Carry on pushing code out of tty_io when it belongs to other drivers. I'm
not 100% happy with some of this and it will be worth revisiting some of the
exports later when the restructuring work is done.
Signed-off-by: Alan Cox <alan@redhat.com>
Right now there are various drivers that try to use tty->count to know when
they get the final close. Aristeau Rozanski showed while debugging the vt
sysfs race that this isn't entirely safe.
Instead of driver side tricks to work around this introduce a shutdown which
is called when the tty is being destructed. This also means that the shutdown
method is tied into the refcounting.
Use this to rework the console close/sysfs logic.
Remove lots of special case code from the tty core code. The pty code can now
have a shutdown() method that replaces the special case hackery in the tree
free up paths.
For hysterical raisins the vt layer drops and retakes locks in the write
method. This is a left over from the days when user/kernel data was passed
directly to the tty not pre-buffered.
The open path for ptmx slaves is via the ptmx device. Opening them any
other way is not allowed. Vegard Nossum found that previously this was not
the case and mknod foo c 128 42; cat foo would produce nasty diagnostics
Currently it is sometimes locked by the tty mutex and sometimes by the
sighand lock. The latter is in fact correct and now we can hand back referenced
objects we can fix this up without problems around sleeping functions.
We now have the infrastructure to sort this out but rather than teaching
the syscall tty lock rules we move the hard work into a tty helper
Use tty_port_init and krefs in the stallion drivers to protect us from devices
going away underneath us. As with the other drives some rearranging is done to
pass the tty structure down properly on the user side.
Rather than blindly keep taking krefs we reorder the code in a few places
to pass the tty down to the right place (which is important as from the user
side it is not the case that tty == port->tty in all situations). For the irq
and related paths use the krefs to stop the tty being freed under us.
Use kref in the USB serial drivers so that we don't free tty structures
from under the URB receive handlers as has historically been the case if
you were unlucky. This also gives us a framework for general tty drivers to
use tty_port objects and refcount.
Contains two err->dev_err changes merged together to fix clashes in the
-next tree.
This is pure tty code so put it in the tty layer where it can be with the
locking relevant material it uses
We now return a kref covered tty reference. That ensures the tty structure
doesn't go away when you have a return from get_current_tty. This is not
enough to protect you from most of the resources being freed behind your
back - yet.
[Updated to include fixes for SELinux problems found by Andrew Morton and
an s390 leak found while debugging the former]
We always use the real tty one for stuff so the pty one should not be
compared. As we propagate window changes to both it doesn't currently
matter but will when we tidy up the pty termios logic a bit more
This moves us towards sanity and should mean our termios locking is now
complete and comprehensive.
We need a way to describe the various additional modes and flow control
features that random weird hardware shows up and software such as wine
wants to emulate as Windows supports them.
TCGETX/TCSETX and the termiox ioctl are a SYS5 extension that we might as
well adopt. This patches adds the structures and the basic ioctl interfaces
when the TCGETX etc defines are added for an architecture. Drivers wishing
to use this stuff need to add new methods.
This came in via another tree and unfortunately is rather broken on
the tty side. Comment the apparent locking problems for someone who knows
the driver to look at.
Fix the termios and other ioctl handling. The driver was calling the wrong
methods for what it wanted to do but the right ones existed so its a simple
fix up.
The tty layer keeps driver module counts that are used so the driver knows
when it can be unloaded. For obvious reasons we want to tie that to the
refcounting properly.
At this point the driver side itself isn't refcounted nicely but we can do
that later and kref the drivers.
Introduce a kref to the tty structure and use it to protect the tty->signal
tty references. For now we don't introduce it for anything else.
Not much in it yet but this will grow a lot
The two are basically independent chunks of code so lets split them up for
readability and sanity. It also makes the API boundaries much clearer.
Right now we have ifdefs and hooks in the core ioctl handler for TIOCLINUX
and then test if its a console. This is brain dead. Instead call the
tioclinux helper from the relevant driver ioctl methods.
This requires three changes:
1) Remove !SPARC restriction in Kconfig.
2) Move Sparc specific serial drivers before 8250, so that serial
console devices don't change names on us, even if 8250 finds
devices.
3) Since the Sparc specific serial drivers try to use the
same major/minor device namespace as 8250, some coordination
is necessary. Use the sunserial_*() layer routines to allocate
minor number space within TTY_MAJOR when CONFIG_SPARC.
This has no effect on other platforms.
Thanks to Josip Rodin for bringing up this issue and testing
plus debugging various revisions of this patch.
Remove some inlines from various functions that are called once, are too
big to inline, or are called only from slow path code. This saves around
300 bytes of code for me.
Signed-off-by: Will Newton <will.newton@gmail.com>
<rmk> talking about leaks - I noticed that the 'check return of
pci_enable_dev()' in the 8250 pci resume function finally made it in
despite my objections against it (causing stuff in higher levels to
leak).
Fixes #10783
This patch removes the private check for the termios_initialized for
the pl2303 usb driver. It forced the baud to 9600 on the first call
to pl2303_set_termios()
Based on the tty changes in the 2.6.27 kernel, the termios passed to
the *_set_termios functions is always populated the first time.
This means there is no need to privately initialize the settings the
first time, and doing so will not allow the use of the kernel
parameter "console=ttyUSB0,115200" as an example.
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
Nozomi assumes the close method isn't called if open errors. The tty layer
is different to other drives in this respect however. Pointed out by Denis J
Barrow.
Data read from a TTY can contain an embedded NUL byte (e.g. after
pressing Ctrl-2, or sent to a PTY). After the previous patch, the data
would be logged only up to the first NUL.
This patch modifies the AUDIT_TTY record to always use the hexadecimal
format, which does not terminate at the first NUL byte. The vast
majority of recorded TTY input data will contain either ' ' or '\n', so
the hexadecimal format would have been used anyway.
Signed-off-by: Miloslav Trmac <mitr@redhat.com>
add_timer() is not supposed to be called when the timer is pending.
ip2 driver attempts to avoid that condition by setting and resetting
a flag (TimerOn) in timer function. But there is some gap between
add_timer() and setting TimerOn.
This patch fix this problem by using mod_timer() and remove TimerOn
which has been unnecessary by this change.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Cleanup of module_init/exit:
- mostly whitespace
- remove empty functions
- replace c++ comments
- remove useless prints (module loaded, unloaded)
- mark the calls as __exit and __init
- use break; and return; to save some indent levels after it
- note resource leakage
It's still mess, but now it's readable.
- do not init .bss zeroed data to zero again (by memset or
explicit assignment)
- use char [] instead of char * for string constants
It's pretty useless to have one setup() function separated along with
module_init() which only calls a function from ip2main anyway. Get rid
of ip2base.
Remove also checks of always-true now.
board->base is increased for CF cards after mapping. Use board->base2
for unmapping the region, since it holds the original/correct address.
readl/writel are not expected to accept iomap return value. Replace
bogus mapping by standard ioremap.
For some reason the oti6858 driver undefines and redefines the dbg
macro. This makes it spew debugging messages at KERN_INFO instead of
KERN_DEBUG.
This patch removes the undef and define making the driver log like every
other USB serial driver.
Signed-off-by: Scott Ashcroft <scott.ashcroft@talk21.com>
interrupts in PIO mode
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
Signed-off-by: Bryan Wu <cooloney@kernel.org>
We now use the sir_dev/irtty_sir/uart/bfin_serial drivers framework
to monitor the TX status.
Signed-off-by: Graf Yang <graf.yang@analog.com>
Disable irq and return immediately.
the serial driver
move common variables out of serial headers and into the serial driver and
rename "nr_ports" to "nr_active_ports" so as to easily differentiate
between BFIN_UART_NR_PORTS (the # of available) and nr_ports (the # of enabled)
Signed-off-by: Mike Frysinger <vapier.adi@gmail.com>
This patch contains the scheduled removal of the obsolete
SERIAL_COLDFIRE driver.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
The call to put_tty_driver is out of place and is applied to the wrong
argument.
The function enclosing the patched code calls alloc_tty_driver and stores
the result in drv. Subsequently, there are two occurrences of error
handling code, one making a goto to put_tty and one making a goto to
stop_thread. At the point of the first one the assignment hvc_driver = drv
has not yet been executed, and from inspecting the rest of the file it
seems that hvc_driver would be NULL. Thus the current call to
put_tty_driver is useless, and one applied to drv is needed. The goto
stop_thread is in the error handling code for a call to
tty_register_driver, but the error cases in tty_register_driver do not free
its argument, so it should be done here. Thus, I have moved the put_tty
label after the stop_thread label, so that put_tty_driver is called in both
cases.
The semantic match that finds this problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
// <smpl>
@r exists@
local idexpression x;
expression E,f;
position p1,p2,p3;
identifier l;
statement S;
x = alloc_tty_driver@p1(...)
if (x == NULL) S
... when != E = x
when != put_tty_driver(x)
goto@p2 l;
... when != E = x
when != f(...,x,...)
when any
return \(0\|x\);
return@p3 ...;
@script:python@
p1 << r.p1;
p2 << r.p2;
p3 << r.p3;
print "%s: call on line %s not freed or saved before return on line %s via line %s" % (p1[0].file,p1[0].line,p3[0].line,p2[0].line)
// </smpl>
alloc_tty_driver is called at the beginning of the function containing the
lines of code shown in the patch. Thus, put_tty_driver is needed before
returning in the error handling code.
// <smpl>
@nr exists@
expression E,f;
position p1,p2,p3;
identifier l;
statement S;
if (x == NULL) S
... when != E = x
when != goto l;
return \(0\|x\);
return@p3 ...;
@script:python@
p1 << nr.p1;
p3 << nr.p3;
print "%s: call on line %s not freed or saved before return on line %s" % (p1[0].file,p1[0].line,p3[0].line)
// </smpl>
It needs the WM97xx touchscreen driver to be compiled in, not as a
module. And it cannot itself be a module, due to some unfortunate
interactions with platform data.
Reported-by: Herbert Xu <herbert@gondor.apana.org.au>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
