path: root/drivers
2019-05-21treewide: Add SPDX license identifier for missed filesThomas Gleixner
Add SPDX license identifiers to all files which: - Have no license information of any form - Have EXPORT_.*_SYMBOL_GPL inside which was used in the initial scan/conversion to ignore the file These files fall under the project license, GPL v2 only. The resulting SPDX license identifier is: GPL-2.0-only Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-19Merge tag 'kbuild-v5.2-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild Pull more Kbuild updates from Masahiro Yamada: - remove unneeded use of cc-option, cc-disable-warning, cc-ldoption - exclude tracked files from .gitignore - re-enable -Wint-in-bool-context warning - refactor samples/Makefile - stop building immediately if syncconfig fails - do not sprinkle error messages when $(CC) does not exist - move arch/alpha/defconfig to the configs subdirectory - remove crappy header search path manipulation - add comment lines to .config to clarify the end of menu blocks - check uniqueness of module names (adding new warnings intentionally) * tag 'kbuild-v5.2-2' of git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild: (24 commits) kconfig: use 'else ifneq' for Makefile to improve readability kbuild: check uniqueness of module names kconfig: Terminate menu blocks with a comment in the generated config kbuild: add LICENSES to KBUILD_ALLDIRS kbuild: remove 'addtree' and 'flags' magic for header search paths treewide: prefix header search paths with $(srctree)/ media: prefix header search paths with $(srctree)/ media: remove unneeded header search paths alpha: move arch/alpha/defconfig to arch/alpha/configs/defconfig kbuild: terminate Kconfig when $(CC) or $(LD) is missing kbuild: turn auto.conf.cmd into a mandatory include file .gitignore: exclude .get_maintainer.ignore and .gitattributes kbuild: add all Clang-specific flags unconditionally kbuild: Don't try to add '-fcatch-undefined-behavior' flag kbuild: add some extra warning flags unconditionally kbuild: add -Wvla flag unconditionally arch: remove dangling asm-generic wrappers samples: guard sub-directories with CONFIG options kbuild: re-enable int-in-bool-context warning MAINTAINERS: kbuild: Add pattern for scripts/*vmlinux* ...
2019-05-19Merge branch 'i2c/for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux Pull i2c updates from Wolfram Sang: "Some I2C core API additions which are kind of simple but enhance error checking for users a lot, especially by returning errno now. There are wrappers to still support the old API but it will be removed once all users are converted" * 'i2c/for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: i2c: core: add device-managed version of i2c_new_dummy i2c: core: improve return value handling of i2c_new_device and i2c_new_dummy
2019-05-19Merge branch 'timers-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull clocksource updates from Ingo Molnar: "Misc clocksource/clockevent driver updates that came in a bit late but are ready for v5.2" * 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: misc: atmel_tclib: Do not probe already used TCBs clocksource/drivers/timer-atmel-tcb: Convert tc_clksrc_suspend|resume() to static clocksource/drivers/tcb_clksrc: Rename the file for consistency clocksource/drivers/timer-atmel-pit: Rework Kconfig option clocksource/drivers/tcb_clksrc: Move Kconfig option ARM: at91: Implement clocksource selection clocksource/drivers/tcb_clksrc: Use tcb as sched_clock clocksource/drivers/tcb_clksrc: Stop depending on atmel_tclib ARM: at91: move SoC specific definitions to SoC folder clocksource/drivers/timer-milbeaut: Cleanup common register accesses clocksource/drivers/timer-milbeaut: Add shutdown function clocksource/drivers/timer-milbeaut: Fix to enable one-shot timer clocksource/drivers/tegra: Rework for compensation of suspend time clocksource/drivers/sp804: Add COMPILE_TEST to CONFIG_ARM_TIMER_SP804 clocksource/drivers/sun4i: Add a compatible for suniv dt-bindings: timer: Add Allwinner suniv timer
2019-05-19Merge branch 'irq-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull IRQ chip updates from Ingo Molnar: "A late irqchips update: - New TI INTR/INTA set of drivers - Rewrite of the stm32mp1-exti driver as a platform driver - Update the IOMMU MSI mapping API to be RT friendly - A number of cleanups and other low impact fixes" * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (34 commits) iommu/dma-iommu: Remove iommu_dma_map_msi_msg() irqchip/gic-v3-mbi: Don't map the MSI page in mbi_compose_m{b, s}i_msg() irqchip/ls-scfg-msi: Don't map the MSI page in ls_scfg_msi_compose_msg() irqchip/gic-v3-its: Don't map the MSI page in its_irq_compose_msi_msg() irqchip/gicv2m: Don't map the MSI page in gicv2m_compose_msi_msg() iommu/dma-iommu: Split iommu_dma_map_msi_msg() in two parts genirq/msi: Add a new field in msi_desc to store an IOMMU cookie arm64: arch_k3: Enable interrupt controller drivers irqchip/ti-sci-inta: Add msi domain support soc: ti: Add MSI domain bus support for Interrupt Aggregator irqchip/ti-sci-inta: Add support for Interrupt Aggregator driver dt-bindings: irqchip: Introduce TISCI Interrupt Aggregator bindings irqchip/ti-sci-intr: Add support for Interrupt Router driver dt-bindings: irqchip: Introduce TISCI Interrupt router bindings gpio: thunderx: Use the default parent apis for {request,release}_resources genirq: Introduce irq_chip_{request,release}_resource_parent() apis firmware: ti_sci: Add helper apis to manage resources firmware: ti_sci: Add RM mapping table for am654 firmware: ti_sci: Add support for IRQ management firmware: ti_sci: Add support for RM core ops ...
2019-05-19Merge branch 'efi-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull EFI fix from Ingo Molnar: "Fix an EFI-fb regression that affects certain x86 systems" * 'efi-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: fbdev/efifb: Ignore framebuffer memmap entries that lack any memory types
2019-05-19Merge tag 'armsoc-late' of git://git.kernel.org/pub/scm/linux/kernel/git/soc/socLinus Torvalds
Pull ARM SoC late updates from Olof Johansson: "This is some material that we picked up into our tree late. Most of it are smaller fixes and additions, some defconfig updates due to recent development, etc. Code-wise the largest portion is a series of PM updates for the at91 platform, and those have been in linux-next a while through the at91 tree before we picked them up" * tag 'armsoc-late' of git://git.kernel.org/pub/scm/linux/kernel/git/soc/soc: (29 commits) arm64: dts: sprd: Add clock properties for serial devices Opt out of scripts/get_maintainer.pl ARM: ixp4xx: Remove duplicated include from common.c soc: ixp4xx: qmgr: Fix an NULL vs IS_ERR() check in probe arm64: tegra: Disable XUSB support on Jetson TX2 arm64: tegra: Enable SMMU translation for PCI on Tegra186 arm64: tegra: Fix insecure SMMU users for Tegra186 arm64: tegra: Select ARM_GIC_PM amba: tegra-ahb: Mark PM functions as __maybe_unused ARM: dts: logicpd-som-lv: Fix MMC1 card detect ARM: mvebu: drop return from void function ARM: mvebu: prefix coprocessor operand with p ARM: mvebu: drop unnecessary label ARM: mvebu: fix a leaked reference by adding missing of_node_put ARM: socfpga_defconfig: enable LTC2497 ARM: mvebu: kirkwood: remove error message when retrieving mac address ARM: at91: sama5: make ov2640 as a module ARM: OMAP1: ams-delta: fix early boot crash when LED support is disabled ARM: at91: remove HAVE_FB_ATMEL for sama5 SoC as they use DRM soc/fsl/qe: Fix an error code in qe_pin_request() ...
2019-05-19Merge tag 'riscv-for-linus-5.2-mw2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/palmer/riscv-linux Pull RISC-V updates from Palmer Dabbelt: "This contains an assortment of RISC-V related patches that I'd like to target for the 5.2 merge window. Most of the patches are cleanups, but there are a handful of user-visible changes: - The nosmp and nr_cpus command-line arguments are now supported, which work like normal. - The SBI console no longer installs itself as a preferred console, we rely on standard mechanisms (/chosen, command-line, hueristics) instead. - sfence_remove_sfence_vma{,_asid} now pass their arguments along to the SBI call. - Modules now support BUG(). - A missing sfence.vma during boot has been added. This bug only manifests during boot. - The arch/riscv support for SiFive's L2 cache controller has been merged, which should un-block the EDAC framework work. I've only tested this on QEMU again, as I didn't have time to get things running on the Unleashed. The latest master from this morning merges in cleanly and passes the tests as well" * tag 'riscv-for-linus-5.2-mw2' of git://git.kernel.org/pub/scm/linux/kernel/git/palmer/riscv-linux: (31 commits) riscv: fix locking violation in page fault handler RISC-V: sifive_l2_cache: Add L2 cache controller driver for SiFive SoCs RISC-V: Add DT documentation for SiFive L2 Cache Controller RISC-V: Avoid using invalid intermediate translations riscv: Support BUG() in kernel module riscv: Add the support for c.ebreak check in is_valid_bugaddr() riscv: support trap-based WARN() riscv: fix sbi_remote_sfence_vma{,_asid}. riscv: move switch_mm to its own file riscv: move flush_icache_{all,mm} to cacheflush.c tty: Don't force RISCV SBI console as preferred console RISC-V: Access CSRs using CSR numbers RISC-V: Add interrupt related SCAUSE defines in asm/csr.h RISC-V: Use tabs to align macro values in asm/csr.h RISC-V: Fix minor checkpatch issues. RISC-V: Support nr_cpus command line option. RISC-V: Implement nosmp commandline option. RISC-V: Add RISC-V specific arch_match_cpu_phys_id riscv: vdso: drop unnecessary cc-ldoption riscv: call pm_power_off from machine_halt / machine_power_off ...
2019-05-18treewide: prefix header search paths with $(srctree)/Masahiro Yamada
Currently, the Kbuild core manipulates header search paths in a crazy way [1]. To fix this mess, I want all Makefiles to add explicit $(srctree)/ to the search paths in the srctree. Some Makefiles are already written in that way, but not all. The goal of this work is to make the notation consistent, and finally get rid of the gross hacks. Having whitespaces after -I does not matter since commit 48f6e3cf5bc6 ("kbuild: do not drop -I without parameter"). [1]: https://patchwork.kernel.org/patch/9632347/ Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2019-05-18media: prefix header search paths with $(srctree)/Masahiro Yamada
Currently, the Kbuild core manipulates header search paths in a crazy way [1]. To fix this mess, I want all Makefiles to add explicit $(srctree)/ to the search paths in the srctree. Some Makefiles are already written in that way, but not all. The goal of this work is to make the notation consistent, and finally get rid of the gross hacks. Having whitespaces after -I does not matter since commit 48f6e3cf5bc6 ("kbuild: do not drop -I without parameter"). [1]: https://patchwork.kernel.org/patch/9632347/ Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Sakari Ailus <sakari.ailus@linux.intel.com>
2019-05-18media: remove unneeded header search pathsMasahiro Yamada
I was able to build without these extra header search paths. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2019-05-17i2c: core: add device-managed version of i2c_new_dummyHeiner Kallweit
i2c_new_dummy is typically called from the probe function of the driver for the primary i2c client. It requires calls to i2c_unregister_device in the error path of the probe function and in the remove function. This can be simplified by introducing a device-managed version. Note the changed error case return value type: i2c_new_dummy returns NULL whilst devm_i2c_new_dummy_device returns an ERR_PTR. Signed-off-by: Heiner Kallweit <hkallweit1@gmail.com> [wsa: rename new functions and fix minor kdoc issues] Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com> Reviewed-by: Peter Rosin <peda@axentia.se> Reviewed-by: Kieran Bingham <kieran.bingham+renesas@ideasonboard.com> Reviewed-by: Bartosz Golaszewski <bgolaszewski@baylibre.com> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2019-05-17i2c: core: improve return value handling of i2c_new_device and i2c_new_dummyHeiner Kallweit
Currently i2c_new_device and i2c_new_dummy return just NULL in error case although they have more error details internally. Therefore move the functionality into new functions returning detailed errors and add wrappers for compatibility with the current API. This allows to use these functions with detailed error codes within the i2c core or for API extensions. Signed-off-by: Heiner Kallweit <hkallweit1@gmail.com> [wsa: rename new functions and fix minor kdoc issues] Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com> Reviewed-by: Peter Rosin <peda@axentia.se> Reviewed-by: Kieran Bingham <kieran.bingham+renesas@ideasonboard.com> Reviewed-by: Bartosz Golaszewski <bgolaszewski@baylibre.com> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2019-05-17Merge tag 's390-5.2-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull more s390 updates from Martin Schwidefsky: - Enhancements for the QDIO layer - Remove the RCP trace event - Avoid three build issues - Move the defconfig to the configs directory * tag 's390-5.2-2' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: s390: move arch/s390/defconfig to arch/s390/configs/defconfig s390/qdio: optimize state inspection of HW-owned SBALs s390/qdio: use get_buf_state() in debug_get_buf_state() s390/qdio: allow to scan all Output SBALs in one go s390/cio: Remove tracing for rchp instruction s390/kasan: adapt disabled_wait usage to avoid build error latent_entropy: avoid build error when plugin cflags are not set s390/boot: fix compiler error due to missing awk strtonum
2019-05-17fbdev/efifb: Ignore framebuffer memmap entries that lack any memory typesArd Biesheuvel
The following commit: 38ac0287b7f4 ("fbdev/efifb: Honour UEFI memory map attributes when mapping the FB") updated the EFI framebuffer code to use memory mappings for the linear framebuffer that are permitted by the memory attributes described by the EFI memory map for the particular region, if the framebuffer happens to be covered by the EFI memory map (which is typically only the case for framebuffers in shared memory). This is required since non-x86 systems may require cacheable attributes for memory mappings that are shared with other masters (such as GPUs), and this information cannot be described by the Graphics Output Protocol (GOP) EFI protocol itself, and so we rely on the EFI memory map for this. As reported by James, this breaks some x86 systems: [ 1.173368] efifb: probing for efifb [ 1.173386] efifb: abort, cannot remap video memory 0x1d5000 @ 0xcf800000 [ 1.173395] Trying to free nonexistent resource <00000000cf800000-00000000cf9d4bff> [ 1.173413] efi-framebuffer: probe of efi-framebuffer.0 failed with error -5 The problem turns out to be that the memory map entry that describes the framebuffer has no memory attributes listed at all, and so we end up with a mem_flags value of 0x0. So work around this by ensuring that the memory map entry's attribute field has a sane value before using it to mask the set of usable attributes. Reported-by: James Hilliard <james.hilliard1@gmail.com> Tested-by: James Hilliard <james.hilliard1@gmail.com> Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Cc: <stable@vger.kernel.org> # v4.19+ Cc: Borislav Petkov <bp@alien8.de> Cc: James Morse <james.morse@arm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Matt Fleming <matt@codeblueprint.co.uk> Cc: Peter Jones <pjones@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-efi@vger.kernel.org Fixes: 38ac0287b7f4 ("fbdev/efifb: Honour UEFI memory map attributes when ...") Link: http://lkml.kernel.org/r/20190516213159.3530-2-ard.biesheuvel@linaro.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2019-05-16tty: Don't force RISCV SBI console as preferred consoleAnup Patel
The Linux kernel will auto-disables all boot consoles whenever it gets a preferred real console. Currently on RISC-V systems, if we have a real console which is not RISCV SBI console then boot consoles (such as earlycon=sbi) are not auto-disabled when a real console (ttyS0 or ttySIF0) is available. This results in duplicate prints at boot-time after kernel starts using real console (i.e. ttyS0 or ttySIF0) if "earlycon=" kernel parameter was passed by bootloader. The reason for above issue is that RISCV SBI console always adds itself as preferred console which is causing other real consoles to be not used as preferred console. Ideally "console=" kernel parameter passed by bootloaders should be the one selecting a preferred real console. This patch fixes above issue by not forcing RISCV SBI console as preferred console. Fixes: afa6b1ccfad5 ("tty: New RISC-V SBI console driver") Cc: stable@vger.kernel.org Signed-off-by: Anup Patel <anup.patel@wdc.com> Reviewed-by: Atish Patra <atish.patra@wdc.com> Signed-off-by: Palmer Dabbelt <palmer@sifive.com>
2019-05-16Merge tag 'for-5.2/block-post-20190516' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull more block updates from Jens Axboe: "This is mainly some late lightnvm changes that came in just before the merge window, as well as fixes that have been queued up since the initial pull request was frozen. This contains: - lightnvm changes, fixing race conditions, improving memory utilization, and improving pblk compatability (Chansol, Igor, Marcin) - NVMe pull request with minor fixes all over the map (via Christoph) - remove redundant error print in sata_rcar (Geert) - struct_size() cleanup (Jackie) - dasd CONFIG_LBADF warning fix (Ming) - brd cond_resched() improvement (Mikulas)" * tag 'for-5.2/block-post-20190516' of git://git.kernel.dk/linux-block: (41 commits) block/bio-integrity: use struct_size() in kmalloc() nvme: validate cntlid during controller initialisation nvme: change locking for the per-subsystem controller list nvme: trace all async notice events nvme: fix typos in nvme status code values nvme-fabrics: remove unused argument nvme-multipath: avoid crash on invalid subsystem cntlid enumeration nvme-fc: use separate work queue to avoid warning nvme-rdma: remove redundant reference between ib_device and tagset nvme-pci: mark expected switch fall-through nvme-pci: add known admin effects to augument admin effects log page nvme-pci: init shadow doorbell after each reset brd: add cond_resched to brd_free_pages sata_rcar: Remove ata_host_alloc() error printing s390/dasd: fix build warning in dasd_eckd_build_cp_raw lightnvm: pblk: use nvm_rq_to_ppa_list() lightnvm: pblk: simplify partial read path lightnvm: do not remove instance under global lock lightnvm: track inflight target creations lightnvm: pblk: recover only written metadata ...
2019-05-16Merge tag 'clk-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux Pull more clk framework updates from Stephen Boyd: "One more patch to remove io.h from clk-provider.h. We used to need this include when we had clk_readl() and clk_writel(), but those are gone now so this patch pushes the dependency out to the users of clk-provider.h" * tag 'clk-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux: clk: Remove io.h from clk-provider.h
2019-05-16Merge tag 'ceph-for-5.2-rc1' of git://github.com/ceph/ceph-clientLinus Torvalds
Pull ceph updates from Ilya Dryomov: "On the filesystem side we have: - a fix to enforce quotas set above the mount point (Luis Henriques) - support for exporting snapshots through NFS (Zheng Yan) - proper statx implementation (Jeff Layton). statx flags are mapped to MDS caps, with AT_STATX_{DONT,FORCE}_SYNC taken into account. - some follow-up dentry name handling fixes, in particular elimination of our hand-rolled helper and the switch to __getname() as suggested by Al (Jeff Layton) - a set of MDS client cleanups in preparation for async MDS requests in the future (Jeff Layton) - a fix to sync the filesystem before remounting (Jeff Layton) On the rbd side, work is on-going on object-map and fast-diff image features" * tag 'ceph-for-5.2-rc1' of git://github.com/ceph/ceph-client: (29 commits) ceph: flush dirty inodes before proceeding with remount ceph: fix unaligned access in ceph_send_cap_releases libceph: make ceph_pr_addr take an struct ceph_entity_addr pointer libceph: fix unaligned accesses in ceph_entity_addr handling rbd: don't assert on writes to snapshots rbd: client_mutex is never nested ceph: print inode number in __caps_issued_mask debugging messages ceph: just call get_session in __ceph_lookup_mds_session ceph: simplify arguments and return semantics of try_get_cap_refs ceph: fix comment over ceph_drop_caps_for_unlink ceph: move wait for mds request into helper function ceph: have ceph_mdsc_do_request call ceph_mdsc_submit_request ceph: after an MDS request, do callback and completions ceph: use pathlen values returned by set_request_path_attr ceph: use __getname/__putname in ceph_mdsc_build_path ceph: use ceph_mdsc_build_path instead of clone_dentry_name ceph: fix potential use-after-free in ceph_mdsc_build_path ceph: dump granular cap info in "caps" debugfs file ceph: make iterate_session_caps a public symbol ceph: fix NULL pointer deref when debugging is enabled ...
2019-05-16Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux Pull thermal management updates from Zhang Rui: - Remove the 'module' Kconfig option for thermal subsystem framework because the thermal framework are required to be ready as early as possible to avoid overheat at boot time (Daniel Lezcano) - Fix a bug that thermal framework pokes disabled thermal zones upon resume (Wei Wang) - A couple of cleanups and trivial fixes on int340x thermal drivers (Srinivas Pandruvada, Zhang Rui, Sumeet Pawnikar) * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux: drivers: thermal: processor_thermal: Downgrade error message mlxsw: Remove obsolete dependency on THERMAL=m hwmon/drivers/core: Simplify complex dependency thermal/drivers/core: Fix typo in the option name thermal/drivers/core: Remove depends on THERMAL in Kconfig thermal/drivers/core: Remove module unload code thermal/drivers/core: Remove the module Kconfig's option thermal: core: skip update disabled thermal zones after suspend thermal: make device_register's type argument const thermal: intel: int340x: processor_thermal_device: simplify to get driver data thermal/int3403_thermal: favor _TMP instead of PTYP
2019-05-16Merge tag 'for-5.2/dm-changes-v2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm Pull device mapper updates from Mike Snitzer: - Improve DM snapshot target's scalability by using finer grained locking. Requires some list_bl interface improvements. - Add ability for DM integrity to use a bitmap mode, that tracks regions where data and metadata are out of sync, instead of using a journal. - Improve DM thin provisioning target to not write metadata changes to disk if the thin-pool and associated thin devices are merely activated but not used. This avoids metadata corruption due to concurrent activation of thin devices across different OS instances (e.g. split brain scenarios, which ultimately would be avoided if proper device filters were used -- but not having proper filtering has proven a very common configuration mistake) - Fix missing call to path selector type->end_io in DM multipath. This fixes reported performance problems due to inaccurate path selector IO accounting causing an imbalance of IO (e.g. avoiding issuing IO to particular path due to it seemingly being heavily used). - Fix bug in DM cache metadata's loading of its discard bitset that could lead to all cache blocks being discarded if the very first cache block was discarded (thankfully in practice the first cache block is generally in use; be it FS superblock, partition table, disk label, etc). - Add testing-only DM dust target which simulates a device that has failing sectors and/or read failures. - Fix a DM init error path reference count hang that caused boot hangs if user supplied malformed input on kernel commandline. - Fix a couple issues with DM crypt target's logging being overly verbose or lacking context. - Various other small fixes to DM init, DM multipath, DM zoned, and DM crypt. * tag 'for-5.2/dm-changes-v2' of git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm: (42 commits) dm: fix a couple brace coding style issues dm crypt: print device name in integrity error message dm crypt: move detailed message into debug level dm ioctl: fix hang in early create error condition dm integrity: whitespace, coding style and dead code cleanup dm integrity: implement synchronous mode for reboot handling dm integrity: handle machine reboot in bitmap mode dm integrity: add a bitmap mode dm integrity: introduce a function add_new_range_and_wait() dm integrity: allow large ranges to be described dm ingerity: pass size to dm_integrity_alloc_page_list() dm integrity: introduce rw_journal_sectors() dm integrity: update documentation dm integrity: don't report unused options dm integrity: don't check null pointer before kvfree and vfree dm integrity: correctly calculate the size of metadata area dm dust: Make dm_dust_init and dm_dust_exit static dm dust: remove redundant unsigned comparison to less than zero dm mpath: always free attached_handler_name in parse_path() dm init: fix max devices/targets checks ...
2019-05-16Merge tag 'media/v5.2-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media fixes from Mauro Carvalho Chehab: "Some fixes for some platform drivers (rockchip, atmel, omap, daVinci, tegra-cec, coda and rcar). Also includes a fix on one of the V4L2 uAPI doc, explaining a border case" * tag 'media/v5.2-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: media: rockchip/vpu: Fix/re-order probe-error/remove path media: rockchip/vpu: Initialize mdev->bus_info media: rockchip/vpu: Get vdev from the file arg in vidioc_querycap() media: rockchip/vpu: Add missing dont_use_autosuspend() calls media: rockchip/vpu: Do not request id 0 for our video device media: tegra-cec: fix cec_notifier_parse_hdmi_phandle return check media: davinci/vpbe: array underflow in vpbe_enum_outputs() media: field-order.rst: clarify FIELD_ANY and FIELD_NONE media: staging/imx: add media device to capture register media: rcar-csi2: Propagate the FLD signal for NTSC and PAL media: rcar-csi2: restart CSI-2 link if error is detected media: omap_vout: potential buffer overflow in vidioc_dqbuf() media: coda: fix unset field and fail on invalid field in buf_prepare media: atmel: atmel-isc: fix asd memory allocation media: atmel: atmel-isc: fix INIT_WORK misplacement media: atmel: atmel-isc: limit incoming pixels per frame
2019-05-16Merge tag 'edac_fixes_for_5.2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp Pull EDAC fixes from Borislav Petkov: - Do not build mpc85_edac as a module (Michael Ellerman) - Correct edac_mc_find()'s return value on error (Robert Richter) * tag 'edac_fixes_for_5.2' of git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp: EDAC/mc: Fix edac_mc_find() in case no device is found EDAC/mpc85xx: Prevent building as a module
2019-05-16Merge tag 'tegra-for-5.2-bus-fixes' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/tegra/linux into arm/late bus/tegra: Fixes for v5.2-rc1 This contains a single fix for a potential PM-related build issue. * tag 'tegra-for-5.2-bus-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tegra/linux: amba: tegra-ahb: Mark PM functions as __maybe_unused Signed-off-by: Olof Johansson <olof@lixom.net>
2019-05-16Merge tag 'soc-fsl-fix-v5.1' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/leo/linux into arm/late NXP/FSL soc driver fixes for v5.1 QE drivers - Fix an error path in qe_pin_request() * tag 'soc-fsl-fix-v5.1' of git://git.kernel.org/pub/scm/linux/kernel/git/leo/linux: soc/fsl/qe: Fix an error code in qe_pin_request() Signed-off-by: Olof Johansson <olof@lixom.net>
2019-05-16soc: ixp4xx: qmgr: Fix an NULL vs IS_ERR() check in probeDan Carpenter
The devm_ioremap_resource() function doesn't retunr NULL, it returns error pointers. Fixes: ecc133c6da60 ("soc: ixp4xx: qmgr: Pass resources") Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2019-05-16Merge tag 'armsoc-drivers' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/soc/soc Pull ARM SoC-related driver updates from Olof Johansson: "Various driver updates for platforms and a couple of the small driver subsystems we merge through our tree: Among the larger pieces: - Power management improvements for TI am335x and am437x (RTC suspend/wake) - Misc new additions for Amlogic (socinfo updates) - ZynqMP FPGA manager - Nvidia improvements for reset/powergate handling - PMIC wrapper for Mediatek MT8516 - Misc fixes/improvements for ARM SCMI, TEE, NXP i.MX SCU drivers" * tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/soc/soc: (57 commits) soc: aspeed: fix Kconfig soc: add aspeed folder and misc drivers spi: zynqmp: Fix build break soc: imx: Add generic i.MX8 SoC driver MAINTAINERS: Update email for Qualcomm SoC maintainer memory: tegra: Fix a typos for "fdcdwr2" mc client Revert "ARM: tegra: Restore memory arbitration on resume from LP1 on Tegra30+" memory: tegra: Replace readl-writel with mc_readl-mc_writel memory: tegra: Fix integer overflow on tick value calculation memory: tegra: Fix missed registers values latching ARM: tegra: cpuidle: Handle tick broadcasting within cpuidle core on Tegra20/30 optee: allow to work without static shared memory soc/tegra: pmc: Move powergate initialisation to probe soc/tegra: pmc: Remove reset sysfs entries on error soc/tegra: pmc: Fix reset sources and levels soc: amlogic: meson-gx-pwrc-vpu: Add support for G12A soc: amlogic: meson-gx-pwrc-vpu: Fix power on/off register bitmask fpga manager: Adding FPGA Manager support for Xilinx zynqmp dt-bindings: fpga: Add bindings for ZynqMP fpga driver firmware: xilinx: Add fpga API's ...
2019-05-16Merge tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/soc/socLinus Torvalds
Pull ARM SoC platform updates from Olof Johansson: "SoC updates, mostly refactorings and cleanups of old legacy platforms. Major themes this release: - Conversion of ixp4xx to a modern platform (drivers, DT, bindings) - Moving some of the ep93xx headers around to get it closer to multiplatform enabled. - Cleanups of Davinci This also contains a few patches that were queued up as fixes before 5.1 but I didn't get sent in before release" * tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/soc/soc: (123 commits) ARM: debug-ll: add default address for digicolor ARM: u300: regulator: add MODULE_LICENSE() ARM: ep93xx: move private headers out of mach/* ARM: ep93xx: move pinctrl interfaces into include/linux/soc ARM: ep93xx: keypad: stop using mach/platform.h ARM: ep93xx: move network platform data to separate header ARM: stm32: add AMBA support for stm32 family MAINTAINERS: update arch/arm/mach-davinci ARM: rockchip: add missing of_node_put in rockchip_smp_prepare_pmu ARM: dts: Add queue manager and NPE to the IXP4xx DTSI soc: ixp4xx: qmgr: Add DT probe code soc: ixp4xx: qmgr: Add DT bindings for IXP4xx qmgr soc: ixp4xx: npe: Add DT probe code soc: ixp4xx: Add DT bindings for IXP4xx NPE soc: ixp4xx: qmgr: Pass resources soc: ixp4xx: Remove unused functions soc: ixp4xx: Uninline several functions soc: ixp4xx: npe: Pass addresses as resources ARM: ixp4xx: Turn the QMGR into a platform device ARM: ixp4xx: Turn the NPE into a platform device ...
2019-05-16Merge branch 'linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/evalenti/linux-soc-thermal Pull thermal soc updates from Eduardo Valentin: - thermal core has a new devm_* API for registering cooling devices. I took the entire series, that is why you see changes on drivers/hwmon in this pull (Guenter Roeck) - rockchip thermal driver gains support to PX30 SoC (Elaine Zhang) - the generic-adc thermal driver now considers the lookup table DT property as optional (Jean-Francois Dagenais) - Refactoring of tsens thermal driver (Amit Kucheria) - Cleanups on cpu cooling driver (Daniel Lezcano) - broadcom thermal driver dropped support to ACPI (Srinath Mannam) - tegra thermal driver gains support to OC hw throttle and GPU throtle (Wei Ni) - Fixes in several thermal drivers. * 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/evalenti/linux-soc-thermal: (59 commits) hwmon: (pwm-fan) Use devm_thermal_of_cooling_device_register hwmon: (npcm750-pwm-fan) Use devm_thermal_of_cooling_device_register hwmon: (mlxreg-fan) Use devm_thermal_of_cooling_device_register hwmon: (gpio-fan) Use devm_thermal_of_cooling_device_register hwmon: (aspeed-pwm-tacho) Use devm_thermal_of_cooling_device_register thermal: rcar_gen3_thermal: Fix to show correct trip points number thermal: rcar_thermal: update calculation formula for R-Car Gen3 SoCs thermal: cpu_cooling: Actually trace CPU load in thermal_power_cpu_get_power thermal: rockchip: Support the PX30 SoC in thermal driver dt-bindings: rockchip-thermal: Support the PX30 SoC compatible thermal: rockchip: fix up the tsadc pinctrl setting error thermal: broadcom: Remove ACPI support thermal: Fix build error of missing devm_ioremap_resource on UM thermal/drivers/cpu_cooling: Remove pointless field thermal/drivers/cpu_cooling: Add Software Package Data Exchange (SPDX) thermal/drivers/cpu_cooling: Fixup the header and copyright thermal/drivers/cpu_cooling: Remove pointless test in power2state() thermal: rcar_gen3_thermal: disable interrupt in .remove thermal: rcar_gen3_thermal: fix interrupt type thermal: Introduce devm_thermal_of_cooling_device_register ...
2019-05-16Merge tag 'drm-next-2019-05-16' of git://anongit.freedesktop.org/drm/drmLinus Torvalds
Pull drm fixes from Dave Airlie: "A bunch of fixes for the merge window closure, doesn't seem to be anything too major or serious in there. It does add TU117 turing modesetting to nouveau but it's just an enable for preexisting code. amdgpu: - gpu reset at load crash fix - ATPX hotplug fix for when dGPU is off - SR-IOV fixes radeon: - r5xx pll fixes i915: - GVT (MCHBAR, buffer alignment, misc warnings fixes) - Fixes for newly enabled semaphore code - Geminilake disable framebuffer compression - HSW edp fast modeset fix - IRQ vs RCU race fix nouveau: - Turing modesetting fixes - TU117 support msm: - SDM845 bringup fixes panfrost: - static checker fixes pl111: - spinlock init fix. bridge: - refresh rate register fix for adv7511" * tag 'drm-next-2019-05-16' of git://anongit.freedesktop.org/drm/drm: (36 commits) drm/msm: Upgrade gxpd checks to IS_ERR_OR_NULL drm/msm/dpu: Remove duplicate header drm/pl111: Initialize clock spinlock early drm/msm: correct attempted NULL pointer dereference in debugfs drm/msm: remove resv fields from msm_gem_object struct drm/nouveau: fix duplication of nv50_head_atom struct drm/nouveau/disp/dp: respect sink limits when selecting failsafe link configuration drm/nouveau/core: initial support for boards with TU117 chipset drm/nouveau/core: allow detected chipset to be overridden drm/nouveau/kms/gf119-gp10x: push HeadSetControlOutputResource() mthd when encoders change drm/nouveau/kms/nv50-: fix bug preventing non-vsync'd page flips drm/nouveau/kms/gv100-: fix spurious window immediate interlocks drm/bridge: adv7511: Fix low refresh rate selection drm/panfrost: Add missing _fini() calls in panfrost_device_fini() drm/panfrost: Only put sync_out if non-NULL drm/i915: Seal races between async GPU cancellation, retirement and signaling drm/i915: Fix fastset vs. pfit on/off on HSW EDP transcoder drm/i915/fbc: disable framebuffer compression on GeminiLake drm/amdgpu/psp: move psp version specific function pointers to early_init drm/radeon: prefer lower reference dividers ...
2019-05-16dm: fix a couple brace coding style issuesSheetal Singala
Signed-off-by: Sheetal Singala <2396sheetal@gmail.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com>
2019-05-16dm crypt: print device name in integrity error messageMilan Broz
This message should better identify the DM device with the integrity failure. Signed-off-by: Milan Broz <gmazyland@gmail.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com>
2019-05-16dm crypt: move detailed message into debug levelMilan Broz
The information about tag size should not be printed without debug info set. Also print device major:minor in the error message to identify the device instance. Also use rate limiting and debug level for info about used crypto API implementaton. This is important because during online reencryption the existing message saturates syslog (because we are moving hotzone across the whole device). Cc: stable@vger.kernel.org Signed-off-by: Milan Broz <gmazyland@gmail.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com>
2019-05-16dm ioctl: fix hang in early create error conditionHelen Koike
The dm_early_create() function (which deals with "dm-mod.create=" kernel command line option) calls dm_hash_insert() who gets an extra reference to the md object. In case of failure, this reference wasn't being released, causing dm_destroy() to hang, thus hanging the whole boot process. Fix this by calling __hash_remove() in the error path. Fixes: 6bbc923dfcf57d ("dm: add support to directly boot to a mapped device") Cc: stable@vger.kernel.org Signed-off-by: Helen Koike <helen.koike@collabora.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com>
2019-05-15Merge branch 'fixes' into arm/socOlof Johansson
Merge in a few pending fixes from pre-5.1 that didn't get sent in: MAINTAINERS: update arch/arm/mach-davinci ARM: dts: ls1021: Fix SGMII PCS link remaining down after PHY disconnect ARM: dts: imx6q-logicpd: Reduce inrush current on USBH1 ARM: dts: imx6q-logicpd: Reduce inrush current on start ARM: dts: imx: Fix the AR803X phy-mode ARM: dts: sun8i: a33: Reintroduce default pinctrl muxing arm64: dts: allwinner: a64: Rename hpvcc-supply to cpvdd-supply ARM: sunxi: fix a leaked reference by adding missing of_node_put ARM: sunxi: fix a leaked reference by adding missing of_node_put Signed-off-by: Olof Johansson <olof@lixom.net>
2019-05-15Merge tag 'libnvdimm-fixes-5.2-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm Pull libnvdimm updates from Dan Williams: "Just a small collection of fixes this time around. The new virtio-pmem driver is nearly ready, but some last minute device-mapper acks and virtio questions made it prudent to await v5.3. Other major topics that were brewing on the linux-nvdimm mailing list like sub-section hotplug, and other devm_memremap_pages() reworks will go upstream through Andrew's tree. Summary: - Fix a long standing namespace label corruption scenario when re-provisioning capacity for a namespace. - Restore the ability of the dax_pmem module to be built-in. - Harden the build for the 'nfit_test' unit test modules so that the userspace test harness can ensure all required test modules are available" * tag 'libnvdimm-fixes-5.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm: drivers/dax: Allow to include DEV_DAX_PMEM as builtin libnvdimm/namespace: Fix label tracking error tools/testing/nvdimm: add watermarks for dax_pmem* modules dax/pmem: Fix whitespace in dax_pmem
2019-05-15Merge tag 'for-v5.2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sre/linux-power-supply Pull power supply and reset updates from Sebastian Reichel: "Core: - Add over-current health state - Add standard, adaptive and custom charge types - Add new properties for start/end charge threshold New Drivers / Hardware: - UCS1002 Programmable USB Port Power Controller - Ingenic JZ47xx Battery Fuel Gauge - AXP20x USB Power: Add AXP813 support - AT91 poweroff: Add SAM9X60 support - OLPC battery: Add XO-1.5 and XO-1.75 support Misc Changes: - syscon-reboot: support mask property - AXP288 fuel gauge: Blacklist ACEPC T8/T11. Looks like some vendor thought it's a good idea to build a desktop system with a fuel gauge, that slowly "discharges"... - cpcap-battery: Fix calculation errors - misc fixes" * tag 'for-v5.2' of git://git.kernel.org/pub/scm/linux/kernel/git/sre/linux-power-supply: (54 commits) power: supply: olpc_battery: force the le/be casts power: supply: ucs1002: Fix build error without CONFIG_REGULATOR power: supply: ucs1002: Fix wrong return value checking power: supply: Add driver for Microchip UCS1002 dt-bindings: power: supply: Add bindings for Microchip UCS1002 power: supply: core: Add POWER_SUPPLY_HEALTH_OVERCURRENT constant power: supply: core: fix clang -Wunsequenced power: supply: core: Add missing documentation for CHARGE_CONTROL_* properties power: supply: core: Add CHARGE_CONTROL_{START_THRESHOLD,END_THRESHOLD} properties power: supply: core: Add Standard, Adaptive, and Custom charge types power: supply: axp288_fuel_gauge: Add ACEPC T8 and T11 mini PCs to the blacklist power: supply: bq27xxx_battery: Notify also about status changes power: supply: olpc_battery: Have the framework register sysfs files for us power: supply: olpc_battery: Add OLPC XO 1.75 support power: supply: olpc_battery: Avoid using platform_info power: supply: olpc_battery: Use devm_power_supply_register() power: supply: olpc_battery: Move priv data to a struct power: supply: olpc_battery: Use DT to get battery version x86/platform/olpc: Use a correct version when making up a battery node x86/platform/olpc: Trivial code move in DT fixup ...
2019-05-15Merge tag 'for-linus-5.2b-rc1-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip Pull xen updates from Juergen Gross: - some minor cleanups - two small corrections for Xen on ARM - two fixes for Xen PVH guest support - a patch for a new command line option to tune virtual timer handling * tag 'for-linus-5.2b-rc1-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: xen/arm: Use p2m entry with lock protection xen/arm: Free p2m entry if fail to add it to RB tree xen/pvh: correctly setup the PV EFI interface for dom0 xen/pvh: set xen_domain_type to HVM in xen_pvh_init xenbus: drop useless LIST_HEAD in xenbus_write_watch() and xenbus_file_write() xen-netfront: mark expected switch fall-through xen: xen-pciback: fix warning Using plain integer as NULL pointer x86/xen: Add "xen_timer_slop" command line option
2019-05-16Merge tag 'drm-misc-next-fixes-2019-05-15' of ↵Dave Airlie
git://anongit.freedesktop.org/drm/drm-misc into drm-next - A couple new panfrost fixes - Fix the low refresh rate register in adv7511 - A handful of msm fixes that fell out of 5.1 bringup on SDM845 - Fix spinlock initialization in pl111 Signed-off-by: Dave Airlie <airlied@redhat.com> From: Sean Paul <sean@poorly.run> Link: https://patchwork.freedesktop.org/patch/msgid/20190515201729.GA89093@art_vandelay
2019-05-16Merge tag 'drm-intel-next-fixes-2019-05-15' of ↵Dave Airlie
git://anongit.freedesktop.org/drm/drm-intel into drm-next - Disable framebuffer compression on Geminilake - Fixes for HSW EDP fastset and a IRQ handler vs. RCU race Signed-off-by: Dave Airlie <airlied@redhat.com> From: Joonas Lahtinen <joonas.lahtinen@linux.intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/20190515074817.GA10472@jlahtine-desk.ger.corp.intel.com
2019-05-15clk: Remove io.h from clk-provider.hStephen Boyd
Now that we've gotten rid of clk_readl() we can remove io.h from the clk-provider header and push out the io.h include to any code that isn't already including the io.h header but using things like readl/writel, etc. Found with this grep: git grep -l clk-provider.h | grep '.c$' | xargs git grep -L 'linux/io.h' | \ xargs git grep -l \ -e '\<__iowrite32_copy\>' --or \ -e '\<__ioread32_copy\>' --or \ -e '\<__iowrite64_copy\>' --or \ -e '\<ioremap_page_range\>' --or \ -e '\<ioremap_huge_init\>' --or \ -e '\<arch_ioremap_pud_supported\>' --or \ -e '\<arch_ioremap_pmd_supported\>' --or \ -e '\<devm_ioport_map\>' --or \ -e '\<devm_ioport_unmap\>' --or \ -e '\<IOMEM_ERR_PTR\>' --or \ -e '\<devm_ioremap\>' --or \ -e '\<devm_ioremap_nocache\>' --or \ -e '\<devm_ioremap_wc\>' --or \ -e '\<devm_iounmap\>' --or \ -e '\<devm_ioremap_release\>' --or \ -e '\<devm_memremap\>' --or \ -e '\<devm_memunmap\>' --or \ -e '\<__devm_memremap_pages\>' --or \ -e '\<pci_remap_cfgspace\>' --or \ -e '\<arch_has_dev_port\>' --or \ -e '\<arch_phys_wc_add\>' --or \ -e '\<arch_phys_wc_del\>' --or \ -e '\<memremap\>' --or \ -e '\<memunmap\>' --or \ -e '\<arch_io_reserve_memtype_wc\>' --or \ -e '\<arch_io_free_memtype_wc\>' --or \ -e '\<__io_aw\>' --or \ -e '\<__io_pbw\>' --or \ -e '\<__io_paw\>' --or \ -e '\<__io_pbr\>' --or \ -e '\<__io_par\>' --or \ -e '\<__raw_readb\>' --or \ -e '\<__raw_readw\>' --or \ -e '\<__raw_readl\>' --or \ -e '\<__raw_readq\>' --or \ -e '\<__raw_writeb\>' --or \ -e '\<__raw_writew\>' --or \ -e '\<__raw_writel\>' --or \ -e '\<__raw_writeq\>' --or \ -e '\<readb\>' --or \ -e '\<readw\>' --or \ -e '\<readl\>' --or \ -e '\<readq\>' --or \ -e '\<writeb\>' --or \ -e '\<writew\>' --or \ -e '\<writel\>' --or \ -e '\<writeq\>' --or \ -e '\<readb_relaxed\>' --or \ -e '\<readw_relaxed\>' --or \ -e '\<readl_relaxed\>' --or \ -e '\<readq_relaxed\>' --or \ -e '\<writeb_relaxed\>' --or \ -e '\<writew_relaxed\>' --or \ -e '\<writel_relaxed\>' --or \ -e '\<writeq_relaxed\>' --or \ -e '\<readsb\>' --or \ -e '\<readsw\>' --or \ -e '\<readsl\>' --or \ -e '\<readsq\>' --or \ -e '\<writesb\>' --or \ -e '\<writesw\>' --or \ -e '\<writesl\>' --or \ -e '\<writesq\>' --or \ -e '\<inb\>' --or \ -e '\<inw\>' --or \ -e '\<inl\>' --or \ -e '\<outb\>' --or \ -e '\<outw\>' --or \ -e '\<outl\>' --or \ -e '\<inb_p\>' --or \ -e '\<inw_p\>' --or \ -e '\<inl_p\>' --or \ -e '\<outb_p\>' --or \ -e '\<outw_p\>' --or \ -e '\<outl_p\>' --or \ -e '\<insb\>' --or \ -e '\<insw\>' --or \ -e '\<insl\>' --or \ -e '\<outsb\>' --or \ -e '\<outsw\>' --or \ -e '\<outsl\>' --or \ -e '\<insb_p\>' --or \ -e '\<insw_p\>' --or \ -e '\<insl_p\>' --or \ -e '\<outsb_p\>' --or \ -e '\<outsw_p\>' --or \ -e '\<outsl_p\>' --or \ -e '\<ioread8\>' --or \ -e '\<ioread16\>' --or \ -e '\<ioread32\>' --or \ -e '\<ioread64\>' --or \ -e '\<iowrite8\>' --or \ -e '\<iowrite16\>' --or \ -e '\<iowrite32\>' --or \ -e '\<iowrite64\>' --or \ -e '\<ioread16be\>' --or \ -e '\<ioread32be\>' --or \ -e '\<ioread64be\>' --or \ -e '\<iowrite16be\>' --or \ -e '\<iowrite32be\>' --or \ -e '\<iowrite64be\>' --or \ -e '\<ioread8_rep\>' --or \ -e '\<ioread16_rep\>' --or \ -e '\<ioread32_rep\>' --or \ -e '\<ioread64_rep\>' --or \ -e '\<iowrite8_rep\>' --or \ -e '\<iowrite16_rep\>' --or \ -e '\<iowrite32_rep\>' --or \ -e '\<iowrite64_rep\>' --or \ -e '\<__io_virt\>' --or \ -e '\<pci_iounmap\>' --or \ -e '\<virt_to_phys\>' --or \ -e '\<phys_to_virt\>' --or \ -e '\<ioremap_uc\>' --or \ -e '\<ioremap\>' --or \ -e '\<__ioremap\>' --or \ -e '\<iounmap\>' --or \ -e '\<ioremap\>' --or \ -e '\<ioremap_nocache\>' --or \ -e '\<ioremap_uc\>' --or \ -e '\<ioremap_wc\>' --or \ -e '\<ioremap_wc\>' --or \ -e '\<ioremap_wt\>' --or \ -e '\<ioport_map\>' --or \ -e '\<ioport_unmap\>' --or \ -e '\<ioport_map\>' --or \ -e '\<ioport_unmap\>' --or \ -e '\<xlate_dev_kmem_ptr\>' --or \ -e '\<xlate_dev_mem_ptr\>' --or \ -e '\<unxlate_dev_mem_ptr\>' --or \ -e '\<virt_to_bus\>' --or \ -e '\<bus_to_virt\>' --or \ -e '\<memset_io\>' --or \ -e '\<memcpy_fromio\>' --or \ -e '\<memcpy_toio\>' I also reordered a couple includes when they weren't alphabetical and removed clk.h from kona, replacing it with clk-provider.h because that driver doesn't use clk consumer APIs. Acked-by: Geert Uytterhoeven <geert+renesas@glider.be> Cc: Chen-Yu Tsai <wens@csie.org> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com> Acked-by: Tero Kristo <t-kristo@ti.com> Acked-by: Sekhar Nori <nsekhar@ti.com> Cc: Krzysztof Kozlowski <krzk@kernel.org> Acked-by: Mark Brown <broonie@kernel.org> Cc: Chris Zankel <chris@zankel.net> Acked-by: Max Filippov <jcmvbkbc@gmail.com> Acked-by: John Crispin <john@phrozen.org> Acked-by: Heiko Stuebner <heiko@sntech.de> Signed-off-by: Stephen Boyd <sboyd@kernel.org>
2019-05-15drm/msm: Upgrade gxpd checks to IS_ERR_OR_NULLSean Paul
dev_pm_domain_attach_by_name() can return NULL, so we should check for that case when we're about to dereference gxpd. Fixes: 9325d4266afd ("drm/msm/gpu: Attach to the GPU GX power domain") Cc: Jordan Crouse <jcrouse@codeaurora.org> Cc: Rob Clark <robdclark@chromium.org> Reviewed-by: Jordan Crouse <jcrouse@codeauorora.org> Signed-off-by: Sean Paul <seanpaul@chromium.org> Link: https://patchwork.freedesktop.org/patch/msgid/20190515170104.155525-1-sean@poorly.run
2019-05-15drm/msm/dpu: Remove duplicate headerSabyasachi Gupta
Remove dpu_kms.h which is included more than once Signed-off-by: Sabyasachi Gupta <sabyasachi.linux@gmail.com> Signed-off-by: Sean Paul <seanpaul@chromium.org> Link: https://patchwork.freedesktop.org/patch/msgid/5cda6de6.1c69fb81.a3ae5.836a@mx.google.com
2019-05-15Merge tag 'acpi-5.2-rc1-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull more ACPI updates from Rafael Wysocki: "These fix two regressions introduced during the 5.0 cycle, in ACPICA and in device PM, cause the values returned by _ADR to be stored in 64 bits and fix two ACPI documentation issues. Specifics: - Update the ACPICA code in the kernel to upstream revision 20190509 including one regression fix: * Prevent excessive ACPI debug messages from being printed by moving the ACPI_DEBUG_DEFAULT definition to the right place (Erik Schmauss). - Set the enable_for_wake bits for wakeup GPEs during suspend to idle to allow acpi_enable_all_wakeup_gpes() to enable them as aproppriate and make wakeup devices sighaling events through ACPI GPEs work with suspend-to-idle again (Rajat Jain). - Use 64 bits to store the return values of _ADR which are assumed to be 64-bit by some bus specs and may contain nonzero bits in the upper 32 bits part for some devices (Pierre-Louis Bossart). - Fix two minor issues with the ACPI documentation (Sakari Ailus)" * tag 'acpi-5.2-rc1-2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: ACPI: PM: Set enable_for_wake for wakeup GPEs during suspend-to-idle Documentation: ACPI: Direct references are allowed to devices only Documentation: ACPI: Use tabs for graph ASL indentation ACPICA: Update version to 20190509 ACPICA: Linux: move ACPI_DEBUG_DEFAULT flag out of ifndef ACPI: bus: change _ADR representation to 64 bits
2019-05-15Merge tag 'pm-5.2-rc1-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull more power management updates from Rafael Wysocki: "These fix a recent regression causing kernels built with CONFIG_PM unset to crash on systems that support the Performance and Energy Bias Hint (EPB), clean up the cpufreq core and some users of transition notifiers and introduce a new power domain flag into the generic power domains framework (genpd). Specifics: - Fix recent regression causing kernels built with CONFIG_PM unset to crash on systems that support the Performance and Energy Bias Hint (EPB) by avoiding to compile the EPB-related code depending on CONFIG_PM when it is unset (Rafael Wysocki). - Clean up the transition notifier invocation code in the cpufreq core and change some users of cpufreq transition notifiers accordingly (Viresh Kumar). - Change MAINTAINERS to cover the schedutil governor as part of cpufreq (Viresh Kumar). - Simplify cpufreq_init_policy() to avoid redundant computations (Yue Hu). - Add explanatory comment to the cpufreq core (Rafael Wysocki). - Introduce a new flag, GENPD_FLAG_RPM_ALWAYS_ON, to the generic power domains (genpd) framework along with the first user of it (Leonard Crestez)" * tag 'pm-5.2-rc1-2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: soc: imx: gpc: Use GENPD_FLAG_RPM_ALWAYS_ON for ERR009619 PM / Domains: Add GENPD_FLAG_RPM_ALWAYS_ON flag cpufreq: Update MAINTAINERS to include schedutil governor cpufreq: Don't find governor for setpolicy drivers in cpufreq_init_policy() cpufreq: Explain the kobject_put() in cpufreq_policy_alloc() cpufreq: Call transition notifier only once for each policy x86: intel_epb: Take CONFIG_PM into account
2019-05-15Merge branch 'linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6 Pull crypto fixes from Herbert Xu: "This fixes a number of issues in the chelsio and caam drivers" * 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: Revert "crypto: caam/jr - Remove extra memory barrier during job ring dequeue" crypto: caam - fix caam_dump_sg that iterates through scatterlist crypto: caam - fix DKP detection logic MAINTAINERS: Maintainer for Chelsio crypto driver crypto: chelsio - count incomplete block in IV crypto: chelsio - Fix softlockup with heavy I/O crypto: chelsio - Fix NULL pointer dereference
2019-05-15media: rockchip/vpu: Fix/re-order probe-error/remove pathJonas Karlman
media_device_cleanup() and v4l2_m2m_unregister_media_controller() were missing in the probe error path. While at it, re-order calls in the remove path to unregister/cleanup things in the reverse order they were initialized/registered. Signed-off-by: Jonas Karlman <jonas@kwiboo.se> Signed-off-by: Boris Brezillon <boris.brezillon@collabora.com> Signed-off-by: Hans Verkuil <hverkuil-cisco@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
2019-05-15media: rockchip/vpu: Initialize mdev->bus_infoBoris Brezillon
v4l2-compliance complains that ->bus_info is empty. Signed-off-by: Boris Brezillon <boris.brezillon@collabora.com> Signed-off-by: Hans Verkuil <hverkuil-cisco@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
2019-05-15media: rockchip/vpu: Get vdev from the file arg in vidioc_querycap()Boris Brezillon
This makes the function more generic so it can easily be re-used when adding support for the decoding functionality. Signed-off-by: Boris Brezillon <boris.brezillon@collabora.com> Signed-off-by: Hans Verkuil <hverkuil-cisco@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
2019-05-15media: rockchip/vpu: Add missing dont_use_autosuspend() callsJonas Karlman
Those calls are needed to restore a clean PM state when the probe fails or when the driver is unloaded such that future ->probe() calls can initialize runtime PM again. Signed-off-by: Jonas Karlman <jonas@kwiboo.se> Signed-off-by: Boris Brezillon <boris.brezillon@collabora.com> Signed-off-by: Hans Verkuil <hverkuil-cisco@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
