Process SG-elements in batches of MAX_NR_SG if they are greater
than MAX_NR_SG. Due to this, at any given time only those many
slots will be used in the given channel no matter how long the
scatter list is. We keep track of how much has been written
inorder to process the next batch of elements in the scatter-list
and detect completion.
For such intermediate transfer completions (one batch of MAX_NR_SG),
make use of pause and resume functions instead of start and stop
when such intermediate transfer is in progress or completed as we
donot want to clear any pending events.
Signed-off-by: Joel Fernandes <joelf@ti.com>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
Changes are made here for configuring existing parameters to support
DMA'ing them out in batches as needed.
Also allocate as many as slots as needed by the SG list, but not more
than MAX_NR_SG. Then these slots will be reused accordingly.
For ex, if MAX_NR_SG=10, and number of SG entries is 40, still only
10 slots will be allocated to DMA the entire SG list of size 40.
Also enable TC interrupts for slots that are a last in a current
iteration, or that fall on a MAX_NR_SG boundary.
drivers/dma/sh/Kconfig
drivers/dma/sh/shdmac.c
Use devm_ioremap_resource instead of devm_request_and_ioremap.
This was done using the semantic patch
scripts/coccinelle/api/devm_ioremap_resource.cocci
The relevant call to platform_get_resource was manually moved down to the
call to devm_ioremap_resource.
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
kcalloc can return NULL. Check the pointer before dereferencing.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
'const' was added twice.
kfree on a NULL pointer is a no-op. Null pointer check is
not necessary.
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
Trivial fix for function name mismatches I stumbled over.
Signed-off-by: Daniel Mack <zonque@gmail.com>
Add support for HPB-DMAC found in Renesas R-Car SoCs, using 'shdma-base' DMA
driver framework.
Based on the original patch by Phil Edworthy <phil.edworthy@renesas.com>.
Signed-off-by: Max Filippov <max.filippov@cogentembedded.com>
[Sergei: removed useless #include, sorted #include's, fixed HPB_DMA_TCR_MAX,
fixed formats and removed line breaks in the dev_dbg() calls, rephrased and
added IRQ # to the shdma_request_irq() failure message, added MODULE_AUTHOR(),
removed '__init'/'__exit' annotations from the probe()/remove() methods, removed
'__initdata' annotation from 'hpb_dmae_driver', fixed guard macro name in the
header file, fixed #define ASYNCRSTR_ASRST20, added #define ASYNCRSTR_ASRST24,
added the necessary runtime PM calls to the probe() and remove() methods,
handled errors returned by dma_async_device_register(), beautified comments
and #define's.]
Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
Use devm_ioremap_resource() because devm_request_and_ioremap() is
obsoleted by devm_ioremap_resource().
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Acked-by: Zhangfei Gao <zhangfei.gao@linaro.org>
Sparse report the following warnings:
drivers/dma/imx-sdma.c:330:25: warning: symbol 'sdma_imx31' was not declared. Should it be static?
drivers/dma/imx-sdma.c:351:25: warning: symbol 'sdma_imx25' was not declared. Should it be static?
drivers/dma/imx-sdma.c:357:25: warning: symbol 'sdma_imx35' was not declared. Should it be static?
drivers/dma/imx-sdma.c:375:25: warning: symbol 'sdma_imx51' was not declared. Should it be static?
drivers/dma/imx-sdma.c:395:25: warning: symbol 'sdma_imx53' was not declared. Should it be static?
drivers/dma/imx-sdma.c:414:25: warning: symbol 'sdma_imx6q' was not declared. Should it be static?
Make the sdma_driver_data structures static.
pch_dma currently isn't auto-loaded if built as a module.
Many audio interface drivers require support of cyclic transfers to work
correctly, for example Samsung ASoC DMA driver. This patch adds support
for cyclic transfers to the amba-pl08x driver.
Signed-off-by: Alban Bedel <alban.bedel@avionic-design.de>
[tfiga: Rebase and slightly beautify the original patch.]
Signed-off-by: Tomasz Figa <tomasz.figa@gmail.com>
There are more fields than just SWIDTH in CH_CONTROL register, so read
register value must be masked in addition to shifting.
PL080S has separate register to store transfer size in, allowing single
transfer to be much larger than in standard PL080.
This patch makes the amba-pl08x driver aware of this and removes writing
transfer size to reserved bits of CH_CONTROL register on PL080S, which
was not a problem witn transfer sizes fitting the original bitfield
of PL080, but now would overwrite other fields.
PL080S is a modified version of PL080 that can be found on Samsung SoCs,
such as S3C6400 and S3C6410.
It has different offset of CONFIG register, separate CONTROL1 register
that holds transfer size and larger maximum transfer size.
This patch refactors debugging code that dumps LLI entries by moving it
into separate function, which is stubbed when VERBOSE_DEBUG is not
selected. This allows us to get rid of the ugly ifdef from the body of
pl08x_fill_llis_for_desc().
No functional change is introduced by this patch.
Currently memory allocated for LLIs is casted to an array of structs,
which is fragile and also limits the driver to a single, predefined LLI
layout, while there are some variants of PL08x, which have more fields
in LLI (namely PL080S with its extra CCTL2).
This patch makes LLIs a sequence of 32-bit words, which is just filled
with appropriate values in appropriate order and padded with required
amount of dummy words (currently zero, but PL080S will make better use
of this).
Suggested-by: Linus Walleij <linus.walleij@linaro.org>
Some variants of PL08x (namely PL080S, found in Samsung S3C64xx SoCs)
have CONFIG register at different offset. This patch makes the driver
use offset from vendor data struct.
Further patch will introduce support for PL080S, which requires some
things to be done conditionally, thus increasing indentation level of
some functions even more.
This patch reduces indentation level of pl08x_getbytes_chan() function
by inverting several conditions and returning from function wherever
possible.
The pl330 DMA driver is broken in regard to handling a terminate all request
while it is processing the list of completed descriptors. This is most visible
when calling dmaengine_terminate_all() from within the descriptors callback for
cyclic transfers. In this case the TERMINATE_ALL transfer will clear the
work_list and stop the transfer. But after all callbacks for all completed
descriptors have been handled the descriptors will be re-enqueued into the (now
empty) work_list. So the next time dma_async_issue_pending() is called for the
channel these descriptors will be transferred again which will cause data
corruption. Similar issues can occur if dmaengine_terminate_all() is not called
from within the descriptor callback but runs on a different CPU at the same time
as the completed descriptor list is processed.
This patch introduces a new per channel list which will hold the completed
descriptors. While processing the list the channel's lock will be held to avoid
racing against dmaengine_terminate_all(). The lock will be released when calling
the descriptors callback though. Since the list of completed descriptors might
be modified (e.g. by calling dmaengine_terminate_all() from the callback) we can
not use the normal list iterator macros. Instead we'll need to check for each
loop iteration again if there are still items in the list. The drivers
TERMINATE_ALL implementation is updated to move descriptors from both the
work_list as well the new completed_list back to the descriptor pool. This makes
sure that none of the descripts finds its way back into the work list and also
that we do not call any futher complete callbacks after
dmaengine_terminate_all() has been called.
Add dmaengine driver for hisilicon k3 platform based on virt_dma
Signed-off-by: Zhangfei Gao <zhangfei.gao@linaro.org>
Tested-by: Kai Yang <jean.yangkai@huawei.com>
A bad merge resulted in a left-over free_irq() call. This patch removes it.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski+renesas@gmail.com>
The driver core clears the driver data to NULL after device_release
or on probe failure. Thus, it is not needed to manually clear the
device driver data to NULL.
Acked-by: Simon Horman <horms+renesas@verge.net.au>
Acked-by: Guennadi Liakhovetski <g.liakhovetski+renesas@gmail.com>
This configuration data will be used, when DMAC DT support is added to
r8a73a4.
All shdma DMACs on ARM SoCs share certain register layout patterns, which
are currently defined in arch/arm/mach-shmobile/include/mach/dma-register.h.
That header is included by SoC-specific setup-*.c files to be used in DMAC
platform data. That header, however, cannot be directly used by the driver.
This patch copies those defines into a driver-local header to be used by
Device Tree configurations.
Macros, named like TEND or SAR lack a namespace and are too broadly named
for a global header. Besides, they aren't needed globally. Move them to
where they belong - into the driver. Some other macros aren't used at all,
remove them.
This facilitates DMAC DT support by eliminating the need in AUXDATA and
avoiding creating complex DT data. This also fits well with DMAC devices,
of which SoCs often have multiple identical copies and it is perfectly
valid to use a single configuration data set for all of them.
Platform data shouldn't be changed at run-time, so, pointers to it should
be const.
Fix the following compiler warning:
drivers/dma/sh/sudmac.c: In function 'sudmac_chan_remove':
drivers/dma/sh/sudmac.c:302: warning: unused variable 'sc'
Switch shdma to using devm_* managed functions for allocation of memory,
requesting IRQs, mapping IO resources etc.
On newer r-car SoCs the CHCLR register only contains one bit per channel,
to which a 1 has to be written to reset the channel. Older SoC versions had
one CHCLR register per channel, to which a 0 must be written to reset the
channel and clear its buffers. This patch adds support for the newer
layout.
This adds the ROM script addresses for i.MX25, i.MX5x and i.MX6 to the
SDMA driver needed for the driver to work without additional firmware.
The ROM script addresses are SoC specific and in some cases even tapeout
specific. This patch adds the ROM script addresses only for SoCs which
do not have a tapeout specific SDMA ROM, because currently it's unclear
how this case should be handled.
Acked-by: Shawn Guo <shawn.guo@linaro.org>
Use a struct type instead of an enum type for distinguishing between
different versions. This makes it simpler to handle multiple differences
without cluttering the code with comparisons for certain devtypes.
As the driver now has its own xlate function and makes use of the
dma_get_slave_channel(), we need to manually set the DMA_PRIVATE flags.
Drivers which rely on of_dma_simple_xlate() do implicitly the same by
going through __dma_request_channel().
Provide a callback to prepare cyclic DMA transfers.
This is for instance needed for audio channel transport.
In order to fully support multiple transactions per channel, we need to
assure we get an interrupt for each completed transaction. That flags
bit is also our only way to tell at which descriptor a transaction ends.
So, remove the manual clearing of that bit, and then inline the only
remaining command that is left in append_pending_queue() for better
readability.
Currently, when an interrupt has occured for a channel, the tasklet
worker code will only look at the very last entry in the running list
and complete its cookie, and then dispose the entire running chain.
Hence, the first transaction's cookie will never complete.
In fact, the interrupt we should handle will be the one related to the
first descriptor in the chain with the ENDIRQEN bit set, so complete
the second transaction that is in fact still running.
As a result, the driver can't currently handle multiple transactions on
one chanel, and it's likely that no drivers exist that rely on this
feature.
Fix this by walking the running_chain and look for the first
descriptor that has the interrupt-enable bit set. Only queue
descriptors up to that point for completion handling, while leaving
the rest intact. Also, only make the channel idle if the list is
completely empty after such a cycle.
In case of big endian CPU we have to convert either all fields in the structure
or leave this job to ACPICA. The second choice seems the best.
So, let's remove the ugly conversion that is not fully comprehensive anyway.
Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com>
If "num_disabled" is equal to STEDMA40_MAX_PHYS (32) then we would write
one space beyond the end of the pdata->disable_channels[] array.
When CONFIG_ARM_LPAE=y the following build warning are generated:
drivers/dma/ste_dma40.c:3228:2: warning: format '%x' expects argument of type 'unsigned int', but argument 4 has type 'resource_size_t' [-Wformat]
drivers/dma/ste_dma40.c:3582:3: warning: format '%x' expects argument of type 'unsigned int', but argument 4 has type 'resource_size_t' [-Wformat]
drivers/dma/ste_dma40.c:3582:3: warning: format '%x' expects argument of type 'unsigned int', but argument 5 has type 'resource_size_t' [-Wformat]
drivers/dma/ste_dma40.c:3593:5: warning: format '%x' expects argument of type 'unsigned int', but argument 5 has type 'resource_size_t' [-Wformat]
According to Documentation/printk-formats.txt '%pa' can be used to properly
print 'resource_size_t'.
Also, for printing memory region the '%pr' is more convenient.
Reported-by: Kevin Hilman <khilman@linaro.org>
Acked-by: Kevin Hilman <khilman@linaro.org>
In the shdma driver __iomem pointers are used to point to hardware
registers. Using typed pointers like "u32 __iomem *" in this case is
inconvenient, because then offsets, added to such pointers, have to be
devided by sizeof(u32) or similar. Switch the driver to use void
pointers, which avoids this clumsiness.
struct sh_dmae_device::chan_reg is a pointer to u32, therefore when adding
offsets to it care should be taken to add offsets in sizeof(u32) units, not
in bytes. This patch corrects such a bug. While at it we also remove the
redundant parameter of the affected function.
Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de>
With all mxs-dma clients moved to use generic DMA helper, the code
left from generic DMA binding conversion can be removed now.
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
