path: root/drivers
2011-04-12Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem Conflicts: drivers/net/wireless/ath/ar9170/main.c drivers/net/wireless/ath/ar9170/phy.c drivers/net/wireless/zd1211rw/zd_rf_rf2959.c
2011-04-12vxge: update driver versionJon Mason
Update vxge driver version to 2.5.3 Signed-off-by: Jon Mason <jdmason@kudzu.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-12vxge: spin-lock issueJon Mason
In vxge_hw_vpath_close, __vxge_hw_vp_terminate memsets the vpath which clobbers the spin lock state, then the driver attempts to acquire the spin lock. Resolve this by not zeroing the lock part of vpath struct, clean-up vpath locking in init, close, and fix locking hole in fw_api call. Issue found by Bob Picco <bpicco@redhat.com> Signed-off-by: Jon Mason <jdmason@kudzu.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-12vxge: always enable hardware time stampJon Mason
Hardware time stamp calculation can only be enabled by the privileged function. Enable it always by default and simply use the ethtool interface to set a flag to indicate whether or not the respective function driver should indicate the timestamp along with the received packet. Also, make certain fields in vxge_hw_device_config bit-fields to reduce the size of the struct. Signed-off-by: Jon Mason <jdmason@kudzu.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-12s2io: Fix warnings due to -Wunused-but-set-variable.David S. Miller
Most of these are cases where we are trying to read back a register after a write to ensure completion. Simply pre-fixing the readl() or readq() with "(void)" is sufficient because these are volatile operations and the compiler cannot eliminate them just because no real assignment takes place. The case of free_rxd_blk()'s assignments to "struct buffAdd *ba" is a real spurious assignment as this variable is completely otherwise unused. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Jon Mason <jdmason@kudzu.us>
2011-04-11niu: Fix warnings due to -Wunused-but-set-variableDavid S. Miller
Most of these were legitimate, and once case was a real bug (not propagating errors from ->xcvr_init() methods). Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/smsc911x.c
2011-04-11niu: Recognise original ethtool class code for AH/ESP flow hashingBen Hutchings
When the RX network flow classification interface was originally defined for reporting and controlling of flow hashing, AH and ESP were not given distinct flow class codes (apparently because the Sun Neptune hardware treats them very similarly). For flow steering, they must be distinguished, so new and separate flow class codes were added for AH and ESP. But for backward- compatibility, flow hash operations should continue to support the original class codes. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-11gianfar: Clean up implementation of RX network flow classificationBen Hutchings
This code was cribbed from niu, so gfar_set_hash_opts() begins by converting the ethtool flow class code into a class code for Sun Neptune hardware, then does the same thing again for the hardware it's really dealing with. It may also return -1 (-EPERM) for some unhandled ethtool flow class codes. Remove the useless code and definitions, and fix the error code. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-11qlge: use ethtool set_phys_idstephen hemminger
This is a stab at replacing old ethtool phys_id with set_phys_id on the Qlogic 10Gb driver. Compile tested only. Not sure if set_led_cfg will flash continuously, or needs to be replaced by ETHTOOL_ID_ON/ETHTOOL_ID_OFF Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-11netxen: limit skb frags for non tso packetamit salecha
Machines are getting deadlock in four node cluster environment. All nodes are accessing (find /gfs2 -depth -print|cpio -ocv > /dev/null) 200 GB storage on a GFS2 filesystem. This result in memory fragmentation and driver receives 18 frags for 1448 byte packets. For non tso packet, fw drops the tx request, if it has >14 frags. Fixing it by pulling extra frags. Cc: stable@kernel.org Signed-off-by: Amit Kumar Salecha <amit.salecha@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-11bonding:fix two typosPeter Pan(潘卫平)
replace relpy with reply. replace premanent with permanent. Signed-off-by: Weiping Pan(潘卫平) <panweiping3@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-11net: fix tranmitted/tranmitting typoPeter Pan(潘卫平)
replace tranmitted with transmitted. replace tranmitting with transmitting. Signed-off-by: Weiping Pan(潘卫平) <panweiping3@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-11bonding:delete unused rlb_interval_counterPeter Pan(潘卫平)
Now, alb_bond_info uses rx_ntt,rlb_update_delay_counter and rlb_update_retry_counter to decide when to call rlb_update_rx_clients(). Signed-off-by: Weiping Pan(潘卫平) <panweiping3@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-11bonding:delete unused alb_timerPeter Pan(潘卫平)
Now bonding-alb uses delayed_work instead of timer_list. Signed-off-by: Weiping Pan(潘卫平) <panweiping3@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-11bonding:set save_load to 0 when initializingPeter Pan(潘卫平)
It is unnecessary to set save_load to 1 here, as the tx_hashtbl is just kzalloced. Signed-off-by: Weiping Pan(潘卫平) <panweiping3@gmail.com> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-11stmmac: fix Transmit Underflow errorGiuseppe CAVALLARO
On some old MAC chips without COE sometime the Transmit Underflow error is issued. The driver aborted all the transmission process and initialized it from scratch. This breaks the network activity as raised by Nachiketa on a SPEAr board. The patch is to fix this rare underflow event. The driver will only clear the interrupt and the Tx DMA will go out the Suspend state as soon as the descriptor is fetched again. The driver will continue to bump-up the DMA FIFO threshold that, indeed, helped somebody to prevent this kind of error in the past as well. Reported-by: Nachiketa Prachanda <nprachanda@ncomputing.com> Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-11stmmac: fix open funct when exit on errorGiuseppe CAVALLARO
This patch reviews the open function and fixes some errors when exit with an error state. It also moves the request_irq after core is initialized when interrupts are properly masked. Signed-off-by: Shiraz Hashim <shiraz.hashim@st.com> Hacked-by: Giuseppe Cavallaro <peppe.cavallaro@st.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-11stmmac: fixed dma lib build when turn-on the debug optionGiuseppe CAVALLARO
This patch fixes a compilation error when build the dwmac_lib with the DEBUG option enabled. Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-11iwlegacy: make iwl3945 and iwl4965 select IWLWIFI_LEGACYJohn W. Linville
Otherwise, IWLWIFI_LEGACY has to be selected independently before the drivers are made available. Reported-by: Dave Airlie <airlied@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Cc: Stanislaw Gruszka <sgruszka@redhat.com> Cc: Wey-Yi Guy <wey-yi.w.guy@intel.com>
2011-04-11pci: fix PCI bus allocation alignment handlingLinus Torvalds
In commit 13583b16592a ("PCI: refactor io size calculation code") Ram had a thinko in the refactorization of the code: the end result used the variable 'align' for the bus alignment, but the original code used 'min_align'. Since then, another use of that 'align' variable got introduced by commit c8adf9a3e873 ("PCI: pre-allocate additional resources to devices only after successful allocation of essential resources.") Fix both of those uses to use 'min_align' as they should. Daniel Hellstrom <daniel@gaisler.com> Acked-by: Ram Pai <linuxram@us.ibm.com> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (34 commits) net: Add support for SMSC LAN9530, LAN9730 and LAN89530 mlx4_en: Restoring RX buffer pointer in case of failure mlx4: Sensing link type at device initialization ipv4: Fix "Set rt->rt_iif more sanely on output routes." MAINTAINERS: add entry for Xen network backend be2net: Fix suspend/resume operation be2net: Rename some struct members for clarity pppoe: drop PPPOX_ZOMBIEs in pppoe_flush_dev dsa/mv88e6131: add support for mv88e6085 switch ipv6: Enable RFS sk_rxhash tracking for ipv6 sockets (v2) be2net: Fix a potential crash during shutdown. bna: Fix for handling firmware heartbeat failure can: mcp251x: Allow pass IRQ flags through platform data. smsc911x: fix mac_lock acquision before calling smsc911x_mac_read iwlwifi: accept EEPROM version 0x423 for iwl6000 rt2x00: fix cancelling uninitialized work rtlwifi: Fix some warnings/bugs p54usb: IDs for two new devices wl12xx: fix potential buffer overflow in testmode nvs push zd1211rw: reset rx idle timer from tasklet ...
2011-04-10net: Add support for SMSC LAN9530, LAN9730 and LAN89530Steve Glendinning
This patch adds support for SMSC's LAN9530, LAN9730 and LAN89530 USB ethernet controllers to the existing smsc95xx driver by adding their new USB VID/PID pairs. Signed-off-by: Steve Glendinning <steve.glendinning@smsc.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-10net: bnx2: convert to hw_featuresMichał Mirosław
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-10net: via-velocity: convert to hw_featuresMichał Mirosław
Trivial conversion. This also enables toggling TX VLAN offload and fixes TX checksumming race with offload changes. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-10net: ksz884x: convert to hw_featuresMichał Mirosław
This also fixes possible race when changing receive checksum state and removes IPV6_CSUM_GEN_HACK as it's always set. BTW, The claim about fake IPV6 checksum looks dubious. If that were true, then there's a problem in networking core and should be fixed there and not in random drivers. BTW#2, there's no MAINTAINERS entry for this driver. I assume this driver is supported by Micrel? Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-10net: stmmac: convert to hw_featuresMichał Mirosław
This also removes TSO as it's made fully in software --- better to leave this to networking core. If the MAC features can be detected at probe time and not at open, then stmmac_fix_features could be simplified by limiting hw_features. That's also better for users as they don't see offloads being togglable but never turned on. Redundant fallbacks for TX csum are removed as it's already handled by network core. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-10net: 8139cp: convert to hw_featuresMichał Mirosław
2011-04-10net: r8169: convert to hw_featuresMichał Mirosław
Simple conversion with a bit of needed cleanup. This also fixes: - confusion around vlan_features in rtl8169_vlan_mode(), - problem with broken TSO for too big MTU (the limit is set at 0xFFF --- max MSS field value). SG+IP_CSUM+TSO is left disabled by default, based on suggestion by David Dillow. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-10net: benet: convert to hw_features - fixupMichał Mirosław
Fix up after merge with NETIF_F_RXHASH implementation. This allows to toggle NETIF_F_RXHASH and NETIF_F_HW_VLAN_TX. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-10net: Remove invalid offloadsMichał Mirosław
Remove offload changing ethtool ops which drivers don't really support: - fs_enet - ucc_geth Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-10usb: plusb: Add debug to reset functionsimon
This patch adds some debug to the reset function to print out the reason why it fails. Signed-off-by: Simon Wood <simon@mungewell.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-10usb: plusb: Add support for PL-25A1simon
This patch adds support for the PL-25A1 by adding the appropriate USB ID's. This chip is used in the Belkin 'Windows Easy Transfer' Cables. Signed-off-by: Simon Wood <simon@mungewell.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-10usb: plusb: Whitespacesimon
This patch cleans up a couple of instances of incorrect whitespace Signed-off-by: Simon Wood <simon@mungewell.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-09Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: mtd: atmel_nand: use CPU I/O when buffer is in vmalloc(ed) region mtd: atmel_nand: modify test case for using DMA operations mtd: atmel_nand: fix support for CPUs that do not support DMA access mtd: atmel_nand: trivial: change DMA usage information trace mtd: mtdswap: fix printk format warning
2011-04-08cxgb4vf: drop phys_id interface and implement the newer set_phys_idDimitris Michailidis
Signed-off-by: Dimitris Michailidis <dm@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-08cxgb4: drop phys_id interface and implement the newer set_phys_idDimitris Michailidis
2011-04-08cnic: Fix rtnl deadlockMichael Chan
When cnic_stop_hw() -> cnic_cm_stop_bnx2x_hw() is called under rtnl_lock() from NETDEV_DOWN event, it waits for cnic_delete_task() to complete. It will deadlock when cnic_delete_task() takes rtnl_lock() before calling cnic_ulp_stop_one(). We fix it by removing the rtnl_lock() in cnic_delete_task(). cnic_ulp_stop_one() has mutex and atomic bit ops to prevent important operations from being done more than once, so it is not necessary to take rtnl_lock(). Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-08p54: Initialize extra_len in p54_tx_80211Jason Conti
This patch fixes a very serious off-by-one bug in the driver, which could leave the device in an unresponsive state. The problem was that the extra_len variable [used to reserve extra scratch buffer space for the firmware] was left uninitialized. Because p54_assign_address later needs the value to reserve additional space, the resulting frame could be to big for the small device's memory window and everything would immediately come to a grinding halt. Reference: https://bugs.launchpad.net/bugs/722185 Cc: <stable@kernel.org> Acked-by: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: Jason Conti <jason.conti@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-04-08ath9k: fix missing ath9k_ps_wakeup/ath9k_ps_restore callsFelix Fietkau
These missing chip wakeups mainly cause crashes on AR5416 cards in MIPS boards, but have also been reported to cause radio stability issues on AR9285. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Cc: stable@kernel.org Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-04-08Merge branch 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: [S390] compile fix for latest binutils [S390] cio: prevent purging of CCW devices in the online state [S390] qdio: fix init sequence [S390] Fix parameter passing for smp_switch_to_cpu() [S390] oprofile s390: prevent stack corruption
2011-04-07mlx4_en: Restoring RX buffer pointer in case of failureYevgeny Petrilin
If not done, second attempt to open the RX ring would cause memory corruption. Signed-off-by: Yevgeny Petrilin <yevgenyp@mellanox.co.il> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-07mlx4: Sensing link type at device initializationYevgeny Petrilin
When bringing the port up, performing a SENSE_PORT command To try and check to which physical link type (IB or Ethernet) the physical port is connected. In case there is no valid link partner, the port will come up as its supported default. Signed-off-by: Yevgeny Petrilin <yevgenyp@mellanox.co.il> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-07net: atl*: convert to hw_featuresMichał Mirosław
Things left as they were: - atl1: is RX checksum really enabled? - atl2: copy-paste from atl1, with-errors-on-modify I presume - atl1c: there's a bug: MTU can't be changed if device is not up Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-07net: tg3: convert to hw_featuresMichał Mirosław
Cleanup hint: Some features are calculated in tg3_get_invariants() and the rest in its caller --- tg3_init_one(). This is not changed here. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Acked-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-07net: enic: convert to hw_featuresMichał Mirosław
As the driver uses GRO and not LRO, LRO settings are ignored anyway and are removed here to avoid confusion. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-07net: benet: convert to hw_featuresMichał Mirosław
Simple conversion. This also fixes a bug in TX checksum toggling --- driver was changing NETIF_F_HW_CSUM instead of NETIF_F_IP_CSUM+NETIF_F_IPV6_CSUM. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-07skge: convert to hw_featuresMichał Mirosław
just IP_CSUM. This needs testing and so is not changed here. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-07be2net: call FLR after setup wol in be_shutdownAjit Khaparde
Calling setup_wol after a reset is inconsequential. The WOL setting should be programmed before FLR. And yes, FLR does not erase wol information. Signed-off-by: Ajit Khaparde <ajit.khaparde@emulex.com> Signed-off-by: David S. Miller <davem@davemloft.net>
