Add support for the next generation of HP Smart Array SAS/SATA
controllers. Shipping date is late Fall 2008.
Bump the driver version to 3.6.20 to reflect the new hardware support from
patch 1 of this set.
Signed-off-by: Mike Miller <mike.miller@hp.com>
Cc: Jens Axboe <jens.axboe@oracle.com>
Cc: <stable@kernel.org>
Release ports which are requested during detection which are not freed if
there is no hga card. Otherwise there is a crash during cat /proc/ioports
command.
Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl>
Addresses https://bugs.edge.launchpad.net/ubuntu/+source/linux-source-2.6.22/+bug/178634
Signed-off-by: Amit Kucheria <amit.kucheria@ubuntu.com>
Signed-off-by: maximilian attems <max@stro.at>
Acked-by: Dave Airlie <airlied@linux.ie>
This patch fixes a compile failure in 2.6.26-rc5-git5.
The variable is expected to be called ofdev.
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6:
USB: don't use reset-resume if drivers don't support it
USB: isp1760: Assign resource fields before adding hcd
isight_firmware: Avoid crash on loading invalid firmware
USB: fix build bug in USB_ISIGHTFW
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6:
kobject: Documentation Spelling Patch
dev_set_name: fix missing kernel-doc
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (23 commits)
ACPICA: fix stray va_end() caused by mis-merge
ACPI: Reject below-freezing temperatures as invalid critical temperatures
ACPICA: Fix for access to deleted object <regression>
ACPICA: Fix to make _SST method optional
ACPICA: Fix for Load operator, load table at the namespace root
ACPICA: Ignore ACPI table signature for Load() operator
ACPICA: Fix to allow zero-length ASL field declarations
ACPI: use memory_read_from_buffer()
bay: exit if notify handler cannot be installed
dock.c remove trailing printk whitespace
proper prototype for acpi_processor_tstate_has_changed()
ACPI: handle invalid ACPI SLIT table
PNPACPI: use _CRS IRQ descriptor length for _SRS
pnpacpi: fix shareable IRQ encode/decode
pnpacpi: fix IRQ flag decoding
MAINTAINERS: update ACPI homepage
ACPI 2.6.26-rc2: Add missing newline to DSDT/SSDT warning message
ACPI: EC: Use msleep instead of udelay while waiting for event.
thinkpad-acpi: fix LED handling on older ThinkPads
thinkpad-acpi: fix initialization error paths
This patch tries to identify which devices are able to accept
reset-resume handling, by checking that there is at least one
interface driver bound and that all of the drivers have a reset_resume
method defined. If these conditions don't hold then during resume
processing, the device is logicall disconnected.
This is only a temporary fix. Later on we will explicitly unbind
drivers that can't handle reset-resumes.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Cc: Oliver Neukum <oliver@neukum.org>
Cc: Pavel Machek <pavel@suse.cz>
This fixes the bogus "io mem 0x00000000" message printed
during driver init due to hcd->rsrc_start being assigned after
the call to usb_add_hcd().
Signed-off-by: Nate Case <ncase@xes-inc.com>
Acked-by: Sebastian Siewior <bigeasy@linutronix.de>
Different tools generate slightly different formats of the isight
firmware. Ensure that the firmware buffer is not overrun, while still
ensuring that the correct amount of data is written if trailing data is
present.
Report-by: Justin Mattock <justinmattock@gmail.com>
Tested-by: Justin Mattock <justinmattock@gmail.com>
-tip tree testing found this build bug:
drivers/built-in.o: In function `isight_firmware_load':
isight_firmware.c:(.text+0x1ade08): undefined reference to `request_firmware'
isight_firmware.c:(.text+0x1adf9c): undefined reference to `release_firmware'
select FW_LOADER in USB_ISIGHTFW.
Fix kernel-doc for new dev_set_name() function:
Warning(lin2626-rc5//drivers/base/core.c:767): No description found for parameter 'fmt'
Signed-off-by: Len Brown <len.brown@intel.com>
My laptop thinks that it's a good idea to give -73C as the critical
CPU temperature.... which isn't the best thing since it causes a shutdown
right at bootup.
Temperatures below freezing are clearly invalid critical thresholds
so just reject these as such.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Acked-by: Zhang Rui <rui.zhang@intel.com>
Fixes problem introduced in 20080123, with fix for Unload operator.
Parse tree object can be already deleted; must use the opcode
within the WalkState.
ACPI: kmemcheck: Caught 16-bit read from freed memory
http://bugzilla.kernel.org/show_bug.cgi?id=10669
Signed-off-by: Lin Ming <ming.m.lin@intel.com>
Signed-off-by: Bob Moore <robert.moore@intel.com>
Fixes a problem introduced in 20080514 where the status of
execution of _SST is incorrectly returned to the caller. _SST
is optional, and if it is AE_NOT_FOUND, the exception should be
ignored.
http://www.acpica.org/bugzilla/show_bug.cgi?id=716
This reverts a change introduced in version 20071019. The table
is now loaded at the namespace root even though this goes against
the ACPI specification. This provides compatibility with other
ACPI implementations.
Only "SSDT" is acceptable to the ACPI spec, but tables are
seen with OEMx and null sigs. Therefore, signature validation
is worthless. Apparently MS ACPI accepts such signatures, ACPICA
must be compatible.
http://bugzilla.kernel.org/show_bug.cgi?id=10454
Allows null field list in Field(), BankField(), and IndexField().
2.6.26-rc1 regression: ACPI fails to load SDT. - Dell M1530
http://bugzilla.kernel.org/show_bug.cgi?id=10606
If acpi_install_notify_handler() for a bay device fails, the bay driver is
superfluous. Most likely, another driver (like libata) is already caring
about this device anyway. Furthermore,
register_hotplug_dock_device(acpi_handle) from the dock driver must not be
called twice with the same handler. This would result in an endless loop
consuming 100% of CPU. So clean up and exit.
Signed-off-by: Holger Macht <hmacht@suse.de>
Signed-off-by: Tim Pepper <lnxninja@linux.vnet.ibm.com>
This patch adds a proper prototype for acpi_processor_tstate_has_changed()
in include/acpi/processor.h
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Cc: Len Brown <lenb@kernel.org>
This is a SLIT sanity checking patch. It moves slit_valid() function to
generic ACPI code and does sanity checking for both x86 and ia64. It sets up
node_distance with LOCAL_DISTANCE and REMOTE_DISTANCE when hitting invalid
SLIT table on ia64. It also cleans up unused variable localities in
acpi_parse_slit() on x86.
Signed-off-by: Fenghua Yu <fenghua.yu@intel.com>
When configuring the resources of an ACPI device, we first evaluate _CRS
to get a template of resource descriptors, then fill in the specific
resource values we want, and finally evaluate _SRS to actually configure
the device.
Some resources have optional fields, so the size of encoded descriptors
varies depending on the specific values. For example, IRQ descriptors can
be either two or three bytes long. The third byte contains triggering
information and can be omitted if the IRQ is edge-triggered and active
high.
The BIOS often assumes that IRQ descriptors in the _SRS buffer use the
same format as those in the _CRS buffer, so this patch enforces that
constraint.
The "Start Dependent Function" descriptor also has an optional byte, but
we don't currently encode those descriptors, so I didn't do anything for
those.
I have tested this patch on a Toshiba Portege 4000. Without the patch,
parport_pc claims the parallel port only if I use "pnpacpi=off". This
patch makes it work with PNPACPI.
This is an extension of a patch by Tom Jaeger:
http://bugzilla.kernel.org/show_bug.cgi?id=9487#c42
References:
http://bugzilla.kernel.org/show_bug.cgi?id=5832 Enabling ACPI Plug and Play in kernels >2.6.9 kills Parallel support
http://bugzilla.kernel.org/show_bug.cgi?id=9487 buggy firmware expects four-byte IRQ resource descriptor (was: Serial port disappears after Suspend on Toshiba R25)
http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commitdiff;h=1d5b285da1893b90507b081664ac27f1a8a3dc5b related ACPICA fix
Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
When we encode IRQ resources, we should use the "shareable" flag we got
from _PRS rather than guessing based on the IRQ trigger mode.
This is based on a patch by Tom Jaeger:
http://bugzilla.kernel.org/show_bug.cgi?id=9487#c32
When decoding IRQ trigger mode and polarity, it is not enough to mask by
IORESOURCE_BITS because there are now additional bits defined. For
example, if IORESOURCE_IRQ_SHAREABLE was set, we failed to set *triggering
and *polarity at all.
I can't point to a failure that this patch fixes, but
bugs in this area have caused problems when resuming after
suspend, for example:
http://bugzilla.kernel.org/show_bug.cgi?id=6316
https://bugs.launchpad.net/ubuntu/+source/linux-source-2.6.22/+bug/152187
[rene.herman@keyaccess.nl: fix comment]
As of recently (probably 2.6.26-rc1) I've been getting the following mangling
in the kernel log:
[4294014.568167] ACPI: DSDT override uses original SSDTs unless "acpi_no_auto_ssdt"<6>CPU0: Intel(R) Pentium(R) Dual CPU E2160 @ 1.80GHz stepping 0d
This is due to a missing newline character in the first message. The following
patch against 2.6.26-rc2 fixes it. Please apply.
Signed-off-by: Alistair John Strachan <alistair@devzero.co.uk>
http://bugzilla.kernel.org/show_bug.cgi?id=10724
Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de>
The less tested codepaths for LED handling, used on ThinkPads 570, 600e/x,
770e, 770x, A21e, A2xm/p, T20-22, X20 and maybe a few others, would write
data to kernel memory it had no business touching, for leds number 3 and
above. If one is lucky, that illegal write would cause an OOPS, but
chances are it would silently corrupt a byte.
The problem was introduced in commit af116101, "ACPI: thinkpad-acpi: add
sysfs led class support to thinkpad leds (v3.2)".
Fix the bug by refactoring the entire code to be far more obvious on what
it wants to do. Also do some defensive "constification".
Issue reported by Karol Lewandowski <lmctlx@gmail.com> (he's an lucky guy
and got an OOPS instead of silent corruption :-) ).
Root cause of the OOPS identified by Adrian Bunk <bunk@kernel.org>.
Thanks, Adrian!
Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br>
Tested-by: Karol Lewandowski <lmctlx@gmail.com>
Rework some subdriver init and exit handlers, in order to fix some
initialization error paths that were missing, or broken.
Hitting those bugs should be extremely rare in the real world, but should
that happen, thinkpad-acpi would fail to dealocate some resources and a
reboot might well be needed to be able to load the driver again.
Rename SW_RADIO to SW_RFKILL_ALL in thinkpad-acpi code and docs, following
5adad0133907790c50283bf03271d920d6897043 "Input: rename SW_RADIO to
SW_RFKILL_ALL".
cpuidle and acpi driver interaction bug with the way cpuidle_register_driver()
is called. Due to this bug, there will be oops on
AC<->DC on some systems, where they support C-states in one DC and not in AC.
The current code does
ON BOOT:
Look at CST and other C-state info to see whether more than C1 is
supported. If it is, then acpi processor_idle does a
cpuidle_register_driver() call, which internally enables the device.
ON CST change notification (AC<->DC) and on suspend-resume:
acpi driver temporarily disables device, updates the device with
any new C-states, and reenables the device.
The problem is is on boot, there are no C2, C3 states supported and we skip
the register. Later on AC<->DC, we may get a CST notification and we try
to reevaluate CST and enabled the device, without actually registering it.
This causes breakage as we try to create /sys fs sub directory, without the
parent directory which is created at register time.
Thanks to Sanjeev for reporting the problem here.
http://bugzilla.kernel.org/show_bug.cgi?id=10394
Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
The Fixed_RTC event should be disabled when installing RTC handler.
Only when RTC alarm is set will it be enabled again. If it is not
disabled, maybe some machines will be powered on automatically after
the system is shutdown even when the RTC alarm is not set.
http://bugzilla.kernel.org/show_bug.cgi?id=10010
Signed-off-by: Zhao Yakui <yakui.zhao@intel.com>
Signed-off-by: Zhang Rui <rui.zhang@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/avi/kvm
* 'kvm-updates-2.6.26' of git://git.kernel.org/pub/scm/linux/kernel/git/avi/kvm:
KVM: MMU: Fix is_empty_shadow_page() check
KVM: MMU: Fix printk() format string
KVM: IOAPIC: only set remote_irr if interrupt was injected
KVM: MMU: reschedule during shadow teardown
KVM: VMX: Clear CR4.VMXE in hardware_disable
KVM: migrate PIT timer
KVM: ppc: Report bad GFNs
KVM: ppc: Use a read lock around MMU operations, and release it on error
KVM: ppc: Remove unmatched kunmap() call
KVM: ppc: add lwzx/stwz emulation
KVM: ppc: Remove duplicate function
KVM: s390: Fix race condition in kvm_s390_handle_wait
KVM: s390: Send program check on access error
KVM: s390: fix interrupt delivery
KVM: s390: handle machine checks when guest is running
KVM: s390: fix locking order problem in enable_sie
KVM: s390: use yield instead of schedule to implement diag 0x44
KVM: x86 emulator: fix hypercall return value on AMD
KVM: ia64: fix zero extending for mmio ld1/2/4 emulation in KVM
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (42 commits)
net: Fix routing tables with id > 255 for legacy software
sky2: Hold RTNL while calling dev_close()
s2io iomem annotations
atl1: fix suspend regression
qeth: start dev queue after tx drop error
qeth: Prepare-function to call s390dbf was wrong
qeth: reduce number of kernel messages
qeth: Use ccw_device_get_id().
qeth: layer 3 Oops in ip event handler
virtio: use callback on empty in virtio_net
virtio: virtio_net free transmit skbs in a timer
virtio: Fix typo in virtio_net_hdr comments
virtio_net: Fix skb->csum_start computation
ehea: set mac address fix
sfc: Recover from RX queue flush failure
add missing lance_* exports
ixgbe: fix typo
forcedeth: msi interrupts
ipsec: pfkey should ignore events when no listeners
pppoe: Unshare skb before anything else
Cc: Jeff Garzik <jeff@garzik.org>
Signed-off-by: Bryan Wu <cooloney@kernel.org>
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6
dev_close() must be called holding the RTNL.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
Using vendor magic to force the PHY into power save mode breaks
suspend. It isn't needed anyway, so remove it.
Tested-by: Avuton Olrich <avuton@gmail.com>
Signed-off-by: Jay Cliburn <jacliburn@bellsouth.net>
In case the xmit function drop out with an error, we have to wake
the netdevice queue to start another xmit.
Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com>
Prepare-function to call s390dbf was wrong handling variable arguments.
This worked as macro but not as function any more.
Now using va_list processing.
Signed-off-by: Peter Tiedemann <ptiedem@de.ibm.com>
Remove unnecessary messages. Write important debug information to
s390dbf.
Get the devno from the ccw device via ccw_device_get_id() instead
of parsing the bus_id.
Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com>
The ip event handler may present us non qeth network interfaces.
Add qeth card pointer check.
virtio_net uses a timer to free old transmitted packets, rather than
leaving callbacks enabled all the time. If the host promises to
always notify us when the transmit ring is empty, we can free packets
at that point and avoid the timer.
virtio_net currently only frees old transmit skbs just
before queueing new ones. If the queue is full, it then
enables interrupts and waits for notification that more
work has been performed.
However, a side-effect of this scheme is that there are
always xmit skbs left dangling when no new packets are
sent, against the Documentation/networking/driver.txt
guideline:
"... it is not allowed for your TX mitigation scheme
to let TX packets "hang out" in the TX ring unreclaimed
forever if no new TX packets are sent."
Add a timer to ensure that any time we queue new TX
skbs, we will shortly free them again.
This fixes an easily reproduced hang at shutdown where
iptables attempts to unload nf_conntrack and nf_conntrack
waits for an skb it is tracking to be freed, but virtio_net
never frees it.
Signed-off-by: Mark McLoughlin <markmc@redhat.com>
hdr->csum_start is the offset from the start of the ethernet
header to the transport layer checksum field. skb->csum_start
is the offset from skb->head.
skb_partial_csum_set() assumes that skb->data points to the
ethernet header - i.e. it computes skb->csum_start by adding
the headroom to hdr->csum_start.
Since eth_type_trans() skb_pull()s the ethernet header,
skb_partial_csum_set() should be called before
eth_type_trans().
(Without this patch, GSO packets from a guest to the world outside the
host are corrupted).
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
eHEA has to call firmware functions in order to change the mac address
of a logical port. This patch checks if the logical port is up
when calling the register / deregister mac address calls. If the port
is down these firmware calls would fail and are therefore not executed.
Signed-off-by: Jan-Bernd Themann <themann@de.ibm.com>
