git://git.kernel.org/pub/scm/linux/kernel/git/iwlwifi/iwlwifi-fixes
Fix a copy paste error in iwl_calc_basic_rates which leads
to a wrong calculation of CCK basic rates.
Cc: stable@vger.kernel.org
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
In target mode, sent sk_buff were not freed in pn533_tm_send_complete
Signed-off-by: Thierry Escande <thierry.escande@linux.intel.com>
cmd is allocated in pn533_dep_link_up and passed as an arg to
pn533_send_cmd_frame_async together with a complete cb.
arg is passed to the cb and must be kfreed there.
Signed-off-by: Waldemar Rymarkiewicz <waldemar.rymarkiewicz@tieto.com>
cmd was freed in pn533_dep_link_up regardless of
pn533_send_cmd_frame_async return code. Cmd is passed as argument to
pn533_in_dep_link_up_complete callback and should be freed there.
Signed-off-by: Szymon Janc <szymon.janc@tieto.com>
In pn533_wq_cmd command was removed from list without cmd_lock held
(race with pn533_send_cmd_frame_async) which could lead to list
corruption. Delete command from list before releasing lock.
Commit "ath9k: improve suspend/resume reliability" broke ath9k_htc
and bringing up the device would hang indefinitely. Fix this.
Signed-off-by: Sujith Manoharan <c_manoha@qca.qualcomm.com>
This can happen when we shut down suddenly an interface.
When host_sleep_config command fails we should return error to
MMC core to indicate the failure for our device.
The misspelled variable is also removed as it's redundant.
Cc: "3.0+" <stable@vger.kernel.org>
Signed-off-by: Bing Zhao <bzhao@marvell.com>
Reported by Tim Shepard:
I was seeing sporadic failures (wedgeups), and the majority of those
failures I saw printed the printouts in mwifiex_cmd_timeout_func with
cmd = 0xe5 which is CMD_802_11_HS_CFG_ENH. When this happens, two
minutes later I get notified that the rtcwake thread is blocked, like
this:
INFO: task rtcwake:3495 blocked for more than 120 seconds.
To get the hung thread unblocked we wake up the cmd wait queue and
cancel the ioctl.
Cc: "3.4+" <stable@vger.kernel.org>
Reported-by: Tim Shepard <shep@laptop.org>
This is an ISY IWL 2000. Probably a clone of Belkin F7D1102 050d:1102.
Its FCC ID is the same.
Signed-off-by: Albert Pool <albertpool@solcon.nl>
Acked-by: Larry Finger <Larry.Finger@lwfinger.net>
The old ifdef CONFIG_BRCMFISCAN looks wrong to me and it makes more
sense when CONFIG_BRCMISCAN is used.
This patch was just compile tested by me, but not runtime tested.
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
Acked-by: Franky Lin <frankyl@broadcom.com>
git://git.kernel.org/pub/scm/linux/kernel/git/bluetooth/bluetooth
When the firmware is in SNIFFER mode, it leaves
the FCS at the end of frame. Not telling mac80211
means it won't add the right flag to the radiotap
header and that confuses wireshark.
Since mac80211 doesn't have a per-packet flag, set
the HW flag dynamically. This works as the monitor
vif can only be present in the driver by itself.
This fixes a regression introduced by my
commit 578977264199de9815ace51ade87cec4894cf010
Author: Johannes Berg <johannes.berg@intel.com>
Date: Fri May 11 10:53:18 2012 +0200
iwlwifi: support explicit monitor interface
Cc: stable@vger.kernel.org [3.5+]
Reported-by: MARK PHILLIPS <mark.phillips@virgin.net>
Reviewed-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
Added Atheros AR3011 internal bluetooth device found in Sony VAIO VPCEH to the
devices list.
Before this, the bluetooth module was identified as an Foxconn / Hai bluetooth
device [0489:e027], now it claims to be an AtherosAR3011 Bluetooth
[0cf3:3005].
T: Bus=01 Lev=02 Prnt=02 Port=04 Cnt=02 Dev#= 4 Spd=12 MxCh= 0
D: Ver= 1.10 Cls=e0(wlcon) Sub=01 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=0489 ProdID=e027 Rev= 0.01
C:* #Ifs= 2 Cfg#= 1 Atr=e0 MxPwr=100mA
I:* If#= 0 Alt= 0 #EPs= 3 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=81(I) Atr=03(Int.) MxPS= 16 Ivl=1ms
E: Ad=82(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
I:* If#= 1 Alt= 0 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=83(I) Atr=01(Isoc) MxPS= 0 Ivl=1ms
E: Ad=03(O) Atr=01(Isoc) MxPS= 0 Ivl=1ms
I: If#= 1 Alt= 1 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=83(I) Atr=01(Isoc) MxPS= 9 Ivl=1ms
E: Ad=03(O) Atr=01(Isoc) MxPS= 9 Ivl=1ms
I: If#= 1 Alt= 2 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=83(I) Atr=01(Isoc) MxPS= 17 Ivl=1ms
E: Ad=03(O) Atr=01(Isoc) MxPS= 17 Ivl=1ms
I: If#= 1 Alt= 3 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=83(I) Atr=01(Isoc) MxPS= 25 Ivl=1ms
E: Ad=03(O) Atr=01(Isoc) MxPS= 25 Ivl=1ms
I: If#= 1 Alt= 4 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=83(I) Atr=01(Isoc) MxPS= 33 Ivl=1ms
E: Ad=03(O) Atr=01(Isoc) MxPS= 33 Ivl=1ms
I: If#= 1 Alt= 5 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=83(I) Atr=01(Isoc) MxPS= 49 Ivl=1ms
E: Ad=03(O) Atr=01(Isoc) MxPS= 49 Ivl=1ms
Signed-off-by: Marcos Chaparro <marcos@mrkindustries.com.ar>
Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
To let mac80211 clean up any TX information when
a frame is dropped, use ieee80211_free_txskb().
The RX replenish code doesn't handle DMA mapping failures,
which will cause issues if there actually is a failure. This
was reported by Shuah Khan who found a DMA mapping framework
warning ("device driver failed to check map error").
Reported-by: Shuah Khan <shuah.khan@hp.com>
The ath9k xmit functions for AMPDUs can send frames as non-aggregate in case
only one frame is currently available. The client will then answer using a
normal Ack instead of a BlockAck. This acknowledgement has no TID stored and
therefore the hardware is not able to provide us the corresponding TID.
The TID set by the hardware in the tx status descriptor has to be seen as
undefined and not as a valid TID value for normal acknowledgements. Doing
otherwise results in a massive amount of retransmissions and stalls of
connections.
Users may experience low bandwidth and complete connection stalls in
environments with transfers using multiple TIDs.
This regression was introduced in b11b160defc48e4daa283f785192ea3a23a51f8e
("ath9k: validate the TID in the tx status information").
Signed-off-by: Sven Eckelmann <sven@narfation.org>
Signed-off-by: Simon Wunderlich <siwu@hrz.tu-chemnitz.de>
Acked-by: Felix Fietkau <nbd@openwrt.org>
Some hardware has correct (!= 0xff) value of tssi_bounds[4] in the
EEPROM, but step is equal to 0xff. This results on ridiculous delta
calculations and completely broke TX power settings.
Reported-and-tested-by: Pavel Lucik <pavel.lucik@gmail.com>
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
Acked-by: Ivo van Doorn <IvDoorn@gmail.com>
bf->bf_next is only while buffers are chained as part of an A-MPDU
in the tx queue. When a tid queue is flushed (e.g. on tearing down
an aggregation session), frames can be enqueued again as normal
transmission, without bf_next being cleared. This can lead to the
old pointer being dereferenced again later.
This patch might fix crashes and "Failed to stop TX DMA!" messages.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
When b43 fails to find firmware when loaded, a subsequent unload will
oops due to calling ieee80211_unregister_hw() when the corresponding
register call was never made.
Commit 2d838bb608e2d1f6cb4280e76748cb812dc822e7 fixed the same problem
for b43legacy.
Tested-by: Markus Kanet <dvmailing@gmx.eu>
Cc: Stable <stable@vger.kernel.org> [V3.3.0+ (the patch will need to be refactored)]
Cc: Markus Kanet <dvmailing@gmx.eu>
De-reference and deallocate scan state on failure.
Signed-off-by: Paul Stewart <pstew@chromium.org>
Tested-by: Paul Stewart <pstew@chromium.org>
Reviewed-by: Ryan Cairns <rtc@chromium.org>
Signed-off-by: Amitkumar Karwar <akarwar@marvell.com>
Previous patch "mwifiex: return -EBUSY if scan request cannot.."
corrected regular scan request only. There is another case for
specific scan that needs the same handling.
Also, removed !req_ssid check as it has already been validated
by caller.
Fix a samtch warnings catched by Fengguang's 0-DAY system:
+ drivers/net/wireless/brcm80211/brcmfmac/wl_cfg80211.c:3572 brcmf_cfg80211_sched_scan_start() error: we previously assumed 'request' could be null (see line 3571)
Cc: John W. Linville <linville@tuxdriver.com>
Signed-off-by: Yuanhan Liu <yuanhan.liu@linux.intel.com>
This reverts commit a240dc7b3c7463bd60cf0a9b2a90f52f78aae0fd.
This commit is reducing tx power by at least 10 db on some devices,
e.g. the Buffalo WZR-HP-G450H.
Cc: rmanohar@qca.qualcomm.com
Roger says, Ubiquiti produce 2 versions of their WiFiStation USB adapter. One
has an internal antenna, the other has an external antenna and
name suffix EXT. They have separate USB ids and in distribution
openSUSE 12.2 (kernel 3.4.6), file /usr/share/usb.ids shows:
0cf3 Atheros Communications, Inc.
b002 Ubiquiti WiFiStation 802.11n [Atheros AR9271]
b003 Ubiquiti WiFiStationEXT 802.11n [Atheros AR9271]
Add b002 Ubiquiti WiFiStation in the PID/VID list.
Reported-by: Roger Price <ath9k@rogerprice.org>
Signed-off-by: Mohammed Shafi Shajakhan <mohammed@qca.qualcomm.com>
Patch fixes warnings like below happened on resume:
WARNING: at net/mac80211/driver-ops.h:12 check_sdata_in_driver+0x32/0x34()
Problem is that in __ieee80211_susped() we remove sdata (i.e wlan0
interface) and then during resume we call usb_unbind_interface() ->
ieee80211_unregister_hw() with sdata removed.
Patch fixes problem by adding .reset_resume calback, hence we do not
unbind usb device on resume. This callback can be the same as normal
.resume callback, sice we do all needed initalization during interface
start, which is performed on resume [ ieee80211_resume() ->
ieee80211_reconfig() -> rt2x00mac_start() -> rt2x00lib_start ].
Resolves:
https://bugzilla.kernel.org/show_bug.cgi?id=48041
Reported-by: David Herrmann <dh.herrmann@googlemail.com>
Reported-and-tested-by: Stephen Boyd <bebarino@gmail.com>
Acked-by: Gertjan van Wingerde <gwingerde@gmail.com>
If _rtl_usb_receive fails, the device is
probably not ready. Hence the error code
should be passed to the caller, so it can
react accordingly and notify the user.
Signed-off-by: Christian Lamparter <chunkeey@googlemail.com>
The channel switch command for 6000 series devices
is larger than the maximum inline command size of
320 bytes. The command is therefore refused with a
warning. Fix this by allocating the command and
using the NOCOPY mechanism.
Cc: stable@kernel.org
The driver does not count space of radiotap fields when allocating skb for
radiotap packet. This leads to kernel panic with the following call trace:
[67607.676067] [<c152f90f>] error_code+0x67/0x6c
[67607.676067] [<c142f831>] ? skb_put+0x91/0xa0
[67607.676067] [<f8cf5e5b>] ? ipw_handle_promiscuous_tx+0x16b/0x2d0 [ipw2200]
[67607.676067] [<f8cf5e5b>] ipw_handle_promiscuous_tx+0x16b/0x2d0 [ipw2200]
[67607.676067] [<f8cf899b>] ipw_net_hard_start_xmit+0x8b/0x90 [ipw2200]
[67607.676067] [<f8741c5a>] libipw_xmit+0x55a/0x980 [libipw]
[67607.676067] [<c143d3e8>] dev_hard_start_xmit+0x218/0x4d0
This bug was found by VittGam.
https://bugzilla.kernel.org/show_bug.cgi?id=43255
Signed-off-by: Stanislav Yakovlev <stas.yakovlev@gmail.com>
When cores are unregistered, entries
need to be removed from cores list in a safe manner.
Reported-by: Stanislaw Gruszka <sgruszka@redhat.com>
Reviewed-by: Arend Van Spriel <arend@broadcom.com>
Signed-off-by: Piotr Haber <phaber@broadcom.com>
The problem here is that we loop until "remained_buf_len" is less than
zero, but since it is unsigned, it never is.
"remained_buf_len" has to be large enough to hold the value from
"mgmt_ie_buf_len". That variable is type u32, but it only holds small
values so I have changed to both variables to int.
Also I removed the bogus initialization from "mgmt_ie_buf_len" so that
GCC can detect if it is used unitialized. I moved the declaration of
"remained_buf_len" closer to where it is used so it's easier to read.
Reviewed-by: Pieter-Paul Giesberts <pieterpg@broadcom.com>
Reviewed-by: Hante Meuleman <meuleman@broadcom.com>
Signed-off-by: Franky Lin <frankyl@broadcom.com>
The mode of WiFi dongle should be initialized in brcmf_cfg80211_up
which get called when network interface is brought up. Otherwise
brcmf_cfg80211_get_station would return error.
Channel reported in scan results passed to cfg80211 is control
channel. But chanspec is reported while notifying cfg80211 about
roamed update. Cfg80211 complains because it could not find the
bss in the list. Report control channel while calling
cfg80211_roamed.
in brcmf_usb_probe_cb only return code ENOLINK was seen as an
error. This is wrong, all error codes should be returned to usb
subsystem.
Signed-off-by: Hante Meuleman <meuleman@broadcom.com>
Pull md updates from NeilBrown:
- "discard" support, some dm-raid improvements and other assorted bits
and pieces.
* tag 'md-3.7' of git://neil.brown.name/md: (29 commits)
md: refine reporting of resync/reshape delays.
md/raid5: be careful not to resize_stripes too big.
md: make sure manual changes to recovery checkpoint are saved.
md/raid10: use correct limit variable
md: writing to sync_action should clear the read-auto state.
Subject: [PATCH] md:change resync_mismatches to atomic64_t to avoid races
md/raid5: make sure to_read and to_write never go negative.
md: When RAID5 is dirty, force reconstruct-write instead of read-modify-write.
md/raid5: protect debug message against NULL derefernce.
md/raid5: add some missing locking in handle_failed_stripe.
MD: raid5 avoid unnecessary zero page for trim
MD: raid5 trim support
md/bitmap:Don't use IS_ERR to judge alloc_page().
md/raid1: Don't release reference to device while handling read error.
raid: replace list_for_each_continue_rcu with new interface
add further __init annotations to crypto/xor.c
DM RAID: Fix for "sync" directive ineffectiveness
DM RAID: Fix comparison of index and quantity for "rebuild" parameter
DM RAID: Add rebuild capability for RAID10
DM RAID: Move 'rebuild' checking code to its own function
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull TPM bugfixes from James Morris.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security:
tpm: Propagate error from tpm_transmit to fix a timeout hang
driver/char/tpm: fix regression causesd by ppi
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux
Pull ACPI & Thermal updates from Len Brown:
"The generic Linux thermal layer is gaining some new capabilities
(generic cooling via cpufreq) and some new customers (ARM).
Also, an ACPI EC bug fix plus a regression fix."
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux: (30 commits)
tools/power/acpi/acpidump: remove duplicated include from acpidump.c
ACPI idle, CPU hotplug: Fix NULL pointer dereference during hotplug
cpuidle / ACPI: fix potential NULL pointer dereference
ACPI: EC: Add a quirk for CLEVO M720T/M730T laptop
ACPI: EC: Make the GPE storm threshold a module parameter
thermal: Exynos: Fix NULL pointer dereference in exynos_unregister_thermal()
Thermal: Fix bug on cpu_cooling, cooling device's id conflict problem.
thermal: exynos: Use devm_* functions
ARM: exynos: add thermal sensor driver platform data support
thermal: exynos: register the tmu sensor with the kernel thermal layer
thermal: exynos5: add exynos5250 thermal sensor driver support
hwmon: exynos4: move thermal sensor driver to driver/thermal directory
thermal: add generic cpufreq cooling implementation
Fix a build error.
thermal: Fix potential NULL pointer accesses
thermal: add Renesas R-Car thermal sensor support
thermal: fix potential out-of-bounds memory access
Thermal: Introduce locking for cdev.thermal_instances list.
Thermal: Unify the code for both active and passive cooling
Thermal: Introduce simple arbitrator for setting device cooling state
git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/kgdb
Pull KGDB/KDB fixes and cleanups from Jason Wessel:
"Cleanups
- Clean up compile warnings in kgdboc.c and x86/kernel/kgdb.c
- Add module event hooks for simplified debugging with gdb
Fixes
- Fix kdb to stop paging with 'q' on bta and dmesg
- Fix for data that scrolls off the vga console due to line wrapping
when using the kdb pager
New
- The debug core registers for kernel module events which allows a
kernel aware gdb to automatically load symbols and break on entry
to a kernel module
- Allow kgdboc=kdb to setup kdb on the vga console"
* tag 'for_linus-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/kgdb:
tty/console: fix warnings in drivers/tty/serial/kgdboc.c
kdb,vt_console: Fix missed data due to pager overruns
kdb: Fix dmesg/bta scroll to quit with 'q'
kgdboc: Accept either kbd or kdb to activate the vga + keyboard kdb shell
kgdb,x86: fix warning about unused variable
mips,kgdb: fix recursive page fault with CONFIG_KPROBES
kgdb: Add module event hooks
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc
Pull two more mmc changes from Chris Ball:
- Disintegrate UAPI
- fix a mismerge that caused a build error.
* tag 'mmc-merge-for-3.7-rc1-part2' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc:
UAPI: (Scripted) Disintegrate include/linux/mmc
mmc: mxs-mmc: Fix merge issue causing build error
git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-dm
Pull device-mapper changes from Alasdair G Kergon:
"Remove the power-of-2 block size constraint on discards in dm thin
provisioning and factor the bio_prison code out into a separate module
(for sharing with the forthcoming cache target).
Use struct bio's front_pad to eliminate the use of one separate
mempool by bio-based devices.
A few other tiny clean-ups."
* tag 'dm-3.7-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-dm:
dm: store dm_target_io in bio front_pad
dm thin: move bio_prison code to separate module
dm thin: prepare to separate bio_prison code
dm thin: support discard with non power of two block size
dm persistent data: convert to use le32_add_cpu
dm: use ACCESS_ONCE for sysfs values
dm bufio: use list_move
dm mpath: fix check for null mpio in end_io fn
Pull misc SCSI updates from James Bottomley:
"This is an assorted set of stragglers into the merge window with
driver updates for megaraid_sas, lpfc, bfi and mvumi. It also
includes some fairly major fixes for virtio-scsi (scatterlist init),
scsi_debug (off by one error), storvsc (use after free) and qla2xxx
(potential deadlock).
Signed-off-by: James Bottomley <JBottomley@Parallels.com>"
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (49 commits)
[SCSI] storvsc: Account for in-transit packets in the RESET path
[SCSI] qla2xxx: fix potential deadlock on ha->hardware_lock
[SCSI] scsi_debug: Fix off-by-one bug when unmapping region
[SCSI] Shorten the path length of scsi_cmd_to_driver()
[SCSI] virtio-scsi: support online resizing of disks
[SCSI] virtio-scsi: fix LUNs greater than 255
[SCSI] virtio-scsi: initialize scatterlist structure
[SCSI] megaraid_sas: Version, Changelog, Copyright update
[SCSI] megaraid_sas: Remove duplicate code
[SCSI] megaraid_sas: Add SystemPD FastPath support
[SCSI] megaraid_sas: Add array boundary check for SystemPD
[SCSI] megaraid_sas: Load io_request DataLength in bytes
[SCSI] megaraid_sas: Add module param for configurable MSI-X vector count
[SCSI] megaraid_sas: Remove un-needed completion_lock spinlock calls
[SCSI] lpfc 8.3.35: Update lpfc version for 8.3.35 driver release
[SCSI] lpfc 8.3.35: Fixed not reporting logical link speed to SCSI midlayer when QoS not on
[SCSI] lpfc 8.3.35: Fix error with fabric service parameters causing performance issues
[SCSI] lpfc 8.3.35: Fixed SCSI host create showing wrong link speed on SLI3 HBA ports
[SCSI] lpfc 8.3.35: Fixed not checking solicition in progress bit when verifying FCF record for use
[SCSI] lpfc 8.3.35: Fixed messages for misconfigured port errors
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input layer updates from Dmitry Torokhov:
"2nd round of updates for the input subsystem. With it input core no
longer limits number of character devices per event handler (such as
evdev) to 32, but switches to dynamic minors once legacy range is
exhausted. This should get multi-seat installations that currently
run our of event devices very quickly.
You will also get an update for Wacom driver and a couple of driver
fixes."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: extend the number of event (and other) devices
Input: mousedev - mark mousedev interfaces as non-seekable
Input: mousedev - rename mixdev_open to opened_by_mixdev
Input: mousedev - reformat structure initializers
Input: mousedev - factor out psaux code to reduce #ifdefery
Input: samsung-keypad - add clk_prepare and clk_unprepare
Input: atmel_mxt_ts - simplify mxt_dump_message
Input: wacom - clean up wacom_query_tablet_data
Input: wacom - introduce wacom_fix_phy_from_hid
Input: wacom - allow any multi-input Intuos device to set prox
Input: wacom - report correct touch contact size for I5/Bamboo
Pull networking updates from David Miller:
1) Alexey Kuznetsov noticed we routed TCP resets improperly in the
assymetric routing case, fix this by reverting a change that made us
use the incoming interface in the outgoing route key when we didn't
have a socket context to work with.
2) TCP sysctl kernel memory leakage to userspace fix from Alan Cox.
3) Move UAPI bits from David Howells, WIMAX and CAN this time.
4) Fix TX stalls in e1000e wrt. Byte Queue Limits, from Hiroaki
SHIMODA, Denys Fedoryshchenko, and Jesse Brandeburg.
5) Fix IPV6 crashes in packet generator module, from Amerigo Wang.
6) Tidies and fixes in the new VXLAN driver from Stephen Hemminger.
7) Bridge IP options parse doesn't check first if SKB header has at
least an IP header's worth of content present. Fix from Sarveshwar
Bandi.
8) The kernel now generates compound pages on transmit and the Xen
netback drivers needs some adjustments in order to handle this. Fix
from Ian Campbell.
9) Turn off ASPM in JME driver, from Kevin Bardon and Matthew Garrett.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (43 commits)
mcs7830: Fix link state detection
net: add doc for in4_pton()
net: add doc for in6_pton()
vti: fix sparse bit endian warnings
tcp: resets are misrouted
usbnet: Support devices reporting idleness
Add CDC-ACM support for the CX93010-2x UCMxx USB Modem
net/ethernet/jme: disable ASPM
tcp: sysctl interface leaks 16 bytes of kernel memory
kaweth: print correct debug ptr
e1000e: Change wthresh to 1 to avoid possible Tx stalls
ipv4: fix route mark sparse warning
xen: netback: handle compound page fragments on transmit.
bridge: Pull ip header into skb->data before looking into ip header.
isdn: fix a wrapping bug in isdn_ppp_ioctl()
vxlan: fix oops when give unknown ifindex
vxlan: fix receive checksum handling
vxlan: add additional headroom
vxlan: allow configuring port range
vxlan: associate with tunnel socket on transmit
Use the recently-added bio front_pad field to allocate struct dm_target_io.
Prior to this patch, dm_target_io was allocated from a mempool. For each
dm_target_io, there is exactly one bio allocated from a bioset.
This patch merges these two allocations into one allocation: we create a
bioset with front_pad equal to the size of dm_target_io so that every
bio allocated from the bioset has sizeof(struct dm_target_io) bytes
before it. We allocate a bio and use the bytes before the bio as
dm_target_io.
_tio_cache is removed and the tio_pool mempool is now only used for
request-based devices.
This idea was introduced by Kent Overstreet.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Cc: Kent Overstreet <koverstreet@google.com>
Cc: tj@kernel.org
Cc: Vivek Goyal <vgoyal@redhat.com>
Cc: Bill Pemberton <wfp5p@viridian.itc.virginia.edu>
Signed-off-by: Alasdair G Kergon <agk@redhat.com>
The bio prison code will be useful to other future DM targets so
move it to a separate module.
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Signed-off-by: Joe Thornber <ejt@redhat.com>
The bio prison code will be useful to share with future DM targets.
Prepare to move this code into a separate module, adding a dm prefix
to structures and functions that will be exported.
Support discards when the pool's block size is not a power of 2.
The block layer assumes discard_granularity is a power of 2 (in
blkdev_issue_discard), so we set this to the largest power of 2 that is
a divides into the number of sectors in each block, but never less than
DATA_DEV_BLOCK_SIZE_MIN_SECTORS.
This patch eliminates the "Discard support must be disabled when the
block size is not a power of 2" constraint that was imposed in commit
55f2b8b ("dm thin: support for non power of 2 pool blocksize"). That
commit was incomplete: using a block size that is not a power of 2
shouldn't mean disabling discard support on the device completely.
