git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-dm
Pull device-mapper updates from Alasdair Kergon:
"Allow devices that hold metadata for the device-mapper thin
provisioning target to be extended easily; allow WRITE SAME on
multipath devices; an assortment of little fixes and clean-ups."
* tag 'dm-3.10-changes-2' of git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-dm: (21 commits)
dm cache: set config value
dm cache: move config fns
dm thin: generate event when metadata threshold passed
dm persistent metadata: add space map threshold callback
dm persistent data: add threshold callback to space map
dm thin: detect metadata device resizing
dm persistent data: support space map resizing
dm thin: open dev read only when possible
dm thin: refactor data dev resize
dm cache: replace memcpy with struct assignment
dm cache: fix typos in comments
dm cache policy: fix description of lookup fn
dm: document iterate_devices
dm persistent data: fix error message typos
dm cache: tune migration throttling
dm mpath: enable WRITE SAME support
dm table: fix write same support
dm bufio: avoid a possible __vmalloc deadlock
dm snapshot: fix error return code in snapshot_ctr
dm cache: fix error return code in cache_create
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid
Pull HID fixes from Jiri Kosina:
- fix usage of sleeping lock in atomic context from Jiri Kosina
- build fix for hid-steelseries under certain .config setups by Simon Wood
- simple mismerge fix from Fernando Luis Vázquez Cao
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid:
HID: debug: fix RCU preemption issue
HID: hid-steelseries fix led class build issue
HID: reintroduce fix-up for certain Sony RF receivers
Pull MIPS updates from Ralf Baechle:
- More work on DT support for various platforms
- Various fixes that were to late to make it straight into 3.9
- Improved platform support, in particular the Netlogic XLR and
BCM63xx, and the SEAD3 and Malta eval boards.
- Support for several Ralink SOC families.
- Complete support for the microMIPS ASE which basically reencodes the
existing MIPS32/MIPS64 ISA to use non-constant size instructions.
- Some fallout from LTO work which remove old cruft and will generally
make the MIPS kernel easier to maintain and resistant to compiler
optimization, even in absence of LTO.
- KVM support. While MIPS has announced hardware virtualization
extensions this KVM extension uses trap and emulate mode for
virtualization of MIPS32. More KVM work to add support for VZ
hardware virtualizaiton extensions and MIPS64 will probably already
be merged for 3.11.
Most of this has been sitting in -next for a long time. All defconfigs
have been build or run time tested except three for which fixes are being
sent by other maintainers.
Semantic conflict with kvm updates done as per Ralf
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (118 commits)
MIPS: Add new GIC clockevent driver.
MIPS: Formatting clean-ups for clocksources.
MIPS: Refactor GIC clocksource code.
MIPS: Move 'gic_frequency' to common location.
MIPS: Move 'gic_present' to common location.
MIPS: MIPS16e: Add unaligned access support.
MIPS: MIPS16e: Support handling of delay slots.
MIPS: MIPS16e: Add instruction formats.
MIPS: microMIPS: Optimise 'strnlen' core library function.
MIPS: microMIPS: Optimise 'strlen' core library function.
MIPS: microMIPS: Optimise 'strncpy' core library function.
MIPS: microMIPS: Optimise 'memset' core library function.
MIPS: microMIPS: Add configuration option for microMIPS kernel.
MIPS: microMIPS: Disable LL/SC and fix linker bug.
MIPS: microMIPS: Add vdso support.
MIPS: microMIPS: Add unaligned access support.
MIPS: microMIPS: Support handling of delay slots.
MIPS: microMIPS: Add support for exception handling.
MIPS: microMIPS: Floating point support.
MIPS: microMIPS: Fix macro naming in micro-assembler.
git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu
Pull m68knommu updates from Greg Ungerer:
"The bulk of the changes are generalizing the ColdFire v3 core support
and adding in 537x CPU support. Also a couple of other bug fixes, one
to fix a reintroduction of a past bug in the romfs filesystem nommu
support."
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu:
m68knommu: enable Timer on coldfire 532x
m68knommu: fix ColdFire 5373/5329 QSPI base address
m68knommu: add support for configuring a Freescale M5373EVB board
m68knommu: add support for the ColdFire 537x family of CPUs
m68knommu: make ColdFire M532x platform support more v3 generic
m68knommu: create and use a common M53xx ColdFire class of CPUs
m68k: remove unused asm/dbg.h
m68k: Set ColdFire ACR1 cache mode depending on kernel configuration
romfs: fix nommu map length to keep inside filesystem
m68k: clean up unused "config ROMVECSIZE"
Share configuration option processing code between the dm cache
ctr and message functions.
Signed-off-by: Joe Thornber <ejt@redhat.com>
Signed-off-by: Alasdair G Kergon <agk@redhat.com>
Move process_config_option() in dm-cache-target.c to make the
next patch more readable.
Generate a dm event when the amount of remaining thin pool metadata
space falls below a certain level.
The threshold is taken to be a quarter of the size of the metadata
device with a minimum threshold of 4MB.
Add a threshold callback to dm persistent data space maps.
Add a threshold callback function to the persistent data space map
interface for a subsequent patch to use.
dm-thin and dm-cache are interested in knowing when they're getting
low on metadata or data blocks. This patch introduces a new method
for registering a callback against a threshold.
Allow the dm thin pool metadata device to be extended.
Whenever a pool is resumed, detect whether the size of the metadata
device has increased, and if so, extend the metadata to use the new
space.
Support extending a dm persistent data metadata space map.
The extend itself is implemented by switching back to the boostrap
allocator and pointing to the new space. The extra bitmap indexes are
then allocated from the new space, and finally we switch back to the
proper space map ops and tweak the reference counts.
If a thin pool is created in read-only-metadata mode then only open the
metadata device read-only.
Previously it was always opened with FMODE_READ | FMODE_WRITE.
(Note that dm_get_device() still allows read-only dm devices to be used
read-write at the moment: If I create a read-only linear device for the
metadata, via dmsetup load --readonly, then I can still create a rw pool
out of it.)
Refactor device size functions in preparation for similar metadata
device resizing functions.
Use struct assignment rather than memcpy in dm cache.
Fix up some typos in dm-cache comments.
Correct the documented requirement on the return code from dm cache policy
lookup functions stated in the policy module header file.
Fix some typos in dm-space-map-metadata.c error messages.
Tune the dm cache migration throttling.
i) Issue a tick every second, just in case there's no i/o going through.
ii) Drop the migration threshold right down to something suitable for
background work.
Enable WRITE SAME support in dm multipath. As far as multipath is
concerned it is just another write request.
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Tested-by: Bharata B Rao <bharata.rao@gmail.com>
If device_not_write_same_capable() returns true then the iterate_devices
loop in dm_table_supports_write_same() should return false.
Reported-by: Bharata B Rao <bharata.rao@gmail.com>
Cc: stable@vger.kernel.org # v3.8+
This patch uses memalloc_noio_save to avoid a possible deadlock in
dm-bufio. (it could happen only with large block size, at most
PAGE_SIZE << MAX_ORDER (typically 8MiB).
__vmalloc doesn't fully respect gfp flags. The specified gfp flags are
used for allocation of requested pages, structures vmap_area, vmap_block
and vm_struct and the radix tree nodes.
However, the kernel pagetables are allocated always with GFP_KERNEL.
Thus the allocation of pagetables can recurse back to the I/O layer and
cause a deadlock.
This patch uses the function memalloc_noio_save to set per-process
PF_MEMALLOC_NOIO flag and the function memalloc_noio_restore to restore
it. When this flag is set, all allocations in the process are done with
implied GFP_NOIO flag, thus the deadlock can't happen.
This should be backported to stable kernels, but they don't have the
PF_MEMALLOC_NOIO flag and memalloc_noio_save/memalloc_noio_restore
functions. So, PF_MEMALLOC should be set and restored instead.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Cc: stable@kernel.org
Return -ENOMEM instead of success if unable to allocate pending
exception mempool in snapshot_ctr.
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Return -ENOMEM if memory allocation fails in cache_create
instead of 0 (to avoid NULL pointer dereference).
Fix a regression in the calculation of the stripe_width in the
dm stripe target which led to incorrect processing of device limits.
The stripe_width is the stripe device length divided by the number of
stripes. The group of commits in the range f14fa69 ("dm stripe: fix
size test") to eb850de ("dm stripe: support for non power of 2
chunksize") interfered with each other (a merging error) and led to the
stripe_width being set incorrectly to the stripe device length divided by
chunk_size * stripe_count.
For example, a stripe device's table with: 0 33553920 striped 3 512 ...
should result in a stripe_width of 11184640 (33553920 / 3), but due to
the bug it was getting set to 21845 (33553920 / (512 * 3)).
The impact of this bug is that device topologies that previously worked
fine with the stripe target are no longer considered valid. In
particular, there is a higher risk of seeing this issue if one of the
stripe devices has a 4K logical block size. Resulting in an error
message like this:
"device-mapper: table: 253:4: len=21845 not aligned to h/w logical block size 4096 of dm-1"
The fix is to swap the order of the divisions and to use a temporary
variable for the second one, so that width retains the intended
value.
Cc: stable@vger.kernel.org # 3.6+
Pull NVMe driver update from Matthew Wilcox:
"Lots of exciting new features in the NVM Express driver this time,
including support for emulating SCSI commands, discard support and the
ability to submit per-sector metadata with I/Os.
It's still mostly bugfixes though!"
* git://git.infradead.org/users/willy/linux-nvme: (27 commits)
NVMe: Use user defined admin ioctl timeout
NVMe: Simplify Firmware Activate code slightly
NVMe: Only clear the enable bit when disabling controller
NVMe: Wait for device to acknowledge shutdown
NVMe: Schedule timeout for sync commands
NVMe: Meta-data support in NVME_IOCTL_SUBMIT_IO
NVMe: Device specific stripe size handling
NVMe: Split non-mergeable bio requests
NVMe: Remove dead code in nvme_dev_add
NVMe: Check for NULL memory in nvme_dev_add
NVMe: Fix error clean-up on nvme_alloc_queue
NVMe: Free admin queue on request_irq error
NVMe: Add scsi unmap to SG_IO
NVMe: queue usage fixes in nvme-scsi
NVMe: Set TASK_INTERRUPTIBLE before processing queues
NVMe: Add a character device for each nvme device
NVMe: Fix endian-related problems in user I/O submission path
NVMe: Fix I/O cancellation status on big-endian machines
NVMe: Fix sparse warnings in scsi emulation
NVMe: Don't fail initialisation unnecessarily
Pull ACPICA fixes from Rafael Wysocki:
- _INI regression fix from Tomasz Nowicki.
- Fix for a possible memory leak in _OSI support routine from Jung-uk
Kim.
- Fix for a possible buffer overflow during field unit read operation
from Bob Moore.
* tag 'acpi-fixes-3.10-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
ACPICA: ACPICA: Fix for _INI regression
ACPICA: _OSI support: Fix possible memory leak
ACPICA: Fix possible buffer overflow during a field unit read operation
Pull ARM SoC fixes and straggler patches from Olof Johansson:
"A collection of fixes for fall out from 3.10 merge window, some build
fixes and warning cleanups and a small handful of patches that were
small and contained and made sense to still include in 3.10 (some of
these have also been in -next since the merge window opened).
Largest continous series is for OMAP, but there's a handful for other
platforms.
For i.MX, one of the patches are framebuffer fixups due to fallout
during the merge window, and the other removes some stale and broken
code."
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (34 commits)
ARM: exynos: dts: Fixed vbus-gpios
ARM: EXYNOS5: Fix kernel dump in AFTR idle mode
ARM: ux500: Rid ignored return value of regulator_enable() compiler warning
ARM: ux500: read the correct soc_id number
ARM: exynos: dts: cros5250: add cyapa trackpad
video: mxsfb: Adapt to new videomode API
ARM: imx: Select GENERIC_ALLOCATOR
ARM: imx: compile fix for hotplug.c
ARM: dts: don't assume boards are using twl4030 for omap3
ARM: OMAP2+: Remove bogus IS_ERR_OR_NULL checking from id.c
ARM: dts: Configure and fix the McSPI pins for 4430sdp
ARM: dts: AM33XX: Add GPMC node
ARM: dts: OMAP4460: Fix CPU OPP voltages
ARM: dts: OMAP36xx: Fix CPU OPP voltages
ARM: OMAP4+: omap2plus_defconfig: Enable audio via TWL6040 as module
ARM: OMAP2: AM33XX: id: Add support for new AM335x PG2.1 Si
omap: mux: add AM/DM37x gpios
ARM: OMAP1: DMA: fix error handling in omap1_system_dma_init()
ARM: OMAP2+: omap_device: use late_initcall_sync
ARM: OMAP: RX-51: change probe order of touchscreen and panel SPI devices
git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile
Pull tile update from Chris Metcalf:
"The interesting bug fix is support for the upcoming "4.2" release of
the Tilera hypervisor, which by default launches Linux at privilege
level 2 instead of 1. The fix lets new and old hypervisors and
Linuxes interoperate more smoothly, so I've tagged it for
stable@kernel.org so that older Linuxes will be able to boot under the
newer hypervisor."
* 'stable' of git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile:
usb: tilegx: fix memleak when create hcd fail
arch/tile: remove inline marking of EXPORT_SYMBOL functions
rtc: rtc-tile: add missing platform_device_unregister() when module exit
tile: support new Tilera hypervisor
commit 6cd2c7db4 (videomode: videomode_from_timing work) changed the name of
the function from videomode_from_timing() to videomode_from_timings().
commit 32ed6ef1 (videomode: create enum for videomode's display flags) changed
the 'data_flags' field in videomode structure to 'flags'
Adapt to these changes in order to fix the following errors:
drivers/video/mxsfb.c:761:3: error: too many arguments to function 'videomode_from_timing'
drivers/video/mxsfb.c:761:7: error: void value not ignored as it ought to be
drivers/video/mxsfb.c:768:9: error: 'struct videomode' has no member named 'data_flags'
drivers/video/mxsfb.c:770:9: error: 'struct videomode' has no member named 'data_flags'
Also, select VIDEOMODE_HELPER instead of OF_VIDEOMODE, as this one is
deprecated.
Acked-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Signed-off-by: Keith Busch <keith.busch@intel.com>
Signed-off-by: Matthew Wilcox <matthew.r.wilcox@intel.com>
When usb_create_hcd fail, we should call gxio_usb_host_destroy
Signed-off-by: Libo Chen <libo.chen@huawei.com>
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> [extended to EHCI]
Pull networking update from David Miller:
1) Propagate return error values properly in irda, spider_net, sfc, and
bfin_mac. From Wei Yongjun.
2) Fix fec driver OOPS on rapid link up/down, from Frank Li.
3) FIX VF resource allocation and chip message payload length errors in
be2net driver, from Sathya Perla.
4) Fix inner protocol inspection during GSO from Pravin B Shelar.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net:
if_cablemodem.h: Add parenthesis around ioctl macros
gso: Handle Trans-Ether-Bridging protocol in skb_network_protocol()
net: fec: fix kernel oops when plug/unplug cable many times
bfin_mac: fix error return code in bfin_mac_probe()
sfc: fix return value check in efx_ptp_probe_channel()
net/spider_net: fix error return code in spider_net_open()
net/irda: fix error return code in bfin_sir_open()
net: of_mdio: fix behavior on missing phy device
sierra_net: keep status interrupt URB active
usbnet: allow status interrupt URB to always be active
qmi_wwan/cdc_ether: add device IDs for Dell 5804 (Novatel E371) WWAN card
be2net: disable TX in be_close()
be2net: fix EQ from getting full while cleaning RX CQ
be2net: fix payload_len value for GET_MAC_LIST cmd req
be2net: provision VF resources before enabling SR-IOV
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
"MSI:
PCI: Set ->mask_pos correctly
Hotplug:
PCI: Delay final fixups until resources are assigned
Moorestown:
x86/pci/mrst: Use configuration mechanism 1 for 00:00.0, 00:02.0, 00:03.0"
* tag 'pci-v3.10-fixes-1' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci:
Pull MTD update from David Woodhouse:
- Lots of cleanups from Artem, including deletion of some obsolete
drivers
- Support partitions larger than 4GiB in device tree
- Support for new SPI chips
* tag 'for-linus-20130509' of git://git.infradead.org/linux-mtd: (83 commits)
mtd: omap2: Use module_platform_driver()
mtd: bf5xx_nand: Use module_platform_driver()
mtd: denali_dt: Remove redundant use of of_match_ptr
mtd: denali_dt: Change return value to fix smatch warning
mtd: denali_dt: Use module_platform_driver()
mtd: denali_dt: Fix incorrect error check
mtd: nand: subpage write support for hardware based ECC schemes
mtd: omap2: use msecs_to_jiffies()
mtd: nand_ids: use size macros
mtd: nand_ids: improve LEGACY_ID_NAND macro a bit
mtd: add 4 Toshiba nand chips for the full-id case
mtd: add the support to parse out the full-id nand type
mtd: add new fields to nand_flash_dev{}
mtd: sh_flctl: Use of_match_ptr() macro
mtd: gpio: Use of_match_ptr() macro
mtd: gpio: Use devm_kzalloc()
mtd: davinci_nand: Use of_match_ptr()
mtd: dataflash: Use of_match_ptr() macro
mtd: remove h720x flash support
mtd: onenand: remove OneNAND simulator
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394
Pull firewure updates from Stefan Richter:
- fix controller removal when controller is in suspended state
- fix video reception on VIA VT6306 with gstreamer, MythTV, and maybe dv4l
- fix a startup issue with Agere/LSI FW643-e2
- error logging improvements and other small updates
* tag 'firewire-updates' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394:
firewire: ohci: dump_stack() for PHY regs read/write failures
firewire: ohci: Improve bus reset error messages
firewire: ohci: Alias dev_* log functions
firewire: ohci: Fix 'failed to read phy reg' on FW643 rev8
firewire: ohci: fix VIA VT6306 video reception
firewire: ohci: Check LPS before register access on pci removal
firewire: ohci: Fix double free_irq()
firewire: remove unnecessary alloc/OOM messages
firewire: sbp2: replace BUG_ON by WARN_ON
firewire: core: remove an always false test
firewire: Remove two unneeded checks for macros
git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp
Pull two small EDAC fixes from Borislav Petkov.
* tag 'edac_fixes_for_3.10' of git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp:
EDAC: Don't give write permission to read-only files
EDAC, mc_sysfs.c: Fix string array pointer types
Pull watchdog update from Wim Van Sebroeck:
"Fix a kdump issue in hpwdt and a possible NULL dereference"
* git://www.linux-watchdog.org/linux-watchdog:
watchdog: Fix race condition in registration code
watchdog: Convert to devm_ioremap_resource()
Pull removal of GENERIC_GPIO from Grant Likely:
"GENERIC_GPIO now synonymous with GPIOLIB. There are no longer any
valid cases for enableing GENERIC_GPIO without GPIOLIB, even though it
is possible to do so which has been causing confusion and breakage.
This branch does the work to completely eliminate GENERIC_GPIO."
* tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux:
gpio: update gpio Chinese documentation
Remove GENERIC_GPIO config option
Convert selectors of GENERIC_GPIO to GPIOLIB
blackfin: force use of gpiolib
m68k: coldfire: use gpiolib
mips: pnx833x: remove requirement for GENERIC_GPIO
openrisc: default GENERIC_GPIO to false
avr32: default GENERIC_GPIO to false
xtensa: remove explicit selection of GENERIC_GPIO
sh: replace CONFIG_GENERIC_GPIO by CONFIG_GPIOLIB
powerpc: remove redundant GENERIC_GPIO selection
unicore32: default GENERIC_GPIO to false
unicore32: remove unneeded select GENERIC_GPIO
arm: plat-orion: use GPIO driver on CONFIG_GPIOLIB
arm: remove redundant GENERIC_GPIO selection
mips: alchemy: require gpiolib
mips: txx9: change GENERIC_GPIO to GPIOLIB
mips: loongson: use GPIO driver on CONFIG_GPIOLIB
mips: remove redundant GENERIC_GPIO select
Pull slave-dmaengine updates from Vinod Koul:
"This time we have dmatest improvements from Andy along with dw_dmac
fixes. He has also done support for acpi for dmanegine.
Also we have bunch of fixes going in DT support for dmanegine for
various folks. Then Haswell and other ioat changes from Dave and
SUDMAC support from Shimoda."
* 'for-linus' of git://git.infradead.org/users/vkoul/slave-dma: (53 commits)
dma: tegra: implement suspend/resume callbacks
dma:of: Use a mutex to protect the of_dma_list
dma: of: Fix of_node reference leak
dmaengine: sirf: move driver init from module_init to subsys_initcall
sudmac: add support for SUDMAC
dma: sh: add Kconfig
at_hdmac: move to generic DMA binding
ioatdma: ioat3_alloc_sed can be static
ioatdma: Adding write back descriptor error status support for ioatdma 3.3
ioatdma: S1200 platforms ioatdma channel 2 and 3 falsely advertise RAID cap
ioatdma: Adding support for 16 src PQ ops and super extended descriptors
ioatdma: Removing hw bug workaround for CB3.x .2 and earlier
dw_dmac: add ACPI support
dmaengine: call acpi_dma_request_slave_channel as well
dma: acpi-dma: introduce ACPI DMA helpers
dma: of: Remove unnecessary list_empty check
DMA: OF: Check properties value before running be32_to_cpup() on it
DMA: of: Constant names
ioatdma: skip silicon bug workaround for pq_align for cb3.3
ioatdma: Removing PQ val disable for cb3.3
git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux
Pull thermal management update from Zhang Rui:
"The most important one is to build thermal core and governor and cpu
cooling code into one module. This fixes a regression that thermal
core does not work if it is built as module, since 3.7. I'll backport
them to stable kernel once those changes are in upstream.
The largest batch is the thermal kernel-doc & coding style
updates/cleanups from Eduardo.
Highlights:
- build all thermal framework code into one module to fix a
regression that thermal does not work if it is built as module.
- Marvell Armada 370/XP thermal sensor driver
- thermal core/cpu cooling kernel-doc & coding style updates and
cleanups.
- Add Eduardo Valentin as thermal sub-maintainer, both in mailing
list and patchwork. He will help me on arm thermal drivers."
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux: (68 commits)
thermal: db8500_cpufreq_cooling: remove usage of IS_ERR_OR_NULL()
thermal: thermal_core: remove usage of IS_ERR_OR_NULL
thermal: cpu_cooling: improve line breaking
thermal: cpu_cooling: alignment improvements
thermal: cpu_cooling: remove checkpatch.pl warning
thermal: cpu_cooling: remove trailing blank line
thermal: cpu_cooling: align on open parenthesis
thermal: cpu_cooling: standardize comment style
thermal: cpu_cooling: standardize end of function
thermal: cpu_cooling: remove trailing white spaces
Thermal: update documentation for thermal_zone_device_register
thermal: update kernel-doc for thermal_zone_device_register
thermal: update kernel-doc for create_trip_attrs
thermal: update kernel-doc for thermal_cooling_device_register
thermal: update kernel-doc for thermal_zone_unbind_cooling_device
thermal: update kernel-doc for thermal_zone_bind_cooling_device
thermal: use EXPORT_SYMBOL_GPL
thermal: rename notify_thermal_framework to thermal_notify_framework
thermal: update driver license
thermal: use strlcpy instead of strcpy
I get the following warning on boot:
WARNING: at drivers/base/core.c:575 device_create_file+0x9a/0xa0()
Hardware name: -[8737R2A]-
Write permission without 'store'
</snip>
Drilling down, this is related to dynamic channel ce_count attribute
files sporting a S_IWUSR mode without a ->store() function. Looking
around, it appears that they aren't supposed to have a ->store()
function. So remove the bogus write permission to get rid of the
warning.
Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
Cc: Mauro Carvalho Chehab <mchehab@redhat.com>
Cc: <stable@vger.kernel.org> # 3.[89]
[ shorten commit message ]
A race condition exists when registering the first watchdog device.
Sequence of events:
- watchdog_register_device calls watchdog_dev_register
- watchdog_dev_register creates the watchdog misc device by calling
misc_register.
At that time, the matching character device (/dev/watchdog0) does not yet
exist, and old_wdd is not set either.
- Userspace gets an event and opens /dev/watchdog
- watchdog_open is called and sets wdd = old_wdd, which is still NULL,
and tries to dereference it. This causes the kernel to panic.
Seen with systemd trying to open /dev/watchdog immediately after
it was created.
Reported-by: Arkadiusz Miskiewicz <arekm@maven.pl>
Tested-by: Arkadiusz Miskiewicz <arekm@maven.pl>
Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
Use the newly introduced devm_ioremap_resource() instead of
devm_request_and_ioremap() which provides more consistent error handling.
devm_ioremap_resource() provides its own error messages; so all explicit
error messages can be removed from the failure code paths.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Reviewed-by: Thierry Reding <thierry.reding@avionic-design.de>
Cc: Gabor Juhos <juhosg@openwrt.org>
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
Pull InfiniBand/RDMA changes from Roland Dreier:
- XRC transport fixes
- Fix DHCP on IPoIB
- mlx4 preparations for flow steering
- iSER fixes
- miscellaneous other fixes
* tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (23 commits)
IB/iser: Add support for iser CM REQ additional info
IB/iser: Return error to upper layers on EAGAIN registration failures
IB/iser: Move informational messages from error to info level
IB/iser: Add module version
mlx4_core: Expose a few helpers to fill DMFS HW strucutures
mlx4_core: Directly expose fields of DMFS HW rule control segment
mlx4_core: Change a few DMFS fields names to match firmare spec
mlx4: Match DMFS promiscuous field names to firmware spec
mlx4_core: Move DMFS HW structs to common header file
IB/mlx4: Set link type for RAW PACKET QPs in the QP context
IB/mlx4: Disable VLAN stripping for RAW PACKET QPs
mlx4_core: Reduce warning message for SRQ_LIMIT event to debug level
RDMA/iwcm: Don't touch cmid after dropping reference
IB/qib: Correct qib_verbs_register_sysfs() error handling
IB/ipath: Correct ipath_verbs_register_sysfs() error handling
RDMA/cxgb4: Fix SQ allocation when on-chip SQ is disabled
SRPT: Fix odd use of WARN_ON()
IPoIB: Fix ipoib_hard_header() return value
RDMA: Rename random32() to prandom_u32()
RDMA/cxgb3: Fix uninitialized variable
into for-next
reproduce steps
1. flood ping from other machine
ping -f -s 41000 IP
2. run below script
while [ 1 ]; do ethtool -s eth0 autoneg off;
sleep 3;ethtool -s eth0 autoneg on; sleep 4; done;
You can see oops in one hour.
The reason is fec_restart clear BD but NAPI may use it.
The solution is disable NAPI and stop xmit when reset BD.
disable NAPI may sleep, so fec_restart can't be call in
atomic context.
Signed-off-by: Frank Li <Frank.Li@freescale.com>
Reviewed-by: Lucas Stach <l.stach@pengutronix.de>
Tested-by: Lucas Stach <l.stach@pengutronix.de>
Fix to return a negative error code from the error handling
case instead of 0, as done elsewhere in this function.
In case of error, the function ptp_clock_register() returns ERR_PTR()
and never returns NULL. The NULL test in the return value check should
be replaced with IS_ERR().
Reviewed-by: Ben Hutchings <bhutchings@solarflare.com>
Fix to return -ENOMEM in the irlap_open() error handling case instead
of 0(overwrite to 0 by bfin_sir_startup()), as done elsewhere in this
function.
