* git://git.kernel.org/pub/scm/linux/kernel/git/steve/linux-dm:
dm: raid fix device status indicator when array initializing
dm log userspace: add log device dependency
dm log userspace: fix comment hyphens
dm: add thin provisioning target
dm: add persistent data library
dm: add bufio
dm: export dm get md
dm table: add immutable feature
dm table: add always writeable feature
dm table: add singleton feature
dm kcopyd: add dm_kcopyd_zero to zero an area
dm: remove superfluous smp_mb
dm: use local printk ratelimit
dm table: propagate non rotational flag
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-edac
* 'linux_next' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-edac: (21 commits)
MAINTAINERS: add an entry for Edac Sandy Bridge driver
edac: tag sb_edac as EXPERIMENTAL, as it requires more testing
EDAC: Fix incorrect edac mode reporting in sb_edac
edac: sb_edac: Add it to the building system
edac: Add an experimental new driver to support Sandy Bridge CPU's
i7300_edac: Fix error cleanup logic
i7core_edac: Initialize memory name with cpu, channel, bank
i7core_edac: Fix compilation on 32 bits arch
i7core_edac: scrubbing fixups
EDAC: Correct Kconfig dependencies
i7core_edac: return -ENODEV if no MC is found
i7core_edac: use edac's own way to print errors
MAINTAINERS: remove dropped edac_mce.* from the file
i7core_edac: Drop the edac_mce facility
x86, MCE: Use notifier chain only for MCE decoding
EDAC i7core: Use mce socketid for better compatibility
i7core_edac: Don't enable memory scrubbing for Xeon 35xx
i7core_edac: Add scrubbing support
edac: Move edac main structs to include/linux/edac.h
i7core_edac: Fix oops when trying to inject errors
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux
* 'misc-3.2' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux:
MAINTAINERS: Update entry for IA64
[IA64] gpio: GENERIC_GPIO default must be n
[IA64[ add CONFIG_NET_VENDOR_INTEL=y to default config files where needed
[IA64] agp/hp-agp: Allow binding user memory to the AGP GART
[IA64] sn2: add missing put_cpu()
Says Andrew:
"60 patches. That's good enough for -rc1 I guess. I have quite a lot
of detritus to be rechecked, work through maintainers, etc.
- most of the remains of MM
- rtc
- various misc
- cgroups
- memcg
- cpusets
- procfs
- ipc
- rapidio
- sysctl
- pps
- w1
- drivers/misc
- aio"
* akpm: (60 commits)
memcg: replace ss->id_lock with a rwlock
aio: allocate kiocbs in batches
drivers/misc/vmw_balloon.c: fix typo in code comment
drivers/misc/vmw_balloon.c: determine page allocation flag can_sleep outside loop
w1: disable irqs in critical section
drivers/w1/w1_int.c: multiple masters used same init_name
drivers/power/ds2780_battery.c: fix deadlock upon insertion and removal
drivers/power/ds2780_battery.c: add a nolock function to w1 interface
drivers/power/ds2780_battery.c: create central point for calling w1 interface
w1: ds2760 and ds2780, use ida for id and ida_simple_get() to get it
pps gpio client: add missing dependency
pps: new client driver using GPIO
pps: default echo function
include/linux/dma-mapping.h: add dma_zalloc_coherent()
sysctl: make CONFIG_SYSCTL_SYSCALL default to n
sysctl: add support for poll()
RapidIO: documentation update
drivers/net/rionet.c: fix ethernet address macros for LE platforms
RapidIO: fix potential null deref in rio_setup_device()
RapidIO: add mport driver for Tsi721 bridge
Fix typo in code comment.
Signed-off-by: Rakib Mullick <rakib.mullick@gmail.com>
Acked-by: Dmitry Torokhov <dtor@vmware.com>
loop
In vmballoon_reserve_page(), flags has been passed from the callee
function (vmballoon_inflate here). So, we can determine can_sleep outside
the loop.
Interrupting w1_delay() in w1_read_bit() results in missing the low level
on the w1 line and receiving "1" instead of "0".
Add local_irq_save()/local_irq_restore() around the critical section
Signed-off-by: Jan Weitzel <j.weitzel@phytec.de>
Acked-by: Evgeniy Polyakov <zbr@ioremap.net>
When using multiple masters, w1_int.c would use the .init_name from w1.c
for all entities, which will fail when creating a corresponding sysfs
entry. This patch uses the unique name previously generated.
WARNING: at fs/sysfs/dir.c:451 sysfs_add_one+0x48/0x64()
sysfs: cannot create duplicate filename '/devices/w1 bus master'
Modules linked in:
Call trace:
[<9001a604>] warn_slowpath_common+0x34/0x44
[<9001a64c>] warn_slowpath_fmt+0x14/0x18
[<90078020>] sysfs_add_one+0x48/0x64
[<900784ec>] create_dir+0x40/0x68
[<9007857a>] sysfs_create_dir+0x66/0x78
[<900c1a8a>] kobject_add_internal+0x6e/0x104
[<900c1bc0>] kobject_add_varg+0x20/0x2c
[<900c1c1c>] kobject_add+0x30/0x3c
[<900dbd66>] device_add+0x6a/0x378
[<900dbb4a>] device_initialize+0x12/0x48
[<900dc080>] device_register+0xc/0x10
[<900f99be>] w1_add_master_device+0x162/0x274
[<90008e7a>] w1_gpio_probe+0x66/0xb4
[<9000030c>] kernel_init+0x0/0xe8
[<900dde54>] platform_drv_probe+0xc/0xe
[<900dd4f8>] driver_probe_device+0x6c/0xdc
[<900dd5fc>] __driver_attach+0x34/0x48
[<900dcce8>] bus_for_each_dev+0x2c/0x48
[<900dd5c8>] __driver_attach+0x0/0x48
[<900dd38c>] driver_attach+0x10/0x14
[<900dd16a>] bus_add_driver+0x6a/0x18c
[<900dd768>] driver_register+0x60/0xb8
[<90011594>] __initcall_w1_therm_init6+0x0/0x4
[<90008e00>] w1_gpio_init+0x0/0x14
[<900ddf48>] platform_driver_register+0x30/0x38
[<900ddf5e>] platform_driver_probe+0xe/0x3c
[<90008e0c>] w1_gpio_init+0xc/0x14
[<900126d4>] do_one_initcall+0x34/0x130
[<90000372>] kernel_init+0x66/0xe8
[<9001ca3e>] do_exit+0x0/0x3a6
---[ end trace 5a9233884fead918 ]---
kobject_add_internal failed for w1 bus master with -EEXIST, don't try to register things with the same name in the same directory.
Signed-off-by: Florian Faber <faber@faberman.de>
Cc: Evgeniy Polyakov <zbr@ioremap.net>
Fixes the deadlock when inserting and removing the ds2780.
Signed-off-by: Clifton Barnes <cabarnes@indesign-llc.com>
Cc: <stable@kernel.org>
Cc: <stable@vger.kernel.org>
Adds a nolock function to the w1 interface to avoid locking the
mutex if needed.
Simply creates one point to call the w1 interface.
Straightforward. As an aside, the ida_init calls are not needed as far as
I can see needed. (DEFINE_IDA does the same already).
Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk>
Acked-by: Clifton Barnes <cabarnes@indesign-llc.com>
Add "depends on GENERIC_HARDIRQS" to avoid compile breakage on s390:
drivers/built-in.o: In function `pps_gpio_remove':
linux-next/drivers/pps/clients/pps-gpio.c:189: undefined reference to `free_irq'
Cc: James Nuss <jamesnuss@nanometrics.ca>
Cc: Rodolfo Giometti <giometti@enneenne.com>
This client driver allows you to use a GPIO pin as a source for PPS
signals. Platform data [1] are used to specify the GPIO pin number,
label, assert event edge type, and whether clear events are captured.
This driver is based on the work by Ricardo Martins who submitted an
initial implementation [2] of a PPS IRQ client driver to the linuxpps
mailing-list on Dec 3 2010.
[1] include/linux/pps-gpio.h
[2] http://ml.enneenne.com/pipermail/linuxpps/2010-December/004155.html
[akpm@linux-foundation.org: remove unneeded cast of void*]
Signed-off-by: James Nuss <jamesnuss@nanometrics.ca>
Cc: Ricardo Martins <rasm@fe.up.pt>
Acked-by: Rodolfo Giometti <giometti@linux.it>
Signed-off-by: Ricardo Martins <rasm@fe.up.pt>
Cc: Alexander Gordeev <lasaine@lvk.cs.msu.su>
Cc: Igor Plyatov <plyatov@gmail.com>
A default echo function has been provided so it is no longer an error when
you specify PPS_ECHOASSERT or PPS_ECHOCLEAR without an explicit echo
function. This allows some code re-use and also makes it easier to write
client drivers since the default echo function does not normally need to
change.
Reviewed-by: Ben Gardiner <bengardiner@nanometrics.ca>
Modify Ethernet addess macros to be compatible with BE/LE platforms
Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com>
Cc: Chul Kim <chul.kim@idt.com>
Cc: Kumar Gala <galak@kernel.crashing.org>
Cc: Matt Porter <mporter@kernel.crashing.org>
Cc: Li Yang <leoli@freescale.com>
Cc: <stable@kernel.org> [2.6.39+]
The "goto cleanup" path can deference "rswitch" when it is NULL.
Reported-by: Dan Carpenter <error27@gmail.com>
Cc: Dan Carpenter <error27@gmail.com>
Add RapidIO mport driver for IDT TSI721 PCI Express-to-SRIO bridge device.
The driver provides full set of callback functions defined for mport
devices in RapidIO subsystem. It also is compatible with current version
of RIONET driver (Ethernet over RapidIO messaging services).
This patch is applicable to kernel versions starting from 2.6.39.
Signed-off-by: Chul Kim <chul.kim@idt.com>
complete
The discovered bit in PGCCSR register indicates if the device has been
discovered by system host. In Rapidio systems, some agent devices can also
be master devices. They can issue requests into the system.
Signed-off-by: Liu Gang <Gang.Liu@freescale.com>
Acked-by: Alexandre Bounine <alexandre.bounine@idt.com>
.exit.text
The driver is added using platform_driver_probe(), so the callbacks can be
discarded more aggessively.
Cc: Alessandro Zummo <a.zummo@towertech.it>
Add initial support for the microchip mcp7941x series of real time clocks.
The mcp7941x series is generally compatible with the ds1307 and ds1337 rtc
devices from dallas semiconductor. minor differences include a backup
battery enable bit, and the polarity of the oscillator enable bit.
Signed-off-by: David Anders <danders.dev@gmail.com>
Reviewed-by: Wolfram Sang <w.sang@pengutronix.de>
This is the one use of an ida that doesn't retry on receiving -EAGAIN.
I'm assuming do so will cause no harm and may help on a rare occasion.
* git://github.com/rustyrussell/linux:
virtio-blk: use ida to allocate disk index
virtio: Add platform bus driver for memory mapped virtio device
virtio: Dont add "config" to list for !per_vq_vector
virtio: console: wait for first console port for early console output
virtio: console: add port stats for bytes received, sent and discarded
virtio: console: make discard_port_data() use get_inbuf()
virtio: console: rename variable
virtio: console: make get_inbuf() return port->inbuf if present
virtio: console: Fix return type for get_inbuf()
virtio: console: Use wait_event_freezable instead of _interruptible
virtio: console: Ignore port name update request if name already set
virtio: console: Fix indentation
virtio: modify vring_init and vring_size to take account of the layout containing *_event_idx
virtio.h: correct comment for struct virtio_driver
virtio-net: Use virtio_config_val() for retrieving config
virtio_config: Add virtio_config_val_len()
virtio-console: Use virtio_config_val() for retrieving config
git://git.kernel.org/pub/scm/linux/kernel/git/hch/vfs-queue
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/hch/vfs-queue:
vfs: add d_prune dentry operation
vfs: protect i_nlink
filesystems: add set_nlink()
filesystems: add missing nlink wrappers
logfs: remove unnecessary nlink setting
ocfs2: remove unnecessary nlink setting
jfs: remove unnecessary nlink setting
hypfs: remove unnecessary nlink setting
vfs: ignore error on forced remount
readlinkat: ensure we return ENOENT for the empty pathname for normal lookups
vfs: fix dentry leak in simple_fill_super()
* 'for-linus' of git://github.com/richardweinberger/linux: (90 commits)
um: fix ubd cow size
um: Fix kmalloc argument order in um/vdso/vma.c
um: switch to use of drivers/Kconfig
UserModeLinux-HOWTO.txt: fix a typo
UserModeLinux-HOWTO.txt: remove ^H characters
um: we need sys/user.h only on i386
um: merge delay_{32,64}.c
um: distribute exports to where exported stuff is defined
um: kill system-um.h
um: generic ftrace.h will do...
um: segment.h is x86-only and needed only there
um: asm/pda.h is not needed anymore
um: hw_irq.h can go generic as well
um: switch to generic-y
um: clean Kconfig up a bit
um: a couple of missing dependencies...
um: kill useless argument of free_chan() and free_one_chan()
um: unify ptrace_user.h
um: unify KSTK_...
um: fix gcov build breakage
Signed-off-by: Richard Weinberger <richard@nod.at>
* kill duplicates with drivers/char/Kconfig
* take watchdog one into drivers/watchdog/Kconfig
* take mmapper to arch/um/Kconfig.um
* rename Kconfig.char menu to "UML Character Devices"
Replace remaining direct i_nlink updates with a new set_nlink()
updater function.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Tested-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com>
Replace direct i_nlink updates with the respective updater function
(inc_nlink, drop_nlink, clear_nlink, inode_dec_link_count).
* 'next/dt' of git://git.linaro.org/people/arnd/arm-soc:
ARM: gic: use module.h instead of export.h
ARM: gic: fix irq_alloc_descs handling for sparse irq
ARM: gic: add OF based initialization
ARM: gic: add irq_domain support
irq: support domains with non-zero hwirq base
of/irq: introduce of_irq_init
ARM: at91: add at91sam9g20 and Calao USB A9G20 DT support
ARM: at91: dt: at91sam9g45 family and board device tree files
arm/mx5: add device tree support for imx51 babbage
arm/mx5: add device tree support for imx53 boards
ARM: msm: Add devicetree support for msm8660-surf
msm_serial: Add devicetree support
msm_serial: Use relative resources for iomem
Fix up conflicts in arch/arm/mach-at91/{at91sam9260.c,at91sam9g45.c}
* 'next/cleanup2' of git://git.linaro.org/people/arnd/arm-soc: (31 commits)
ARM: OMAP: Warn if omap_ioremap is called before SoC detection
ARM: OMAP: Move set_globals initialization to happen in init_early
ARM: OMAP: Map SRAM later on with ioremap_exec()
ARM: OMAP: Remove calls to SRAM allocations for framebuffer
ARM: OMAP: Avoid cpu_is_omapxxxx usage until map_io is done
ARM: OMAP1: Use generic map_io, init_early and init_irq
arm/dts: OMAP3+: Add mpu, dsp and iva nodes
arm/dts: OMAP4: Add a main ocp entry bound to l3-noc driver
ARM: OMAP2+: l3-noc: Add support for device-tree
ARM: OMAP2+: board-generic: Add i2c static init
ARM: OMAP2+: board-generic: Add DT support to generic board
arm/dts: Add support for OMAP3 Beagle board
arm/dts: Add initial device tree support for OMAP3 SoC
arm/dts: Add support for OMAP4 SDP board
arm/dts: Add support for OMAP4 PandaBoard
arm/dts: Add initial device tree support for OMAP4 SoC
ARM: OMAP: omap_device: Add a method to build an omap_device from a DT node
ARM: OMAP: omap_device: Add omap_device_[alloc|delete] for DT integration
of: Add helpers to get one string in multiple strings property
ARM: OMAP2+: devices: Remove all omap_device_pm_latency structures
Fix up trivial header file conflicts in arch/arm/mach-omap2/board-generic.c
* 'next/devel' of git://git.linaro.org/people/arnd/arm-soc: (50 commits)
ARM: tegra: update defconfig
arm/tegra: Harmony: Configure PMC for low-level interrupts
arm/tegra: device tree support for ventana board
arm/tegra: add support for ventana pinmuxing
arm/tegra: prepare Seaboard pinmux code for derived boards
arm/tegra: pinmux: ioremap registers
gpio/tegra: Convert to a platform device
arm/tegra: Convert pinmux driver to a platform device
arm/dt: Tegra: Add pinmux node to tegra20.dtsi
arm/tegra: Prep boards for gpio/pinmux conversion to pdevs
ARM: mx5: fix clock usage for suspend
ARM i.MX entry-macro.S: remove now unused code
ARM i.MX boards: use CONFIG_MULTI_IRQ_HANDLER
ARM i.MX tzic: add handle_irq function
ARM i.MX avic: add handle_irq function
ARM: mx25: Add the missing IIM base definition
ARM i.MX avic: convert to use generic irq chip
mx31moboard: Add poweroff support
ARM: mach-qong: Add watchdog support
ARM: davinci: AM18x: Add wl1271/wlan support
Fix up conflicts in:
arch/arm/mach-at91/at91sam9g45.c
arch/arm/mach-mx5/devices-imx53.h
arch/arm/plat-mxc/include/mach/memory.h
* 'next/timer' of git://git.linaro.org/people/arnd/arm-soc:
clocksource: fixup ux500 build problems
ARM: omap: use __devexit_p in dmtimer driver
ARM: ux500: Reprogram timers upon resume
ARM: plat-nomadik: timer: Export reset functions
ARM: plat-nomadik: timer: Add support for periodic timers
ARM: ux500: Move timer code to separate file
ARM: ux500: add support for clocksource DBX500 PRCMU
clocksource: add DBX500 PRCMU Timer support
ARM: plat-nomadik: MTU sched_clock as an option
ARM: OMAP: dmtimer: add error handling to export APIs
ARM: OMAP: dmtimer: low-power mode support
ARM: OMAP: dmtimer: skip reserved timers
ARM: OMAP: dmtimer: pm_runtime support
ARM: OMAP: dmtimer: switch-over to platform device driver
ARM: OMAP: dmtimer: platform driver
ARM: OMAP2+: dmtimer: convert to platform devices
ARM: OMAP1: dmtimer: conversion to platform devices
ARM: OMAP2+: dmtimer: add device names to flck nodes
ARM: OMAP: Add support for dmtimer v2 ip
* 'next/driver' of git://git.linaro.org/people/arnd/arm-soc:
hw_random: add driver for atmel true hardware random number generator
ARM: at91: at91sam9g45: add trng clock and platform device
MX53 Enable the AHCI SATA on MX53 SMD board
MX53 Enable the AHCI SATA on MX53 LOCO board
MX53 Enable the AHCI SATA on MX53 ARD board
AHCI Add the AHCI SATA feature on the MX53 platforms
Fix pata imx resource
ARM: imx: Define functions for registering PATA
ARM: imx: Add PATA clock support
ARM: imx: Add PATA resources for other i.MX processors
imx: efika: Enable pata.
imx51: add pata clock
imx51: add pata device
Fix up trivial conflict (new selects next to each other from separate
branches for EFIKA_COMMON) in arch/arm/mach-mx5/Kconfig
* 'next/cleanup' of git://git.linaro.org/people/arnd/arm-soc: (125 commits)
ARM: mach-mxs: fix machines' initializers order
mmc: mxcmmc: explicitly includes mach/hardware.h
arm/imx: explicitly includes mach/hardware.h in pm-imx27.c
arm/imx: remove mx27_setup_weimcs() from mx27.h
arm/imx: explicitly includes mach/hardware.h in mach-kzm_arm11_01.c
arm/imx: remove mx31_setup_weimcs() from mx31.h
ARM: tegra: devices.c should include devices.h
ARM: tegra: cpu-tegra: unexport two functions
ARM: tegra: cpu-tegra: sparse type fix
ARM: tegra: dma: staticify some tables and functions
ARM: tegra: tegra2_clocks: don't export some tables
ARM: tegra: tegra_powergate_is_powered should be static
ARM: tegra: tegra_rtc_read_ms should be static
ARM: tegra: tegra_init_cache should be static
ARM: tegra: pcie: 0 -> NULL changes
ARM: tegra: pcie: include board.h
ARM: tegra: pcie: don't cast __iomem pointers
ARM: tegra: tegra2_clocks: 0 -> NULL changes
ARM: tegra: tegra2_clocks: don't cast __iomem pointers
ARM: tegra: timer: don't cast __iomem pointers
Fix up trivial conflicts in
arch/arm/mach-omap2/Makefile,
arch/arm/mach-u300/{Makefile.boot,core.c}
arch/arm/plat-{mxc,omap}/devices.c
* 'next/fixes' of git://git.linaro.org/people/arnd/arm-soc: (28 commits)
ARM: pxa/cm-x300: properly set bt_reset pin
ARM: mmp: rename SHEEVAD to GPLUGD
ARM: imx: Fix typo 'MACH_MX31_3DS_MXC_NAND_USE_BBT'
ARM: i.MX28: shift frac value in _CLK_SET_RATE
plat-mxc: iomux-v3.h: implicitly enable pull-up/down when that's desired
ARM: pxa: use correct __iomem annotations
ARM: pxa: sharpsl pm needs SPI
ARM: pxa: centro and treo680 need palm27x
ARM: pxa: make pxafb_smart_*() empty when not enabled
ARM: pxa: select POWER_SUPPLY on raumfeld
ARM: pxa: pxa95x is incompatible with earlier pxa
ARM: pxa: CPU_FREQ_TABLE is needed for CPU_FREQ
ARM: pxa: pxa95x/saarb depends on pxa3xx code
ARM: pxa: allow selecting just one of TREO680/CENTRO
ARM: pxa: export symbols from pxa3xx-ulpi
ARM: pxa: make zylonite_pxa*_init declaration match code
ARM: pxa/z2: fix building error of pxa27x_cpu_suspend() no longer available
ARM: at91: add defconfig for at91sam9g45 family
ARM: at91: remove dependency for Atmel PWM driver selector in Kconfig
Based on a patch by Mark Wu <dwu@redhat.com>
Current index allocation in virtio-blk is based on a monotonically
increasing variable "index". This means we'll run out of numbers
after a while. It also could cause confusion about the disk
name in the case of hot-plugging disks.
Change virtio-blk to use ida to allocate index, instead.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
This patch, based on virtio PCI driver, adds support for memory
mapped (platform) virtio device. This should allow environments
like qemu to use virtio-based block & network devices even on
platforms without PCI support.
One can define and register a platform device which resources
will describe memory mapped control registers and "mailbox"
interrupt. Such device can be also instantiated using the Device
Tree node with compatible property equal "virtio,mmio".
Cc: Anthony Liguori <aliguori@us.ibm.com>
Cc: Michael S.Tsirkin <mst@redhat.com>
Signed-off-by: Pawel Moll <pawel.moll@arm.com>
For the MSI but non-per_vq_vector case, the config/change vq
also gets added to the list of vqs that need to process the
MSI interrupt. This is not needed as config has it's own
handler (vp_config_changed). In any case, vring_interrupt()
finds nothing needs to be done on this vq.
I tested this patch by testing the "Fallback:" and "Finally
fall back" cases in vp_find_vqs(). Please review.
Signed-off-by: Krishna Kumar <krkumar2@in.ibm.com>
Acked-by: Michael S. Tsirkin <mst@redhat.com>
On s390 I have seen some random
"Warning: unable to open an initial console"
boot failure. Turns out that tty_open fails, because the
hvc_alloc was not yet done. In former times this could not happen,
since the probe function automatically called hvc_alloc. With newer
versions (multiport) some host<->guest interaction is required
before hvc_alloc is called. This might be too late, especially if
an initramfs is involved. Lets use a completion if we have
multiport and an early console.
[Amit:
* Use NULL instead of 0 for pointer comparison
* Rename 'port_added' to 'early_console_added'
* Re-format, re-word commit message
* Rebase patch on top of current queue]
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Signed-off-by: Amit Shah <amit.shah@redhat.com>
Acked-by: Chrstian Borntraeger <borntraeger@de.ibm.com>
This commit adds port-specific stats for the number of bytes received,
sent and discarded. They're exposed via the debugfs interface. This
data can be used to check for data loss bugs (or disprove such claims).
It can also be used for accounting, if there's such a need.
The stats remain valid throughout the lifetime of the port. Unplugging
a port will reset the stats. The numbers are not reset across port
opens/closes.
discard_port_data() used virtqueue_get_buf() directly instead of using
get_inbuf(). Fix this, so that we get accounting for all received
bytes. This also simplifies the code a lot.
'ret' is a misnomer in discard_port_data() since we don't return the
value. Rename it to 'err'.
Instead of pulling in a buffer from the vq each time it's called,
get_inbuf() now checks if the current active buffer, in port->inbuf is
valid. If it is, just returns a pointer to it. This ends up
simplifying a lot of code calling get_inbuf() since the check for
port->inbuf being valid was done by all the callers.
get_inbuf() returns void *. There's no reason to return void pointers
instead of the correct struct port_buffer *.
Get ready to support suspend/resume by using the freezable calls so that
blocking read/write syscalls are handled properly across suspend/resume.
We don't allow port name changes dynamically for a port. So any
requests by the host to change the name are ignored.
Before this patch, if the hypervisor sent a port name while we had one
set already, we would leak memory equivalent to the size of the old
name.
This scenario wasn't expected so far, but with the suspend-resume
support, we'll send the VIRTIO_CONSOLE_PORT_READY message after restore,
which can get us into this situation.
Convert spaces to tabs and fix indentation for an if statement split
into multiple lines.
This patch modifies virtio-net to use virtio_config_val() instead
of a 'if(virtio_has_feature()) vdev->config->get()' construct to retrieve
optional values from the config space.
Cc: Amit Shah <amit.shah@redhat.com>
Cc: "Michael S. Tsirkin" <mst@redhat.com>
Cc: virtualization@lists.linux-foundation.org
Signed-off-by: Sasha Levin <levinsasha928@gmail.com>
