Commit 03dbaa04a2e5 ("mmc: slot-gpio: Add support to enable irq wake on
cd_irq") enabled wakeup at initialization. However drivers may wish to
enable and disable based on different criteria. Add a helper function
mmc_gpio_set_cd_wake() to make it easy for drivers to do that.
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
Do not enable wakeup for SDIO card interrupt unless the SDIO function
driver has requested it which is indicated by mmc_card_wake_sdio_irq().
Do not unnecessarily enable card detect wakeup in the cases that the card
is not removable or a GPIO is used for card detect.
Now that tuning no longer leaves the Buffer Read Enable bit set (refer
intel_execute_tuning()), glk_cqe_enable() is no longer needed. Get rid of
it.
Not sure why it was there in the first place, but it's
obviously useless check, so let's remove it.
Signed-off-by: Shawn Lin <shawn.lin@rock-chips.com>
cur_slot and num_slots has been removed from struct dw_mci in 42f989c002f2.
Unfortunately, inline documentation was not updated so far.
Fix @lock field documentation in Locking section.
Move @mrq field of struct dw_mci_slot mention closer to it
description, so no one could miss this slightest detail.
Couple of code style fixes as a bonus.
Signed-off-by: Alexey Roslyakov <alexey.roslyakov@gmail.com>
Reviewed-by: Shawn Lin <shawn.lin@rock-chips.com>
Acked-by: Jaehoon Chung <jh80.chung@samsung.com>
Clang reports a compile warning:
drivers/mmc/host/dw_mmc.c:2124:5: warning: Value stored to 'prev_state'
is never read
By checking the code, prev_state and state assignment for
STATE_SENDING_CMD is indeed never used after jumping to unlock tag.
So remove it.
Use the newly added macro to simply to the code.
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
...instead of open coding file operations followed by custom ->open()
callbacks per each attribute.
Reviewed-by: Avri Altman <avri.altman@wdc.com>
TMIO_MASK_CMD is properly enabled in tmio_mmc_start_command().
We have no reason to set it up in tmio_mmc_host_probe(). (If we
really wanted to set it in the probe, we would have to do likewise
when resuming.)
Even worse, the following code is extremely confusing:
_host->sdcard_irq_mask &= ~irq_mask;
The logic is opposite between "->sdcard_irq_mask" and "irq_mask".
The intention is not clear at a glance.
Reviewed-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
Tested-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
Currently, force_pio is cleared when the driver exits. Then, it
resulted in clearing it in multiple places since MMC drivers in
general have multiple exit points.
tmio_mmc_reset_work - bails out on timeout
tmio_process_mrq - error out when it cannot send a command
tmio_mmc_finish_request - successful exit
This is error-prone since we may miss to cover all bail-out points.
To simplify the code, the data structure should be initialized just
before used since we have a single entrance. force_pio is only used
for data transfer, so tmio_mmc_start_data() will be a suitable place
to clear this flag.
As far as I tested the IP on UniPhier SoCs, TMIO_STAT_{RXRDY,TXRQ}
are asserted for DMA mode as well as for PIO. I need to disable the
those IRQs in dma_ops->start hook, otherwise the DMA transfer fails
with the following error message:
PIO IRQ in DMA mode!
Renesas chips are the same cases since I see their dma_ops->start
hooks explicitly clear TMIO_STAT_{RXRDY,TXRQ} (with nice comment!).
If we do this sanity check in TMIO MMC core, RXRDY/TXRQ handling
should be entirely moved to the core. tmio_mmc_cmd_irq() will
be a suitable place to disable them.
The probe function sets TMIO_MASK_{READOP,WRITEOP} but this is odd.
/* Unmask the IRQs we want to know about */
if (!_host->chan_rx)
irq_mask |= TMIO_MASK_READOP;
if (!_host->chan_tx)
irq_mask |= TMIO_MASK_WRITEOP;
At this point, _host->{chan_rx,chan_tx} are _always_ NULL because
tmio_mmc_request_dma() is called after this code. Consequently,
TMIO_MASK_{READOP,WRITEOP} are set here whether DMA is used or not.
Remove this pointless code.
The TMIO mmc cannot detect the card insertion in native_hotplug mode
if the driver is probed without a card inserted.
The reason is obvious; all IRQs are disabled by tmio_mmc_host_probe(),
as follows:
tmio_mmc_disable_mmc_irqs(_host, TMIO_MASK_ALL);
The card event IRQs are first enabled by tmio_mmc_start_command() as
follows:
if (!host->native_hotplug)
irq_mask &= ~(TMIO_STAT_CARD_REMOVE | TMIO_STAT_CARD_INSERT);
tmio_mmc_enable_mmc_irqs(host, irq_mask);
If the driver is probed without a card, tmio_mmc_start_command() is
never called in the first place. So, the card is never detected.
The card event IRQs must be enabled in probe/resume functions.
A card detect GPIO is set up only for platforms with "cd-gpios"
DT property or TMIO_MMC_USE_GPIO_CD flag. However, the driver
core always uses mmc_gpio_get_cd, which just fails with -ENOSYS
if ctx->cd_gpio is unset.
The bit 5 of the status register provides the current signal level
of the CD line. Allow to use it if the GPIO is unused.
This property is equivalent to "disable-wp" defined in
Documentation/devicetree/bindings/mmc/mmc.txt
The TMIO MMC core calls mmc_of_parse(), and it sets
MMC_CAP2_NO_WRITE_PROTECT if "disable-wp" property is present.
We do not need a vendor-specific property to do the same thing.
Let's remove the description from the dt-binding to prevent new boards
from using it.
I am keeping the driver code for existing DT files, but added
comments that this is deprecated.
Acked-by: Rob Herring <robh@kernel.org>
The use of this flag has been replaced with MMC_CAP2_NO_WRITE_PROTECT.
No platform defines this flag any more. Remove.
Acked-by: Lee Jones <lee.jones@linaro.org>
TMIO_MMC_WRPROTECT_DISABLE is equivalent to MMC_CAP2_NO_WRITE_PROTECT.
Only the difference is the TMIO_... makes tmio_mmc_get_ro() return 0
(i.e. it does not affect mmc_gpio_get_ro() at all), while MMC_CAP2_...
returns 0 before calling ->get_ro() hook (i.e. it affects both IP own
logic and GPIO detection).
The TMIO MMC drivers do not set-up gpio_ro by themselves. Only the
possibility, if any, would be DT specifies "wp-gpios" property, and
gpio_ro is set by mmc_gpiod_request_ro() called from mmc_of_parse().
However, it does not make sense to specify "wp-gpios" property and
"toshiba,mmc-wrprotect-disable" at the same time.
I checked under arch/arm/boot/dts/ and arch/arm64/boot/dts/renesas/,
and I did not see any Renesas boards with "wp-gpios". So, this
conversion should be safe.
The flag is propagated as follows:
renesas_sdhi_of_data::capabilities2
-> tmio_mmc_data::capabilities2
-> mmc_host::caps2
TMIO_MMC_WRPROTECT_DISABLE at the same time.
According to the BCM2835 datasheet there are no preset value registers.
This wasn't an issue before, because we didn't propagate 1.8V support.
Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com>
If the max_discard value is zero, the conditional branch that checks the
trim capabilities will never update this value with max_trim.
Change the condition statement to also check the max_discard value in order
to avoid an unnecessary call to mmc_do_calc_max_discard.
Signed-off-by: Sergio Valverde <vlvrdv@gmail.com>
Reviewed-by: Shawn Lin <shawn.lin@rock-chip.com>
The TODO section from 2010 is obsolete. We have DMA and PM meanwhile and
we always want to handle errors better, if possible. Also DRIVER_VERSION
is not used anymore these days.
Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
Reviewed-by: Simon Horman <horms+renesas@verge.net.au>
Add SDHCI_QUIRK2_PRESET_VALUE_BROKEN quirk as setting preset values loads
incorrect CLKD values (for UHS modes).
Remove SDHCI_QUIRK2_NO_1_8_V quirk as sdhci-omap now supports UHS modes.
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
The data manual of J6/J6 Eco recommends to set different IODELAY values
depending on the mode in which the MMC/SD is enumerated in order to
ensure IO timings are met.
Add support to set the IODELAY values depending on the various MMC
modes using the pinctrl APIs.
Errata i802 in AM572x Sitara Processors Silicon Revision 2.0, 1.1
(SPRZ429K July 2014–Revised March 2017 [1]) mentions
DCRC error interrupts (MMCHS_STAT[21] DCRC=0x1) can occur
during the tuning procedure and it has to be disabled during the
tuning procedure Implement workaround for Errata i802 here..
[1] -> http://www.ti.com/lit/er/sprz429k/sprz429k.pdf
Acked-by: Adrian Hunter <adrian.hunter@intel.com>
MMC tuning procedure is required to support SD card
UHS1-SDR104 mode and EMMC HS200 mode.
SDR104/HS200 DLL Tuning Procedure for AM572x platform is mentioned
in Figure 25-51. SDR104/HS200 DLL Tuning Procedure of
AM572x Sitara Processors Silicon Revision 2.0, 1.1 TRM
(SPRUHZ6I - October 2014–Revised April 2017 [1]).
The tuning function sdhci_omap_execute_tuning() will only be
called by the MMC/SD core if the corresponding speed modes
are supported by the OMAP silicon which is set in the mmc
host "caps" field.
[1] -> http://www.ti.com/lit/ug/spruhz6i/spruhz6i.pdf
UHS-1 DDR50 and MMC DDR52 mode require DDR bit to be
set in the configuration register (MMCHS_CON). Add
sdhci-omap specific set_uhs_signaling ops to set
this bit. Also while setting the UHSMS bit, clock should be
disabled.
Add card_busy host ops in sdhci_omap to check card busy status.
The voltage switching sequence for AM572x platform is mentioned
in Figure 25-48. eMMC/SD/SDIO Power Switching Procedure of
In the voltage switching sequence, CLKEXTFREE bit in MMCHS_CON
should also be set after switching to 1.8v which is also taken
care in the card_busy ops.
Updating 'power_mode' in sdhci_omap_init_74_clocks results in
'power_mode' never updated to MMC_POWER_OFF during card
removal. This results in initialization sequence not sent to the
card during re-insertion.
Fix it here by adding sdhci_omap_set_power_mode to update power_mode.
This function can also be used later to perform operations that
are specific to a power mode (e.g, disable tuning during power off).
Pull timer fixes from Thomas Gleixner:
"A small set of fixes from the timer departement:
- Add a missing timer wheel clock forward when migrating timers off a
unplugged CPU to prevent operating on a stale clock base and
missing timer deadlines.
- Use the proper shift count to extract data from a register value to
prevent evaluating unrelated bits
- Make the error return check in the FSL timer driver work correctly.
Checking an unsigned variable for less than zero does not really
work well.
- Clarify the confusing comments in the ARC timer code"
* 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
timers: Forward timer base before migrating timers
clocksource/drivers/arc_timer: Update some comments
clocksource/drivers/mips-gic-timer: Use correct shift count to extract data
clocksource/drivers/fsl_ftm_timer: Fix error return checking
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c fixes from Wolfram Sang:
"A driver fix and a documentation fix (which makes dependency handling
for the next cycle easier)"
* 'i2c/for-current-fixed' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux:
i2c: octeon: Prevent error message on bus error
dt-bindings: at24: sort manufacturers alphabetically
git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm
Pull libnvdimm fixes from Dan Williams:
"A 4.16 regression fix, three fixes for -stable, and a cleanup fix:
- During the merge window support for the new ACPI NVDIMM Platform
Capabilities structure disabled support for "deep flush", a
force-unit- access like mechanism for persistent memory. Restore
that mechanism.
- VFIO like RDMA is yet one more memory registration / pinning
interface that is incompatible with Filesystem-DAX. Disable long
term pins of Filesystem-DAX mappings via VFIO.
- The Filesystem-DAX detection to prevent long terms pins mistakenly
also disabled Device-DAX pins which are not subject to the same
block- map collision concerns.
- Similar to the setup path, softlockup warnings can trigger in the
shutdown path for large persistent memory namespaces. Teach
for_each_device_pfn() to perform cond_resched() in all cases.
- Boaz noticed that the might_sleep() in dax_direct_access() is stale
as of the v4.15 kernel.
These have received a build success notification from the 0day robot,
and the longterm pin fixes have appeared in -next. However, I recently
rebased the tree to remove some other fixes that need to be reworked
after review feedback.
* 'libnvdimm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm:
memremap: fix softlockup reports at teardown
libnvdimm: re-enable deep flush for pmem devices via fsync()
vfio: disable filesystem-dax page pinning
dax: fix vma_is_fsdax() helper
dax: ->direct_access does not sleep anymore
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media fixes from Mauro Carvalho Chehab:
- some build fixes with randconfigs
- an m88ds3103 fix to prevent an OOPS if the chip doesn't provide the
right version during probe (with can happen if the hardware hangs)
- a potential out of array bounds reference in tvp5150
- some fixes and improvements in the DVB memory mapped API (added for
kernel 4.16)
* tag 'media/v4.16-3' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media:
media: vb2: Makefile: place vb2-trace together with vb2-core
media: Don't let tvp5150_get_vbi() go out of vbi_ram_default array
media: dvb: update buffer mmaped flags and frame counter
media: dvb: add continuity error indicators for memory mapped buffers
media: dmxdev: Fix the logic that enables DMA mmap support
media: dmxdev: fix error code for invalid ioctls
media: m88ds3103: don't call a non-initalized function
media: au0828: add VIDEO_V4L2 dependency
media: dvb: fix DVB_MMAP dependency
media: dvb: fix DVB_MMAP symbol name
media: videobuf2: fix build issues with vb2-trace
media: videobuf2: Add VIDEOBUF2_V4L2 Kconfig option for VB2 V4L2 part
git://www.linux-watchdog.org/linux-watchdog
Pull watchdog fixes from Wim Van Sebroeck:
- rave-sp: add NVMEM dependency
- build fixes for i6300esb_wdt, xen_wdt and sp5100_tco
* tag 'linux-watchdog-4.16-fixes-1' of git://www.linux-watchdog.org/linux-watchdog:
watchdog: sp5100_tco.c: fix potential build failure
watchdog: xen_wdt: fix potential build failure
watchdog: i6300esb: fix build failure
watchdog: rave-sp: add NVMEM dependency
Re-enable deep flush so that users always have a way to be sure that a
write makes it all the way out to media. Writes from the PMEM driver
always arrive at the NVDIMM since movnt is used to bypass the cache, and
the driver relies on the ADR (Asynchronous DRAM Refresh) mechanism to
flush write buffers on power failure. The Deep Flush mechanism is there
to explicitly write buffers to protect against (rare) ADR failure. This
change prevents a regression in deep flush behavior so that applications
can continue to depend on fsync() as a mechanism to trigger deep flush
in the filesystem-DAX case.
Fixes: 06e8ccdab15f4 ("acpi: nfit: Add support for detect platform CPU cache...")
Reviewed-by: Jeff Moyer <jmoyer@redhat.com>
Signed-off-by: Dave Jiang <dave.jiang@intel.com>
Filesystem-DAX is incompatible with 'longterm' page pinning. Without
page cache indirection a DAX mapping maps filesystem blocks directly.
This means that the filesystem must not modify a file's block map while
any page in a mapping is pinned. In order to prevent the situation of
userspace holding of filesystem operations indefinitely, disallow
'longterm' Filesystem-DAX mappings.
RDMA has the same conflict and the plan there is to add a 'with lease'
mechanism to allow the kernel to notify userspace that the mapping is
being torn down for block-map maintenance. Perhaps something similar can
be put in place for vfio.
Note that xfs and ext4 still report:
"DAX enabled. Warning: EXPERIMENTAL, use at your own risk"
...at mount time, and resolving the dax-dma-vs-truncate problem is one
of the last hurdles to remove that designation.
Acked-by: Alex Williamson <alex.williamson@redhat.com>
Cc: Michal Hocko <mhocko@suse.com>
Cc: kvm@vger.kernel.org
Cc: <stable@vger.kernel.org>
Reported-by: Haozhong Zhang <haozhong.zhang@intel.com>
Tested-by: Haozhong Zhang <haozhong.zhang@intel.com>
Fixes: d475c6346a38 ("dax,ext2: replace XIP read and write with DAX I/O")
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI fixes from Bjorn Helgaas:
- Update pci.ids location (documentation only) (Randy Dunlap)
- Fix a crash when BIOS didn't assign a BAR and we try to enlarge it
(Christian König)
* tag 'pci-v4.16-fixes-2' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci:
PCI: Allow release of resources that were never assigned
PCI: Update location of pci.ids file
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip
Pull xen fixes from Juergen Gross:
"Five minor fixes for Xen-specific drivers"
* tag 'for-linus-4.16a-rc4-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip:
pvcalls-front: 64-bit align flags
x86/xen: add tty0 and hvc0 as preferred consoles for dom0
xen-netfront: Fix hang on device removal
xen/pirq: fix error path cleanup when binding MSIs
xen/pvcalls: fix null pointer dereference on map->sock
Pull block fixes from Jens Axboe:
"A collection of fixes for this series. This is a little larger than
usual at this time, but that's mainly because I was out on vacation
last week. Nothing in here is major in any way, it's just two weeks of
fixes. This contains:
- NVMe pull from Keith, with a set of fixes from the usual suspects.
- mq-deadline zone unlock fix from Damien, fixing an issue with the
SMR zone locking added for 4.16.
- two bcache fixes sent in by Michael, with changes from Coly and
Tang.
- comment typo fix from Eric for blktrace.
- return-value error handling fix for nbd, from Gustavo.
- fix a direct-io case where we don't defer to a completion handler,
making us sleep from IRQ device completion. From Jan.
- a small series from Jan fixing up holes around handling of bdev
references.
- small set of regression fixes from Jiufei, mostly fixing problems
around the gendisk pointer -> partition index change.
- regression fix from Ming, fixing a boundary issue with the discard
page cache invalidation.
- two-patch series from Ming, fixing both a core blk-mq-sched and
kyber issue around token freeing on a requeue condition"
* tag 'for-linus-20180302' of git://git.kernel.dk/linux-block: (24 commits)
block: fix a typo
block: display the correct diskname for bio
block: fix the count of PGPGOUT for WRITE_SAME
mq-deadline: Make sure to always unlock zones
nvmet: fix PSDT field check in command format
nvme-multipath: fix sysfs dangerously created links
nbd: fix return value in error handling path
bcache: fix kcrashes with fio in RAID5 backend dev
bcache: correct flash only vols (check all uuids)
blktrace_api.h: fix comment for struct blk_user_trace_setup
blockdev: Avoid two active bdev inodes for one device
genhd: Fix BUG in blkdev_open()
genhd: Fix use after free in __blkdev_get()
genhd: Add helper put_disk_and_module()
genhd: Rename get_disk() to get_disk_and_module()
genhd: Fix leaked module reference for NVME devices
direct-io: Fix sleep in atomic due to sync AIO
nvme-pci: Fix nvme queue cleanup if IRQ setup fails
block: kyber: fix domain token leak during requeue
blk-mq: don't call io sched's .requeue_request when requeueing rq to ->dispatch
git://git.kernel.org/pub/scm/linux/kernel/git/ulfh/mmc
Pull MMC fixes from Ulf Hansson:
"MMC core:
- mmc: core: Avoid hang when claiming host
MMC host:
- dw_mmc: Avoid hang when accessing registers
- dw_mmc: Fix out-of-bounds access for slot's caps
- dw_mmc-k3: Fix out-of-bounds access through DT alias
- sdhci-pci: Fix S0i3 for Intel BYT-based controllers"
* tag 'mmc-v4.16-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/ulfh/mmc:
mmc: core: Avoid hanging to claim host for mmc via some nested calls
mmc: dw_mmc: Avoid accessing registers in runtime suspended state
mmc: dw_mmc: Fix out-of-bounds access for slot's caps
mmc: dw_mmc: Factor out dw_mci_init_slot_caps
mmc: dw_mmc-k3: Fix out-of-bounds access through DT alias
mmc: sdhci-pci: Fix S0i3 for Intel BYT-based controllers
Pull power management fixes from Rafael Wysocki:
"These fix three issues in cpufreq drivers: one recent regression, one
leftover Kconfig dependency and one old but "stable" material.
Specifics:
- Make the task scheduler load and utilization signals be
frequency-invariant again after recent changes in the SCPI cpufreq
driver (Dietmar Eggemann).
- Drop an unnecessary leftover Kconfig dependency from the SCPI
cpufreq driver (Sudeep Holla).
- Fix the initialization of the s3c24xx cpufreq driver (Viresh
Kumar)"
* tag 'pm-4.16-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
cpufreq: s3c24xx: Fix broken s3c_cpufreq_init()
cpufreq: scpi: Fix incorrect arm_big_little config dependency
cpufreq: scpi: invoke frequency-invariance setter function
The error message:
[Fri Feb 16 13:42:13 2018] i2c-thunderx 0000:01:09.4: unhandled state: 0
is mis-leading as state 0 (bus error) is not an unknown state.
Return -EIO as before but avoid printing the message. Also rename
STAT_ERROR to STATE_BUS_ERROR.
Signed-off-by: Jan Glauber <jglauber@cavium.com>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
* cpufreq-scpi:
git://people.freedesktop.org/~airlied/linux
Pull drm fixes from Dave Airlie:
"Pretty much run of the mill drm fixes.
amdgpu:
- power management fixes
- some display fixes
- one ppc 32-bit dma fix
i915:
- two display fixes
- three gem fixes
sun4i:
- display regression fixes
nouveau:
virtio-gpu:
- dumb airlied ioctl fix"
* tag 'drm-fixes-for-v4.16-rc4' of git://people.freedesktop.org/~airlied/linux: (25 commits)
drm/amdgpu: skip ECC for SRIOV in gmc late_init
drm/amd/amdgpu: Correct VRAM width for APUs with GMC9
drm/amdgpu: fix&cleanups for wb_clear
drm/amdgpu: Correct sdma_v4 get_wptr(v2)
drm/amd/powerplay: fix power over limit on Fiji
drm/amdgpu:Fixed wrong emit frame size for enc
drm/amdgpu: move WB_FREE to correct place
drm/amdgpu: only flush hotplug work without DC
drm/amd/display: check for ipp before calling cursor operations
drm/i915: Make global seqno known in i915_gem_request_execute tracepoint
drm/i915: Clear the in-use marker on execbuf failure
drm/i915/cnl: Fix PORT_TX_DW5/7 register address
drm/i915/audio: fix check for av_enc_map overflow
drm/i915: Fix rsvd2 mask when out-fence is returned
virtio-gpu: fix ioctl and expose the fixed status to userspace.
drm/sun4i: Protect the TCON pixel clocks
drm/sun4i: Enable the output on the pins (tcon0)
drm/nouveau: prefer XBGR2101010 for addfb ioctl
drm/radeon: insist on 32-bit DMA for Cedar on PPC64/PPC64LE
drm/amd/display: VGA black screen from s3 when attached to hook
git://git.infradead.org/linux-platform-drivers-x86
Pull x86 platform drivers fixes from Andy Shevchenko:
- fix a regression on laptops like Dell XPS 9360 where keyboard stopped
working.
- correct sysfs wakeup attribute after removal of some drivers to
reflect that they are not able to wake system up anymore.
* tag 'platform-drivers-x86-v4.16-5' of git://git.infradead.org/linux-platform-drivers-x86:
platform/x86: wmi: Fix misuse of vsprintf extension %pULL
platform/x86: intel-hid: Reset wakeup capable flag on removal
platform/x86: intel-vbtn: Reset wakeup capable flag on removal
platform/x86: intel-vbtn: Only activate tablet mode switch on 2-in-1's
Pull MD bugfixes from Shaohua Li:
- fix raid5-ppl flush request handling hang from Artur
- fix a potential deadlock in raid5/10 reshape from BingJing
- fix a deadlock for dm-raid from Heinz
- fix two md-cluster of raid10 from Lidong and Guoqing
- fix a NULL deference problem in device removal from Neil
- fix a NULL deference problem in raid1/raid10 in specific condition
from Yufen
- other cleanup and fixes
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/shli/md:
md/raid1: fix NULL pointer dereference
md: fix a potential deadlock of raid5/raid10 reshape
md-cluster: choose correct label when clustered layout is not supported
md: raid5: avoid string overflow warning
raid5-ppl: fix handling flush requests
md raid10: fix NULL deference in handle_write_completed()
md: only allow remove_and_add_spares when no sync_thread running.
md: document lifetime of internal rdev pointer.
md: fix md_write_start() deadlock w/o metadata devices
MD: Free bioset when md_run fails
raid10: change the size of resync window for clustered raid
md-multipath: Use seq_putc() in multipath_status()
md/raid1: Fix trailing semicolon
md/raid5: simplify uninitialization of shrinker
%pULL doesn't officially exist but %pUL does.
Miscellanea:
o Add missing newlines to a couple logging messages
Signed-off-by: Darren Hart (VMware) <dvhart@infradead.org>
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl
Pull pin control fixes from Linus Walleij:
"Two smallish pin control fixes: one actual code fix for the Meson and
a MAINTAINERS update.
Summary:
- fix a pin group on the Meson
- assign maintainers for Freescale/NXP pin controllers"
* tag 'pinctrl-v4.16-2' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl:
MAINTAINERS: add Freescale pin controllers
pinctrl: meson-axg: adjust uart_ao_b pin group naming
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO fixes from Linus Walleij:
"Fix up device tree properties readout caused by my own refactorings"
* tag 'gpio-v4.16-2' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio:
gpio: Handle deferred probing in of_find_gpio() properly
gpiolib: Keep returning EPROBE_DEFER when we should
Fix a typo in pkt_start_recovery.
Fixes: 74d46992e0d9 ("block: replace bi_bdev with a gendisk pointer and partitions index")
Signed-off-by: Jiufei Xue <jiufei.xue@linux.alibaba.com>
The intel-hid device will not be able to wake up the system any more
after removing the notify handler provided by its driver, so make
its sysfs attributes reflect that.
Fixes: ef884112e55c (platform: x86: intel-hid: Wake up the system from suspend-to-idle)
