commit 5b479a076de091590423a9e6dfc2584126b28761 upstream.
My previous change added in:
commit 815833e7ecf0b9a017315cae6aef4d7cd9517681
ath9k: fix tx status reporting
was not checking all possible tx error conditions. This could possibly
lead to throughput issues due to slow rate control adaption or missed
retransmissions of failed A-MPDU frames.
This patch adds a mask for all possible error conditions and uses it
in the xmit ok check.
Reported-by: Björn Smedman <bjorn.smedman@venatech.se>
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
commit e8009e9850d59000d518296af372888911a129bd upstream.
When TX DMA termination has failed, the HW has to be reset
completely. Doing a fast channel change in this case is insufficient.
Also, change the debug level of a couple of messages to FATAL.
Signed-off-by: Sujith <Sujith.Manoharan@atheros.com>
commit 5f70a88f631c3480107853cae12925185eb4c598 upstream.
When we remove a IBSS/AP/Mesh interface we stop DMA
but to do this we should ensure hardware is on. Awaken
the device prior to these calls. This should ensure
DMA is stopped upon suspend and plain device removal.
Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com>
commit 242ab7ad689accafd5e87ffd22b85cf1bf7fbbef upstream.
The calibration period is now invoked by triggering a software
interrupt from within the ISR by ath5k_hw_calibration_poll()
instead of via a timer.
However, the calibration interval isn't initialized before
interrupts are enabled, so we can have a situation where an
interrupt occurs before the interval is assigned, so the
interval is actually negative. As a result, the ISR will
arm a software interrupt to schedule the tasklet, and then
rearm it when the SWI is processed, and so on, leading to a
softlockup at modprobe time.
Move the initialization order around so the calibration interval
is set before interrupts are active. Another possible fix
is to schedule the tasklet directly from the poll routine,
but I think there are additional plans for the SWI.
Signed-off-by: Bob Copeland <me@bobcopeland.com>
commit 6c853da3f30c93eae847ecbcd9fdf10ba0da04c2 upstream.
Allocate priv->rx_packets[IWM_RX_ID_HASH + 1] because the max array
index is IWM_RX_ID_HASH according to IWM_RX_ID_GET_HASH().
Signed-off-by: Zhu Yi <yi.zhu@intel.com>
commit 45b241689179a6065384260242637cf21dabfb2d upstream.
The libertas driver copies the SSID buffer back to the wireless core and
appends a trailing NULL character for termination. This is
a) unnecessary because the buffer is allocated with kzalloc and is hence
already NULLed when this function is called, and
b) for priv->curbssparams.ssid_len == 32, it writes back one byte too
much which causes memory corruptions.
Fix this by removing the extra write.
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Cc: Stephen Hemminger <shemminger@vyatta.com>
Cc: Maithili Hinge <maithili@marvell.com>
Cc: Kiran Divekar <dkiran@marvell.com>
Cc: Michael Hirsch <m.hirsch@raumfeld.com>
Cc: netdev@vger.kernel.org
Cc: libertas-dev@lists.infradead.org
Cc: linux-wireless@lists.infradead.org
Acked-by: Holger Schurig <holgerschurig@gmail.com>
Acked-by: Dan Williams <dcbw@redhat.com>
commit a6d52d70677e99bdb89b6921c265d0a58c22e597 upstream.
Put the ioat2 and ioat3 state machines in the halted state with all
errors cleared.
The ioat1 init path is not disturbed for stability, there are no
reported ioat1 initiaization issues.
Reported-by: Roland Dreier <rdreier@cisco.com>
Tested-by: Roland Dreier <rdreier@cisco.com>
Acked-by: Simon Horman <horms@verge.net.au>
commit cd78809f6191485a90ea6c92c2b58900ab5c156f upstream.
When continuing a pq calculation the driver needs 3 extra sources. The
driver can perform a 3 source calculation with a single descriptor, but
needs an extended descriptor to process up to 8 sources in one
operation. However, in the p-disabled case only one extra source is
needed. When continuing a p-disabled operation there are occasions
(i.e. 0 < src_cnt % 8 < 3) where the tail operation does not need an
extended descriptor. Properly account for this fact otherwise invalid
'dmacount' values will be written to hardware usually causing the
channel to halt with 'invalid descriptor' errors.
commit 4297a462f455e38f08976df7b16c849614a287da upstream.
Correct a typo error in locking calls.
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
commit cbd1998377504df005302ac90d49db72a48552a6 upstream.
evms configures md arrays by:
open device
send ioctl
close device
for each different ioctl needed.
Since 2.6.29, the device can disappear after the 'close'
unless a significant configuration has happened to the device.
The change made by "SET_ARRAY_INFO" can too minor to stop the device
from disappearing, but important enough that losing the change is bad.
So: make sure SET_ARRAY_INFO sets mddev->ctime, and keep the device
active as long as ctime is non-zero (it gets zeroed with lots of other
things when the array is stopped).
This is suitable for -stable kernels since 2.6.29.
Signed-off-by: NeilBrown <neilb@suse.de>
commit 6057912d7baad31be9819518674ffad349a065b1 upstream.
sizeof(dev->dev_addr) is the size of a pointer. A few lines above, the
size of this field is obtained using netdev->addr_len for a call to memcpy,
so do the same here.
A simplified version of the semantic patch that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
expression *x;
expression f;
type T;
*f(...,(T)x,...)
// </smpl>
commit da307123c621b01cce147a4be313d8a754674f63 upstream.
This patch (as1315) fixes some bugs in the USB core authorization
code:
usb_deauthorize_device() should deallocate the device strings
instead of leaking them, and it should invoke
usb_destroy_configuration() (which does proper reference
counting) instead of freeing the config information directly.
usb_authorize_device() shouldn't change the device strings
until it knows that the authorization will succeed, and it should
autosuspend the device at the end (having autoresumed the
device at the start).
Because the device strings can be changed, the sysfs routines
to display the strings must protect the string pointers by
locking the device.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
CC: Inaky Perez-Gonzalez <inaky@linux.intel.com>
Acked-by: David Vrabel <david.vrabel@csr.com>
commit 8d8558d10806b7e805cb80df867ebb0a453d4765 upstream.
This patch (as1314) renames usb_configure_device() and
usb_configure_device_otg() in the hub driver. Neither name is
appropriate because these routines enumerate devices, they don't
configure them. That's handled by usb_choose_configuration() and
usb_set_configuration().
commit 652fd781a52ad6e24b908cd8b83d12699754f253 upstream.
The device must be marked busy as it receives data.
Signed-off-by: Oliver Neukum <oliver@neukum.org>
Tested-by: Matthew Garrett <mjg@redhat.com>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
commit 17be5c5f5ef99c94374e07f71effa78e93a20eda upstream.
Gadget stalling a zero-length SETUP request results in this error message:
SetupEnd came in a wrong ep0stage idle
In order to avoid it, always set the CSR0.DataEnd bit after detecting a zero-
length request. Add the missing '\n' to the error message itself as well...
Acked-by: Anand Gadiyar <gadiyar@ti.com>
Signed-off-by: Felipe Balbi <felipe.balbi@nokia.com>
commit 37e9066b2f85480d99d3795373f5ef0b00ac1189 upstream.
brightness status is reported by the Apple Cinema Displays as an
'unsigned char' (u8) value, but the code used 'char' instead.
Note that he driver was developed on the PowerPC architecture,
where the two types are synonymous, which is not always the case.
Fixed that. Otherwise the driver will interpret brightness
levels > 127 as negative, and fail to load.
Signed-off-by: pancho horrillo <pancho@pancho.name>
commit c983202bd03eb82394ef1dce5906702fcbc7bb80 upstream.
I made this patch for usbserial driver to add the support for EVDO modem
Haier CE100. The bugs report for this is here:
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/490068
This patch based on these post:
http://blankblondtank.wordpress.com/2009/09/04/mengoptimalkan-koneksi-modem-haier-ce-100-cdma-di-linux/
http://tantos.web.id/blogs/how-to-internet-connection-using-cdma-evdo-modem-and-karmic-koala-ubuntu-9-10
I hope this patch can help other that have the Haier C100 modem, mostly in my country, Indonesia.
Signed-off-by: Donny Kurnia <donnykurnia@gmail.com>
commit ac06c06770bb8761b1f1f9bdf2f5420fa6d3e9fa upstream.
While converting emi62 to use request_firmware(), the driver was also
changed to use the ihex helper functions. However, this broke the loading
of the FPGA firmware because the code tries to access the addr field of
the EOF record which works with a plain array that has an empty last
record but not with the ihex helper functions where the end of the data is
signaled with a NULL record pointer, resulting in:
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: [<f80d248c>] emi62_load_firmware+0x33c/0x740 [emi62]
This can be fixed by changing the loop condition to test the return value
of ihex_next_binrec() directly (like in emi26.c).
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
Reported-and-tested-by: Der Mickster <retroeffective@gmail.com>
Acked-by: David Woodhouse <David.Woodhouse@intel.com>
commit 794f3141a194a4f4c28c1d417b071a901f78d9bb upstream.
drivers/gpu/drm/radeon/radeon_test.c:45: undefined reference to `__udivdi3'
Reported-by: Mr. James W. Laferriere <babydr@baby-dragons.com>
commit 13c199c0d0cf78b27592991129fb8cbcfc5164de upstream.
On some laptops it will return NOTIFY_OK(non-zero) when calling the ACPI LID
notifier. Then it is used as the result of ACPI LID resume function, which
will complain the following warning message in course of suspend/resume:
>PM: Device PNP0C0D:00 failed to resume: error 1
This patch is to eliminate the above warning message.
http://bugzilla.kernel.org/show_bug.cgi?id=14782
Signed-off-by: Zhao Yakui <yakui.zhao@intel.com>
Signed-off-by: Len Brown <len.brown@intel.com>
commit 55b313f249e11b815fd0be51869f166aaf368f44 upstream.
MSI strings should be ORed, not ANDed.
Reference: http://bugzilla.kernel.org/show_bug.cgi?id=14446
Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de>
commit bdc731bc5fcd1794e9ac8ac80c389d302381c123 upstream.
BugLink: https://bugs.launchpad.net/ubuntu/+bug/435958
The module alias currently matches any Acer computer but when loaded the
BIOS checks will only succeed on Aspire One models. This causes a invalid
BIOS warning for all other models (seen on Aspire 4810T). This is not
fatal but worries users that see this message. Limiting the moule alias
to models starting with AOA or DOA for Packard Bell.
Signed-off-by: Stefan Bader <stefan.bader@canonical.com>
Acked-by: Borislav Petkov <petkovbb@gmail.com>
Acked-by: Peter Feuerer <peter@piie.net>
commit 509426bd46ad0903dca409803e0ee3d30f99f1e8 upstream.
adev->dma_mode stores the transfer mode value not UDMA mode number
so the condition in cmd64x_set_dmamode() is always true and the higher
UDMA clock is always selected. This can potentially result in data
corruption when UDMA33 device is used, when 40-wire cable is used or
when the error recovery code decides to lower the device speed down.
The issue was introduced in the commit 6a40da0 ("libata cmd64x: whack
into a shape that looks like the documentation") which goes back to
kernel 2.6.20.
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
commit 256ace9bbd4cdb6d48d5f55d55d42fa20527fad1 upstream.
The clock turnaround code still doesn't work for several reasons:
- 'USE_DPLL' flag in 'ap->host->private_data' is never initialized
or updated, so the driver can only set the chip to the DPLL clock
mode, not the PCI mode;
- the driver doesn't serialize access to the channels depending on
the current clock mode like the vendor drivers, so the clock
turnaround is only executed "optionally", not always as it should be;
- the wrong ports are written to when hpt3x2n_set_clock() is called
for the secondary channel;
- hpt3x2n_set_clock() can inadvertently enable the disabled channels
when resetting the channel state machines.
commit 48de68a40aef032a2e198437f4781a83bfb938db upstream.
If transport_class_register fails we should unregister any
registered classes, or we will leak memory or other
resources.
I did a quick modprobe of scsi_transport_fc to test the
patch.
Signed-off-by: Mike Christie <michaelc@cs.wisc.edu>
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
commit c982c368bb90adbd312faa05d0cfd842e9ab45a7 upstream.
dio transfer always resets mdata->page_order to zero. It breaks
high-order pages previously allocated for non-dio transfer.
This patches adds reserved_page_order to st_buffer structure to save
page order for non-dio transfer.
http://bugzilla.kernel.org/show_bug.cgi?id=14563
When enlarge_buffer() allocates 524288 from 0, st uses six-order page
allocation. So mdata->page_order is 6 and frp_seg is 2.
After that, if st uses dio, sgl_map_user_pages() sets
mdata->page_order to 0 for st_do_scsi(). After that, when we call
normalize_buffer(), it frees only free frp_seg * PAGE_SIZE (2 * 4096)
though we should free frp_seg * PAGE_SIZE << 6 (2 * 4096 << 6). So we
see buffer_size is set to 516096 (524288 - 8192).
Reported-by: Joachim Breuer <linux-kernel@jmbreuer.net>
Tested-by: Joachim Breuer <linux-kernel@jmbreuer.net>
Acked-by: Kai Makisara <kai.makisara@kolumbus.fi>
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
commit 1486400f7edd009d49550da968d5744e246dc7f8 upstream.
Fix crash in qla2x00_fdmi_register() due to the dpc
thread executing before the scsi host has been fully
added.
Unable to handle kernel NULL pointer dereference (address 00000000000001d0)
qla2xxx_7_dpc[4140]: Oops 8813272891392 [1]
Call Trace:
[<a000000100016910>] show_stack+0x50/0xa0
sp=e00000b07c59f930 bsp=e00000b07c591400
[<a000000100017180>] show_regs+0x820/0x860
sp=e00000b07c59fb00 bsp=e00000b07c5913a0
[<a00000010003bd60>] die+0x1a0/0x2e0
sp=e00000b07c59fb00 bsp=e00000b07c591360
[<a0000001000681a0>] ia64_do_page_fault+0x8c0/0x9e0
sp=e00000b07c59fb00 bsp=e00000b07c591310
[<a00000010000c8e0>] ia64_native_leave_kernel+0x0/0x270
sp=e00000b07c59fb90 bsp=e00000b07c591310
[<a000000207197350>] qla2x00_fdmi_register+0x850/0xbe0 [qla2xxx]
sp=e00000b07c59fd60 bsp=e00000b07c591290
[<a000000207171570>] qla2x00_configure_loop+0x1930/0x34c0 [qla2xxx]
sp=e00000b07c59fd60 bsp=e00000b07c591128
[<a0000002071732b0>] qla2x00_loop_resync+0x1b0/0x2e0 [qla2xxx]
sp=e00000b07c59fdf0 bsp=e00000b07c5910c0
[<a000000207166d40>] qla2x00_do_dpc+0x9a0/0xce0 [qla2xxx]
sp=e00000b07c59fdf0 bsp=e00000b07c590fa0
[<a0000001000d5bb0>] kthread+0x110/0x140
sp=e00000b07c59fe00 bsp=e00000b07c590f68
[<a000000100014a30>] kernel_thread_helper+0xd0/0x100
sp=e00000b07c59fe30 bsp=e00000b07c590f40
[<a00000010000a4c0>] start_kernel_thread+0x20/0x40
crash> dis a000000207197350
0xa000000207197350 <qla2x00_fdmi_register+2128>: [MMI] ld1 r45=[r14];;
crash> scsi_qla_host.host 0xe00000b058c73ff8
host = 0xe00000b058c73be0,
crash> Scsi_Host.shost_data 0xe00000b058c73be0
shost_data = 0x0, <<<<<<<<<<<
The fc_transport fc_* workqueue threads have yet to be created.
crash> ps | grep _7
3891 2 2 e00000b075c80000 IN 0.0 0 0 [scsi_eh_7]
4140 2 3 e00000b07c590000 RU 0.0 0 0 [qla2xxx_7_dpc]
The thread creating adding the Scsi_Host is blocked due to other
activity in sysfs.
crash> bt 3762
PID: 3762 TASK: e00000b071e70000 CPU: 3 COMMAND: "modprobe"
#0 [BSP:e00000b071e71548] schedule at a000000100727e00
#1 [BSP:e00000b071e714c8] __mutex_lock_slowpath at a0000001007295a0
#2 [BSP:e00000b071e714a8] mutex_lock at a000000100729830
#3 [BSP:e00000b071e71478] sysfs_addrm_start at a0000001002584f0
#4 [BSP:e00000b071e71440] create_dir at a000000100259350
#5 [BSP:e00000b071e71410] sysfs_create_subdir at a000000100259510
#6 [BSP:e00000b071e713b0] internal_create_group at a00000010025c880
#7 [BSP:e00000b071e71388] sysfs_create_group at a00000010025cc50
#8 [BSP:e00000b071e71368] dpm_sysfs_add at a000000100425050
#9 [BSP:e00000b071e71310] device_add at a000000100417d90
#10 [BSP:e00000b071e712d8] scsi_add_host at a00000010045a380
#11 [BSP:e00000b071e71268] qla2x00_probe_one at a0000002071be950
#12 [BSP:e00000b071e71248] local_pci_probe at a00000010032e490
#13 [BSP:e00000b071e71218] pci_device_probe at a00000010032ecd0
#14 [BSP:e00000b071e711d8] driver_probe_device at a00000010041d480
#15 [BSP:e00000b071e711a8] __driver_attach at a00000010041d6e0
#16 [BSP:e00000b071e71170] bus_for_each_dev at a00000010041c240
#17 [BSP:e00000b071e71150] driver_attach at a00000010041d0a0
#18 [BSP:e00000b071e71108] bus_add_driver at a00000010041b080
#19 [BSP:e00000b071e710c0] driver_register at a00000010041dea0
#20 [BSP:e00000b071e71088] __pci_register_driver at a00000010032f610
#21 [BSP:e00000b071e71058] (unknown) at a000000207200270
#22 [BSP:e00000b071e71018] do_one_initcall at a00000010000a9c0
#23 [BSP:e00000b071e70f98] sys_init_module at a0000001000fef00
#24 [BSP:e00000b071e70f98] ia64_ret_from_syscall at a00000010000c740
So, it appears that qla2xxx dpc thread is moving forward before the
scsi host has been completely added.
This patch moves the setting of the init_done (and online) flag to
after the call to scsi_add_host() to hold off the dpc thread.
Found via large lun count testing using 2.6.31.
Signed-off-by: Michael Reed <mdr@sgi.com>
Acked-by: Giridhar Malavali <giridhar.malavali@qlogic.com>
commit 99c965dd9ee1a004efc083c3d760ba982bb76adf upstream.
After commits c82f63e411f1b58427c103bd95af2863b1c96dd1 (PCI: check saved
state before restore) and 4b77b0a2ba27d64f58f16d8d4d48d8319dda36ff (PCI:
Clear saved_state after the state has been restored) PCI drivers are
prevented from restoring the device standard configuration registers
twice in a row. These changes introduced a regression on ipr EEH
recovery.
The ipr device driver saves the PCI state only during the device probe
and restores it on ipr_reset_restore_cfg_space() during IOA resets. This
behavior is causing the EEH recovery to fail after the second error
detected, since the registers are not being restored.
One possible solution would be saving the registers after restoring
them. The problem with this approach is that while recovering from an
EEH error if pci_save_state() results in an EEH error, the adapter/slot
will be reset, and end up back in ipr_reset_restore_cfg_space(), but it
won't have a valid saved state to restore, so pci_restore_state() will
fail.
The following patch introduces a workaround for this problem, hacking
around the PCI API by setting pdev->state_saved = true before we do the
restore. It fixes the EEH regression and prevents that we hit another
EEH error during EEH recovery.
[jejb: fix is a hack ... Jesse and Rafael will fix properly]
Signed-off-by: Kleber Sacilotto de Souza <klebers@linux.vnet.ibm.com>
Acked-by: Brian King <brking@linux.vnet.ibm.com>
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
commit 1672af1164d3d50ba8908014fd34cc0b58afdc1e upstream.
We are seeing a bug when booting w/ iommu=pt with current upstream
(bisect blames 19943b0e30b05d42e494ae6fef78156ebc8c637e "intel-iommu:
Unify hardware and software passthrough support).
The issue is specific to this loop during identity map initialization
of each device:
domain_context_mapping_one(si_domain, ..., CONTEXT_TT_PASS_THROUGH)
/* Skip top levels of page tables for
* iommu which has less agaw than default.
for (agaw = domain->agaw; agaw != iommu->agaw; agaw--) {
pgd = phys_to_virt(dma_pte_addr(pgd));
if (!dma_pte_present(pgd)) { <------ failing here
spin_unlock_irqrestore(&iommu->lock, flags);
return -ENOMEM;
This box has 2 iommu's in it. The catchall iommu has MGAW == 48, and
SAGAW == 4. The other iommu has MGAW == 39, SAGAW == 2.
The device that's failing the above pgd test is the only device connected
to the non-catchall iommu, which has a smaller address width than the
domain default. This test is not necessary since the context is in PT
mode and the ASR is ignored.
Thanks to Don Dutile for discovering and debugging this one.
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
commit 44cd613c0e4cd93079ea2a93aa06649d8ca0830a upstream.
The hotplug notifier will call find_domain() to see if the device in
question has been assigned an IOMMU domain. However, this should never
be called for devices with a "dummy" domain, such as graphics devices
when intel_iommu=igfx_off is set and the corresponding IOMMU isn't even
initialised. If you do that, it'll oops as it dereferences the (-1)
pointer.
The notifier function should check iommu_no_mapping() for the
device before doing anything else.
commit 5595b528b49a702c0428c0762bab60999648254c upstream.
Some HP BIOSes report an RMRR region (a region which needs a 1:1 mapping
in the IOMMU for a given device) which has an end address lower than its
start address. Detect that and warn, rather than triggering the
BUG() in dma_pte_clear_range().
commit 6ecbf01c7ce4c0f4c3bdfa0e64ac6258328fda6c upstream.
The BIOS errors where an IOMMU is reported either at zero or a bogus
address are causing problems even when the IOMMU is disabled -- because
interrupt remapping uses the same hardware. Ensure that the checks get
applied for the interrupt remapping initialisation too.
commit 2c99220810c1c79322034628b993573b088ff2da upstream.
Many BIOSes will lie to us about the existence of an IOMMU, and claim
that there is one at an address which actually returns all 0xFF.
We need to detect this early, so that we know we don't have a viable
IOMMU and can set up swiotlb before it's too late.
commit 1b3c7a47f993bf9ab6c4c7cc3bbf5588052b58f4 upstream.
In disable sequence, all output ports on PCH have to be disabled
before PCH transcoder, but LVDS port was left always enabled. This
one fixes that by disable LVDS port properly during pipe disable
process, and resolved stability issue seen on Ironlake. Also move
panel fitting disable time just after pipe disable to align with
the spec.
Signed-off-by: Zhenyu Wang <zhenyuw@linux.intel.com>
Signed-off-by: Eric Anholt <eric@anholt.net>
commit 103a196f4224dc6872081305cf7f82ebf67aa7bd upstream.
PineView only has 2 ports for LVDS and CRT. Don't enable other
ports for it.
Cc: Shaohua Li <shaohua.li@intel.com>
commit d271817baecbccb47da0d9f28c285a0dae8a06b7 upstream.
In commit d2d9f2324, the guard for a valid video mode was removed. This
caused the regression:
kernel crash during kms graphic boot on Intel GM4500 platform
https://bugzilla.redhat.com/show_bug.cgi?id=540218
This patches changes the logic slightly not to rely on a coupled
variable, but to just check whether the video_modes is valid before
dereferencing.
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Zhenyu Wang <zhenyu.z.wang@intel.com>
[ickle: Actually reference the correct bug report]
Acked-by: Zhenyu Wang <zhenyuw@linux.intel.com>
commit a3f92eea04101d9a8e14d50f8048cc5b7bca07a8 upstream.
This patch converts bcm63xx_enet to uset get_sset_count
like the other drivers do.
Signed-off-by: Florian Fainelli <ffainelli@freebox.fr>
commit 518c8df77c21b7d1690dd8b96eb0e54c4ec1c9c1 upstream.
Signed-off-by: Rafal Milecki <zajec5@gmail.com>
Signed-off-by: Jean-Francois Moine <moinejf@free.fr>
Cc: Surbhi Palande <surbhi.palande@canonical.com>
commit d951d4cc84e8b5ddb8e0ab81cf6a72cc73fdd668 upstream.
The light sensor disable brightness key and
/sys/class/backlight/ control. There was a lot of report
from users who didn't understand why they couldn't change their
brightness, including:
https://bugs.launchpad.net/bugs/222171
https://bugzilla.novell.com/show_bug.cgi?id=514747
http://bugzilla.kernel.org/show_bug.cgi?id=13671
http://bugzilla.kernel.org/show_bug.cgi?id=14432
Now the light sensor is disabled, and if the user want to enable
it, the level should be ok.
The funny thing is that comments where ok, not code.
Cc: stable@kernel.org
Cc: Thomas Renninger <trenn@suse.de>
Cc: Peter Küppers <peter-mailbox@web.de>
Cc: Michael Franzl <michaelfranzl@gmx.at>
Cc: Ian Turner <vectro@vectro.org>
Signed-off-by: Corentin Chary <corentincj@iksaif.net>
commit 360657463679dee44f0b167ffa61f563b4fee101 upstream.
Added new BIOS versions for following netbooks: Acer 1410, Gateway LT31,
Packard Bell DOA150. As the Gateway LT31 machines have different register
values for setting and checking the off-state, the "cmd_off" variable has
been splitted up to "cmd_off" and "chk_off".
Signed-off-by: Peter Feuerer <peter@piie.net>
Cc: Borislav Petkov <petkovbb@gmail.com>
Cc: Andreas Mohr <andi@lisas.de>
commit 8c651311a3a08c1e4815de6933e00a760e498dae upstream.
Regression caused in 2.6.23 and then despite repeated requests never fixed
or dealt with (Petr promised to sort it in 2008 but seems to have
forgotten).
Enough is enough - remove the problem line that was added. If it upsets
someone they've had two years to deal with it and at the very least it'll
rattle their cage and wake them up.
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=9709
Signed-off-by: Alan Cox <alan@linux.intel.com>
Reported-by: Damon <account@bugzilla.kernel.org.juxtaposition.net>
Tested-by: Ruud van Melick <rvm1974@raketnet.nl>
Cc: Petr Vandrovec <VANDROVE@vc.cvut.cz>
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
Cc: Paul A. Clarke <pc@us.ibm.com>
commit 52ce3e9a7db754b78cf2cbabc87013f921b25b28 upstream.
Add PCI .shutdown method so that we can disable the device during
shutdown or reboot. Without this, the reboot doesn't work well on
some platforms.
This fixes http://bugzilla.intellinuxwireless.org/show_bug.cgi?id=2124
Tested-by: pablo <pablolm2005@gmail.com>
commit 208b996b6c460285650d39b2330f8ef82c007d10 upstream.
Since the rfkill rework in 2.6.31, the driver is always resuming with
the radios disabled.
Change thinkpad-acpi to ask the firmware to resume with the radios in
the last state. This fixes the Bluetooth and WWAN rfkill switches.
Note that it means we respect the firmware's oddities. Should the
user toggle the hardware rfkill switch on and off, it might cause the
radios to resume enabled.
UWB is an unknown quantity since it has nowhere the same level of
firmware support (no control over state storage in NVRAM, for
example), and might need further fixing. Testers welcome.
This change fixes a regression from 2.6.30.
Reported-by: Jerone Young <jerone.young@canonical.com>
Reported-by: Ian Molton <ian.molton@collabora.co.uk>
Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br>
Tested-by: Ian Molton <ian.molton@collabora.co.uk>
commit a9f8eacca4e9e8693de9b896c1fa7aadaa9402e8 upstream.
According to a report, the R50e wants EC-based brightness control,
even if it uses an Intel GPU. The current driver default was reported
to not work at all.
This bug can be worked around by the "brightness_mode=3" module
parameter.
Change the default of the R50e and R51 2xxx models (which use the same
EC firmware, 1V) to TPACPI_BRGHT_Q_EC, but keep TPACPI_BRGHT_Q_ASK set
for now, as I'd like to get more reports.
This fixes a regression caused by commit
59fe4fe34d7afdf63208124f313be9056feaa2f4,
"thinkpad-acpi: fix incorrect use of TPACPI_BRGHT_MODE_ECNVRAM"
Kernel 2.6.31 also needs this fix.
Reported-by: Ferenc Wagner <wferi@niif.hu>
Tested-by: Ferenc Wagner <wferi@niif.hu>
commit 778c902640530371a169ad1c03566e7c51b09874 upstream
In current vblank-wait implementation, if we turn off VGA output,
drm_wait_vblank will still wait on the disabled pipe until timeout,
because vblank on the pipe is assumed be enabled. This would cause
slow system response on some system such as moblin.
This patch resolve the issue by adding a drm helper function
drm_vblank_off which explicitly clear vblank_enabled[crtc], wake up
any waiting queue and save last vblank counter before turning off
crtc. It also slightly change drm_vblank_get to ensure that we will
will return immediately if trying to wait on a disabled pipe.
Signed-off-by: Li Peng <peng.li@intel.com>
Reviewed-by: Jesse Barnes <jbarnes@virtuousgeek.org>
[anholt: hand-applied for conflicts with overlay changes]
Cc: Stefan Bader <stefan.bader@canonical.com>
This is a backport of upstream commit: e8c6342d989e241513baeba4b05a04b6b1f3bc8b
This patch fixes a bug in ath9k's tx status check, which
caused mac80211 to consider regularly transmitted unicast frames
as un-acked.
When checking the ts_status field for errors, it needs to be masked
with ATH9K_TXERR_FILT, because this field also contains other fields
like ATH9K_TX_ACKED.
Without this patch, AP mode is pretty much unusable, as hostapd
checks the ACK status for the frames that it injects.
This is a backport of upstream commit: f4709fdf683e1ed37b321c258b614ebe39752bf3
Atheros single stream AR9285 and AR9271 have half the PCU TX FIFO
buffer size of that of dual stream devices. Dual stream devices
have a max PCU TX FIFO size of 8 KB while single stream devices
have 4 KB. Single stream devices have an issue though and require
hardware only to use half of the amount of its capable PCU TX FIFO
size, 2 KB and this requires a change in software.
Technically a change would not have been required (except for frame
burst considerations of 128 bytes) if these devices would have been
able to use the full 4 KB of the PCU TX FIFO size but our systems
engineers recommend 2 KB to be used only. We enforce this through
software by reducing the max frame triggger level to 2 KB.
Fixing the max frame trigger level should then have a few benefits:
* The PER will now be adjusted as designed for underruns when the
max trigger level is reached. This should help alleviate the
bus as the rate control algorithm chooses a slower rate which
should ensure frames are transmitted properly under high system
bus load.
* The poll we use on our TX queues should now trigger and work
as designed for single stream devices. The hardware passes
data from each TX queue on the PCU TX FIFO queue respecting each
queue's priority. The new trigger level ensures this seeding of
the PCU TX FIFO queue occurs as designed which could mean avoiding
false resets and actually reseting hw correctly when a TX queue
is indeed stuck.
* Some undocumented / unsupported behaviour could have been triggered
when the max trigger level level was being set to 4 KB on single
stream devices. Its not clear what this issue was to me yet.
Cc: Kyungwan Nam <kyungwan.nam@atheros.com>
Cc: Bennyam Malavazi <bennyam.malavazi@atheros.com>
Cc: Stephen Chen <stephen.chen@atheros.com>
Cc: Shan Palanisamy <shan.palanisamy@atheros.com>
Cc: Paul Shaw <paul.shaw@atheros.com>
Signed-off-by: Vasanthakumar Thiagarajan <vasanth@atheros.com>
This is a backport of upstream commit: e7824a50662f7f79b1a739f705b4d906c31cf221
When mac80211 was telling us to go into Powersave we listened
and immediately turned RX off. This meant hardware would not
see the ACKs from the AP we're associated with and hardware
we'd end up retransmiting the null data frame in a loop
helplessly.
Fix this by keeping track of the transmitted nullfunc frames
and only when we are sure the AP has sent back an ACK do we
go ahead and shut RX off.
Signed-off-by: Vivek Natarajan <Vivek.Natarajan@atheros.com>
This is a backport of upstream commit: 332c556633b8c5fb4e890b1783122f2315526590
When TX is hung, the chip is reset. Ensure that
the chip is awake by using the PS wrappers.
commit 316a4d966cae3c2dec83ebb1ee1a3515f97b30ff upstream.
For PPC architecture with PHY Revision < 3, a read of the register
B43_MMIO_HWENABLED_LO will cause a CPU fault unless b43legacy_status()
returns a value of 2 (B43legacy_STAT_STARTED); however, one finds that
the driver is unable to associate after resuming from hibernation unless
this routine returns 1. To satisfy both conditions, the routine is rewritten
to return TRUE whenever b43legacy_status() returns a value < 2.
This patch fixes the second problem listed in the postings for Red Hat
Bugzilla #538523.
