path: root/drivers
2014-08-26usb: ehci/ohci-exynos: Fix PHY getting sequenceVivek Gautam
Since we want to keep support for both older usb-phys as well as the newer generic phys, lets first get the generic PHYs and fallback to older USB-PHYs only when we fail to get the former. This should fix the issue with ehci-exynos and ohci-exynos, wherein in the absence of SAMSUNG_USB2PHY config symbol, we end up getting the NOP_USB_XCEIV phy when the same is enabled. And thus the PHYs are not configured properly. Reported-by: Sachin Kamat <sachin.kamat@samsung.com> Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Jingoo Han <jg1.han@samsung.com> Tested-by: Sachin Kamat <sachin.kamat@samsung.com> Acked-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-08-26usb: hub: Prevent hub autosuspend if usbcore.autosuspend is -1Roger Quadros
If user specifies that USB autosuspend must be disabled by module parameter "usbcore.autosuspend=-1" then we must prevent autosuspend of USB hub devices as well. commit 596d789a211d introduced in v3.8 changed the original behaivour and stopped respecting the usbcore.autosuspend parameter for hubs. Fixes: 596d789a211d "USB: set hub's default autosuspend delay as 0" Cc: [3.8+] <stable@vger.kernel.org> Signed-off-by: Roger Quadros <rogerq@ti.com> Tested-by: Michael Welling <mwelling@emacinc.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-08-26thunderbolt: Clear hops before overwritingAndreas Noever
Zero hops in tb_path_activate before writing a new path. This fixes the following scenario: - Boot with a coldplugged device - Unplug device - Plug device back in - PCI hotplug fails The hotplug operation fails because our new path matches the (now defunct) path which was setup by the firmware for the coldplugged device. By writing zeros before writing our path configuration we can force thunderbolt to retrain the path. Signed-off-by: Andreas Noever <andreas.noever@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-08-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 updates from Martin Schwidefsky: - wire up the system calls seccomp, getrandom and memfd_create - use static system information as input to add_device_randomness - .. and three bug fixes * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: s390/sclp: remove unnecessary XTABS flag s390/3215: fix tty output containing tabs s390: wire up memfd_create syscall s390: add system information as device randomness s390/kdump: Clear subchannel ID to signal non-CCW/SCSI IPL s390: wire up seccomp and getrandom syscalls
2014-08-26USB: sisusb: add device id for Magic Control USB videoStephen Hemminger
I have a j5 create (JUA210) USB 2 video device and adding it device id to SIS USB video gets it to work. Signed-off-by: Stephen Hemminger <stephen@networkplumber.org> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-08-26drm/radeon: handle broken disabled rb mask gracefully (6xx/7xx) (v2)Alex Deucher
This is a port of cedb655a3a7764c3fd946077944383c9e0e68dd4 to older asics. Fixes a possible divide by 0 if the harvest register is invalid. v2: drop some additional harvest munging. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Cc: stable@vger.kernel.org
2014-08-26drm/radeon: save/restore the PD addr on suspend/resumeChristian König
This fixes a problem with GPU resets and TLB flushes on SI/CIK. Signed-off-by: Christian König <christian.koenig@amd.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2014-08-26drm/msm: Fix missing unlock on error in msm_fbdev_create()Wei Yongjun
Add the missing unlock before return from function msm_fbdev_create() in the error handling case. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Rob Clark <robdclark@gmail.com>
2014-08-26drm/msm: fix compile error for non-dt buildsRob Clark
2014-08-26drm/msm/mdp4: request vblank during modesetRob Clark
This avoids a problem seen with weston (for example) where the display gets stuck in "black screen" if starting weston first thing after boot. Possibly mdp5 needs something similar. The downstream android fbdev driver always requests DMA_E (or DMA_P) when display is active, rather than only enabling it on-demand as the drm driver does, which I believe has the same end result. Signed-off-by: Rob Clark <robdclark@gmail.com>
2014-08-26drm/msm: avoid flood of kernel logs on faultsRob Clark
87e956e9 changed the fault handler to return -ENOSYS, which causes the iommu driver to print out a huge splat. Which wouldn't be quite so bad if nothing ever faulted. But seems like some EXA composite operations generate quite a lot of (seemingly harmless) faults. That is probably a userspace problem, but the huge increase in verbosity from iommu fault dumps makes things kind of unusable. We probably should actually log *some* message (not conditional on drm.debug). But ratelimit it. Signed-off-by: Rob Clark <robdclark@gmail.com>
2014-08-26video: da8xx-fb: preserve display width when changing HSYNCIan Abbott
When looking at this driver for a client, I noticed the code that configures the HSYNC pulse clobbers the display width in the same register. It only preserves the MS part of the width in bit 3 and zeros the LS part of the width in bits 9 to 4. This doesn't matter during initialization as the width is configured afterwards, but subsequent use of the FBIPUT_HSYNC ioctl would clobber the width. Preserve bits 9 to 0 of LCD_RASTER_TIMING_0_REG when configuring the horizontal sync. Signed-off-by: Ian Abbott <abbotti@mev.co.uk> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2014-08-26drm: sti: Add missing dependency on RESET_CONTROLLERJingoo Han
Add missing dependency on RESET_CONTROLLER in order to fix the following build error. drivers/gpu/drm/sti/sti_hdmi.c: In function 'sti_hdmi_probe' drivers/gpu/drm/sti/sti_hdmi.c:780:2: error: implicit declaration of function 'devm_reset_control_get' [-Werror=implicit-function-declaration] Benjamin Gaignard remark: I have change "depends on" to "select" but keep the original author name. Signed-off-by: Jingoo Han <jg1.han@samsung.com>
2014-08-26drm: sti: Make of_device_id array constKiran Padwal
Make of_device_id array const, because all OF functions handle it as const. Signed-off-by: Kiran Padwal <kiran.padwal@smartplayin.com>
2014-08-26drm: sti: Fix return value check in sti_drm_platform_probe()Wei Yongjun
In case of error, the function platform_device_register_resndata() returns ERR_PTR() and never returns NULL. The NULL test in the return value check should be replaced with IS_ERR(). Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
2014-08-26drm: sti: hda: fix return value check in sti_hda_probe()Wei Yongjun
In case of error, the function devm_ioremap_nocache() returns NULL pointer not ERR_PTR(). The IS_ERR() test in the return value check should be replaced with NULL test. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
2014-08-26drm: sti: hdmi: fix return value check in sti_hdmi_probe()Wei Yongjun
2014-08-26drm: sti: tvout: fix return value check in sti_tvout_probe()Wei Yongjun
2014-08-26video: of: display_timing: double free on errorDan Carpenter
The display_timings_release() function frees "disp" and we free it again on the next line. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2014-08-26drivers: video: fbdev: atmel_lcdfb.c: fix error return codeJulia Lawall
Convert a zero return value on error to a negative one, as returned elsewhere in the function. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> ( if@p1 (\(ret < 0\|ret != 0\)) { ... return ret; } | ret@p1 = 0 ) ... when != ret = e1 when != &ret *if(...) { ... when != ret = e2 when forall return ret; } // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2014-08-26video: ARM CLCD: Fix calculation of bits-per-pixelJon Medhurst (Tixy)
If the device-tree specifies a max-memory-bandwidth property then the CLCD driver uses that to calculate the bits-per-pixel supported, however, this calculation is faulty for two reasons. 1. It doesn't ensure that the result is a sane value, i.e. a power of 2 and <= 32 as the rest of the code assumes. 2. It uses the displayed resolution and calculates the average bandwidth across the whole frame. It should instead calculate the peak bandwidth based on the pixel clock. This patch fixes both the above. Signed-off-by: Jon Medhurst <tixy@linaro.org> Acked-by: Pawel Moll <pawel.moll@arm.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2014-08-26fbdev: Remove __init from chips_hw_init() to fix build failurePranith Kumar
Fix build failure caused as follows: The function chipsfb_pci_init() references the function __init chips_hw_init(). This is often because chipsfb_pci_init lacks a __init annotation or the annotation of chips_hw_init is wrong. make: *** [drivers] Error 2 by removing the __init annotation from chips_hw_init(). The other thing that could have been done was annotating chipsfb_pci_init(). But that cannot be done since chipsfb_pci_init() is called from non __init functions. Signed-off-by: Pranith Kumar <bobby.prani@gmail.com> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2014-08-26ACPI / LPSS: Add ACPI IDs for Intel BraswellAlan Cox
Enable more identifiers for the existing devices for Intel Braswell and Cherryview. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-08-26ACPI / EC: Add support to disallow QR_EC to be issued before completing ↵Lv Zheng
previous QR_EC There is platform refusing to respond QR_EC when SCI_EVT isn't set which is Acer Aspire V5-573G. By disallowing QR_EC to be issued before the previous one has been completed we are able to reduce the possibilities to trigger issues on such platforms. Note that this fix can only reduce the occurrence rate of this issue, but this issue may still occur when such a platform doesn't clear SCI_EVT before or immediately after completing the previous QR_EC transaction. This patch cannot fix the CLEAR_ON_RESUME quirk which also relies on the assumption that the platforms are able to respond even when SCI_EVT isn't set. But this patch is still useful as it can help to reduce the number of scheduled QR_EC work items. Link: https://bugzilla.kernel.org/show_bug.cgi?id=82611 Reported-and-tested-by: Alexander Mezin <mezin.alexander@gmail.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Cc: 3.16+ <stable@vger.kernel.org> # 3.16+ Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-08-26ACPI / EC: Add support to disallow QR_EC to be issued when SCI_EVT isn't setLv Zheng
There is a platform refusing to respond QR_EC when SCI_EVT isn't set (Acer Aspire V5-573G). Currently, we rely on the behaviour that the EC firmware can respond something (for example, 0x00 to indicate "no outstanding events") to QR_EC even when SCI_EVT is not set, but the reporter has complained about AC/battery pluging/unpluging and video brightness change delay on that platform. This is because the work item that has issued QR_EC has to wait until timeout in this case, and the _Qxx method evaluation work item queued after QR_EC one is delayed. It sounds reasonable to fix this issue by: 1. Implementing SCI_EVT sanity check before issuing QR_EC in the EC driver's main state machine. 2. Moving QR_EC issuing out of the work queue used by _Qxx evaluation to a seperate IRQ handling thread. This patch fixes this issue using solution 1. By disallowing QR_EC to be issued when SCI_EVT isn't set, we are able to handle such platform in the EC driver's main state machine. This patch enhances the state machine in this way to survive with such malfunctioning EC firmware. Note that this patch can also fix CLEAR_ON_RESUME quirk which also relies on the assumption that the platforms are able to respond even when SCI_EVT isn't set. Fixes: c0d653412fc8 ACPI / EC: Fix race condition in ec_transaction_completed() Link: https://bugzilla.kernel.org/show_bug.cgi?id=82611 Reported-and-tested-by: Alexander Mezin <mezin.alexander@gmail.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Cc: 3.16+ <stable@vger.kernel.org> # 3.16+ Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-08-26ACPI: Run fixed event device notifications in process contextLan Tianyu
Currently, notify callbacks for fixed button events are run from interrupt context. That is not necessary and after commit 0bf6368ee8f2 (ACPI / button: Add ACPI Button event via netlink routine) it causes netlink routines to be called from interrupt context which is not correct. Also, that is different from non-fixed device events (including non-fixed button events) whose notify callbacks are all executed from process context. For the above reasons, make fixed button device notify callbacks run in process context which will avoid the deadlock when using netlink to report button events to user space. Fixes: 0bf6368ee8f2 (ACPI / button: Add ACPI Button event via netlink routine) Link: https://lkml.org/lkml/2014/8/21/606 Reported-by: Benjamin Block <bebl@mageta.org> Reported-by: Knut Petersen <Knut_Petersen@t-online.de> Signed-off-by: Lan Tianyu <tianyu.lan@intel.com> [rjw: Function names, subject and changelog.] Cc: 3.15+ <stable@vger.kernel.org> # 3.15+ Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-08-26ACPI / scan: Allow ACPI drivers to bind to PNP device objectsRafael J. Wysocki
We generally don't allow ACPI drivers to bind to ACPI device objects that companion "physical" device objects are created for to avoid situations in which two different drivers may attempt to handle one device at the same time. Recent ACPI device enumeration rework extended that approach to ACPI PNP devices by starting to use a scan handler for enumerating them. However, we previously allowed ACPI drivers to bind to ACPI device objects with existing PNP device companions and changing that led to functional regressions on some systems. For this reason, add a special check for PNP devices in acpi_device_probe() so that ACPI drivers can bind to ACPI device objects having existing PNP device companions as before. Fixes: eec15edbb0e1 (ACPI / PNP: use device ID list for PNPACPI device enumeration) Link: https://bugzilla.kernel.org/show_bug.cgi?id=81511 Link: https://bugzilla.kernel.org/show_bug.cgi?id=81971 Reported-by: Gabriele Mazzotta <gabriele.mzt@gmail.com> Reported-by: Dirk Griesbach <spamthis@freenet.de> Cc: 3.16+ <stable@vger.kernel.org> # 3.16+ Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-08-25mtd: nand: omap: Fix 1-bit Hamming code scheme, omap_calculate_ecc()Roger Quadros
commit 65b97cf6b8de introduced in v3.7 caused a regression by using a reversed CS_MASK thus causing omap_calculate_ecc to always fail. As the NAND base driver never checks for .calculate()'s return value, the zeroed ECC values are used as is without showing any error to the user. However, this won't work and the NAND device won't be guarded by any error code. Fix the issue by using the correct mask. Code was tested on omap3beagle using the following procedure - flash the primary bootloader (MLO) from the kernel to the first NAND partition using nandwrite. - boot the board from NAND. This utilizes OMAP ROM loader that relies on 1-bit Hamming code ECC. Fixes: 65b97cf6b8de (mtd: nand: omap2: handle nand on gpmc) Cc: <stable@vger.kernel.org> [3.7+] Signed-off-by: Roger Quadros <rogerq@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-08-25mtd: nand: omap: Revert to using software ECC by defaultRoger Quadros
For v3.12 and prior, 1-bit Hamming code ECC via software was the default choice. Commit c66d039197e4 in v3.13 changed the behaviour to use 1-bit Hamming code via Hardware using a different ECC layout i.e. (ROM code layout) than what is used by software ECC. This ECC layout change causes NAND filesystems created in v3.12 and prior to be unusable in v3.13 and later. So revert back to using software ECC by default if an ECC scheme is not explicitely specified. This defect can be observed on the following boards during legacy boot -omap3beagle -omap3touchbook -overo -am3517crane -devkit8000 -ldp -3430sdp Signed-off-by: Roger Quadros <rogerq@ti.com> Tested-by: Grazvydas Ignotas <notasas@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-08-25Merge tag 'renesas-sh-drivers-for-v3.17' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas Pull SH driver fix from Simon Horman: "Confine SH_INTC to platforms that need it" * tag 'renesas-sh-drivers-for-v3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas: sh: intc: Confine SH_INTC to platforms that need it
2014-08-25staging: r8188eu: Add new USB IDLarry Finger
The Elecom WDC-150SU2M uses this chip. Reported-by: Hiroki Kondo <kompiro@gmail.com> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-08-25staging/rtl8188eu: add 0df6:0076 Sitecom Europe B.V.Holger Paradies
The stick is not recognized. This dongle uses r8188eu but usb-id is missing. 3.16.0 Signed-off-by: Holger Paradies <retabell@gmx.de> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-08-25mei: nfc: fix memory leak in error pathAlexander Usyskin
NFC will leak buffer if send failed. Use single exit point that does the freeing Cc: stable@vger.kernel.org #3.10+ Signed-off-by: Alexander Usyskin <alexander.usyskin@intel.com> Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-08-25mei: reset client state on queued connect requestAlexander Usyskin
If connect request is queued (e.g. device in pg) set client state to initializing, thus avoid preliminary exit in wait if current state is disconnected. This is regression from: commit e4d8270e604c3202131bac607969605ac397b893 Author: Alexander Usyskin <alexander.usyskin@intel.com> mei: set connecting state just upon connection request is sent to the fw CC: stable@vger.kernel.org # 3.15+ Signed-off-by: Alexander Usyskin <alexander.usyskin@intel.com> Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-08-25usb: dwc2: gadget: Set the default EP max packet value as 8 bytesJingoo Han
Set the default EP max packet value as 8 bytes, because in the case of low-speed, 'ep_mps' is not set. Thus, the default value of 'ep_mps' should be considered for the case of low-speed. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Paul Zimmerman <paulz@synopsys.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-08-25usb: ehci: using wIndex + 1 for hub portPeter Chen
The roothub's index per controller is from 0, but the hub port index per hub is from 1, this patch fixes "can't find device at roohub" problem for connecting test fixture at roohub when do USB-IF Embedded Host High-Speed Electrical Test. This patch is for v3.12+. Cc: stable@vger.kernel.org Signed-off-by: Peter Chen <peter.chen@freescale.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-08-25USB: storage: add quirk for Newer Technology uSCSI SCSI-USB converterMark
The uSCSI from Newer Technology is a SCSI-USB converter with USB ID 06ca:2003. Like several other SCSI-USB products, it's a Shuttle Technology OEM device. Without a suitable entry in unusual-devs.h, the converter can only access the (single) device with SCSI ID 0. Copying the entry for device 04e6:0002 allows it to work with devices with other SCSI IDs too. There are currently six entries for Shuttle-developed SCSI-USB devices in unusual-devs.h (grep for euscsi): 04e6:0002 Shuttle eUSCSI Bridge USB_SC_DEVICE, USB_PR_DEVICE 04e6:000b Shuttle eUSCSI Bridge USB_SC_SCSI, USB_PR_BULK 04e6:000c Shuttle eUSCSI Bridge USB_SC_SCSI, USB_PR_BULK 050d:0115 Belkin USB SCSI Adaptor USB_SC_SCSI, USB_PR_BULK 07af:0004 Microtech USB-SCSI-DB25 USB_SC_DEVICE, USB_PR_DEVICE 07af:0005 Microtech USB-SCSI-HD50 USB_SC_DEVICE, USB_PR_DEVICE lsusb -v output for the uSCSI lists bInterfaceSubClass 6 SCSI bInterfaceProtocol 80 Bulk (Zip) This patch adds an entry for the uSCSI to unusual_devs.h. Signed-off-by: Mark Knibbs <markk@clara.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-08-25usbip: remove struct usb_device_id tableValentina Manea
This was used back when usbip-host was an interface device driver; after the conversion to device driver, the table remained unused. Remove it in order to stop receiving a warning about it. Signed-off-by: Valentina Manea <valentina.manea.m@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-08-25usbip: move usbip kernel code out of stagingValentina Manea
At this point, USB/IP kernel code is fully functional and can be moved out of staging. Signed-off-by: Valentina Manea <valentina.manea.m@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-08-25usbip: move usbip userspace code out of stagingValentina Manea
At this point, USB/IP userspace code is fully functional and can be moved out of staging. Signed-off-by: Valentina Manea <valentina.manea.m@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-08-25HID: logitech-dj: prevent false errors to be shownBenjamin Tissoires
Commit "HID: logitech: perform bounds checking on device_id early enough" unfortunately leaks some errors to dmesg which are not real ones: - if the report is not a DJ one, then there is not point in checking the device_id - the receiver (index 0) can also receive some notifications which can be safely ignored given the current implementation Move out the test regarding the report_id and also discards printing errors when the receiver got notified. Fixes: ad3e14d7c5268c2e24477c6ef54bbdf88add5d36 Cc: stable@vger.kernel.org Reported-and-tested-by: Markus Trippelsdorf <markus@trippelsdorf.de> Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2014-08-24Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Ingo Molnar: "A couple of EFI fixes, plus misc fixes all around the map" * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: efi/arm64: Store Runtime Services revision firmware: Do not use WARN_ON(!spin_is_locked()) x86_32, entry: Clean up sysenter_badsys declaration x86/doc: Fix the 'tlb_single_page_flush_ceiling' sysconfig path x86/mm: Fix sparse 'tlb_single_page_flush_ceiling' warning and make the variable read-mostly x86/mm: Fix RCU splat from new TLB tracepoints
2014-08-24Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "A collection of fixes from this week, it's been pretty quiet and nothing really stands out as particularly noteworthy here -- mostly minor fixes across the field: - ODROID booting was fixed due to PMIC interrupts missing in DT - a collection of i.MX fixes - minor Tegra fix for regulators - Rockchip fix and addition of SoC-specific mailing list to make it easier to find posted patches" * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: bus: arm-ccn: Fix warning message ARM: shmobile: koelsch: Remove non-existent i2c6 pinmux ARM: tegra: apalis/colibri t30: fix on-module 5v0 supplies MAINTAINERS: add new Rockchip SoC list ARM: dts: rockchip: readd missing mmc0 pinctrl settings ARM: dts: ODROID i2c improvements ARM: dts: Enable PMIC interrupts on ODROID ARM: dts: imx6sx: fix the pad setting for uart CTS_B ARM: dts: i.MX53: fix apparent bug in VPU clks ARM: imx: correct gpu2d_axi and gpu3d_axi clock setting ARM: dts: imx6: edmqmx6: change enet reset pin ARM: dts: vf610-twr: Fix pinctrl_esdhc1 pin definitions. ARM: imx: remove unnecessary ARCH_HAS_OPP select ARM: imx: fix TLB missing of IOMUXC base address during suspend ARM: imx6: fix SMP compilation again ARM: dt: sun6i: Add #address-cells and #size-cells to i2c controller nodes
2014-08-24Merge tag 'gpio-v3.17-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio Pull gpio fixes from Linus Walleij: - a largeish fix for the IRQ handling in the new Zynq driver. The quite verbose commit message gives the exact details. - move some defines for gpiod flags outside an ifdef to make stub functions work again. - various minor fixes that we can accept for -rc1. * tag 'gpio-v3.17-2' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: gpio-lynxpoint: enable input sensing in resume gpio: move GPIOD flags outside #ifdef gpio: delete unneeded test before of_node_put gpio: zynq: Fix IRQ handlers gpiolib: devres: use correct structure type name in sizeof MAINTAINERS: Change maintainer for gpio-bcm-kona.c
2014-08-24Merge branch 'drm-fixes' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm fixes from Dave Airlie: "Intel and radeon fixes. Post KS/LC git requests from i915 and radeon stacked up. They are all fixes along with some new pci ids for radeon, and one maintainers file entry. - i915: display fixes and irq fixes - radeon: pci ids, and misc gpuvm, dpm and hdp cache" * 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: (29 commits) MAINTAINERS: Add entry for Renesas DRM drivers drm/radeon: add additional SI pci ids drm/radeon: add new bonaire pci ids drm/radeon: add new KV pci id Revert "drm/radeon: Use write-combined CPU mappings of ring buffers with PCIe" drm/radeon: fix active_cu mask on SI and CIK after re-init (v3) drm/radeon: fix active cu count for SI and CIK drm/radeon: re-enable selective GPUVM flushing drm/radeon: Sync ME and PFP after CP semaphore waits v4 drm/radeon: fix display handling in radeon_gpu_reset drm/radeon: fix pm handling in radeon_gpu_reset drm/radeon: Only flush HDP cache for indirect buffers from userspace drm/radeon: properly document reloc priority mask drm/i915: don't try to retrain a DP link on an inactive CRTC drm/i915: make sure VDD is turned off during system suspend drm/i915: cancel hotplug and dig_port work during suspend and unload drm/i915: fix HPD IRQ reenable work cancelation drm/i915: take display port power domain in DP HPD handler drm/i915: Don't try to enable cursor from setplane when crtc is disabled drm/i915: Skip load detect when intel_crtc->new_enable==true ...
2014-08-24Merge tag 'fixes-for-v3.17-rc2' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/balbi/usb into work-linus Felipe writes: usb: fixes for v3.17-rc2 Here's our first set of fixes for v3.17-rc cycle. Most fixes are pretty minor changes like the signedness bug in dwc3, or the wrong string format on MUSB. The most interesting part is the addition of Intel Quark X1000 support to PCH UDC. Signed-of-by: Felipe Balbi <balbi@ti.com>
2014-08-24USB: whiteheat: Added bounds checking for bulk command responseJames Forshaw
This patch fixes a potential security issue in the whiteheat USB driver which might allow a local attacker to cause kernel memory corrpution. This is due to an unchecked memcpy into a fixed size buffer (of 64 bytes). On EHCI and XHCI busses it's possible to craft responses greater than 64 bytes leading a buffer overflow. Signed-off-by: James Forshaw <forshaw@google.com> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-08-24bus: arm-ccn: Fix warning messagePawel Moll
A message warning a user about wrong vc value was printing out port instead. Reported-by: Drew Richardson <drew.richardson@arm.com> Signed-off-by: Pawel Moll <pawel.moll@arm.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2014-08-23Merge tag 'usb-serial-3.17-rc2' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/johan/usb-serial into work-linus Johan writes: USB-serial fixes for v3.17-rc2 These updates fix the log level for some option log messages that started bothering people after a recent change. They also fix some issues reported against the zte_ev driver by moving most device ids back from the zte_ev driver to the option driver (and removing two duplicate ids). The zte_ev driver is planned to be removed in 3.18. Some new device ids are also added. Signed-off-by: Johan Hovold <johan@kernel.org>
2014-08-22Merge tag 'pwm/for-3.17-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm Pull pwm fix from Thierry Reding: "Just one bugfix for the PWM lookup table code that would cause a PWM channel to be set to the wrong period and polarity for non-perfect matches" * tag 'pwm/for-3.17-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm: pwm: Fix period and polarity in pwm_get() for non-perfect matches
