path: root/drivers
2008-03-11Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: RDMA/iwcm: Don't access a cm_id after dropping reference IB/iser: Handle iser_device allocation error gracefully IB/iser: Fix list iteration bug RDMA/cxgb3: Fix iwch_create_cq() off-by-one error RDMA/cxgb3: Return correct max_inline_data when creating a QP IB/fmr_pool: Flush all dirty FMRs from ib_fmr_pool_flush() Revert "IB/fmr_pool: ib_fmr_pool_flush() should flush all dirty FMRs" IB/cm: Flush workqueue when removing device MAINTAINERS: update ipath owner
2008-03-10RDMA/iwcm: Don't access a cm_id after dropping referenceSteve Wise
cm_work_handler() can access cm_id_priv after it drops its reference by calling iwch_deref_id(), which might cause it to be freed. The fix is to look at whether IWCM_F_CALLBACK_DESTROY is set _before_ dropping the reference. Then if it was set, free the cm_id on this thread. Signed-off-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-03-10IB/iser: Handle iser_device allocation error gracefullyArne Redlich
"iser_device" allocation failure is "handled" with a BUG_ON() right before dereferencing the NULL-pointer - fix this! Signed-off-by: Arne Redlich <arne.redlich@xiranet.com> Signed-off-by: Erez Zilber <erezz@voltaire.com>
2008-03-10IB/iser: Fix list iteration bugArne Redlich
The iteration through the list of "iser_device"s during device lookup/creation is broken -- it might result in an infinite loop if more than one HCA is used with iSER. Fix this by using list_for_each_entry() instead of the open-coded flawed list iteration code. Signed-off-by: Arne Redlich <arne.redlich@xiranet.com> Signed-off-by: Erez Zilber <erezz@voltaire.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-03-10Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev: [libata] Add support for the RB500 PATA CompactFlash ahci: logical-bitwise and confusion in ahci_save_initial_config() libata: don't allow sysfs read access to force param ahci: add the Device IDs for nvidia MCP7B AHCI libata-sff: handle controllers w/o ctl register libata: allow LLDs w/o any reset method ata: replace remaining __FUNCTION__ occurrences
2008-03-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: USB:Update mailing list information in documentation USB: fix ehci unlink regressions USB: new ftdi_sio device id USB: Remove __KERNEL__ check from non-exported gadget.h. USB: g_printer.h does not need to be "unifdef"ed. USB: fsl_usb2_udc: fix broken Kconfig USB: option: add novatel device ids USB: usbaudio: handle kcalloc failure USB: cypress_m8: add UPS Powercom (0d9f:0002) USB: drivers/usb/storage/sddr55.c: fix uninitialized var warnings USB: fix usb-serial generic recursive lock
2008-03-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/pci-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/pci-2.6: PCI Hotplug: Fix small mem leak in IBM Hot Plug Controller Driver PCI: rename DECLARE_PCI_DEVICE_TABLE to DEFINE_PCI_DEVICE_TABLE
2008-03-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6: drivers: fix dma_get_required_mask firmware: provide stubs for the FW_LOADER=n case nozomi: fix initialization and early flow control access sysdev: fix problem with sysdev_class being re-registered
2008-03-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: lguest: Do not append space to guests kernel command line lguest: Revert 1ce70c4fac3c3954bd48c035f448793867592bc0, fix real problem. lguest: Sanitize the lguest clock. lguest: fix __get_vm_area usage. lguest: make sure cpu is initialized before accessing it
2008-03-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdogLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdog: [WATCHDOG] make watchdog/hpwdt.c:asminline_call() static [WATCHDOG] Remove volatiles from watchdog device structures [WATCHDOG] replace remaining __FUNCTION__ occurrences [WATCHDOG] hpwdt: Use dmi_walk() instead of own copy [WATCHDOG] Fix return value warning in hpwdt [WATCHDOG] Fix declaration of struct smbios_entry_point in hpwdt [WATCHDOG] it8712f_wdt support for 16-bit timeout values, WDIOC_GETSTATUS
2008-03-10fbdev: add BF52x EZkit Display driverMichael Hennerich
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com> Cc: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-10BF54x LQ043 Framebuffer driver: Update copyright on previously modified filesMichael Hennerich
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-10BF54x LQ043 Framebuffer driver: fix bug lcd_device_register API breakageBryan Wu
2008-03-10BF54x LQ043 Framebuffer driver: fix bug NULL for gpio_request label is not ↵Michael Hennerich
allowed Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-10stifb: fix crash A1439A CRX (Rattler) graphics cardHelge Deller
Fix kernel crash when stifb driver is used with a A1439A CRX (Rattler) graphics card. (Reference: http://thread.gmane.org/gmane.linux.ports.hppa/1834) Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-10mbxfb: fix incorrect argument typeKrzysztof Helt
Fix wrong pointer type passed into the dev_dbg() function. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Acked-by: Mike Rapoport <mike@compulab.co.il> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-10i8042: use SGI_HAS_I8042 to select SGI i8042 handlinigThomas Bogendoerfer
Use SGI_HAS_I8042 to select SGI i8042 handling Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Cc: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-10gpio/pca953x bugfix: mark as can_sleepArnaud Patard
The pca953x driver is an I2C driver so gpio_chip->can_sleep should be set. This lets upper layers know they should use the gpio_*_cansleep() calls to access values, and may not access them from nonsleeping contexts. Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: "eric miao" <eric.y.miao@gmail.com> Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-10md: reduce CPU wastage on idle md array with a write-intent bitmapNeilBrown
Recent patch titled Reduce CPU wastage on idle md array with a write-intent bitmap. would sometimes leave the array with dirty bitmap bits that stay dirty. A subsequent write would sort things out so it isn't a big problem, but should be fixed nonetheless. We need to make sure that when the bitmap becomes not "allclean", the daemon_sleep really does get set to a sensible value. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-10md: fix formatting error in /proc/mdstatNeilBrown
If an md array is "auto-read-only", then this appears in /proc/mdstat as /dev/md0: active(auto-read-only) whereas if it is truely readonly, it appears as /dev/md0: active (read-only) The difference being a space. One program known to parse this file expects the space and gets badly confused. It will be fixed, but it would be best if what the kernel generates is more consistent too. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-10memstick: add support for JMicron jmb38x MemoryStick host controllerAlex Dubov
Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-10memstick: try harder to recover from unsuccessful interface mode switchAlex Dubov
2008-03-10memstick: fix parsing of "assembly_date" attribute fieldAlex Dubov
2008-03-10memstick: add support for decoding "specfile" media attributesAlex Dubov
2008-03-10tifm: clear interrupt mask bits before setting them on adapter initAlex Dubov
This should improve reliability of detection of cards already in socket on driver load. Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-10tifm: fix memorystick host initialization codeAlex Dubov
Instead of assuming that host is powered on only once at card insertion, allow for the possibility that memstick layer may need to cycle card's power to get it out from some unhealthy states. Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-10tifm: fix the MemoryStick host fifo handling codeAlex Dubov
Additional input received from JMicron on MemoryStick host interfaces showed that some assumtions in fifo handling code were incorrect. This patch also fixes data corruption used to occure during PIO transfers. Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-10memstick: drop DRIVER_VERSION numbers as meaninglessAlex Dubov
2008-03-10memstick: make sure number of command retries is exactly as specifiedAlex Dubov
2008-03-10memstick: add memstick_suspend/resume_host methodsAlex Dubov
Bus driver may need to be informed that host is being suspended/resumed. Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-10memstick: introduce correct definitions in the headerAlex Dubov
Thanks to some input from kind people at JMicron it is now possible to have more correct definitions of protocol structures and bit field semantics. Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-10tridentfb: fix memory size detectionKrzysztof Helt
Fix memory size multiplier during detection. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-10tridentfb: register should be left in non-locked stateKrzysztof Helt
Remove locking registers after they are unlocked during switch to/from MMIO mode. This fixes regression on the Blade3D (Trident 9880) caused by the previous patch (probe fixes). Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-10of_serial: fix section mismatch warningsJosh Boyer
Fix the following section mismatches: WARNING: drivers/built-in.o(.exit.text+0x5a): Section mismatch in reference from the function of_platform_serial_exit() to the variable .devinit.data:of_platform_serial_driver The function __exit of_platform_serial_exit() references a variable __devinitdata of_platform_serial_driver. Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-10[libata] Add support for the RB500 PATA CompactFlashFlorian Fainelli
Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-03-10ahci: logical-bitwise and confusion in ahci_save_initial_config()Roel Kluin
logical-bitwise & confusion Signed-off-by: Roel Kluin <12o3l@tiscali.nl> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-03-10libata: don't allow sysfs read access to force paramTejun Heo
Buffer for force param is deallocated after initialization, so trying to read it via sysfs results in oops. Don't allow read access to the param node. Spotted by Eric Sesterhenn. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-03-10ahci: add the Device IDs for nvidia MCP7B AHCIpeerchen
Signed-off-by: Peer Chen <peerchen@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-03-10libata-sff: handle controllers w/o ctl registerTejun Heo
SFF incorrectly assumed that ctl register is available for all controllers while some old SFF controllers don't have ctl register. Make SFF handle controllers w/o ctl register by conditionalizing ctl register access and softreset method. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-03-10libata: allow LLDs w/o any reset methodTejun Heo
Some old SFF controllers don't have any way to reset the channel. Currently, this isn't supported and libata EH causes an oops. Allow LLDs w/o any reset method and just assume ATA class in such cases. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-03-10ata: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-03-10USB: fix ehci unlink regressionsDavid Brownell
The recent EHCI driver update to split the IAA watchdog timer out from the other timers made several things work better, but not everything; and it created a couple new issues in bugzilla. Ergo this patch: - Handle a should-be-rare SMP race between the watchdog firing and (very late) IAA interrupts; - Remove a shouldn't-have-been-added WARN_ON() test; - Guard against one observed OOPS; - If this watchdog fires during clean HC shutdown, it should act as a NOP instead of interfering with the shutdown sequence; - Guard against silicon errata hypothesized by some vendors: * IAA status latch broken, but IAAD cleared OK; * IAAD wasn't cleared when IAA status got reported; The WARN_ON is in bugzilla as 10168; the OOPS as 10078; these are both regressions. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Tested-by: Gordon Farquharson <gordonfarquharson@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-10USB: new ftdi_sio device idMirko Bordignon
Here is a patch that adds support for the propox jtagcable II dongle (http://www.propox.com/products/t_117.html): their PID was missing, therefore we were not able to have the device recognized though it uses a standard FTDI chip. Signed-off-by: Mirko Bordignon <mirko.bordignon@ieee.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-10USB: fsl_usb2_udc: fix broken KconfigLi Yang
The patch fixes broken Kconfig caused by the name change of MPC834x option. It also makes fsl_usb2_udc selectable on new platforms like MPC837x. Signed-off-by: Li Yang <leoli@freescale.com> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-10USB: option: add novatel device idsDirk DeSchepper
This updates the option driver with a lot more novatel driver ids. From: Dirk DeSchepper <ddeschepper@nvtl.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-10USB: cypress_m8: add UPS Powercom (0d9f:0002)Dmitry Shapin
Add support for UPS Powercom USB interface (0d9f:0002) in chip CY7C63723. In my case, this Powercom BNT800AP. Signed-off-by: Dmitry Shapin <shapin@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-10USB: drivers/usb/storage/sddr55.c: fix uninitialized var warningsAndrew Morton
drivers/usb/storage/sddr55.c: In function 'sddr55_transport': drivers/usb/storage/sddr55.c:526: warning: 'deviceID' may be used uninitialized in this function drivers/usb/storage/sddr55.c:525: warning: 'manufacturerID' may be used uninitialized in this function Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-10USB: fix usb-serial generic recursive lockPete Zaitcev
Nobody should be using the generic usb-serial for anything other than testing. Still, it's not a good thing that it's easy to lock up. There is a traceback from NMI oopser here: https://bugzilla.redhat.com/show_bug.cgi?id=431379 But in short, if a line discipline has a chance to echo anything, input can loop back a write method. So, don't call tty_flip_buffer_push from under a lock taken on write path. Signed-off-by: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-10PCI Hotplug: Fix small mem leak in IBM Hot Plug Controller DriverJesper Juhl
In drivers/pci/hotplug/ibmphp_ebda.c::ebda_rsrc_controller(), storage is allocated with kzalloc() and assigned to 'tmp_slot'. Then lots of stuff, like ->flag, ->supported_speed etc is set in tmp_slot. A bit further down there's then this test : if (!bus_info_ptr1) { rc = -ENODEV; goto error; } At this point, tmp_slot has not been assigned to anything, so when erroring-out we want to free it, but nothing at the 'error:' label free's 'tmp_slot' - and we can't really free 'tmp_slot' at 'error:' since we may jump to that label later when 'tmp_slot' *has* been used and we do not want it freed. So, the only sane option left seems to be to kfree(tmp_slot) just before jumping to the 'error:' label in the one place where this is what actually makes sense. The following patch does just that and thus kills off a tiny potential memory leak. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-10drivers: fix dma_get_required_maskJames Bottomley
There's a bug in the current implementation of dma_get_required_mask() where it ands the returned mask with the current device mask. This rather defeats the purpose if you're using the call to determine what your mask should be (since you will at that time have the default DMA_32BIT_MASK). This bug results in any driver that uses this function *always* getting a 32 bit mask, which is wrong. Fix by removing the and with dev->dma_mask. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
