cf and cf->mem_base have been allocated at the point of this failure, so
they should be freed before leaving the function.
[linux@dominikbrodowski.net: limit call to device_init_wakeup() to the
same error paths as before]
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
Signed-off-by: Jim Cromie <jim.cromie@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm
Pull device-mapper fixes from Mike Snitzer:
"Quite a few fixes for DM's blk-mq support thanks to extra DM multipath
testing from Junichi Nomura and Bart Van Assche.
Also fix a casting bug in dm_merge_bvec() that could cause only a
single page to be added to a bio (Joe identified this while testing
dm-cache writeback)"
* tag 'dm-4.1-fixes-3' of git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm:
dm: fix casting bug in dm_merge_bvec()
dm: fix reload failure of 0 path multipath mapping on blk-mq devices
dm: fix false warning in free_rq_clone() for unmapped requests
dm: requeue from blk-mq dm_mq_queue_rq() using BLK_MQ_RQ_QUEUE_BUSY
dm mpath: fix leak of dm_mpath_io structure in blk-mq .queue_rq error path
dm: fix NULL pointer when clone_and_map_rq returns !DM_MAPIO_REMAPPED
dm: run queue on re-queue
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull fixes for cpumask and modules from Rusty Russell:
"** NOW WITH TESTING! **
Two fixes which got lost in my recent distraction. One is a weird
cpumask function which needed to be rewritten, the other is a module
bug which is cc:stable"
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
cpumask_set_cpu_local_first => cpumask_local_spread, lament
module: Call module notifier on failure after complete_formation()
Pull drm fixes from Dave Airlie:
"This is made up 4 groups of fixes detailed below.
vgem:
Due to some misgivings about possible bad use cases this allow,
backout a chunk of the interface to stop those use cases for now.
radeon:
Fix for an oops regression in the audio code, and a partial revert
for a fix that was cauing problems.
nouveau:
regression fix for Fermi, and display-less Maxwell boot fixes.
drm core:
a fix for i915 cursor vblank waiting in the atomic helpers"
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux:
drm/nouveau/gr/gm204: remove a stray printk
drm/nouveau/devinit/gm100-: force devinit table execution on boards without PDISP
drm/nouveau/devinit/gf100: make the force-post condition more obvious
drm/nouveau/gr/gf100-: fix wrong constant definition
drm/radeon: partially revert "fix VM_CONTEXT*_PAGE_TABLE_END_ADDR handling"
drm/radeon/audio: make sure connector is valid in hotplug case
Revert "drm/radeon: only mark audio as connected if the monitor supports it (v3)"
drm/radeon: don't share plls if monitors differ in audio support
drm/vgem: drop DRIVER_PRIME (v2)
drm/plane-helper: Adapt cursor hack to transitional helpers
dm_merge_bvec() was originally added in f6fccb ("dm: introduce
merge_bvec_fn"). In that commit a value in sectors is converted to
bytes using << 9, and then assigned to an int. This code made
assumptions about the value of BIO_MAX_SECTORS.
A later commit 148e51 ("dm: improve documentation and code clarity in
dm_merge_bvec") was meant to have no functional change but it removed
the use of BIO_MAX_SECTORS in favor of using queue_max_sectors(). At
this point the cast from sector_t to int resulted in a zero value. The
fallout being dm_merge_bvec() would only allow a single page to be added
to a bio.
This interim fix is minimal for the benefit of stable@ because the more
comprehensive cleanup of passing a sector_t to all DM targets' merge
function will impact quite a few DM targets.
Signed-off-by: Joe Thornber <ejt@redhat.com>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Cc: stable@vger.kernel.org # 3.19+
dm-multipath accepts 0 path mapping.
# echo '0 2097152 multipath 0 0 0 0' | dmsetup create newdev
Such a mapping can be used to release underlying devices while still
holding requests in its queue until working paths come back.
However, once the multipath device is created over blk-mq devices,
it rejects reloading of 0 path mapping:
# echo '0 2097152 multipath 0 0 1 1 queue-length 0 1 1 /dev/sda 1' \
| dmsetup create mpath1
# echo '0 2097152 multipath 0 0 0 0' | dmsetup load mpath1
device-mapper: reload ioctl on mpath1 failed: Invalid argument
Command failed
With following kernel message:
device-mapper: ioctl: can't change device type after initial table load.
DM tries to inherit the current table type using dm_table_set_type()
but it doesn't work as expected because of unnecessary check about
whether the target type is hybrid or not.
Hybrid type is for targets that work as either request-based or bio-based
and not required for blk-mq or non blk-mq checking.
Fixes: 65803c205983 ("dm table: train hybrid target type detection to select blk-mq if appropriate")
Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com>
Pull m,ore md bugfixes gfrom Neil Brown:
"Assorted fixes for new RAID5 stripe-batching functionality.
Unfortunately this functionality was merged a little prematurely. The
necessary testing and code review is now complete (or as complete as
it can be) and to code passes a variety of tests and looks quite
sensible.
Also a fix for some recent locking changes - a race was introduced
which causes a reshape request to sometimes fail. No data safety
issues"
* tag 'md/4.1-rc5-fixes' of git://neil.brown.name/md:
md: fix race when unfreezing sync_action
md/raid5: break stripe-batches when the array has failed.
md/raid5: call break_stripe_batch_list from handle_stripe_clean_event
md/raid5: be more selective about distributing flags across batch.
md/raid5: add handle_flags arg to break_stripe_batch_list.
md/raid5: duplicate some more handle_stripe_clean_event code in break_stripe_batch_list
md/raid5: remove condition test from check_break_stripe_batch_list.
md/raid5: Ensure a batch member is not handled prematurely.
md/raid5: close race between STRIPE_BIT_DELAY and batching.
md/raid5: ensure whole batch is delayed for all required bitmap updates.
When stacking request-based dm device on non blk-mq device and
device-mapper target could not map the request (error target is used,
multipath target with all paths down, etc), the WARN_ON_ONCE() in
free_rq_clone() will trigger when it shouldn't.
The warning was added by commit aa6df8d ("dm: fix free_rq_clone() NULL
pointer when requeueing unmapped request"). But free_rq_clone() with
clone->q == NULL is valid usage for the case where
dm_kill_unmapped_request() initiates request cleanup.
Fix this false warning by just removing the WARN_ON -- it only generated
false positives and was never useful in catching the intended case
(completing clone request not being mapped e.g. clone->q being NULL).
Fixes: aa6df8d ("dm: fix free_rq_clone() NULL pointer when requeueing unmapped request")
Reported-by: Bart Van Assche <bart.vanassche@sandisk.com>
Reported-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com>
git://anongit.freedesktop.org/git/nouveau/linux-2.6 into drm-fixes
Regression fix for Fermi acceleration, and fixes important to bringing
up display-less Maxwell boards.
* 'linux-4.1' of git://anongit.freedesktop.org/git/nouveau/linux-2.6:
Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
PDISP
Should fix fdo#89558
And also more generic, so it can be used on newer chipsets.
Commit 3740c82590d8 ("drm/nouveau/gr/gf100-: add symbolic names for
classes") introduced a wrong macro definition causing acceleration setup
to fail. Fix it.
Signed-off-by: Lars Seipel <ls@slrz.net>
Fixes: 3740c82590d8 ("drm/nouveau/gr/gf100-: add symbolic names for classes")
git://git.infradead.org/users/dvhart/linux-platform-drivers-x86
Pull x86 platform driver fix from Darren Hart:
"thinkpad_acpi: Revert unintentional device attribute renaming"
* tag 'platform-drivers-x86-v4.1-3' of git://git.infradead.org/users/dvhart/linux-platform-drivers-x86:
We have that bug for years and some users report side effects when fixing it on older hardware.
So revert it for VM_CONTEXT0_PAGE_TABLE_END_ADDR, but keep it for VM 1-15.
Signed-off-by: Christian König <christian.koenig@amd.com>
CC: stable@vger.kernel.org
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
A recent change removed the need for locking around writing
to "sync_action" (and various other places), but introduced a
subtle race.
When e.g. setting 'reshape' on a 'frozen' array, the 'frozen'
flag is cleared before 'reshape' is set, so the md thread can
get in and start trying recovery - which isn't wanted.
So instead of clearing MD_RECOVERY_FROZEN for any command
except 'frozen', only clear it when each specific command
is parsed. This allows the handling of 'reshape' to clear
the bit while a lock is held.
Also remove some places where we set MD_RECOVERY_NEEDED,
as it is always set on non-error exit of the function.
Signed-off-by: NeilBrown <neilb@suse.de>
Fixes: 6791875e2e53 ("md: make reconfig_mutex optional for writes to md sysfs files.")
Once the array has too much failure, we need to break
stripe-batches up so they can all be dealt with.
Now that the code in break_stripe_batch_list() is nearly identical
to the end of handle_stripe_clean_event, replace the later
with a function call.
The only remaining difference of any interest is the masking that is
applieds to dev[i].flags copied from head_sh.
R5_WriteError certainly isn't wanted as it is set per-stripe, not
per-patch. R5_Overlap isn't wanted as it is explicitly handled.
When a batch of stripes is broken up, we keep some of the flags
that were per-stripe, and copy other flags from the head to all
others.
This only happens while a stripe is being handled, so many of the
flags are irrelevant.
The "SYNC_FLAGS" (which I've renamed to make it clear there are
several) and STRIPE_DEGRADED are set per-stripe and so need to be
preserved. STRIPE_INSYNC is the only flag that is set on the head
that needs to be propagated to all others.
For safety, add a WARN_ON if others are set, except:
STRIPE_HANDLE - this is safe and per-stripe and we are going to set
in several cases anyway
STRIPE_INSYNC
STRIPE_IO_STARTED - this is just a hint and doesn't hurt.
STRIPE_ON_PLUG_LIST
STRIPE_ON_RELEASE_LIST - It is a point pointless for a batched
stripe to be on one of these lists, but it can happen
as can be safely ignored.
When we break a stripe_batch_list we sometimes want to set
STRIPE_HANDLE on the individual stripes, and sometimes not.
So pass a 'handle_flags' arg. If it is zero, always set STRIPE_HANDLE
(on non-head stripes). If not zero, only set it if any of the given
flags are present.
break_stripe_batch list didn't clear head_sh->batch_head.
This was probably a bug.
Also clear all R5_Overlap flags and if any were cleared, wake up
'wait_for_overlap'.
This isn't always necessary but the worst effect is a little
extra checking for code that is waiting on wait_for_overlap.
Also, don't use wake_up_nr() because that does the wrong thing
if 'nr' is zero, and it number of flags cleared doesn't
strongly correlate with the number of threads to wake.
handle_stripe_clean_event() contains a chunk of code very
similar to check_break_stripe_batch_list().
If we make the latter more like the former, we can end up
with just one copy of this code.
This first step removed the condition (and the 'check_') part
of the name. This has the added advantage of making it clear
what check is being performed at the point where the function is
called.
If a stripe is a member of a batch, but not the head, it must
not be handled separately from the rest of the batch.
'clear_batch_ready()' handles this requirement to some
extent but not completely. If a member is passed to handle_stripe()
a second time it returns '0' indicating the stripe can be handled,
which is wrong.
So add an extra test.
da91309e0a7e (cpumask: Utility function to set n'th cpu...) created a
genuinely weird function. I never saw it before, it went through DaveM.
(He only does this to make us other maintainers feel better about our own
mistakes.)
cpumask_set_cpu_local_first's purpose is say "I need to spread things
across N online cpus, choose the ones on this numa node first"; you call
it in a loop.
It can fail. One of the two callers ignores this, the other aborts and
fails the device open.
It can fail in two ways: allocating the off-stack cpumask, or through a
convoluted codepath which AFAICT can only occur if cpu_online_mask
changes. Which shouldn't happen, because if cpu_online_mask can change
while you call this, it could return a now-offline cpu anyway.
It contains a nonsensical test "!cpumask_of_node(numa_node)". This was
drawn to my attention by Geert, who said this causes a warning on Sparc.
It sets a single bit in a cpumask instead of returning a cpu number,
because that's what the callers want.
It could be made more efficient by passing the previous cpu rather than
an index, but that would be more invasive to the callers.
Fixes: da91309e0a7e8966d916a74cce42ed170fde06bf
Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (then rebased)
Tested-by: Amir Vadai <amirv@mellanox.com>
Acked-by: Amir Vadai <amirv@mellanox.com>
When we add a write to a stripe we need to make sure the bitmap
bit is set. While doing that the stripe is not locked so it could
be added to a batch after which further changes to STRIPE_BIT_DELAY
and ->bm_seq are ineffective.
So we need to hold off adding to a stripe until bitmap_startwrite has
completed at least once, and we need to avoid further changes to
STRIPE_BIT_DELAY once the stripe has been added to a batch.
If a bitmap_startwrite() completes after the stripe was added to a
batch, it will not have set the bit, only incremented a counter, so no
extra delay of the stripe is needed.
Reported-by: Shaohua Li <shli@kernel.org>
When we add a stripe to a batch, we need to be sure that
head stripe will wait for the bitmap update required for the new
stripe.
git://anongit.freedesktop.org/drm-intel into drm-fixes
here's a drm regression fix for drivers only partially
converted to atomic.
* tag 'topic/drm-fixes-2015-05-27' of git://anongit.freedesktop.org/drm-intel:
Use BLK_MQ_RQ_QUEUE_BUSY to requeue a blk-mq request directly from the
DM blk-mq device's .queue_rq. This cleans up the previous convoluted
handling of request requeueing that would return BLK_MQ_RQ_QUEUE_OK
(even though it wasn't) and then run blk_mq_requeue_request() followed
by blk_mq_kick_requeue_list().
Also, document that DM blk-mq ontop of old request_fn devices cannot
fail in clone_rq() since the clone request is preallocated as part of
the pdu.
Reported-by: Christoph Hellwig <hch@lst.de>
Otherwise kmemleak reported:
unreferenced object 0xffff88009b14e2b0 (size 16):
comm "fio", pid 4274, jiffies 4294978034 (age 1253.210s)
hex dump (first 16 bytes):
40 12 f3 99 01 88 ff ff 00 10 00 00 00 00 00 00 @...............
backtrace:
[<ffffffff81600029>] kmemleak_alloc+0x49/0xb0
[<ffffffff811679a8>] kmem_cache_alloc+0xf8/0x160
[<ffffffff8111c950>] mempool_alloc_slab+0x10/0x20
[<ffffffff8111cb37>] mempool_alloc+0x57/0x150
[<ffffffffa04d2b61>] __multipath_map.isra.17+0xe1/0x220 [dm_multipath]
[<ffffffffa04d2cb5>] multipath_clone_and_map+0x15/0x20 [dm_multipath]
[<ffffffffa02889b5>] map_request.isra.39+0xd5/0x220 [dm_mod]
[<ffffffffa028b0e4>] dm_mq_queue_rq+0x134/0x240 [dm_mod]
[<ffffffff812cccb5>] __blk_mq_run_hw_queue+0x1d5/0x380
[<ffffffff812ccaa5>] blk_mq_run_hw_queue+0xc5/0x100
[<ffffffff812ce350>] blk_sq_make_request+0x240/0x300
[<ffffffff812c0f30>] generic_make_request+0xc0/0x110
[<ffffffff812c0ff2>] submit_bio+0x72/0x150
[<ffffffff811c07cb>] do_blockdev_direct_IO+0x1f3b/0x2da0
[<ffffffff811c166e>] __blockdev_direct_IO+0x3e/0x40
[<ffffffff8120aa1a>] ext4_direct_IO+0x1aa/0x390
Fixes: e5863d9ad ("dm: allocate requests in target when stacking on blk-mq devices")
Cc: stable@vger.kernel.org # 4.0+
Pull networking fixes from David Miller:
1) Don't use MMIO on certain iwlwifi devices otherwise we get a
firmware crash.
2) Don't corrupt the GRO lists of mac80211 contexts by doing sends via
timer interrupt, from Johannes Berg.
3) SKB tailroom is miscalculated in AP_VLAN crypto code, from Michal
Kazior.
4) Fix fw_status memory leak in iwlwifi, from Haim Dreyfuss.
5) Fix use after free in iwl_mvm_d0i3_enable_tx(), from Eliad Peller.
6) JIT'ing of large BPF programs is broken on x86, from Alexei
Starovoitov.
7) EMAC driver ethtool register dump size is miscalculated, from Ivan
Mikhaylov.
8) Fix PHY initial link mode when autonegotiation is disabled in
amd-xgbe, from Tom Lendacky.
9) Fix NULL deref on SOCK_DEAD socket in AF_UNIX and CAIF protocols,
from Mark Salyzyn.
10) credit_bytes not initialized properly in xen-netback, from Ross
Lagerwall.
11) Fallback from MSI-X to INTx interrupts not handled properly in mlx4
driver, fix from Benjamin Poirier.
12) Perform ->attach() after binding dev->qdisc in packet scheduler,
otherwise we can crash. From Cong WANG.
13) Don't clobber data in sctp_v4_map_v6(). From Jason Gunthorpe.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (30 commits)
sctp: Fix mangled IPv4 addresses on a IPv6 listening socket
net_sched: invoke ->attach() after setting dev->qdisc
xen-netfront: properly destroy queues when removing device
mlx4_core: Fix fallback from MSI-X to INTx
xen/netback: Properly initialize credit_bytes
net: netxen: correct sysfs bin attribute return code
tools: bpf_jit_disasm: fix segfault on disabled debugging log output
unix/caif: sk_socket can disappear when state is unlocked
amd-xgbe-phy: Fix initial mode when autoneg is disabled
net: dp83640: fix improper double spin locking.
net: dp83640: reinforce locking rules.
net: dp83640: fix broken calibration routine.
net: stmmac: create one debugfs dir per net-device
net/ibm/emac: fix size of emac dump memory areas
x86: bpf_jit: fix compilation of large bpf programs
net: phy: bcm7xxx: Fix 7425 PHY ID and flags
iwlwifi: mvm: avoid use-after-free on iwl_mvm_d0i3_enable_tx()
iwlwifi: mvm: clean net-detect info if device was reset during suspend
iwlwifi: mvm: take the UCODE_DOWN reference when resuming
iwlwifi: mvm: BT Coex - duplicate the command if sent ASYNC
xennet_remove() freed the queues before freeing the netdevice which
results in a use-after-free when free_netdev() tries to delete the
napi instances that have already been freed.
Fix this by fully destroy the queues (which includes deleting the napi
instances) before freeing the netdevice.
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Avoids a crash when a monitor is hotplugged and the encoder
and connector are not linked yet.
bug:
https://bugs.freedesktop.org/show_bug.cgi?id=90681
The test in mlx4_load_one() to remove MLX4_FLAG_MSI_X expects mlx4_NOP() to
fail with -EBUSY. It is also necessary to avoid the reset since the device
is not fully reinitialized before calling mlx4_start_hca() a second time.
Note that this will also affect mlx4_test_interrupts(), the only other user
of MLX4_CMD_NOP.
Fixes: f5aef5a ("net/mlx4_core: Activate reset flow upon fatal command cases")
Signed-off-by: Benjamin Poirier <bpoirier@suse.de>
This bug has been there since day 1; addresses in the top guest physical
page weren't considered valid. You could map that page (the check in
check_gpte() is correct), but if a guest tried to put a pagetable there
we'd check that address manually when walking it, and kill the guest.
Cc: stable@kernel.org
Commit e9ce7cb6b107 ("xen-netback: Factor queue-specific data into queue
struct") introduced a regression when moving queue-specific data into
the queue struct by failing to set the credit_bytes field. This
prevented bandwidth limiting from working. Initialize the field as it
was done before multiqueue support was added.
Signed-off-by: Ross Lagerwall <ross.lagerwall@citrix.com>
Acked-by: Wei Liu <wei.liu2@citrix.com>
(v3)"
This breaks too many things.
bugs:
https://bugzilla.kernel.org/show_bug.cgi?id=99041
This reverts commit 0f55db36d49d45b80eff0c0a2a498766016f458b.
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd
Pull an MFD fix from Lee Jones:
"One simple fix to repair broken regulator probe() in DA9052"
* tag 'mfd-fixes-4.1' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd:
mfd: da9052: Fix broken regulator probe
git://git.kernel.org/pub/scm/linux/kernel/git/lee/backlight
Pull backlight fix from Lee Jones:
"One simple fix to correctly handle -EPROBE_DEFER"
* tag 'backlight-fixes-4.1' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/backlight:
backlight: pwm: Handle EPROBE_DEFER while requesting the PWM
When stacking request-based DM on blk_mq device, request cloning and
remapping are done in a single call to target's clone_and_map_rq().
The clone is allocated and valid only if clone_and_map_rq() returns
DM_MAPIO_REMAPPED.
The "IS_ERR(clone)" check in map_request() does not cover all the
!DM_MAPIO_REMAPPED cases that are possible (E.g. if underlying devices
are not ready or unavailable, clone_and_map_rq() may return
DM_MAPIO_REQUEUE without ever having established an ERR_PTR). Fix this
by explicitly checking for a return that is not DM_MAPIO_REMAPPED in
map_request().
Without this fix, DM core may call setup_clone() for a NULL clone
and oops like this:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000068
IP: [<ffffffff81227525>] blk_rq_prep_clone+0x7d/0x137
CPU: 2 PID: 5793 Comm: kdmwork-253:3 Not tainted 4.0.0-nm #1
Call Trace:
[<ffffffffa01d1c09>] map_tio_request+0xa9/0x258 [dm_mod]
[<ffffffff81071de9>] kthread_worker_fn+0xfd/0x150
[<ffffffff81071cec>] ? kthread_parkme+0x24/0x24
[<ffffffff81071fdd>] kthread+0xe6/0xee
[<ffffffff81093a59>] ? put_lock_stats+0xe/0x20
[<ffffffff81071ef7>] ? __init_kthread_worker+0x5b/0x5b
[<ffffffff814c2d98>] ret_from_fork+0x58/0x90
Fix broken probe of da9052 regulators, which since commit b3f6c73db732
("mfd: da9052-core: Fix platform-device id collision") use a
non-deterministic platform-device id to retrieve static regulator
information. Fortunately, adequate error handling was in place so probe
would simply fail with an error message.
Update the mfd-cell ids to be zero-based and use those to identify the
cells when probing the regulator devices.
Fixes: b3f6c73db732 ("mfd: da9052-core: Fix platform-device id collision")
Cc: stable <stable@vger.kernel.org> # v3.19
Signed-off-by: Johan Hovold <johan@kernel.org>
Acked-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Reviewed-by: Mark Brown <broonie@kernel.org>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
If read() syscall requests unexpected number of bytes from "dimm" binary
attribute file, return EINVAL instead of EPERM.
At the same time pin down sysfs file size to the fixed
sizeof(struct netxen_dimm_cfg), which allows to exploit some missing
sanity checks from kernfs (file boundary checks vs offset etc.)
Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
Enabling audio may enable different pll dividers. Don't share
plls if the monitors differ in audio support.
bug:
https://bugzilla.kernel.org/show_bug.cgi?id=98751
When the ethtool command is used to set the speed of the device while
the device is down, the check to set the initial mode may fail when
the device is brought up, causing failure to bring the device up.
Update the code to set the initial mode based on the desired speed if
auto-negotiation is disabled.
This patch fixes a bug introduced by:
d9663c8c2149 ("amd-xgbe-phy: Use phydev advertising field vs supported")
Signed-off-by: Tom Lendacky <thomas.lendacky@amd.com>
Without kicking queue, requeued request may stay forever in
the queue if there are no other I/O activities to the device.
The original error had been in v2.6.39 with commit 7eaceaccab5f
("block: remove per-queue plugging"), which replaced conditional
plugging by periodic runqueue.
Commit 9d1deb83d489 in v4.1-rc1 removed the periodic runqueue
and the problem started to manifest.
Fixes: 9d1deb83d489 ("dm: don't schedule delayed run of the queue if nothing to do")
When trying to request the PWM device with devm_pwm_get(), the EPROBE_DEFER
flag is not handled properly. It can lead to the PWM not being found.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Acked-by: Thierry Reding <thierry.reding@gmail.com>
For actual sharing of buffers with other drivers (ie. actual hardware)
we'll need to pimp things out a bit better to deal w/ caching, multiple
memory domains, etc. See thread:
http://lists.freedesktop.org/archives/dri-devel/2015-May/083160.html
But for the llvmpipe use-case this isn't a problem. Nor do we really
need prime/dri3 (dri2 is sufficient). So until the other issues are
sorted lets remove DRIVER_PRIME.
v2: also drop the dead code
[airlied:
Okay I'm convinced this API could have a lot of use cases
that are really really bad, yes the upload use case is valid
however that isn't the only use case enabled, and if we allow
all the other use cases, people will start to (ab)use them,
and then they'll be ABI and my life will get worse, so disable
PRIME for now]
Acked-by: Thomas Hellstrom <thellstrom@vmware.com>
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Signed-off-by: Rob Clark <robdclark@gmail.com>
A pair of nested spin locks was introduced in commit 63502b8d0
"dp83640: Fix receive timestamp race condition".
Unfortunately the 'flags' parameter was reused for the inner lock,
clobbering the originally saved IRQ state. This patch fixes the issue
by changing the inner lock to plain spin_lock without irqsave.
Signed-off-by: Richard Cochran <richardcochran@gmail.com>
Callers of the ext_write function are supposed to hold a mutex that
protects the state of the dialed page, but one caller was missing the
lock from the very start, and over time the code has been changed
without following the rule. This patch cleans up the call sites in
violation of the rule.
Currently, the calibration function that corrects the initial offsets
among multiple devices only works the first time. If the function is
called more than once, the calibration fails and bogus offsets will be
programmed into the devices.
In a well hidden spot, the device documentation tells that trigger indexes
0 and 1 are special in allowing the TRIG_IF_LATE flag to actually work.
This patch fixes the issue by using one of the special triggers during the
recalibration method.
