path: root/drivers
2012-03-20drm: allow loading an EDID as firmware to override broken monitorCarsten Emde
Broken monitors and/or broken graphic boards may send erroneous or no EDID data. This also applies to broken KVM devices that are unable to correctly forward the EDID data of the connected monitor but invent their own fantasy data. This patch allows to specify an EDID data set to be used instead of probing the monitor for it. It contains built-in data sets of frequently used screen resolutions. In addition, a particular EDID data set may be provided in the /lib/firmware directory and loaded via the firmware interface. The name is passed to the kernel as module parameter of the drm_kms_helper module either when loaded options drm_kms_helper edid_firmware=edid/1280x1024.bin or as kernel commandline parameter drm_kms_helper.edid_firmware=edid/1280x1024.bin It is also possible to restrict the usage of a specified EDID data set to a particular connector. This is done by prepending the name of the connector to the name of the EDID data set using the syntax edid_firmware=[<connector>:]<edid> such as, for example, edid_firmware=DVI-I-1:edid/1920x1080.bin in which case no other connector will be affected. The built-in data sets are Resolution Name -------------------------------- 1024x768 edid/1024x768.bin 1280x1024 edid/1280x1024.bin 1680x1050 edid/1680x1050.bin 1920x1080 edid/1920x1080.bin They are ignored, if a file with the same name is available in the /lib/firmware directory. The built-in EDID data sets are based on standard timings that may not apply to a particular monitor and even crash it. Ideally, EDID data of the connected monitor should be used. They may be obtained through the drm/cardX/cardX-<connector>/edid entry in the /sys/devices PCI directory of a correctly working graphics adapter. It is even possible to specify the name of an EDID data set on-the-fly via the /sys/module interface, e.g. echo edid/myedid.bin >/sys/module/drm_kms_helper/parameters/edid_firmware The new screen mode is considered when the related kernel function is called for the first time after the change. Such calls are made when the X server is started or when the display settings dialog is opened in an already running X server. Signed-off-by: Carsten Emde <C.Emde@osadl.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-20drm/exynos: enable hdmi audio featureSeung-Woo Kim
This patch adds hdmi audio feature for exynos drm. With this patch, i2s channel feeds audio data in hdmi when hdmi is connected. Signed-off-by: Seung-Woo Kim <sw0312.kim@samsung.com> Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Inki Dae <inki.dae@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-20drm/exynos: add default pixel format for planeEunchul Kim
DRM checks whether the plane supports a pixel format of fb when plane is updated. This adds a default pixel format supporting format exynos drm plane. Signed-off-by: Eunchul Kim <chulspro.kim@samsung.com> Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Inki Dae <inki.dae@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-20drm/exynos: cleanup exynos_hdmi.hJoonyoung Shim
The some contents of the exynos_hdmi.h are used only in exynos_hdmi.c, so move them to exynos_hdmi.c. Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Inki Dae <inki.dae@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-20drm/exynos: add is_local member in exynos_drm_subdrv structJoonyoung Shim
The is_local member indicates unused subdrv such connector and encoder so doesn't make resources for them. Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Inki Dae <inki.dae@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-20drm/exynos: add subdrv open/close functionsJoonyoung Shim
Some subdrv need open and close functions call when open and close drm. Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Inki Dae <inki.dae@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-20drm/exynos: remove module of exynos drm subdrvJoonyoung Shim
The exynos drm driver has several subdrv. They each can be module but it causes unfixed probe order of exynodr drm driver and each subdrv. It also needs some weird codes such as exynos_drm_fbdev_reinit and exynos_drm_mode_group_reinit. This patch can remove weird codes and clear codes through we doesn't modularity each subdrv. Also this removes unnecessary codes related module. Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Inki Dae <inki.dae@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-20drm/exynos: release pending pageflip events when closedJoonyoung Shim
We should release pending pageflip events when closed. If not, they will be dangling events. Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Inki Dae <inki.dae@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-20drm/exynos: added new funtion to get/put dma address.Inki Dae
this function would be used for drm based 2d acceleration driver to get/put dma address through gem handle. when exynos_drm_get_dma_address is called reference count of gem object would be increased not to be released by gem close and when exynos_drm_put_dma_address is called the reference count of this gem object would be decreased to be released. Signed-off-by: Inki Dae <inki.dae@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-20drm/exynos: update gem and buffer framework.Inki Dae
with this patch, we can allocate physically continuous or non-continuous memory and also it creates scatterlist for iommu support so allocated memory region can be mapped to iommu page table using scatterlist. Signed-off-by: Inki Dae <inki.dae@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-20drm/exynos: added mode_fixup feature and code clean.Inki Dae
this patch adds mode_fixup feature for hdmi module that specific driver changes current mode to driver desired mode properly. Signed-off-by: Inki Dae <inki.dae@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-20drm/exynos: add HDMI version 1.4 supportJoonyoung Shim
Later Exynos series from Exynos4X12 support HDMI version 1.4. We will distinguish to use which version via platform data. This patch supports only default features of HDMI version 1.4(The 3D, sound and etc don't support yet) Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Inki Dae <inki.dae@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-20drm/exynos: remove exynos_mixer.hJoonyoung Shim
The contents of exynos_mixer.h are used only in exynos_mixer.c, so separated header is unnecessary. Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-20gma500: Fix mmap frambufferYoichi Yuasa
It cannot map correctly if page fault begins from a intermediate address. [The driver prefaults the mapping, so we need to work from the correct base address not the faulting address otherwise the map appears offset by the fault offset] Signed-off-by: Yoichi Yuasa <yuasa@linux-mips.org> Signed-off-by: Alan Cox <alan@linux.intel.com> Cc: stable@kernel.org Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-20Merge tag 'drm-intel-next-2012-03-01' of ↵Dave Airlie
git://people.freedesktop.org/~danvet/drm-intel into drm-next * tag 'drm-intel-next-2012-03-01' of git://people.freedesktop.org/~danvet/drm-intel: drm/i915: Only clear the GPU domains upon a successful finish drm/i915: reenable gmbus on gen3+ again drm/i915: i2c: unconditionally set up gpio fallback drm/i915: merge gmbus and gpio i2c adpater into one drm/i915: merge struct intel_gpio into struct intel_gmbus i2c: export bit-banging algo functions drm/nouveau: do a better job at hiding the NIH i2c bit-banging algo drm/i915: add dev_priv to intel_gmbus drm/i915: Fix single msg gmbus_xfers writes drm/i915: error_buffer->ring should be signed drm/i915: Silence the error message from i915_wait_request() drm/i915: use the new hdmi_force_audio enum more drm/i915: No need to search again after retiring requests drm/i915: Only bump refcnt on objects scheduled for eviction drm/i915/bios: Downgrade the "signature missing" DRM_ERROR to debug drm/i915: Ignore LVDS on hp t5745 and hp st5747 thin client drm/i915: Fixes distorted external screen image on HP 2730p
2012-03-20drm/radeon: Drop radeon_gem_object_(un)pin.Michel Dänzer
Only radeon_gem_object_unpin was used anymore, in only one place. Signed-off-by: Michel Dänzer <michel.daenzer@amd.com> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-20drm/radeon: Restrict offset for legacy display engine.Michel Dänzer
The hardware only takes 27 bits for the offset, so larger offsets are truncated, and the display shows random bits other than the intended ones. Signed-off-by: Michel Dänzer <michel.daenzer@amd.com> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-20drm/radeon: Restrict offset for legacy hardware cursor.Michel Dänzer
The hardware only takes 27 bits for the offset, so larger offsets are truncated, and the hardware cursor shows random bits other than the intended ones. Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=46796 Cc: stable@vger.kernel.org Signed-off-by: Michel Dänzer <michel.daenzer@amd.com> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-20drm/radeon/kms: reduce probe latency on digital connectorsTvrtko Ursulin
On a system with one HDMI and one VGA connector the latter causes output polling to run every ten seconds. This causes full EDID re-fetch on every poll and approx. 100ms rendering stalls are experienced by full screen page-flipping applications. Optimisation is to trust HPD sense on R600+ ASICs and to skip doing these expensive probes unless HPD sense has changed. Fixes: https://bugs.freedesktop.org/show_bug.cgi?id=47007 agd5f: fix patch and message formatting. Signed-off-by: Tvrtko Ursulin <tvrtko.ursulin@onelan.co.uk> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-20drm/radeon/kms: add connector quirk for Fujitsu D3003-S2 boardAlex Deucher
vbios lists DVI-I port as VGA and DVI-D. Fixes: https://bugs.freedesktop.org/show_bug.cgi?id=47007 Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Cc: stable@vger.kernel.org Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-20drm/radeon/kms: fix analog load detection on DVI-I connectorsAlex Deucher
We digital encoders have a detect function as well (for DP to VGA bridges), so we make sure we choose the analog one here. Fixes: https://bugs.freedesktop.org/show_bug.cgi?id=47007 Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Cc: stable@vger.kernel.org Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-20drm/ttm: Use pr_fmt and pr_<level>Joe Perches
Use the more current logging style. Add pr_fmt and remove the TTM_PFX uses. Coalesce formats and align arguments. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-20drivers/gpu/drm/savage/savage_state.c: add missing kfreeJulia Lawall
Most of the error handling code in this function frees the buffers kcmd_addr, kvb_addr, and kbox_addr allocated at the beginning of this function. These two branches are changed to do the same. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-20drivers/gpu/drm/radeon/radeon_cs.c: eliminate possible double freeJulia Lawall
The function radeon_cs_parser_init is only called from two places, in drivers/gpu/drm/radeon/radeon_cs.c and drivers/gpu/drm/radeon/r600_cs.c. In each case, if the call fails another function is called that frees all of the kdata and dpage information in the chunks array. So this information should not be freed in radeon_cs_parser_init as well. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Reviewed-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-20drm/radeon: dp only enable enhanced framing if sink supports.Dave Airlie
DisplayPort spec v1.1a, Table 2-52. Same commit to Intel by ajax in 9962c9252e46eda7058067cbe73bdf1ed74b0d37 Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-20drm/radeon/kms: skip db/cb/streamout checking when possible on r600Marek Olšák
Signed-off-by: Marek Olšák <maraeo@gmail.com> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-20drm/radeon/kms: compute GPU addresses correctly on r600Marek Olšák
2012-03-20drm/radeon/kms: remove some unused variables in evergreen_cs_trackMarek Olšák
and document the other unused ones. Signed-off-by: Marek Olšák <maraeo@gmail.com> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-20drm/radeon/kms: skip db/cb/streamout checking when possible on evergreenMarek Olšák
2012-03-20drm/radeon/kms: optimize streamout checking for evergreenMarek Olšák
2012-03-20drm/radeon/kms: compute GPU addresses correctly on evergreenMarek Olšák
There are also two fixes: - In DRAW_INDEX_2, we read idx_value, but should have read idx+1. - When correcting SQ_VTX_CONSTANT_WORD1_0.SIZE, we should subtract the offset. Signed-off-by: Marek Olšák <maraeo@gmail.com> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-20drm/radeon/kms: make some DRM errors more informativeMarek Olšák
2012-03-20drm/radeon/kms: skip cb/db checking if SX_MISC is 1 on r600+Marek Olšák
2012-03-20drm/usb: move usb support into a separate moduleDave Airlie
In order to satisfy all the various Kconfig options between USB and DRM, we need to split the USB code out into a separate module and export symbols to it. This fixes build problems in -next reported by sfr. Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-16drm: fix build with UDL if USB is a moduleDave Airlie
reported by sfr on -next merge. Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-15drm/udl: initial UDL driver (v4)Dave Airlie
This is an initial drm/kms driver for the displaylink devices. Supports fb_defio, supports KMS dumb interface supports 24bpp via conversion to 16bpp, hw can do this better. supports hot unplug using new drm core features. On an unplug, it disables connector polling, unplugs connectors from sysfs, unplugs fbdev layer (using Kay's API), drops all the USB device URBs, and call the drm core to unplug the device. This driver is based in large parts on udlfb.c so I've licensed it under GPLv2. Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-15drm: add core support for unplugging a device (v2)Dave Airlie
Two parts to this, one is simple unplug from sysfs for the device node. The second adds an unplugged state, if we have device opens, we just set the unplugged state and return, if we have no device opens we drop the drm device. If after a lastclose we discover we are unplugged we then drop the drm device. v2: use an atomic for unplugged and wrap it for users, add checks on open + mmap + ioctl entry points. Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-15drm/modeset: add helper to unplug all connectors from sysfsDave Airlie
In order to get correct ordering at hot-unplug for userspace, we need to tear down all the sysfs bits at the correct time. This adds a helper to allow drivers to remove the sysfs nodes for all connectors. Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-15drm/sysfs: protect sysfs removal code against being run twice.Dave Airlie
a step towards correct hot unplug for USB devices, we need to remove the userspace facing bits at the unplug time for correct udev operation. Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-15udlfb: remove sysfs framebuffer device with USB .disconnect()Kay Sievers
The USB graphics card driver delays the unregistering of the framebuffer device to a workqueue, which breaks the userspace visible remove uevent sequence. Recent userspace tools started to support USB graphics card hotplug out-of-the-box and rely on proper events sent by the kernel. The framebuffer device is a direct child of the USB interface which is removed immediately after the USB .disconnect() callback. But the fb device in /sys stays around until its final cleanup, at a time where all the parent devices have been removed already. To work around that, we remove the sysfs fb device directly in the USB .disconnect() callback and leave only the cleanup of the internal fb data to the delayed work. Before: add /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2 (usb) add /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.0 (usb) add /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.0/graphics/fb0 (graphics) remove /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.0 (usb) remove /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2 (usb) remove /2-1.2:1.0/graphics/fb0 (graphics) After: add /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2 (usb) add /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.0 (usb) add /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.0/graphics/fb1 (graphics) remove /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.0/graphics/fb1 (graphics) remove /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.0 (usb) remove /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2 (usb) Cc: stable@vger.kernel.org Tested-by: Bernie Thompson <bernie@plugable.com> Acked-by: Bernie Thompson <bernie@plugable.com> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
2012-03-15drm: Merge tag 'v3.3-rc7' into drm-core-nextDave Airlie
Merge the fixes so far into core-next, needed to test intel driver. Conflicts: drivers/gpu/drm/i915/intel_ringbuffer.c
2012-03-15drm: Add drm_mode_copy()Ville Syrjälä
Add a helper function to copy a display mode. Use it in drm_mode_duplicate() and nouveau mode_fixup hooks. Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-15drm: Use a flexible array member for blob property dataVille Syrjälä
The blob property data is always allocated immediately after the object header. No need for the extra indirection when accessing it, just use a flexible array member. Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-15drm: Handle drm_object_get() failuresVille Syrjälä
Check drm_mode_object_get() return value everywhere. Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-15drm: Make drm_crtc_convert_{umode, to_umode} static and constify their paramsVille Syrjälä
drm_crtc_convert_umode() and drm_crtc_convert_to_umode() are never used outside drm_crtc.c, so make them static. Also make the input mode structure const for both functions. Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-15drm: Fix drm_mode_attachmode_crtc()Ville Syrjälä
Change drm_mode_attachmode_crtc() to take an "all or nothing" approach. If an error is returned, there are no side effects visible. Also change the function to always duplicate the mode passed in. Also change the function to not give up when it finds the first connector without and encoder. A simpler approach would be to just remove the function completely as it's unused currently. Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-15drm: Check CRTC viewport against framebuffer sizeVille Syrjälä
Make sure the requested CRTC viewport fits inside the framebuffer. Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-15drm: Check user mode against overflowsVille Syrjälä
The internal mode representation drm_display_mode uses signed data types. When converting the user mode to internal representation, check that the unsigned values don't overflow the signed datatypes. Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-15drm: Fix memory leak in drm_mode_setcrtc()Ville Syrjälä
The mode passed to the .set_config() hook was never freed. The drivers will make a copy of the mode, so simply free it when done. Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-03-15drm: Make drm_mode_attachmode() voidVille Syrjälä
drm_mode_attachmode() always returns 0. Change the return type to void. Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
