If oprofilefs_ulong_from_user() is called with count equals
zero, *val remains unchanged. Depending on the implementation it
might be uninitialized.
Change oprofilefs_ulong_from_user()'s interface to return count
on success. Thus, we are able to return early if count equals
zero which avoids using *val uninitialized. Fixing all users of
oprofilefs_ulong_ from_user().
This follows write syscall implementation when count is zero:
"If count is zero ... [and if] no errors are detected, 0 will be
returned without causing any other effect." (man 2 write)
Reported-By: Mike Waychison <mikew@google.com>
Signed-off-by: Robert Richter <robert.richter@amd.com>
Cc: <stable@vger.kernel.org>
Cc: oprofile-list <oprofile-list@lists.sourceforge.net>
Link: http://lkml.kernel.org/r/20111219153830.GH16765@erda.amd.com
I noticed that hotplug of one setup does not work with recent change in
pci tree.
After checking the bridge conf setup, I noticed that the bridges get
assigned but do not get enabled.
The reason is the following commit, while simply ignores bridge
resources when enabling a pci device:
| commit bbef98ab0f019f1b0c25c1acdf1683c68933d41b
| Author: Ram Pai <linuxram@us.ibm.com>
| Date: Sun Nov 6 10:33:10 2011 +0800
| PCI: defer enablement of SRIOV BARS
| NOTE: Note, there is subtle change in the pci_enable_device() API. Any
| driver that depends on SRIOV BARS to be enabled in pci_enable_device()
| can fail.
Put back bridge resource and ROM resource checking to fix the problem.
That should fix regression like BIOS does not assign correct resource to
bridge.
Discussion can be found at:
http://www.spinics.net/lists/linux-pci/msg12874.html
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci:
PCI: Set device power state to PCI_D0 for device without native PM support
PCI hotplug: Always allow acpiphp to handle non-PCIe bridges
PCI: fix ats compile failure
This reverts commit eb1711bb94991e93669c5a1b5f84f11be2d51ea1.
It blows up the i915 seqno tracking, resulting in the
BUG_ON(seqno == 0);
in i915_wait_request() triggering, which will cause lock-ups.
See for example
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/903010
https://lkml.org/lkml/2011/12/14/395
Reported-requested-and-tested-by: Dirk Hohndel <dirk@hohndel.org>
Reported-by: Richard Eames <Richard.Eames@flinders.edu.au>
Reported-by: Rocko Requin <rockorequin@hotmail.com>
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: Dave Airlie <airlied@redhat.com>
Cc: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Keith Packard <keithp@keithp.com>
Cc: Eric Anholt <eric@anholt.net>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc:
sparc32: Be less strict in matching %lo part of relocation.
sbus: convert drivers/sbus/char/* to use module_platform_driver()
bbc_i2c: Remove unneeded err variable
sparc: Use kmemdup rather than duplicating its implementation
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net:
ipv6: Check dest prefix length on original route not copied one in rt6_alloc_cow().
sch_gred: should not use GFP_KERNEL while holding a spinlock
ipip, sit: copy parms.name after register_netdevice
ipv6: Fix for adding multicast route for loopback device automatically.
ssb: fix init regression with SoCs
rtl8192{ce,cu,de,se}: avoid problems because of possible ERFOFF -> ERFSLEEP transition
mac80211: fix another race in aggregation start
fsl_pq_mdio: Clean up tbi address configuration
ppp: fix pptp double release_sock in pptp_bind()
net/fec: fix the use of pdev->id
ath9k: fix check for antenna diversity support
batman-adv: delete global entry in case of roaming
batman-adv: in case of roaming mark the client with TT_CLIENT_ROAM
Bluetooth: Correct version check in hci_setup
btusb: fix a memory leak in btusb_send_frame()
Bluetooth: bnep: Fix module reference
Bluetooth: cmtp: Fix module reference
Bluetooth: btmrvl: support Marvell Bluetooth device SD8797
* 'drm-intel-fixes' of git://people.freedesktop.org/~keithp/linux:
drm/i915/dp: Dither down to 6bpc if it makes the mode fit
drm/i915: enable semaphores on per-device defaults
drm/i915: don't set unpin_work if vblank_get fails
drm/i915: By default, enable RC6 on IVB and SNB when reasonable
iommu: Export intel_iommu_enabled to signal when iommu is in use
drm/i915/sdvo: Include LVDS panels for the IS_DIGITAL check
drm/i915: prevent division by zero when asking for chipset power
drm/i915: add PCH info to i915_capabilities
drm/i915: set the right SDVO transcoder for CPT
drm/i915: no-lvds quirk for ASUS AT5NM10T-I
drm/i915: Treat pre-gen4 backlight duty cycle value consistently
drm/i915: Hook up Ivybridge eDP
drm/i915: add multi-threaded forcewake support
* 'gpio/merge' of git://git.secretlab.ca/git/linux-2.6:
gpio: Fix DA9052 GPIO build errors.
gpio: mpc8xxx: don't allow input-only pins to be output for MPC5121
gpio-ml-ioh: Add the irq_disable/irq_enable hooks for ml-ioh irq chip
gpio-ml-ioh: fix a bug in the interrupt handler
gpio: pl061: drop extra check for NULL platform_data
* 'for-linus' of git://git.kernel.dk/linux-block:
block: don't kick empty queue in blk_drain_queue()
block/swim3: Locking fixes
loop: Fix discard_alignment default setting
cfq-iosched: fix cfq_cic_link() race confition
cfq-iosched: free cic_index if blkio_alloc_blkg_stats fails
cciss: fix flush cache transfer length
cciss: Add IRQF_SHARED back in for the non-MSI(X) interrupt handler
loop: fix loop block driver discard and encryption comment
block: initialize request_queue's numa node during
Some active adaptors (VGA usually) only have two lanes at 2.7GHz.
That's a maximum pixel clock of 144MHz at 8bpc, but 192MHz at 6bpc.
Fixes Asus UX31 panel being black at startup due to no valid modes since
dc22ee6fc18ce0f15424e753e8473c306ece95c1.
v2: Rebased to current code, resulting in the fix applying to EDP panels as
well. Also changed from spatio-temporal to just spatial dithering on
pre-ironlake, to be conssitent (and less visual flicker)
Signed-off-by: Adam Jackson <ajax@redhat.com>
Signed-off-by: Eric Anholt <eric@anholt.net>
Tested-by: Eric Anholt <eric@anholt.net>
Tested-by: Dirk Hohndel <hohndel@infradead.org>
Signed-off-by: Keith Packard <keithp@keithp.com>
This adds a default setting for semaphores parameter, and enables
semaphores by default on IVB.
For now, as semaphores interaction with VTd causes random issues on
SNB, we do not enable them by default. But they can still be enabled
via the semaphores=1 kernel parameter.
v2: enables semaphores on SNB when IO remapping is disabled, with base
on Keith Packard patch.
CC: Daniel Vetter <daniel.vetter@ffwll.ch>
CC: Ben Widawsky <ben@bwidawsk.net>
CC: Keith Packard <keithp@keithp.com>
CC: Jesse Barnes <jbarnes@virtuousgeek.org>
CC: Chris Wilson <chris@chris-wilson.co.uk>
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=42696
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=40564
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=41353
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=38862
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Signed-off-by: Eugeni Dodonov <eugeni.dodonov@intel.com>
This fixes a race where we may try to finish a page flip and decrement
the refcount even if our vblank_get failed and we ended up with a
spurious flip pending interrupt.
Fixes https://bugs.freedesktop.org/show_bug.cgi?id=34211.
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
RC6 should always work on IVB, and should work on SNB whenever IO
remapping is disabled. RC6 never works on Ironlake. Make the default
value for the parameter follow these guidelines. Setting the value
to either 0 or 1 will force the specified behavior.
Reviewed-by: Kenneth Graunke <kenneth@whitecape.org>
Reviewed-by: Eugeni Dodonov <eugeni.dodonov@intel.com>
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=38567
Cc: Ted Phelps <phelps@gnusto.com>
Cc: Peter <pab1612@gmail.com>
Cc: Lukas Hejtmanek <xhejtman@fi.muni.cz>
Cc: Andrew Lutomirski <luto@mit.edu>
In i915 driver, we do not enable either rc6 or semaphores on SNB when dmar
is enabled. The new 'intel_iommu_enabled' variable signals when the
iommu code is in operation.
Cc: Eugeni Dodonov <eugeni.dodonov@intel.com>
We were checking whether the supplied edid matched the connector it was
read from. We do this in case a DDC read returns an EDID for another
device on a multifunction or otherwise interesting card. However, we
failed to include LVDS as a digital device and so rejecting an otherwise
valid EDID.
Fixes the detection of the secondary SDVO LVDS panel on the Libretto
W105.
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Reviewed-by: Adam Jackson <ajax@redhat.com>
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=39216
This prevents an in-kernel division by zero which happens when we are
asking for i915_chipset_val too quickly, or within a race condition
between the power monitoring thread and userspace accesses via debugfs.
The issue can be reproduced easily via the following command:
while ``; do cat /sys/kernel/debug/dri/0/i915_emon_status; done
This is particularly dangerous because it can be triggered by
a non-privileged user by just reading the debugfs entry.
This issue was also found independently by Konstantin Belousov
<kostikbel@gmail.com>, who proposed a similar patch.
Reported-by: Konstantin Belousov <kostikbel@gmail.com>
Acked-by: Keith Packard <keithp@keithp.com>
Signed-off-by: Paulo Zanoni <paulo.r.zanoni@intel.com>
v2: add a CPT-specific macro, make code cleaner
v3: fix commit message
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=41272
Cc: stable@kernel.org
https://bugzilla.redhat.com/show_bug.cgi?id=750006
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/ibft
* 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/ibft:
ibft: Fix finding IBFT ACPI table on UEFI
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
* 'staging-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging:
staging: r8712u: Add new USB ID
staging: tidspbridge: request dmtimer clocks on init
staging: tidspbridge: include module.h by default
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
* 'usb-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb:
USB: option: Removing one bogus and adding some new Huawei combinations
USB: cdc-acm: add IDs for Motorola H24 HSPA USB module.
usb: option: Add Huawei E398 controlling interfaces
usb: renesas_usbhs: add hcd->has_tt for low/full speed
usb: renesas_usbhs: typofix: irq_dtch control DTCHE
usb: gadget: storage: release superspeed descriptors.
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen
* 'stable/for-linus-fixes-3.2' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
xen/swiotlb: Use page alignment for early buffer allocation.
xen: only limit memory map to maximum reservation for domain 0.
This patch is functionally tested on Samsung SMDKV6410.
Signed-off-by: David Dajun Chen <dchen@diasemi.com>
Signed-off-by: Ashish Jangam <ashish.jangam@kpitcummins.com>
[grant.likely: don't create an unnecessary header file]
This fixes an odd bug found on a Dell PowerEdge 1850/0RC130
(BIOS A05 01/09/2006) where all of the modules doing pci_set_dma_mask
would fail with:
ata_piix 0000:00:1f.1: enabling device (0005 -> 0007)
ata_piix 0000:00:1f.1: can't derive routing for PCI INT A
ata_piix 0000:00:1f.1: BMDMA: failed to set dma mask, falling back to PIO
The issue was the Xen-SWIOTLB was allocated such as that the end of
buffer was stradling a page (and also above 4GB). The fix was
spotted by Kalev Leonid which was to piggyback on git commit
e79f86b2ef9c0a8c47225217c1018b7d3d90101c "swiotlb: Use page alignment
for early buffer allocation" which:
We could call free_bootmem_late() if swiotlb is not used, and
it will shrink to page alignment.
So alloc them with page alignment at first, to avoid lose two pages
And doing that fixes the outstanding issue.
CC: stable@kernel.org
Suggested-by: "Kalev, Leonid" <Leonid.Kalev@ca.com>
Reported-and-Tested-by: "Taylor, Neal E" <Neal.Taylor@ca.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
During test of one IB card with guest VM, found that, msi is not
initialized properly.
It turns out __write_msi_msg will do nothing if device current_state is
not PCI_D0. And, that pci device does not have pm_cap in guest VM.
There is an error in setting of power state to PCI_D0 in
pci_enable_device(), but error is not returned for this. Following is
code flow:
pci_enable_device() --> __pci_enable_device_flags() -->
do_pci_enable_device() --> pci_set_power_state() -->
__pci_start_power_transition()
We have following condition inside __pci_start_power_transition():
if (platform_pci_power_manageable(dev)) {
error = platform_pci_set_power_state(dev, state);
if (!error)
pci_update_current_state(dev, state);
} else {
error = -ENODEV;
/* Fall back to PCI_D0 if native PM is not supported */
if (!dev->pm_cap)
dev->current_state = PCI_D0;
Here, from platform_pci_set_power_state(), acpi_pci_set_power_state() is
getting called and that is failing with ENODEV because of following
condition:
if (!handle || ACPI_SUCCESS(acpi_get_handle(handle, "_EJ0",&tmp)))
return -ENODEV;
Because of that, pci_update_current_state() is not getting called.
With this patch, if device power state can not be set via
platform_pci_set_power_state and that device does not have native pm
support, then PCI device power state will be set to PCI_D0.
-v2: This also reverts 47e9037ac16637cd7f12b8790ea7ce6680e42168, as it's
not needed after this change.
Acked-by: "Rafael J. Wysocki" <rjw@sisk.pl>
Signed-off-by: Ajaykumar Hotchandani<ajaykumar.hotchandani@oracle.com>
Signed-off-by: Yinghai Lu<yinghai.lu@oracle.com>
Add USB ID for Sitecom WLA-2000 v1.001 WLAN.
Reported-and-tested-by: Roland Gruber <post@rolandgruber.de>
Cc: Stable <stable@vger.kernel.org>
Given that dm timer framework doesn't support request of clocks
by soft | hard irqs because some recent changes, tidspbridge needs
to request its clocks on init and enable/disable them on demand.
This was first seen on 3.2-rc1.
Signed-off-by: Omar Ramirez Luna <omar.ramirez@ti.com>
Fixes compilation break when compiled as part of the kernel:
drivers/staging/tidspbridge/rmgr/drv_interface.c:134: error: expected declaration specifiers or '...' before string constant
drivers/staging/tidspbridge/rmgr/drv_interface.c:134: warning: data definition has no type or storage class
drivers/staging/tidspbridge/rmgr/drv_interface.c:134: warning: type defaults to 'int' in declaration of 'MODULE_AUTHOR'
drivers/staging/tidspbridge/rmgr/drv_interface.c:134: warning: function declaration isn't a prototype
drivers/staging/tidspbridge/rmgr/drv_interface.c:135: error: expected declaration specifiers or '...' before string constant
drivers/staging/tidspbridge/rmgr/drv_interface.c:135: warning: data definition has no type or storage class
drivers/staging/tidspbridge/rmgr/drv_interface.c:135: warning: type defaults to 'int' in declaration of 'MODULE_LICENSE'
drivers/staging/tidspbridge/rmgr/drv_interface.c:135: warning: function declaration isn't a prototype
drivers/staging/tidspbridge/rmgr/drv_interface.c:136: error: expected declaration specifiers or '...' before string constant
drivers/staging/tidspbridge/rmgr/drv_interface.c:136: warning: data definition has no type or storage class
drivers/staging/tidspbridge/rmgr/drv_interface.c:136: warning: type defaults to 'int' in declaration of 'MODULE_VERSION'
drivers/staging/tidspbridge/rmgr/drv_interface.c:136: warning: function declaration isn't a prototype
drivers/staging/tidspbridge/rmgr/drv_interface.c: In function 'omap34_xx_bridge_probe':
drivers/staging/tidspbridge/rmgr/drv_interface.c:359: error: 'THIS_MODULE' undeclared (first use in this function)
drivers/staging/tidspbridge/rmgr/drv_interface.c:359: error: (Each undeclared identifier is reported only once
drivers/staging/tidspbridge/rmgr/drv_interface.c:359: error: for each function it appears in.)
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client:
ceph: add missing spin_unlock at ceph_mdsc_build_path()
ceph: fix SEEK_CUR, SEEK_SET regression
crush: fix mapping calculation when force argument doesn't exist
ceph: use i_ceph_lock instead of i_lock
rbd: remove buggy rollback functionality
rbd: return an error when an invalid header is read
ceph: fix rasize reporting by ceph_show_options
Commit 0d52f54e2ef64c189dedc332e680b2eb4a34590a (PCI / ACPI: Make
acpiphp ignore root bridges using PCIe native hotplug) added code
that made the acpiphp driver completely ignore PCIe root complexes
for which the kernel had been granted control of the native PCIe
hotplug feature by the BIOS through _OSC. Unfortunately, however,
this was a mistake, because on some systems there were PCI bridges
supporting PCI (non-PCIe) hotplug under such root complexes and
those bridges should have been handled by acpiphp.
For this reason, revert the changes made by the commit mentioned
above and make register_slot() in drivers/pci/hotplug/acpiphp_glue.c
avoid registering hotplug slots for PCIe ports that belong to
root complexes with native PCIe hotplug enabled (which means that
the BIOS has granted the kernel control of this feature for the
given root complex). This is reported to address the original
issue fixed by commit 0d52f54e2ef64c189dedc332e680b2eb4a34590a and
to work on the system where that commit broke things.
Add a 5121-custom reject if an input-only pin is requested to be output
(see 18.3.1.1 in the refman). Also, rewrite mach-specific quirk setup to
consume less lines which scales better.
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
[grant.likely: Fixed build error]
These hooks will be needed by the general disabl/enable_irq();
Signed-off-by: Feng Tang <feng.tang@intel.com>
GPIO's irq action's dev_id is set to the first struct ioh_gpio chip,
so when loop checking the 8 chips, the "chip" should be changed
according.
In adding DT binding support, the check for NULL platform_data got added
back in inadvertently, so remove it.
Huawei use the product code HUAWEI_PRODUCT_E353 (0x1506) for a
number of different devices, which each can appear with a number
of different descriptor sets. Different types of interfaces
can be identified by looking at the subclass and protocol fields
Subclass 1 protocol 8 is actually the data interface of a CDC
ECM set, with subclass 1 protocol 9 as the control interface.
Neither support serial data communcation, and cannot therefore
be supported by this driver.
At the same time, add a few other sets which appear if the
device is configured in "Windows mode" using this modeswitch
message:
55534243000000000000000000000011060000000100000000000000000000
Signed-off-by: Bjørn Mork <bjorn@mork.no>
Cc: stable <stable@vger.kernel.org>
Found one system with UEFI/iBFT, kernel does not detect the iBFT during
iscsi_ibft module loading.
Root cause: on x86 (UEFI), we are calling of find_ibft_region() much earlier
- specifically in setup_arch() before ACPI is enabled.
Try to split acpi checking code out and call that later
At that time ACPI iBFT already get permanent mapped with ioremap.
So isa_virt_to_bus() will get wrong phys from right virt address.
We could just skip that phys address printing.
For legacy one, print the found address early.
-v2: update comments and description according to Konrad.
-v3: fix problem about module use case that is found by Konrad.
-v4: use acpi_get_table() instead of acpi_table_parse() to handle module use case that is found by Konrad again..
Signed-off-by: Konrad Rzeszutek Wilk <konrad@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging
* 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging:
hwmon: (jz4740) Staticise jz4740_hwmon_driver
hwmon: (jz4740) fix signedness bug
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc:
mmc: core: Fix deadlock when the CONFIG_MMC_UNSAFE_RESUME is not defined
mmc: sdhci-s3c: Remove old and misprototyped suspend operations
mmc: tmio: fix clock gating on platforms with a .set_pwr() method
mmc: sh_mmcif: fix clock gating on platforms with a .down_pwr() method
mmc: core: Fix typo at mmc_card_sleep
mmc: core: Fix power_off_notify during suspend
mmc: core: Fix setting power notify state variable for non-eMMC
mmc: core: Add quirk for long data read time
mmc: Add module.h include to sdhci-cns3xxx.c
mmc: mxcmmc: fix falling back to PIO
mmc: omap_hsmmc: DMA unmap only once in case of MMC error
Add USB IDs for Motorola H24 HSPA USB module.
Signed-off-by: Krzysztof Hałasa <khalasa@piap.pl>
Acked-by: Oliver Neukum <oneukum@suse.de>
This patch adds the controlling interfaces for the Huawei E398.
Thanks to Bjørn Mork <bjorn@mork.no> for extracting the interface
numbers from the windows driver.
Signed-off-by: Alex Hermann <alex@wenlex.nl>
It is not used outside this driver so no need to make the symbol global.
Acked-by: Lars-Peter Clausen <lars@metafoo.de>
Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
wait_for_completion_interruptible_timeout() may return negative value.
In this case, checking if (t > 0) will return true if t is unsigned.
Cc: stable@kernel.org (3.0+)
The old PowerMac swim3 driver has some "interesting" locking issues,
using a private lock and failing to lock the queue before completing
requests, which triggered WARN_ONs among others.
This rips out the private lock, makes everything operate under the
block queue lock, and generally makes things simpler.
We used to also share a queue between the two possible instances which
was problematic since we might pick the wrong controller in some cases,
so make the queue and the current request per-instance and use
queuedata to point to our private data which is a lot cleaner.
We still share the queue lock but then, it's nearly impossible to actually
use 2 swim3's simultaneously: one would need to have a Wallstreet
PowerBook, the only machine afaik with two of these on the motherboard,
and populate both hotswap bays with a floppy drive (the machine ships
only with one), so nobody cares...
While at it, add a little fix to clear up stale interrupts when loading
the driver or plugging a floppy drive in a bay.
Low/Full speed device is not recognized without this patch
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
Release superspeed mass storage descriptors memory
when the function is unbind.
Signed-off-by: Yu Xu <yuxu@marvell.com>
Acked-by: Michal Nazarewicz <mina86@mina86.com>
mmc_suspend_host() tries to claim host during suspend
and release it only when the bus suspend operation is
compeleted. If CONFIG_MMC_UNSAFE_RESUME is defined and
the host is flagged as removable, mmc_suspend_host()
tries to remove the card. In this process, the file system
sync can get blocked trying to acquire host which is already
claimed by mmc_suspend_host() causing deadlock.
Fix this deadlock by releasing host before ->remove() is called.
Signed-off-by: Sujit Reddy Thumma <sthumma@codeaurora.org>
Acked-by: Ulf Hansson <ulf.hansson@stericsson.com>
Signed-off-by: Chris Ball <cjb@laptop.org>
Now that the driver is using dev_pm_ops the suspend operations in the
platform_driver structure won't get called so don't need to be there,
and certainly shouldn't be the same function as dev_pm_ops since the
signatures are different.
Acked-by: Jaehoon Chung <jh80.chung@samsung.com>
Do not power down the card in .set_ios(), unless MMC_POWER_OFF is
requested. This fixes the SDHI functionality on ecovec.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
