Part of reorganising wireless drivers directory and Kconfig.
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
Add new a Kconfig file and a vendor config for realtek. Also update MAINTAINERS
which we missed to do when earlier moving rtlwifi.
Part of reorganising wireless drivers directory and Kconfig. Note that I had to
edit Makefiles from subdirectories to use the new location.
Merge final patch-bomb from Andrew Morton:
"Various leftovers, mainly Christoph's pci_dma_supported() removals"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>:
pci: remove pci_dma_supported
usbnet: remove ifdefed out call to dma_supported
kaweth: remove ifdefed out call to dma_supported
sfc: don't call dma_supported
nouveau: don't call pci_dma_supported
netup_unidvb: use pci_set_dma_mask insted of pci_dma_supported
cx23885: use pci_set_dma_mask insted of pci_dma_supported
cx25821: use pci_set_dma_mask insted of pci_dma_supported
cx88: use pci_set_dma_mask insted of pci_dma_supported
saa7134: use pci_set_dma_mask insted of pci_dma_supported
saa7164: use pci_set_dma_mask insted of pci_dma_supported
tw68-core: use pci_set_dma_mask insted of pci_dma_supported
pcnet32: use pci_set_dma_mask insted of pci_dma_supported
lib/string.c: add ULL suffix to the constant definition
hugetlb: trivial comment fix
selftests/mlock2: add ULL suffix to 64-bit constants
selftests/mlock2: add missing #define _GNU_SOURCE
Pull drm fixes from Dave Airlie:
"Two build fixes, one for VC4, one for nouveau where the ARM only code
is doing something a bit strange. While people are discussing that,
just workaround it and fix the build for now. The code in question
will never get used on anything non-ARM anyways.
Also one fix for AST that SuSE had been hiding in their kernel, that
allows all fbdev apps to work on that driver"
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux:
drm/nouveau: fix build failures on all non ARM.
drm/ast: Initialized data needed to map fbdev memory
drm/vc4: Add dependency on HAVE_DMA_ATTRS, and select DRM_GEM_CMA_HELPER
gk20a is an ARM only GPU, so we can just do the correct thing on
ARM but fail on other architectures. The other option was to use
SWIOTLB as the define, which means phys_to_page exists, but
this seems clearer.
Due to a missing initialization there was no way to map fbdev memory.
Thus for example using the Xserver with the fbdev driver failed.
This fix adds initialization for fix.smem_start and fix.smem_len
in the fb_info structure, which fixes this problem.
Requested-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Cc: stable@vger.kernel.org
Signed-off-by: Egbert Eich <eich@suse.de>
[pulled from SuSE tree by me - airlied]
Pull networking fixes from David Miller:
1) Fix null deref in xt_TEE netfilter module, from Eric Dumazet.
2) Several spots need to get to the original listner for SYN-ACK
packets, most spots got this ok but some were not. Whilst covering
the remaining cases, create a helper to do this. From Eric Dumazet.
3) Missiing check of return value from alloc_netdev() in CAIF SPI code,
from Rasmus Villemoes.
4) Don't sleep while != TASK_RUNNING in macvtap, from Vlad Yasevich.
5) Use after free in mvneta driver, from Justin Maggard.
6) Fix race on dst->flags access in dst_release(), from Eric Dumazet.
7) Add missing ZLIB_INFLATE dependency for new qed driver. From Arnd
Bergmann.
8) Fix multicast getsockopt deadlock, from WANG Cong.
9) Fix deadlock in btusb, from Kuba Pawlak.
10) Some ipv6_add_dev() failure paths were not cleaning up the SNMP6
counter state. From Sabrina Dubroca.
11) Fix packet_bind() race, which can cause lost notifications, from
Francesco Ruggeri.
12) Fix MAC restoration in qlcnic driver during bonding mode changes,
from Jarod Wilson.
13) Revert bridging forward delay change which broke libvirt and other
userspace things, from Vlad Yasevich.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (65 commits)
Revert "bridge: Allow forward delay to be cfgd when STP enabled"
bpf_trace: Make dependent on PERF_EVENTS
qed: select ZLIB_INFLATE
net: fix a race in dst_release()
net: mvneta: Fix memory use after free.
net: Documentation: Fix default value tcp_limit_output_bytes
macvtap: Resolve possible __might_sleep warning in macvtap_do_read()
mvneta: add FIXED_PHY dependency
net: caif: check return value of alloc_netdev
net: hisilicon: NET_VENDOR_HISILICON should depend on HAS_DMA
drivers: net: xgene: fix RGMII 10/100Mb mode
netfilter: nft_meta: use skb_to_full_sk() helper
net_sched: em_meta: use skb_to_full_sk() helper
sched: cls_flow: use skb_to_full_sk() helper
netfilter: xt_owner: use skb_to_full_sk() helper
smack: use skb_to_full_sk() helper
net: add skb_to_full_sk() helper and use it in selinux_netlbl_skbuff_setsid()
bpf: doc: correct arch list for supported eBPF JIT
dwc_eth_qos: Delete an unnecessary check before the function call "of_node_put"
bonding: fix panic on non-ARPHRD_ETHER enslave failure
Pull block IO poll support from Jens Axboe:
"Various groups have been doing experimentation around IO polling for
(really) fast devices. The code has been reviewed and has been
sitting on the side for a few releases, but this is now good enough
for coordinated benchmarking and further experimentation.
Currently O_DIRECT sync read/write are supported. A framework is in
the works that allows scalable stats tracking so we can auto-tune
this. And we'll add libaio support as well soon. Fow now, it's an
opt-in feature for test purposes"
* 'for-4.4/io-poll' of git://git.kernel.dk/linux-block:
direct-io: be sure to assign dio->bio_bdev for both paths
directio: add block polling support
NVMe: add blk polling support
block: add block polling support
blk-mq: return tag/queue combo in the make_request_fn handlers
block: change ->make_request_fn() and users to return a queue cookie
Pull UBI/UBIFS updates from Richard Weinberger:
- access time support for UBIFS by Dongsheng Yang
- random cleanups and bug fixes all over the place
* tag 'upstream-4.4-rc1' of git://git.infradead.org/linux-ubifs:
ubifs: introduce UBIFS_ATIME_SUPPORT to ubifs
ubifs: make ubifs_[get|set]xattr atomic
UBIFS: Delete unnecessary checks before the function call "iput"
UBI: Remove in vain semicolon
UBI: Fastmap: Fix PEB array type
UBIFS: Fix possible memory leak in ubifs_readdir()
fs/ubifs: remove unnecessary new_valid_dev check
ubi: fastmap: Implement produce_free_peb()
UBIFS: print verbose message when rescanning a corrupted node
UBIFS: call dbg_is_power_cut() instead of reading c->dbg->pc_happened
UBI: drop null test before destroy functions
UBI: Update comments to reflect UBI_METAONLY flag
UBI: Fix debug message
UBI: Fix typo in comment
UBI: Fastmap: Simplify expression
UBIFS: fix a typo in comment of ubifs_budget_req
UBIFS: use kmemdup rather than duplicating its implementation
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Helge Deller <deller@gmx.de>
Cc: Oliver Neukum <oneukum@suse.com>
Cc: Oliver Neukum <oliver@neukum.org>
Cc: Alexey Khoroshilov <khoroshilov@ispras.ru>
dma_set_mask already checks for a supported DMA mask before updating it,
the call to dma_supported is redundant.
Cc: Solarflare linux maintainers <linux-net-drivers@solarflare.com>
Cc: Shradha Shah <sshah@solarflare.com>
Just try to set a 64-bit DMA mask first and retry with the smaller dma_mask
if dma_set_mask failed.
Cc: David Airlie <airlied@linux.ie>
Cc: Ben Skeggs <bskeggs@redhat.com>
Cc: Alexandre Courbot <acourbot@nvidia.com>
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: Thierry Reding <treding@nvidia.com>
Cc: Dave Airlie <airlied@redhat.com>
This ensures the dma mask that is supported by the driver is recorded
in the device structure.
Cc: Sergey Kozlov <serjk@netup.ru>
Cc: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
Cc: Hans Verkuil <hans.verkuil@cisco.com>
Cc: Pawel Osciak <pawel@osciak.com>
Cc: Hans Verkuil <hverkuil@xs4all.nl>
Cc: Sakari Ailus <sakari.ailus@linux.intel.com>
Cc: Steven Toth <stoth@kernellabs.com>
All drivers should be using dma_set_mask / pci_set_dma_mask to try to
set the dma mask instead of just querying it. Without that some iommu
implementations may not work.
pci_dma_supported is removed entirely, but dma_supported stays for
dma_ops implementations for now.
This patch (of 15):
Acked-by: Don Fry <pcnet32@frontier.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Jiri Slaby <jslaby@suse.com>
Pull ARM DT updates from Olof Johansson:
"As usual, this is the massive branch we have for each release. Lots
of various updates and additions of hardware descriptions on existing
hardware, as well as the usual additions of new boards and SoCs.
This is also the first release where we've started mixing 64- and
32-bit DT updates in one branch.
(Specific details on what's actually here and new is pretty easy to
tell from the diffstat, so there's little point in duplicating listing
it here)"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (499 commits)
ARM: dts: uniphier: add system-bus-controller nodes
ARM64: juno: disable NOR flash node by default
ARM: dts: uniphier: add outer cache controller nodes
arm64: defconfig: Enable PCI generic host bridge by default
arm64: Juno: Add support for the PCIe host bridge on Juno R1
Documentation: of: Document the bindings used by Juno R1 PCIe host bridge
ARM: dts: uniphier: add I2C aliases for ProXstream2 boards
dts/Makefile: Add build support for LS2080a QDS & RDB board DTS
dts/ls2080a: Add DTS support for LS2080a QDS & RDB boards
dts/ls2080a: Update Simulator DTS to add support of various peripherals
dts/ls2080a: Remove text about writing to Free Software Foundation
dts/ls2080a: Update DTSI to add support of various peripherals
doc: DTS: Update DWC3 binding to provide reference to generic bindings
doc/bindings: Update GPIO devicetree binding documentation for LS2080A
Documentation/dts: Move FSL board-specific bindings out of /powerpc
Documentation: DT: Add entry for FSL LS2080A QDS and RDB boards
arm64: Rename FSL LS2085A SoC support code to LS2080A
arm64: Use generic Layerscape SoC family naming
ARM: dts: uniphier: add ProXstream2 Vodka board support
ARM: dts: uniphier: add ProXstream2 Gentil board support
Pull ARM SoC driver updates from Olof Johansson:
"As we've enabled multiplatform kernels on ARM, and greatly done away
with the contents under arch/arm/mach-*, there's still need for
SoC-related drivers to go somewhere.
Many of them go in through other driver trees, but we still have
drivers/soc to hold some of the "doesn't fit anywhere" lowlevel code
that might be shared between ARM and ARM64 (or just in general makes
sense to not have under the architecture directory).
This branch contains mostly such code:
- Drivers for qualcomm SoCs for SMEM, SMD and SMD-RPM, used to
communicate with power management blocks on these SoCs for use by
clock, regulator and bus frequency drivers.
- Allwinner Reduced Serial Bus driver, again used to communicate with
PMICs.
- Drivers for ARM's SCPI (System Control Processor). Not to be
confused with PSCI (Power State Coordination Interface). SCPI is
used to communicate with the assistant embedded cores doing power
management, and we have yet to see how many of them will implement
this for their hardware vs abstracting in other ways (or not at all
like in the past).
- To make confusion between SCPI and PSCI more likely, this release
also includes an update of PSCI to interface version 1.0.
- Rockchip support for power domains.
- A driver to talk to the firmware on Raspberry Pi"
* tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (57 commits)
soc: qcom: smd-rpm: Correct size of outgoing message
bus: sunxi-rsb: Add driver for Allwinner Reduced Serial Bus
bus: sunxi-rsb: Add Allwinner Reduced Serial Bus (RSB) controller bindings
ARM: bcm2835: add mutual inclusion protection
drivers: psci: make PSCI 1.0 functions initialization version dependent
dt-bindings: Correct paths in Rockchip power domains binding document
soc: rockchip: power-domain: don't try to print the clock name in error case
soc: qcom/smem: add HWSPINLOCK dependency
clk: berlin: add cpuclk
ARM: berlin: dts: add CLKID_CPU for BG2Q
ARM: bcm2835: Add the Raspberry Pi firmware driver
soc: qcom: smem: Move RPM message ram out of smem DT node
soc: qcom: smd-rpm: Correct the active vs sleep state flagging
soc: qcom: smd: delete unneeded of_node_put
firmware: qcom-scm: build for correct architecture level
soc: qcom: smd: Correct SMEM items for upper channels
qcom-scm: add missing prototype for qcom_scm_is_available()
qcom-scm: fix endianess issue in __qcom_scm_is_call_available
soc: qcom: smd: Reject send of too big packets
soc: qcom: smd: Handle big endian CPUs
Pull ARM SoC platform updates from Olof Johansson:
"New and/or improved SoC support for this release:
Marvell Berlin:
- Enable standard DT-based cpufreq
- Add CPU hotplug support
Freescale:
- Ethernet init for i.MX7D
- Suspend/resume support for i.MX6UL
Allwinner:
- Support for R8 chipset (used on NTC's $9 C.H.I.P board)
Mediatek:
- SMP support for some platforms
Uniphier:
- L2 support
- Cleaned up SMP support, etc.
plus a handful of other patches around above functionality, and a few
other smaller changes"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (42 commits)
ARM: uniphier: rework SMP operations to use trampoline code
ARM: uniphier: add outer cache support
Documentation: EXYNOS: Update bootloader interface on exynos542x
ARM: mvebu: add broken-idle option
ARM: orion5x: use mac_pton() helper
ARM: at91: pm: at91_pm_suspend_in_sram() must be 8-byte aligned
ARM: sunxi: Add R8 support
ARM: digicolor: select pinctrl/gpio driver
arm: berlin: add CPU hotplug support
arm: berlin: use non-self-cleared reset register to reset cpu
ARM: mediatek: add smp bringup code
ARM: mediatek: enable gpt6 on boot up to make arch timer working
soc: mediatek: Fix random hang up issue while kernel init
soc: ti: qmss: make acc queue support optional in the driver
soc: ti: add firmware file name as part of the driver
Documentation: dt: soc: Add description for knav qmss driver
ARM: S3C64XX: Use PWM lookup table for mach-smartq
ARM: S3C64XX: Use PWM lookup table for mach-hmt
ARM: S3C64XX: Use PWM lookup table for mach-crag6410
ARM: S3C64XX: Use PWM lookup table for smdk6410
Pull ARM SoC cleanups from Olof Johansson:
"Again we have a sizable (but not huge) cleanup branch with a net delta
of about -3k lines.
Main contents here is:
- A bunch of development/cleanup of a few PXA boards
- Removal of bockw platforms on shmobile, since the platform has now
gone completely multiplatform. Whee!
- move of the 32kHz timer on OMAP to a proper timesource
- Misc cleanup of older OMAP material (incl removal of one board
file)
- Switch over to new common PWM lookup support for several platforms
There's also a handful of other cleanups across the tree, but the
above are the major pieces"
* tag 'armsoc-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (103 commits)
ARM: OMAP3: hwmod data: Remove legacy mailbox data and addrs
ARM: DRA7: hwmod data: Remove spinlock hwmod addrs
ARM: OMAP4: hwmod data: Remove spinlock hwmod addrs
ARM: DRA7/AM335x/AM437x: hwmod: Remove gpmc address space from hwmod data
ARM: Remove __ref on hotplug cpu die path
ARM: Remove open-coded version of IRQCHIP_DECLARE
arm: omap2: board-generic: use omap4_local_timer_init for AM437x
ARM: DRA7/AM335x/AM437x: hwmod: Remove elm address space from hwmod data
ARM: OMAP: Remove duplicated operand in OR operation
clocksource: ti-32k: make it depend on GENERIC_CLOCKSOURCE
ARM: pxa: remove incorrect __init annotation on pxa27x_set_pwrmode
ARM: pxa: raumfeld: make some variables static
ARM: OMAP: Change all cpu_is_* occurences to soc_is_* for id.c
ARM: OMAP2+: Rename cpu_is macros to soc_is
arm: omap2: timer: limit hwmod usage to non-DT boots
arm: omap2+: select 32k clocksource driver
clocksource: add TI 32.768 Hz counter driver
arm: omap2: timer: rename omap_sync32k_timer_init()
arm: omap2: timer: always call clocksource_of_init() when DT
arm: omap2: timer: move realtime_counter_init() around
Pull ARM SoC non-urgent fixes from Olof Johansson:
"A handful of fixes that came in and didn't seem warranted to go in
through the 4.3-rc cycle.
- MAINTAINERS updates for one of the Broadcom platforms and lpc18xx
- A couple of non-critical Davinci bugfixes
- A fix to reset irq affinity for TI platforms (silences a warning at
reboot)"
* tag 'armsoc-fixes-nc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
MAINTAINERS: update lpc18xx entry with more drivers
soc: ti: reset irq affinity before freeing irq
ARM: cns3xxx: pci: avoid potential stack overflow
ARM: davinci: clock: Correct return values for API functions
ARM: davinci: re-use %*ph specifier
MAINTAINERS: add entry for the Broadcom Northstar Plus SoCs
The newly added qlogic qed driver uses the zlib library, but
misses the dependency:
drivers/built-in.o: In function `qed_alloc_stream_mem':
drivers/net/ethernet/qlogic/qed/qed_main.c:707: undefined reference to `zlib_inflate_workspacesize'
drivers/built-in.o: In function `qed_unzip_data':
drivers/net/ethernet/qlogic/qed/qed_main.c:675: undefined reference to `zlib_inflateInit2'
This changes Kconfig to always select zlib when needed.
Fixes: fe56b9e6a8d9 ("qed: Add module with basic common support")
Pull config fix for md from Neil Brown:
"New config dependency needed as md/raid5 now uses crc32c"
* tag 'md/4.4-rc0-fix' of git://neil.brown.name/md:
raid5-cache: add crc32c Kconfig dependency
