) UBIFS: clean-up commentaries UBIFS: save 128KiB or more RAM UBIFS: allocate orphans scan buffer on demand UBIFS: allocate lpt dump buffer on demand UBIFS: allocate ltab checking buffer on demand UBIFS: allocate scanning buffer on demand UBIFS: allocate dump buffer on demand UBIFS: do not check data crc by default UBIFS: simplify UBIFS Kconfig menu UBIFS: print max. index node size UBIFS: handle allocation failures in UBIFS write path UBIFS: use max_write_size during recovery UBIFS: use max_write_size for write-buffers UBIFS: introduce write-buffer size field UBI: incorporate LEB offset information UBIFS: incorporate maximum write size UBI: provide LEB offset information UBI: incorporate maximum write size UBIFS: fix LEB number in printk UBIFS: restrict world-writable debugfs files ...
2011-03-18Merge branch 'linux-next' of git://git.infradead.org/ubi-2.6Linus Torvalds
* 'linux-next' of git://git.infradead.org/ubi-2.6: UBI: make tests modes dynamic UBI: make self-checks dynamic UBI: make debugging messages dynamic UBI: remove UBI_IO_DEBUG macro UBI: kill debugging buffer UBI: allocate erase checking buffer on demand UBI: allocate write checking buffer on demand UBI: always re-read in case of read failures UBI: cleanup comments about corrupted PEBs UBI: add slab cache for ubi_scan_leb objects UBI: use raw mtd read function in debugging code UBI: try to reveal buggy MTD drivers UBI: add a commentary about allocating VID header buffer on stack UBI: cleanup LEB start calculations UBI: fix NOR erase preparation quirk
2011-03-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (308 commits) ALSA: sound/pci/asihpi: check adapter index in hpi_ioctl ALSA: aloop - Fix possible IRQ lock inversion ALSA: sound/core: merge list_del()/list_add_tail() to list_move_tail() ALSA: ctxfi - use list_move() instead of list_del()/list_add() combination ALSA: firewire - msleep needs delay.h ALSA: firewire-lib, firewire-speakers: handle packet queueing errors ALSA: firewire-lib: allocate DMA buffer separately ALSA: firewire-lib: use no-info SYT for packets without SYT sample ALSA: add LaCie FireWire Speakers/Griffin FireWave Surround driver ALSA: hda - Remove an unused variable in patch_realtek.c ALSA: hda - pin-adc-mux-dmic auto-configuration of 92HD8X codecs ALSA: hda - fix digital mic selection in mixer on 92HD8X codecs ALSA: hda - Move default input-src selection to init part ALSA: hda - Initialize special cases for input src in init phase ALSA: ctxfi - Clear input settings before initialization ALSA: ctxfi - Fix SPDIF status retrieval ALSA: ctxfi - Fix incorrect SPDIF status bit mask ALSA: ctxfi - Fix microphone boost codes/comments ALSA: atiixp - Fix wrong time-out checks during ac-link reset ALSA: intel8x0m: append 'm' to "r_intel8x0" ...
2011-03-18Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (30 commits) trace, filters: Initialize the match variable in process_ops() properly trace, documentation: Fix branch profiling location in debugfs oprofile, s390: Cleanups oprofile, s390: Remove hwsampler_files.c and merge it into init.c perf: Fix tear-down of inherited group events perf: Reorder & optimize perf_event_context to remove alignment padding on 64 bit builds perf: Handle stopped state with tracepoints perf: Fix the software events state check perf, powerpc: Handle events that raise an exception without overflowing perf, x86: Use INTEL_*_CONSTRAINT() for all PEBS event constraints perf, x86: Clean up SandyBridge PEBS events perf lock: Fix sorting by wait_min perf tools: Version incorrect with some versions of grep perf evlist: New command to list the names of events present in a perf.data file perf script: Add support for H/W and S/W events perf script: Add support for dumping symbols perf script: Support custom field selection for output perf script: Move printing of 'common' data from print_event and rename perf tracing: Remove print_graph_cpu and print_graph_proc from trace-event-parse perf script: Change process_event prototype ...
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (47 commits) doc: CONFIG_UNEVICTABLE_LRU doesn't exist anymore Update cpuset info & webiste for cgroups dcdbas: force SMI to happen when expected arch/arm/Kconfig: remove one to many l's in the word. asm-generic/user.h: Fix spelling in comment drm: fix printk typo 'sracth' Remove one to many n's in a word Documentation/filesystems/romfs.txt: fixing link to genromfs drivers:scsi Change printk typo initate -> initiate serial, pch uart: Remove duplicate inclusion of linux/pci.h header fs/eventpoll.c: fix spelling mm: Fix out-of-date comments which refers non-existent functions drm: Fix printk typo 'failled' coh901318.c: Change initate to initiate. mbox-db5500.c Change initate to initiate. edac: correct i82975x error-info reported edac: correct i82975x mci initialisation edac: correct commented info fs: update comments to point correct document target: remove duplicate include of target/target_core_device.h from drivers/target/target_core_hba.c ... Trivial conflict in fs/eventpoll.c (spelling vs addition)
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (48 commits) HID: add support for Logitech Driving Force Pro wheel HID: hid-ortek: remove spurious reference HID: add support for Ortek PKB-1700 HID: roccat-koneplus: vorrect mode of sysfs attr 'sensor' HID: hid-ntrig: init settle and mode check HID: merge hid-egalax into hid-multitouch HID: hid-multitouch: Send events per slot if CONTACTCOUNT is missing HID: ntrig remove if and drop an indent HID: ACRUX - activate the device immediately after binding HID: ntrig: apply NO_INIT_REPORTS quirk HID: hid-magicmouse: Correct touch orientation direction HID: ntrig don't dereference unclaimed hidinput HID: Do not create input devices for feature reports HID: bt hidp: send Output reports using SET_REPORT on the Control channel HID: hid-sony.c: Fix sending Output reports to the Sixaxis HID: add support for Keytouch IEC 60945 HID: Add HID Report Descriptor to sysfs HID: add IRTOUCH infrared USB to hid_have_special_driver HID: kernel oops in out_cleanup in function hidinput_connect HID: Add teletext/color keys - gyration remote - EU version (GYAR3101CKDE) ...
2011-03-18spi/dw_spi: move dw_spi.h into drivers/spiGrant Likely
include/linux/dw_spi.h only includes driver internal data. It doesn't expose a platform_data configuration structure or similar (at least nothing in-tree). This patch moves the header into drivers/spi so that the scope is limited to only the dw_spi_*.c driver files Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: Feng Tang <feng.tang@intel.com> Cc: spi-devel-general@lists.sourceforge.net
2011-03-18Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (62 commits) powerpc/85xx: Fix signedness bug in cache-sram powerpc/fsl: 85xx: document cache sram bindings powerpc/fsl: define binding for fsl mpic interrupt controllers powerpc/fsl_msi: Handle msi-available-ranges better drivers/serial/ucc_uart.c: Add of_node_put to avoid memory leak powerpc/85xx: Fix SPE float to integer conversion failure powerpc/85xx: Update sata controller compatible for p1022ds board ATA: Add FSL sata v2 controller support powerpc/mpc8xxx_gpio: simplify searching for 'fsl, qoriq-gpio' compatiable powerpc/8xx: remove obsolete mgsuvd board powerpc/82xx: rename and update mgcoge board support powerpc/83xx: rename and update kmeter1 powerpc/85xx: Workaroudn e500 CPU erratum A005 powerpc/fsl_pci: Add support for FSL PCIe controllers v2.x powerpc/85xx: Fix writing to spin table 'cpu-release-addr' on ppc64e powerpc/pseries: Disable MSI using new interface if possible powerpc: Enable GENERIC_HARDIRQS_NO_DEPRECATED. powerpc: core irq_data conversion. powerpc: sysdev/xilinx_intc irq_data conversion. powerpc: sysdev/uic irq_data conversion. ... Fix up conflicts in arch/powerpc/sysdev/fsl_msi.c (due to getting rid of of_platform_driver in arch/powerpc)
2011-03-17gpio/langwell: Clear edge bit before handlingThomas Gleixner
I don't have the specs for this beast, but it looks a lot like the PXA GPIO block. Though I bet it's the same IP and the driver should have reused the PXA code. Acknowleding the edge detect status after handling one or more gpio interrupts looks wrong. We might lose an edge which came in while we handled the previous one. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Alek Du <alek.du@intel.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-03-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tileLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: (27 commits) arch/tile: support newer binutils assembler shift semantics arch/tile: fix deadlock bugs in rwlock implementation drivers/edac: provide support for tile architecture tile on-chip network driver: sync up with latest fixes arch/tile: support 4KB page size as well as 64KB arch/tile: add some more VMSPLIT options and use consistent naming arch/tile: fix some comments and whitespace arch/tile: export some additional module symbols arch/tile: enhance existing finv_buffer_remote() routine arch/tile: fix two bugs in the backtracer code arch/tile: use extended assembly to inline __mb_incoherent() arch/tile: use a cleaner technique to enable interrupt for cpu_idle() arch/tile: sync up with <arch/sim.h> and <arch/sim_def.h> changes arch/tile: fix reversed test of strict_strtol() return value arch/tile: avoid a simulator warning during bootup arch/tile: export <asm/hardwall.h> to userspace arch/tile: warn and retry if an IPI is not accepted by the target cpu arch/tile: stop disabling INTCTRL_1 interrupts during hypervisor downcalls arch/tile: fix __ndelay etc to work better arch/tile: bug fix: exec'ed task thought it was still single-stepping ... Fix up trivial conflict in arch/tile/kernel/vmlinux.lds.S (percpu alignment vs section naming convention fix)
2011-03-17Merge branch 'omap-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (258 commits) omap: zoom: host should not pull up wl1271's irq line arm: plat-omap: iommu: fix request_mem_region() error path OMAP2+: Common CPU DIE ID reading code reads wrong registers for OMAP4430 omap4: mux: Remove duplicate mux modes omap: iovmm: don't check 'da' to set IOVMF_DA_FIXED flag omap: iovmm: disallow mapping NULL address when IOVMF_DA_ANON is set omap2+: mux: Fix compile when CONFIG_OMAP_MUX is not selected omap4: board-omap4panda: Initialise the serial pads omap3: board-3430sdp: Initialise the serial pads omap4: board-4430sdp: Initialise the serial pads omap2+: mux: Add macro for configuring static with omap_hwmod_mux_init omap2+: mux: Remove the use of IDLE flag omap2+: Add separate list for dynamic pads to mux perf: add OMAP support for the new power events OMAP4: Add IVA OPP enteries. OMAP4: Update Voltage Rail Values for MPU, IVA and CORE OMAP4: Enable 800 MHz and 1 GHz MPU-OPP OMAP3+: OPP: Replace voltage values with Macros OMAP3: wdtimer: Fix CORE idle transition Watchdog: omap_wdt: add fine grain runtime-pm ... Fix up various conflicts in - arch/arm/mach-omap2/board-omap3evm.c - arch/arm/mach-omap2/clock3xxx_data.c - arch/arm/mach-omap2/usb-musb.c - arch/arm/plat-omap/include/plat/usb.h - drivers/usb/musb/musb_core.h
2011-03-17Merge branch 'for-linus' of git://codeaurora.org/quic/kernel/davidb/linux-msmLinus Torvalds
* 'for-linus' of git://codeaurora.org/quic/kernel/davidb/linux-msm: (46 commits) msm: scm: Check for interruption immediately msm: scm: Fix improper register assignment msm: scm: Mark inline asm as volatile msm: iommu: Enable HTW L2 redirection on MSM8960 msm: iommu: Don't read from write-only registers msm: iommu: Remove dependency on IDR msm: iommu: Use ASID tagging instead of VMID tagging msm: iommu: Rework clock logic and add IOMMU bus clock control msm: iommu: Clock control for the IOMMU driver msm: mdp: Set the correct pack pattern for XRGB/ARGB msm_fb: Fix framebuffer console msm: mdp: Add support for RGBX 8888 image format. video: msmfb: Put the partial update magic value into the fix_screen struct. msm: clock: Migrate to clkdev msm: clock: Remove references to clk_ops_pcom msm: headsmp.S: Fix section mismatch msm: Use explicit GPLv2 licenses msm: iommu: Enable IOMMU support for MSM8960 msm: iommu: Generalize platform data for multiple targets msm: iommu: Create a Kconfig item for the IOMMU driver ...
2011-03-17Merge branch 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel-stable' of master.kernel.org:/home/rmk/linux-2.6-arm: (289 commits) davinci: DM644x EVM: register MUSB device earlier davinci: add spi devices on tnetv107x evm davinci: add ssp config for tnetv107x evm board davinci: add tnetv107x ssp platform device spi: add ti-ssp spi master driver mfd: add driver for sequencer serial port ARM: EXYNOS4: Implement Clock gating for System MMU ARM: EXYNOS4: Enhancement of System MMU driver ARM: EXYNOS4: Add support for gpio interrupts ARM: S5P: Add function to register gpio interrupt bank data ARM: S5P: Cleanup S5P gpio interrupt code ARM: EXYNOS4: Add missing GPYx banks ARM: S3C64XX: Fix section mismatch from cpufreq init ARM: EXYNOS4: Add keypad device to the SMDKV310 ARM: EXYNOS4: Update clocks for keypad ARM: EXYNOS4: Update keypad base address ARM: EXYNOS4: Add keypad device helpers ARM: EXYNOS4: Add support for SATA on ARMLEX4210 plat-nomadik: make GPIO interrupts work with cpuidle ApSleep mach-u300: define a dummy filter function for coh901318 ... Fix up various conflicts in - arch/arm/mach-exynos4/cpufreq.c - arch/arm/mach-mxs/gpio.c - drivers/net/Kconfig - drivers/tty/serial/Kconfig - drivers/tty/serial/Makefile - drivers/usb/gadget/fsl_mxc_udc.c - drivers/video/Kconfig
2011-03-17Merge branches 'defcfg', 'drivers' and 'cyberpro-next' of ↵Linus Torvalds
master.kernel.org:/home/rmk/linux-2.6-arm * 'defcfg' of master.kernel.org:/home/rmk/linux-2.6-arm: ARM: 6647/1: add Versatile Express defconfig ARM: 6644/1: mach-ux500: update the U8500 defconfig * 'drivers' of master.kernel.org:/home/rmk/linux-2.6-arm: ARM: 6764/1: pl011: factor out FIFO to TTY code ARM: 6763/1: pl011: add optional RX DMA to PL011 v2 ARM: 6758/1: amba: support pm ops ARM: amba: make amba_driver id_table const ARM: amba: make internal ID table handling const ARM: amba: make probe() functions take const id tables ARM: 6662/1: amba: make amba_bustype non-static ARM: mmci: add dmaengine-based DMA support ARM: mmci: no need for separate host->data_xfered ARM: mmci: avoid unnecessary switch to data available PIO interrupts ARM: mmci: no need to call flush_dcache_page() with sg_miter API ARM: mmci: avoid reporting too many completed bytes on fifo overrun ALSA: AACI: make fifo variables more explanitory ALSA: AACI: no need to call snd_pcm_period_elapsed() for each period ALSA: AACI: use snd_pcm_lib_period_bytes() ALSA: AACI: clean up AACI announcement printk ALSA: AACI: fix channel mask selection ALSA: AACI: fix number of channels for record ALSA: AACI: fix multiple IRQ claiming * 'cyberpro-next' of master.kernel.org:/home/rmk/linux-2.6-arm: VIDEO: cyberpro: remove unused cyber2000fb_get_fb_var() VIDEO: cyberpro: remove useless function extreg pointers VIDEO: cyberpro: update handling of device structures VIDEO: cyberpro: add support for video capture I2C VIDEO: cyberpro: make 'reg_b0_lock' always present VIDEO: cyberpro: add I2C support VIDEO: cyberpro: select lowest multipler/divisor for PLL
2011-03-17Merge branch 'kvm-updates/2.6.39' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/2.6.39' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (55 commits) KVM: unbreak userspace that does not sets tss address KVM: MMU: cleanup pte write path KVM: MMU: introduce a common function to get no-dirty-logged slot KVM: fix rcu usage in init_rmode_* functions KVM: fix kvmclock regression due to missing clock update KVM: emulator: Fix permission checking in io permission bitmap KVM: emulator: Fix io permission checking for 64bit guest KVM: SVM: Load %gs earlier if CONFIG_X86_32_LAZY_GS=n KVM: x86: Remove useless regs_page pointer from kvm_lapic KVM: improve comment on rcu use in irqfd_deassign KVM: MMU: remove unused macros KVM: MMU: cleanup page alloc and free KVM: MMU: do not record gfn in kvm_mmu_pte_write KVM: MMU: move mmu pages calculated out of mmu lock KVM: MMU: set spte accessed bit properly KVM: MMU: fix kvm_mmu_slot_remove_write_access dropping intermediate W bits KVM: Start lock documentation KVM: better readability of efer_reserved_bits KVM: Clear async page fault hash after switching to real mode KVM: VMX: Initialize vm86 TSS only once. ...
2011-03-17Merge branch 'stable/xen.pm.bug-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/xen.pm.bug-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen: use freeze/restore/thaw PM events for suspend/resume/chkpt xen: xenbus PM events support
2011-03-17Merge branches 'stable/irq.fairness' and 'stable/irq.ween_of_nr_irqs' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/irq.fairness' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen: events: Remove redundant clear of l2i at end of round-robin loop xen: events: Make round-robin scan fairer by snapshotting each l2 word once only xen: events: Clean up round-robin evtchn scan. xen: events: Make last processed event channel a per-cpu variable. xen: events: Process event channels notifications in round-robin order. * 'stable/irq.ween_of_nr_irqs' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen: events: Fix compile error if CONFIG_SMP is not defined. xen: events: correct locking in xen_irq_from_pirq xen: events: propagate irq allocation failure instead of panicking xen: events: do not workaround too-small nr_irqs xen: events: remove use of nr_irqs as upper bound on number of pirqs xen: events: dynamically allocate irq info structures xen: events: maintain a list of Xen interrupts xen: events: push setup of irq<->{evtchn,ipi,virq,pirq} maps into irq_info init functions xen: events: turn irq_info constructors into initialiser functions xen: events: use per-cpu variable for cpu_evtchn_mask xen: events: refactor GSI pirq bindings functions xen: events: rename restore_cpu_pirqs -> restore_pirqs xen: events: remove unused public functions xen: events: fix xen_map_pirq_gsi error return xen: events: simplify comment xen: events: separate two unrelated halves of if condition Fix up trivial conflicts in drivers/xen/events.c
2011-03-17Merge branches 'stable/hvc-console', 'stable/gntalloc.v6' and ↵Linus Torvalds
'stable/balloon' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/hvc-console' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen/hvc: Disable probe_irq_on/off from poking the hvc-console IRQ line. * 'stable/gntalloc.v6' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen: gntdev: fix build warning xen/p2m/m2p/gnttab: do not add failed grant maps to m2p override xen-gntdev: Add cast to pointer xen-gntdev: Fix incorrect use of zero handle xen: change xen/[gntdev/gntalloc] to default m xen-gntdev: prevent using UNMAP_NOTIFY_CLEAR_BYTE on read-only mappings xen-gntdev: Avoid double-mapping memory xen-gntdev: Avoid unmapping ranges twice xen-gntdev: Use map->vma for checking map validity xen-gntdev: Fix unmap notify on PV domains xen-gntdev: Fix memory leak when mmap fails xen/gntalloc,gntdev: Add unmap notify ioctl xen-gntalloc: Userspace grant allocation driver xen-gntdev: Support mapping in HVM domains xen-gntdev: Add reference counting to maps xen-gntdev: Use find_vma rather than iterating our vma list manually xen-gntdev: Change page limit to be global instead of per-open * 'stable/balloon' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: (24 commits) xen-gntdev: Use ballooned pages for grant mappings xen-balloon: Add interface to retrieve ballooned pages xen-balloon: Move core balloon functionality out of module xen/balloon: Remove pr_info's and don't alter retry_count xen/balloon: Protect against CPU exhaust by event/x process xen/balloon: Migration from mod_timer() to schedule_delayed_work() xen/balloon: Removal of driver_pages
2011-03-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (170 commits) [SCSI] scsi_dh_rdac: Add MD36xxf into device list [SCSI] scsi_debug: add consecutive medium errors [SCSI] libsas: fix ata list corruption issue [SCSI] hpsa: export resettable host attribute [SCSI] hpsa: move device attributes to avoid forward declarations [SCSI] scsi_debug: Logical Block Provisioning (SBC3r26) [SCSI] sd: Logical Block Provisioning update [SCSI] Include protection operation in SCSI command trace [SCSI] hpsa: fix incorrect PCI IDs and add two new ones (2nd try) [SCSI] target: Fix volume size misreporting for volumes > 2TB [SCSI] bnx2fc: Broadcom FCoE offload driver [SCSI] fcoe: fix broken fcoe interface reset [SCSI] fcoe: precedence bug in fcoe_filter_frames() [SCSI] libfcoe: Remove stale fcoe-netdev entries [SCSI] libfcoe: Move FCOE_MTU definition from fcoe.h to libfcoe.h [SCSI] libfc: introduce __fc_fill_fc_hdr that accepts fc_hdr as an argument [SCSI] fcoe, libfc: initialize EM anchors list and then update npiv EMs [SCSI] Revert "[SCSI] libfc: fix exchange being deleted when the abort itself is timed out" [SCSI] libfc: Fixing a memory leak when destroying an interface [SCSI] megaraid_sas: Version and Changelog update ... Fix up trivial conflicts due to whitespace differences in drivers/scsi/libsas/{sas_ata.c,sas_scsi_host.c}
2011-03-17Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq: [CPUFREQ] pcc-cpufreq: remove duplicate statements [CPUFREQ] Remove the pm_message_t argument from driver suspend [CPUFREQ] Remove unneeded locks [CPUFREQ] Remove old, deprecated per cpu ondemand/conservative sysfs files [CPUFREQ] Remove deprecated sysfs file sampling_rate_max [CPUFREQ] powernow-k8: The table index is not worth displaying [CPUFREQ] calculate delay after dbs_check_cpu [CPUFREQ] Add documentation for sampling_down_factor [CPUFREQ] drivers/cpufreq: Remove unnecessary semicolons
2011-03-17Merge branch 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/bp/bpLinus Torvalds
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp: (38 commits) amd64_edac: Fix decode_syndrome types amd64_edac: Fix DCT argument type amd64_edac: Fix ranges signedness amd64_edac: Drop local variable amd64_edac: Fix PCI config addressing types amd64_edac: Fix DRAM base macros amd64_edac: Fix node id signedness amd64_edac: Drop redundant declarations amd64_edac: Enable driver on F15h amd64_edac: Adjust ECC symbol size to F15h amd64_edac: Simplify scrubrate setting PCI: Rename CPU PCI id define amd64_edac: Improve DRAM address mapping amd64_edac: Sanitize ->read_dram_ctl_register amd64_edac: Adjust sys_addr to chip select conversion routine to F15h amd64_edac: Beef up early exit reporting amd64_edac: Revamp online spare handling amd64_edac: Fix channel interleave removal amd64_edac: Correct node interleaving removal amd64_edac: Add support for interleaved region swapping ... Fix up trivial conflict in include/linux/pci_ids.h due to AMD_15H_NB_MISC being renamed as AMD_15H_NB_F3 next to the new AMD_15H_NB_LINK entry.
2011-03-17Merge branch 'for-linus/2639/i2c-1' of git://git.fluff.org/bjdooks/linuxLinus Torvalds
* 'for-linus/2639/i2c-1' of git://git.fluff.org/bjdooks/linux: i2c-mpc: Add support for 64bit system i2c: add driver for Freescale i.MX28 i2c: tegra: Add i2c support
2011-03-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdogLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdog: watchdog: booke_wdt: clean up status messages watchdog: cleanup spaces before tabs watchdog: convert to DEFINE_PCI_DEVICE_TABLE watchdog: Xen watchdog driver watchdog: Intel SCU Watchdog Timer Driver for Moorestown and Medfield platforms. watchdog: jz4740_wdt - fix magic character checking watchdog: add JZ4740 watchdog driver watchdog: it87_wdt: Add support for IT8721F watchdog watchdog: hpwdt: build hpwdt as module by default with NMI_DECODING enabled watchdog: hpwdt: Fix a couple of typos
2011-03-17Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging: (44 commits) hwmon: (lineage-pem): Fix in1 voltage alarm sysfs attributes hwmon/f71882fg: Add support for f71808e hwmon/f71882fg: Add support for f71869f and f71869e hwmon/f71882fg: Add support for f71889ed hwmon/f71882fg: Break out test for auto pwm's controlled by digital readings hwmon/f71882fg: Separate temp beep sysfs attr from the other temp sysfs attr hwmon/f71882fg: Remove bogus temp2_type for certain models hwmon/f71882fg: Make number of temps configurable hwmon/f71882fg: Make creation of in sysfs attributes more generic hwmon/f71882fg: Only allow negative auto point temps if fan_neg_temp is enabled hwmon/f71882fg: Fix temp1 sensor type reporting hwmon: (w83627ehf) Display correct temperature sensor labels for systems with NCT6775F hwmon: (w83627ehf) Add fan debounce support for NCT6775F and NCT6776F hwmon: (w83627ehf) Update Kconfig for W83677HG-B, NCT6775F and NCT6776F hwmon: (w83627ehf) Store rpm instead of raw fan speed data hwmon: (w83627ehf) Use 16 bit fan count registers if supported hwmon: (w83627ehf) Add support for Nuvoton NCT6775F and NCT6776F hwmon: (w83627ehf) Permit enabling SmartFan IV mode if configured at startup hwmon: (w83627ehf) Convert register arrays to 16 bit, and convert access to pointers hwmon: (w83627ehf) Remove references to datasheets which no longer exist ...
2011-03-17gpio/langwell: Simplify demux loopThomas Gleixner
Use __ffs() to find the pending interrupt source instead of looping 32 times. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Feng Tang <feng.tang@intel.com> Cc: Alek Du <alek.du@intel.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-03-17gpio/langwell: Convert irq name spaceThomas Gleixner
Convert to the new irq function names. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Feng Tang <feng.tang@intel.com> Cc: Alek Du <alek.du@intel.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-03-17gpio/langwell: Fix broken irq_eoi change.Thomas Gleixner
commit 0766d20fd (langwell_gpio: modify EOI handling following change of kernel irq subsystem) changes - desc->chip->eoi(irq); + + if (desc->chip->irq_eoi) + desc->chip->irq_eoi(irq_get_irq_data(irq)); + else + dev_warn(pg->chip.dev, "missing EOI handler for irq %d\n", irq); With the following explanation: "Latest kernel has many changes in IRQ subsystem and its interfaces, like adding irq_eoi" for struct irq_chip, this patch will make it support both the new and old interface." This is completely bogus. #1) The changelog does not match the patch at all #2) This driver relies on the assumption that it sits behind an eoi capable interrupt line. If the implementation of the underlying chip changes from eoi to irq_eoi then this driver has to follow that change and not add a total bogosity. #3) Just mechanically changing eoi to irq_eoi without checking the background of that change is sloppy at best. Remove the sillyness and retrieve the interrupt data from irq_desc directly. No need to go through a sparse irq lookup. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Feng Tang <feng.tang@intel.com> Cc: Alek Du <alek.du@intel.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-03-17gpio; Make Intel chipset gpio drivers depend on x86Thomas Gleixner
Nothing outside of x86 can use that code. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-03-17Merge remote-tracking branch 'origin' into spi/nextGrant Likely
Pull in Linus' tree to pick up changes required for the langwell gpio fixes
2011-03-17gpio/cs5535-gpio: Fix section mismatchNikanth Karthikesan
Fix section mismatch by annotating using variable name suffix. Signed-off-by: Nikanth Karthikesan <knikanth@suse.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-03-17Merge tag 'v2.6.38' of ↵Chris Metcalf
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 into for-linus
2011-03-17Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/epip/linux-2.6-unicore32 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/epip/linux-2.6-unicore32: (40 commits) unicore32: rewrite arch-specific tlb.h to use asm-generic version unicore32: modify io_p2v and io_v2p macros, and adjust PKUNITY_mmio_BASEs unicore32: replace unicore32-specific iomap functions with generic lib implementation unicore32 machine related: add frame buffer driver for pkunity-v3 soc unicore32 machine related files: add i2c bus drivers for pkunity-v3 soc unicore32 io: redefine __REG(x) and re-use readl/writel funcs unicore32 i8042 upgrade and bugfix: adjust resource request region type unicore32 upgrade to v2.6.38-rc5: add one more paramter for pte_alloc_map call unicore32 i8042: adjust io funcs of i8042-unicore32io.h unicore32: rename PKUNITY_IOSPACE_BASE to PKUNITY_MMIO_BASE unicore32: modify function names and parameters for irq_chips unicore32: remove unused lines in arch/unicore32/include/asm/irq.h unicore32 time.c: change calculate method for clock_event_device unicore32: ADD MAINTAINER for unicore32 architecture unicore32 machine related files: ps2 driver unicore32 machine related files: pci bus handling unicore32 machine related files: hardware registers unicore32 machine related files: core files unicore32 additional architecture files: boot process unicore32 additional architecture files: low-level lib: misc ... Acked-by: Arnd Bergmann <arnd@arndb.de>
2011-03-17Merge branch 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: [S390] kexec: Disable ftrace during kexec [S390] support XZ compressed kernel [S390] css_bus_type: make it static [S390] css_driver: remove duplicate members [S390] css: remove subchannel private [S390] css: move chsc_private to drv_data [S390] css: move io_private to drv_data [S390] cio: move cdev pointer to io_subchannel_private [S390] cio: move options to io_sch_private [S390] cio: move asms to generic header [S390] cio: move orb definitions to separate header [S390] Write protect module text and RO data [S390] dasd: get rid of compile warning [S390] remove superfluous check from do_IRQ [S390] remove redundant stack check option
2011-03-17Merge branch 'sh-latest' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6 * 'sh-latest' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (34 commits) sh: Convert to generic show_interrupts. sh: Wire up new fhandle and clock_adjtime syscalls. sh: modify platform_device for sh_eth driver sh: add GETHER's platform_device in board-sh7757lcr sh: update sh7757lcr_defconfig sh: add platform_device of tmio_mmc and sh_mmcif to sh7757lcr sh: dmaengine support for SH7757 sh: add mmc clock in clock-sh7757 sh: add spi_board_info in sh7757lcr sh: add platform_device for SPI sh: add USB_ARCH_HAS_EHCI and OHCI for SH7757 sh: Rename cpuidle states to fit general conventions serial: sh-sci: fix deadlock when resuming from S3 sleep sh: Enable CONFIG_GCOV_PROFILE_ALL for sh sh: Fix up async PCIe probing on SMP. serial: sh-sci: Kill off the special earlyprintk device. serial: sh-sci: Use dev_name() for region reservations. serial: sh-sci: Fix up earlyprintk port mapping. serial: sh-sci: Limit early console to one device. serial: sh-sci: Fix up break timer scheduling race. ...
2011-03-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/lethal/fbdev-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/fbdev-2.6: fbdev: sh_mobile_lcdc: Add YUV framebuffer support viafb: split pll configs up viafb: remove duplicated clock storage viafb: always return the best possible clock viafb: remove duplicated clock information fbdev: sh_mobile_lcdcfb: add backlight support viafb: factor lcd scaling parameters out viafb: strip some structures viafb: remove unused data_mode and device_type viafb: kill lcd_panel_id video via: make local variables static video via: fix iomem access video/via: drop deprecated (and unused) i2c_adapter.id
2011-03-17spi/rtc-{ds1390,ds3234,m41t94}: Use spi_get_drvdata() for SPI devicesGeert Uytterhoeven
The recently increased type checking in platform_get_drvdata() reveals a few offenders: drivers/rtc/rtc-ds1390.c:161: warning: passing argument 1 of ‘platform_get_drvdata’ from incompatible pointer type drivers/rtc/rtc-ds3234.c:161: warning: passing argument 1 of ‘platform_get_drvdata’ from incompatible pointer type drivers/rtc/rtc-m41t94.c:139: warning: passing argument 1 of ‘platform_get_drvdata’ from incompatible pointer type Use spi_get_drvdata() instead of platform_get_drvdata(). Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-03-17Merge branch 'drm-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (177 commits) drm/radeon: fixup refcounts in radeon dumb create ioctl. drm: radeon: *_cs_packet_parse_vline() cleanup radeon: merge list_del()/list_add_tail() to list_move_tail() drm: Retry i2c transfer of EDID block after failure drm/radeon/kms: fix typo in atom overscan setup drm: Hold the mode mutex whilst probing for sysfs status drm/nouveau: fix __nouveau_fence_wait performance drm/nv40: attempt to reserve just enough vram for all 32 channels drm/nv50: check for vm traps on every gr irq drm/nv50: decode vm faults some more drm/nouveau: add nouveau_enum_find() util function drm/nouveau: properly handle pushbuffer check failures drm/nvc0: remove vm hack forcing large/small pages to not share a PDE drm/i915: disable opregion lid detection for now. drm/i915: Only wait on a pending flip if we intend to write to the buffer drm/i915/dp: Sanity check eDP existence drm: add cap bit to denote if dumb ioctl is available or not. drm/core: add ioctl to query device/driver capabilities drm/radeon/kms: allow max clock of 340 Mhz on hdmi 1.3+ drm/radeon/kms: add cayman pci ids ...
2011-03-17mm: export __get_user_pagesHuang Ying
In most cases, get_user_pages and get_user_pages_fast should be used to pin user pages in memory. But sometimes, some special flags except FOLL_GET, FOLL_WRITE and FOLL_FORCE are needed, for example in following patch, KVM needs FOLL_HWPOISON. To support these users, __get_user_pages is exported directly. There are some symbol name conflicts in infiniband driver, fixed them too. Signed-off-by: Huang Ying <ying.huang@intel.com> CC: Andrew Morton <akpm@linux-foundation.org> CC: Michel Lespinasse <walken@google.com> CC: Roland Dreier <roland@kernel.org> CC: Ralph Campbell <infinipath@qlogic.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-03-17amd64_edac: Fix decode_syndrome typesBorislav Petkov
Those should all be unsigned. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2011-03-17amd64_edac: Fix DCT argument typeBorislav Petkov
Fix amd64_debug_display_dimm_sizes() arguments order per convention (pvt is always first). Also, the now second arg denotes the DCT so adjust its type. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2011-03-17amd64_edac: Fix ranges signednessBorislav Petkov
The dram ranges make sense only as an unsigned type. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2011-03-17amd64_edac: Drop local variableBorislav Petkov
Use the macro directly instead Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2011-03-17amd64_edac: Fix PCI config addressing typesBorislav Petkov
Adjust argument types to the PCI config API's types. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2011-03-17amd64_edac: Fix DRAM base macrosBorislav Petkov
Return unsigned u8 values only. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2011-03-17amd64_edac: Fix node id signednessBorislav Petkov
A node id can never be negative since we use it as an index into the DRAM ranges array. This also makes one of the BUG_ON conditions redundant. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2011-03-17amd64_edac: Drop redundant declarationsBorislav Petkov
Those were moved to the mce_amd.h header. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2011-03-17amd64_edac: Enable driver on F15hBorislav Petkov
Add the PCI device ids required for driver registration. Remove pvt->ctl_name and use the family descriptor directly, instead. Then, bump driver version and fixup its format. Finally, enable DRAM ECC decoding on F15h. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2011-03-17amd64_edac: Adjust ECC symbol size to F15hBorislav Petkov
F15h has the same ECC symbol size options as F10h revD and later so adjust checks to that. Simplify code a bit. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
