path: root/drivers
2013-03-13Merge branch 'akpm' (fixes from Andrew)Linus Torvalds
Merge misc fixes from Andrew Morton: - A bunch of fixes - Finish off the idr API conversions before someone starts to use the old interfaces again. * emailed patches from Andrew Morton <akpm@linux-foundation.org>: idr: idr_alloc() shouldn't trigger lowmem warning when preloaded UAPI: fix endianness conditionals in M32R's asm/stat.h UAPI: fix endianness conditionals in linux/raid/md_p.h UAPI: fix endianness conditionals in linux/acct.h UAPI: fix endianness conditionals in linux/aio_abi.h decompressors: fix typo "POWERPC" mm/fremap.c: fix oops on error path idr: deprecate idr_pre_get() and idr_get_new[_above]() tidspbridge: convert to idr_alloc() zcache: convert to idr_alloc() mlx4: remove leftover idr_pre_get() call workqueue: convert to idr_alloc() nfsd: convert to idr_alloc() nfsd: remove unused get_new_stid() kernel/signal.c: use __ARCH_HAS_SA_RESTORER instead of SA_RESTORER signal: always clear sa_restorer on execve mm: remove_memory(): fix end_pfn setting include/linux/res_counter.h needs errno.h
2013-03-13tidspbridge: convert to idr_alloc()Tejun Heo
idr_get_new*() and friends are about to be deprecated. Convert to the new idr_alloc() interface. There are some peculiarities and possible bugs in the converted functions. This patch preserves those. * drv_insert_node_res_element() returns -ENOMEM on alloc failure, -EFAULT if id space is exhausted. -EFAULT is at best misleading. * drv_proc_insert_strm_res_element() is even weirder. It returns -EFAULT if kzalloc() fails, -ENOMEM if idr preloading fails and -EPERM if id space is exhausted. What's going on here? * drv_proc_insert_strm_res_element() doesn't free *pstrm_res after failure. Only compile tested. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Víctor Manuel Jáquez Leal <vjaquez@igalia.com> Cc: Rene Sapiens <rene.sapiens@ti.com> Cc: Armando Uribe <x0095078@ti.com> Cc: Omar Ramirez Luna <omar.ramirez@ti.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-13zcache: convert to idr_alloc()Tejun Heo
idr_get_new*() and friends are about to be deprecated. Convert to the new idr_alloc() interface. Only compile tested. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Dan Magenheimer <dan.magenheimer@oracle.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-13mlx4: remove leftover idr_pre_get() callTejun Heo
Commit 6a9200603d76 ("IB/mlx4: convert to idr_alloc()") forgot to remove idr_pre_get() call in mlx4_ib_cm_paravirt_init(). It's unnecessary and idr_pre_get() will soon be deprecated. Remove it. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Jack Morgenstein <jackm@dev.mellanox.co.il> Cc: Or Gerlitz <ogerlitz@mellanox.com> Cc: Roland Dreier <roland@purestorage.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-13Merge tag 'usb-3.9-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB fixes from Greg Kroah-Hartman: "Here are a number of tiny USB fixes and new USB device ids for your 3.9 tree. The "largest" one here is a revert of a usb-storage patch that turned out to be incorrect, breaking existing users, which is never a good thing. Everything else is pretty simple and small" * tag 'usb-3.9-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (43 commits) USB: quatech2: only write to the tty if the port is open. qcserial: bind to DM/DIAG port on Gobi 1K devices USB: cdc-wdm: fix buffer overflow usb: serial: Add Rigblaster Advantage to device table qcaux: add Franklin U600 usb: musb: core: fix possible build error with randconfig usb: cp210x new Vendor/Device IDs usb: gadget: pxa25x: fix disconnect reporting usb: dwc3: ep0: fix sparc64 build usb: c67x00 RetryCnt value in c67x00 TD should be 3 usb: Correction to c67x00 TD data length mask usb: Makefile: fix drivers/usb/phy/ Makefile entry USB: added support for Cinterion's products AH6 and PLS8 usb: gadget: fix omap_udc build errors USB: storage: fix Huawei mode switching regression USB: storage: in-kernel modeswitching is deprecated tools: usb: ffs-test: Fix build failure USB: option: add Huawei E5331 usb: musb: omap2430: fix sparse warning usb: musb: omap2430: fix omap_musb_mailbox glue check again ...
2013-03-13Merge tag 'tty-3.9-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty/serial fixes from Greg Kroah-Hartman: "Here are some tty/serial driver fixes for 3.9 We finally mute the annoying WARN_ON that lots of people are hitting and it turns out isn't needed anymore. Also add a few new device ids and a some other minor fixes." * tag 'tty-3.9-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: tty: serial: fix typo "SERIAL_S3C2412" serial: 8250: Keep 8250.<xxxx> module options functional after driver rename tty: serial: fix typo "ARCH_S5P6450" tty/8250_pnp: serial port detection regression since v3.7 serial: bcm63xx_uart: fix compilation after "TTY: switch tty_insert_flip_char" serial: 8250_pci: add support for another kind of NetMos Technology PCI 9835 Multi-I/O Controller Fix 4 port and add support for 8 port 'Unknown' PCI serial port cards tty/serial: Add support for Altera serial port tty: serial: vt8500: Unneccessary duplicated clock code removed tty: serial: mpc5xxx: fix PSC clock name bug TTY: disable debugging warning
2013-03-13Merge tag 'staging-3.9-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging Pull staging tree fixes from Greg Kroah-Hartman: "Here are some drivers/staging and drivers/iio fixes for 3.9 (the two are still pretty intertwined, hence them coming both from my tree still.) Nothing major, just a few things that have been reported by users, all of these have been in linux-next for a while." * tag 'staging-3.9-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: staging: comedi: dt9812: use CR_CHAN() for channel number staging/vt6656: Fix too large integer constant warning on 32-bit staging: comedi: drivers: usbduxsigma.c: fix DMA buffers on stack staging: imx/drm: request irq only after adding the crtc staging: comedi: drivers: usbduxfast.c: fix for DMA buffers on stack staging: comedi: drivers: usbdux.c: fix DMA buffers on stack staging: vt6656: Fix oops on resume from suspend. iio:common:st_sensors fixed all warning messages about uninitialized variables iio: Fix build error seen if IIO_TRIGGER is defined but IIO_BUFFER is not iio/imu: inv_mpu6050 depends on IIO_BUFFER iio:ad5064: Initialize register cache correctly iio:ad5064: Fix off by one in DAC value range check iio:ad5064: Fix address of the second channel for ad5065/ad5045/ad5025
2013-03-13USB: quatech2: only write to the tty if the port is open.Bill Pemberton
The commit 2e124b4a390ca85325fae75764bef92f0547fa25 removed the checks that prevented qt2_process_read_urb() from trying to put chars into ttys that weren't actually opened. This resulted in 'tty is NULL' warnings from flush_to_ldisc() when the device was used. The devices use just one read urb for all ports. As a result qt2_process_read_urb() may be called with the current port set to a port number that has not been opened. Add a check if the port is open before calling tty_flip_buffer_push(). Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-13qcserial: bind to DM/DIAG port on Gobi 1K devicesDan Williams
Turns out we just need altsetting 1 and then we can talk to it. Signed-off-by: Dan Williams <dcbw@redhat.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-12Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull virtio rng buffix from Rusty Russell: "Simple virtio-rng fix." * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: virtio: rng: disallow multiple device registrations, fixes crashes
2013-03-12Merge tag 'stable/for-linus-3.9-rc2-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen Pull Xen fixes from Konrad Rzeszutek Wilk: - Compile warnings and errors (one on x86, two on ARM) - WARNING in xen-pciback - Use the acpi_processor_get_performance_info instead of the 'register' version * tag 'stable/for-linus-3.9-rc2-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen/acpi: remove redundant acpi/acpi_drivers.h include xen: arm: mandate EABI and use generic atomic operations. acpi: Export the acpi_processor_get_performance_info xen/pciback: Don't disable a PCI device that is already disabled.
2013-03-12USB: cdc-wdm: fix buffer overflowOliver Neukum
The buffer for responses must not overflow. If this would happen, set a flag, drop the data and return an error after user space has read all remaining data. Signed-off-by: Oliver Neukum <oliver@neukum.org> CC: stable@kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-12Merge branch 'drm-fixes' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm nouveau fixes from Dave Airlie: "This is just nouveau fixes from Ben, one fixes a nasty oops that some Fedora people have been seeing, so I'd like to get it out of the way." * 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: drm/nv50: use correct tiling methods for m2mf buffer moves drm/nouveau: idle channel before releasing notify object drm/nouveau: fix regression in vblanking drm/nv50: encoder creation failure doesn't mean full init failure
2013-03-12Merge tag 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC fixes from Arnd Bergmann: "These bug fixes are for the largest part for mvebu/kirkwood, which saw a few regressions after the clock infrastructure was enabled, and for OMAP, which showed a few more preexisting bugs with the new multiplatform support. Other small fixes are for imx, mxs, tegra, spear and socfpga" * tag 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (37 commits) ARM: spear3xx: Use correct pl080 header file Arm: socfpga: pl330: Add #dma-cells for generic dma binding support ARM: multiplatform: Sort the max gpio numbers. ARM: imx: fix typo "DEBUG_IMX50_IMX53_UART" ARM: imx: pll1_sys should be an initial on clk arm: mach-orion5x: fix typo in compatible string of a .dts file arm: mvebu: fix address-cells in mpic DT node arm: plat-orion: fix address decoding when > 4GB is used arm: mvebu: Reduce reg-io-width with UARTs ARM: Dove: add RTC device node arm: mvebu: enable the USB ports on Armada 370 Reference Design board ARM: dove: drop "select COMMON_CLK_DOVE" rtc: rtc-mv: Add support for clk to avoid lockups gpio: mvebu: Add clk support to prevent lockup ARM: kirkwood: fix to retain gbe MAC addresses for DT kernels ARM: kirkwood: of_serial: fix clock gating by removing clock-frequency ARM: mxs: cfa10049: Fix fb initialisation function ARM: SPEAr13xx: Fix typo "ARCH_HAVE_CPUFREQ" ARM: OMAP: RX-51: add missing USB phy binding clk: Tegra: Remove duplicate smp_twd clock ...
2013-03-12usb: serial: Add Rigblaster Advantage to device tableSteve Conklin
The Rigblaster Advantage is an amateur radio interface sold by West Mountain Radio. It contains a cp210x serial interface but the device ID is not in the driver. Signed-off-by: Steve Conklin <sconklin@canonical.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-12tty: serial: fix typo "SERIAL_S3C2412"Paul Bolle
The Kconfig symbol SERIAL_S3C2412 got removed in commit da121506eb03ee5daea55404709110b798bd61d9 ("serial: samsung: merge probe() function from all SoC specific extensions"). But it also added a last reference to that symbol. The commit and the tree make clear that CPU_S3C2412 should have been used instead. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-12serial: 8250: Keep 8250.<xxxx> module options functional after driver renameJosh Boyer
With commit 835d844d1 (8250_pnp: do pnp probe before legacy probe), the 8250 driver was renamed to 8250_core. This means any existing usage of the 8259.<xxxx> module parameters or as a kernel command line switch is now broken, as the 8250_core driver doesn't parse options belonging to something called "8250". To solve this, we redefine the module options in a dummy function using a redefined MODULE_PARAM_PREFX when built into the kernel. In the case where we're building as a module, we provide an alias to the old 8250 name. The dummy function prevents compiler errors due to global variable redefinitions that happen as part of the module_param_ macro expansions. Signed-off-by: Josh Boyer <jwboyer@redhat.com> Acked-by: Jiri Slaby <jslaby@suse.cz> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-12tty: serial: fix typo "ARCH_S5P6450"Paul Bolle
This could have been either ARCH_S5P64X0 or CPU_S5P6450. Looking at commit 2555e663b367b8d555e76023f4de3f6338c28d6c ("ARM: S5P64X0: Add UART serial support for S5P6450") - which added this typo - makes clear this should be CPU_S5P6450. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-12tty/8250_pnp: serial port detection regression since v3.7Sean Young
The InsydeH2O BIOS (version dated 09/12/2011) has the following in its pnp resouces for its serial ports: $ cat /sys/bus/pnp/devices/00:0b/resources state = active io disabled irq disabled We do not check if the resources are disabled, and create a bogus ttyS* device. Since commit 835d844d1a28e (8250_pnp: do pnp probe before legacy probe) we get a bogus ttyS0, which prevents the legacy probe from detecting it. Note, the BIOS can also be upgraded, fixing this problem, but for people who can't do that, this fix is needed. Reported-by: Vincent Deffontaines <vincent@gryzor.com> Tested-by: Vincent Deffontaines <vincent@gryzor.com> Signed-off-by: Sean Young <sean@mess.org> Cc: stable@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-12serial: bcm63xx_uart: fix compilation after "TTY: switch tty_insert_flip_char"Jonas Gorski
92a19f9cec9a80ad93c06e115822deb729e2c6ad introduced a local variable with the same name as the argument to bcm_uart_do_rx, breaking compilation. Fix this by renaming the new variable and its uses where expected. Signed-off-by: Jonas Gorski <jogo@openwrt.org> Acked-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-12serial: 8250_pci: add support for another kind of NetMos Technology PCI 9835 ↵Wang YanQing
Multi-I/O Controller 01:08.0 Communication controller: NetMos Technology PCI 9835 Multi-I/O Controller (rev 01) Subsystem: Device [1000:0012] Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx- Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx- Interrupt: pin A routed to IRQ 20 Region 0: I/O ports at e050 [size=8] Region 1: I/O ports at e040 [size=8] Region 2: I/O ports at e030 [size=8] Region 3: I/O ports at e020 [size=8] Region 4: I/O ports at e010 [size=8] Region 5: I/O ports at e000 [size=16] Signed-off-by: Wang YanQing <udknight@gmail.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-12Fix 4 port and add support for 8 port 'Unknown' PCI serial port cardsScott Ashcroft
I've managed to find an 8 port version of the card 4 port card which was discussed here: http://marc.info/?l=linux-serial&m=120760744205314&w=2 Looking back at that thread there were two issues in the original patch. 1) The I/O ports for the UARTs are within BAR2 not BAR0. This can been seen in the original post. 2) A serial quirk isn't needed as these cards have no memory in BAR0 which makes pci_plx9050_init just return. This patch fixes the 4 port support to use BAR2, removes the bogus quirk and adds support for the 8 port card. $ lspci -vvv -n -s 00:08.0 00:08.0 0780: 10b5:9050 (rev 01) Subsystem: 10b5:1588 Control: I/O+ Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx- Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx- Interrupt: pin A routed to IRQ 17 Region 1: I/O ports at ff00 [size=128] Region 2: I/O ports at fe00 [size=64] Region 3: I/O ports at fd00 [size=8] Capabilities: <access denied> Kernel driver in use: serial $ dmesg | grep 0000:00:08.0: [ 0.083320] pci 0000:00:08.0: [10b5:9050] type 0 class 0x000780 [ 0.083355] pci 0000:00:08.0: reg 14: [io 0xff00-0xff7f] [ 0.083369] pci 0000:00:08.0: reg 18: [io 0xfe00-0xfe3f] [ 0.083382] pci 0000:00:08.0: reg 1c: [io 0xfd00-0xfd07] [ 0.083460] pci 0000:00:08.0: PME# supported from D0 D3hot [ 1.212867] 0000:00:08.0: ttyS4 at I/O 0xfe00 (irq = 17) is a 16550A [ 1.233073] 0000:00:08.0: ttyS5 at I/O 0xfe08 (irq = 17) is a 16550A [ 1.253270] 0000:00:08.0: ttyS6 at I/O 0xfe10 (irq = 17) is a 16550A [ 1.273468] 0000:00:08.0: ttyS7 at I/O 0xfe18 (irq = 17) is a 16550A [ 1.293666] 0000:00:08.0: ttyS8 at I/O 0xfe20 (irq = 17) is a 16550A [ 1.313863] 0000:00:08.0: ttyS9 at I/O 0xfe28 (irq = 17) is a 16550A [ 1.334061] 0000:00:08.0: ttyS10 at I/O 0xfe30 (irq = 17) is a 16550A [ 1.354258] 0000:00:08.0: ttyS11 at I/O 0xfe38 (irq = 17) is a 16550A Signed-off-by: Scott Ashcroft <scott.ashcroft@talk21.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-12tty/serial: Add support for Altera serial portLey Foon Tan
Add support for Altera 8250/16550 compatible serial port. Signed-off-by: Ley Foon Tan <lftan@altera.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-12tty: serial: vt8500: Unneccessary duplicated clock code removedTony Prisk
Remove the extra code left over when the serial driver was changed to require a clock. There is no fallback to 24Mhz as a clock is now required. Also remove a second call to of_clk_get which is unnecessary. Signed-off-by: Tony Prisk <linux@prisktech.co.nz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-12tty: serial: mpc5xxx: fix PSC clock name bugAnatolij Gustschin
mpc512x platform clock code names PSC clocks as "pscX_mclk" but the driver tries to get "pscX_clk" clock and this results in errors like: mpc52xx-psc-uart 80011700.psc: Failed to get PSC clock entry! The problem appears when opening ttyPSC devices other than the system's serial console. Since getting and enabling the PSC clock fails, uart port startup doesn't succeed and tty flag TTY_IO_ERROR remains set causing further errors in tty ioctls, i.e. 'strace stty -F /dev/ttyPSC1' shows: open("/dev/ttyPSC1", O_RDONLY|O_NONBLOCK|O_LARGEFILE) = 3 dup2(3, 0) = 0 close(3) = 0 fcntl64(0, F_GETFL) = 0x10800 (flags O_RDONLY|O_NONBLOCK|O_LARGEFILE) fcntl64(0, F_SETFL, O_RDONLY|O_LARGEFILE) = 0 ioctl(0, TCGETS, 0xbff89038) = -1 EIO (Input/output error) Only request PSC clock names that the platform actually provides. Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-11Merge tag 'mvebu_fixes_for_v3.9' of ↵Arnd Bergmann
git://git.infradead.org/users/jcooper/linux into fixes mvebu fixes for v3.9 from Jason Cooper <jason@lakedaemon.net>: The first four patches: 89c58c1 rtc: rtc-mv: Add support for clk to avoid lockups de88747 gpio: mvebu: Add clk support to prevent lockup 7bf5b40 ARM: kirkwood: fix to retain gbe MAC addresses for DT kernels 93fff4c ARM: kirkwood: of_serial: fix clock gating by removing clock-frequency are Cc'd to stable since they were held over from the previous merge window. The rest are a small collection of fixes and a couple of devicetree conversion catchups. * tag 'mvebu_fixes_for_v3.9' of git://git.infradead.org/users/jcooper/linux: arm: mach-orion5x: fix typo in compatible string of a .dts file arm: mvebu: fix address-cells in mpic DT node arm: plat-orion: fix address decoding when > 4GB is used arm: mvebu: Reduce reg-io-width with UARTs ARM: Dove: add RTC device node arm: mvebu: enable the USB ports on Armada 370 Reference Design board ARM: dove: drop "select COMMON_CLK_DOVE" rtc: rtc-mv: Add support for clk to avoid lockups gpio: mvebu: Add clk support to prevent lockup ARM: kirkwood: fix to retain gbe MAC addresses for DT kernels ARM: kirkwood: of_serial: fix clock gating by removing clock-frequency Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2013-03-11qcaux: add Franklin U600Dan Williams
4 ports; AT/PPP is standard CDC-ACM. The other three (added by this patch) are QCDM/DIAG, possibly GPS, and unknown. Signed-off-by: Dan Williams <dcbw@redhat.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-11usb: musb: core: fix possible build error with randconfigFelipe Balbi
when making commit e574d57 (usb: musb: fix compile warning) I forgot to git add this part of the patch which ended up introducing a possible build error. Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-11xen/acpi: remove redundant acpi/acpi_drivers.h includeLiu Jinsong
It's redundant since linux/acpi.h has include it when CONFIG_ACPI enabled, and when CONFIG_ACPI disabled it will trigger compiling warning In file included from drivers/xen/xen-stub.c:28:0: include/acpi/acpi_drivers.h:103:31: warning: 'struct acpi_device' declared inside parameter list [enabled by default] include/acpi/acpi_drivers.h:103:31: warning: its scope is only this definition or declaration, which is probably not what you want [enabled by default] include/acpi/acpi_drivers.h:107:43: warning: 'struct acpi_pci_root' declared inside parameter list [enabled by default] Reported-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Liu Jinsong <jinsong.liu@intel.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2013-03-11staging: comedi: dt9812: use CR_CHAN() for channel numberIan Abbott
As pointed out by Dan Carpenper in <http://driverdev.linuxdriverproject.org/pipermail/devel/2013-February/036025.html>, the dt9812 comedi driver's use of the `chanspec` member of `struct comedi_insn` as a channel number is incorrect. Change it to use `CR_CHAN(insn->chanspec)` as the channel number (where `insn` is a pointer to the `struct comedi_insn` being processed). Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Cc: stable <stable@vger.kernel.org> # 3.8 onwards Cc: Anders Blomdell <anders.blomdell@control.lth.se> Signed-off-by: Ian Abbott <abbotti@mev.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-11staging/vt6656: Fix too large integer constant warning on 32-bitGeert Uytterhoeven
drivers/staging/vt6656/card.c: In function ‘CARDqGetNextTBTT’: drivers/staging/vt6656/card.c:793: warning: integer constant is too large for ‘unsigned long’ type Commit c7b7cad0d8df823ea063c86a54316bbcbfa04a7c ("staging/vt6656: Fix sparse warning constant 0xffffffff00000000U is so big it is unsigned long") changed the constant to "0xffffffff00000000UL", but that only works on 64-bit. Change it "0xffffffff00000000ULL" to fix it for 32-bit, too. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Reviewed-by: Peter Huewe <peterhuewe@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-11staging: comedi: drivers: usbduxsigma.c: fix DMA buffers on stackKumar Amit Mehta
This patch fixes an instance of DMA buffer on stack(being passed to usb_control_msg)for the USB-DUXsigma Board driver. Found using smatch. Signed-off-by: Kumar Amit Mehta <gmate.amit@gmail.com> Reviewed-by: Dan Carpenter <dan.carpenter@oracle.com> Reviewed-by: Ian Abbott <abbotti@mev.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-11staging: imx/drm: request irq only after adding the crtcPhilipp Zabel
If the bootloader already enabled the display, the interrupt handler will be called as soon as it is registered. If the CRTC is not already added at this time, the call to imx_drm_handle_vblank will result in a NULL pointer dereference. The patch fixes a kernel panic [1], which has been on linux-next since Jan 8 [2]. [1] http://thread.gmane.org/gmane.linux.ports.arm.kernel/218858 [2] http://thread.gmane.org/gmane.linux.ports.arm.kernel/208192 Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de> Tested-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-11staging: comedi: drivers: usbduxfast.c: fix for DMA buffers on stackKumar Amit Mehta
fix for instances of DMA buffer on stack(being passed to usb_control_msg) for the USB-DUXfast Board driver. Signed-off-by: Kumar Amit Mehta <gmate.amit@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-11staging: comedi: drivers: usbdux.c: fix DMA buffers on stackKumar Amit Mehta
fix for instances of DMA buffer on stack(being passed to usb_control_msg) for the USB-DUX-D Board driver. Signed-off-by: Kumar Amit Mehta <gmate.amit@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-11staging: vt6656: Fix oops on resume from suspend.Malcolm Priestley
Remove usb_put_dev from vt6656_suspend and usb_get_dev from vt6566_resume. These are not normally in suspend/resume functions. Signed-off-by: Malcolm Priestley <tvboxspy@gmail.com> Cc: stable@vger.kernel.org # 3.0+ Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-11usb: cp210x new Vendor/Device IDsMatwey V. Kornilov
This patch adds support for the Lake Shore Cryotronics devices to the CP210x driver. These lines are ported from cp210x driver distributed by Lake Shore web site: http://www.lakeshore.com/Documents/Lake%20Shore%20cp210x-3.0.0.tar.gz and licensed under the terms of GPLv2. Moreover, I've tested this changes with Lake Shore 335 in my labs. Signed-off-by: Matwey V. Kornilov <matwey@sai.msu.ru> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-11Merge tag 'fixes-for-v3.9-rc3' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/balbi/usb into usb-linus Felipe writes: usb: fixes for v3.9-rc3 Most fixes are on 'musb' driver. There's a sparse warning fix which marks omap2430_glue as static, a build warning fix which was found with randconfig, a fix for omap_musb_mailbox check and removal of 'select' from musb's Kconfig to prevent Kconfig warnings. Other than that, pxa25x got a fix which was introduced by the latest conversion to udc_start/udc_stop patchset, kernel-doc warnings for composite layer and dwc3 got a build fix on sparc64. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Missing cancel of work items in mac80211 MLME, from Ben Greear. 2) Fix DMA mapping handling in iwlwifi by using coherent DMA for command headers, from Johannes Berg. 3) Decrease the amount of pressure on the page allocator by using order 1 pages less in iwlwifi, from Emmanuel Grumbach. 4) Fix mesh PS broadcast OOPS in mac80211, from Marco Porsch. 5) Don't forget to recalculate idle state in mac80211 monitor interface, from Felix Fietkau. 6) Fix varargs in netfilter conntrack handler, from Joe Perches. 7) Need to reset entire chip when command queue fills up in iwlwifi, from Emmanuel Grumbach. 8) The TX antenna value must be valid when calibrations are performed in iwlwifi, fix from Dor Shaish. 9) Don't generate netfilter audit log entries when audit is disabled, from Gao Feng. 10) Deal with DMA unit hang on e1000e during power state transitions, from Bruce Allan. 11) Remove BUILD_BUG_ON check from igb driver, from Alexander Duyck. 12) Fix lockdep warning on i2c handling of igb driver, from Carolyn Wyborny. 13) Fix several TTY handling issues in IRDA ircomm tty driver, from Peter Hurley. 14) Several QFQ packet scheduler fixes from Paolo Valente. 15) When VXLAN encapsulates on transmit, we have to reset the netfilter state. From Zang MingJie. 16) Fix jiffie check in net_rx_action() so that we really cap the processing at 2HZ. From Eric Dumazet. 17) Fix erroneous trigger of IP option space exhaustion, when routers are pre-specified and we are looking to see if we can insert a timestamp, we will have the space. From David Ward. 18) Fix various issues in benet driver wrt waiting for firmware to finish POST after resets or errors. From Gavin Shan and Sathya Perla. 19) Fix TX locking in SFC driver, from Ben Hutchings. 20) Like the VXLAN fix above, when we encap in a TUN device we have to reset the netfilter state. This should fix several strange crashes reported by Dave Jones and others. From Eric Dumazet. 21) Don't forget to clean up MAC address resources when shutting down a port in mlx4 driver, from Yan Burman. 22) Fix divide by zero in vmxnet3 driver, from Bhavesh Davda. 23) Fix device statistic regression in tg3 when the driver is using phylib, from Nithin Sujir. 24) Fix info leak in several netlink handlers, from Mathias Krause. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (79 commits) 6lowpan: Fix endianness issue in is_addr_link_local(). rrunner.c: fix possible memory leak in rr_init_one() dcbnl: fix various netlink info leaks rtnl: fix info leak on RTM_GETLINK request for VF devices bridge: fix mdb info leaks tg3: Update link_up flag for phylib devices ipv6: stop multicast forwarding to process interface scoped addresses bridging: fix rx_handlers return code netlabel: fix build problems when CONFIG_IPV6=n drivers/isdn: checkng length to be sure not memory overflow net/rds: zero last byte for strncpy bnx2x: Fix SFP+ misconfiguration in iSCSI boot scenario bnx2x: Fix intermittent long KR2 link up time macvlan: Set IFF_UNICAST_FLT flag to prevent unnecessary promisc mode. team: unsyc the devices addresses when port is removed bridge: add missing vid to br_mdb_get() Fix: sparse warning in inet_csk_prepare_forced_close afkey: fix a typo MAINTAINERS: Update qlcnic maintainers list netlabel: correctly list all the static label mappings ...
2013-03-11Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input updates from Dmitry Torokhov: "Except for the largish change to the ALPS driver adding "Dolphin V1" support and Wacom getting a new signature of yet another device, the rest are straightforward driver fixes." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: mms114 - Fix regulator enable and disable paths Input: ads7864 - check return value of regulator enable Input: tc3589x-keypad - fix keymap size Input: wacom - add support for 0x10d Input: ALPS - update documentation for recent touchpad driver mods Input: ALPS - add "Dolphin V1" touchpad support Input: ALPS - remove unused argument to alps_enter_command_mode() Input: cypress_ps2 - fix trackpadi found in Dell XPS12
2013-03-11usb: gadget: pxa25x: fix disconnect reportingFelipe Balbi
when commit 6166c24 (usb: gadget: pxa25x_udc: convert to udc_start/udc_stop) converted this driver to udc_start/udc_stop, it failed to consider the fact that stop_activity() is called from disconnect interrupt. Fix the problem so that gadget drivers know about proper disconnect sequences. Signed-off-by: Felipe Balbi <balbi@ti.com>
2013-03-11Merge branch 'drm-nouveau-fixes-3.9' of ↵Dave Airlie
git://anongit.freedesktop.org/git/nouveau/linux-2.6 into drm-next Regression fixes and oops fixes for nouveau. * 'drm-nouveau-fixes-3.9' of git://anongit.freedesktop.org/git/nouveau/linux-2.6: drm/nv50: use correct tiling methods for m2mf buffer moves drm/nouveau: idle channel before releasing notify object drm/nouveau: fix regression in vblanking drm/nv50: encoder creation failure doesn't mean full init failure
2013-03-10Input: mms114 - Fix regulator enable and disable pathsMark Brown
When it uses regulators the mms114 driver checks to see if it managed to acquire regulators and ignores errors. This is not the intended usage and not great style in general. Since the driver already refuses to probe if it fails to allocate the regulators simply make the enable and disable calls unconditional and add appropriate error handling, including adding cleanup of the regulators if setup_reg() fails. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2013-03-10Input: ads7864 - check return value of regulator enableMark Brown
At least print a warning if we can't power the device up. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2013-03-10Input: tc3589x-keypad - fix keymap sizeRabin Vincent
The keymap size used by tc3589x is too low, leading to the driver overwriting other people's memory. Fix this by making the driver use the automatically allocated keymap provided by matrix_keypad_build_keymap() instead of allocating one on its own. Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2013-03-11drm/nv50: use correct tiling methods for m2mf buffer movesMarcin Slusarz
Currently used only on original nv50, nvaa and nvac. Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2013-03-11drm/nouveau: idle channel before releasing notify objectMarcin Slusarz
Unmapping it while it's still in use (e.g. by M2MF) can lead to page faults and a lot of TRAP_M2MF spam in dmesg. Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2013-03-11drm/nouveau: fix regression in vblankingMaarten Lankhorst
nv50_vblank_enable/disable got switched from NV50_PDISPLAY_INTR_EN_1_VBLANK_CRTC_0 (4) << head to 1 << head, which is wrong. 4 << head is the correct value. Fixes regression with vblanking since 1d7c71a3e2f77 "drm/nouveau/disp: port vblank handling to event interface" Signed-off-by: Maarten Lankhorst <maarten.lankhorst@canonical.com> Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2013-03-11drm/nv50: encoder creation failure doesn't mean full init failureBen Skeggs
It's meant as a notification only, not a fatal error. Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2013-03-10rrunner.c: fix possible memory leak in rr_init_one()David Oostdyk
In the event that register_netdev() failed, the rrpriv->evt_ring allocation would have not been freed. Signed-off-by: David Oostdyk <daveo@ll.mit.edu> Signed-off-by: David S. Miller <davem@davemloft.net>
