commit aa52b3a92918039b273fc9d1994bd34227c40269 upstream.
/drivers/usb/serial/option.c: Adding support for Cinterion's HC25, HC28,
HC28J, EU3-E, EU3-P and PH8 by correcting/adding Cinterion's and
Siemens' Vendor IDs as well as Product IDs and USB_DEVICE tuples
Signed-off-by: Nicolaus Colberg <nicolaus.colberg@cinterion.com>
commit a9d61bc49188e32d2ae9cf0f683cde3e1744feef upstream.
I found the original patch on the db0fhn repeater wiki (couldn't find the email
of the origial author) I guess it was never commited.
I updated and added some Icom HAM-radio devices to the ftdi driver.
Added extra comments to make clear what devices it are.
Signed-off-by: Pieter Maes <maescool@gmail.com>
commit 3ea3c9b5a8464ec8223125f95e5dddb3bfd02a39 upstream.
This patch (as1444) adds an unusual_devs entry for an MP3 player from
Coby electronics. The device has two nasty bugs.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Tested-by: Jasper Mackenzie <scarletpimpernal@hotmail.com>
commit 12f68c480c7155a66bd2a76ab2fef28dd5f93fa2 upstream.
This patch (as1438) adds an unusual_devs entry for the MagicPixel
FW_Omega2 chip, used in the CamSport Evo camera. The firmware
incorrectly reports a vendor-specific bDeviceClass.
Reported-by: <ttkspam@free.fr>
external hard drive enclosure
commit 7e1e7bd9dbd469267b6e6de1bf8d71a7d65ce86a upstream.
The TrekStor DataStation maxi g.u external hard drive enclosure uses a
JMicron USB to SATA chip which needs the US_FL_IGNORE_RESIDUE flag to work
properly.
Signed-off-by: Richard Schütz <r.schtz@t-online.de>
commit cae41118f50ef0c431e13159df6d7dd8bbd54004 upstream.
New device ID added for unusual Cypress ATACB device.
commit 9926c0df7b31b2128eebe92e0e2b052f380ea464 upstream.
Device ID removed 0x10C4/0x8149 for West Mountain Radio Computerized
Battery Analyzer. This device is actually based on a SiLabs C8051Fxxx,
see http://www.etheus.net/SiUSBXp_Linux_Driver for further info.
Signed-off-by: Craig Shelley <craig@microtron.org.uk>
commit faea63f7ccfddfb8fc19798799fcd38c58415172 upstream.
Device Ids added for IRZ Automation Teleport SG-10 GSM/GPRS Modem and
DekTec DTA Plus VHF/UHF Booster/Attenuator.
commit d14fc1a74e846d7851f24fc9519fe87dc12a1231 upstream.
Alan's commit 335f8514f200e63d689113d29cb7253a5c282967 introduced
.carrier_raised function in several drivers. That also means
tty_port_block_til_ready can now suspend the process trying to open the serial
port when Carrier Detect is low and put it into tty_port.open_wait queue. We
need to wake up the process when Carrier Detect goes high and trigger TTY
hangup when CD goes low.
Some of the devices do not report modem status line changes, or at least we
don't understand the status message, so for those we remove .carrier_raised
again.
Signed-off-by: Libor Pechacek <lpechacek@suse.cz>
commit f790674d3f87df6390828ac21a7d1530f71b59c8 upstream.
Functions set_fan_min() and set_fan_div() assume that the fan_div
values have already been read from the register. The driver currently
doesn't initialize them at load time, they are only set when function
via686a_update_device() is called. This means that set_fan_min() and
set_fan_div() misbehave if, for example, "sensors -s" is called
before any monitoring application (e.g. "sensors") is has been run.
Fix the problem by always initializing the fan_div values at device
bind time.
Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
commit 9c4cf6d94fb362c27a24df5223ed6e327eb7279a upstream.
This patch adds the device id for the windy31 USB device to the rt73usb
driver.
Thanks to Ralf Flaxa for reporting this and providing testing and a
sample device.
Reported-by: Ralf Flaxa <rf@suse.de>
Tested-by: Ralf Flaxa <rf@suse.de>
Acked-by: Ivo van Doorn <IvDoorn@gmail.com>
commit 05570297ecbe834b1756b522412b68eaffb9ab11 upstream.
When ASPM PM Feature is enabled on UMI link, devices that use ISOC stream of
data transfer may be exposed to longer latency causing less than optimal per-
formance of the device. The longer latencies are normal and are due to link
wake time coming out of low power state which happens frequently to save
power when the link is not active.
The following code will make exception for certain features of ASPM to be by
passed and keep the logic normal state only when the ISOC device is connected
and active. This change will allow the device to run at optimal performance
yet minimize the impact on overall power savings.
Signed-off-by: Alex He <alex.he@amd.com>
Acked-by: David Brownell <dbrownell@users.sourceforge.net>
commit 7571f089d7522a95c103558faf313c7af8856ceb upstream.
In the vhci_urb_dequeue() function the TCP connection is checked twice.
Each time when the TCP connection is closed the URB is unlinked and given
back. Remove the second attempt of unlinking and giving back of the URB completely.
This patch fixes the bug described at https://bugzilla.kernel.org/show_bug.cgi?id=24872 .
Signed-off-by: Márton Németh <nm127@freemail.hu>
commit e692cb668fdd5a712c6ed2a2d6f2a36ee83997b4 upstream.
When stacking devices, a request_queue is not always available. This
forced us to have a no_cluster flag in the queue_limits that could be
used as a carrier until the request_queue had been set up for a
metadevice.
There were several problems with that approach. First of all it was up
to the stacking device to remember to set queue flag after stacking had
completed. Also, the queue flag and the queue limits had to be kept in
sync at all times. We got that wrong, which could lead to us issuing
commands that went beyond the max scatterlist limit set by the driver.
The proper fix is to avoid having two flags for tracking the same thing.
We deprecate QUEUE_FLAG_CLUSTER and use the queue limit directly in the
block layer merging functions. The queue_limit 'no_cluster' is turned
into 'cluster' to avoid double negatives and to ease stacking.
Clustering defaults to being enabled as before. The queue flag logic is
removed from the stacking function, and explicitly setting the cluster
flag is no longer necessary in DM and MD.
Reported-by: Ed Lin <ed.lin@promise.com>
Acked-by: Mike Snitzer <snitzer@redhat.com>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
commit 8333f65ef094e47020cd01452b4637e7daf5a77f upstream.
use mv_xor_slot_cleanup() instead of __mv_xor_slot_cleanup() as the former function
aquires the spin lock that needed to protect the drivers data.
Signed-off-by: Saeed Bishara <saeed@marvell.com>
commit 56e6417b49132d4f56e9f2241d31942b90b46315 upstream.
This USB ID is for the WUBI-100GW 802.11g Wireless LAN USB Device that
uses p54usb.
Signed-off-by: Eduardo Costa <ecosta.tmp@gmail.com>
commit 16cad7fba037b34ca32cc0adac65bc089d969fb8 upstream.
This patch adds five more USBIDs to the table.
Source:
http://www.linuxant.com/pipermail/driverloader/2005q3/002307.html
http://wireless.kernel.org/en/users/Drivers/p54/devices (by M. Davis)
Signed-off-by: Christian Lamparter <chunkeey@googlemail.com>
commit d73a9b3001f29271c2e9f2a806b05a431c5d9591 upstream.
Add an unusual_devs entry for the Samsung YP-CP3 MP4 player.
User was getting the following errors in dmesg:
usb 2-6: reset high speed USB device using ehci_hcd and address 2
usb 2-6: USB disconnect, address 2
sd 3:0:0:0: [sdb] Assuming drive cache: write through
sdb:<2>ldm_validate_partition_table(): Disk read failed.
Dev sdb: unable to read RDB block 0
unable to read partition table
Signed-off-by: Vitaly Kuznetsov <vitty@altlinux.ru>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
CC: Matthew Dharm <mdharm-usb@one-eyed-alien.net>
commit 5363cdc3c5da9bd431552cf5989ab481596f0c6d upstream.
Add FTDI PID to identify D.O.Tec devices correctly.
Signed-off-by: Florian Faber <faberman@linuxproaudio.org>
commit ecc1624a2fff45780959efbcb73ace18fdb3c58d upstream.
Fabio Battaglia report that he has another cable that works with this
driver, so this patch adds its vendor/product ID.
Signed-off-by: Thomas Sailer <t.sailer@alumni.ethz.ch>
commit 31b24b955c3ebbb6f3008a6374e61cf7c05a193c upstream.
This change makes it so that vlan_gro_receive is only used if vlans have been
registered to the adapter structure. Previously we were just sending all vlan
tagged frames in via this function but this results in a null pointer
dereference when vlans are not registered.
[ This fixes bugzilla entry 15582 -Eric Dumazet]
Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com>
commit 7873ca4e4401f0ecd8868bf1543113467e6bae61 upstream.
The port data structure related to fc_host statistics collection is
not initialized. This causes system crash when reading the fc_host
statistics. The fix is to initialize port structure during driver
attach.
Signed-off-by: Krishna Gudipati <kgudipat@brocade.com>
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
commit cb174681a9ececa6702f114b85bdf82144b6a5af upstream.
[ Backport to .32.y by Antonio Ospite <ospite@studenti.unina.it> ]
There is a window between hidraw_table check and its dereference.
In that window, the device may be unplugged and removed form the
system and we will then dereference NULL.
Lock that place properly so that either we get NULL and jump out or we
can work with real pointer.
Signed-off-by: Antonio Ospite <ospite@studenti.unina.it>
commit 320718ee074acce5ffced6506cb51af1388942aa upstream.
I don't claim to understand the tty layer, but it seems like hvc_open and
hvc_close should be balanced in their kref reference counting.
Right now we get a kref every call to hvc_open:
if (hp->count++ > 0) {
tty_kref_get(tty); <----- here
spin_unlock_irqrestore(&hp->lock, flags);
hvc_kick();
return 0;
} /* else count == 0 */
tty->driver_data = hp;
hp->tty = tty_kref_get(tty); <------ or here if hp->count was 0
But hvc_close has:
tty_kref_get(tty);
if (--hp->count == 0) {
/* Put the ref obtained in hvc_open() */
tty_kref_put(tty);
tty_kref_put(tty);
Since the outside kref get/put balance we only do a single kref_put when
count reaches 0.
The patch below changes things to call tty_kref_put once for every
hvc_close call, and with that my machine boots fine.
Acked-by: Amit Shah <amit.shah@redhat.com>
commit e74d098c66543d0731de62eb747ccd5b636a6f4c upstream.
Alan pointed out a race in the code where hvc_remove is invoked. The
recent virtio_console work is the first user of hvc_remove().
Alan describes it thus:
The hvc_console assumes that a close and remove call can't occur at the
same time.
In addition tty_hangup(tty) is problematic as tty_hangup is asynchronous
itself....
So this can happen
hvc_close hvc_remove
hung up ? - no
lock
tty = hp->tty
unlock
lock
hp->tty = NULL
unlock
notify del
kref_put the hvc struct
close completes
tty is destroyed
tty_hangup dead tty
tty->ops will be NULL
NULL->...
This patch adds some tty krefs and also converts to using tty_vhangup().
Reported-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Signed-off-by: Amit Shah <amit.shah@redhat.com>
CC: Alan Cox <alan@lxorguk.ukuu.org.uk>
CC: linuxppc-dev@ozlabs.org
CC: Rusty Russell <rusty@rustcorp.com.au>
commit 254e42006c893f45bca48f313536fcba12206418 upstream.
On platforms with Intel 7500 chipset, there were some reports of system
hang/NMI's during kexec/kdump in the presence of interrupt-remapping enabled.
During kdump, there is a window where the devices might be still using old
kernel's interrupt information, while the kdump kernel is coming up. This can
cause vt-d faults as the interrupt configuration from the old kernel map to
null IRTE entries in the new kernel etc. (with out interrupt-remapping enabled,
we still have the same issue but in this case we will see benign spurious
interrupt hit the new kernel).
Based on platform config settings, these platforms seem to generate NMI/SMI
when a vt-d fault happens and there were reports that the resulting SMI causes
the system to hang.
Fix it by masking vt-d spec defined errors to platform error reporting logic.
VT-d spec related errors are already handled by the VT-d OS code, so need to
report the same error through other channels.
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
LKML-Reference: <1291667190.2675.8.camel@sbsiddha-MOBL3.sc.intel.com>
Reported-by: Max Asbock <masbock@linux.vnet.ibm.com>
Reported-and-tested-by: Takao Indoh <indou.takao@jp.fujitsu.com>
Acked-by: Chris Wright <chrisw@sous-sol.org>
Acked-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com>
commit 7f99d946e71e71d484b7543b49e990508e70d0c0 upstream.
Fault handling is getting enabled after enabling the interrupt-remapping (as
the success of interrupt-remapping can affect the apic mode and hence the
fault handling mode).
Hence there can potentially be some faults between the window of enabling
interrupt-remapping in the vt-d and the fault-handling of the vt-d units.
Handle any previous faults after enabling the vt-d fault handling.
For v2.6.38 cleanup, need to check if we can remove the dmar_fault() in the
enable_intr_remapping() and see if we can enable fault handling along with
enabling intr-remapping.
LKML-Reference: <20101201062244.630417138@intel.com>
commit 1a855a0606653d2d82506281e2c686bacb4b2f45 upstream.
With v0.90 metadata, a hot-spare does not become a full member of the
array until recovery is complete. So if we re-add such a device to
the array, we know that all of it is as up-to-date as the event count
would suggest, and so it a bitmap-based recovery is possible.
However with v1.x metadata, the hot-spare immediately becomes a full
member of the array, but it record how much of the device has been
recovered. If the array is stopped and re-assembled recovery starts
from this point.
When such a device is hot-added to an array we currently lose the 'how
much is recovered' information and incorrectly included it as a full
in-sync member (after bitmap-based fixup).
This is wrong and unsafe and could corrupt data.
So be more careful about setting saved_raid_disk - which is what
guides the re-adding of devices back into an array.
The new code matches the code in slot_store which does a similar
thing, which is encouraging.
This is suitable for any -stable kernel.
Reported-by: "Dailey, Nate" <Nate.Dailey@stratus.com>
Signed-off-by: NeilBrown <neilb@suse.de>
commit ba34fcee476d11e7c9df95932787a22a96ff6e68 upstream.
... and interface up.
In these situations, you are usually trying to connect to a new AP, so
keeping TKIP countermeasures active is confusing. This is already how
the driver behaves (inadvertently). However, querying SIOCGIWAUTH may
tell userspace that countermeasures are active when they aren't.
Clear the setting so that the reporting matches what the driver has
done..
Signed-off by: David Kilroy <kilroyd@googlemail.com>
commit 0a54917c3fc295cb61f3fb52373c173fd3b69f48 upstream.
Enable the port when disabling countermeasures, and disable it on
enabling countermeasures.
This bug causes the response of the system to certain attacks to be
ineffective.
It also prevents wpa_supplicant from getting scan results, as
wpa_supplicant disables countermeasures on startup - preventing the
hardware from scanning.
wpa_supplicant works with ap_mode=2 despite this bug because the commit
handler re-enables the port.
The log tends to look like:
State: DISCONNECTED -> SCANNING
Starting AP scan for wildcard SSID
Scan requested (ret=0) - scan timeout 5 seconds
EAPOL: disable timer tick
EAPOL: Supplicant port status: Unauthorized
Scan timeout - try to get results
Failed to get scan results
Failed to get scan results - try scanning again
Setting scan request: 1 sec 0 usec
Scan requested (ret=-1) - scan timeout 5 seconds
Failed to initiate AP scan.
Reported by: Giacomo Comes <comes@naic.edu>
commit a5dc4f898c2a0f66e2cefada6c687db82ba2fcbc upstream.
http://bugzilla.kernel.org/show_bug.cgi?id=15418
Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de>
Signed-off-by: Len Brown <len.brown@intel.com>
commit 8df3fc981dc12d9fdcaef4100a2193b605024d7a upstream.
Some Panasonic Toughbooks create nodes in module level code.
Module level code is the executable AML code outside of control method,
for example, below AML code creates a node \_SB.PCI0.GFX0.DD02.CUBL
If (\_OSI ("Windows 2006"))
Scope (\_SB.PCI0.GFX0.DD02)
Name (CUBL, Ones)
Scope() op does not actually create a new object, it refers to an
existing object(\_SB.PCI0.GFX0.DD02 in above example). However, for
Scope(), we want to indeed open a new scope, so the child nodes(CUBL in
above example) can be created correctly under it.
https://bugzilla.kernel.org/show_bug.cgi?id=19462
Signed-off-by: Bob Moore <robert.moore@intel.com>
Signed-off-by: Lin Ming <ming.m.lin@intel.com>
commit 7182afea8d1afd432a17c18162cc3fd441d0da93 upstream.
In ib_uverbs_poll_cq() code there is a potential integer overflow if
userspace passes in a large cmd.ne. The calls to kmalloc() would
allocate smaller buffers than intended, leading to memory corruption.
There iss also an information leak if resp wasn't all used.
Unprivileged userspace may call this function, although only if an
RDMA device that uses this function is present.
Fix this by copying CQ entries one at a time, which avoids the
allocation entirely, and also by moving this copying into a function
that makes sure to initialize all memory copied to userspace.
Special thanks to Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
for his help and advice.
[ Monkey around with things a bit to avoid bad code generation by gcc
when designated initializers are used. - Roland ]
Signed-off-by: Roland Dreier <rolandd@cisco.com>
commit e726f3c368e7c1919a7166ec09c5705759f1a69d upstream.
When matching error address to the range contained by one memory node,
we're in valid range when node interleaving
1. is disabled, or
2. enabled and when the address bits we interleave on match the
interleave selector on this node (see the "Node Interleaving" section in
the BKDG for an enlightening example).
Thus, when we early-exit, we need to reverse the compound logic
statement properly.
Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
commit 52bc9802ce849d0d287cc5fe76d06b0daa3986ca upstream.
Prevent setting fan_div from stomping on other fans that share the
same I2C register.
Signed-off-by: Gabriele Gorla <gorlik@penguintown.net>
commit 8b0f1840a46449e1946fc88860ef3ec8d6b1c2c7 upstream.
Allow 1 as a valid div value as specified in the ADM1026 datasheet.
commit e76116ca9671e2e5239054a40303b94feab585ad upstream.
Grub doesn't parse spaces in parameters correctly, so
this makes it impossible to force video= parameters
for kms on the grub kernel command line.
v2: shorten the names to make them easier to type.
Reported-by: Sergej Pupykin <ml@sergej.pp.ru>
Cc: Sergej Pupykin <ml@sergej.pp.ru>
Signed-off-by: Alex Deucher <alexdeucher@gmail.com>
The backported version of "TTY: ldisc, fix open flag handling" in
2.6.32.27 causes tty_ldisc_open() to return 0 on error. Fix that.
Cc: Jiri Slaby <jslaby@suse.cz>
Cc: Alan Cox <alan@linux.intel.com>
commit 15b87d67ff3dc042bee42f991858d6b121b3b3ca upstream.
Under heavy load conditions, our set of xpc messages may become exhausted.
The code handles this correctly with the exception of the management code
which hits a NULL pointer dereference.
Signed-off-by: Robin Holt <holt@sgi.com>
Cc: Jack Steiner <steiner@sgi.com>
commit dbd2918ec65c35f36bb102c88eafe87be0552f6f upstream.
Many times while the initial connection is being made, the contacted
partition will send back both the ACTIVATING and the ACTIVE
remote_act_state changes in very close succescion. The 1/4 second delay
in the make first contact loop is large enough to nearly always miss the
ACTIVATING state change.
Since either state indicates the remote partition has acknowledged our
state change, accept either.
commit 046d6c563b1c6226bbf0f84e5b2413ad8ab921a1 upstream.
This was a difficult bug to trip. XPC was in the middle of sending an
acknowledgement for a received message.
In xpc_received_payload_uv():
ret = xpc_send_gru_msg(ch->sn.uv.cached_notify_gru_mq_desc, msg,
sizeof(struct xpc_notify_mq_msghdr_uv));
if (ret != xpSuccess)
XPC_DEACTIVATE_PARTITION(&xpc_partitions[ch->partid], ret);
msg->hdr.msg_slot_number += ch->remote_nentries;
at the point in xpc_send_gru_msg() where the hardware has dispatched the
acknowledgement, the remote side is able to reuse the message structure
and send a message with a different slot number. This problem is made
worse by interrupts.
The adjustment of msg_slot_number and the BUG_ON in
xpc_handle_notify_mq_msg_uv() which verifies the msg_slot_number is
consistent are only used for debug purposes. Since a fix for this that
preserves the debug functionality would either have to infringe upon the
payload or allocate another structure just for debug, I decided to remove
it entirely.
commit 57e6d258b1e41cd7ceb26fa43ce116939d8440b1 upstream.
Currently, the UV xpc code is passing nid to the gru_create_message_queue
instead of nasid as it expects.
Signed-off-by: Jack Steiner <steiner@sgi.com>
commit c054a076a1bd4731820a9c4d638b13d5c9bf5935 upstream.
On certain VIA chipsets AES-CBC requires the input/output to be
a multiple of 64 bytes. We had a workaround for this but it was
buggy as it sent the whole input for processing when it is meant
to only send the initial number of blocks which makes the rest
As expected this causes memory corruption whenever the workaround
kicks in.
Reported-by: Phil Sutter <phil@nwl.cc>
commit 405707985594169cfd0b1d97d29fcb4b4c6f2ac9 upstream.
The FBIOGET_VBLANK device ioctl allows unprivileged users to read 16
bytes of uninitialized stack memory, because the "reserved" member of
the fb_vblank struct declared on the stack is not altered or zeroed
before being copied back to the user. This patch takes care of it.
Signed-off-by: Dan Rosenberg <dan.j.rosenberg@gmail.com>
Signed-off-by: Andy Walls <awalls@md.metrocast.net>
[Note that the mainline will not have this particular fix but rather
will blacklist entire VAIO line based off DMI board name. For stable
I am being a bit more cautious and blacklist one particular product.]
Trying to query/activate active multiplexing mode on this VAIO makes
both keyboard and touchpad inoperable. Futher kernels will blacklist
entire VAIO line, however here we blacklist just one particular model.
Reported-by: Jesse Barnes <jbarnes@virtuousgeek.org>
descriptors
commit c4ed8c66d79d707d89fe732ff5b97739edf1ba62 upstream.
At least one 5986:0241 webcam model includes vendor-specific descriptors
at the end of its streaming interface descriptors. Print an information
UVC_TRACE_DESCR message and try to continue parsing the descriptors
rather than bailing out with an error.
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Cc: maximilian attems <max@stro.at>
commit a5757c2a474a15f87e5baa9a4caacc31cde2bae6 upstream.
Enable the EFI framebuffer on 14 more Macs, including the iMac11,1
iMac10,1 iMac8,1 Macmini3,1 Macmini4,1 MacBook5,1 MacBook6,1 MacBook7,1
MacBookPro2,2 MacBookPro5,2 MacBookPro5,3 MacBookPro6,1 MacBookPro6,2 and
MacBookPro7,1
Information gathered from various user submissions.
https://bugzilla.redhat.com/show_bug.cgi?id=528232
http://ubuntuforums.org/showthread.php?t=1557326
Signed-off-by: Luke Macken <lmacken@redhat.com>
Signed-off-by: Peter Jones <pjones@redhat.com>
commit 8a3bdfe6cd841880a5d849c40f90093b3817f6e0 upstream.
Description of patch:
This is a patch for the EFI framebuffer driver to enable the framebuffer
of the NVIDIA 9400M as found in MacBook Pro (MBP) 5,1 and up. The
framebuffer of the NVIDIA graphic cards are located at the following
addresses in memory:
9400M: 0xC0010000
9600M GT: 0xB0030000
The patch delivered right here only provides the memory location of the
framebuffer of the 9400M device. The 9600M GT is not covered. It is
assumed that the 9400M is used when powered up the MBP.
The information which device is currently powered and in use is stored in
the 64 bytes large EFI variable "gpu-power-prefs". More specifically,
byte 0x3B indicates whether 9600M GT (0x00) or 9400M (0x01) is online.
The PCI bus IDs are the following:
9400M: PCI 03:00:00
9600M GT: PCI 02:00:00
The EFI variables can be easily read-out and manipulated with "rEFIt", an
MBP specific bootloader tool. For more information on how handle rEFIt
and EFI variables please consult "http://refit.sourceforge.net" and
"http://ubuntuforums.org/archive/index.php/t-1076879.html".
IMPORTANT NOTE: The information on how to activate the 9400M device given
at "ubuntuforums.org" is not correct, since it states
gpu-power-prefs[0x3B] = 0x00 -> 9400M (PCI 02:00:00)
gpu-power-prefs[0x3B] = 0x01 -> 9600M GT (PCI 03:00:00)
Actually, the assignment of the values and the PCI bus IDs are swapped.
Suggestions:
To cover framebuffers of both 9400M and 9600M GT, I would suggest to
implement a conditional on "gpu-power-prefs". Depending on the value of
byte 0x3B, the according framebuffer is selected. However, this requires
kernel access to the EFI variables.
[akpm@linux-foundation.org: rename optname, per Peter Jones]
Signed-off-by: Thomas Gerlach <t.m.gerlach@freenet.de>
Acked-by: Peter Jones <pjones@redhat.com>
linux-2.6.36-rc5 crash with gianfar ethernet at full line rate traffic)
[ Upstream commit 0d1fe1111c667e9c713d7efc7ae468a605f236a4 ]
The rx_recycle queue is global per device but can be accesed by many
napi handlers at the same time, so it needs full skb_queue primitives
(with locking). Otherwise, various crashes caused by broken skbs are
possible.
This patch resolves, at least partly, bugzilla bug 19692. (Because of
some doubts that there could be still something around which is hard
to reproduce my proposal is to leave this bug opened for a month.)
Fixes commit: 0fd56bb5be6455d0d42241e65aed057244665e5e ("gianfar: Add
support for skb recycling")
Reported-by: emin ak <eminak71@gmail.com>
Tested-by: emin ak <eminak71@gmail.com>
Signed-off-by: Jarek Poplawski <jarkao2@gmail.com>
CC: Andy Fleming <afleming@freescale.com>
commit e42dee9a99a3ecd32b5c027e8f7411fb5bc11eb6 upstream.
BUG: unable to handle kernel NULL pointer dereference at 0000000000000028
IP: [<ffffffffa0f0a625>] hidraw_write+0x3b/0x116 [hid]
This is reproducible by disconnecting the device while userspace writes
to dev node in a loop and doesn't check return values in order to exit
the loop.
