As HW cursor BOs never move, we can store the offset in VRAM in the
cursor-plane's HWC state. This removes the last possible source of
runtime errors from atomic_update.
Signed-off-by: Thomas Zimmermann <tzimmermann@suse.de>
Acked-by: Gerd Hoffmann <kraxel@redhat.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20210209134632.12157-10-tzimmermann@suse.de
The BOs of the hardware cursor are now mapped permanently while the
cursor plane is being used. This reduces the CPU overhead of the cursor
plane's atomic_update function.
The change also resolves a problem with the vmap call in the commit tail.
The vmap implementation could acquire the DMA reservation lock on the
BO, which is not allowed that late in the atomic update. Removing the
vmap call from atomic_update fixes the issue.
Link: https://patchwork.freedesktop.org/patch/msgid/20210209134632.12157-9-tzimmermann@suse.de
The cursor uses two BOs in video RAM to implement double buffering. Store
both in struct ast_cursor_plane.
Link: https://patchwork.freedesktop.org/patch/msgid/20210209134632.12157-8-tzimmermann@suse.de
Cursor state is currently located throughout struct ast_private. Having
struct ast_cursor_plane as dedicated data structure for cursors helps to
organize the modesetting code.
Link: https://patchwork.freedesktop.org/patch/msgid/20210209134632.12157-7-tzimmermann@suse.de
The logic for cursor updates is now located in the cursor plane's
modesetting code. A number of helper functions remain to modify the
rsp registers and image.
Link: https://patchwork.freedesktop.org/patch/msgid/20210209134632.12157-6-tzimmermann@suse.de
The BOs are eventually released by the cursor plane's destroy callback.
Link: https://patchwork.freedesktop.org/patch/msgid/20210209134632.12157-5-tzimmermann@suse.de
This change will help with inlining cursor functions into modesetting
code. The primary plane's field used to be cleared with memset(). This
has been dropped as the memory is always allocated with kzalloc().
Link: https://patchwork.freedesktop.org/patch/msgid/20210209134632.12157-4-tzimmermann@suse.de
Use AST_MAX_HWC_HEIGHT for setting offset_y in the cursor plane's
atomic_check. The code used AST_MAX_HWC_WIDTH instead. This worked
because both constants has the same value.
Link: https://patchwork.freedesktop.org/patch/msgid/20210209134632.12157-3-tzimmermann@suse.de
Set the bits in VGACRCB with constants. Alo move the rsp code into a
helper function.
Link: https://patchwork.freedesktop.org/patch/msgid/20210209134632.12157-2-tzimmermann@suse.de
The drm_display_mode_to_videomode() does not populate DISPLAY_FLAGS_DE_LOW
or DISPLAY_FLAGS_PIXDATA_NEGEDGE flags in struct videomode. Therefore, no
matter what polarity the next bridge or display might require, these flags
are never set, and thus the LTDC GCR_DEPOL and GCR_PCPOL bits are never set
and the LTDC behaves as if both DISPLAY_FLAGS_PIXDATA_POSEDGE and
DISPLAY_FLAGS_DE_HIGH were always set.
The fix for this problem is taken almost verbatim from MXSFB driver. In
case there is a bridge attached to the LTDC, the bridge might have extra
polarity requirements, so extract bus_flags from the bridge and use them
for LTDC configuration. Otherwise, extract bus_flags from the connector,
which is the display.
Fixes: b759012c5fa7 ("drm/stm: Add STM32 LTDC driver")
Signed-off-by: Yannick Fertre <yannick.fertre@st.com>
Cc: Alexandre Torgue <alexandre.torgue@st.com>
Cc: Antonio Borneo <antonio.borneo@st.com>
Cc: Benjamin Gaignard <benjamin.gaignard@st.com>
Cc: Maxime Coquelin <mcoquelin.stm32@gmail.com>
Cc: Philippe Cornu <philippe.cornu@st.com>
Cc: Vincent Abriou <vincent.abriou@st.com>
Cc: Yannick Fertre <yannick.fertre@st.com>
Cc: linux-stm32@st-md-mailman.stormreply.com
To: dri-devel@lists.freedesktop.org
Tested-by: Yannick Fertre <yannick.fertre@foss.st.com>
Signed-off-by: Philippe Cornu <philippe.cornu@foss.st.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20210127110756.125570-1-marex@denx.de
Doing a hw-irq -> threaded-irq round-trip is counter-productive, stay
in the threaded irq handler as long as we can.
v2:
* Rework the loop to avoid a goto
Signed-off-by: Boris Brezillon <boris.brezillon@collabora.com>
Reviewed-by: Steven Price <steven.price@arm.com>
Reviewed-by: Rob Herring <robh@kernel.org>
Link: https://patchwork.freedesktop.org/patch/msgid/20210205111757.585248-4-boris.brezillon@collabora.com
We allocate 2MB chunks at a time, so it might appear that a page fault
has already been handled by a previous page fault when we reach
panfrost_mmu_map_fault_addr(). Bail out in that case to avoid mapping the
same area twice.
Cc: <stable@vger.kernel.org>
Fixes: 187d2929206e ("drm/panfrost: Add support for GPU heap allocations")
Link: https://patchwork.freedesktop.org/patch/msgid/20210205111757.585248-3-boris.brezillon@collabora.com
When a fault is handled it will unblock the GPU which will continue
executing its shader and might fault almost immediately on a different
page. If we clear interrupts after handling the fault we might miss new
faults, so clear them before.
Link: https://patchwork.freedesktop.org/patch/msgid/20210205111757.585248-2-boris.brezillon@collabora.com
Swapping bo->mem was completely unecessary. Cleanup the function which
is just a leftover from a TTM cleanup.
Signed-off-by: Christian König <christian.koenig@amd.com>
Reviewed-by: Thomas Zimmermann <tzimmermann@suse.de>
Tested-by: Thomas Zimmermann <tzimmermann@suse.de>
Link: https://patchwork.freedesktop.org/patch/msgid/20210211131659.276275-1-christian.koenig@amd.com
There's no need to check for the presence of the hotplug
property just to return because this is the end of the function
so we're returning either way.
Signed-off-by: Zack Rusin <zackr@vmware.com>
Reviewed-by: Martin Krastev <krastevm@vmware.com>
Reviewed-by: Roland Scheidegger <sroland@vmware.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20210209161700.335611-2-zackr@vmware.com
Our sysfs "modes" entries were broken because our preffered mode
never had its name set correctly. This resulted in the first
entry simply being called "preferred" followed by a list of
other resolutions. Lets fix it by actually setting the name of
mode (which is its resolution). This allows one to quickly
validate the modes set by the open-vm-tools.
Link: https://patchwork.freedesktop.org/patch/msgid/20210209161700.335611-1-zackr@vmware.com
The default list was old and in particular lacking all common 16:9
resolutions, as well as some newer 16:10 ones.
This makes them selectable in resolution change lists, which can be
quite useful (for instance in case auto-fit isn't enabled).
Signed-off-by: Roland Scheidegger <sroland@vmware.com>
Reviewed-by: Zack Rusin <zackr@vmware.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20210205010446.26559-1-sroland@vmware.com
Use getter and setter functions, for platform_device structures and a
mipi_dsi_device structure.
Signed-off-by: Julia Lawall <Julia.Lawall@inria.fr>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Link: https://patchwork.freedesktop.org/patch/msgid/20210209211304.1261740-1-Julia.Lawall@inria.fr
I got real badly confused when trying to review a fix from Ville for
this. Let's try to document better what's required for this, and check
the minimal settings at runtime - we can't check ofc that there's
indeed no races in the driver callback.
Also noticed that the drm_vblank_restore version is unused, so lets
unexport that while at it.
Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Cc: Ville Syrjala <ville.syrjala@linux.intel.com>
Signed-off-by: Daniel Vetter <daniel.vetter@intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20210209101523.2954281-1-daniel.vetter@ffwll.ch
DE3.0 VI layers supports plane-global alpha channel.
DE2.0 FCC block have GLOBAL_ALPHA register that can be used as alpha source
for blender.
Add alpha property to the DRM plane and connect it to the
corresponding registers in the mixer.
Do not add alpha property for V3s SOC that have DE2.0 and 2 VI planes.
Signed-off-by: Roman Stratiienko <r.stratiienko@gmail.com>
Reviewed-by: Jernej Skrabec <jernej.skrabec@siol.net>
Signed-off-by: Maxime Ripard <maxime@cerno.tech>
Link: https://patchwork.freedesktop.org/patch/msgid/20210128113940.347013-3-r.stratiienko@gmail.com
DE2.0 and DE3.0 UI layers supports plane-global alpha channel.
corresponding registers in mixer.
Link: https://patchwork.freedesktop.org/patch/msgid/20210128113940.347013-2-r.stratiienko@gmail.com
There are minor differences in the values for the threshold value and
the scan line size between families of ASPEED SoC. Additionally the SCU
registers for the output control and scratch registers differ between
families.
This adds device tree matching to parameterise these values, allowing us
to add support for the AST2400 now, and in the future the AST2600.
Reviewed-by: Jeremy Kerr <jk@ozlabs.org>
Signed-off-by: Joel Stanley <joel@jms.id.au>
Link: https://patchwork.freedesktop.org/patch/msgid/20210209123734.130483-3-joel@jms.id.au
This scales better to multiple families of SoC. The lookup by compatible
can be removed in a future change.
The fallback path is for the ast2500 platform only. Other platforms will
be added with the new style, so they won't need fallback paths.
Reviewed-by: Andrew Jeffery <andrew@aj.id.au>
Link: https://patchwork.freedesktop.org/patch/msgid/20210209123734.130483-2-joel@jms.id.au
When run xrandr to change resolution on Beaglebone Black board, it will
print the error information:
root@beaglebone:~# xrandr -display :0 --output HDMI-1 --mode 720x400
[drm:drm_crtc_commit_wait] *ERROR* flip_done timed out
[drm:drm_atomic_helper_wait_for_dependencies] *ERROR* [CRTC:32:tilcdc crtc] commit wait timed out
[drm:drm_atomic_helper_wait_for_dependencies] *ERROR* [CONNECTOR:34:HDMI-A-1] commit wait timed out
[drm:drm_atomic_helper_wait_for_dependencies] *ERROR* [PLANE:31:plane-0] commit wait timed out
tilcdc 4830e000.lcdc: already pending page flip!
This is because there is operation sequence as below:
drm_atomic_connector_commit_dpms(mode is DRM_MODE_DPMS_OFF):
drm_atomic_helper_setup_commit <- init_completion(commit_A->flip_done)
drm_atomic_helper_commit_tail
tilcdc_crtc_atomic_disable
tilcdc_plane_atomic_update <- drm_crtc_send_vblank_event in tilcdc_crtc_irq
is skipped since tilcdc_crtc->enabled is 0
tilcdc_crtc_atomic_flush <- drm_crtc_send_vblank_event is skipped since
crtc->state->event is set to be NULL in
drm_mode_setcrtc:
drm_atomic_helper_setup_commit <- init_completion(commit_B->flip_done)
drm_crtc_commit_wait <- wait for commit_A->flip_done completing
Just as shown above, the steps which could complete commit_A->flip_done
are all skipped and commit_A->flip_done will never be completed. This will
result a time-out ERROR when drm_crtc_commit_wait check the commit_A->flip_done.
So add drm_crtc_send_vblank_event in tilcdc_crtc_atomic_disable to
complete commit_A->flip_done.
Fixes: cb345decb4d2 ("drm/tilcdc: Use standard drm_atomic_helper_commit")
Signed-off-by: Quanyang Wang <quanyang.wang@windriver.com>
Reviewed-by: Jyri Sarha <jyri.sarha@iki.fi>
Tested-by: Jyri Sarha <jyri.sarha@iki.fi>
Signed-off-by: Jyri Sarha <jyri.sarha@iki.fi>
Link: https://patchwork.freedesktop.org/patch/msgid/20210209082415.382602-1-quanyang.wang@windriver.com
Not used any more.
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Link: https://patchwork.freedesktop.org/patch/msgid/20210208133226.36955-3-christian.koenig@amd.com
This is just another feature which is only used by VMWGFX, so move
it into the driver instead.
I've tried to add the accounting sysfs file to the kobject of the drm
minor, but I'm not 100% sure if this works as expected.
v2: fix typo in KFD and avoid 64bit divide
v3: fix init order in VMWGFX
v4: use pdev sysfs reference instead of drm
Reviewed-by: Zack Rusin <zackr@vmware.com> (v3)
Tested-by: Nirmoy Das <nirmoy.das@amd.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20210208133226.36955-2-christian.koenig@amd.com
TTM implements a rather extensive accounting of allocated memory.
There are two reasons for this:
1. It tries to block userspace allocating a huge number of very small
BOs without accounting for the kmalloced memory.
2. Make sure we don't over allocate and run into an OOM situation
during swapout while trying to handle the memory shortage.
This is only partially a good idea. First of all it is perfectly
valid for an application to use all of system memory, limiting it to
50% is not really acceptable.
What we need to take care of is that the application is held
accountable for the memory it allocated. This is what control
mechanisms like memcg and the normal Linux page accounting already do.
Making sure that we don't run into an OOM situation while trying to
cope with a memory shortage is still a good idea, but this is also
not very well implemented since it means another opportunity of
recursion from the driver back into TTM.
So start to rework all of this by implementing a shrinker callback which
allows for TT object to be swapped out if necessary.
v2: Switch from limit to shrinker callback.
v3: fix gfp mask handling, use atomic for swapable_pages, add debugfs
v4: drop the extra gfp_mask checks
Link: https://patchwork.freedesktop.org/patch/msgid/20210208133226.36955-1-christian.koenig@amd.com
Only a zombie leftover from rebasing.
Fixes: 3763d635deaa ("drm/ttm: add debugfs directory v2")
Reported-by: Gerd Hoffmann <kraxel@redhat.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20210209131756.24650-1-christian.koenig@amd.com
Functions in the atomic commit tail are not allowed to acquire the
dmabuf's reservation lock. So we cannot legally call the GEM object's
vmap functionality in atomic_update.
Instead use struct drm_shadow_plane_state and friends. It vmaps the
framebuffer BOs in prepare_fb and vunmaps them in cleanup_fb. The
cursor plane state stores the mapping's address. The pinning of the
BO is implicitly done by vmap.
As an extra benefit, there's no source of runtime errors left in
atomic_update.
v2:
* rebase patch onto struct drm_shadow_plane_state
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
Tested-by: Hans de Goede <hdegoede@redhat.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20210209121042.24098-3-tzimmermann@suse.de
Export the helpers for shadow-buffered planes. These will be used by
several drivers.
v3:
* fix documentation typos and formatting (Daniel)
Link: https://patchwork.freedesktop.org/patch/msgid/20210209121042.24098-2-tzimmermann@suse.de
Blits cannot happen anymore since we removed the 2d accel code. Stop
checking for a busy blitter and remove the remaining blitter code.
Signed-off-by: Patrik Jakobsson <patrik.r.jakobsson@gmail.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20210201132617.1233-6-patrik.r.jakobsson@gmail.com
Since everything else in accel_2d.c got removed we can move psb_spank()
into psb_drv.c where it is used.
Link: https://patchwork.freedesktop.org/patch/msgid/20210201132617.1233-5-patrik.r.jakobsson@gmail.com
CDV crtc helpers are identical to other chips so use gma_ prefix for the
crtc helper struct and remove the CDV copy.
Link: https://patchwork.freedesktop.org/patch/msgid/20210201132617.1233-4-patrik.r.jakobsson@gmail.com
Afaik tv out is not available on Cedarview and the code isn't doing
anything so remove it.
Link: https://patchwork.freedesktop.org/patch/msgid/20210201132617.1233-3-patrik.r.jakobsson@gmail.com
DPST never got enabled so remove it. We keep the reg save/restore code
just for safety.
Link: https://patchwork.freedesktop.org/patch/msgid/20210201132617.1233-2-patrik.r.jakobsson@gmail.com
Clearly never been used so just remove it.
Link: https://patchwork.freedesktop.org/patch/msgid/20210201132617.1233-1-patrik.r.jakobsson@gmail.com
With support for the MID-only Medfield chips removed, simply build
the complete driver if DRM_GMA500 has been selected. Anyone who wants
to enable one of the chips would probably also want the rest.
Fixes: 837f23bb4b60 ("drm/gma500: Drop DRM_GMA3600 config option")
Cc: Patrik Jakobsson <patrik.r.jakobsson@gmail.com>
Cc: dri-devel@lists.freedesktop.org
Link: https://patchwork.freedesktop.org/patch/msgid/20210209112721.3421-1-tzimmermann@suse.de
The driver is using msleep() if it is safe to use based on in_atomic().
This is not needed this macro is only used from
i2c_algorithm::master_xfer() which is always invoked from preemptible
context.
Remove in_atomic() because it is superfluous. Remove wait_for_atomic()
because it has no users.
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Link: https://patchwork.freedesktop.org/patch/msgid/20210208233119.391103-2-bigeasy@linutronix.de
Vmap operations may acquire the dmabuf reservation lock, which is not
allowed within atomic commit-tail functions. Therefore move vmap and
vunmap from the damage handler into prepare_fb and cleanup_fb callbacks.
The mapping is provided as GEM shadow-buffered plane. The functions in
the commit tail use the pre-established mapping for damage handling.
Tested-by: Gerd Hoffmann <kraxel@redhat.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20210208115538.6430-8-tzimmermann@suse.de
Link: https://patchwork.freedesktop.org/patch/msgid/20210208115538.6430-7-tzimmermann@suse.de
Link: https://patchwork.freedesktop.org/patch/msgid/20210208115538.6430-6-tzimmermann@suse.de
Link: https://patchwork.freedesktop.org/patch/msgid/20210208115538.6430-5-tzimmermann@suse.de
Several drivers use GEM buffer objects as shadow buffers for the actual
framebuffer memory. Right now, drivers do these vmap operations in their
commit tail, which is actually not allowed by the locking rules for
the dma-buf reservation lock. The involved BO has to be vmapped in the
plane's prepare_fb callback and vunmapped in cleanup_fb.
This patch introduces atomic helpers for such shadow planes. Plane
functions manage the plane state for shadow planes. The provided
implementations for prepare_fb and cleanup_fb vmap and vunmap all BOs of
struct drm_plane_state.fb. The mappings are afterwards available in the
plane's commit-tail functions.
For now, all rsp drivers use the simple KMS helpers, so we add the plane
callbacks and wrappers for simple KMS. The internal plane functions can
later be exported as needed.
v3:
* documentation fixes
v2:
* make duplicate_state interface compatible with
struct drm_plane_funcs
Link: https://patchwork.freedesktop.org/patch/msgid/20210208115538.6430-4-tzimmermann@suse.de
The symbols will be required by the upcoming helpers for shadow-buffered
planes.
Reported-by: kernel test robot <lkp@intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20210208115538.6430-3-tzimmermann@suse.de
Just like regular plane-state helpers, drivers can use these new
callbacks to create and destroy private plane state.
v2:
Link: https://patchwork.freedesktop.org/patch/msgid/20210208115538.6430-2-tzimmermann@suse.de
This patch adapts the panfrost pre-defined thresholds change [0] to the
lima driver to improve real-world performance. The upthreshold value has
been set to ramp GPU frequency to max freq faster (compared to panfrost)
to compensate for the lower overall performance of utgard devices.
[0] https://patchwork.kernel.org/project/dri-devel/patch/20210121170445.19761-1-lukasz.luba@arm.com/
Signed-off-by: Christian Hewitt <christianshewitt@gmail.com>
Reviewed-by: Lukasz Luba <lukasz.luba@arm.com>
Signed-off-by: Qiang Yu <yuq825@gmail.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20210127194047.21462-1-christianshewitt@gmail.com
Devfreq framework supports 2 modes for monitoring devices.
Use delayed timer as default instead of deferrable timer
in order to monitor the GPU status regardless of CPU idle.
Signed-off-by: Lukasz Luba <lukasz.luba@arm.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20210127105121.20345-1-lukasz.luba@arm.com
Don't populate the const array m_div_val on the stack but instead make
it static. Makes the object code smaller by 29 bytes:
Before:
34736 4552 0 39288 9978 drivers/gpu/drm/mgag200/mgag200_mode.o
After:
34625 4616 0 39241 9949 drivers/gpu/drm/mgag200/mgag200_mode.o
(gcc version 10.2.0)
Link: https://patchwork.freedesktop.org/patch/msgid/20210204191156.110778-1-colin.king@canonical.com
Allow multiple schedulers to share the load balancing score.
This is useful when one engine has different hw rings.
Reviewed-and-Tested-by: Leo Liu <leo.liu@amd.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20210204144405.2737-1-christian.koenig@amd.com
dumb buffers are shadowed anyway, so there is no need to store them
in device memory. Use QXL_GEM_DOMAIN_CPU (TTM_PL_SYSTEM) instead.
Signed-off-by: Gerd Hoffmann <kraxel@redhat.com>
Acked-by: Thomas Zimmermann <tzimmermann@suse.de>
Link: http://patchwork.freedesktop.org/patch/msgid/20210204145712.1531203-11-kraxel@redhat.com
