Renamed the sysfs attribute kone_driver_version to kone_abi_version and
simplified returned data to integer.
Signed-off-by: Stefan Achatz <erazor_de@users.sourceforge.net>
Fixed the following warning of checkpatch.pl:
WARNING: space prohibited between function name and open parenthesis '('
Removed comment that is obsolete since roccat char device is
implemented
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (47 commits)
mfd: Rename twl5031 sih modules
mfd: Storage class for timberdale should be before const qualifier
mfd: Remove unneeded and dangerous clearing of clientdata
mfd: New AB8500 driver
gpio: Fix inverted rdc321x gpio data out registers
mfd: Change rdc321x resources flags to IORESOURCE_IO
mfd: Move pcf50633 irq related functions to its own file.
mfd: Use threaded irq for pcf50633
mfd: pcf50633-adc: Fix potential race in pcf50633_adc_sync_read
mfd: Fix pcf50633 bitfield logic in interrupt handler
gpio: rdc321x needs to select MFD_CORE
mfd: Use menuconfig for quicker config editing
ARM: AB3550 board configuration and irq for U300
mfd: AB3550 core driver
mfd: AB3100 register access change to abx500 API
mfd: Renamed ab3100.h to abx500.h
gpio: Add TC35892 GPIO driver
mfd: Add Toshiba's TC35892 MFD core
mfd: Delay to mask tsc irq in max8925
mfd: Remove incorrect wm8350 kfree
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx:
DMAENGINE: DMA40 U8500 platform configuration
DMA: PL330: Add dma api driver
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband:
IB/qib: Remove DCA support until feature is finished
IB/qib: Use a single txselect module parameter for serdes tuning
IB/qib: Don't rely on (undefined) order of function parameter evaluation
IB/ucm: Use memdup_user()
IB/qib: Fix undefined symbol error when CONFIG_PCI_MSI=n
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6:
quota: Convert quota statistics to generic percpu_counter
ext3 uses rb_node = NULL; to zero rb_root.
quota: Fixup dquot_transfer
reiserfs: Fix resuming of quotas on remount read-write
pohmelfs: Remove dead quota code
ufs: Remove dead quota code
udf: Remove dead quota code
quota: rename default quotactl methods to dquot_
quota: explicitly set ->dq_op and ->s_qcop
quota: drop remount argument to ->quota_on and ->quota_off
quota: move unmount handling into the filesystem
quota: kill the vfs_dq_off and vfs_dq_quota_on_remount wrappers
quota: move remount handling into the filesystem
ocfs2: Fix use after free on remount read-only
Fix up conflicts in fs/ext4/super.c and fs/ufs/file.c
Fix a bunch of new rapidio kernel-doc warnings:
Warning(include/linux/rio.h:123): No description found for parameter 'comp_tag'
Warning(include/linux/rio.h:123): No description found for parameter 'phys_efptr'
Warning(include/linux/rio.h:123): No description found for parameter 'em_efptr'
Warning(include/linux/rio.h:123): No description found for parameter 'pwcback'
Warning(include/linux/rio.h:247): No description found for parameter 'set_domain'
Warning(include/linux/rio.h:247): No description found for parameter 'get_domain'
Warning(drivers/rapidio/rio-scan.c:1133): No description found for parameter 'rdev'
Warning(drivers/rapidio/rio-scan.c:1133): Excess function parameter 'port' description in 'rio_init_em'
Warning(drivers/rapidio/rio.c:349): No description found for parameter 'rdev'
Warning(drivers/rapidio/rio.c:349): Excess function parameter 'mport' description in 'rio_request_inb_pwrite'
Warning(drivers/rapidio/rio.c:393): No description found for parameter 'port'
Warning(drivers/rapidio/rio.c:393): No description found for parameter 'local'
Warning(drivers/rapidio/rio.c:393): No description found for parameter 'destid'
Warning(drivers/rapidio/rio.c:393): No description found for parameter 'hopcount'
Warning(drivers/rapidio/rio.c:393): Excess function parameter 'rdev' description in 'rio_mport_get_physefb'
Warning(drivers/rapidio/rio.c:845): Excess function parameter 'local' description in 'rio_std_route_clr_table'
Cc: Alexandre Bounine <alexandre.bounine@idt.com>
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6:
drm/radeon: fix the r100/r200 ums block 0 page fix
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6
* 'idle-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6:
intel_idle: native hardware cpuidle driver for latest Intel processors
ACPI: acpi_idle: touch TS_POLLING only in the non-MWAIT case
acpi_pad: uses MONITOR/MWAIT, so it doesn't need to clear TS_POLLING
sched: clarify commment for TS_POLLING
ACPI: allow a native cpuidle driver to displace ACPI
cpuidle: make cpuidle_curr_driver static
cpuidle: add cpuidle_unregister_driver() error check
cpuidle: fail to register if !CONFIG_CPU_IDLE
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (27 commits)
ACPI: Don't let acpi_pad needlessly mark TSC unstable
drivers/acpi/sleep.h: Checkpatch cleanup
ACPI: Minor cleanup eliminating redundant PMTIMER_TICKS to NS conversion
ACPI: delete unused c-state promotion/demotion data strucutures
ACPI: video: fix acpi_backlight=video
ACPI: EC: Use kmemdup
drivers/acpi: use kasprintf
ACPI, APEI, EINJ injection parameters support
Add x64 support to debugfs
ACPI, APEI, Use ERST for persistent storage of MCE
ACPI, APEI, Error Record Serialization Table (ERST) support
ACPI, APEI, Generic Hardware Error Source memory error support
ACPI, APEI, UEFI Common Platform Error Record (CPER) header
Unified UUID/GUID definition
ACPI Hardware Error Device (PNP0C33) support
ACPI, APEI, PCIE AER, use general HEST table parsing in AER firmware_first setup
ACPI, APEI, Document for APEI
ACPI, APEI, EINJ support
ACPI, APEI, HEST table parsing
ACPI, APEI, APEI supporting infrastructure
airlied -> brown paper bag.
I blame Hi-5 or the Wiggles for lowering my IQ, move the fix inside some
brackets instead of breaking everything in site.
Cc: stable@kernel.org
acpi pad driver kind of aggressively marks TSC as unstable at init
time, on mwait capable and non X86_FEATURE_NONSTOP_TSC systems. This is
irrespective of whether pad driver is ever going to be used on the
system or deep C-states are supported/used. This will affect every user
who just happens to compile in (or get a kernel version which
compiles in) acpi pad driver.
Move mark_tsc_unstable() out of init to the actual idle invocation path
of the pad driver.
There is also another bug/missing_feature in the code that it does not
support 'always running apic timer' and switches to broadcast mode
unconditionally. Shaohua, can you take a look at that please.
Signed-off-by: Venkatesh Pallipadi <venki@google.com>
Signed-off-by: Len Brown <len.brown@intel.com>
drivers/acpi/sleep.h:3: WARNING: space prohibited between function name and open parenthesis '('
Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net>
acpi_enter_[simple,bm] does
idle timing in ns, convert it to timeval, then to us, then to
pmtimer_ticks and then back to ns.
This patch changes things to
idle timing in ns, convert it to us, and then to pmtimer_ticks.
Just saves an imul along this path, but makes the code cleaner.
This EXPERIMENTAL driver supersedes acpi_idle on
Intel Atom Processors, Intel Core i3/i5/i7 Processors
and associated Intel Xeon processors.
It does not support the Intel Core2 processor or earlier.
For kernels configured with ACPI, CONFIG_INTEL_IDLE=y
allows intel_idle to probe before the ACPI processor driver.
Booting with "intel_idle.max_cstate=0" disables intel_idle
and the system will fall back on ACPI's "acpi_idle".
Typical Linux distributions load ACPI processor module early,
making CONFIG_INTEL_IDLE=m not easily useful on ACPI platforms.
intel_idle probes all processors at module_init time.
Processors that are hot-added later will be limited
to using C1 in idle.
commit d306ebc28649b89877a22158fe0076f06cc46f60
(ACPI: Be in TS_POLLING state during mwait based C-state entry)
fixed an important power & performance issue where ACPI c2 and c3 C-states
were clearing TS_POLLING even when using MWAIT (ACPI_STATE_FFH).
That bug had been causing us to receive redundant scheduling interrups
when we had already been woken up by MONITOR/MWAIT.
Following up on that...
In the MWAIT case, we don't have to subsequently
check need_resched(), as that c heck was there
for the TS_POLLING-clearing case.
Note that not only does the cpuidle calling function
already check need_resched() before calling us, the
low-level entry into monitor/mwait calls it twice --
guaranteeing that a write to the trigger address
can not go un-noticed.
Also, in this case, we don't have to set TS_POLLING
when we wake, because we never cleared it.
Acked-by: Venkatesh Pallipadi <venki@google.com>
* 'for-linus' of git://git.o-hand.com/linux-rpurdie-leds:
leds: Fix leds-gpio openfirmware compile issue
leds: Kconfig fixes
* 'for-linus/2635-updates' of git://git.fluff.org/bjdooks/linux:
ARM: S5PV210: serial: Fix section mismatch warning
ARM: s3c2410_defconfig: Add new machines
ARM: s3c6400_defconfig: Add framebuffer and basic LCD
ARM: s3c6400_defconfig: Add RTC driver support
ARM: s3c6400_defconfig: Enable USB host side
ARM: s3c6400_defconfig: Add SPI driver
ARM: s3c6400_defconfig: Update compiled machines
ARM: S5P: Regoster clk_xusbxti clock for hsotg driver
ARM: S3C64XX: Add USB OTG HCLK to the list of clocks
ARM: SAMSUNG: gpio-cfg.h: update documentation
ARM: SAMSUNG: Documentation: add documentation on GPIO code
ARM: SAMSUNG: Fix documentation for s3c_gpio_cfgpin()
ARM: S3C24XX: Documentation: add section on gpiolib changes
ARM: S3C24XX: Documentation: update GPIO documentation
ARM: S3C24XX: Documentation: update documentation overview
ARM: SAMSUNG: Documentation: update directory layout
ARM: SAMSUNG: Documentation: update the list of SoCs supported
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (22 commits)
netlink: bug fix: wrong size was calculated for vfinfo list blob
netlink: bug fix: don't overrun skbs on vf_port dump
xt_tee: use skb_dst_drop()
netdev/fec: fix ifconfig eth0 down hang issue
cnic: Fix context memory init. on 5709.
drivers/net: Eliminate a NULL pointer dereference
drivers/net/hamradio: Eliminate a NULL pointer dereference
be2net: Patch removes redundant while statement in loop.
ipv6: Add GSO support on forwarding path
net: fix __neigh_event_send()
vhost: fix the memory leak which will happen when memory_access_ok fails
vhost-net: fix to check the return value of copy_to/from_user() correctly
vhost: fix to check the return value of copy_to/from_user() correctly
vhost: Fix host panic if ioctl called with wrong index
net: fix lock_sock_bh/unlock_sock_bh
net/iucv: Add missing spin_unlock
net: ll_temac: fix checksum offload logic
net: ll_temac: fix interrupt bug when interrupt 0 is used
sctp: dubious bitfields in sctp_transport
ipmr: off by one in __ipmr_fill_mroute()
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6:
remove detritus left by "mm: make read_cache_page synchronous"
fix fs/sysv s_dirt handling
fat: convert to use the new truncate convention.
ext2: convert to use the new truncate convention.
tmpfs: convert to use the new truncate convention
fs: convert simple fs to new truncate
kill spurious reference to vmtruncate
fs: introduce new truncate sequence
fs/super: fix kernel-doc warning
fs/minix: bugfix, number of indirect block ptrs per block depends on block size
rename the generic fsync implementations
drop unused dentry argument to ->fsync
fs: Add missing mutex_unlock
Fix racy use of anon_inode_getfd() in perf_event.c
get rid of the magic around f_count in aio
VFS: fix recent breakage of FS_REVAL_DOT
Revert "anon_inode: set S_IFREG on the anon_inode"
BugLink: http://bugs.launchpad.net/bugs/559065
In fec open/close function, we need to use phy_connect and phy_disconnect
operation before we start/stop phy. Otherwise it will cause system hang.
Only call fec_enet_mii_probe() in open function, because the first open
action will cause NULL pointer error.
Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
Rename the structure to avoid the following warning:
WARNING: drivers/serial/built-in.o(.data+0x534): Section mismatch in reference from the variable s5p_serial_drv to the function .devexit.text:s3c24xx_serial_remove()
The variable s5p_serial_drv references
the function __devexit s3c24xx_serial_remove()
If the reference is valid then annotate the
variable with __exit* (see linux/init.h) or name the variable:
*driver, *_template, *_timer, *_sht, *_ops, *_probe, *_probe_one, *_console,
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
We need to zero context memory on 5709 in the function cnic_init_context().
Without this, iscsid restart on 5709 will not work because of stale data.
TX context blocks should not be initialized by cnic_init_context() because
of the special remapping on 5709.
Update version to 2.1.2.
Signed-off-by: Michael Chan <mchan@broadcom.com>
At the point of the print, dev is NULL.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
@r exists@
expression E,E1;
identifier f;
statement S1,S2,S3;
if ((E == NULL && ...) || ...)
... when != if (...) S1 else S2
when != E = E1
* E->f
... when any
return ...;
else S3
// </smpl>
// <smpl>
@r exists@
expression E,E1;
identifier f;
statement S1,S2,S3;
when != E = E1
* E->f
... when any
return ...;
else S3
// </smpl>
Signed-off-by: Sarveshwar Bandi <sarveshwarb@serverengines.com>
Fix a compile issue when openfirmware is enabled from commit
2146325df2c2640059a9e064890c30c6e259b458.
Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
Soekris net5501 is x86 only and cleanup some undeeded dependencies
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev
* 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev:
libata: implement dump_id force param
libata: disable ATAPI AN by default
libata-sff: make BMDMA optional
libata-sff: kill dummy BMDMA ops from sata_qstor and pata_octeon_cf
libata-sff: separate out BMDMA init
libata-sff: separate out BMDMA irq handler
libata-sff: ata_sff_irq_clear() is BMDMA specific
sata_mv: drop unncessary EH callback resetting
api_pad exclusively uses MONITOR/MWAIT to sleep in idle,
so it does not need the wakeup IPI during idle sleep
that is provoked by clearing TS_POLLING.
Cc: Shaohua Li <shaohua.li@intel.com>
The ACPI driver would fail probe when it found that
another driver had previously registered with cpuidle.
But this is a natural situation, as a native hardware
cpuidle driver should be able to bind instead of ACPI,
and the ACPI processor driver should be able to handle
yielding control of C-states while still handling
P-states and T-states.
Add a KERN_DEBUG line showing when acpi_idle
does successfully register.
cpuidle_register_driver() sets cpuidle_curr_driver
cpuidle_unregister_driver() clears cpuidle_curr_driver
We should't expose cpuidle_curr_driver to
potential modification except via these interfaces.
So make it static and create cpuidle_get_driver() to observe it.
Fix the names of twl5031 specific sih modules to match
the documentation.
Signed-off-by: Ilkka Koskinen <ilkka.koskinen@nokia.com>
The C99 specification states in section 6.11.5:
The placement of a storage-class specifier other than at the beginning
of the declaration specifiers in a declaration is an obsolescent
feature.
Signed-off-by: Tobias Klauser <tklauser@distanz.ch>
Unlike real i2c-devices which get detached from the driver, dummy-devices
get truly unregistered. So, there has never been a need to clear the
clientdata because the device will go away anyhow. For the occasions fixed
here, clearing clientdata was even dangerous as the structure was freed
already.
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
Acked-by: Jean Delvare <khali@linux-fr.org>
Add a new driver to support the AB8500 Power Management chip, replacing
the current AB4500. The new driver replaces the old one, instead of an
incremental modification, because this is a substantial overhaul
including:
- Split of the driver into -core and -spi portions, to allow another
interface layer to be added
- Addition of interrupt support
- Switch to MFD core API for handling subdevices
- Simplification of the APIs to remove a redundant block parameter
- Rename of the APIs and macros from ab4500_* to ab8500_*
- Rename of the files from ab4500* to ab8500*
- Change of the driver name from ab4500 to ab8500
Acked-by: Linus Walleij <linus.walleij@stericsson.com>
Acked-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com>
rdc_gpio_set_value_impl has the gpio data registers 1 and 2 inverted, fix this.
Signed-off-by: Bernhard Loos <bernhardloos@gmail.com>
Signed-off-by: Florian Fainelli <florian@openwrt.org>
The rdc321x southbridge PCI device has no MEM PCI resources that we could
pass to mfd_add_devices. Since 33254dd5, mfd_add_device checks for the
mem_base argument that we set to NULL. Changing the resources passed to
our MFD cells from IORESOURCE_MEM to IORESOURCE_IO fixes that. Since we use
those resources as offsets to the PCI configuration space base address of
the southbridge device this is also more adequate.
This reduces code clutter a bit and will ease an migration to genirq.
Use threaded oneshot irq handler instead of normal irq handler and a workqueue.
Currently it's not guaranteed that request struct is not already freed when
reading from it. Fix this by moving synced request related fields from the
pcf50633_adc_request struct to its own struct and store it on the functions
stack.
Those constants are alreay bitfields.
Fix rdc321x-southbridge build: GPIO_RDC321X needs to select
MFD_CORE so that the core is built at the same (or higher)
tristate level.
rdc321x-southbridge.c:(.devinit.text+0x6103): undefined reference to `mfd_add_devices'
rdc321x-southbridge.c:(.devexit.text+0xe5f): undefined reference to `mfd_remove_devices'
Cc: Florian Fainelli <florian@openwrt.org>
