commit ce7e9065958191e6b7ca49d7ed0e1099c486d198 upstream.
Here is a patch for a new PID (zeitcontrol-device mifare-reader FT232BL(like FT232BM but lead free)).
Signed-off-by: Artur Zimmer <artur128@3dzimmer.de>
commit 2f1def2695c223b2aa325e5e47d0d64200a45d23 upstream.
A new device ID pair is added for Sierra Wireless MC8305.
Signed-off-by: Florian Echtler <floe@butterbrot.org>
commit e0c87bd95e8dad455c23bc56513af8dcb1737e55 upstream.
Modify Ethernet addess macros to be compatible with BE/LE platforms
Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com>
Cc: Chul Kim <chul.kim@idt.com>
Cc: Kumar Gala <galak@kernel.crashing.org>
Cc: Matt Porter <mporter@kernel.crashing.org>
Cc: Li Yang <leoli@freescale.com>
commit 9fbdaeb4f4dd14a0caa9fc35c496d5440c251a3a upstream.
The newer Lenovo ThinkPads have HKEY HID of LEN0068 instead
of IBM0068. Added new HID so that thinkpad_acpi module will
auto load on these newer Lenovo ThinkPads.
Acked-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br>
Cc: stable@vger.kernel.org
Signed-off-by: Manoj Iyer <manoj.iyer@canonical.com>
Signed-off-by: Andy Lutomirski <luto@mit.edu>
Signed-off-by: Bjørn Mork <bjorn@mork.no>
Commit 6d86a0ee (watchdog: mtx1-wdt: request gpio before using it) was
backported from upstream. The patch is using a gpiolib call which is only
available in kernel 2.6.34+. Fix build by using the "old" gpiolib API
instead.
Signed-off-by: Florian Fainelli <florian@openwrt.org>
This reverts commit 262e2d9d559334e09bc80516132ea99d82f97b8c.
Turns out this breaks the build, and as such, really isn't needed for
the 2.6.32-stable branch at all.
Reported-by: Phil Carmody <ext-phil.2.carmody@nokia.com>
Cc: Anand Gadiyar <gadiyar@ti.com>
Cc: Ajay Kumar Gupta <ajay.gupta@ti.com>
Cc: Felipe Balbi <balbi@ti.com>
commit 9bab0b7fbaceec47d32db51cd9e59c82fb071f5a upstream
This adds a mechanism to resume selected IRQs during syscore_resume
instead of dpm_resume_noirq.
Under Xen we need to resume IRQs associated with IPIs early enough
that the resched IPI is unmasked and we can therefore schedule
ourselves out of the stop_machine where the suspend/resume takes
place.
This issue was introduced by 676dc3cf5bc3 "xen: Use IRQF_FORCE_RESUME".
Back ported to 2.6.32 (which lacks syscore support) by calling the relavant
resume function directly from sysdev_resume).
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
Cc: Rafael J. Wysocki <rjw@sisk.pl>
Cc: Jeremy Fitzhardinge <Jeremy.Fitzhardinge@citrix.com>
Cc: xen-devel <xen-devel@lists.xensource.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Link: http://lkml.kernel.org/r/1318713254.11016.52.camel@dagon.hellion.org.uk
commit 9bed77ee2fb46b74782d0d9d14b92e9d07f3df6e upstream.
This device is not using the proper demod IF. Instead of using the
IF macro, it is specifying a IF frequency. This doesn't work, as xc3028
needs to load an specific SCODE for the tuner. In this case, there's
no IF table for 5 MHz.
commit d59a7b1dbce8b972ec2dc9fcaaae0bfa23687423 upstream.
If the bus has been reset on resume, set the alternate setting to 0.
This should be the default value, but some devices crash or otherwise
misbehave if they don't receive a SET_INTERFACE request before any other
video control request.
Microdia's 0c45:6437 camera has been found to require this change or it
will stop sending video data after resume.
uvc_video.c]
Signed-off-by: Ming Lei <ming.lei@canonical.com>
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
commit c84c14224bbca6ec60d5851fcc87be0e34df2f44 upstream.
The third parameter of module_param is supposed to be an octal value.
The missing leading "0" causes the following:
$ ls -l /sys/module/carminefb/parameters/
total 0
-rw-rwxr-- 1 root root 4096 Jul 8 08:55 fb_displays
-rw-rwxr-- 1 root root 4096 Jul 8 08:55 fb_mode
-rw-rwxr-- 1 root root 4096 Jul 8 08:55 fb_mode_str
After fixing the perm parameter, we get the expected:
total 0
-r--r--r-- 1 root root 4096 Jul 8 08:56 fb_displays
-r--r--r-- 1 root root 4096 Jul 8 08:56 fb_mode
-r--r--r-- 1 root root 4096 Jul 8 08:56 fb_mode_str
Signed-off-by: Jean Delvare <jdelvare@suse.de>
Cc: Sebastian Siewior <bigeasy@linutronix.de>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
commit dbdf1afcaaabe83dea15a3cb9b9013e73ae3b1ad upstream.
Put sysfs attributes of ccwgroup devices in an attribute group to
ensure that these attributes are actually present when userspace
is notified via uevents.
Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com>
commit 273d23574f9dacd9c63c80e7d63639a669aad441 upstream.
For USB CONTROL transaction, when the data length is zero,
the IN package is needed to finish this transaction in status stage.
Signed-off-by: Jerry Huang <r66093@freescale.com>
commit 3687f641307eeff6f7fe31a88dc39db88e89238b upstream.
Some Stellaris evaluation kits have the JTAG/SWD FTDI chip onboard,
and some, like EK-LM3S9B90, come with a separate In-Circuit Debugger
Interface Board. The ICDI board can also be used stand-alone, for
other boards and chips than the kit it came with. The ICDI has both
old style 20-pin JTAG connector and new style JTAG/SWD 10-pin 1.27mm
pitch connector.
Tested with EK-LM3S9B90, where the BD-ICDI board is included.
Signed-off-by: Peter Stuge <peter@stuge.se>
commit 74bdf22b5c3858b06af46f19d05c23e76c40a3bb upstream.
Add PID 0xfc8a, 0xfc8b for device Sony Ericsson Urban
Signed-off-by: Hakan Kvist <hakan.kvist@sonyericsson.com>
Signed-off-by: Oskar Andero <oskar.andero@sonyericsson.com>
commit 598f0b703506da841d3459dc0c48506be14d1778 upstream.
Add vendor and product ID for the SMART USB to serial adapter. These
were meant to be used with their SMART Board whiteboards, but can be
re-purposed for other tasks. Tested and working (at at least 9600 bps).
Signed-off-by: Eric Benoit <eric@ecks.ca>
commit 2394d67e446bf616a0885167d5f0d397bdacfdfc upstream.
The new runtime PM code has shown that many webcams suffer
from a race condition that may crash them upon resume.
Runtime PM is especially prone to show the problem because
it retains power to the cameras at all times. However
system suspension may also crash the devices and retain
power to the devices.
The only way to solve this problem without races is in
usbcore with the RESET_RESUME quirk.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
commit 65e52f41fa944cef2e6d4222b8c54f46cc575214 upstream.
here is the patch to support Owen SI-30 device.
This is a pulse counter controller.
http://www.owen.ru/en/catalog/93788515
usb-drivers output:
T: Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 4 Spd=12 MxCh= 0
D: Ver= 2.00 Cls=02(commc) Sub=00 Prot=00 MxPS= 8 #Cfgs= 1
P: Vendor=03eb ProdID=0030 Rev=01.01
C: #Ifs= 2 Cfg#= 1 Atr=c0 MxPwr=0mA
I: If#= 0 Alt= 0 #EPs= 1 Cls=02(commc) Sub=02 Prot=00 Driver=cdc_acm
I: If#= 1 Alt= 0 #EPs= 2 Cls=0a(data ) Sub=00 Prot=00 Driver=cdc_acm
This patch is installed on my home system which receives data from this
controller connected to cold water counter.
Signed-off-by: Denis Pershin <dyp@perchine.com>
commit aec01c5895051849ed842dc5b8794017a7751f28 upstream.
Alan Stern points out that after spin_unlock(&ps->lock) there is no
guarantee that ps->pid won't be freed. Since kill_pid_info_as_uid() is
called after the spin_unlock(), the pid passed to it must be pinned.
Reported-by: Alan Stern <stern@rowland.harvard.edu>
Signed-off-by: Serge Hallyn <serge.hallyn@canonical.com>
commit e16da02fcdf1c5e824432f88abf42623dafdf191 upstream.
This patch solves two things:
1) Enables autosense emulation code to correctly
interpret descriptor format sense data, and
2) Fixes a bug whereby the autosense emulation
code would overwrite descriptor format sense data
with SENSE KEY HARDWARE ERROR in fixed format, to
incorrectly look like this:
Oct 21 14:11:07 localhost kernel: sd 7:0:0:0: [sdc] Sense Key : Recovered Error [current] [descriptor]
Oct 21 14:11:07 localhost kernel: Descriptor sense data with sense descriptors (in hex):
Oct 21 14:11:07 localhost kernel: 72 01 04 1d 00 00 00 0e 09 0c 00 00 00 00 00 00
Oct 21 14:11:07 localhost kernel: 00 4f 00 c2 00 50
Oct 21 14:11:07 localhost kernel: sd 7:0:0:0: [sdc] ASC=0x4 ASCQ=0x1d
Signed-off-by: Luben Tuikov <ltuikov@yahoo.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Acked-by: Matthew Dharm <mdharm-usb@one-eyed-alien.net>
commit 236c448cb6e7f82096101e1ace4b77f8b38f82c8 upstream.
Report the number of dropped packets instead of zero
when using the binary usbmon interface with tcpdump.
# tcpdump -i usbmon1 -w dump
tcpdump: listening on usbmon1, link-type USB_LINUX_MMAPPED (USB with padded Linux header), capture size 65535 bytes
^C2155 packets captured
2155 packets received by filter
1019 packets dropped by kernel
Signed-off-by: Johannes Stezenbach <js@sig21.net>
commit bb041a0e9c31229071b6e56e1d0d8374af0d2038 upstream.
Libsas forget to set the sas_address and device type of rphy lead to file
under /sys/class/sas_x show wrong value, fix that.
Signed-off-by: Jack Wang <jack_wang@usish.com>
Tested-by: Crystal Yu <crystal_yu@usish.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
commit 5d7c20b7fa5c6ca19e871b4050e321c99d32bd43 upstream.
During kdump testing I noticed timeouts when initialising each IPR
adapter. While the driver has logic to detect an adapter in an
indeterminate state, it wasn't triggering and each adapter went
through a 5 minute timeout before finally going operational.
Some analysis showed the needs_hard_reset flag wasn't getting set.
We can check the reset_devices kernel parameter which is set by
kdump and force a full reset. This fixes the problem.
Acked-by: Brian King <brking@linux.vnet.ibm.com>
commit 0e6c7f746ea99089fb3263709075c20485a479ae upstream.
There are 2 situations wherein the xhci_ring* might not get freed:
- When xhci_ring_alloc() -> xhci_segment_alloc() returns NULL and
we goto the fail: label in xhci_ring_alloc. In this case, the ring
will not get kfreed.
- When the num_segs argument to xhci_ring_alloc is passed as 0 and
we try to free the rung after that.
( This doesn't really happen as of now in the code but we seem to
be entertaining num_segs=0 in xhci_ring_alloc )
This should be backported to kernels as old as 2.6.31.
Signed-off-by: Kautuk Consul <consul.kautuk@gmail.com>
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
commit 1bfac90d1b8e63a4d44158c3445d8fda3fb6d5eb upstream.
add device ID for "HP un2430 Mobile Broadband Module"
Signed-off-by: Rigbert Hamisch <rigbert@gmx.de>
commit e8df1674d383d2ecc6efa8d7dba74c03aafdfdd7 upstream.
If the usermode app does an ioctl over this serial device by
using TIOCMIWAIT, then the code will wait by setting the current
task state to TASK_INTERRUPTIBLE and then calling schedule().
This will be woken up by the qt2_process_modem_status on URB
completion when the port_extra->shadowMSR is set to the new
modem status.
However, this could result in a lost wakeup scenario due to a race
in the logic in the qt2_ioctl(TIOCMIWAIT) loop and the URB completion
for new modem status in qt2_process_modem_status.
Due to this, the usermode app's task will continue to sleep despite a
change in the modem status.
commit bf164c58e58328c40ebc597a8ac00cc6840f9703 upstream.
The w83627ehf driver is improperly reporting thermal diode sensors as
type 2, instead of 3. This caused "sensors" and possibly other
monitoring tools to report these sensors as "transistor" instead of
"thermal diode".
Furthermore, diode subtype selection (CPU vs. external) is only
supported by the original W83627EHF/EHG. All later models only support
CPU diode type, and some (NCT6776F) don't even have the register in
question so we should avoid reading from it.
Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
commit f5e4282586dc0c9dab8c7d32e6c43aa07f68586b upstream.
Patch to add SiGma Micro-based keyboards (1c4f:0002) to hid-quirks.
These keyboards dont seem to allow the records to be initialized, and hence a
timeout occurs when the usbhid driver attempts to initialize them. The patch
just adds the signature for these keyboards to the hid-quirks list with the
setting HID_QUIRK_NO_INIT_REPORTS. This removes the 5-10 second wait for the
timeout to occur.
Signed-off-by: Jeremiah Matthey <sprg86@gmail.com>
Signed-off-by: Jonathan Nieder <jrnieder@gmail.com>
commit 3c4aa91f21f65b7b40bdfb015eacbcb8453ccae2 upstream.
Like e65cc194f7628ecaa02462f22f42fb09b50dcd49 this patch enables 64bit DMA
for the AHCI SATA controller of a board that has the SB600 southbridge. In
this case though we're enabling 64bit DMA for the Asus M3A motherboard. It
is a new enough board that all of the BIOS releases since the initial
release (0301 from 2007-10-22) work correctly with 64bit DMA enabled.
Signed-off-by: Mark Nelson <mdnelson8@gmail.com>
Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
commit a73914c35b05d80f8ce78288e10056c91090b666 upstream.
When a wide port is being utilized to a target, if one disables only one
of the
phys, we get an OS crash:
BUG: unable to handle kernel NULL pointer dereference at
0000000000000238
IP: [<ffffffff814ca9b1>] mutex_lock+0x21/0x50
PGD 4103f5067 PUD 41dba9067 PMD 0
Oops: 0002 [#1] SMP
last sysfs file: /sys/bus/pci/slots/5/address
CPU 0
Modules linked in: pm8001(U) ses enclosure fuse nfsd exportfs autofs4
ipmi_devintf ipmi_si ipmi_msghandler nfs lockd fscache nfs_acl
auth_rpcgss 8021q fcoe libfcoe garp libfc scsi_transport_fc stp scsi_tgt
llc sunrpc cpufreq_ondemand acpi_cpufreq freq_table ipv6 sr_mod cdrom
dm_mirror dm_region_hash dm_log uinput sg i2c_i801 i2c_core iTCO_wdt
iTCO_vendor_support e1000e mlx4_ib ib_mad ib_core mlx4_en mlx4_core ext3
jbd mbcache sd_mod crc_t10dif usb_storage ata_generic pata_acpi ata_piix
libsas(U) scsi_transport_sas dm_mod [last unloaded: pm8001]
Pid: 5146, comm: scsi_wq_5 Not tainted
2.6.32-71.29.1.el6.lustre.7.x86_64 #1 Storage Server
RIP: 0010:[<ffffffff814ca9b1>] [<ffffffff814ca9b1>]
RSP: 0018:ffff8803e4e33d30 EFLAGS: 00010246
RAX: 0000000000000000 RBX: 0000000000000238 RCX: 0000000000000000
RDX: 0000000000000000 RSI: ffff8803e664c800 RDI: 0000000000000238
RBP: ffff8803e4e33d40 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000001 R12: 0000000000000000
R13: 0000000000000238 R14: ffff88041acb7200 R15: ffff88041c51ada0
FS: 0000000000000000(0000) GS:ffff880028200000(0000)
knlGS:0000000000000000
CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b
CR2: 0000000000000238 CR3: 0000000410143000 CR4: 00000000000006f0
Process scsi_wq_5 (pid: 5146, threadinfo ffff8803e4e32000, task
ffff8803e4e294a0)
Stack:
ffff8803e664c800 0000000000000000 ffff8803e4e33d70 ffffffffa001f06e
<0> ffff8803e4e33d60 ffff88041c51ada0 ffff88041acb7200 ffff88041bc0aa00
<0> ffff8803e4e33d90 ffffffffa0032b6c 0000000000000014 ffff88041acb7200
Call Trace:
[<ffffffffa001f06e>] sas_port_delete_phy+0x2e/0xa0 [scsi_transport_sas]
[<ffffffffa0032b6c>] sas_unregister_devs_sas_addr+0xac/0xe0 [libsas]
[<ffffffffa0034914>] sas_ex_revalidate_domain+0x204/0x330 [libsas]
[<ffffffffa00307f0>] ? sas_revalidate_domain+0x0/0x90 [libsas]
[<ffffffffa0030855>] sas_revalidate_domain+0x65/0x90 [libsas]
[<ffffffff8108c7d0>] worker_thread+0x170/0x2a0
[<ffffffff81091ea0>] ? autoremove_wake_function+0x0/0x40
[<ffffffff8108c660>] ? worker_thread+0x0/0x2a0
[<ffffffff81091b36>] kthread+0x96/0xa0
[<ffffffff810141ca>] child_rip+0xa/0x20
[<ffffffff81091aa0>] ? kthread+0x0/0xa0
[<ffffffff810141c0>] ? child_rip+0x0/0x20
Code: ff ff 85 c0 75 ed eb d6 66 90 55 48 89 e5 48 83 ec 10 48 89 1c 24
4c 89 64 24 08 0f 1f 44 00 00 48 89 fb e8 92 f4 ff ff 48 89 df <f0> ff
0f 79 05 e8 25 00 00 00 65 48 8b 04 25 08 cc 00 00 48 2d
RIP [<ffffffff814ca9b1>] mutex_lock+0x21/0x50
RSP <ffff8803e4e33d30>
The following patch is admittedly a band-aid, and does not solve the
root cause, but it still is a good candidate for hardening as a pointer
check before reference.
Signed-off-by: Mark Salyzyn <mark_salyzyn@us.xyratex.com>
Tested-by: Jack Wang <jack_wang@usish.com>
child.
commit 24926dadc41cc566e974022b0e66231b82c6375f upstream.
In an enclosure model where there are chaining expanders to a large body
of storage, it was discovered that libsas, responding to a broadcast
event change, would only revalidate the domain of first child expander
in the list.
The issue is that the pointer value to the discovered source device was
used to break out of the loop, rather than the content of the pointer.
This still remains non-compliant as the revalidate domain code is
supposed to loop through all child expanders, and not stop at the first
one it finds that reports a change count. However, the design of this
routine does not allow multiple device discoveries and that would be a
more complicated set of patches reserved for another day. We are fixing
the glaring bug rather than refactoring the code.
Signed-off-by: Mark Salyzyn <msalyzyn@us.xyratex.com>
commit d0efab26f89506387a1bde898556660e06d7eb15 upstream.
scsi reset on hardware with enabled MSI interrupts generates WARNING message
[11027.798722] aacraid: Host adapter abort request (0,0,0,0)
[11027.798814] aacraid: Host adapter reset request. SCSI hang ?
[11087.762237] aacraid: SCSI bus appears hung
[11135.082543] ------------[ cut here ]------------
[11135.082646] WARNING: at drivers/pci/msi.c:658 pci_enable_msi_block+0x251/0x290()
Signed-off-by: Vasily Averin <vvs@sw.ru>
Acked-by: Mark Salyzyn <mark_salyzyn@us.xyratex.com>
commit 96067723e46b0dd24ae7b934085ab4eff4d26a1b upstream.
Following reports on the list, it looks like the 3e-9xxx driver will leak dma
mappings every time we get a transient queueing error back from the card.
This is because it maps the sg list in the routine that sends the command, but
doesn't unmap again in the transient failure path (even though the command is
sent back to the block layer). Fix by unmapping before returning the status.
Reported-by: Chris Boot <bootc@bootc.net>
Tested-by: Chris Boot <bootc@bootc.net>
Acked-by: Adam Radford <aradford@gmail.com>
commit db1d350fcb156b58f66a67680617077bcacfe6fc upstream.
During NETDEV_UP, we use symbol_get() to get the net driver's cnic
probe function. This sometimes doesn't work if NETDEV_UP happens
right after NETDEV_REGISTER and the net driver is still running module
init code. As a result, the cnic device may not be discovered. We
fix this by probing on all NETDEV events if the device's netif_running
state is up.
Signed-off-by: Michael Chan <mchan@broadcom.com>
commit 74dcd0ec735ba9c5bef254b2f6e53068cf3f9ff0 upstream.
Have libiscsi_tcp have upper layers allocate the LLD data
along with the iscsi_cls_conn struct, so it is refcounted.
Signed-off-by: Mike Christie <michaelc@cs.wisc.edu>
commit 3321c07ae5068568cd61ac9f4ba749006a7185c9 upstream.
Since the buffer might contain security related data it might be a good idea to
zero the buffer after we have copied it to userspace.
This got assigned CVE-2011-1162.
Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com>
Signed-off-by: James Morris <jmorris@namei.org>
commit 6b07d30aca7e52f2881b8c8c20c8a2cd28e8b3d3 upstream.
This patch changes the call of tpm_transmit by supplying the size of the
userspace buffer instead of TPM_BUFSIZE.
This got assigned CVE-2011-1161.
[The first hunk didn't make sense given one could expect
way less data than TPM_BUFSIZE, so added tpm_transmit boundary
check over bufsiz instead
The last parameter of tpm_transmit() reflects the amount
of data expected from the device, and not the buffer size
being supplied to it. It isn't ideal to parse it directly,
so we just set it to the maximum the input buffer can handle
and let the userspace API to do such job.]
commit 8c2381af0d3ef62a681dac5a141b6dabb27bf2e1 upstream.
Currently, the hvc_console_print() function drops console output if the
hvc backend's put_chars() returns 0. This patch changes this behavior
to allow a retry through returning -EAGAIN.
This change also affects the hvc_push() function. Both functions are
changed to handle -EAGAIN and to retry the put_chars() operation.
If a hvc backend returns -EAGAIN, the retry handling differs:
- hvc_console_print() spins to write the complete console output.
- hvc_push() behaves the same way as for returning 0.
Now hvc backends can indirectly control the way how console output is
handled through the hvc console layer.
Signed-off-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com>
Acked-by: Anton Blanchard <anton@samba.org>
commit 308859097831831a979f2e82cbeef0a94f438080 upstream.
This device can be found in Acer Iconia TAB W500 tablet dock.
commit 8d48fdf689fed2c73c493e5146d1463689246442 upstream.
PL2303: correctly handle baudrates above 115200
Signed-off-by: Michal Sroczynski <msroczyn@gmail.com>
commit 8c23516fbb209ccf8f8c36268311c721faff29ee upstream.
In ad-hoc mode, driver b43 does not issue beacons.
Signed-off-by: Manual Munz <freifunk@somakoma.de>
Tested-by: Larry Finger <Larry.Finger@lwfinger.net>
commit e2faeec2de9e2c73958e6ea6065dde1e8cd6f3a2 upstream.
The checksum field in the EEPROM on HPPA is really not a
checksum but a signature (0x16d6). So allow 0x16d6 as the
matching checksum on HPPA systems.
This issue is present on longterm/stable kernels, I have
verified that this patch is applicable back to at least
2.6.32.y kernels.
v2- changed ifdef to use CONFIG_PARISC instead of __hppa__
CC: Guy Martin <gmsoft@tuxicoman.be>
CC: Rolf Eike Beer <eike-kernel@sf-tec.de>
CC: Matt Turner <mattst88@gmail.com>
Reported-by: Mikulas Patocka <mikulas@artax.kerlin.mff.cuni.cz>
Acked-by: Jesse Brandeburg <jesse.brandeburg@intel.com>
commit 58b48576966ed0afd3f63ef17480ec12748a7119 upstream.
Transitioning to a LOOP_UPDATE loop-state could cause the driver
to miss normal link/target processing. LOOP_UPDATE is a crufty
artifact leftover from at time the driver performed it's own
internal command-queuing. Safely remove this state.
Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com>
Signed-off-by: Chad Dupuis <chad.dupuis@qlogic.com>
commit f470e5ae34d68880a38aa79ee5c102ebc2a1aef6 upstream.
Fix section mismatch warning:
WARNING: drivers/net/irda/smsc-ircc2.o(.devinit.text+0x1a7): Section mismatch in reference from the function smsc_ircc_pnp_probe() to the function .init.text:smsc_ircc_open()
commit 27a7b260f71439c40546b43588448faac01adb93 upstream.
0.90 metadata uses an unsigned 32bit number to count the number of
kilobytes used from each device.
This should allow up to 4TB per device.
However we multiply this by 2 (to get sectors) before casting to a
larger type, so sizes above 2TB get truncated.
Also we allow rdev->sectors to be larger than 4TB, so it is possible
for the array to be resized larger than the metadata can handle.
So make sure rdev->sectors never exceeds 4TB when 0.90 metadata is in
used.
Also the sanity check at the end of super_90_load should include level
1 as it used ->size too. (RAID0 and Linear don't use ->size at all).
Reported-by: Pim Zandbergen <P.Zandbergen@macroscoop.nl>
Signed-off-by: NeilBrown <neilb@suse.de>
commit 1b6afa17581027218088a18a9ceda600e0ddba7a upstream.
I don't know what I was thinking putting 'rcu' after a dynamically
sized array! The array could still be in use when we call rcu_free()
(That is the point) so we mustn't corrupt it.
commit 4352b47ab7918108b389a48d2163c9a4c2aaf139 upstream.
barrier variable is int, not long. This overflow caused another variable
override: "err" (in PV code) and "binfo" (in xenlinux code -
drivers/xen/blkfront/blkfront.c). The later caused incorrect device
flags (RO/removable etc).
Signed-off-by: Marek Marczykowski <marmarek@mimuw.edu.pl>
Acked-by: Ian Campbell <Ian.Campbell@citrix.com>
[v1: Changed title]
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit 8e1e8a4779cb23c1d9f51e9223795e07ec54d77a upstream.
Found this problem when testing IPv6 from a KVM guest to a remote
host via e1000e device on the host.
The following patch fixes the check for IPv6 GSO packet in Intel
ethernet drivers to use skb_is_gso_v6(). SKB_GSO_DODGY is also set
when packets are forwarded from a guest.
Signed-off-by: Sridhar Samudrala <sri@us.ibm.com>
Signed-off-by: Faidon Liambotis <paravoid@debian.org>
commit 543cc38c8fe86deba4169977c61eb88491036837 upstream.
When hibernating ->resume may not be called by usb core, but disconnect
and probe instead, so we do not increase the counter after decreasing
it in ->supend. As a result we free memory early, and get crash when
unplugging usb dongle.
BUG: unable to handle kernel paging request at 6b6b6b9f
IP: [<c06909b0>] driver_sysfs_remove+0x10/0x30
*pdpt = 0000000034f21001 *pde = 0000000000000000
Pid: 20, comm: khubd Not tainted 3.1.0-rc1-wl+ #20 LENOVO 6369CTO/6369CTO
EIP: 0060:[<c06909b0>] EFLAGS: 00010202 CPU: 1
EIP is at driver_sysfs_remove+0x10/0x30
EAX: 6b6b6b6b EBX: f52bba34 ECX: 00000000 EDX: 6b6b6b6b
ESI: 6b6b6b6b EDI: c0a0ea20 EBP: f61c9e68 ESP: f61c9e64
DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068
Process khubd (pid: 20, ti=f61c8000 task=f6138270 task.ti=f61c8000)
Call Trace:
[<c06909ef>] __device_release_driver+0x1f/0xa0
[<c0690b20>] device_release_driver+0x20/0x40
[<c068fd64>] bus_remove_device+0x84/0xe0
[<c068e12a>] ? device_remove_attrs+0x2a/0x80
[<c068e267>] device_del+0xe7/0x170
[<c06d93d4>] usb_disconnect+0xd4/0x180
[<c06d9d61>] hub_thread+0x691/0x1600
[<c0473260>] ? wake_up_bit+0x30/0x30
[<c0442a39>] ? complete+0x49/0x60
[<c06d96d0>] ? hub_disconnect+0xd0/0xd0
[<c0472eb4>] kthread+0x74/0x80
[<c0472e40>] ? kthread_worker_fn+0x150/0x150
[<c0809b3e>] kernel_thread_helper+0x6/0x10
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
Acked-by: Ivo van Doorn <IvDoorn@gmail.com>
ehci_bus_resume().
commit d0f2fb2500b1c5fe4967eb45d8c9bc758d7aef80 upstream.
From EHCI Spec p.28 HC should clear PORT_SUSPEND when SW clears
PORT_RESUME. In Intel Oaktrail platform, MPH (Multi-Port Host
Controller) core clears PORT_SUSPEND directly when SW sets PORT_RESUME
bit. If we rely on PORT_SUSPEND bit to stop USB resume, we will miss
the action of clearing PORT_RESUME. This will cause unexpected long
resume signal on USB bus.
Signed-off-by: Wang Zhi <zhi.wang@windriver.com>
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
commit c96fbdd0ab97235f930ebf24b38fa42a2e3458cf upstream.
Calao use on there dev kits a FT2232 where the port 0 is used for the JTAG and
port 1 for the UART
They use the same VID and PID as FTDI Chip but they program the manufacturer
name in the eeprom
So use this information to detect it
Cc: Gregory Hermant <gregory.hermant@calao-systems.com>
Cc: Alan Cox <alan@linux.intel.com>
