path: root/drivers
2007-04-27V4L/DVB (5345): ivtv driver for Conexant cx23416/cx23415 MPEG encoder/decoderHans Verkuil
It took three core maintainers, over four years of work, eight new i2c modules, eleven new V4L2 ioctls, three new DVB video ioctls, a Sliced VBI API, a new MPEG encoder API, an enhanced DVB video MPEG decoding API, major YUV/OSD contributions from Ian and John, web/wiki/svn/trac support from Axel Thimm, (hardware) support from Hauppauge, support and assistance from the v4l-dvb people and the many, many users of ivtv to finally make it possible to merge this driver into the kernel. Thank you all! Signed-off-by: Kevin Thayer <nufan_wfk@yahoo.com> Signed-off-by: Chris Kennedy <c@groovy.org> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: John P Harvey <john.p.harvey@btinternet.com> Signed-off-by: Ian Armstrong <ian@iarmst.demon.co.uk> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5344): Dvb-ttpci: Support for MSC_RAW and MSC_SCAN RC eventsOliver Endriss
Support for MSC_RAW and MSC_SCAN remote control events. Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5335): Budget-ci: Use the repeat handling of the input subsystemDavid Härdeman
The attached patch contains the last set of changes to the budget-ci IR handling which makes it use the repeat handling of the input subsystem. This allows some code simplification, makes sure that repeat key presses are reported as such and also allows the "debounce" hack to be removed altogether. In addition a couple of static variables were removed which would have confused the IR code if more than one card is used. Signed-off-by: David Hardeman <david@hardeman.nu> Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5334): Dvb-ttpci: Infrared remote control refactoringOliver Endriss
Infrared remote control support rewritten. Now each device provides its own event device, keymap, protocol, inversion and address setting. EVIOCGKEYCODE and EVIOCSKEYCODE ioctls are supported to read/modify a keymap. Keymaps may be loaded using - input tools (keyb etc.) - av7110_loadkeys (obsolete, for backward compatibility) New command line parameters: - ir_protocol: select infrared protocol: 0 RC5, 1 RCMM (default) - ir_inversion: signal inversion: 0 not inverted (default), 1 inverted - ir_device_mask: bitmask of infrared devices (default: accept all) Those parameters may be set anytime. Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5331): Identify MSI TV@nywhere DuoPeter Missel
It is a Lifeview Duo with a different ID Signed-off-by: Peter Missel <peter.missel@onlinehome.de> Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5330): Added card definition for AverMedia M102 miniPCIMarkus Rechberger
Signed-off-by: Markus Rechberger <mrechberger@gmail.com> Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5329): Some saa7134 cleanupsHeikki Orsila
- use generic sort instead of bubblesort - removed useless saa7134_video_fini function - small coding style changes Signed-off-by: Heikki Orsila <heikki.orsila@iki.fi> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5326): Allow to set tuner_config in attach informHartmut Hackmann
This patch move the assignment of the tuner config and the callback before the check whether it is called in the attach inform. This solves a module load order issue Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5324): This patch fixes request_module_depend()Markus Rechberger
this patch fixes request_module_depend() Signed-off-by: Markus Rechberger <markus.rechberger@amd.com> Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5323): Updated support for tuner callbacksHartmut Hackmann
This change supplies a more generic version of the tuner callback. The tuner struct now has a function pointer int (*tuner_callback) (void *dev, int command, int arg) additionally to a int config parameter. both can be set through the TUNER_SET_TYPE_ADDR client call. Note that the meaning of the parameters depend on the tuner type. Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5322): Removed board naming code in saa7134-dvbHartmut Hackmann
This is for better consistency with other drivers Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5321): Saa7134-dvb: initialize the dvb frontend in dvb_initHartmut Hackmann
The hardware is completely initialized afterwards, especially the tda10046 has its firmware - which is also necessary in analog mode of some hybrid boards. Calling the sleep function afterwards saves power and definitely puts hybrid boards into analog mode without additional code elsewere. Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5320): Filled in limiting values in tda827x.cHartmut Hackmann
The parameters for minimum and maximum frequency were missing. Also added mail addresses of the module authors. Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5319): Set tda827x to sleep mode after attachHartmut Hackmann
This change sets the tda827x to sleep mode right after attach in dvb mode. It is just to save power. For the same reason, the ADC of the tda10046 gets turned off in sleep mode. Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5318): Fix tda8290 code for tda827x moduleHartmut Hackmann
During tuner attach, the pointers to host dev structure are not set yet, so the I2c adapter needs to be accessed differently. This patch also does some minor cleanup in the saa7134-dvb module. Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5317): Create tda827x dvb tuner moduleMichael Krufky
The patch moves the tda827x dvb tuning code to a separate module Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5316): Add radio support for the Lifeview FlyDVB-T DuoPeter Missel
There are card variants supporting FM radio through tda8275. Signed-off-by: Peter Missel <peter.missel@onlinehome.de> Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5315): Tda1004x: check request firmware for NULL ponter againHartmut Hackmann
In older versions, this was used to decide whether to boot from eeprom or file. This is no longer necessary but the check helps to avoid an oops with misconfigured cards. Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5314): Added support for tda827x tuners with preamlifiersHartmut Hackmann
This patch contains - new tuning code for the tda827xa silicon tuner. - controls the preamplifier of some boards with this tuner. - support for the Philips Tiger S hybrid DVB-T reference design. - reworked the saa7134-dvb modulue to get rid of most of the small board specific functions. Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5313): Added a config entry and a gpio function pointer to tuner structHartmut Hackmann
These entries mainly are to support configurations of the tda827x silicon tuner with a preamplifier. The values can be set throgh the attach inform or through the extended TUNER_SET_TYPE_ADDR client call. The function pointer will only be updated if the parameter is not NULL. Since a typecast is necessary to set the pointer, i added a typedef for this pointer (tuner_gpio_func_t) in tuner.h Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5312): Saa713x: added a GPIO handler functionHartmut Hackmann
This function allows to set, clear and tristate the GPIO ports. Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5311): Tda1004x driver updatesHartmut Hackmann
There are the following changes: - separate configuration of IF and GPIOs. - set GPIOs before firmware load. This helps to avoid I2C address collisions. - if desired invert GPIOs at sleep (automatic return to analog mode of card). - added 3 tuner configuration bytes to config stuct. - added i2c gate address to config struct. - moved _state struct declaration to header file to make it accessible on board layer. - added "conf_probed" to the state struct to allow i.e. probing for correct tuner version. - changed firmware load mechanism to always: + check if already loaded + try to boot from eeprom + try downlad from host - corrected name of tda10046 firmware image (backward compatible). Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5307): Add support for the cx23415 MPEG decoding features.Hans Verkuil
The cx23415 adds some extra features that this DVB decoding API did not support. This API has been expanded to support the required features. Both source and binary backwards compatibility is kept intact by these changes. So existing applications are not affected. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Ralph Metzler <rjkm@metzlerbros.de> Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5306): Add support for VIDIOC_G_CHIP_IDENTHans Verkuil
VIDIOC_G_CHIP_IDENT improves debugging of card problems: it can be used to detect which chips are on the board and based on that information selected register dumps can be made, making it easy to debug complicated media chips containing tens or hundreds of registers. This ioctl replaces the internal VIDIOC_INT_G_CHIP_IDENT ioctl. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5299): Added support for loading cx88-dvb and cx88-blackbirdMarkus Rechberger
Added support for loading cx88-dvb and cx88-blackbird Signed-off-by: Markus Rechberger <mrechberger@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5298): Added support for deferred module requesting to cx88Markus Rechberger
added support for deferred module requesting to cx88 Signed-off-by: Markus Rechberger <mrechberger@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5297): Fix identation on tda10021.cMauro Carvalho Chehab
2007-04-27V4L/DVB (5294): Make pvr2_encoder_prep_config() staticAdrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5293): Make dvb_usb_gl861_debug staticAdrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2007-04-27V4L/DVB (5290): Add support for VIDIOC_INT_G/S_STD_OUTPUTHans Verkuil
Added VIDIOC_INT_G_STD_OUTPUT and VIDIOC_INT_S_STD_OUTPUT to allow drivers to set the TV standard for video output separately from the video capture. This is needed for cx23415 support where the decoder is separate from the encoder and can have a different TV standard. Modified the saa7127 module to listen to VIDIOC_INT_G/S_STD_OUTPUT instead of VIDIOC_G/S_STD. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5289): Add support for video output overlays.Hans Verkuil
Add V4L2_BUF_TYPE_VIDEO_OUTPUT_OVERLAY support. Also add support for local and global alpha overlays. Add new field enums V4L2_FIELD_INTERLACED_TB and V4L2_FIELD_INTERLACED_BT. These changes are needed to support the ivtv On Screen Display features. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5278): Bt8xx/: possible cleanupsAdrian Bunk
This patch contains the following possible cleanups: - remove the following unused global functions: - bttv-if.c: bttv_get_cardinfo() - bttv-if.c: bttv_get_id() - bttv-if.c: bttv_get_gpio_queue() - bttv-if.c: bttv_i2c_call() - remove the following unused EXPORT_SYMBOL's: - bttv-gpio.c: bttv_sub_bus_type - bttv-gpio.c: bttv_gpio_inout - bttv-gpio.c: bttv_gpio_read - bttv-gpio.c: bttv_gpio_write - bttv-gpio.c: bttv_gpio_bits Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5268): Add support for three new MPEG controls.Hans Verkuil
Added V4L2_CID_MPEG_AUDIO_MUTE, V4L2_CID_MPEG_VIDEO_MUTE and V4L2_CID_MPEG_CX2341X_STREAM_INSERT_NAV_PACKETS controls together with their implementation in the cx2341x module. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5257): USB: add zr364xx V4L2 driverAntoine Jacquet
This patch adds a V4L2 driver giving support for USB webcams based on the zr364xx chipsets. Signed-off-by: Antoine Jacquet <royale@zerezo.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27Merge branch 'for-linus' of git://git.infradead.org/ubi-2.6Linus Torvalds
* 'for-linus' of git://git.infradead.org/ubi-2.6: UBI: remove unused variable UBI: add me to MAINTAINERS JFFS2: add UBI support UBI: Unsorted Block Images
2007-04-27Merge branch 'e1000-fixes' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 * 'e1000-fixes' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6: e1000: FIX: Stop raw interrupts disabled nag from RT e1000: FIX: firmware handover bits e1000: FIX: be ready for incoming irq at pci_request_irq
2007-04-27Merge branch 'for-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of master.kernel.org:/pub/scm/linux/kernel/git/roland/infiniband: (49 commits) IB: Set class_dev->dev in core for nice device symlink IB/ehca: Implement modify_port IB/umad: Clarify documentation of transaction ID IPoIB/cm: spin_lock_irqsave() -> spin_lock_irq() replacements IB/mad: Change SMI to use enums rather than magic return codes IB/umad: Implement GRH handling for sent/received MADs IB/ipoib: Use ib_init_ah_from_path to initialize ah_attr IB/sa: Set src_path_bits correctly in ib_init_ah_from_path() IB/ucm: Simplify ib_ucm_event() RDMA/ucma: Simplify ucma_get_event() IB/mthca: Simplify CQ cleaning in mthca_free_qp() IB/mthca: Fix mthca_write_mtt() on HCAs with hidden memory IB/mthca: Update HCA firmware revisions IB/ipath: Fix WC format drift between user and kernel space IB/ipath: Check that a UD work request's address handle is valid IB/ipath: Remove duplicate stuff from ipath_verbs.h IB/ipath: Check reserved memory keys IB/ipath: Fix unit selection when all CPU affinity bits set IB/ipath: Don't allow QPs 0 and 1 to be opened multiple times IB/ipath: Disable IB link earlier in shutdown sequence ...
2007-04-27Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6: (67 commits) [SCSI] SUNESP: Complete driver rewrite to version 2.0 [SPARC64]: Convert PCI over to generic struct iommu/strbuf. [SPARC]: device_node name constification fallout [SPARC64]: Convert SBUS over to generic iommu/strbuf structs. [SPARC64]: Add generic iommu and strbuf structs to iommu.h [SPARC64]: Consolidate {sbus,pci}_iommu_arena. [SPARC]: Make device_node name and type const [SPARC64]: constify some paramaters of OF routines [TIGON3]: of_get_property() returns const. [SPARC64]: Fix PCI rework to adhere to of_get_property() const return. [SPARC64]: Document and fix calculation of pages_avail. [SPARC64]: Make sure pbm->prom_node is setup easly enough in psycho.c [SPARC64]: Use bootmem_bootmap_pages() in choose_bootmap_pfn(). [SPARC64]: Add proper header file extern for cmdline_memory_size. [SPARC64]: Kill sparc_ultra_dump_{i,d}tlb() [SPARC64]: Use DECLARE_BITMAP and BITS_TO_LONGS in mm/init.c [SPARC64]: Give move verbose show_mem() output just like i386. [SPARC64]: Mark show_mem() printk's with KERN_INFO. [SPARC64]: Kill kvaddr_to_phys() and friends. [SPARC64]: Privatize sun4u_get_pte() and fix name. ...
2007-04-27Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: (448 commits) [IPV4] nl_fib_lookup: Initialise res.r before fib_res_put(&res) [IPV6]: Fix thinko in ipv6_rthdr_rcv() changes. [IPV4]: Add multipath cached to feature-removal-schedule.txt [WIRELESS] cfg80211: Clarify locking comment. [WIRELESS] cfg80211: Fix locking in wiphy_new. [WEXT] net_device: Don't include wext bits if not required. [WEXT]: Misc code cleanups. [WEXT]: Reduce inline abuse. [WEXT]: Move EXPORT_SYMBOL statements where they belong. [WEXT]: Cleanup early ioctl call path. [WEXT]: Remove options. [WEXT]: Remove dead debug code. [WEXT]: Clean up how wext is called. [WEXT]: Move to net/wireless [AFS]: Eliminate cmpxchg() usage in vlocation code. [RXRPC]: Fix pointers passed to bitops. [RXRPC]: Remove bogus atomic_* overrides. [AFS]: Fix u64 printing in debug logging. [AFS]: Add "directory write" support. [AFS]: Implement the CB.InitCallBackState3 operation. ...
2007-04-27[S390] SPIN_LOCK_UNLOCKED cleanup in drivers/s390Milind Arun Choudhary
SPIN_LOCK_UNLOCKED cleanup,use __SPIN_LOCK_UNLOCKED instead. Signed-off-by: Milind Arun Choudhary <milindchoudhary@gmail.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-04-27[S390] Processor degradation notification.Heiko Carstens
Generate uevents for all cpus if cpu capability changes. This can happen e.g. because the cpus are overheating. The cpu capability can be read via /sys/devices/system/cpu/cpuN/capability. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2007-04-27[S390] sclp: fix coding style.Stefan Haberland
Use only capital letters for defines. Cc: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Stefan Haberland <stefan.haberland@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-04-27[S390] vmlogrdr: stop IUCV connection in vmlogrdr_release.Ursula Braun
Reopen of /dev/account failed. The IUCV path has to be terminated in vmlogrdr_release. Signed-off-by: Ursula Braun <braunu@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-04-27[S390] sclp: initialize early.Peter Oberparleiter
Add explicit sclp initialization for those sclp users that do not register with the interface. Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-04-27[S390] ctc: kmalloc->kzalloc/casting cleanups.Ahmed S. Darwish
A patch for the CTC / ESCON network driver. Switch from kmalloc to kzalloc when appropriate, remove some unnecessary kmalloc casts too. Since I have no s390 machine, I didn't compile it but I examined it carefully. Signed-off-by: "Ahmed S. Darwish" <darwish.07@gmail.com> Cc: Frank Pavlic <fpavlic@de.ibm.com> Cc: Ursula Braun <braunu@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-04-27[S390] zfcpdump support.Michael Holzheu
s390 machines provide hardware support for creating Linux dumps on SCSI disks. For creating a dump a special purpose dump Linux is used. The first 32 MB of memory are saved by the hardware before the dump Linux is booted. Via an SCLP interface, the saved memory can be accessed from Linux. This patch exports memory and registers of the crashed Linux to userspace via a debugfs file. For more information refer to Documentation/s390/zfcpdump.txt, which is included in this patch. Signed-off-by: Michael Holzheu <holzheu@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2007-04-27[S390] dasd: Add ipldev parameter.Peter Oberparleiter
Specifying 'ipldev' in the dasd= kernel parameter will automatically activate the boot device for use by the dasd driver. Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-04-27[S390] dasd: Add sysfs attribute status and generate uevents.Horst Hummel
This patch adds a sysfs-attribute 'status' to make the DASD device-status accessible from user-space. In addition, the DASD driver generates an uevent(CHANGE) for the ccw-device on each device-status change. This enables user-space applications (e.g. udev) to do related processing. Signed-off-by: Horst Hummel <horst.hummel@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-04-27[S390] Get rid of console setup functions.Heiko Carstens
We get this: Section mismatch: reference to .init.text:con3270_consetup from .data between 'con3270' (at offset 0x45c8) and 'con3270_fn' Section mismatch: reference to .init.text:con3215_consetup from .data between 'con3215' (at offset 0x4678) and 'raw3215_ccw_driver' Since there is no difference between a non present console setup function and one that returns only 0 remove them. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2007-04-27[S390] cio: Unregister ccw devices directly.Cornelia Huck
We used to unregister ccw devices not directly from the I/O subchannel remove function in order to avoid lifelocks on the css bus semaphore. This semaphore is gone, and there is no reason to not unregister the ccw device directly (it is even better since it is more in keeping with the goal of immediate disconnect). Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
