Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
if (controller && !request_region) then we leaked a tty driver struct, fix it
by adding function deinit tail with goto-ing into it (and from other fail
paths too)
We may use pdev->revision instead of reading pci config space directly, so
remove pci_read_config_dword invoking.
- register_device unconditionally (non-pci dependent) to have also isa
devices in /dev
- unregister devices on module removal
- don't set TTY_DRIVER_DYNAMIC_DEV twice (removed the one dependent on some
macro)
Cc: Ferenc Wagner <wferi@niif.hu>
rocket, switch sleep_on to completion
- sleep_on is deprecated and racy, use completion instead
- also check retval of interruptible function and return ERESTARTSYS
eventually
interruptible_sleep_on is deprecated, use completion instead
prepend moxa_ to all moxa functions which laxes this
- use dev_* where pdev is available (probe function)
- add some printks on fail paths
- add KERN_ macros otherwise
- remove useless verbose variable
- wrap lines to 80 cols at most
CC drivers/char/cyclades.o
drivers/char/cyclades.c: In function 'cy_init':
drivers/char/cyclades.c:5488: warning: label 'err_unr' defined but not used
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
Acked-by: Jiri Slaby <jirislaby@gmail.com>
Most of them are signedness, the rest unused function parameters.
Lock whole processing in isr, avoid error-prone locking/unlocking in rx/tx
esp. On fail paths (there was a bug in the past yet).
Due to large indent the code was wrapped and unreadable. Create 3 function
instead of one and reorder the code, so it is readable now.
The work done in bottom half doesn't cost much cpu time (e.g. tty_hangup
itself schedules its own bottom half), it's possible to do the work in isr
directly and save hence some .text.
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Paul Fulghum <paulkf@microgate.com>
moxa, fix and optimise empty timer
don't wait and delete empty timer in empty timer function. Also fire next
empty timer at rounded jiffies to save power.
drivers/char/mxser.c:386: warning: 'mxser_get_PCI_conf' declared 'static' but never defined
when building without CONFIG_PCI.
[jesper.juhl@gmail.com: Fix warning: 'CheckIsMoxaMust' defined but not used]
This is years dead code and it keeps turning up in confusing ways when
grepping for stuff.
Signed-off-by: Alan Cox <alan@redhat.com>
Cc: Jiri Slaby <jirislaby@gmail.com>
mxser_new, remove useless comments in mxser_cards
It was rest from times, where info about the card was separated (name,
ports number and flags).
mxser_new, move to PCI_VDEVICE
mxser_new, upgrade to 1.10
This adds support for new (5 cards) hardware.
Instead of having a bunch of ifdefs in sysctl.c move all of the pty sysctl
logic into drivers/char/pty.c
As well as cleaning up the logic this prevents sysctl_check_table from
complaining that the root table has a NULL data pointer on something with
generic methods.
The sysctl binary paths don't look as if they even code work, .data is not
filled in, and all of the proc_handlers look at extra1 and there is not
strategy routine.
So just kill the binary paths.
In addition this patch removes the setting of extra1 on directories. It
doesn't look like the parport code ever examines it, and it's bad sysctl form.
[bunk@kernel.org: remove parport_device_num()]
Signed-off-by: Adrian Bunk <bunk@kernel.org>
The binary interface for the cdrom sysctls can't possilby work. So remove the
binary sysctls and update the test for finding out which sysctl table entry we
are dealy with to use the procname and not the ctl_name (which I am removing).
Cc: Alexey Dobriyan <adobriyan@sw.ru>
Cc: Jens Axboe <jens.axboe@oracle.com>
By previous cpu hotplug notifier change, we don't need to track topology_dev
existence for each cpu by topology_dev_map.
Cc: Gautham R Shenoy <ego@in.ibm.com>
Cc: Oleg Nesterov <oleg@tv-sign.ru>
Remove redundant DMA_..BIT_MASK definitions across two drivers. The
computation of the majority of the bitmasks is done by the compiler. The
initial split of the patch touching each a different file got removed due
to possible git bisect breakage.
Signed-off-by: Borislav Petkov <bbpetkov@yahoo.de>
Cc: Muli Ben-Yehuda <muli@il.ibm.com>
Cc: Jeff Garzik <jeff@garzik.org>
Cc: James Bottomley <James.Bottomley@steeleye.com>
Reviewed-by: Satyam Sharma <satyam@infradead.org>
The following scenario leads to total confusion of the platform firmware on
some boxes (eg. HPC nx6325):
* Hibernate with ACPI enabled
* Resume passing "acpi=off" to the boot kernel
To prevent this from happening it's necessary to check if ACPI is enabled (and
enable it if that's not the case) _right_ _after_ control has been transfered
from the boot kernel to the image kernel, before device_power_up() is called
(ie. with interrupts disabled). Enabling ACPI after calling
device_power_up() turns out to be insufficient.
For this reason, introduce new hibernation callback ->leave() that will be
executed before device_power_up() by the restored image kernel. To make it
work, it also is necessary to move swsusp_suspend() from swsusp.c to disk.c
(it's name is changed to "create_image", which is more up to the point).
Acked-by: Pavel Machek <pavel@ucw.cz>
Currently, there's a CONFIG_DISABLE_CONSOLE_SUSPEND that allows one to stop
the serial console from being suspended when the rest of the machine goes
to sleep. This is incredibly useful for debugging power management-related
things; however, having it as a compile-time option has proved to be
incredibly inconvenient for us (OLPC). There are plenty of times that we
want serial console to not suspend, but for the most part we'd like serial
console to be suspended.
This drops CONFIG_DISABLE_CONSOLE_SUSPEND, and replaces it with a kernel
boot parameter (no_console_suspend). By default, the serial console will
be suspended along with the rest of the system; by passing
'no_console_suspend' to the kernel during boot, serial console will remain
alive during suspend.
For now, this is pretty serial console specific; further fixes could be
applied to make this work for things like netconsole.
Signed-off-by: Andres Salomon <dilinger@debian.org>
Acked-by: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: Nigel Cunningham <nigel@suspend2.net>
The way in which read_magic_time() displays the date read from the RTC is
apparently confusing to the users (cf.
https://bugzilla.redhat.com/bugzilla/show_bug.cgi?id=250238). Make it
print dates in the standard way.
Acked-by: Dave Jones <davej@redhat.com>
Introduce freezer-friendly wrappers around wait_event_interruptible() and
wait_event_interruptible_timeout(), originally defined in <linux/wait.h>, to
be used in freezable kernel threads. Make some of the freezable kernel
threads use them.
This is necessary for the freezer to stop sending signals to kernel threads,
which is implemented in the next patch.
Cc: Nigel Cunningham <nigel@nigel.suspend2.net>
Rename 'struct hibernation_ops' to 'struct platform_hibernation_ops' in
analogy with 'struct platform_suspend_ops'.
Cc: Len Brown <lenb@kernel.org>
Cc: Greg KH <greg@kroah.com>
During hibernation we also need to tell the ACPI core that we're going to put
the system into the S4 sleep state. For this reason, an additional method in
'struct hibernation_ops' is needed, playing the role of set_target() in
'struct platform_suspend_operations'. Moreover, the role of the .prepare()
method is now different, so it's better to introduce another method, that in
general may be different from .prepare(), that will be used to prepare the
platform for creating the hibernation image (.prepare() is used anyway to
notify the platform that we're going to enter the low power state after the
image has been saved).
There is no reason why the .prepare() and .finish() methods in 'struct
platform_suspend_ops' should take any arguments, since architectures don't use
these methods' argument in any practically meaningful way (ie. either the
target system sleep state is conveyed to the platform by .set_target(), or
there is only one suspend state supported and it is indicated to the PM core
by .valid(), or .prepare() and .finish() aren't defined at all). There also
is no reason why .finish() should return any result.
The name of 'struct pm_ops' suggests that it is related to the power
management in general, but in fact it is only related to suspend. Moreover,
its name should indicate what this structure is used for, so it seems
reasonable to change it to 'struct platform_suspend_ops'. In that case, the
name of the global variable of this type used by the PM core and the names of
related functions should be changed accordingly.
Move the definition of 'struct pm_ops' and related functions from <linux/pm.h>
to <linux/suspend.h> .
There are, at least, the following reasons to do that:
* 'struct pm_ops' is specifically related to suspend and not to the power
management in general.
* As long as 'struct pm_ops' is defined in <linux/pm.h>, any modification of it
causes the entire kernel to be recompiled, which is unnecessary and annoying.
* Some suspend-related features are already defined in <linux/suspend.h>, so it
is logical to move the definition of 'struct pm_ops' into there.
* 'struct hibernation_ops', being the hibernation-related counterpart of
'struct pm_ops', is defined in <linux/suspend.h> .
This has not been any serious user of this ill conceived thing since the
original invention in like '95 so I recently deleted this from everywhere
except the last instance in logo.c. This patch removes the last two
instances in logo.c. They conditions were not useful anyway as when
compiled in they would always evaluate as true.
Last not least this is necessary to get the SGI IP22 and DECstation kernels
to compile again.
Cc: "Antonino A. Daplas" <adaplas@pol.net>
Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
The tty_termios_encode_baud_rate() function as defined by tty_ioctl.c has a
problem with the baud_table within. The comparison operators are reversed
and as a result this table's entries never match and BOTHER is always used.
Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org>
Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Since default_utf8 is already a sysfs attribute, having an extra
CONFIG_VT_UNICODE compile-time option is redundant, since sysfs attributes can
be set at boot and run time.
Also let Linux VCs default to UTF-8 (as per the discussion at
http://lkml.org/lkml/2007/9/6/99).
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de>
Cc: Bill Nottingham <notting@redhat.com>
The patch
- Includes the call to capilib_data_b3_req in the spinlock. This routine
in turn calls the offending mq_enqueue routine that triggered the
freeze if not locked. This should also fix other indicators of
incosistent capilib_msgidqueue list, that trigger messages like:
Oct 5 03:05:57 BERL0 kernel: kcapi: msgid 3019 ncci 0x30301 not on queue
that we saw several times a day (usually several in a row).
- Fixes all occurrences of c4_dispatch_tx to be called with active
spinlock, there were some instances where no lock was active. Mostly
these are in very infrequently called routines, so the additional
performance penalty is minimal.
Signed-off-by: Karsten Keil <kkeil@suse.de>
Signed-off-by: Rainer Brestan <rainer.brestan@frequentis.com>
Signed-off-by: Ralf Schlatterbeck <rsc@runtux.com>
Cc: <stable@kernel.org>
This fix the same issue which was debbuged for the C4 controller for the B1
versions.
The capilib_ function modify or traverse a linked list without locking.
This patch extends the existing locking to the calls of these function to
prevent access to a list which is in the middle of a modification.
C: <stable@kernel.org>
MODPOST vmlinux.o
WARNING: vmlinux.o(.text+0x170be8): Section mismatch: reference to .init.data:au1100fb_fix (between 'au1100fb_drv_probe' and 'read_null')
WARNING: vmlinux.o(.text+0x170dc4): Section mismatch: reference to .init.data:au1100fb_var (between 'au1100fb_drv_probe' and 'read_null')
WARNING: vmlinux.o(.text+0x170dd0): Section mismatch: reference to .init.data:au1100fb_fix (between 'au1100fb_drv_probe' and 'read_null')
WARNING: vmlinux.o(.text+0x170de0): Section mismatch: reference to .init.data:au1100fb_var (between 'au1100fb_drv_probe' and 'read_null')
WARNING: vmlinux.o(.text+0x170e70): Section mismatch: reference to .init.data:au1100fb_var (between 'au1100fb_drv_probe' and 'read_null')
Fix build broken by accaa24c492f1aa3b9c37226d868dc59c3007531:
CC drivers/video/console/newport_con.o
drivers/video/console/newport_con.c: In function 'newport_show_logo':
drivers/video/console/newport_con.c:111: error: assignment of read-only location
drivers/video/console/newport_con.c:111: warning: assignment makes integer from pointer without a cast
drivers/video/console/newport_con.c:112: error: assignment of read-only location
drivers/video/console/newport_con.c:112: warning: assignment makes integer from pointer without a cast
Cc: "Randy.Dunlap" <rdunlap@xenotime.net>
git://git.kernel.org/pub/scm/linux/kernel/git/drzeus/mmc
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/drzeus/mmc:
net: libertas sdio driver
mmc: at91_mci: cleanup: use MCI_ERRORS
mmc: possible leak in mmc_read_ext_csd
Add driver for Marvell's Libertas 8385 and 8686 wifi chips.
Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
Acked-by: Dan Williams <dcbw@redhat.com>
* ssh://master.kernel.org/pub/scm/linux/kernel/git/tglx/linux-2.6-x86: (114 commits)
x86: delete vsyscall files during make clean
kbuild: fix typo SRCARCH in find_sources
x86: fix kernel rebuild due to vsyscall fallout
.gitignore update for x86 arch
x86: unify include/asm/debugreg_32/64.h
x86: unify include/asm/unwind_32/64.h
x86: unify include/asm/types_32/64.h
x86: unify include/asm/tlb_32/64.h
x86: unify include/asm/siginfo_32/64.h
x86: unify include/asm/bug_32/64.h
x86: unify include/asm/mman_32/64.h
x86: unify include/asm/agp_32/64.h
x86: unify include/asm/kdebug_32/64.h
x86: unify include/asm/ioctls_32/64.h
x86: unify include/asm/floppy_32/64.h
x86: apply missing DMA/OOM prevention to floppy_32.h
x86: unify include/asm/cache_32/64.h
x86: unify include/asm/dmi_32/64.h
x86: unify include/asm/delay_32/64.h
A small MMC driver cleanup.
Use the defined AT91_MCI_ERRORS in at91_mci_completed_command() instead
of specifying all the error bits individually.
Signed-off-by: Andrew Victor <andrew@sanpeople.com>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
The exception path associated with an invalid ext_csd_struct returns
without freeing ext_csd.
Coverity CID 1909.
Signed-off-by: Florin Malita
* 'for-linus' of git://git.kernel.dk/data/git/linux-2.6-block:
[BLOCK] blk_rq_map_sg() next_sg fixup
Revert "[SCSI] Remove full sg table memset()"
Create an inline function for clflush(), with the proper arguments,
and use it instead of hard-coding the instruction.
This also removes one instance of hard-coded wbinvd, based on a patch
by Bauder de Oliveira Costa.
[ tglx: arch/x86 adaptation ]
Cc: Glauber de Oliveira Costa <gcosta@redhat.com>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Signed-off-by: Andi Kleen <ak@suse.de>
Remove rogue default m in drivers/video/Kconfig
default m is near always wrong, like here. For some reason ACPI
likes to reintroduce these and I like to immediately squash them again
before they pollute too many .configs.
Cc: len.brown@intel.com
Cc: luming.yu@gmail.com
Acked-by: Len Brown <len.brown@intel.com>
