kthread_create_on_node takes format+args, so there's no need to do the
pretty-printing in advance. Moreover, "mtip_svc_thd_99" (including its
'\0') only just fits in 16 bytes, so if index could ever go above 99
we'd have a stack buffer overflow.
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Reviewed-by: Jeff Moyer <jmoyer@redhat.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
Make sure that there are no unprocesssed entries on a completion
queue before deleting it, and check for validity of the CQ
door bell before writing completions to it.
This fixes problems with doing a sysfs reset of the device while
it's handling IO.
Tested-by: Jon Derrick <jonathan.derrick@intel.com>
Add free block, used block, and bad block information to the show debug
interface. This information is used to debug how targets track blocks.
Also, change debug function name to make it more generic.
Signed-off-by: Javier Gonzalez <javier@cnexlabs.com>
Signed-off-by: Matias Bjørling <m@bjorling.me>
Maintain number of in use blocks, free blocks, and bad blocks in a per
lun basis. This allows the upper layers to get information about the
state of each lun.
Also, account for blocks reserved to the device on the free block count.
nr_free_blocks matches now the actual number of blocks on the free list
when the device is booted.
According to the Open-Channel SSD Specification, the NVMe-NVM admin
commands use vendor specific opcodes of NVMe, so use the NVMe admin
queue to dispatch these commands.
Signed-off-by: Wenwei Tao <ww.tao0320@gmail.com>
Updated by me to include set bad block table as well and also use
the admin queue for l2p len calculation.
If either max_phys_sect is out of bound, the nvm_dev structure is not
freed.
The return value should be non-zero under error conditions.
Remove nvme_free(dev) to avoid free dev more than once.
The gendisk structure has not been initialized when using lightnvm.
Make sure to not delete it upon exit. Also make sure that we use the
appropriate disk_name at unregistration.
The linear addressing mode was removed in 7386af2. Make null_blk instead
expose the ppa format geometry and support the generic addressing mode.
Instead of using a page pool, we can save memory by only allocating room
for 64 entries for the ppa command. Introduce a ppa_cache to allocate only
the required memory for the ppa list.
Reported-by: Paul Grabinar <paul.grabinar@ranbarg.com>
Signed-off-by: Keith Busch <keith.busch@intel.com>
Add support for registering as a LightNVM device. This allows us to
evaluate the performance of the LightNVM subsystem.
In /drivers/Makefile, LightNVM is moved above block device drivers
to make sure that the LightNVM media managers have been initialized
before drivers under /drivers/block are initialized.
Fix by Jens Axboe to remove unneeded slab cache and the following
memory leak.
This prevents outstanding IOs to be sent for completion to target after
the target has been removed. The flow is now: stop new IOs > cleanup
queue > remove target.
The specification was updated the remove the double word just after
number of configuration groups and capabilities. Update the identify
structure to reflect it.
The ppa format was not copied from the NVMe specific ppa format to the
lightnvm specific ppa format. This led to the ppa format not being
communicated to the layers above.
The linear and device specific address modes can be replaced with a
simple offset and bit length conversion that is generic across all
devices.
This both simplifies the specification and removes the special case for
qemu nvme, that previously relied on the linear address mapping.
Both the nvm_register and nvm_init does a kfree(dev) on error. Make sure
to only free it once.
We register with nvm_devices when there registration can still fail.
Move the final registration at the end of the nvm_register function
to make sure we are fully registered when added to the nvm_devices list.
Only NAND flash with SLC and MLC is supported. Make sure to not try to
initialize TLC memory or other non-volatile memory types.
The mccap field is required for I/O command option support. It defines the
following flash access modes:
* SLC mode
* Erase/Program Suspension
* Scramble On/Off
* Encryption
It is slotted in between mpos and cpar, changing the offset for
cpar as well.
A single 8 bit and 16 bit reserve field were inserted in the
specification to align fields appropriately. Reflect this in the
identify group structure.
The specification was changed to reflect a multi-value bad block table.
Instead of bit-based bad block table, the bad block table now allows
eight bad block categories. Currently four are defined:
* Factory bad blocks
* Grown bad blocks
* Device-side reserved blocks
* Host-side reserved blocks
The factory and grown bad blocks are the regular bad blocks. The
reserved blocks are either for internal use or external use. In
particular, the device-side reserved blocks allows the host to
bootstrap from a limited number of flash blocks. Reducing the flash
blocks to scan upon super block initialization.
Support for both get bad block table and set bad block table is added.
Pull MIPS updates from Ralf Baechle:
"These are the highlists of the main MIPS pull request for 4.4:
- Add latencytop support
- Support appended DTBs
- VDSO support and initially use it for gettimeofday.
- Drop the .MIPS.abiflags and ELF NOTE sections from vmlinux
- Support for the 5KE, an internal test core.
- Switch all MIPS platfroms to libata drivers.
- Improved support, cleanups for ralink and Lantiq platforms.
- Support for the new xilfpga platform.
- A number of DTB improvments for BMIPS.
- Improved support for CM and CPS.
- Minor JZ4740 and BCM47xx enhancements"
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (120 commits)
MIPS: idle: add case for CPU_5KE
MIPS: Octeon: Support APPENDED_DTB
MIPS: vmlinux: create a section for appended DTB
MIPS: Clean up compat_siginfo_t
MIPS: Fix PAGE_MASK definition
MIPS: BMIPS: Enable GZIP ramdisk and timed printks
MIPS: Add xilfpga defconfig
MIPS: xilfpga: Add mipsfpga platform code
MIPS: xilfpga: Add xilfpga device tree files.
dt-bindings: MIPS: Document xilfpga bindings and boot style
MIPS: Make MIPS_CMDLINE_DTB default
MIPS: Make the kernel arguments from dtb available
MIPS: Use USE_OF as the guard for appended dtb
MIPS: BCM63XX: Use pr_* instead of printk
MIPS: Loongson: Cleanup CONFIG_LOONGSON_SUSPEND.
MIPS: lantiq: Disable xbar fpi burst mode
MIPS: lantiq: Force the crossbar to big endian
MIPS: lantiq: Initialize the USB core on boot
MIPS: lantiq: Return correct value for fpi clock on ar9
MIPS: ralink: Add missing clock on rt305x
git://git.kernel.org/pub/scm/linux/kernel/git/olof/chrome-platform
Pull chrome platform updates from Olof Johansson:
"Here's the branch of chrome platform changes for v4.4. Some have been
queued up for the full 4.3 release cycle since I forgot to send them
in for that round (rebased early on to deal with fixes conflicts).
Most of these enable EC communication stuff -- Pixel 2015 support,
enabling building for ARM64 platforms, and a few fixes for memory
leaks.
There's also a patch in here to allow reading/writing the verified
boot context, which depends on a sysfs patch acked by Greg"
* tag 'chrome-platform-4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/olof/chrome-platform:
platform/chrome: Fix i2c-designware adapter name
platform/chrome: Support reading/writing the vboot context
sysfs: Support is_visible() on binary attributes
platform/chrome: cros_ec: Fix possible leak in led_rgb_store()
platform/chrome: cros_ec: Fix leak in sequence_store()
platform/chrome: Enable Chrome platforms on 64-bit ARM
platform/chrome: cros_ec_dev - Add a platform device ID table
platform/chrome: cros_ec_lpc - Add support for Google Pixel 2
platform/chrome: cros_ec_lpc - Use existing function to check EC result
platform/chrome: Make depends on MFD_CROS_EC instead CROS_EC_PROTO
Revert "platform/chrome: Don't make CHROME_PLATFORMS depends on X86 || ARM"
git://git.infradead.org/users/dvhart/linux-platform-drivers-x86
Pull another x86 platform driver update from Darren Hart:
"Support for the unfortunately rather unique ESC key on the Ideapad
Yoga 3 and two DMI matches for rfkill support. Solitary fix for
potential missed errors for asus-wmi. Downgrade a thinkpad_acpi
message to info.
asus-wmi:
- fix error handling in store_sys_wmi()
ideapad-laptop:
- Add Lenovo Yoga 900 to no_hw_rfkill dmi list
- include Yoga 3 1170 in add rfkill whitelist
- add support for Yoga 3 ESC key
thinkpad_acpi:
- Don't yell on unsupported brightness interfaces"
* tag 'platform-drivers-x86-v4.4-2' of git://git.infradead.org/users/dvhart/linux-platform-drivers-x86:
asus-wmi: fix error handling in store_sys_wmi()
ideapad-laptop: Add Lenovo Yoga 900 to no_hw_rfkill dmi list
ideapad-laptop: include Yoga 3 1170 in add rfkill whitelist
ideapad-laptop: add support for Yoga 3 ESC key
thinkpad_acpi: Don't yell on unsupported brightness interfaces
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull more input updates from Dmitry Torokhov:
"An update to the tsc2005 driver that allows it to also support tsc2004
(basically the same controller, but uses i2c instead of spi bus), and
a couple of bug fixes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: parkbd - drop bogus __init from parkbd_allocate_serio()
Input: elantech - add Fujitsu Lifebook U745 to force crc_enabled
Input: tsc2004 - add support for tsc2004
Input: tsc200x-core - rename functions and variables
Input: tsc2005 - separate SPI and core functions
Pull final round of SCSI updates from James Bottomley:
"Sorry for the delay in this patch which was mostly caused by getting
the merger of the mpt2/mpt3sas driver, which was seen as an essential
item of maintenance work to do before the drivers diverge too much.
Unfortunately, this caused a compile failure (detected by linux-next),
which then had to be fixed up and incubated.
In addition to the mpt2/3sas rework, there are updates from pm80xx,
lpfc, bnx2fc, hpsa, ipr, aacraid, megaraid_sas, storvsc and ufs plus
an assortment of changes including some year 2038 issues, a fix for a
remove before detach issue in some drivers and a couple of other minor
issues"
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (141 commits)
mpt3sas: fix inline markers on non inline function declarations
sd: Clear PS bit before Mode Select.
ibmvscsi: set max_lun to 32
ibmvscsi: display default value for max_id, max_lun and max_channel.
mptfusion: don't allow negative bytes in kbuf_alloc_2_sgl()
scsi: pmcraid: replace struct timeval with ktime_get_real_seconds()
mvumi: 64bit value for seconds_since1970
be2iscsi: Fix bogus WARN_ON length check
scsi_scan: don't dump trace when scsi_prep_async_scan() is called twice
mpt3sas: Bump mpt3sas driver version to 09.102.00.00
mpt3sas: Single driver module which supports both SAS 2.0 & SAS 3.0 HBAs
mpt2sas, mpt3sas: Update the driver versions
mpt3sas: setpci reset kernel oops fix
mpt3sas: Added OEM Gen2 PnP ID branding names
mpt3sas: Refcount fw_events and fix unsafe list usage
mpt3sas: Refcount sas_device objects and fix unsafe list usage
mpt3sas: sysfs attribute to report Backup Rail Monitor Status
mpt3sas: Ported WarpDrive product SSS6200 support
mpt3sas: fix for driver fails EEH, recovery from injected pci bus error
mpt3sas: Manage MSI-X vectors according to HBA device type
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending
Pull SCSI target updates from Nicholas Bellinger:
"This series contains HCH's changes to absorb configfs attribute
->show() + ->store() function pointer usage from it's original
tree-wide consumers, into common configfs code.
It includes usb-gadget, target w/ drivers, netconsole and ocfs2
changes to realize the improved simplicity, that now renders the
original include/target/configfs_macros.h CPP magic for fabric drivers
and others, unnecessary and obsolete.
And with common code in place, new configfs attributes can be added
easier than ever before.
Note, there are further improvements in-flight from other folks for
v4.5 code in configfs land, plus number of target fixes for post -rc1
code"
In the meantime, a new user of the now-removed old configfs API came in
through the char/misc tree in commit 7bd1d4093c2f ("stm class: Introduce
an abstraction for System Trace Module devices").
This merge resolution comes from Alexander Shishkin, who updated his stm
class tracing abstraction to account for the removal of the old
show_attribute and store_attribute methods in commit 517982229f78
("configfs: remove old API") from this pull. As Alexander says about
that patch:
"There's no need to keep an extra wrapper structure per item and the
awkward show_attribute/store_attribute item ops are no longer needed.
This patch converts policy code to the new api, all the while making
the code quite a bit smaller and easier on the eyes.
Signed-off-by: Alexander Shishkin <alexander.shishkin@linux.intel.com>"
That patch was folded into the merge so that the tree should be fully
bisectable.
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (23 commits)
ocfs2/cluster: use per-attribute show and store methods
ocfs2/cluster: move locking into attribute store methods
netconsole: use per-attribute show and store methods
target: use per-attribute show and store methods
spear13xx_pcie_gadget: use per-attribute show and store methods
dlm: use per-attribute show and store methods
usb-gadget/f_serial: use per-attribute show and store methods
usb-gadget/f_phonet: use per-attribute show and store methods
usb-gadget/f_obex: use per-attribute show and store methods
usb-gadget/f_uac2: use per-attribute show and store methods
usb-gadget/f_uac1: use per-attribute show and store methods
usb-gadget/f_mass_storage: use per-attribute show and store methods
usb-gadget/f_sourcesink: use per-attribute show and store methods
usb-gadget/f_printer: use per-attribute show and store methods
usb-gadget/f_midi: use per-attribute show and store methods
usb-gadget/f_loopback: use per-attribute show and store methods
usb-gadget/ether: use per-attribute show and store methods
usb-gadget/f_acm: use per-attribute show and store methods
usb-gadget/f_hid: use per-attribute show and store methods
git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm
Pull libnvdimm fixes from Dan Williams:
- three fixes tagged for -stable including a crash fix, simple
performance tweak, and an invalid i/o error.
- build regression fix for the nvdimm unit tests
- nvdimm documentation update
* 'libnvdimm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm:
dax: fix __dax_pmd_fault crash
libnvdimm: documentation clarifications
libnvdimm, pmem: fix size trim in pmem_direct_access()
libnvdimm, e820: fix numa node for e820-type-12 pmem ranges
tools/testing/nvdimm, acpica: fix flag rename build breakage
Pull VFIO updates from Alex Williamson:
- Use kernel interfaces for VPD emulation (Alex Williamson)
- Platform fix for releasing IRQs (Eric Auger)
- Type1 IOMMU always advertises PAGE_SIZE support when smaller mapping
sizes are available (Eric Auger)
- Platform fixes for incorrectly using copies of structures rather than
pointers to structures (James Morse)
- Rework platform reset modules, fix leak, and add AMD xgbe reset
module (Eric Auger)
- Fix vfio_device_get_from_name() return value (Joerg Roedel)
- No-IOMMU interface (Alex Williamson)
- Fix potential out of bounds array access in PCI config handling (Dan
Carpenter)
* tag 'vfio-v4.4-rc1' of git://github.com/awilliam/linux-vfio:
vfio/pci: make an array larger
vfio: Include No-IOMMU mode
vfio: Fix bug in vfio_device_get_from_name()
VFIO: platform: reset: AMD xgbe reset module
vfio: platform: reset: calxedaxgmac: fix ioaddr leak
vfio: platform: add dev_info on device reset
vfio: platform: use list of registered reset function
vfio: platform: add compat in vfio_platform_device
vfio: platform: reset: calxedaxgmac: add reset function registration
vfio: platform: introduce module_vfio_reset_handler macro
vfio: platform: add capability to register a reset function
vfio: platform: introduce vfio-platform-base module
vfio/platform: store mapped memory in region, instead of an on-stack copy
vfio/type1: handle case where IOMMU does not support PAGE_SIZE size
VFIO: platform: clear IRQ_NOAUTOEN when de-assigning the IRQ
vfio/pci: Use kernel VPD access functions
vfio: Whitelist PCI bridges
Prepare second round of input updates for 4.3 merge window.
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client
Pull Ceph updates from Sage Weil:
"There are several patches from Ilya fixing RBD allocation lifecycle
issues, a series adding a nocephx_sign_messages option (and associated
bug fixes/cleanups), several patches from Zheng improving the
(directory) fsync behavior, a big improvement in IO for direct-io
requests when striping is enabled from Caifeng, and several other
small fixes and cleanups"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client:
libceph: clear msg->con in ceph_msg_release() only
libceph: add nocephx_sign_messages option
libceph: stop duplicating client fields in messenger
libceph: drop authorizer check from cephx msg signing routines
libceph: msg signing callouts don't need con argument
libceph: evaluate osd_req_op_data() arguments only once
ceph: make fsync() wait unsafe requests that created/modified inode
ceph: add request to i_unsafe_dirops when getting unsafe reply
libceph: introduce ceph_x_authorizer_cleanup()
ceph: don't invalidate page cache when inode is no longer used
rbd: remove duplicate calls to rbd_dev_mapping_clear()
rbd: set device_type::release instead of device::release
rbd: don't free rbd_dev outside of the release callback
rbd: return -ENOMEM instead of pool id if rbd_dev_create() fails
libceph: use local variable cursor instead of &msg->cursor
libceph: remove con argument in handle_reply()
ceph: combine as many iovec as possile into one OSD request
ceph: fix message length computation
ceph: fix a comment typo
rbd: drop null test before destroy functions
Pull drm sti driver updates from Dave Airlie:
"The sti driver had a requirement on some patches in Greg's tree, they
are in, so I see no problems just merging this one now"
* 'drm-next' of git://people.freedesktop.org/~airlied/linux:
drm/sti: load HQVDP firmware the first time HQVDP's plane is used
drm/sti: fix typo issue in sti_mode_config_init
drm/sti: set mixer background color through module param
drm/sti: Remove local fbdev emulation Kconfig option
drm/sti: remove redundant sign extensions
drm/sti: hdmi use of_get_i2c_adapter_by_node interface
drm/sti: hdmi fix i2c adapter device refcounting
drm/sti: Do not export symbols
drm/sti: Build monolithic driver
drm/sti: Use drm_crtc_vblank_*() API
drm/sti: Store correct CRTC index in events
drm/sti: Select FW_LOADER
drm/sti: Constify function pointer structs
After merging the scsi tree, today's linux-next build (powerpc
allyesconfig) failed like this:
In file included from drivers/scsi/mpt3sas/mpt3sas_scsih.c:59:0:
drivers/scsi/mpt3sas/mpt3sas_scsih.c: In function '_scsih_io_done':
drivers/scsi/mpt3sas/mpt3sas_base.h:1414:1: error: inlining failed in call to always_inline 'mpt3sas_scsi_direct_io_get': function body not available
mpt3sas_scsi_direct_io_get(struct MPT3SAS_ADAPTER *ioc, u16 smid);
drivers/scsi/mpt3sas/mpt3sas_scsih.c:4448:6: error: called from here
if (mpt3sas_scsi_direct_io_get(ioc, smid) &&
drivers/scsi/mpt3sas/mpt3sas_base.h:1416:1: error: inlining failed in call to always_inline 'mpt3sas_scsi_direct_io_set': function body not available
mpt3sas_scsi_direct_io_set(struct MPT3SAS_ADAPTER *ioc, u16 smid, u8 direct_io);
drivers/scsi/mpt3sas/mpt3sas_scsih.c:4454:3: error: called from here
mpt3sas_scsi_direct_io_set(ioc, smid, 0);
9:0:
Presumably caused by commit
c84b06a48c4d ("mpt3sas: Single driver module which supports both SAS 2.0 & SAS 3.0 HBAs")
Signed-off-by: James Bottomley <JBottomley@Odin.com>
Pull drm fixes from Dave Airlie:
"One urgent fix for an oops under console lock in some drivers, one
uapi fix, and one revert to fix rockchip regression"
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux:
Revert "drm/rockchip: Convert the probe function to the generic drm_of_component_probe()"
drm: Don't oops in drm_calc_timestamping_constants() if drm_vblank_init() wasn't called
drm: Use userspace compatible type in fourcc_mod_code macro
http://git.linaro.org/people/benjamin.gaignard/kernel into drm-next
sti/drm changes
Add better support for firmware loading
lots of fixes.
* 'drm-sti-next-2015-11-03' of http://git.linaro.org/people/benjamin.gaignard/kernel:
This reverts commit 52f5eb60940de889ce98a876f6933b574ead3225.
Rockchip drm can't work with generic drm_of_component_probe now
Signed-off-by: Mark Yao <mark.yao@rock-chips.com>
Acked-by: Liviu Dudau <Liviu.Dudau@arm.com>
wasn't called
Seems the crtc helpers call drm_calc_timestamping_constants()
unconditionally even if the driver didn't initialize vblank support by
calling drm_vblank_init(). That used to be OK since the constants were
stored under drm_crtc.
However I broke this with
commit eba1f35dfe14 ("drm: Move timestamping constants into drm_vblank_crtc")
when I moved the constants to live inside the drm_vblank_crtc struct
instead. If drm_vblank_init() isn't called, we don't allocate these
structures, and so drm_calc_timestamping_constants() will oops.
Fix it by adding a check into drm_calc_timestamping_constants() to see
if vblank support was initialized at all. And to keep in line with other
such checks, also toss in a check and warn for the case where vblank
support was initialized, but the wrong number of crtcs was specified.
Fixes the following sort of oops:
BUG: unable to handle kernel NULL pointer dereference at 00000000000000b0
IP: [<ffffffffa014b266>] drm_calc_timestamping_constants+0x86/0x130 [drm]
PGD 0
Oops: 0002 [#1] SMP
Modules linked in: sr_mod cdrom mgag200(+) i2c_algo_bit drm_kms_helper ahci syscopyarea sysfillrect sysimgblt libahci fb_sys_fops bnx2x ttm tg3(+) mdio drm ptp sd_mod libata i2c_core pps_core libcrc32c hpsa dm_mirror dm_region_hash dm_log dm_mod
CPU: 0 PID: 418 Comm: kworker/0:2 Not tainted 4.3.0+ #1
Hardware name: HP ProLiant DL380 Gen9, BIOS P89 06/09/2015
Workqueue: events work_for_cpu_fn
task: ffff88046ca95500 ti: ffff88007830c000 task.ti: ffff88007830c000
RIP: 0010:[<ffffffffa014b266>] [<ffffffffa014b266>] drm_calc_timestamping_constants+0x86/0x130 [drm]
RSP: 0018:ffff88007830f4e8 EFLAGS: 00010246
RAX: 0000000000fe4c00 RBX: ffff88006a849160 RCX: 0000000000000540
RDX: 0000000000000000 RSI: 000000000000fde8 RDI: ffff88006a849000
RBP: ffff88007830f518 R08: ffff88007830c000 R09: 00000001b87e3712
R10: 00000000000050c4 R11: 0000000000000000 R12: 0000000000fe4c00
R13: ffff88006a849000 R14: 0000000000000000 R15: 000000000000fde8
FS: 0000000000000000(0000) GS:ffff88046f800000(0000) knlGS:0000000000000000
CR2: 00000000000000b0 CR3: 00000000019d6000 CR4: 00000000001406f0
Stack:
ffff88007830f518 ffff88006a849000 ffff880c69b90340 ffff880c69b90000
ffff880c69b90348 ffff880c69b90340 ffff88007830f748 ffffffffa042f7e7
ffff88006a849090 0000000000000000 ffff88006a849160 0000000000000000
Call Trace:
[<ffffffffa042f7e7>] drm_crtc_helper_set_mode+0x3d7/0x4b0 [drm_kms_helper]
[<ffffffffa04307d4>] drm_crtc_helper_set_config+0x8d4/0xb10 [drm_kms_helper]
[<ffffffffa01548d4>] drm_mode_set_config_internal+0x64/0x100 [drm]
[<ffffffffa043c342>] drm_fb_helper_pan_display+0xa2/0x280 [drm_kms_helper]
[<ffffffff81392c7b>] fb_pan_display+0xbb/0x170
[<ffffffff8138cf70>] bit_update_start+0x20/0x50
[<ffffffff8138b81b>] fbcon_switch+0x39b/0x590
[<ffffffff8140a3d0>] redraw_screen+0x1a0/0x240
[<ffffffff8140b30e>] do_bind_con_driver+0x2ee/0x310
[<ffffffff8140b651>] do_take_over_console+0x141/0x1b0
[<ffffffff81387377>] do_fbcon_takeover+0x57/0xb0
[<ffffffff8138c98b>] fbcon_event_notify+0x60b/0x750
[<ffffffff810a5599>] notifier_call_chain+0x49/0x70
[<ffffffff810a58dd>] __blocking_notifier_call_chain+0x4d/0x70
[<ffffffff810a5916>] blocking_notifier_call_chain+0x16/0x20
[<ffffffff8139282b>] fb_notifier_call_chain+0x1b/0x20
[<ffffffff81394881>] register_framebuffer+0x1f1/0x330
[<ffffffffa043d9aa>] drm_fb_helper_initial_config+0x27a/0x3d0 [drm_kms_helper]
[<ffffffffa0469b4d>] mgag200_fbdev_init+0xdd/0xf0 [mgag200]
[<ffffffffa0468586>] mgag200_modeset_init+0x176/0x1e0 [mgag200]
[<ffffffffa0464659>] mgag200_driver_load+0x3f9/0x580 [mgag200]
[<ffffffffa014e067>] drm_dev_register+0xa7/0xb0 [drm]
[<ffffffffa015054f>] drm_get_pci_dev+0x8f/0x1e0 [drm]
[<ffffffffa046937b>] mga_pci_probe+0x9b/0xc0 [mgag200]
[<ffffffff813662d5>] local_pci_probe+0x45/0xa0
[<ffffffff8109afe4>] work_for_cpu_fn+0x14/0x20
[<ffffffff8109e13c>] process_one_work+0x14c/0x3c0
[<ffffffff8109eaa4>] worker_thread+0x244/0x470
[<ffffffff8168bfba>] ? __schedule+0x2aa/0x760
[<ffffffff8109e860>] ? rescuer_thread+0x310/0x310
[<ffffffff810a4438>] kthread+0xd8/0xf0
[<ffffffff810a4360>] ? kthread_park+0x60/0x60
[<ffffffff8169030f>] ret_from_fork+0x3f/0x70
Code: f6 31 d2 41 89 c2 8b 83 b4 00 00 00 0f af c1 48 98 48 69 c0 40 42 0f 00 48 f7 f6 f6 43 74 10 41 89 c4 75 26 f6 05 9a 6f 03 00 01 <45> 89 96 b0 00 00 00 45 89 a6 ac 00 00 00 75 35 48 83 c4 08 5b
RIP [<ffffffffa014b266>] drm_calc_timestamping_constants+0x86/0x130 [drm]
RSP <ffff88007830f4e8>
Cc: Jeff Moyer <jmoyer@redhat.com>
Reported-by: Jeff Moyer <jmoyer@redhat.com>
References: http://lists.freedesktop.org/archives/dri-devel/2015-November/094217.html
Fixes: eba1f35dfe14 ("drm: Move timestamping constants into drm_vblank_crtc")
Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Pull misc block fixes from Jens Axboe:
"Stuff that got collected after the merge window opened. This
contains:
- NVMe:
- Fix for non-striped transfer size setting for NVMe from
Sathyavathi.
- (Some) support for the weird Apple nvme controller in the
macbooks. From Stephan Günther.
- The error value leak for dax from Al.
- A few minor blk-mq tweaks from me.
- Add the new linux-block@vger.kernel.org mailing list to the
MAINTAINERS file.
- Discard fix for brd, from Jan.
- A kerneldoc warning for block core from Randy.
- An older fix from Vivek, converting a WARN_ON() to a rate limited
printk when a device is hot removed with dirty inodes"
* 'for-linus' of git://git.kernel.dk/linux-block:
block: don't hardcode blk_qc_t -> tag mask
dax_io(): don't let non-error value escape via retval instead of EFAULT
block: fix blk-core.c kernel-doc warning
fs/block_dev.c: Remove WARN_ON() when inode writeback fails
NVMe: add support for Apple NVMe controller
NVMe: use split lo_hi_{read,write}q
blk-mq: mark __blk_mq_complete_request() static
MAINTAINERS: add reference to new linux-block list
NVMe: Increase the max transfer size when mdts is 0
brd: Refuse improperly aligned discard requests
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem fixes from James Morris:
"This includes several fixes for TPM, as well as a fix for the x.509
certificate parser to address CVE-2015-5327"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security:
X.509: Fix the time validation [ver #2]
tpm: fix compat 'ppi' link handling in tpm_chip_register()
tpm: fix missing migratable flag in sealing functionality for TPM2
TPM: revert the list handling logic fixed in 398a1e7
TPM: Avoid reference to potentially freed memory
tpm_tis: restore IRQ vector in IO memory after failed probing
tpm_tis: free irq after probing
Pull h8300 updates from Yoshinori Sato:
"Some bug fixes"
* tag 'for-4.4' of git://git.osdn.jp/gitroot/uclinux-h8/linux:
h8300: enable CLKSRC_OF
h8300: Don't set CROSS_COMPILE unconditionally
asm-generic: {get,put}_user ptr argument evaluate only 1 time
h8300: bit io fix
h8300: zImage fix
h8300: register address fix
h8300: Fix alignment for .data
h8300: unaligned divcr register support.
Pull more power management and ACPI updates from Rafael Wysocki:
"The only new feature in this batch is support for the ACPI _CCA device
configuration object, which it a pre-requisite for future ACPI PCI
support on ARM64, but should not affect the other architectures.
The rest is fixes and cleanups, mostly in cpufreq (including
intel_pstate), the Operating Performace Points (OPP) framework and
tools (cpupower and turbostat).
Specifics:
- Support for the ACPI _CCA configuration object intended to tell the
OS whether or not a bus master device supports hardware managed
cache coherency and a new set of functions to allow drivers to
check the cache coherency support for devices in a platform
firmware interface agnostic way (Suravee Suthikulpanit, Jeremy
Linton).
- ACPI backlight quirks for ESPRIMO Mobile M9410 and Dell XPS L421X
(Aaron Lu, Hans de Goede).
- Fixes for the arm_big_little and s5pv210-cpufreq cpufreq drivers
(Jon Medhurst, Nicolas Pitre).
- kfree()-related fixup for the recently introduced CPPC cpufreq
frontend (Markus Elfring).
- intel_pstate fix reducing kernel log noise on systems where
P-states are managed by hardware (Prarit Bhargava).
- intel_pstate maintainers information update (Srinivas Pandruvada).
- cpufreq core optimization related to the handling of delayed work
items used by governors (Viresh Kumar).
- Locking fixes and cleanups of the Operating Performance Points
(OPP) framework (Viresh Kumar).
- Generic power domains framework cleanups (Lina Iyer).
- cpupower tool updates (Jacob Tanenbaum, Sriram Raghunathan, Thomas
Renninger).
- turbostat tool updates (Len Brown)"
* tag 'pm+acpi-4.4-rc1-2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (32 commits)
PCI: ACPI: Add support for PCI device DMA coherency
PCI: OF: Move of_pci_dma_configure() to pci_dma_configure()
of/pci: Fix pci_get_host_bridge_device leak
device property: ACPI: Remove unused DMA APIs
device property: ACPI: Make use of the new DMA Attribute APIs
device property: Adding DMA Attribute APIs for Generic Devices
ACPI: Adding DMA Attribute APIs for ACPI Device
device property: Introducing enum dev_dma_attr
ACPI: Honor ACPI _CCA attribute setting
cpufreq: CPPC: Delete an unnecessary check before the function call kfree()
PM / OPP: Add opp_rcu_lockdep_assert() to _find_device_opp()
PM / OPP: Hold dev_opp_list_lock for writers
PM / OPP: Protect updates to list_dev with mutex
PM / OPP: Propagate error properly from dev_pm_opp_set_sharing_cpus()
cpufreq: s5pv210-cpufreq: fix wrong do_div() usage
MAINTAINERS: update for intel P-state driver
Creating a common structure initialization pattern for struct option
cpupower: Enable disabled Cstates if they are below max latency
cpupower: Remove debug message when using cpupower idle-set -D switch
cpupower: cpupower monitor reports uninitialized values for offline cpus
This masking prevents access to the end of the device via dax_do_io(),
and is unnecessary as arch_add_memory() would have rejected an unaligned
allocation.
Cc: <stable@vger.kernel.org>
Cc: Ross Zwisler <ross.zwisler@linux.intel.com>
Rather than punt on the numa node for these e820 ranges try to find a
better answer with memory_add_physaddr_to_nid() when it is available.
Reported-by: Boaz Harrosh <boaz@plexistor.com>
Tested-by: Boaz Harrosh <boaz@plexistor.com>
SCSI queue for 4.4.
into for-linus
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux
Pull DeviceTree fixes from Rob Herring:
- Add empty of_translate_address needed for HiSilicon network driver.
- Fix alignment requirements for CMA regions in DT.
- Fix booting on PPC systems which can't do WARN() early.
- Rename ak4554 binding doc from .c to .txt.
* tag 'devicetree-fixes-for-4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux:
of: Provide static inline function for of_translate_address if needed
drivers: of: of_reserved_mem: fixup the alignment with CMA setup
of: Print rather than WARN'ing when overlap check fails
dt-bindings: ak4554: extension should be .txt
Missing a include file caused compile error.
drivers/thermal/rockchip_thermal.c: In function 'rockchip_thermal_suspend':
drivers/thermal/rockchip_thermal.c:720:2: error: implicit declaration of function 'pinctrl_pm_select_sleep_state' [-Werror=implicit-function-declaration]
Fixes: 7e38a5b1daa1 ("thermal: rockchip: support the sleep pinctrl state
to avoid glitches")
Reported-by: kbuild test robot <lkp@intel.com>
Signed-off-by: Caesar Wang <wxt@rock-chips.com>
Signed-off-by: Eduardo Valentin <edubezval@gmail.com>
According to SPC-4, in a Mode Select, the PS bit in Mode Pages is
reserved and must be set to 0 by the driver. In the sd implementation,
function cache_type_store does a Mode Sense, which might set the PS bit
on the read buffer, followed by a Mode Select, which receives the same
buffer, without explicitly clearing the PS bit. So, in cases where
target supports saving the Mode Page to a non-volatile location, we end
up doing a Mode Select with the PS bit set, which could cause an illegal
request error if the target is checking this.
This was observed on a new firmware change, which was subsequently
reverted, but this changes sd.c to be more compliant with SPC-4.
This patch clears the PS bit in the buffer returned by Mode Select,
right before it is used in the Mode Select command.
Signed-off-by: Gabriel Krisman Bertazi <krisman@linux.vnet.ibm.com>
As defined in 4.6.9 of SAM-4, the encoding of LUN is
on 5 bits (max_lun=32) and the current value is only 8.
Set max_lun to IBMVSCSI_MAX_LUN (32).
Signed-off-by: Laurent Vivier <lvivier@redhat.com>
