Trivial fix to spelling mistake in message text
Use the common code ARRAY_SIZE macro instead of a private implementation.
Reviewed-by: Jean Delvare <jdelvare@suse.de>
Signed-off-by: zhong jiang <zhongjiang@huawei.com>
kmemdup has implemented the function that kmalloc() + memcpy() will
do. We prefer to use the kmemdup function rather than an open coded
implementation.
The SCLP event 24 "Adapter Error Notification" supports three different
action qualifier of which 'adapter reset' is currently not enabled in
the sysfs interface. However, userspace tools might want to be able
to use the reset functionality as well. Enable the 'adapter reset'
qualifier.
Signed-off-by: Jan Höppner <hoeppner@linux.ibm.com>
Reviewed-by: Sebastian Ott <sebott@linux.ibm.com>
kmem_cache_destroy() can handle NULL pointer correctly, so there is
no need to check NULL pointer before calling kmem_cache_destroy().
Signed-off-by: Chengguang Xu <cgxu519@gmx.com>
The resume code checks if the resume cpu is the same as the suspend cpu.
If not, and if it is also not possible to switch to the suspend cpu, an
error message should be printed and the resume process should be stopped
by loading a disabled wait psw.
The current logic is broken in multiple ways, the message is never printed,
and the disabled wait psw never loaded because the kernel panics before that:
- sam31 and SIGP_SET_ARCHITECTURE to ESA mode is wrong, this will break
on the first 64bit instruction in sclp_early_printk().
- The init stack should be used, but the stack pointer is not set up correctly
(missing aghi %r15,-STACK_FRAME_OVERHEAD).
- __sclp_early_printk() checks the sclp_init_state. If it is not
sclp_init_state_uninitialized, it simply returns w/o printing anything.
In the resumed kernel however, sclp_init_state will never be uninitialized.
This patch fixes those issues by removing the sam31/ESA logic, adding a
correct init stack pointer, and also introducing sclp_early_printk_force()
to allow using sclp_early_printk() even when sclp_init_state is not
uninitialized.
Reviewed-by: Heiko Carstens <heiko.carstens@de.ibm.com>
Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Boris writes:
"- Fixes a bug in the ->read/write_reg() implementation of the m25p80
driver
- Make sure of_node_get/put() calls are balanced in the partition
parsing code
- Fix a race in the denali NAND controller driver
- Fix false positive WARN_ON() in the marvell NAND controller driver"
* tag 'mtd/fixes-for-4.19-rc5' of git://git.infradead.org/linux-mtd:
mtd: devices: m25p80: Make sure the buffer passed in op is DMA-able
mtd: partitions: fix unbalanced of_node_get/put()
mtd: rawnand: denali: fix a race condition when DMA is kicked
mtd: rawnand: marvell: prevent harmless warnings
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Takashi writes:
"sound fixes for 4.19-rc5
here comes a collection of various fixes, mostly for stable-tree
or regression fixes.
Two relatively high LOCs are about the (rather simple) conversion of
uapi integer types in topology API, and a regression fix about HDMI
hotplug notification on AMD HD-audio. The rest are all small
individual fixes like ASoC Intel Skylake race condition, minor
uninitialized page leak in emu10k1 ioctl, Firewire audio error paths,
and so on."
* tag 'sound-4.19-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (33 commits)
ALSA: fireworks: fix memory leak of response buffer at error path
ALSA: oxfw: fix memory leak of discovered stream formats at error path
ALSA: oxfw: fix memory leak for model-dependent data at error path
ALSA: bebob: fix memory leak for M-Audio FW1814 and ProjectMix I/O at error path
ALSA: hda - Enable runtime PM only for discrete GPU
ALSA: oxfw: fix memory leak of private data
ALSA: firewire-tascam: fix memory leak of private data
ALSA: firewire-digi00x: fix memory leak of private data
sound: don't call skl_init_chip() to reset intel skl soc
sound: enable interrupt after dma buffer initialization
Revert "ASoC: Intel: Skylake: Acquire irq after RIRB allocation"
ALSA: emu10k1: fix possible info leak to userspace on SNDRV_EMU10K1_IOCTL_INFO
ASoC: cs4265: fix MMTLR Data switch control
ASoC: AMD: Ensure reset bit is cleared before configuring
ALSA: fireface: fix memory leak in ff400_switch_fetching_mode()
ALSA: bebob: use address returned by kmalloc() instead of kernel stack for streaming DMA mapping
ASoC: rsnd: don't fallback to PIO mode when -EPROBE_DEFER
ASoC: rsnd: adg: care clock-frequency size
ASoC: uniphier: change status to orphan
ASoC: rsnd: fixup not to call clk_get/set under non-atomic
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging
Guenter writes:
"Various bug fixes for nct6775 driver"
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi
James writes:
"SCSI fixes on 20180919
A couple of small but important fixes, one affecting big endian and
the other fixing a BUG_ON in scatterlist processing.
Signed-off-by: James E.J. Bottomley <jejb@linux.ibm.com>"
git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6
Crypto stuff from Herbert:
"This push fixes a potential boot hang in ccp and an incorrect
CPU capability check in aegis/morus on x86."
* 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6:
crypto: x86/aegis,morus - Do not require OSXSAVE for SSE2
crypto: ccp - add timeout support in the SEV command
git://git.infradead.org/linux-platform-drivers-x86
Darren writes:
"platform-drivers-x86 for v4.19-2
Free allocated ACPI buffers in two drivers.
The following is an automated git shortlog grouped by driver:
alienware-wmi:
- Correct a memory leak
dell-smbios-wmi:
- Correct a memory leak"
* tag 'platform-drivers-x86-v4.19-2' of git://git.infradead.org/linux-platform-drivers-x86:
platform/x86: alienware-wmi: Correct a memory leak
platform/x86: dell-smbios-wmi: Correct a memory leak
As documented in spi-mem.h, spi_mem_op->data.buf.{in,out} must be
DMA-able, and commit 4120f8d158ef ("mtd: spi-nor: Use the spi_mem_xx()
API") failed to follow this rule as buffers passed to
->{read,write}_reg() are usually placed on the stack.
Fix that by allocating a scratch buffer and copying the data around.
Fixes: 4120f8d158ef ("mtd: spi-nor: Use the spi_mem_xx() API")
Reported-by: Jarkko Nikula <jarkko.nikula@linux.intel.com>
Cc: <stable@vger.kernel.org>
Signed-off-by: Boris Brezillon <boris.brezillon@bootlin.com>
Tested-by: Jarkko Nikula <jarkko.nikula@linux.intel.com>
Reviewed-by: Jarkko Nikula <jarkko.nikula@linux.intel.com>
Dave writes:
"Various fixes, all over the place:
1) OOB data generation fix in bluetooth, from Matias Karhumaa.
2) BPF BTF boundary calculation fix, from Martin KaFai Lau.
3) Don't bug on excessive frags, to be compatible in situations mixing
older and newer kernels on each end. From Juergen Gross.
4) Scheduling in RCU fix in hv_netvsc, from Stephen Hemminger.
5) Zero keying information in TLS layer before freeing copies
of them, from Sabrina Dubroca.
6) Fix NULL deref in act_sample, from Davide Caratti.
7) Orphan SKB before GRO in veth to prevent crashes with XDP,
from Toshiaki Makita.
8) Fix use after free in ip6_xmit, from Eric Dumazet.
9) Fix VF mac address regression in bnxt_en, from Micahel Chan.
10) Fix MSG_PEEK behavior in TLS layer, from Daniel Borkmann.
11) Programming adjustments to r8169 which fix not being to enter deep
sleep states on some machines, from Kai-Heng Feng and Hans de
Goede.
12) Fix DST_NOCOUNT flag handling for ipv6 routes, from Peter
Oskolkov."
* gitolite.kernel.org:/pub/scm/linux/kernel/git/davem/net: (45 commits)
net/ipv6: do not copy dst flags on rt init
qmi_wwan: set DTR for modems in forced USB2 mode
clk: x86: Stop marking clocks as CLK_IS_CRITICAL
r8169: Get and enable optional ether_clk clock
clk: x86: add "ether_clk" alias for Bay Trail / Cherry Trail
r8169: enable ASPM on RTL8106E
r8169: Align ASPM/CLKREQ setting function with vendor driver
Revert "kcm: remove any offset before parsing messages"
net: ethernet: Fix a unused function warning.
net: dsa: mv88e6xxx: Fix ATU Miss Violation
tls: fix currently broken MSG_PEEK behavior
hv_netvsc: pair VF based on serial number
PCI: hv: support reporting serial number as slot information
bnxt_en: Fix VF mac address regression.
ipv6: fix possible use-after-free in ip6_xmit()
net: hp100: fix always-true check for link up state
ARM: dts: at91: add new compatibility string for macb on sama5d3
net: macb: disable scatter-gather for macb on sama5d3
net: mvpp2: let phylink manage the carrier state
Recent firmware revisions have added the ability to force
these modems to USB2 mode, hiding their SuperSpeed
capabilities from the host. The driver has been using the
SuperSpeed capability, as shown by the bcdUSB field of the
device descriptor, to detect the need to enable the DTR
quirk. This method fails when the modems are forced to
USB2 mode by the modem firmware.
Fix by unconditionally enabling the DTR quirk for the
affected device IDs.
Reported-by: Fred Veldini <fred.veldini@gmail.com>
Reported-by: Deshu Wen <dwen@sierrawireless.com>
Signed-off-by: Bjørn Mork <bjorn@mork.no>
Commit d31fd43c0f9a ("clk: x86: Do not gate clocks enabled by the
firmware"), which added the code to mark clocks as CLK_IS_CRITICAL, causes
all unclaimed PMC clocks on Cherry Trail devices to be on all the time,
resulting on the device not being able to reach S0i3 when suspended.
The reason for this commit is that on some Bay Trail / Cherry Trail devices
the r8169 ethernet controller uses pmc_plt_clk_4. Now that the clk-pmc-atom
driver exports an "ether_clk" alias for pmc_plt_clk_4 and the r8169 driver
has been modified to get and enable this clock (if present) the marking of
the clocks as CLK_IS_CRITICAL is no longer necessary.
This commit removes the CLK_IS_CRITICAL marking, fixing Cherry Trail
devices not being able to reach S0i3 greatly decreasing their battery
drain when suspended.
Buglink: https://bugzilla.kernel.org/show_bug.cgi?id=193891#c102
Buglink: https://bugzilla.kernel.org/show_bug.cgi?id=196861
Cc: Johannes Stezenbach <js@sig21.net>
Cc: Carlo Caione <carlo@endlessm.com>
Reported-by: Johannes Stezenbach <js@sig21.net>
Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Acked-by: Stephen Boyd <sboyd@kernel.org>
On some boards a platform clock is used as clock for the r8169 chip,
this commit adds support for getting and enabling this clock (assuming
it has an "ether_clk" alias set on it).
This is related to commit d31fd43c0f9a ("clk: x86: Do not gate clocks
enabled by the firmware") which is a previous attempt to fix this for some
x86 boards, but this causes all Cherry Trail SoC using boards to not reach
there lowest power states when suspending.
This commit (together with an atom-pmc-clk driver commit adding the alias)
fixes things properly by making the r8169 get the clock and enable it when
it needs it.
firmware") causes all unclaimed PMC clocks on Cherry Trail devices to be on
all the time, resulting on the device not being able to reach S0i2 or S0i3
when suspended.
the ethernet controller uses pmc_plt_clk_4. This commit adds an "ether_clk"
alias, so that the relevant ethernet drivers can try to (optionally) use
this, without needing X86 specific code / hacks, thus fixing ethernet on
these devices without breaking S0i3 support.
This commit uses clkdev_hw_create() to create the alias, mirroring the code
for the already existing "mclk" alias for pmc_plt_clk_3.
The Intel SoC was prevented from entering lower idle state because
of RTL8106E's ASPM was not enabled.
So enable ASPM on RTL8106E (chip version 39).
Now the Intel SoC can enter lower idle state, power consumption and
temperature are much lower.
Signed-off-by: Kai-Heng Feng <kai.heng.feng@canonical.com>
There's a small delay after setting ASPM in vendor drivers, r8101 and
r8168.
In addition, those drivers enable ASPM before ClkReq, also change that
to align with vendor driver.
I haven't seen anything bad becasue of this, but I think it's better to
keep in sync with vendor driver.
https://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi
Mark writes:
"spi: Fixes for v4.19
As well as one driver fix there's a couple of fixes here which address
issues with the use of IDRs for allocation of dynamic bus numbers,
ensuring that dynamic bus numbers interact well with static bus numbers
assigned via DT and otherwise."
* tag 'spi-fix-v4.19-rc4' of https://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi:
spi: spi-fsl-dspi: fix broken DSPI_EOQ_MODE
spi: Fix double IDR allocation with DT aliases
spi: fix IDR collision on systems with both fixed and dynamic SPI bus numbers
Fix the following compile warning:
drivers/net/ethernet/microchip/lan743x_main.c:2964:12: warning: lan743x_pm_suspend defined but not used [-Wunused-function]
static int lan743x_pm_suspend(struct device *dev)
drivers/net/ethernet/microchip/lan743x_main.c:2987:12: warning: lan743x_pm_resume defined but not used [-Wunused-function]
static int lan743x_pm_resume(struct device *dev)
Fix a cut/paste error and a typo which results in ATU miss violations
not being reported.
Fixes: 0977644c5005 ("net: dsa: mv88e6xxx: Decode ATU problem interrupt")
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
Matching network device based on MAC address is problematic
since a non VF network device can be creted with a duplicate MAC
address causing confusion and problems. The VMBus API does provide
a serial number that is a better matching method.
Signed-off-by: Stephen Hemminger <sthemmin@microsoft.com>
The Hyper-V host API for PCI provides a unique "serial number" which
can be used as basis for sysfs PCI slot table. This can be useful
for cases where userspace wants to find the PCI device based on
serial number.
When an SR-IOV NIC is added, the host sends an attach message
with serial number. The kernel doesn't use the serial number, but
it is useful when doing the same thing in a userspace driver such
as the DPDK. By having /sys/bus/pci/slots/N it provides a direct
way to find the matching PCI device.
There maybe some cases where serial number is not unique such
as when using GPU's. But the PCI slot infrastructure will handle
that.
This has a side effect which may also be useful. The common udev
network device naming policy uses the slot information (rather
than PCI address).
The recent commit to always forward the VF MAC address to the PF for
approval may not work if the PF driver or the firmware is older. This
will cause the VF driver to fail during probe:
bnxt_en 0000:00:03.0 (unnamed net_device) (uninitialized): hwrm req_type 0xf seq id 0x5 error 0xffff
bnxt_en 0000:00:03.0 (unnamed net_device) (uninitialized): VF MAC address 00:00:17:02:05:d0 not approved by the PF
bnxt_en 0000:00:03.0: Unable to initialize mac address.
bnxt_en: probe of 0000:00:03.0 failed with error -99
We fix it by treating the error as fatal only if the VF MAC address is
locally generated by the VF.
Fixes: 707e7e966026 ("bnxt_en: Always forward VF MAC address to the PF.")
Reported-by: Seth Forshee <seth.forshee@canonical.com>
Reported-by: Siwei Liu <loseweigh@gmail.com>
Signed-off-by: Michael Chan <michael.chan@broadcom.com>
The operation ~(p100_inb(VG_LAN_CFG_1) & HP100_LINK_UP) returns a value
that is always non-zero and hence the wait for the link to drop always
terminates prematurely. Fix this by using a logical not operator instead
of a bitwise complement. This issue has been in the driver since
pre-2.6.12-rc2.
Detected by CoverityScan, CID#114157 ("Logical vs. bitwise operator")
Create a new configuration for the sama5d3-macb new compatibility string.
This configuration disables scatter-gather because we experienced lock down
of the macb interface of this particular SoC under very high load.
Signed-off-by: Nicolas Ferre <nicolas.ferre@microchip.com>
Net drivers using phylink shouldn't mess with the link carrier
themselves and should let phylink manage it. The mvpp2 driver wasn't
following this best practice as the mac_config() function made calls to
change the link carrier state. This led to wrongly reported carrier link
state which then triggered other issues. This patch fixes this
behaviour.
But the PPv2 driver relied on this misbehaviour in two cases: for fixed
links and when not using phylink (ACPI mode). The later was fixed by
adding an explicit call to link_up(), which when the ACPI mode will use
phylink should be removed.
The fixed link case was relying on the mac_config() function to set the
link up, as we found an issue in phylink_start() which assumes the
carrier is off. If not, the link_up() function is never called. To fix
this, a call to netif_carrier_off() is added just before phylink_start()
so that we do not introduce a regression in the driver.
Fixes: 4bb043262878 ("net: mvpp2: phylink support")
Reported-by: Russell King <linux@armlinux.org.uk>
Signed-off-by: Antoine Tenart <antoine.tenart@bootlin.com>
pppoe_rcv() needs to look back at the Ethernet header in order to
lookup the PPPoE session. Therefore we need to ensure that the mac
header is big enough to contain an Ethernet header. Otherwise
eth_hdr(skb)->h_source might access invalid data.
BUG: KMSAN: uninit-value in __get_item drivers/net/ppp/pppoe.c:172 [inline]
BUG: KMSAN: uninit-value in get_item drivers/net/ppp/pppoe.c:236 [inline]
BUG: KMSAN: uninit-value in pppoe_rcv+0xcef/0x10e0 drivers/net/ppp/pppoe.c:450
CPU: 0 PID: 4543 Comm: syz-executor355 Not tainted 4.16.0+ #87
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google
01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:17 [inline]
dump_stack+0x185/0x1d0 lib/dump_stack.c:53
kmsan_report+0x142/0x240 mm/kmsan/kmsan.c:1067
__msan_warning_32+0x6c/0xb0 mm/kmsan/kmsan_instr.c:683
__netif_receive_skb_core+0x47df/0x4a90 net/core/dev.c:4562
__netif_receive_skb net/core/dev.c:4627 [inline]
netif_receive_skb_internal+0x49d/0x630 net/core/dev.c:4701
netif_receive_skb+0x230/0x240 net/core/dev.c:4725
tun_rx_batched drivers/net/tun.c:1555 [inline]
tun_get_user+0x740f/0x7c60 drivers/net/tun.c:1962
tun_chr_write_iter+0x1d4/0x330 drivers/net/tun.c:1990
call_write_iter include/linux/fs.h:1782 [inline]
new_sync_write fs/read_write.c:469 [inline]
__vfs_write+0x7fb/0x9f0 fs/read_write.c:482
vfs_write+0x463/0x8d0 fs/read_write.c:544
SYSC_write+0x172/0x360 fs/read_write.c:589
SyS_write+0x55/0x80 fs/read_write.c:581
do_syscall_64+0x309/0x430 arch/x86/entry/common.c:287
entry_SYSCALL_64_after_hwframe+0x3d/0xa2
RIP: 0033:0x4447c9
RSP: 002b:00007fff64c8fc28 EFLAGS: 00000297 ORIG_RAX: 0000000000000001
RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00000000004447c9
RDX: 000000000000fd87 RSI: 0000000020000600 RDI: 0000000000000004
RBP: 00000000006cf018 R08: 00007fff64c8fda8 R09: 00007fff00006bda
R10: 0000000000005fe7 R11: 0000000000000297 R12: 00000000004020d0
R13: 0000000000402160 R14: 0000000000000000 R15: 0000000000000000
Uninit was created at:
kmsan_save_stack_with_flags mm/kmsan/kmsan.c:278 [inline]
kmsan_internal_poison_shadow+0xb8/0x1b0 mm/kmsan/kmsan.c:188
kmsan_kmalloc+0x94/0x100 mm/kmsan/kmsan.c:314
kmsan_slab_alloc+0x11/0x20 mm/kmsan/kmsan.c:321
slab_post_alloc_hook mm/slab.h:445 [inline]
slab_alloc_node mm/slub.c:2737 [inline]
__kmalloc_node_track_caller+0xaed/0x11c0 mm/slub.c:4369
__kmalloc_reserve net/core/skbuff.c:138 [inline]
__alloc_skb+0x2cf/0x9f0 net/core/skbuff.c:206
alloc_skb include/linux/skbuff.h:984 [inline]
alloc_skb_with_frags+0x1d4/0xb20 net/core/skbuff.c:5234
sock_alloc_send_pskb+0xb56/0x1190 net/core/sock.c:2085
tun_alloc_skb drivers/net/tun.c:1532 [inline]
tun_get_user+0x2242/0x7c60 drivers/net/tun.c:1829
Fixes: 224cf5ad14c0 ("ppp: Move the PPP drivers")
Reported-by: syzbot+f5f6080811c849739212@syzkaller.appspotmail.com
Signed-off-by: Guillaume Nault <g.nault@alphalink.fr>
This patch mades TI_DAVINCI_CPDMA select GENERIC_ALLOCATOR.
without that, the following sparc64 build failure happen
drivers/net/ethernet/ti/davinci_cpdma.o: In function `cpdma_check_free_tx_desc':
(.text+0x278): undefined reference to `gen_pool_avail'
drivers/net/ethernet/ti/davinci_cpdma.o: In function `cpdma_chan_submit':
(.text+0x340): undefined reference to `gen_pool_alloc'
(.text+0x5c4): undefined reference to `gen_pool_free'
drivers/net/ethernet/ti/davinci_cpdma.o: In function `__cpdma_chan_free':
davinci_cpdma.c:(.text+0x64c): undefined reference to `gen_pool_free'
drivers/net/ethernet/ti/davinci_cpdma.o: In function `cpdma_desc_pool_destroy.isra.6':
davinci_cpdma.c:(.text+0x17ac): undefined reference to `gen_pool_size'
davinci_cpdma.c:(.text+0x17b8): undefined reference to `gen_pool_avail'
davinci_cpdma.c:(.text+0x1824): undefined reference to `gen_pool_size'
davinci_cpdma.c:(.text+0x1830): undefined reference to `gen_pool_avail'
drivers/net/ethernet/ti/davinci_cpdma.o: In function `cpdma_ctlr_create':
(.text+0x19f8): undefined reference to `devm_gen_pool_create'
(.text+0x1a90): undefined reference to `gen_pool_add_virt'
Makefile:1011: recipe for target 'vmlinux' failed
Signed-off-by: Corentin Labbe <clabbe@baylibre.com>
While at first mtd_part_of_parse() would just call
of_get_chil_by_name(), it has been patched to deal with sub-partitions
and will now directly manipulate the node returned by mtd_get_of_node()
if the MTD device is a partition.
A of_node_put() was a bit below in the code, to balance the
of_get_child_by_name(). However, despite its name, mtd_get_of_node()
does not take a reference on the OF node. It is a simple helper hiding
some pointer logic to retrieve the OF node related to an MTD
device.
The direct effect of such unbalanced reference counting is visible by
rmmod'ing any module that would have added MTD partitions:
OF: ERROR: Bad of_node_put() on <of_path_to_partition>
As it seems normal to get a reference on the OF node during the
of_property_for_each_string() that follows, add a call to
of_node_get() when relevant.
Fixes: 76a832254ab0 ("mtd: partitions: use DT info for parsing partitions with "compatible" prop")
Cc: stable@vger.kernel.org
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
The documented register to retrieve the fan RPM for fan7 is found
to be unreliable at least with NCT6796D revision 3. Let's use
register 0x4ce instead. This is undocumented for NCT6796D, but
documented for NCT6797D and NCT6798D and known to be working.
Reported-by: Robert Kern <ulteq@web.de>
Cc: Robert Kern <ulteq@web.de>
Fixes: 81820059a428 ("hwmon: (nct6775) Add support for NCT6796D")
GRO expects skbs not to be owned by sockets, but when XDP is enabled veth
passed skbs owned by sockets. It caused corrupted sk_wmem_alloc.
Paolo Abeni reported the following splat:
[ 362.098904] refcount_t overflow at skb_set_owner_w+0x5e/0xa0 in iperf3[1644], uid/euid: 0/0
[ 362.108239] WARNING: CPU: 0 PID: 1644 at kernel/panic.c:648 refcount_error_report+0xa0/0xa4
[ 362.117547] Modules linked in: tcp_diag inet_diag veth intel_rapl sb_edac x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel intel_cstate intel_uncore intel_rapl_perf ipmi_ssif iTCO_wdt sg ipmi_si iTCO_vendor_support ipmi_devintf mxm_wmi ipmi_msghandler pcspkr dcdbas mei_me wmi mei lpc_ich acpi_power_meter pcc_cpufreq xfs libcrc32c sd_mod mgag200 drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops ixgbe igb ttm ahci mdio libahci ptp crc32c_intel drm pps_core libata i2c_algo_bit dca dm_mirror dm_region_hash dm_log dm_mod
[ 362.176622] CPU: 0 PID: 1644 Comm: iperf3 Not tainted 4.19.0-rc2.vanilla+ #2025
[ 362.184777] Hardware name: Dell Inc. PowerEdge R730/072T6D, BIOS 2.1.7 06/16/2016
[ 362.193124] RIP: 0010:refcount_error_report+0xa0/0xa4
[ 362.198758] Code: 08 00 00 48 8b 95 80 00 00 00 49 8d 8c 24 80 0a 00 00 41 89 c1 44 89 2c 24 48 89 de 48 c7 c7 18 4d e7 9d 31 c0 e8 30 fa ff ff <0f> 0b eb 88 0f 1f 44 00 00 55 48 89 e5 41 56 41 55 41 54 49 89 fc
[ 362.219711] RSP: 0018:ffff9ee6ff603c20 EFLAGS: 00010282
[ 362.225538] RAX: 0000000000000000 RBX: ffffffff9de83e10 RCX: 0000000000000000
[ 362.233497] RDX: 0000000000000001 RSI: ffff9ee6ff6167d8 RDI: ffff9ee6ff6167d8
[ 362.241457] RBP: ffff9ee6ff603d78 R08: 0000000000000490 R09: 0000000000000004
[ 362.249416] R10: 0000000000000000 R11: ffff9ee6ff603990 R12: ffff9ee664b94500
[ 362.257377] R13: 0000000000000000 R14: 0000000000000004 R15: ffffffff9de615f9
[ 362.265337] FS: 00007f1d22d28740(0000) GS:ffff9ee6ff600000(0000) knlGS:0000000000000000
[ 362.274363] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 362.280773] CR2: 00007f1d222f35d0 CR3: 0000001fddfec003 CR4: 00000000001606f0
[ 362.288733] Call Trace:
[ 362.291459] <IRQ>
[ 362.293702] ex_handler_refcount+0x4e/0x80
[ 362.298269] fixup_exception+0x35/0x40
[ 362.302451] do_trap+0x109/0x150
[ 362.306048] do_error_trap+0xd5/0x130
[ 362.315766] invalid_op+0x14/0x20
[ 362.319460] RIP: 0010:skb_set_owner_w+0x5e/0xa0
[ 362.324512] Code: ef ff ff 74 49 48 c7 43 60 20 7b 4a 9d 8b 85 f4 01 00 00 85 c0 75 16 8b 83 e0 00 00 00 f0 01 85 44 01 00 00 0f 88 d8 23 16 00 <5b> 5d c3 80 8b 91 00 00 00 01 8b 85 f4 01 00 00 89 83 a4 00 00 00
[ 362.345465] RSP: 0018:ffff9ee6ff603e20 EFLAGS: 00010a86
[ 362.351291] RAX: 0000000000001100 RBX: ffff9ee65deec700 RCX: ffff9ee65e829244
[ 362.359250] RDX: 0000000000000100 RSI: ffff9ee65e829100 RDI: ffff9ee65deec700
[ 362.367210] RBP: ffff9ee65e829100 R08: 000000000002a380 R09: 0000000000000000
[ 362.375169] R10: 0000000000000002 R11: fffff1a4bf77bb00 R12: ffffc0754661d000
[ 362.383130] R13: ffff9ee65deec200 R14: ffff9ee65f597000 R15: 00000000000000aa
[ 362.391092] veth_xdp_rcv+0x4e4/0x890 [veth]
[ 362.399357] veth_poll+0x4d/0x17a [veth]
[ 362.403731] net_rx_action+0x2af/0x3f0
[ 362.407912] __do_softirq+0xdd/0x29e
[ 362.411897] do_softirq_own_stack+0x2a/0x40
[ 362.416561] </IRQ>
[ 362.418899] do_softirq+0x4b/0x70
[ 362.422594] __local_bh_enable_ip+0x50/0x60
[ 362.427258] ip_finish_output2+0x16a/0x390
[ 362.431824] ip_output+0x71/0xe0
[ 362.440670] __tcp_transmit_skb+0x583/0xab0
[ 362.445333] tcp_write_xmit+0x247/0xfb0
[ 362.449609] __tcp_push_pending_frames+0x2d/0xd0
[ 362.454760] tcp_sendmsg_locked+0x857/0xd30
[ 362.459424] tcp_sendmsg+0x27/0x40
[ 362.463216] sock_sendmsg+0x36/0x50
[ 362.467104] sock_write_iter+0x87/0x100
[ 362.471382] __vfs_write+0x112/0x1a0
[ 362.475369] vfs_write+0xad/0x1a0
[ 362.479062] ksys_write+0x52/0xc0
[ 362.482759] do_syscall_64+0x5b/0x180
[ 362.486841] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 362.492473] RIP: 0033:0x7f1d22293238
[ 362.496458] Code: 89 02 48 c7 c0 ff ff ff ff eb b3 0f 1f 80 00 00 00 00 f3 0f 1e fa 48 8d 05 c5 54 2d 00 8b 00 85 c0 75 17 b8 01 00 00 00 0f 05 <48> 3d 00 f0 ff ff 77 58 c3 0f 1f 80 00 00 00 00 41 54 49 89 d4 55
[ 362.517409] RSP: 002b:00007ffebaef8008 EFLAGS: 00000246 ORIG_RAX: 0000000000000001
[ 362.525855] RAX: ffffffffffffffda RBX: 0000000000002800 RCX: 00007f1d22293238
[ 362.533816] RDX: 0000000000002800 RSI: 00007f1d22d36000 RDI: 0000000000000005
[ 362.541775] RBP: 00007f1d22d36000 R08: 00000002db777a30 R09: 0000562b70712b20
[ 362.549734] R10: 0000000000000000 R11: 0000000000000246 R12: 0000000000000005
[ 362.557693] R13: 0000000000002800 R14: 00007ffebaef8060 R15: 0000562b70712260
In order to avoid this, orphan the skb before entering GRO.
Fixes: 948d4f214fde ("veth: Add driver XDP")
Reported-by: Paolo Abeni <pabeni@redhat.com>
Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp>
Tested-by: Paolo Abeni <pabeni@redhat.com>
Synopsys DWC Ethernet MAC can be configured to have 1..32, 64, or
128 unicast filter entries. (Table 7-8 MAC Address Registers from
databook) Fix dwmac1000_validate_ucast_entries() to accept values
between 1 and 32 in addition.
Signed-off-by: Jongsung Kim <neidhard.kim@lge.com>
fan7 on NCT6796D does not have a fan count register; it only has an RPM
register. Switch to using RPM registers to read the fan speed for all
chips supporting it to solve the problem for good.
The following kernel log message is reported for the nct6775 driver
on ASUS WS X299 SAGE.
nct6775: Found NCT6796D or compatible chip at 0x2e:0x290
nct6775 nct6775.656: Invalid temperature source 11 at index 0,
source register 0x100, temp register 0x73
nct6775 nct6775.656: Invalid temperature source 11 at index 2,
source register 0x300, temp register 0x77
nct6775 nct6775.656: Invalid temperature source 11 at index 3,
source register 0x800, temp register 0x79
nct6775 nct6775.656: Invalid temperature source 11 at index 4,
source register 0x900, temp register 0x7b
A recent version of the datasheet lists temperature source 11 as reserved.
However, an older version of the datasheet lists temperature sources 10
and 11 as supported virtual temperature sources. Apparently the older
version of the datasheet is correct, so list those temperature sources
as supported.
Virtual temperature sources are different than other temperature sources:
Values are not read from a temperature sensor, but written either from
BIOS or an embedded controller. As such, each virtual temperature has to
be reported. Since there is now more than one temperature source, we have
to keep virtual temperature sources in a chip-specific mask and can no
longer rely on the assumption that there is only one virtual temperature
source with a fixed index. This accounts for most of the complexity of this
patch.
I thought the read-back of the DMA_ENABLE register was unnecessary
(at least it is working on my boards), then deleted it in commit
586a2c52909d ("mtd: nand: denali: squash denali_enable_dma() helper
into caller"). Sorry, I was wrong - it caused a timing issue on
Cyclone5 SoCFPGAs.
Revive the register read-back, commenting why this is necessary.
Fixes: 586a2c52909d ("mtd: nand: denali: squash denali_enable_dma() helper into caller")
Reported-by: Steffen Trumtrar <s.trumtrar@pengutronix.de>
Reviewed-by: Miquel Raynal <miquel.raynal@bootlin.com>
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux
Pull DeviceTree fix from Rob Herring:
"One regression for a 20 year old PowerMac:
- Fix a regression on systems having a DT without any phandles which
happens on a PowerMac G3"
* tag 'devicetree-fixes-for-4.19-2' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux:
of: fix phandle cache creation for DTs with no phandles
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip
Pull xen fixes from Juergen Gross:
"This contains some minor cleanups and fixes:
- a new knob for controlling scrubbing of pages returned by the Xen
balloon driver to the Xen hypervisor to address a boot performance
issue seen in large guests booted pre-ballooned
- a fix of a regression in the gntdev driver which made it impossible
to use fully virtualized guests (HVM guests) with a 4.19 based dom0
- a fix in Xen cpu hotplug functionality which could be triggered by
wrong admin commands (setting number of active vcpus to 0)
One further note: the patches have all been under test for several
days in another branch. This branch has been rebased in order to avoid
merge conflicts"
* tag 'for-linus-4.19c-rc4-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip:
xen/gntdev: fix up blockable calls to mn_invl_range_start
xen: fix GCC warning and remove duplicate EVTCHN_ROW/EVTCHN_COL usage
xen: avoid crash in disable_hotplug_cpu
xen/balloon: add runtime control for scrubbing ballooned out pages
xen/manage: don't complain about an empty value in control/sysrq node
git://git.infradead.org/users/vkoul/slave-dma
Pull dmaengine fix from Vinod Koul:
"Fix the mic_x100_dma driver to use devm_kzalloc for driver memory, so
that it is freed properly when it unregisters from dmaengine using
managed API"
* tag 'dmaengine-fix-4.19-rc4' of git://git.infradead.org/users/vkoul/slave-dma:
dmaengine: mic_x100_dma: use devm_kzalloc to fix an issue
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB fixes from Greg KH:
"Here are a number of small USB driver fixes for -rc4.
The usual suspects of gadget, xhci, and dwc2/3 are in here, along with
some reverts of reported problem changes, and a number of build
documentation warning fixes. Full details are in the shortlog.
All of these have been in linux-next with no reported issues"
* tag 'usb-4.19-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (28 commits)
Revert "cdc-acm: implement put_char() and flush_chars()"
usb: Change usb_of_get_companion_dev() place to usb/common
usb: xhci: fix interrupt transfer error happened on MTK platforms
usb: cdc-wdm: Fix a sleep-in-atomic-context bug in service_outstanding_interrupt()
usb: misc: uss720: Fix two sleep-in-atomic-context bugs
usb: host: u132-hcd: Fix a sleep-in-atomic-context bug in u132_get_frame()
usb: Avoid use-after-free by flushing endpoints early in usb_set_interface()
linux/mod_devicetable.h: fix kernel-doc missing notation for typec_device_id
usb/typec: fix kernel-doc notation warning for typec_match_altmode
usb: Don't die twice if PCI xhci host is not responding in resume
usb: mtu3: fix error of xhci port id when enable U3 dual role
usb: uas: add support for more quirk flags
USB: Add quirk to support DJI CineSSD
usb: typec: fix kernel-doc parameter warning
usb/dwc3/gadget: fix kernel-doc parameter warning
USB: yurex: Check for truncation in yurex_read()
USB: yurex: Fix buffer over-read in yurex_write()
usb: host: xhci-plat: Iterate over parent nodes for finding quirks
xhci: Fix use after free for URB cancellation on a reallocated endpoint
USB: add quirk for WORLDE Controller KS49 or Prodipe MIDI 49C USB controller
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull tty fixes from Greg KH:
"Here are three small HVC tty driver fixes to resolve a reported
regression from 4.19-rc1.
All of these have been in linux-next for a while with no reported
issues"
* tag 'tty-4.19-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty:
tty: hvc: hvc_write() fix break condition
tty: hvc: hvc_poll() fix read loop batching
tty: hvc: hvc_poll() fix read loop hang
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging/IIO driver fixes from Greg KH:
"Here are a few small staging and iio driver fixes for -rc4.
Nothing major, just a few small bugfixes for some reported issues, and
a MAINTAINERS file update for the fbtft drivers.
We also re-enable the building of the erofs filesystem as the XArray
patches that were causing it to break never got merged in the -rc1
cycle, so there's no reason it can't be turned back on for now. The
problem that was previously there is now being handled in the Xarray
tree at the moment, so it will not hit us again in the future.
All of these patches have been in linux-next with no reported issues"
* tag 'staging-4.19-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging:
staging: vboxvideo: Change address of scanout buffer on page-flip
staging: vboxvideo: Fix IRQs no longer working
staging: gasket: TODO: re-implement using UIO
staging/fbtft: Update TODO and mailing lists
staging: erofs: rename superblock flags (MS_xyz -> SB_xyz)
iio: imu: st_lsm6dsx: take into account ts samples in wm configuration
Revert "iio: temperature: maxim_thermocouple: add MAX31856 part"
Revert "staging: erofs: disable compiling temporarile"
MAINTAINERS: Switch a maintainer for drivers/staging/gasket
staging: wilc1000: revert "fix TODO to compile spi and sdio components in single module"
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver fixes from Greg KH:
"Here are a small handful of char/misc driver fixes for 4.19-rc4.
All of them are simple, resolving reported problems in a few drivers.
* tag 'char-misc-4.19-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc:
firmware: Fix security issue with request_firmware_into_buf()
vmbus: don't return values for uninitalized channels
fpga: dfl: fme: fix return value check in in pr_mgmt_init()
misc: hmc6352: fix potential Spectre v1
Tools: hv: Fix a bug in the key delete code
misc: ibmvsm: Fix wrong assignment of return code
android: binder: fix the race mmap and alloc_new_buf_locked
mei: bus: need to unlink client before freeing
mei: bus: fix hw module get/put balance
mei: fix use-after-free in mei_cl_write
mei: ignore not found client in the enumeration
Patch series "mmu_notifiers follow ups".
Tetsuo has noticed some fallouts from 93065ac753e4 ("mm, oom: distinguish
blockable mode for mmu notifiers"). One of them has been fixed and picked
up by AMD/DRM maintainer [1]. XEN issue is fixed by patch 1. I have also
clarified expectations about blockable semantic of invalidate_range_end.
Finally the last patch removes MMU_INVALIDATE_DOES_NOT_BLOCK which is no
longer used nor needed.
[1] http://lkml.kernel.org/r/20180824135257.GU29735@dhcp22.suse.cz
This patch (of 3):
93065ac753e4 ("mm, oom: distinguish blockable mode for mmu notifiers") has
introduced blockable parameter to all mmu_notifiers and the notifier has
to back off when called in !blockable case and it could block down the
road.
The above commit implemented that for mn_invl_range_start but both
in_range checks are done unconditionally regardless of the blockable mode
and as such they would fail all the time for regular calls. Fix this by
checking blockable parameter as well.
Once we are there we can remove the stale TODO. The lock has to be
sleepable because we wait for completion down in gnttab_unmap_refs_sync.
Link: http://lkml.kernel.org/r/20180827112623.8992-2-mhocko@kernel.org
Fixes: 93065ac753e4 ("mm, oom: distinguish blockable mode for mmu notifiers")
Signed-off-by: Michal Hocko <mhocko@suse.com>
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: Juergen Gross <jgross@suse.com>
Cc: Jerome Glisse <jglisse@redhat.com>
Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Reviewed-by: Juergen Gross <jgross@suse.com>
Signed-off-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
This patch removes duplicate macro useage in events_base.c.
It also fixes gcc warning:
variable ‘col’ set but not used [-Wunused-but-set-variable]
Signed-off-by: Joshua Abraham <j.abraham1776@gmail.com>
The command 'xl vcpu-set 0 0', issued in dom0, will crash dom0:
BUG: unable to handle kernel NULL pointer dereference at 00000000000002d8
PGD 0 P4D 0
Oops: 0000 [#1] PREEMPT SMP NOPTI
CPU: 7 PID: 65 Comm: xenwatch Not tainted 4.19.0-rc2-1.ga9462db-default #1 openSUSE Tumbleweed (unreleased)
Hardware name: Intel Corporation S5520UR/S5520UR, BIOS S5500.86B.01.00.0050.050620101605 05/06/2010
RIP: e030:device_offline+0x9/0xb0
Code: 77 24 00 e9 ce fe ff ff 48 8b 13 e9 68 ff ff ff 48 8b 13 e9 29 ff ff ff 48 8b 13 e9 ea fe ff ff 90 66 66 66 66 90 41 54 55 53 <f6> 87 d8 02 00 00 01 0f 85 88 00 00 00 48 c7 c2 20 09 60 81 31 f6
RSP: e02b:ffffc90040f27e80 EFLAGS: 00010203
RAX: 0000000000000000 RBX: 0000000000000000 RCX: 0000000000000000
RDX: ffff8801f3800000 RSI: ffffc90040f27e70 RDI: 0000000000000000
RBP: 0000000000000000 R08: ffffffff820e47b3 R09: 0000000000000000
R10: 0000000000007ff0 R11: 0000000000000000 R12: ffffffff822e6d30
R13: dead000000000200 R14: dead000000000100 R15: ffffffff8158b4e0
FS: 00007ffa595158c0(0000) GS:ffff8801f39c0000(0000) knlGS:0000000000000000
CS: e033 DS: 0000 ES: 0000 CR0: 0000000080050033
CR2: 00000000000002d8 CR3: 00000001d9602000 CR4: 0000000000002660
Call Trace:
handle_vcpu_hotplug_event+0xb5/0xc0
xenwatch_thread+0x80/0x140
? wait_woken+0x80/0x80
kthread+0x112/0x130
? kthread_create_worker_on_cpu+0x40/0x40
ret_from_fork+0x3a/0x50
This happens because handle_vcpu_hotplug_event is called twice. In the
first iteration cpu_present is still true, in the second iteration
cpu_present is false which causes get_cpu_device to return NULL.
In case of cpu#0, cpu_online is apparently always true.
Fix this crash by checking if the cpu can be hotplugged, which is false
for a cpu that was just removed.
Also check if the cpu was actually offlined by device_remove, otherwise
leave the cpu_present state as it is.
Rearrange to code to do all work with device_hotplug_lock held.
Signed-off-by: Olaf Hering <olaf@aepfle.de>
Scrubbing pages on initial balloon down can take some time, especially
in nested virtualization case (nested EPT is slow). When HVM/PVH guest is
started with memory= significantly lower than maxmem=, all the extra
pages will be scrubbed before returning to Xen. But since most of them
weren't used at all at that point, Xen needs to populate them first
(from populate-on-demand pool). In nested virt case (Xen inside KVM)
this slows down the guest boot by 15-30s with just 1.5GB needed to be
returned to Xen.
Add runtime parameter to enable/disable it, to allow initially disabling
scrubbing, then enable it back during boot (for example in initramfs).
Such usage relies on assumption that a) most pages ballooned out during
initial boot weren't used at all, and b) even if they were, very few
secrets are in the guest at that time (before any serious userspace
kicks in).
Convert CONFIG_XEN_SCRUB_PAGES to CONFIG_XEN_SCRUB_PAGES_DEFAULT (also
enabled by default), controlling default value for the new runtime
switch.
Signed-off-by: Marek Marczykowski-Górecki <marmarek@invisiblethingslab.com>
When guest receives a sysrq request from the host it acknowledges it by
writing '\0' to control/sysrq xenstore node. This, however, make xenstore
watch fire again but xenbus_scanf() fails to parse empty value with "%c"
format string:
sysrq: SysRq : Emergency Sync
Emergency Sync complete
xen:manage: Error -34 reading sysrq code in control/sysrq
Ignore -ERANGE the same way we already ignore -ENOENT, empty value in
control/sysrq is totally legal.
Signed-off-by: Vitaly Kuznetsov <vkuznets@redhat.com>
Reviewed-by: Wei Liu <wei.liu2@citrix.com>
