If the chip isn't recognized, then the correct errors should be returned.
The v4l2_i2c_attach() utility function will return 0 for all errors
except -ENOMEM to provide proper compatibility support for the old I2C
probing function.
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Two new headers were added: one for I2C drivers that are only used
by V4L2 drivers converted to the new bus-based I2C API, and one that
can be used by both converted and unconverted drivers (at the expense of
some additional overhead).
To support the legacy I2C API a helper function was added to v4l2-common.c.
These headers take care of all the 'boilerplate' code that all V4L2 I2C drivers
have in common and will automatically support the bus-based I2C API introduced
in kernel 2.6.22.
This module was always GPL, and will remain GPL
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
Call analog_demod_ops->i2c_gate_ctrl when in analog tuning mode, and
frontend_ops.i2c_gate_ctrl when in digital tuning mode.
In some designs, the tuner silicon may be on an i2c bus behind an i2c gate,
controlled by the analog demodulator. We already have a method to control
such i2c gates when they are controlled by the digital demodulator, but in
some hybrid designs, there may be an i2c gate controlled by each demodulator.
For example, when in analog tuning mode, one would access the tuner by opening
the i2c gate controlled by the analog demodulator, while when in digital
tuning mode, one would access the tuner by opening the i2c gate controlled by
the digital demodulator.
We must add this callback function to analog_tuner_ops in order to handle
such configurations.
Explain who is responsible for freeing analog_demod_priv
Convert all instances of "if ((ops) && (ops->foo))" to "if (ops && ops->foo)"
Reviewed-by: Hans Verkuil <hverkuil@xs4all.nl>
dvb_frontend interface
Convert tda9887 and tda8290/5 to dvb_frontend interface
thanks to checkpatch.pl
Clear analog_demod_ops on release.
Fix test for analog_demod_ops after tuner attach.
analog demod
Add basic support for NXP TDA8295 analog demod and TDA18271 tuner silicon.
TDA8295 + TDA8275a not yet tested.
TDA8290 + TDA18271 not yet supported.
Digital mode of TDA18271 not yet tested & needs more work.
EXPORT_SYMBOL should have been EXPORT_SYMBOL_GPL
tda827x module
Add analog tuning support to tda827x dvb_frontend tuner module.
Convert tda8290 module back to native tuner interface.
The tda8290 analog demodulator will be handled the same way as tda9887.
The tuner.ko module (tuner-core) will pass commands to tda8290 via the
tuner_operations interface. tda8290 will communicate with tda827x via
the dvb_frontend interface, while passing a pointer to a private data
structure.
This changeset converts tuner-xc2028 to the newer hybrid approach. It also
prevents creating twice the xc3028 private struct by both DVB and V4L parts.
Signed-off-by: Michel Ludwig <michel.ludwig@gmail.com>
Add support for Xceive XC2028/XC3028 tuner driver
Also replaces all occurrences of TUNER_XCEIVE_XC3028 to TUNER_XC2028.
Some work is still may be required to make sure that non-tm6000 drivers will
be capable of using tuner-xc2028.
V4L1 ioctls were replaced to V4L2 were applicable. The older ones
already implemented were removed.
Signed-off-by: Nickolay V. Shmyrev <nshmyrev@yandex.ru>
Also convert audio_mode_gpio functions from audio_hook
are unused
