This avoids having to have differnet mq_ops for different setups
with or without poll queues.
Reviewed-by: Sagi Grimberg <sagi@grimberg.me>
The ->poll_fn has been stale for a while, as a lot of places check for mq
ops. But there is no real point in it anyway, as we don't even use
the multipath code for subsystems without multiple ports, which is usually
what we do high performance I/O to. If it really becomes an issue we
should rework the nvme code to also skip the multipath code for any
private namespace, even if that could mean some trouble when rescanning.
Reviewed-by: Keith Busch <keith.busch@intel.com>
The code was always a bit of a hack that digs far too much into
RDMA core internals. Lets kick it out and reimplement proper
dedicated poll queues as needed.
Now that we can't poll regular, interrupt driven I/O queues there
is almost nothing that can race with an interrupt. The only
possible other contexts polling a CQ are the error handler and
queue shutdown, and both are so far off in the slow path that
we can simply use the big hammer of disabling interrupts.
With that we can stop taking the cq_lock for normal queues.
This is the last place outside of nvme_irq that handles CQEs from
interrupt context, and thus is in the way of removing the cq_lock for
normal queues, and avoiding lockdep warnings on the poll queues, for
which we already take it without IRQ disabling.
Pass the opcode for the delete SQ/CQ command as an argument instead of
the somewhat confusing pass loop.
We have three places that can poll for I/O completions on a normal
interrupt-enabled queue. All of them are in slow path code, so
consolidate them to a single helper that uses spin_lock_irqsave and
removes the fast path cqe_pending check.
This will allow us to simplify both the regular NVMe interrupt handler
and the upcoming aio poll code. In addition to that the separate
queues are generally a good idea for performance reasons.
Use a bit flag to mark if the SQ was allocated from the CMB, and clean
up the surrounding code a bit.
This gets rid of all the messing with cq_vector and the ->polled field
by using an atomic bitop to mark the queue enabled or not.
Having another indirect all in the fast path doesn't really help
in our post-spectre world. Also having too many queue type is just
going to create confusion, so I'd rather manage them centrally.
Note that the queue type naming and ordering changes a bit - the
first index now is the default queue for everything not explicitly
marked, the optional ones are read and poll queues.
Pull in v4.20-rc5, solving a conflict we'll otherwise get in aio.c and
also getting the merge fix that went into mainline that users are
hitting testing for-4.21/block and/or for-next.
* tag 'v4.20-rc5': (664 commits)
Linux 4.20-rc5
PCI: Fix incorrect value returned from pcie_get_speed_cap()
MAINTAINERS: Update linux-mips mailing list address
ocfs2: fix potential use after free
mm/khugepaged: fix the xas_create_range() error path
mm/khugepaged: collapse_shmem() do not crash on Compound
mm/khugepaged: collapse_shmem() without freezing new_page
mm/khugepaged: minor reorderings in collapse_shmem()
mm/khugepaged: collapse_shmem() remember to clear holes
mm/khugepaged: fix crashes due to misaccounted holes
mm/khugepaged: collapse_shmem() stop if punched or truncated
mm/huge_memory: fix lockdep complaint on 32-bit i_size_read()
mm/huge_memory: splitting set mapping+index before unfreeze
mm/huge_memory: rename freeze_page() to unmap_page()
initramfs: clean old path before creating a hardlink
kernel/kcov.c: mark funcs in __sanitizer_cov_trace_pc() as notrace
psi: make disabling/enabling easier for vendor kernels
proc: fixup map_files test on arm
debugobjects: avoid recursive calls with kmemleak
userfaultfd: shmem: UFFDIO_COPY: set the page dirty if VM_WRITE is not set
Pull ARM SoC fixes from Olof Johansson:
"Volume is a little higher than usual due to a set of gpio fixes for
Davinci platforms that's been around a while, still seemed appropriate
to not hold off until next merge window.
Besides that it's the usual mix of minor fixes, mostly corrections of
small stuff in device trees.
Major stability-related one is the removal of a regulator from DT on
Rock960, since DVFS caused undervoltage. I expect it'll be restored
once they figure out the underlying issue"
* tag 'armsoc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (28 commits)
MAINTAINERS: Remove unused Qualcomm SoC mailing list
ARM: davinci: dm644x: set the GPIO base to 0
ARM: davinci: da830: set the GPIO base to 0
ARM: davinci: dm355: set the GPIO base to 0
ARM: davinci: dm646x: set the GPIO base to 0
ARM: davinci: dm365: set the GPIO base to 0
ARM: davinci: da850: set the GPIO base to 0
gpio: davinci: restore a way to manually specify the GPIO base
ARM: davinci: dm644x: define gpio interrupts as separate resources
ARM: davinci: dm355: define gpio interrupts as separate resources
ARM: davinci: dm646x: define gpio interrupts as separate resources
ARM: davinci: dm365: define gpio interrupts as separate resources
ARM: davinci: da8xx: define gpio interrupts as separate resources
ARM: dts: at91: sama5d2: use the divided clock for SMC
ARM: dts: imx51-zii-rdu1: Remove EEPROM node
ARM: dts: rockchip: Remove @0 from the veyron memory node
arm64: dts: rockchip: Fix PCIe reset polarity for rk3399-puma-haikou.
arm64: dts: qcom: msm8998: Reserve gpio ranges on MTP
arm64: dts: sdm845-mtp: Reserve reserved gpios
arm64: dts: ti: k3-am654: Fix wakeup_uart reg address
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip
Pull xen fixes from Juergen Gross:
- A revert of a previous commit as it is no longer necessary and has
shown to cause problems in some memory hotplug cases.
- Some small fixes and a minor cleanup.
- A patch for adding better diagnostic data in a very rare failure
case.
* tag 'for-linus-4.20a-rc5-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip:
pvcalls-front: fixes incorrect error handling
Revert "xen/balloon: Mark unallocated host memory as UNUSABLE"
xen: xlate_mmu: add missing header to fix 'W=1' warning
xen/x86: add diagnostic printout to xen_mc_flush() in case of error
x86/xen: cleanup includes in arch/x86/xen/spinlock.c
git://git.infradead.org/users/vkoul/slave-dma
Pull dmaengine fixes from Vinod Koul:
"This contains two fixes to at_hdmac which fixes long standing bus
reported recently on serial transfers causing memory leak. These fixes
were done by Richard Genoud"
* tag 'dmaengine-fix-4.20-rc5' of git://git.infradead.org/users/vkoul/slave-dma:
dmaengine: at_hdmac: fix module unloading
dmaengine: at_hdmac: fix memory leak in at_dma_xlate()
Pull block layer fixes from Jens Axboe:
- Single range elevator discard merge fix, that caused crashes (Ming)
- Fix for a regression in O_DIRECT, where we could potentially lose the
error value (Maximilian Heyne)
- NVMe pull request from Christoph, with little fixes all over the map
for NVMe.
* tag 'for-linus-20181201' of git://git.kernel.dk/linux-block:
block: fix single range discard merge
nvme-rdma: fix double freeing of async event data
nvme: flush namespace scanning work just before removing namespaces
nvme: warn when finding multi-port subsystems without multipathing enabled
fs: fix lost error code in dio_complete
nvme-pci: fix surprise removal
nvme-fc: initialize nvme_req(rq)->ctrl after calling __nvme_fc_init_request()
nvme: Free ctrl device name on init failure
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI fixes from Bjorn Helgaas:
- Fix a link speed checking interface that broke PCIe gen3 cards in
gen1 slots (Mikulas Patocka)
- Fix an imx6 link training error (Trent Piepho)
- Fix a layerscape outbound window accessor calling error (Hou
Zhiqiang)
- Fix a DesignWare endpoint MSI-X address calculation error (Gustavo
Pimentel)
* tag 'pci-v4.20-fixes-2' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci:
PCI: dwc: Fix MSI-X EP framework address calculation bug
PCI: layerscape: Fix wrong invocation of outbound window disable accessor
PCI: imx6: Fix link training status detection in link up check
- Fix DesignWare endpoint MSI-X address calculation bug (Gustavo
Pimentel)
- Fix Layerscape outbound window disable usage (Hou Zhiqiang)
- Fix imx6 link up detection (Trent Piepho)
* lorenzo/pci/controller-fixes:
The macros PCI_EXP_LNKCAP_SLS_*GB are values, not bit masks. We must mask
the register and compare it against them.
This fixes errors like this:
amdgpu: [powerplay] failed to send message 261 ret is 0
when a PCIe-v3 card is plugged into a PCIe-v1 slot, because the slot is
being incorrectly reported as PCIe-v3 capable.
6cf57be0f78e, which appeared in v4.17, added pcie_get_speed_cap() with the
incorrect test of PCI_EXP_LNKCAP_SLS as a bitmask. 5d9a63304032, which
appeared in v4.19, changed amdgpu to use pcie_get_speed_cap(), so the
amdgpu bug reports below are regressions in v4.19.
Fixes: 6cf57be0f78e ("PCI: Add pcie_get_speed_cap() to find max supported link speed")
Fixes: 5d9a63304032 ("drm/amdgpu: use pcie functions for link width and speed")
Link: https://bugs.freedesktop.org/show_bug.cgi?id=108704
Link: https://bugs.freedesktop.org/show_bug.cgi?id=108778
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
[bhelgaas: update comment, remove use of PCI_EXP_LNKCAP_SLS_8_0GB and
PCI_EXP_LNKCAP_SLS_16_0GB since those should be covered by PCI_EXP_LNKCAP2,
remove test of PCI_EXP_LNKCAP for zero, since that register is required]
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Alex Deucher <alexander.deucher@amd.com>
Cc: stable@vger.kernel.org # v4.17+
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull arm64 fixes from Catalin Marinas:
- Cortex-A76 erratum workaround
- ftrace fix to enable syscall events on arm64
- Fix uninitialised pointer in iort_get_platform_device_domain()
* tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux:
ACPI/IORT: Fix iort_get_platform_device_domain() uninitialized pointer value
arm64: ftrace: Fix to enable syscall events on arm64
arm64: Add workaround for Cortex-A76 erratum 1286807
Even if we have no waiters on any of the sbitmap_queue wait states, we
still have to loop every entry to check. We do this for every IO, so
the cost adds up.
Shift a bit of the cost to the slow path, when we actually have waiters.
Wrap prepare_to_wait_exclusive() and finish_wait(), so we can maintain
an internal count of how many are currently active. Then we can simply
check this count in sbq_wake_ptr() and not have to loop if we don't
have any sleepers.
Convert the two users of sbitmap with waiting, blk-mq-tag and iSCSI.
Reviewed-by: Omar Sandoval <osandov@fb.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc fixes from Greg KH:
"Here are a few small char/misc driver fixes for 4.20-rc5 that resolve
a number of reported issues.
The "largest" here is the thunderbolt patch, which resolves an issue
with NVM upgrade, the smallest being some fsi driver fixes. There's
also a hyperv bugfix, and the usual binder bugfixes.
All of these have been in linux-next with no reported issues"
* tag 'char-misc-4.20-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc:
misc: mic/scif: fix copy-paste error in scif_create_remote_lookup
thunderbolt: Prevent root port runtime suspend during NVM upgrade
Drivers: hv: vmbus: check the creation_status in vmbus_establish_gpadl()
binder: fix race that allows malicious free of live buffer
fsi: fsi-scom.c: Remove duplicate header
fsi: master-ast-cf: select GENERIC_ALLOCATOR
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core fix from Greg KH:
"Here is a single driver core fix for 4.20-rc5
It resolves an issue with the data alignment in 'struct devres' for
the ARC platform. The full details are in the commit changelog, but
the short summary is the change is a single line:
- unsigned long long data[]; /* guarantee ull alignment */
+ u8 __aligned(ARCH_KMALLOC_MINALIGN) data[];
This has been in linux-next for a while with no reported issues"
* tag 'driver-core-4.20-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core:
devres: Align data[] to ARCH_KMALLOC_MINALIGN
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging and IIO driver fixes from Greg KH:
"Here are some small IIO and staging driver fixes for 4.20-rc5.
Nothing major, the IIO fix ended up touching the HID drivers at the
same time, but the HID maintainer acked it. The staging fixes are all
minor patches for reported issues and regressions, full details are in
the shortlog.
All of these have been in linux-next for a while with no reported
issues"
* tag 'staging-4.20-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging:
iio/hid-sensors: Fix IIO_CHAN_INFO_RAW returning wrong values for signed numbers
staging: vchiq_arm: fix compat VCHIQ_IOC_AWAIT_COMPLETION
staging: mt7621-pinctrl: fix uninitialized variable ngroups
staging: rtl8723bs: Add missing return for cfg80211_rtw_get_station
staging: most: use format specifier "%s" in snprintf
staging: rtl8723bs: Fix incorrect sense of ether_addr_equal
staging: mt7621-dma: fix potentially dereferencing uninitialized 'tx_desc'
staging: comedi: clarify/unify macros for NI macro-defined terminals
drivers: staging: cedrus: find ctx before dereferencing it ctx
staging: rtl8723bs: Fix the return value in case of error in 'rtw_wx_read32()'
staging: comedi: ni_mio_common: scale ao INSN_CONFIG_GET_CMD_TIMING_CONSTRAINTS
iio:st_magn: Fix enable device after trigger
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB/PHY driver fixes from Greg KH:
"Here are some small USB and PHY driver fixes for 4.20-rc5
Nothing big at all, just the usual handful of USB fixes for reported
issues, along with some gadget and PHY driver bug fixes.
All of these have been in linux-next with no reported issues. Note,
the USB gadget fixes were in linux-next on its own branch, not in
mine, it just got merged into here yesterday and missed linux-next of
today"
* tag 'usb-4.20-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb:
usb: gadget: u_ether: fix unsafe list iteration
USB: omap_udc: fix rejection of out transfers when DMA is used
USB: omap_udc: fix USB gadget functionality on Palm Tungsten E
USB: omap_udc: fix omap_udc_start() on 15xx machines
USB: omap_udc: fix crashes on probe error and module removal
USB: omap_udc: use devm_request_irq()
usb: core: quirks: add RESET_RESUME quirk for Cherry G230 Stream series
USB: usb-storage: Add new IDs to ums-realtek
Revert "usb: dwc3: gadget: skip Set/Clear Halt when invalid"
phy: qcom-qusb2: Fix HSTX_TRIM tuning with fused value for SDM845
phy: qcom-qusb2: Use HSTX_TRIM fused value as is
dt-bindings: phy-qcom-qmp: Fix several mistakes from prior commits
phy: uniphier-pcie: Depend on HAS_IOMEM
Pull mtd fixes from Boris Brezillon:
"NAND fix:
- Fix BBT cache allocation done in nanddev_bbt_init()
SPI NOR fixes:
- Fix the erase type selection logic"
* tag 'mtd/fixes-for-4.20-rc5' of git://git.infradead.org/linux-mtd:
mtd: nand: Fix memory allocation in nanddev_bbt_init()
mtd: spi-nor: fix erase_type array to indicate current map conf
Pull EFI fix from Ingo Molnar:
"An arm64 warning fix"
* 'efi-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
efi: Prevent GICv3 WARN() by mapping the memreserve table before first use
Running the Clang static analyzer on IORT code detected the following
error:
Logic error: Branch condition evaluates to a garbage value
in
If the named component associated with a given device has no IORT
mappings, iort_get_platform_device_domain() exits its MSI mapping loop
with msi_parent pointer containing garbage, which can lead to erroneous
code path execution.
Initialize the msi_parent pointer, fixing the bug.
Fixes: d4f54a186667 ("ACPI: platform: setup MSI domain for ACPI based
platform device")
Reported-by: Patrick Bellasi <patrick.bellasi@arm.com>
Reviewed-by: Hanjun Guo <hanjun.guo@linaro.org>
Acked-by: Will Deacon <will.deacon@arm.com>
Cc: Sudeep Holla <sudeep.holla@arm.com>
Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net>
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Pull drm fixes from Dave Airlie:
"This weeks instalment of fixes. Looks fairly like business as usual
and everything seems to rolling along. There was one MST fix applied
and reverted in the misc tree, but otherwise nothing too strange in
here.
core:
- incorrect master setting on error fix
i915:
- only GVT fixes this week:
* one MOCS register load
* rpm lock fix
* use after free
rcar-du:
- regression fix for group start
amdgpu:
- DP MST fix
- GPUVM fix for huge pages
- RLC fix for vega20
ast:
- fix EDID reading stability
- ioreg free fix
meson:
- sleep in irq fix
- vblank fixes
- array boundary fix"
* tag 'drm-fixes-2018-11-30' of git://anongit.freedesktop.org/drm/drm:
drm/ast: fixed reading monitor EDID not stable issue
drm/ast: Fix incorrect free on ioregs
Revert "drm/dp_mst: Skip validating ports during destruction, just ref"
drm/amdgpu: Add delay after enable RLC ucode
drm/amdgpu: Avoid endless loop in GPUVM fragment processing
drm/amdgpu: Cast to uint64_t before left shift
drm/meson: add support for 1080p25 mode
drm/meson: Fix OOB memory accesses in meson_viu_set_osd_lut()
drm/meson: Enable fast_io in meson_dw_hdmi_regmap_config
drm/meson: Fixes for drm_crtc_vblank_on/off support
drm: set is_master to 0 upon drm_new_set_master() failure
drm: rcar-du: Fix DU3 start/stop on M3-N
drm/amd/dm: Understand why attaching path/tile properties are needed
drm/amd/dm: Don't forget to attach MST encoders
drm/i915/gvt: Avoid use-after-free iterating the gtt list
drm/i915/gvt: ensure gpu is powered before do i915_gem_gtt_insert
drm/i915/gvt: not to touch undefined MOCS registers
Pull rdma fixes from Jason Gunthorpe:
"This is a bit later than usual for our first -rc but I'm not seeing
anything worry-some in the RDMA tree right now. Quiet so far this -rc
cycle, only a few internal driver related bugs and a small series
fixing ODP bugs found by more advanced testing.
A set of small driver and core code fixes:
- Small series fixing longtime user triggerable bugs in the ODP
processing inside mlx5 and core code
- Various small driver malfunctions and crashes (use after, free,
error unwind, implementation bugs)
- A misfunction of the RDMA GID cache that can be triggered by the
administrator"
* tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rdma/rdma:
RDMA/mlx5: Initialize return variable in case pagefault was skipped
IB/mlx5: Fix page fault handling for MW
IB/umem: Set correct address to the invalidation function
IB/mlx5: Skip non-ODP MR when handling a page fault
RDMA/hns: Bugfix pbl configuration for rereg mr
iser: set sector for ambiguous mr status errors
RDMA/rdmavt: Fix rvt_create_ah function signature
IB/mlx5: Avoid load failure due to unknown link width
IB/mlx5: Fix XRC QP support after introducing extended atomic
RDMA/bnxt_re: Avoid accessing the device structure after it is freed
RDMA/bnxt_re: Fix system hang when registration with L2 driver fails
RDMA/core: Add GIDs while changing MAC addr only for registered ndev
RDMA/mlx5: Fix fence type for IB_WR_LOCAL_INV WR
net/mlx5: Fix XRC SRQ umem valid bits
Some error paths in configuration of admin queue free data buffer
associated with async request SQE without resetting the data buffer
pointer to NULL, This buffer is also freed up again if the controller
is shutdown or reset.
Signed-off-by: Prabhath Sajeepa <psajeepa@purestorage.com>
Reviewed-by: Roland Dreier <roland@purestorage.com>
nvme_stop_ctrl can be called also for reset flow and there is no need to
flush the scan_work as namespaces are not being removed. This can cause
deadlock in rdma, fc and loop drivers since nvme_stop_ctrl barriers
before controller teardown (and specifically I/O cancellation of the
scan_work itself) takes place, but the scan_work will be blocked anyways
so there is no need to flush it.
Instead, move scan_work flush to nvme_remove_namespaces() where it really
needs to flush.
Reported-by: Ming Lei <ming.lei@redhat.com>
Signed-off-by: Sagi Grimberg <sagi@grimberg.me>
Reviewed by: James Smart <jsmart2021@gmail.com>
Tested-by: Ewan D. Milne <emilne@redhat.com>
Without CONFIG_NVME_MULTIPATH enabled a multi-port subsystem might
show up as invididual devices and cause problems, warn about it.
Pull ACPI fix from Rafael Wysocki:
"Fix a recent regression in ACPICA releted to the Generic Serial Bus
protocol handling and causing it to read or write too little or too
much data in some cases, so incorrect data may be written to hardware
as a result (Hans de Goede)"
* tag 'acpi-4.20-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
ACPICA: Fix handling of buffer-size in acpi_ex_write_data_to_field()
Pull power management fixes from Rafael Wysocki:
"These fix two issues in the operating performance points (OPP)
framework.
Specifics:
- Fix the handling of the "operating-points-v2" property to avoid
failures if multiple phandles are present in it which is legitimate
(Viresh Kumar).
- Drop the unnecessary static initialization of the .owner field in
the ti_opp_supply_driver structure (YueHaibing)"
* tag 'pm-4.20-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
OPP: Fix parsing of multiple phandles in "operating-points-v2" property
opp: ti-opp-supply: Fix platform_no_drv_owner.cocci warnings
Pagefaults occurred in non-ODP MR are completely valid events, so
initialize return variable to 0.
Fixes: 4d5422a309de ("IB/mlx5: Skip non-ODP MR when handling a page fault")
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Leon Romanovsky <leonro@mellanox.com>
Signed-off-by: Jason Gunthorpe <jgg@mellanox.com>
* acpica-fixes:
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux
Pull s390 updates from Martin Schwidefsky:
- Add two missing kfree calls on error paths in the vfio-ccw code
- Make sure that all data structures of a mediated vfio-ccw device are
initialized before registering it
- Fix a sparse warning in vfio-ccw
- A followup patch for the pgtable_bytes accounting, the page table
downgrade for compat processes missed a mm_dec_nr_pmds()
- Reject sampling requests in the PMU init function of the CPU
measurement counter facility
- With the vfio AP driver an AP queue needs to be reset on every device
probe as the alternative driver could have modified the device state
* tag 's390-4.20-3' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux:
s390/mm: correct pgtable_bytes on page table downgrade
s390/zcrypt: reinit ap queue state machine during device probe
s390/cpum_cf: Reject request for sampling in event initialization
s390/cio: Fix cleanup when unsupported IDA format is used
s390/cio: Fix cleanup of pfn_array alloc failure
vfio: ccw: Register mediated device once all structures are initialized
s390/cio: make vfio_ccw_io_region static
We need this for blk-mq to kick things into gear, if we told it that
we had more IO coming, but then failed to deliver on that promise.
Reviewed-by: Ming Lei <ming.lei@redhat.com>
Acked-by: Michael S. Tsirkin <mst@redhat.com>
Split the command submission and the SQ doorbell ring, and add the
doorbell ring as our ->commit_rqs() hook. This allows a list of
requests to be issued, with nvme only writing the SQ update when
it's necessary. This is more efficient if we have lists of requests
to issue, particularly on virtualized hardware, where writing the
SQ doorbell is more expensive than on real hardware. For those cases,
performance increases of 2-3x have been observed.
The use case for this is plugged IO, where blk-mq flushes a batch of
requests at the time.
kfree() is incorrectly used to release the pages allocated by
__get_free_page() and __get_free_pages(). Use the matching deallocators
i.e., free_page() and free_pages(), respectively.
Signed-off-by: Pan Bian <bianpan2016@163.com>
Reviewed-by: Stefano Stabellini <sstabellini@kernel.org>
Signed-off-by: Juergen Gross <jgross@suse.com>
This reverts commit b3cf8528bb21febb650a7ecbf080d0647be40b9f.
That commit unintentionally broke Xen balloon memory hotplug with
"hotplug_unpopulated" set to 1. As long as "System RAM" resource
got assigned under a new "Unusable memory" resource in IO/Mem tree
any attempt to online this memory would fail due to general kernel
restrictions on having "System RAM" resources as 1st level only.
The original issue that commit has tried to workaround fa564ad96366
("x86/PCI: Enable a 64bit BAR on AMD Family 15h (Models 00-1f, 30-3f,
60-7f)") also got amended by the following 03a551734 ("x86/PCI: Move
and shrink AMD 64-bit window to avoid conflict") which made the
original fix to Xen ballooning unnecessary.
Signed-off-by: Igor Druzhinin <igor.druzhinin@citrix.com>
Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Add a missing header otherwise compiler warns about missed prototype:
drivers/xen/xlate_mmu.c:183:5: warning: no previous prototype for 'xen_xlate_unmap_gfn_range?' [-Wmissing-prototypes]
int xen_xlate_unmap_gfn_range(struct vm_area_struct *vma,
Signed-off-by: Srikanth Boddepalli <boddepalli.srikanth@gmail.com>
Reviewed-by: Joey Pabalinas <joeypabalinas@gmail.com>
Smatch complains that there is an off by one if the allocation fails in:
DMABuffer = atari_stram_alloc(BUFFER_SIZE+512, "ataflop");
In that situation, "i" would be point to one element beyond the end of
the unit[] array.
There is a second bug because the error handling calls
blk_mq_free_tag_set(&unit[i].tag_set); regardless of whether
"disk->queue" is NULL or non-NULL. So if blk_mq_init_sq_queue() fails,
then that means unit[i].tag_set->tags is NULL and it leads to an Oops.
It's easiest to call put_disk() before the goto to clean up the partial
iteration. Then the earlier unit[] elements are fully allocated so we
can remove the checks whether "disk->queue" is NULL and the code is
simpler.
of_dma_controller_free() was not called on module onloading.
This lead to a soft lockup:
watchdog: BUG: soft lockup - CPU#0 stuck for 23s!
Modules linked in: at_hdmac [last unloaded: at_hdmac]
when of_dma_request_slave_channel() tried to call ofdma->of_dma_xlate().
Fixes: bbe89c8e3d59 ("at_hdmac: move to generic DMA binding")
Acked-by: Ludovic Desroches <ludovic.desroches@microchip.com>
Signed-off-by: Richard Genoud <richard.genoud@gmail.com>
Signed-off-by: Vinod Koul <vkoul@kernel.org>
The leak was found when opening/closing a serial port a great number of
time, increasing kmalloc-32 in slabinfo.
Each time the port was opened, dma_request_slave_channel() was called.
Then, in at_dma_xlate(), atslave was allocated with devm_kzalloc() and
never freed. (Well, it was free at module unload, but that's not what we
want).
So, here, kzalloc is more suited for the job since it has to be freed in
atc_free_chan_resources().
Reported-by: Mario Forner <m.forner@be4energy.com>
Suggested-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
Acked-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
git://git.kernel.org/pub/scm/linux/kernel/git/balbi/usb into usb-linus
Felipe writes:
USB: fixes for v4.20-rc4
In this second set of fixes for the current -rc cycle, we have some
regressions fixes for the old omap_udc driver done by Aaro Koskinen.
We're also reverting an old patch on dwc3 which is, now, known to
break USB certification in some cases.
We have a fix on u_ether for an unsafe list iteration.
* tag 'fixes-for-v4.20-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/balbi/usb:
git://anongit.freedesktop.org/drm/drm-misc into drm-fixes
- mst: Don't try to validate ports while destroying them (Lyude)
- Revert: Don't try to validate ports while destroying them (Lyude)
- core: Don't set device to master unless set_master succeeds (Sergio)
- meson: Do vblank_on/off on enable/disable (Neil)
- meson: Use fast_io regmap option to avoid sleeping in irq ctx (Lyude)
- meson: Don't walk off the end of the OSD EOTF LUTs (Lyude)
Cc: Lyude Paul <lyude@redhat.com>
Cc: Sergio Correia <sergio@correia.cc>
Cc: Neil Armstrong <narmstrong@baylibre.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20181128212936.GA21379@art_vandelay
into drm-fixes
Fixes for 4.20. Nothing major.
- DC DP MST fix
- GPUVM fix for huge page mapping
Link: https://patchwork.freedesktop.org/patch/msgid/20181128195905.2897-1-alexander.deucher@amd.com
