Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Cc: "Darrick J. Wong" <djwong@us.ibm.com>
Add temperature sensor support for MacBook Air 2.
Signed-off-by: Henrik Rydberg <rydberg@euromail.se>
Cc: Nicolas Boichat <nicolas@boichat.ch>
of_node_put is needed before discarding a value received from
of_find_node_by_name, eg in error handling code or when the device node is
no longer used.
The semantic match that catches the bug is as follows:
(http://www.emn.fr/x-info/coccinelle/)
// <smpl>
@r exists@
local idexpression struct device_node *n;
position p1, p2;
struct device_node *n1;
statement S;
identifier f;
expression E;
expression *ptr != NULL;
n@p1 = of_find_node_by_name(...)
if (!n) S
... when != of_node_put(n)
when != n1 = f(n,...)
when != E = n
when any
when strict
return \(0\|<+...n...+>\|ptr\);
return@p2 ...;
of_node_put(n);
n1 = f(n,...)
E = n
@script:python@
p1 << r.p1;
p2 << r.p2;
print "* file: %s of_find_node_by_name %s return %s" % (p1[0].file,p1[0].line,p2[0].line)
// </smpl>
Signed-off-by: Nicolas Palix <npalix@diku.dk>
Acked-by: Stephen Rothwell <sfr@canb.auug.org.au>
It turns out that the adt7470's automatic fan control algorithm only works
when the temperature sensors get updated. This in turn happens only when
someone tells the chip to read its temperature sensors. Regrettably, this
means that we have to drive the chip periodically.
Signed-off-by: Darrick J. Wong <djwong@us.ibm.com>
Cc: Jean Delvare <khali@linux-fr.org>
The adt7470 driver currently assumes that 1s is the proper time to wait to
read all temperature sensors. However, the correct time is 200ms *
number_of_sensors. This patch sets the default time to provide for 10
sensors and then lowers it based on the number of sensor inputs that have
nozero values.
In the small window that it takes to read the temperature sensors, the pwm
outputs momentarily drop to 0. This causes a noticeable hiccup in fan
speed, which is slightly annoying. The solution is to manually program
the pwm output with whatever the automatic value is and then shift the
fans to manual control while reading temperatures. Once that is done, put
the fans back to whatever mode of control was there before.
Modify some hwmon drivers to use DIV_ROUND_CLOSEST instead of bloating
source with (naughty) macros.
Eliminate sysrq terse help mode; make sysrq help messages more meaningful
(more explicit/verbose). Make the sysrq action letter clearer by listing
it explicitly in more sysrq help messages (when it is not simple/clear).
The SysRq help message now looks like this:
SysRq : HELP : loglevel(0-9) reBoot terminate-all-tasks(E) memory-full-oom-kill(F) kill-all-tasks(I) saK show-backtrace-all-active-cpus(L) show-memory-usage(M) nice-all-RT-tasks(N) powerOff show-registers(P) show-all-timers(Q) unRaw Sync show-task-states(T) Unmount show-blocked-tasks(W)
Addresses http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=330403.
Cc: <jidanni@jidanni.org>
Cc: <330403@bugs.debian.org>
While looking at reducing the amount of architecture namespace pollution
in the generic kernel, I found that asm/irq.h is included in the vast
majority of compilations on ARM (around 650 files.)
Since asm/irq.h includes a sub-architecture include file on ARM, this
causes a negative impact on the ccache's ability to re-use the build
results from other sub-architectures, so we have a desire to reduce the
dependencies on asm/irq.h.
It turns out that a major cause of this is the needless include of
linux/hardirq.h into asm-generic/local.h. The patch below removes this
include, resulting in some 250 to 300 files (around half) of the kernel
then omitting asm/irq.h.
My test builds still succeed, provided two ARM files are fixed
(arch/arm/kernel/traps.c and arch/arm/mm/fault.c) - so there may be
negative impacts for this on other architectures.
Note that x86 does not include asm/irq.h nor linux/hardirq.h in its
asm/local.h, so this patch can be viewed as bringing the generic version
into line with the x86 version.
[kosaki.motohiro@jp.fujitsu.com: add #include <linux/irqflags.h> to acpi/processor_idle.c]
[adobriyan@gmail.com: fix sparc64]
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Modify ioc4 to always load the sgiioc4 IDE module if the board carrying
the IOC4 hardware actually implements the IDE interface (not all boards
bring this functionality off the IOC4 chip). A drive hosted on the IDE
interface may contain the root filesystem, and sgiioc4 doesn't load
automatically as ioc4 owns the PCI device ID, not sgiioc4.
Signed-off-by: Michael Reed <mdr@sgi.com>
Signed-off-by: Brent Casavant <bcasavan@sgi.com>
Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
f_op->poll is the only vfs operation which is not allowed to sleep. It's
because poll and select implementation used task state to synchronize
against wake ups, which doesn't have to be the case anymore as wait/wake
interface can now use custom wake up functions. The non-sleep restriction
can be a bit tricky because ->poll is not called from an atomic context
and the result of accidentally sleeping in ->poll only shows up as
temporary busy looping when the timing is right or rather wrong.
This patch converts poll/select to use custom wake up function and use
separate triggered variable to synchronize against wake up events. The
only added overhead is an extra function call during wake up and
negligible.
This patch removes the one non-sleep exception from vfs locking rules and
is beneficial to userland filesystem implementations like FUSE, 9p or
peculiar fs like spufs as it's very difficult for those to implement
non-sleeping poll method.
While at it, make the following cosmetic changes to make poll.h and
select.c checkpatch friendly.
* s/type * symbol/type *symbol/ : three places in poll.h
* remove blank line before EXPORT_SYMBOL() : two places in select.c
Oleg: spotted missing barrier in poll_schedule_timeout()
Davide: spotted missing write barrier in pollwake()
Cc: Eric Van Hensbergen <ericvh@gmail.com>
Cc: Ron Minnich <rminnich@sandia.gov>
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Cc: Davide Libenzi <davidel@xmailserver.org>
Cc: Brad Boyer <flar@allandria.com>
Cc: Roland McGrath <roland@redhat.com>
Cc: Mauro Carvalho Chehab <mchehab@infradead.org>
Several subsystem open handlers dereference the fops_get() return value
without checking it for nullness. This opens a race condition between the
open handler and module unloading.
A module can be marked as being unloaded (MODULE_STATE_GOING) before its
exit function is called and gets the chance to unregister the driver.
During that window open handlers can still be called, and fops_get() will
fail in try_module_get() and return a NULL pointer.
This change checks the fops_get() return value and returns -ENODEV if NULL.
Reported-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk>
Signed-off-by: Laurent Pinchart <laurent.pinchart@skynet.be>
Acked-by: Takashi Iwai <tiwai@suse.de>
Cc: Dave Airlie <airlied@linux.ie>
Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Use the newly introduced pci_ioremap_bar() function in drivers/misc.
pci_ioremap_bar() just takes a pci device and a bar number, with the goal
of making it really hard to get wrong, while also having a central place
to stick sanity checks.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Sparse output following warnings.
mm/vmalloc.c:1436:6: warning: symbol 'vread' was not declared. Should it be static?
mm/vmalloc.c:1474:6: warning: symbol 'vwrite' was not declared. Should it be static?
However, it is used by /dev/kmem. fixed here.
Show node to memory section relationship with symlinks in sysfs
Add /sys/devices/system/node/nodeX/memoryY symlinks for all
the memory sections located on nodeX. For example:
/sys/devices/system/node/node1/memory135 -> ../../memory/memory135
indicates that memory section 135 resides on node1.
Also revises documentation to cover this change as well as updating
Documentation/ABI/testing/sysfs-devices-memory to include descriptions
of memory hotremove files 'phys_device', 'phys_index', and 'state'
that were previously not described there.
In addition to it always being a good policy to provide users with
the maximum possible amount of physical location information for
resources that can be hot-added and/or hot-removed, the following
are some (but likely not all) of the user benefits provided by
this change.
Immediate:
- Provides information needed to determine the specific node
on which a defective DIMM is located. This will reduce system
downtime when the node or defective DIMM is swapped out.
- Prevents unintended onlining of a memory section that was
previously offlined due to a defective DIMM. This could happen
during node hot-add when the user or node hot-add assist script
onlines _all_ offlined sections due to user or script inability
to identify the specific memory sections located on the hot-added
node. The consequences of reintroducing the defective memory
could be ugly.
- Provides information needed to vary the amount and distribution
of memory on specific nodes for testing or debugging purposes.
Future:
- Will provide information needed to identify the memory
sections that need to be offlined prior to physical removal
of a specific node.
Symlink creation during boot was tested on 2-node x86_64, 2-node
ppc64, and 2-node ia64 systems. Symlink creation during physical
memory hot-add tested on a 2-node x86_64 system.
Signed-off-by: Gary Hade <garyhade@us.ibm.com>
Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-2.6-dm:
dm snapshot: extend exception store functions
dm snapshot: split out exception store implementations
dm snapshot: rename struct exception_store
dm snapshot: separate out exception store interface
dm mpath: move trigger_event to system workqueue
dm: add name and uuid to sysfs
dm table: rework reference counting
dm: support barriers on simple devices
dm request: extend target interface
dm request: add caches
dm ioctl: allow dm_copy_name_and_uuid to return only one field
dm log: ensure log bitmap fits on log device
dm log: move region_size validation
dm log: avoid reinitialising io_req on every operation
dm: consolidate target deregistration error handling
dm raid1: fix error count
dm log: fix dm_io_client leak on error paths
dm snapshot: change yield to msleep
dm table: drop reference at unbind
Supply dm_add_exception as a callback to the read_metadata function.
Add a status function ready for a later patch and name the functions
consistently.
Signed-off-by: Jonathan Brassow <jbrassow@redhat.com>
Signed-off-by: Alasdair G Kergon <agk@redhat.com>
Move the existing snapshot exception store implementations out into
separate files. Later patches will place these behind a new
interface in preparation for alternative implementations.
Rename struct exception_store to dm_exception_store.
Pull structures that bridge the gap between snapshot and
exception store out of dm-snap.h and put them in a new
.h file - dm-exception-store.h. This file will define the
API for new exception stores.
Ultimately, dm-snap.h is unnecessary, since only dm-snap.c
should be using it.
The same workqueue is used both for sending uevents and processing queued I/O.
Deadlock has been reported in RHEL5 when sending a uevent was blocked waiting
for the queued I/O to be processed. Use scheduled_work() for the asynchronous
uevents instead.
Implement simple read-only sysfs entry for device-mapper block device.
This patch adds a simple sysfs directory named "dm" under block device
properties and implements
- name attribute (string containing mapped device name)
- uuid attribute (string containing UUID, or empty string if not set)
The kobject is embedded in mapped_device struct, so no additional
memory allocation is needed for initializing sysfs entry.
During the processing of sysfs attribute we need to lock mapped device
which is done by a new function dm_get_from_kobj, which returns the md
associated with kobject and increases the usage count.
Each 'show attribute' function is responsible for its own locking.
Signed-off-by: Milan Broz <mbroz@redhat.com>
Rework table reference counting.
The existing code uses a reference counter. When the last reference is
dropped and the counter reaches zero, the table destructor is called.
Table reference counters are acquired/released from upcalls from other
kernel code (dm_any_congested, dm_merge_bvec, dm_unplug_all).
If the reference counter reaches zero in one of the upcalls, the table
destructor is called from almost random kernel code.
This leads to various problems:
* dm_any_congested being called under a spinlock, which calls the
destructor, which calls some sleeping function.
* the destructor attempting to take a lock that is already taken by the
same process.
* stale reference from some other kernel code keeps the table
constructed, which keeps some devices open, even after successful
return from "dmsetup remove". This can confuse lvm and prevent closing
of underlying devices or reusing device minor numbers.
The patch changes reference counting so that the table destructor can be
called only at predetermined places.
The table has always exactly one reference from either mapped_device->map
or hash_cell->new_map. After this patch, this reference is not counted
in table->holders. A pair of dm_create_table/dm_destroy_table functions
is used for table creation/destruction.
Temporary references from the other code increase table->holders. A pair
of dm_table_get/dm_table_put functions is used to manipulate it.
When the table is about to be destroyed, we wait for table->holders to
reach 0. Then, we call the table destructor. We use active waiting with
msleep(1), because the situation happens rarely (to one user in 5 years)
and removing the device isn't performance-critical task: the user doesn't
care if it takes one tick more or not.
This way, the destructor is called only at specific points
(dm_table_destroy function) and the above problems associated with lazy
destruction can't happen.
Finally remove the temporary protection added to dm_any_congested().
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Implement barrier support for single device DM devices
This patch implements barrier support in DM for the common case of dm linear
just remapping a single underlying device. In this case we can safely
pass the barrier through because there can be no reordering between
devices.
NB. Any DM device might cease to support barriers if it gets
reconfigured so code must continue to allow for a possible
-EOPNOTSUPP on every barrier bio submitted. - agk
Signed-off-by: Andi Kleen <ak@suse.de>
This patch prepares some kmem_caches for request-based dm.
Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com>
Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com>
Allow NULL buffer in dm_copy_name_and_uuid if you only want to return one of
the fields.
(Required by a following patch that adds these fields to sysfs.)
Reviewed-by: Alasdair G Kergon <agk@redhat.com>
Check that the log bitmap will fit within the log device.
Move log size validation from mirror target to log constructor.
Removed PAGE_SIZE restriction we no longer think necessary.
rw_header function updates three members of io_req data every time
when I/O is processed. bi_rw and notify.fn are never modified once
they get initialized, and so they can be set in advance.
header_to_disk() can also be pulled out of write_header() since only one
caller needs it and write_header() can be replaced by rw_header()
directly.
Signed-off-by: Takahiro Yasui <tyasui@redhat.com>
Change dm_unregister_target to return void and use BUG() for error
reporting.
dm_unregister_target can only fail because of programming bug in the
target driver. It can't fail because of user's behavior or disk errors.
This patch changes unregister_target to return void and use BUG if
someone tries to unregister non-registered target or unregister target
that is in use.
This patch removes code duplication (testing of error codes in all dm
targets) and reports bugs in just one place, in dm_unregister_target. In
some target drivers, these return codes were ignored, which could lead
to a situation where bugs could be missed.
Always increase the error count when I/O on a leg of a mirror fails.
The error count is used to decide whether to select an alternative
mirror leg. If the target doesn't use the "handle_errors" feature, the
error count is not updated and the bio can get requeued forever by the
read callback.
Fix it by increasing error_count before the handle_errors feature
checking.
Cc: stable@kernel.org
In create_log_context function, dm_io_client_destroy function needs
to be called, when memory allocation of disk_header, sync_bits and
recovering_bits failed, but dm_io_client_destroy is not called.
Acked-by: Jonathan Brassow <jbrassow@redhat.com>
Change yield() to msleep(1). If the thread had realtime priority,
yield() doesn't really yield, so the yielding process would loop
indefinitely and cause machine lockup.
Move one dm_table_put() so that the last reference in the thread
gets dropped in __unbind().
This is required for a following patch,
dm-table-rework-reference-counting.patch, which will change the logic in
such a way that table destructor is called only at specific points in
the code.
* 'for-next' of git://git.o-hand.com/linux-mfd: (30 commits)
mfd: Fix section mismatch in da903x
mfd: move drivers/i2c/chips/menelaus.c to drivers/mfd
mfd: move drivers/i2c/chips/tps65010.c to drivers/mfd
mfd: dm355evm msp430 driver
mfd: Add missing break from wm3850-core
mfd: Add WM8351 support
mfd: Support configurable numbers of DCDCs and ISINKs on WM8350
mfd: Handle missing WM8350 platform data
mfd: Add WM8352 support
mfd: Use irq_to_desc in twl4030 code
power_supply: Add Dialog DA9030 battery charger driver
mfd: Dialog DA9030 battery charger MFD driver
mfd: Register WM8400 codec device
mfd: Pass driver_data onto child devices
mfd: Fix twl4030-core.c build error
mfd: twl4030 regulator bug fixes
mfd: twl4030: create some regulator devices
mfd: twl4030: cleanup symbols and OMAP dependency
mfd: twl4030: simplified child creation code
power_supply: Add battery health reporting for WM8350
* 'i2c-next' of git://aeryn.fluff.org.uk/bjdooks/linux:
i2c-omap: fix type of irq handler function
i2c-s3c2410: Change IRQ to be plain integer.
i2c-s3c2410: Allow more than one i2c-s3c2410 adapter
i2c-s3c2410: Remove default platform data.
i2c-s3c2410: Use platform data for gpio configuration
i2c-s3c2410: Fixup style problems from checkpatch.pl
i2c-omap: Enable I2C wakeups for 34xx
i2c-omap: reprogram OCP_SYSCONFIG register after reset
i2c-omap: convert 'rev1' flag to generic 'rev' u8
i2c-omap: fix I2C timeouts due to recursive omap_i2c_{un,}idle()
i2c-omap: Clean-up i2c-omap
i2c-omap: Don't compile in OMAP15xx I2C ISR for non-OMAP15xx builds
i2c-omap: Mark init-only functions as __init
i2c-omap: Add support for omap34xx
i2c-omap: FIFO handling support and broken hw workaround for i2c-omap
i2c-omap: Add high-speed support to omap-i2c
i2c-omap: Close suspected race between omap_i2c_idle() and omap_i2c_isr()
i2c-omap: Do not use interruptible wait call in omap_i2c_xfer_msg
Fix up apparently-trivial conflict in drivers/i2c/busses/i2c-s3c2410.c
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (22 commits)
HID: fix error condition propagation in hid-sony driver
HID: fix reference count leak hidraw
HID: add proper support for pensketch 12x9 tablet
HID: don't allow DealExtreme usb-radio be handled by usb hid driver
HID: fix default Kconfig setting for TopSpeed driver
HID: driver for TopSeed Cyberlink quirky remote
HID: make boot protocol drivers depend on EMBEDDED
HID: avoid sparse warning in HID_COMPAT_LOAD_DRIVER
HID: hiddev cleanup -- handle all error conditions properly
HID: force feedback driver for GreenAsia 0x12 PID
HID: switch specialized drivers from "default y" to !EMBEDDED
HID: set proper dev.parent in hidraw
HID: add dynids facility
HID: use GFP_KERNEL in hid_alloc_buffers
HID: usbhid, use usb_endpoint_xfer_int
HID: move usbhid flags to usbhid.h
HID: add n-trig digitizer support
HID: add phys and name ioctls to hidraw
HID: struct device - replace bus_id with dev_name(), dev_set_name()
HID: automatically call usbhid_set_leds in usbhid driver
When using "min()", the types of both sides should match. With the cpu
mask changes, the type of num_online_cpus() will now depend on config
options. Use "min_t()" with an explicit type instead.
And make the rx/tx case look the same too, just for sanity.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (44 commits)
qlge: Fix sparse warnings for tx ring indexes.
qlge: Fix sparse warning regarding rx buffer queues.
qlge: Fix sparse endian warning in ql_hw_csum_setup().
qlge: Fix sparse endian warning for inbound packet control block flags.
qlge: Fix sparse warnings for byte swapping in qlge_ethool.c
myri10ge: print MAC and serial number on probe failure
pkt_sched: cls_u32: Fix locking in u32_change()
iucv: fix cpu hotplug
af_iucv: Free iucv path/socket in path_pending callback
af_iucv: avoid left over IUCV connections from failing connects
af_iucv: New error return codes for connect()
net/ehea: bitops work on unsigned longs
Revert "net: Fix for initial link state in 2.6.28"
tcp: Kill extraneous SPLICE_F_NONBLOCK checks.
tcp: don't mask EOF and socket errors on nonblocking splice receive
dccp: Integrate the TFRC library with DCCP
dccp: Clean up ccid.c after integration of CCID plugins
dccp: Lockless integration of CCID congestion-control plugins
qeth: get rid of extra argument after printk to dev_* conversion
qeth: No large send using EDDP for HiperSockets.
git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/davej/cpufreq:
[CPUFREQ] Fix on resume, now preserves user policy min/max.
[CPUFREQ] Add Celeron Core support to p4-clockmod.
[CPUFREQ] add to speedstep-lib additional fsb values for core processors
[CPUFREQ] Disable sysfs ui for p4-clockmod.
[CPUFREQ] p4-clockmod: reduce noise
[CPUFREQ] clean up speedstep-centrino and reduce cpumask_t usage
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6:
inotify: fix type errors in interfaces
fix breakage in reiserfs_new_inode()
fix the treatment of jfs special inodes
vfs: remove duplicate code in get_fs_type()
add a vfs_fsync helper
sys_execve and sys_uselib do not call into fsnotify
zero i_uid/i_gid on inode allocation
inode->i_op is never NULL
ntfs: don't NULL i_op
isofs check for NULL ->i_op in root directory is dead code
affs: do not zero ->i_op
kill suid bit only for regular files
vfs: lseek(fd, 0, SEEK_CUR) race condition
Signed-off-by: Alan Cox <alan@redhat.com>
Warnings:
drivers/net/qlge/qlge_main.c:1474:34: warning: restricted degrades to integer
drivers/net/qlge/qlge_main.c:1475:36: warning: restricted degrades to integer
drivers/net/qlge/qlge_main.c:1592:51: warning: restricted degrades to integer
drivers/net/qlge/qlge_main.c:1941:20: warning: incorrect type in assignment (different base types)
drivers/net/qlge/qlge_main.c:1941:20: expected restricted unsigned int [usertype] tid
drivers/net/qlge/qlge_main.c:1941:20: got int [signed] index
drivers/net/qlge/qlge_main.c:1945:24: warning: incorrect type in assignment (different base types)
drivers/net/qlge/qlge_main.c:1945:24: expected restricted unsigned int [usertype] txq_idx
drivers/net/qlge/qlge_main.c:1945:24: got unsigned int [unsigned] [usertype] tx_ring_idx
Signed-off-by: Ron Mercer <ron.mercer@qlogic.com>
Warnings:
drivers/net/qlge/qlge_main.c:909:17: warning: incorrect type in assignment (different base types)
drivers/net/qlge/qlge_main.c:909:17: expected unsigned int [unsigned] [usertype] addr_lo
drivers/net/qlge/qlge_main.c:909:17: got restricted unsigned int [usertype] <noident>
drivers/net/qlge/qlge_main.c:911:17: warning: incorrect type in assignment (different base types)
drivers/net/qlge/qlge_main.c:911:17: expected unsigned int [unsigned] [usertype] addr_hi
drivers/net/qlge/qlge_main.c:911:17: got restricted unsigned int [usertype] <noident>
drivers/net/qlge/qlge_main.c:974:17: warning: incorrect type in assignment (different base types)
drivers/net/qlge/qlge_main.c:974:17: expected unsigned int [unsigned] [usertype] addr_lo
drivers/net/qlge/qlge_main.c:974:17: got restricted unsigned int [usertype] <noident>
drivers/net/qlge/qlge_main.c:975:17: warning: incorrect type in assignment (different base types)
drivers/net/qlge/qlge_main.c:975:17: expected unsigned int [unsigned] [usertype] addr_hi
drivers/net/qlge/qlge_main.c:975:17: got restricted unsigned int [usertype] <noident>
drivers/net/qlge/qlge_main.c:2132:16: warning: incorrect type in assignment (different base types)
drivers/net/qlge/qlge_main.c:2132:16: expected unsigned int [unsigned] [usertype] addr_lo
drivers/net/qlge/qlge_main.c:2132:16: got restricted unsigned int [usertype] <noident>
drivers/net/qlge/qlge_main.c:2133:16: warning: incorrect type in assignment (different base types)
drivers/net/qlge/qlge_main.c:2133:16: expected unsigned int [unsigned] [usertype] addr_hi
drivers/net/qlge/qlge_main.c:2133:16: got restricted unsigned int [usertype] <noident>
drivers/net/qlge/qlge_main.c:2212:15: warning: incorrect type in assignment (different base types)
drivers/net/qlge/qlge_main.c:2212:15: expected unsigned int [unsigned] [usertype] addr_lo
drivers/net/qlge/qlge_main.c:2212:15: got restricted unsigned int [usertype] <noident>
drivers/net/qlge/qlge_main.c:2214:15: warning: incorrect type in assignment (different base types)
drivers/net/qlge/qlge_main.c:2214:15: expected unsigned int [unsigned] [usertype] addr_hi
drivers/net/qlge/qlge_main.c:2214:15: got restricted unsigned int [usertype] <noident>
Changed u16 to __sum16 usage.
Warnings:
drivers/net/qlge/qlge_main.c:1897:9: warning: incorrect type in assignment (different base types)
drivers/net/qlge/qlge_main.c:1897:9: expected unsigned short [usertype] *check
drivers/net/qlge/qlge_main.c:1897:9: got restricted unsigned short *<noident>
drivers/net/qlge/qlge_main.c:1903:9: warning: incorrect type in assignment (different base types)
drivers/net/qlge/qlge_main.c:1903:9: expected unsigned short [usertype] *check
drivers/net/qlge/qlge_main.c:1903:9: got restricted unsigned short *<noident>
drivers/net/qlge/qlge_main.c:1909:9: warning: incorrect type in assignment (different base types)
drivers/net/qlge/qlge_main.c:1909:9: expected unsigned short [unsigned] [short] [usertype] <noident>
Changed flags element from __le32 to 3 reserved bytes and one byte of
flags. Changed flags bit definitions to reflect byte width instead of
__le32 width.
Warnings:
drivers/net/qlge/qlge_main.c:1206:16: warning: restricted degrades to integer
drivers/net/qlge/qlge_main.c:1207:16: warning: restricted degrades to integer
drivers/net/qlge/qlge_main.c:1233:17: warning: restricted degrades to integer
drivers/net/qlge/qlge_main.c:1276:17: warning: restricted degrades to integer
drivers/net/qlge/qlge_main.c:1349:19: warning: restricted degrades to integer
drivers/net/qlge/qlge_ethtool.c:59:23: warning: cast to restricted type
drivers/net/qlge/qlge_ethtool.c:59:21: warning: incorrect type in assignment (different base types)
drivers/net/qlge/qlge_ethtool.c:59:21: expected restricted unsigned short [usertype] irq_delay
drivers/net/qlge/qlge_ethtool.c:59:21: got unsigned short [unsigned] [usertype] <noident>
drivers/net/qlge/qlge_ethtool.c:61:8: warning: cast to restricted type
drivers/net/qlge/qlge_ethtool.c:60:21: warning: incorrect type in assignment (different base types)
drivers/net/qlge/qlge_ethtool.c:60:21: expected restricted unsigned short [usertype] pkt_delay
drivers/net/qlge/qlge_ethtool.c:60:21: got unsigned short [unsigned] [usertype] <noident>
drivers/net/qlge/qlge_ethtool.c:82:23: warning: cast to restricted type
drivers/net/qlge/qlge_ethtool.c:82:21: warning: incorrect type in assignment (different base types)
drivers/net/qlge/qlge_ethtool.c:82:21: expected restricted unsigned short [usertype] irq_delay
drivers/net/qlge/qlge_ethtool.c:82:21: got unsigned short [unsigned] [usertype] <noident>
drivers/net/qlge/qlge_ethtool.c:84:8: warning: cast to restricted type
drivers/net/qlge/qlge_ethtool.c:83:21: warning: incorrect type in assignment (different base types)
drivers/net/qlge/qlge_ethtool.c:83:21: expected restricted unsigned short [usertype] pkt_delay
drivers/net/qlge/qlge_ethtool.c:83:21: got unsigned short [unsigned] [usertype] <noident>
To help board identification and diagnosis, print the MAC
and serial number on probe failure if they are available.
Signed-off-by: Brice Goglin <brice@myri.com>
The flags field of struct ehea_port is only used with test_bit(),
clear_bit() and set_bit() and these interfaces only work on
"unsigned long"s, so change the field to be an "unsigned long". Also,
this field only has two bits defined for it (0 and 1) so will still be
fine if someone builds this driver for a 32 bit arch (at least as far as
this flags field is concerned).
Also note that ehea_driver_flags is only used in ehca_main.c, so make it
static in there.
Fsync currently has a fdatawrite/fdatawait pair around the method call,
and a mutex_lock/unlock of the inode mutex. All callers of fsync have
to duplicate this, but we have a few and most of them don't quite get
it right. This patch adds a new vfs_fsync that takes care of this.
It's a little more complicated as usual as ->fsync might get a NULL file
pointer and just a dentry from nfsd, but otherwise gets afile and we
want to take the mapping and file operations from it when it is there.
Notes on the fsync callers:
- ecryptfs wasn't calling filemap_fdatawrite / filemap_fdatawait on the
lower file
- coda wasn't calling filemap_fdatawrite / filemap_fdatawait on the host
file, and returning 0 when ->fsync was missing
- shm wasn't calling either filemap_fdatawrite / filemap_fdatawait nor
taking i_mutex. Now given that shared memory doesn't have disk
backing not doing anything in fsync seems fine and I left it out of
the vfs_fsync conversion for now, but in that case we might just
not pass it through to the lower file at all but just call the no-op
simple_sync_file directly.
[and now actually export vfs_fsync]
