The previous patches to workaround the 5706S on an HP blade were not
sufficient. The link state still does not change properly in some
cases. This patch adds polling to make it completely reliable.
Signed-off-by: Michael Chan <mchan@broadcom.com>
We must pin all resources and make sure the PCI subsystem
won't relocate us, as the addresses are hardwired into hardware.
Signed-off-by: Michael Buesch <mb@bu3sch.de>
This silences sparse when run on zd1211rw.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
This silences a few sparse warnings. There are two more where
I can't follow the code.
This fixes the pcicore driver to not die a horrible
crash death when inserting a cardbus card.
This fixes the GPIO API to be reentrancy safe.
This fixes the GPIO API to be usable.
This fixes the SSB watchdog access for devices without a chipcommon.
These devices have the watchdog on the extif.
This fixes the baud settings for new devices
like the Linksys WRT350n.
'u64' is not necessarily 'unsigned long long'
drivers/net/wireless/ath5k/base.c: In function 'ath5k_beacon_update_timers':
drivers/net/wireless/ath5k/base.c:2130: warning: format '%llx' expects type 'long long unsigned int', but argument 4 has type 'u64'
drivers/net/wireless/ath5k/base.c:2130: warning: format '%llx' expects type 'long long unsigned int', but argument 5 has type 'u64'
drivers/net/wireless/ath5k/base.c: In function 'ath5k_intr':
drivers/net/wireless/ath5k/base.c:2391: warning: format '%llx' expects type 'long long unsigned int', but argument 6 has type 'u64'
sparse sees int -> bool cast as an error:
hw.c:3754:10: warning: cast truncates bits from constant value (ffffffea becomes 0)
Fix it by converting the rettype to int and check appropriately.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Cc: Nick Kossifidis <mickflemm@gmail.com>
Cc: Luis R. Rodriguez <mcgrof@gmail.com>
Omitted lock causes sparse warning
drivers/net/wireless/ath5k/base.c:1682:1: warning: context imbalance in 'ath5k_tasklet_rx' - different lock contexts for basic block
Add the lock to the guilty fail path.
Acked-by: Nick Kossifidis <mickflemm@gmail.com>
Based on report from Cavan Carroll <cavancarroll@hotmail.com>:
http://bugzilla.kernel.org/show_bug.cgi?id=9863
Cc: Cavan Carroll <cavancarroll@hotmail.com>
Retarget of an old patch against prism54usb in linux-wireless archive:
http://marc.info/?l=linux-wireless&m=117449935810254&w=2
Cc: Ivo Couckuyt <iv0co@yahoo.co.uk>
When deleting the veth driver, veth_close calls netif_carrier_off
for the two extremities of the network device. netif_carrier_off on
the peer device will fire an event and hold a reference on the peer
device. Just after, the peer is unregistered taking the rtnl_lock while
the linkwatch_event is scheduled. If __linkwatch_run_queue does not
occurs before the unregistering, unregister_netdevice will wait for
the dev refcount to reach zero holding the rtnl_lock and linkwatch_event
will wait for the rtnl_lock and hold the dev refcount.
Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com>
1) niu_enable_alt_mac() needs to be adjusted so that the mask
is computed properly for the BMAC case.
2) BMAC has 6 alt MAC addresses available, not 7.
BMAC port alternate MAC address index needs to start at 1. Index 0 is
used for the main MAC address.
Signed-off-by: Matheos Worku <matheos.worku@sun.com>
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6
master.kernel.org:/pub/scm/linux/kernel/git/linville/wireless-2.6
This adds printk messages with basic information about the driver being loaded.
This information includes a summary of the compiled-in features, which
simplifies bug-reporting and debugging a lot.
Also a firmware ID is printed. This is a unique identifier blob for a specific
version of the firmware. This ID is attached to a specific version of the firmware
blob in b43-fwcutter (see fwcutter git).
This helps users to select the right firmware for their device.
This also makes it possible to use automated scripts to fetch and extract the right
firmware for the driver. (The script will grep the .ko for the "Firmware-ID: xxx" string.)
While the driver might still support other versions of the firmware for backward
compatibility, this will always print out the officially supported version, which
people _should_ use.
Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it>
Restock the RX queue when there are a lot of unused frames so that the
RX ring buffer doesn't overrun, causing a ucode assertion. Backport of
patch "iwlwifi: fix ucode assertion for RX queue overrun".
Signed-off-by: Dan Williams <dcbw@redhat.com>
There is no association process in IBSS mode - so testing the
association id is not needed.
Signed-off-by: Reinette Chatre <reinette.chatre@intel.com>
Signed-off-by: Tomas Winkler <tomas.winkler@intel.com>
CC: Richard Scherping <richard@scherping.de>
This patch revert commit blow that wrongly suppressed sparse warning in
iwlwifi eeprom reading
In addtion it suppresses correctly the iwlwifi eeprom register reading anomaly.
commit 45883ae47a0a4700c0f4716dc75a255cccdc3a76
misc wireless annotations
The firmware version information should always get printed. Not only on a
debug build.
The patch by Michael Buesch has been ported to b43legacy.
This adds the firmware ID to modinfo.
Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com>
on a debug build.
firmware for the driver. (the script will grep the .ko for the "Firmware-ID: xxx" string.
This checks if the DMA address is bigger than what the controller can manage.
It will reallocate the buffers in the GFP_DMA zone in that case.
Thanks to Matti Viljanen for reporting this.
Cc: Matti Viljanen <viljanen.matti@gmail.com>
Value of count is used to decide when to replenish rx buffers. If it is
equal or above 8 we replenish the buffers. Ensure there is no starvation
by initializing count to 8 - thus forcing replenish at first iteration.
This is helpful when rx receives batches of buffers smaller than 8.
Signed-off-by: Mohamed Abbas <mabbas@linux.intel.com>
This patch prevents sending host commands when rfkill is on
Signed-off-by: Gregory Greenman <gregory.greenman@intel.com>
The geos information is set up during probe and should only
be removed during pci_remove, not during _down.
This is a temporary fix until the setting of the status bits
have been cleaned up (to explicitly match all setting with
clearing of status bits).
Enable workaround for poor link stalls by link quality instead of link
speed. Using link speed caused workaround be active always on 802.11b
networks which reduced performance and not even catch all stalls.
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi>
when setting up the tx descriptors for the hardware we must account for any
padding between the header and the data we might have added previously. frame
len is the length of the frame in the air (including FCS but no padding) and
buffer len is the length of the buffer (including padding, but without FCS).
changing the way ah_setup_tx_desc is called: now excluding the FCS, since it's
easier to add that in the function where we need it.
before this fix we sent trailing zero bytes after the packet (because frame len
included the padding) which was not a big problem without WEP, but with WEP
this resultes in a wrong WEP checksum and the packet is discarded - which is
how i noticed at all ;)
an easy way to run into header padding problems, btw, is to connect to a QoS
(WME) enabled access point (eg. madwifi) - QoS data frames are 2 byte longer
and will require padding.
this patch applies on top of luis latest patch series from 04.02.2008.
drivers/net/wireless/ath5k/base.c: Changes-licensed-under: 3-Clause-BSD
drivers/net/wireless/ath5k/hw.c: Changes-licensed-under: ISC
Signed-off-by: Bruno Randolf <bruno@thinktube.com>
With assists from Russell King <rmk+kernel@arm.linux.org.uk> and
Andrew Morton <akpm@linux-foundation.org>...
Users reported that ARP's were lost with e1000e. The problem
is fixed by not enabling this manageability configuration
bit.
None of the release_manageability code is actually needed as the
normal device reset during a shutdown returns everthing to
the right condition automatically.
Signed-off-by: David Graham <david.graham@intel.com>
Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com>
Signed-off-by: Jeff Garzik <jeff@garzik.org>
Users reported that ARP's were lost with igb. The problem
bit.
In reply to "RE: [Fwd: [PATCH 2.6.25] ixgbe/igb: correctly obtain protocol
information on transmit]" from Andy Gospodarek:
The driver was incorrectly looking at socket headers for
protocol information, needed for checksumming offload. Fix
this by not looking at the socket but frame headers instead.
This disregards extension headers but it's unclear that linux
generates those anyway.
Tested by Andy Gospodarek.
CRC stripping was only correctly enabled for packet split recieves
which is used when receiving jumbo frames. Correctly enable SECRC
also for normal buffer packet receives.
Tested by Andy Gospodarek and Johan Andersson, see bugzilla #9940.
According to one of OOPSes reported by Jann softirq can break
while skb is prepared for netif_rx. The report isn't complete,
so the real reason of the later bug could be different, but
IMHO this locking break in ax_bump is unsafe and unnecessary.
Reported-and-tested-by: Jann Traschewski <jann@gmx.de>
Signed-off-by: Jarek Poplawski <jarkao2@gmail.com>
Megahertz EM1144 PCMCIA ethernet adapter needs special handling
because it has two VERS_1 tuples and the station address is in
the second one. Conversion to generic handling of these fields
broke it. Reverting that fixes the device.
https://bugzilla.redhat.com/show_bug.cgi?id=233255
Thanks go to Jon Stanley for not giving up on this one until the
problem was found.
Signed-off-by: Chuck Ebbert <cebbert@redhat.com>
This patch avoids a null pointer dereference when we read local_mac
for netconsole in configfs and shows default local mac address
value.
A null pointer dereference occurs when we call show_local_mac() via
local_mac entry in configfs before we setup the content of netpoll
using netpoll_setup().
Signed-off-by: Keiichi KII <k-keiichi@bx.jp.nec.com>
Arjan:
With the help of kerneloops.org I've spotted a nice little interaction
between the TTY layer and the bluetooth code, however the tty layer is not
something I'm all too familiar with so I rather ask than brute-force fix the
code incorrectly.
The raw details are at:
http://www.kerneloops.org/search.php?search=uart_flush_buffer
What happens is that, on closing the bluetooth tty, the tty layer goes
into the release_dev() function, which first does a bunch of stuff, then
sets the file->private_data to NULL, does some more stuff and then calls the
ldisc close function. Which in this case, is hci_uart_tty_close().
Now, hci_uart_tty_close() calls hci_uart_close() which clears some
internal bit, and then calls hci_uart_flush()... which calls back to the
tty layers' uart_flush_buffer() function. (in drivers/bluetooth/hci_tty.c
around line 194) Which then WARN_ON()'s because that's not allowed/supposed
to be called this late in the shutdown of the port....
Should the bluetooth driver even call this flush function at all??
David:
This seems to be what happens: Hci_uart_close() flushes using
hci_uart_flush(). Subsequently, in hci_dev_do_close(), (one step in
hci_unregister_dev()), hci_uart_flush() is called again. The comment in
uart_flush_buffer(), relating to the WARN_ON(), indicates you can't flush
after the port is closed; which sounds reasonable. I think hci_uart_close()
should set hdev->flush to NULL before returning. Hci_dev_do_close() does
check for this. The code path is rather involved and I'm not entirely clear
of all steps, but I think that's what should be done.
Even if we don't want to register the WMI driver, we should initialize
the wmi_blocks list to be empty, since we don't want the wmi helper
functions to oops just because that basic list has not even been set up.
With this, "find_guid()" will happily return "not found" rather than
oopsing all over the place, and the callers will then just automatically
return false or AE_NOT_FOUND as appropriate.
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband:
mlx4_core: Fix build break (missing include)
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev
* 'upstream-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev:
sata_mv: platform driver allocs dma without create
pata_ninja32: setup changes
pata_legacy: typo fix
pata_amd: Note in the module description it handles Nvidia
sata_mv: fix loop with last port
libata: ignore deverr on SETXFER if mode is configured
pata_via: fix SATA cable detection on cx700
