path: root/drivers
2010-03-12drivers/block/floppy.c: remove unnecessary casting in fd_ioctlJoe Perches
Convert outparam to const void *. Cast outparam to const char * for strlen(). Signed-off-by: Joe Perches <joe@perches.com> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12drivers/block/floppy.c: remove misleading, used once FD_IOCTL_ALLOWED macroJoe Perches
Just code the test directly Signed-off-by: Joe Perches <joe@perches.com> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12drivers/block/floppy.c: remove obfuscating CODE2SIZE macroJoe Perches
2010-03-12drivers/block/floppy.c: add __func__ to debugtJoe Perches
Make debugt messages a little neater. Signed-off-by: Joe Perches <joe@perches.com> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12drivers/block/floppy.c: convert raw_cmd_copyin from while(1) to label: gotoJoe Perches
Reduces indent. Makes a bit more readable and intelligible. Return value now at bottom of function. Signed-off-by: Joe Perches <joe@perches.com> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12drivers/block/floppy.c: remove some unnecessary castingJoe Perches
Remove char/void __user * use. Remove kmalloc cast. Signed-off-by: Joe Perches <joe@perches.com> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12drivers/block/floppy.c: use %pf in logging messagesJoe Perches
Print the function name not the pointer address where useful and possible Signed-off-by: Joe Perches <joe@perches.com> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12drivers/block/floppy.c: use __func__ where appropriateJoe Perches
Add and use __func__ to is_alive. Use __func__ in some DPRINTs. Signed-off-by: Joe Perches <joe@perches.com> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12drivers/block/floppy.c: DPRINT neateningJoe Perches
Move DPRINT macro definition above 1st use Consolidate a format string (>80 columns) Add a newline to an unterminated message Comment neatened Signed-off-by: Joe Perches <joe@perches.com> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12drivers/block/floppy.c: remove #define FLOPPY_SANITY_CHECKJoe Perches
The code could not be compiled without the #define, so just remove it and the #ifdef/#endif lines. Signed-off-by: Joe Perches <joe@perches.com> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12drivers/block/floppy.c: remove unnecessary argument from [__]reschedule_timeoutJoe Perches
Prior to patch "drivers/block/floppy.c: Use pr_<level>" only reschedule_timeout(,"request done"...) printed a numeric value after a reschedule_timeout event message. Restore that behavior and remove the now unnecessary argument. Signed-off-by: Joe Perches <joe@perches.com> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12drivers/block/floppy.c: unclutter redo_fd_request logicJoe Perches
Change for(;;) with continue; to label: goto label Reduces indentation and adds a bit of clarity. Signed-off-by: Joe Perches <joe@perches.com> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12drivers/block/floppy.c: remove REPEAT macroJoe Perches
Macros with hidden flow changes aren't nice. Signed-off-by: Joe Perches <joe@perches.com> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12drivers/block/floppy.c: remove unnecessary return and bracesJoe Perches
2010-03-12drivers/block/floppy.c: add function is_ready_stateJoe Perches
Used a couple of times, might simplify the code a bit. Signed-off-by: Joe Perches <joe@perches.com> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12drivers/block/floppy.c: convert int initialising to bool initializedJoe Perches
Don't initialize initialized either. Default is false. Signed-off-by: Joe Perches <joe@perches.com> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12drivers/block/floppy.c: remove #define DEVICE_NAME "floppy"Joe Perches
Use it directly in the one place it's used. Signed-off-by: Joe Perches <joe@perches.com> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12drivers/block/floppy.c: move leading && and || to preceding lineJoe Perches
2010-03-12drivers/block/floppy.c: convert int 1/0 to bool true/falseJoe Perches
Various functions use int where bool is appropriate lock_fdc, wait_til_done, poll_drive, user_reset_fdc Convert to bool. Signed-off-by: Joe Perches <joe@perches.com> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12drivers/block/floppy.c: remove macros CALL, WAIT and IWAITJoe Perches
Obfuscating macros with embedded returns are not nice Signed-off-by: Joe Perches <joe@perches.com> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12drivers/block/floppy.c: remove [_]COPYIN [_]COPYOUT and ECALL macrosJoe Perches
Remove these obfuscating macros with hidden returns Signed-off-by: Joe Perches <joe@perches.com> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12drivers/block/floppy.c: remove most uses of CALL and ECALL macrosJoe Perches
2010-03-12drivers/block/floppy.c: remove [U]CLEARF, [U]SETF, and [U]TESTF macrosJoe Perches
Use clear_bit, set_bit, and test_bit functions directly Signed-off-by: Joe Perches <joe@perches.com> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12drivers/block/floppy.c: add debug_dcl(...) macroJoe Perches
Converted #ifdef DCL_DEBUG if (test) DPRINTK(...); #endif to debug_dcl(test, ...); Signed-off-by: Joe Perches <joe@perches.com> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12drivers/block/floppy.c: remove macro LOCK_FDCJoe Perches
Macros with hidden returns aren't nice. Signed-off-by: Joe Perches <joe@perches.com> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12drivers/block/floppy.c: remove a few spaces from function castsJoe Perches
2010-03-12drivers/block/floppy.c: remove IN/OUT macros, indent switch/caseJoe Perches
Remove ugly IN/OUT macros, use direct case and code Add missing semicolon after ECALL Signed-off-by: Joe Perches <joe@perches.com> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12drivers/block/floppy.c: indent a commentJoe Perches
2010-03-12drivers/block/floppy.c: remove CLEARSTRUCT macro, use memsetJoe Perches
2010-03-12drivers/block/floppy.c: comment neatening and remove naked ;Joe Perches
Spacing, column alignment and a for loop with a naked semicolon converted to an assign and while Signed-off-by: Joe Perches <joe@perches.com> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12drivers/block/floppy.c: remove LAST_OUT macroJoe Perches
Macros with hidden returns are not nice. Convert the 2 uses to use direct code. Signed-off-by: Joe Perches <joe@perches.com> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12drivers/block/floppy.c: hoist assigns from if()s, neateningJoe Perches
Move assigns above if()s Remove unnecessary parentheses from returns Use a temporary for a duplicated test Signed-off-by: Joe Perches <joe@perches.com> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12drivers/block/floppy.c: remove used once CHECK_READY macroJoe Perches
2010-03-12drivers/block/floppy.c: remove unnecessary bracesJoe Perches
2010-03-12drivers/block/floppy.c: use pr_<level>Joe Perches
Convert bare printk to pr_info and pr_cont Convert printk(KERN_ERR to pr_err Signed-off-by: Joe Perches <joe@perches.com> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12drivers/block/floppy.c: #define space and column neateningJoe Perches
2010-03-12drivers/block/floppy.c: convert some #include <asm/ to #include <linux/Joe Perches
2010-03-12drivers/scsi/ses.c: eliminate double freeJulia Lawall
The few lines below the kfree of hdr_buf may go to the label err_free which will also free hdr_buf. The most straightforward solution seems to be to just move the kfree of hdr_buf after these gotos. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r@ identifier E; expression E1; iterator I; statement S; @@ *kfree(E); ... when != E = E1 when != I(E,...) S when != &E *kfree(E); // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12sdio: recognize io card without powercycleAlbert Herranz
SDIO Simplified Specification V2.00 states that it is strongly recommended that the host executes either a power reset or issues a CMD52 (I/O Reset) to re-initialize an I/O only card or the I/O portion of a combo card. Additionally, the CMD52 must be issued first because it cannot be issued after a CMD0. With this patch the Nintendo Wii SDIO-based WLAN card is detected after a system reset, without requiring a complete system powercycle. Signed-off-by: Albert Herranz <albert_herranz@yahoo.es> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-12rtc/hctosys: only claim the RTC provided the system time if it didUwe Kleine-König
Without this patch /sys/class/rtc/$CONFIG_RTC_HCTOSYS_DEVICE/hctosys contains a 1 (meaning "This rtc was used to initialize the system clock") even if reading the time at bootup failed. Moreover change error handling in rtc_hctosys() to use goto and so reduce the indention level. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: Paul Gortmaker <p_gortmaker@yahoo.com> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-08Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: PCI/PM Runtime: Make runtime PM of PCI devices inactive by default
2010-03-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (62 commits) msi-laptop: depends on RFKILL msi-laptop: Detect 3G device exists by standard ec command msi-laptop: Add resume method for set the SCM load again msi-laptop: Support some MSI 3G netbook that is need load SCM msi-laptop: Add threeg sysfs file for support query 3G state by standard 66/62 ec command msi-laptop: Support standard ec 66/62 command on MSI notebook and nebook Driver core: create lock/unlock functions for struct device sysfs: fix for thinko with sysfs_bin_attr_init() sysfs: Kill unused sysfs_sb variable. sysfs: Pass super_block to sysfs_get_inode driver core: Use sysfs_rename_link in device_rename sysfs: Implement sysfs_rename_link sysfs: Pack sysfs_dirent more tightly. sysfs: Serialize updates to the vfs inode sysfs: windfarm: init sysfs attributes sysfs: Use sysfs_attr_init and sysfs_bin_attr_init on module dynamic attributes sysfs: Document sysfs_attr_init and sysfs_bin_attr_init sysfs: Use sysfs_attr_init and sysfs_bin_attr_init on dynamic attributes sysfs: Use one lockdep class per sysfs attribute. sysfs: Only take active references on attributes. ...
2010-03-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdogLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdog: [WATCHDOG] i6300esb.c: change platform_driver to pci_driver [WATCHDOG] i6300esb: fix unlock register with [WATCHDOG] drivers/watchdog/wdt.c:wdt_ioctl(): make `ident' non-static [WATCHDOG] change reboot_notifier to platform-shutdown method. [WATCHDOG] watchdog_info constify [WATCHDOG] gef_wdt: Author corrections following split of GE Fanuc joint venture [WATCHDOG] iTCO_wdt: clean up probe(), modify err msg [WATCHDOG] ep93xx: watchdog timer driver for TS-72xx SBCs cleanup [WATCHDOG] support for max63xx watchdog timer chips [WATCHDOG] ep93xx: added platform side support for TS-72xx WDT driver [WATCHDOG] ep93xx: implemented watchdog timer driver for TS-72xx SBCs
2010-03-08[WATCHDOG] i6300esb.c: change platform_driver to pci_driverWim Van Sebroeck
Since the intel 6300esb platform uses a dedicated PCI ID for it's watchdog timer (00:1d.4), it's better and easier to have this as a pci_driver. Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2010-03-08[S390] smsgiucv_app: deliver z/VM CP special messages (SMSG) as ueventsHendrik Brueckner
The smsgiucv_app driver registers a callback with the smsgiucv driver to receive z/VM CP special messages (SMSG) starting with "APP". When the callback is called for special messages, the driver creates an uevent for the received message. The uevent consists of additional environment data containing the message prefix ("APP"), message sender, and message content. udev rules can be used to trigger application specific actions through matching the content or sender of the special message. Signed-off-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-03-08[S390] smsgiucv: declare char pointers as "const"Hendrik Brueckner
Declare the smsgiucv prefix char pointer as "const" and use use const char pointers in callback functions. Signed-off-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-03-08[S390] dasd: automatic recognition of read-only devicesStefan Weinhuber
In z/VM it is possible to attach a device as read-only. To prevent unintentional write requests and subsequent I/O errors, we can detect this configuration using the z/VM DIAG 210 interface and set the respective linux block device to read-only as well. Signed-off-by: Stefan Weinhuber <wein@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-03-08[S390] remove unused qdio flags in zfcp and qethUrsula Braun
zfcp and qeth are setting flags for the qdio-layer, but these flags are not used in qdio. Patch removes the flag definitions from qdio and their settings in zfcp and qeth. Cc: Jan Glauber <jang@linux.vnet.ibm.com> Cc: Christof Schmitt <christof.schmitt@de.ibm.com> Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-03-08[S390] qdio: add missing bracketUrsula Braun
Add a missing bracket to only log the outbound handler event in the appropriate case. Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2010-03-08[S390] cio: fix init_count in case of recognition after steal lockSebastian Ott
After we try to steal a lock on a ccw device in boxed state, we have to restart device recognition and potentially reprobing. In this case ccw_device_init_count was erroneously decreased twice. This patch fixes the issue. Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
