path: root/drivers
2008-03-04sm501fb: RGB offsets are reversed in 16bpp modesVille Syrjala
The RGB offsets were reversed in 16bpp modes. Simply trying to reverse the offsets when endianness differs is clearly the wrong thing to do but that is an issue for another patch. Signed-off-by: Ville Syrjala <syrjala@sci.fi> Acked-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04sm501fb: direct color visual does not workVille Syrjala
The sm501fb palette code clearly does not handle direct color so change the driver to use true color visual for 16bpp. Signed-off-by: Ville Syrjala <syrjala@sci.fi> Acked-by: Magnus Damm <damm@igel.co.jp> Acked-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04ds1wm: report bus reset errorAnton Vorontsov
The patch replaces dev_dbg() by dev_err(), so the user could actually see the error, instead of wondering why w1 doesn't work. The root cause of the bus reset error isn't yet debugged though, but this sometimes happens on iPaq H5555. And while I'm at it, some cosmetic cleanups also made (few lines were using spaces instead of tabs). Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com> Acked-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04ds1wm: should check for IS_ERR(clk) instead of NULLAnton Vorontsov
On the error condition clk_get() returns ERR_PTR(..), so checking for NULL doesn't work. ds1wm module causes a kernel oops when ds1wm clock isn't registered. This patch converts NULL check to IS_ERR(), plus uses PTR_ERR() for the return code. Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com> Acked-by: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04powerpc: mpc5200: fix build error on mpc52xx_psc_spi device driverGrant Likely
Commit id 94f389485e27641348c1951ab8d65157122a8939 (Separate MPC52xx PSC FIOF regsiters from the rest of PSC) split the PSC fifo registers away from the core PSC regs. Doing so broke the mpc52xx_psc_spi driver. This patch teaches the mpc52xx_psc_spi driver about the new PSC fifo register definitions. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: David Brownell <david-b@pacbell.net> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Kumar Gala <galak@gate.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04pktcdvd: reduce stack consumptionPeter Osterlund
On my system, pkt_open() consumes 584 bytes because the compiler decides to inline lots of functions that would not normally be part of long call chains. The following patch fixes that problem on my system. Signed-off-by: Peter Osterlund <petero2@telia.com> Cc: Nix <nix@esperi.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04tridentfb: resource management fixes in probe functionKrzysztof Helt
Correct error paths in probe function. The probe function enables mmio mode so it important to disable the mmio mode before exiting the probe function. Otherwise, the console is left in unusable state (garbled fonts at least, lock up at worst). [akpm@linux-foundation.org: cleanups] Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04VT notifier fix for VT switchSamuel Thibault
VT notifier callbacks need to be aware of console switches. This is already partially done from console_callback(), but at that time fg_console, cursor positions, etc. are not yet updated and hence screen readers fetch the old values. This adds an update notify after all of the values are updated in redraw_screen(vc, 1). Signed-off-by: Samuel Thibault <samuel.thibault@ens-lyon.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04specialix.c: fix possible double-unlockHarvey Harrison
Noticed by sparse, trivial to see: drivers/char/specialix.c:2112:3: warning: context imbalance in 'sx_throttle' - unexpected unlock Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04rtc: add support for the S-35390A RTC chipByron Bradley
This adds basic get/set time support for the Seiko Instruments S-35390A. This chip communicates using I2C and is used on the QNAP TS-109/TS-209 NAS devices. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Byron Bradley <byron.bbradley@gmail.com> Acked-by: Jean Delvare <khali@linux-fr.org> Acked-by: David Brownell <david-b@pacbell.net> Tested-by: Tim Ellis <tim@ngndg.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04serial: add PNP ID GVC0303 for Archtek 3334BRV ISA modemBjorn Helgaas
Thomas Lehmann <thomas.lehmann@alumni.tu-berlin.de> verified that this entry works. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: scsi: missing add of padded bytes to io completion byte count
2008-03-04Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: ioat: fix 'ack' handling, driver must ensure that 'ack' is zero dmaengine: fix sparse warning fsldma: do not cleanup descriptors in hardirq context dmaengine: add driver for Freescale MPC85xx DMA controller
2008-03-04scsi: missing add of padded bytes to io completion byte countJens Axboe
Original patch from Tejun Heo <htejun@gmail.com> but should use ->extra_len and not ->data_len, as we would then overshoot the original request size. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-03-04ioat: fix 'ack' handling, driver must ensure that 'ack' is zeroDan Williams
Initialize 'ack' to zero in case the descriptor has been recycled. Prevents "kernel BUG at crypto/async_tx/async_xor.c:185!" Signed-off-by: Dan Williams <dan.j.williams@intel.com> Acked-by: Shannon Nelson <shannon.nelson@intel.com> Cc: stable@kernel.org
2008-03-04fsldma: do not cleanup descriptors in hardirq contextDan Williams
"Cleaning" descriptors involves calling pending callbacks and clients assume that their callback will only ever happen in softirq context. Delay cleanup to the tasklet. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Acked-by: Zhang Wei <wei.zhang@freescale.com>
2008-03-04dmaengine: add driver for Freescale MPC85xx DMA controllerZhang Wei
The driver implements DMA engine API for Freescale MPC85xx DMA controller, which could be used by devices in the silicon. The driver supports the Basic mode of Freescale MPC85xx DMA controller. The MPC85xx processors supported include MPC8540/60, MPC8555, MPC8548, MPC8641 and so on. The MPC83xx(MPC8349, MPC8360) are also supported. [kamalesh@linux.vnet.ibm.com: build fix] [dan.j.williams@intel.com: merge mm fixes, rebase on async_tx-2.6.25] Signed-off-by: Zhang Wei <wei.zhang@freescale.com> Signed-off-by: Ebony Zhu <ebony.zhu@freescale.com> Acked-by: Kumar Gala <galak@gate.crashing.org> Cc: Shannon Nelson <shannon.nelson@intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: block: fix blkdev_issue_flush() not detecting and passing EOPNOTSUPP back block: fix shadowed variable warning in blk-map.c block: remove extern on function definition cciss: remove READ_AHEAD define and use block layer defaults make cdrom.c:check_for_audio_disc() static block/genhd.c: proper externs unexport blk_rq_map_user_iov unexport blk_{get,put}_queue block/genhd.c: cleanups proper prototype for blk_dev_init() block/blk-tag.c should #include "blk.h" Fix DMA access of block device in 64-bit kernel on some non-x86 systems with 4GB or upper 4GB memory block: separate out padding from alignment block: restore the meaning of rq->data_len to the true data length resubmit: cciss: procfs updates to display info about many splice: only return -EAGAIN if there's hope of more data block: fix kernel-docbook parameters and files
2008-03-04m68knommu: fix fec driver interrupt racesGreg Ungerer
The FEC driver has a common interrupt handler for all interrupt event types. It is raised on a number of distinct interrupt vectors. This handler can't be re-entered while processing an interrupt, so make sure all requested vectors are flagged as IRQF_DISABLED. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04Build fix for drivers/s390/char/defkeymap.cTony Breeds
Commit 5ce2087ed0eb424e0889bdc9102727f65d2ecdde (Fix default compose table initialization) left a trailing quote. CC drivers/s390/char/defkeymap.o drivers/s390/char/defkeymap.c:155: error: missing terminating ' character drivers/s390/char/defkeymap.c:156: error: syntax error before ';' token make[3]: *** [drivers/s390/char/defkeymap.o] Error 1 Fix that. Signed-off-by: Tony Breeds <tony@bakeyournoodle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04cciss: remove READ_AHEAD define and use block layer defaultsMike Miller
This patch removes the #define READ_AHEAD 1024 from the driver and uses the block layer defaults, instead. We have found that under certain workloads the setting can cause a disk connected to the e200 controller to go offline. If the disk hiccups the link may try to downshift but the controller is never notified that the link successfully completed the renegotiation. We've also found that performance using the block layer default of 32 pages was on par with the 1024 setting. We tried setting it to zero at one time based on info from our firmware guys but that killed performance. Turns out we were talking about 2 different read ahead settings. Please consider this for inclusion. Signed-off-by: Mike Miller <mike.miller@hp.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-03-04make cdrom.c:check_for_audio_disc() staticAdrian Bunk
This patch makes the needlessly global check_for_audio_disc() static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-03-04block: separate out padding from alignmentTejun Heo
Block layer alignment was used for two different purposes - memory alignment and padding. This causes problems in lower layers because drivers which only require memory alignment ends up with adjusted rq->data_len. Separate out padding such that padding occurs iff driver explicitly requests it. Tomo: restorethe code to update bio in blk_rq_map_user introduced by the commit 40b01b9bbdf51ae543a04744283bf2d56c4a6afa according to padding alignment. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-03-04block: restore the meaning of rq->data_len to the true data lengthFUJITA Tomonori
The meaning of rq->data_len was changed to the length of an allocated buffer from the true data length. It breaks SG_IO friends and bsg. This patch restores the meaning of rq->data_len to the true data length and adds rq->extra_len to store an extended length (due to drain buffer and padding). This patch also removes the code to update bio in blk_rq_map_user introduced by the commit 40b01b9bbdf51ae543a04744283bf2d56c4a6afa. The commit adjusts bio according to memory alignment (queue_dma_alignment). However, memory alignment is NOT padding alignment. This adjustment also breaks SG_IO friends and bsg. Padding alignment needs to be fixed in a proper way (by a separate patch). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <axboe@carl.home.kernel.dk>
2008-03-04resubmit: cciss: procfs updates to display info about manyMike Miller
volumes This patch allows us to display information about all of the logical volumes configured on a particular controller without stepping on memory even when there are many volumes (128 or more) configured. Please consider this for inclusion. Signed-off-by: Mike Miller <mike.miller@hp.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-03-03Fix default compose table initializationSamuel Thibault
Oddly enough, unsigned int c = '\300'; puts a "negative" value in c, not 0300... This fixes the default unicode compose table by using integers instead of character constants. Signed-off-by: Samuel Thibault <samuel.thibault@ens-lyon.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-03docbook: fix fusion source filesRandy Dunlap
Fix docbook problems in fusion source files. These cause the generated docbook to be incorrect. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-03docbook: fix kernel-api source filesRandy Dunlap
Fix docbook problems in kernel-api.tmpl. These cause the generated docbook to be incorrect. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-03docbook: fix usb source filesRandy Dunlap
Fix docbook problems in USB source files. These cause the generated docbook to be incorrect. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-03docbook: fix scsi source fileRandy Dunlap
Fix docbook problem in SCSI source files. These cause the generated docbook to be incorrect. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-03docbook: fix rapidio source filesRandy Dunlap
Fix docbook problems in rapidio source files. These cause the generated docbook to be incorrect. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-03Merge branch 'for-2.6.25' of ↵Paul Mackerras
master.kernel.org:/pub/scm/linux/kernel/git/arnd/cell-2.6 into merge
master.kernel.org:/pub/scm/linux/kernel/git/jwboyer/powerpc-4xx into merge
2008-03-02firewire: fix crash in automatic module unloadingStefan Richter
"modprobe firewire-ohci; sleep .1; modprobe -r firewire-ohci" used to result in crashes like this: BUG: unable to handle kernel paging request at ffffffff8807b455 IP: [<ffffffff8807b455>] PGD 203067 PUD 207063 PMD 7c170067 PTE 0 Oops: 0010 [1] PREEMPT SMP CPU 0 Modules linked in: i915 drm cpufreq_ondemand acpi_cpufreq freq_table applesmc input_polldev led_class coretemp hwmon eeprom snd_seq_oss snd_seq_midi_event snd_seq snd_seq_device snd_pcm_oss snd_mixer_oss button thermal processor sg snd_hda_intel snd_pcm snd_timer snd snd_page_alloc sky2 i2c_i801 rtc [last unloaded: crc_itu_t] Pid: 9, comm: events/0 Not tainted 2.6.25-rc2 #3 RIP: 0010:[<ffffffff8807b455>] [<ffffffff8807b455>] RSP: 0018:ffff81007dcdde88 EFLAGS: 00010246 RAX: ffff81007dc95040 RBX: ffff81007dee5390 RCX: 0000000000005e13 RDX: 0000000000008c8b RSI: 0000000000000001 RDI: ffff81007dee5388 RBP: ffff81007dc5eb40 R08: 0000000000000002 R09: ffffffff8022d05c R10: ffffffff8023b34c R11: ffffffff8041a353 R12: ffff81007dee5388 R13: ffffffff8807b455 R14: ffffffff80593bc0 R15: 0000000000000000 FS: 0000000000000000(0000) GS:ffffffff8055a000(0000) knlGS:0000000000000000 CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b CR2: ffffffff8807b455 CR3: 0000000000201000 CR4: 00000000000006e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process events/0 (pid: 9, threadinfo ffff81007dcdc000, task ffff81007dc95040) Stack: ffffffff8023b396 ffffffff88082524 0000000000000000 ffffffff8807d9ae ffff81007dc5eb40 ffff81007dc9dce0 ffff81007dc5eb40 ffff81007dc5eb80 ffff81007dc9dce0 ffffffffffffffff ffffffff8023be87 0000000000000000 Call Trace: [<ffffffff8023b396>] ? run_workqueue+0xdf/0x1df [<ffffffff8023be87>] ? worker_thread+0xd8/0xe3 [<ffffffff8023e917>] ? autoremove_wake_function+0x0/0x2e [<ffffffff8023bdaf>] ? worker_thread+0x0/0xe3 [<ffffffff8023e813>] ? kthread+0x47/0x74 [<ffffffff804198e0>] ? trace_hardirqs_on_thunk+0x35/0x3a [<ffffffff8020c008>] ? child_rip+0xa/0x12 [<ffffffff8020b6e3>] ? restore_args+0x0/0x3d [<ffffffff8023e68a>] ? kthreadd+0x14c/0x171 [<ffffffff8023e68a>] ? kthreadd+0x14c/0x171 [<ffffffff8023e7cc>] ? kthread+0x0/0x74 [<ffffffff8020bffe>] ? child_rip+0x0/0x12 Code: Bad RIP value. RIP [<ffffffff8807b455>] RSP <ffff81007dcdde88> CR2: ffffffff8807b455 ---[ end trace c7366c6657fe5bed ]--- Note that this crash happened _after_ firewire-core was unloaded. The shared workqueue tried to run firewire-core's device initialization jobs or similar jobs. The fix makes sure that firewire-ohci and hence firewire-core is not unloaded before all device shutdown jobs have been completed. This is determined by the count of device initializations minus device releases. Also skip useless retries in the node initialization job if the node is to be shut down. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Jarod Wilson <jwilson@redhat.com>
2008-03-02firewire: potentially invalid pointers used in fw_card_bm_workStefan Richter
The bus management workqueue job was in danger to dereference NULL pointers. Also, after having temporarily lifted card->lock, a few node pointers and a device pointer may have become invalid. Add NULL pointer checks and get the necessary references. Also, move card->local_node out of fw_card_bm_work's sight during shutdown of the card. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Jarod Wilson <jwilson@redhat.com>
2008-03-02firewire: fw-sbp2: better fix for NULL pointer dereference in scsi_remove_deviceStefan Richter
Patch "firewire: fw-sbp2: fix NULL pointer deref. in scsi_remove_device" had the unintended effect that firewire-sbp2 could not be unloaded anymore until all SBP-2 devices were unplugged. We now fix the NULL pointer bug by reacquiring a reference to the sdev instead of holding a reference to the sdev (and to the module) all the time. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Tested-by: Jarod Wilson <jwilson@redhat.com>
2008-02-29Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev: [libata] wrap kmap_atomic(KM_IRQ0) with local_irq_save/restore() sata_svw: Add support for HT1100 SATA controller
2008-02-29[libata] wrap kmap_atomic(KM_IRQ0) with local_irq_save/restore()Jeff Garzik
Interrupts must be disabled if using kmap_atomic(KM_IRQ0), but that was not the case in a few code paths coming directly from ATA driver interrupt handlers (which use spin_lock rather than spin_lock_irqsave). Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-02-29Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/blackfin-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/blackfin-2.6: (35 commits) Blackfin Serial Driver: Fix bug - Only insert UART rx char in timer task. Blackfin Serial Driver: Fix bug - update tx dma buffer tail before wake up processes. Blackfin Serial Driver: Fix bug - Increase buffer tail immediately before starting tx dma. [Blackfin] serial driver: Add flow control support to bf54x [Blackfin] serial driver: Fix bug Poll RTS/CTS status in DMA mode as well [Blackfin] serial driver: ADSP-BF52x arch/mach support [Blackfin] serial driver: use simpler comment headers and strip out information that is maintained in the scm's log [Blackfin] serial driver: rework break flood anomaly handling to be more robust/realistic about what we can actually work around [Blackfin] serial driver: fix bug - cache the bits of the LSR on systems where the LSR is read-to-clear [Blackfin] serial driver: fix bug - should not wait for the TFI bit, just clear it when tx stop. [Blackfin] serial driver: Fix bug serial driver in DMA mode spams history to console on shell restart [Blackfin] serial driver: Fix bug Free rx dma buffer in shutdown. [Blackfin] serial driver: Clean up UART DMA code. Blackfin Serial driver: Fix bug - serial driver in PIO mode cant handle input very quickly [Blackfin] arch: kill section mismatch warnings [Blackfin] arch: handle the most common L1 shrinkage case (L1 does not exist for a part) so that any parts labeled for L1 instead get placed into external memory sections [Blackfin] arch: add bfin_clear_PPIx_STATUS() helper funcs like we have for other parts [Blackfin] arch: make sure we have proper description/copyright/license lines [Blackfin] arch: Fix CONFIG_PM support for BF561 [Blackfin] arch: Remove DPMC char driver option ...
2008-02-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: arch/sh/drivers/dma/dma-sh.c: Correct use of ! and & serial: Move asm-sh/sci.h to linux/serial_sci.h. sh: Fix up HAS_SR_RB typo in entry-macros. maple: fix device detection sh: fix rtc_resources setup for sh770x sh: heartbeat: ioremap is expected to succeed sh: Storage class should be before const qualifier maple: remove unused variable sh: SH5-103 needs to select CPU_SH5. sh: Rename SH-3 CCR3 reg to avoid synclink_cs clash.
2008-02-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (79 commits) [X25]: Use proc_create() to setup ->proc_fops first [WANROUTER]: Use proc_create() to setup ->proc_fops first [8021Q]: Use proc_create() to setup ->proc_fops first [IPV4]: Use proc_create() to setup ->proc_fops first [IPV6]: Use proc_create() to setup ->proc_fops first [SCTP]: Use proc_create() to setup ->proc_fops first [PKTGEN]: Use proc_create() to setup ->proc_fops first [NEIGHBOUR]: Use proc_create() to setup ->proc_fops first [LLC]: Use proc_create() to setup ->proc_fops first [IPX]: Use proc_create() to setup ->proc_fops first [SUNRPC]: Use proc_create() to setup ->proc_fops first [ATM]: Use proc_create() to setup ->proc_fops first [SCTP]: Update AUTH structures to match declarations in draft-16. [SCTP]: Incorrect length was used in SCTP_*_AUTH_CHUNKS socket option [SCTP]: Clean up naming conventions of sctp protocol/address family registration [APPLETALK]: Use proc_create() to setup ->proc_fops first [BNX2X]: add bnx2x to MAINTAINERS [BNX2X]: update version, remove CVS strings [BNX2X]: Fix Xmit bugs [BNX2X]: Prevent PCI queue overflow ...
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: MAINTAINERS: neteffect update RDMA/nes: Fix interrupt moderation low threshold RDMA/nes: Fix CRC endianness for RDMA connection establishment on big-endian RDMA/nes: Fix use-after-free in mini_cm_dec_refcnt_listen() RDMA/nes: Fix use-after-free in nes_create_cq() RDMA/nes: Fix a check-after-use in nes_probe() RDMA/nes: Fix a memory leak in schedule_nes_timer() RDMA/nes: Fix off-by-one RDMA/nes: Resurrect error path dead code RDMA/cxgb3: Fix shift calc in build_phys_page_list() for 1-entry page lists
2008-02-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6: ide: remove stale comments from ide-dma.c (take 2) ide: remove ide-tape documentation from Documentation/ide.txt qd65xx: remove commented out code ide-tape: schedule driver for removal after 6 months ide-disk: add missing printk() KERN_* levels ide: fix sparse warning about shadowing 'flags' symbol ide-cd: fix CD/DVD burning ide-cd: fix 'ireason' handling for REQ_TYPE_ATA_PC requests qd65xx: fix setup of QD6580 Control register ide: skip probing port if "hdx=noprobe" was used for both devices on it ide: remove redundant comment from ide_unregister() hpt366: fix section mismatch warnings ide-cd: Enable audio play quirk for Optiarc DVD RW AD-5200A drive
2008-02-29Fix hpet_(un)register_irq_handler() for emulationDavid Howells
Fix hpet_(un)register_irq_handler() for when CONFIG_HPET_EMULATE_RTC=n. They are provided macros that substitute value 0, but if they are called as functions and the return value isn't checked, the following warnings appear: drivers/char/rtc.c: In function `rtc_init': drivers/char/rtc.c:1063: warning: statement with no effect drivers/char/rtc.c: In function `rtc_exit': drivers/char/rtc.c:1157: warning: statement with no effect Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-29Blackfin Serial Driver: Fix bug - Only insert UART rx char in timer task.Sonic Zhang
http://blackfin.uclinux.org/gf/project/uclinux-dist/tracker/?action=TrackerItemEdit&tracker_item_id=3910 Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2008-02-28sata_svw: Add support for HT1100 SATA controllerAnantha Subramanyam
This patch adds support (including ATAPI DMA) for HT1100 (aka BCM11000) SATA controller. Signed-off-by: Anantha Subramanyam <ananth@broadcom.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2008-02-28[BNX2X]: update version, remove CVS stringsEliezer Tamir
Signed-off-by: Eliezer Tamir <eliezert@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-28[BNX2X]: Fix Xmit bugsEliezer Tamir
Several endianity corrections in start_xmit() Fixed TSO bug where packets were missing the TCP flags. Signed-off-by: Eliezer Tamir <eliezert@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-28[BNX2X]: Prevent PCI queue overflowEliezer Tamir
Limit traffic through an internal queue to prevent overflow. Signed-off-by: Eliezer Tamir <eliezert@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-28[BNX2X]: fix slowpath races and lockingEliezer Tamir
Fixed locking between fastpath and slowpath operations. Corrected order of traffic disabling to prevent race when going down under traffic. - first have the microcode drop all incoming packets - then do the slowpath stuff - only then reset the MAC Got rid of in_reset_task. Remove_one() and friends would deference a null pointer if init_one failed. Signed-off-by: Eliezer Tamir <eliezert@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
