This is a clock driver for the simple PLLs found on Berlin SoCs.
With repect to PLL registers and features, BG2/BG2CD and BG2Q are
slightly different, e.g. different allowed VCO dividers and bit
shifts.
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com>
Signed-off-by: Mike Turquette <mturquette@linaro.org>
This is a driver for the AVPLLs built upon a VCO with 8 channels each
found on Marvell Berlin2 SoCs. While both VCOs found on BG2/BG2CD share
the same register set, sometimes registers shifts for one of the VCOs
are a bit off. Nothing serious that should require a separate driver,
so deal with both VCOs in a single driver instead.
Failure to terminate this match table can lead to boot failures
depending on where the compiler places the match table.
Cc: Gabriel FERNANDEZ <gabriel.fernandez@st.com>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Fixes the following warning:
WARNING: drivers/built-in.o(.text.unlikely+0x2c50): Section mismatch in reference from the function exynos4_clk_sleep_init() to the (unknown reference) .init.data:(unknown)
The function exynos4_clk_sleep_init() references
the (unknown reference) __initdata (unknown).
This is often because exynos4_clk_sleep_init lacks a __initdata
annotation or the annotation of (unknown) is wrong.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Reported-by: kbuild test robot <fengguang.wu@intel.com>
git://nv-tegra.nvidia.com/user/pdeschrijver/linux into clk-fixes
PLLE fixes for 3.15
Commit c686078 ("clk: divider: Add round to closest divider") introduced
a helper function to check whether given divisor is the best one instead
of direct check. However due to int type used instead of unsigned long
for passing calculated rates to this function in certain cases an
overflow could occur, for example when trying to obtain maximum possible
clock rate by calling clk_round_rate(..., UINT_MAX).
This patch fixes this issue by changing the type of rate, now and best
arguments of the function to unsigned long, which is the type that
should be used for clock rates.
Signed-off-by: Tomasz Figa <t.figa@samsung.com>
Acked-by: Maxime Coquelin <maxime.coquelin@st.com>
Implement the clk->determine_rate method for Broadcom Kona peripheral
clocks. This allows a peripheral clock to be re-parented in order to
satisfy a rate change request. This takes the place of the previous
kona_peri_clk_round_rate() functionality, though that function remains
because it is used by the new one.
The parent clock that allows the peripheral clock to produce a rate
closest to the one requested is the one selected, though the current
parent is used by default.
Signed-off-by: Alex Elder <elder@linaro.org>
The address of the blsp2_ahb_clk register is incorrect. Fix it.
Signed-off-by: Georgi Djakov <gdjakov@mm-sol.com>
Reviewed-by: Stephen Boyd <sboyd@codeaurora.org>
This patch adds support for S2MPS14 PMIC clocks (BT and AP) to the
s2mps11 clock driver.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Reviewed-by: Yadwinder Singh Brar <yadi.brar@samsung.com>
Reviewed-by: Tomasz Figa <t.figa@samsung.com>
Acked-by: Mike Turquette <mturquette@linaro.org>
There is no need for checking if 'clk_table' is not NULL twice (first
after allocation and second at the end of probe()). Also move allocation
of this 'clk_table' to probe from s2mps11_clk_parse_dt as this is
logical place for it.
Add of_clk_del_provider to remove previously registered clock provider.
Add of_node_put to decrement the ref count of clock nodes.
When it fails to allocate div, gate should be free'd before return
Signed-off-by: Valentin Ilie <valentin.ilie@gmail.com>
Commit 1d9fe6b97 ("clk: divider: Fix best div calculation for power-of-two and
table dividers") introduces a regression in its _table_round_up function.
When the divider passed to this function is greater than the max divider
available in the table, this function returns table's max divider.
Problem is that it causes an infinite loop in clk_divider_bestdiv() because
_next_div() will never return a value greater than maxdiv.
Instead of returning table's max divider, this patch returns INT_MAX.
Reported-by: Fabio Estevam <festevam@gmail.com>
Reported-by: Shawn Guo <shawn.guo@freescale.com>
Tested-by: Fabio Estevam <festevam@gmail.com>
Tested-by: Shawn Guo <shawn.guo@freescale.com>
Signed-off-by: Maxime Coquelin <maxime.coquelin@st.com>
- Limit ruler to 80 characters (was: 81),
- Widen rate column by 1 for nicer spacing,
- Right-align numbers and their column headers,
- Move a newline to reduce the number of seq_printf() calls,
- Use set_puts() for fixed strings.
Before:
clock enable_cnt prepare_cnt rate accuracy
extal 2 2 20000000 0
thermal 1 1 20000000 0
cp 0 0 10000000 0
tpu0 0 0 10000000 0
tmu0 0 0 10000000 0
main 1 1 20000000 0
pll3 0 0 1600000000 0
ddr 0 0 200000000 0
zb3d2 0 0 200000000 0
zb3 0 0 400000000 0
pll1 4 4 1560000000 0
oscclk 0 0 126953 0
rclk 1 1 31738 0
cmt1 0 0 31738 0
cmt0 1 1 31738 0
imp 0 0 390000000 0
After:
cp 0 0 10000000 0
tpu0 0 0 10000000 0
tmu0 0 0 10000000 0
main 1 1 20000000 0
ddr 0 0 200000000 0
zb3 0 0 400000000 0
oscclk 0 0 126953 0
rclk 1 1 31738 0
cmt1 0 0 31738 0
cmt0 1 1 31738 0
imp 0 0 390000000 0
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Similar to muxes which already have a read-only flag there sometimes
exist dividers which should not be changed by the clock framework
but whose value still should be readable.
Therefore add a READ_ONLY flag similar to the mux-one to clk-divider
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
[changed flag bit to BIT(5) as suggested by Tomasz Figa]
Signed-off-by: Thomas Abraham <thomas.ab@samsung.com>
Acked-by: Tomasz Figa <t.figa@samsung.com>
Acked-by: Max Schwarz <max.schwarz@online.de>
Tested-by: Max Schwarz <max.schwarz@online.de>
Driver for the R8A7740's clocks that are too specific to be supported by a
generic driver.
Signed-off-by: Ulrich Hecht <ulrich.hecht+renesas@gmail.com>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Initialize the XUSB-related clocks with appropriate parents and rates
for both Tegra114 and Tegra124.
Signed-off-by: Jim Lin <jilin@nvidia.com>
Signed-off-by: Andrew Bresticker <abrestic@chromium.org>
Currently the Tegra1x4 clock init code hard-codes the mux setting
for xusb_hs_src and treats it as a fixed-factor clock. It is,
however, a mux which can be parented by either xusb_ss_src/2 or
pll_u_60M. Add the fixed-factor clock xusb_ss_div2 and put an
entry in periph_clks[] for the xusb_hs_src mux.
The parent-to-index mapping for xusb_fs_src is incorrect.
Fix it by adding a mux table.
Enable hardware control of PLLE spread-spectrum, IDDQ, and enable
controls when enabling PLLE. The hardware (e.g. XUSB) using PLLE
will use these controls for power-saving optimizations.
Add clk driver to support clock blocks found on the AXM55xx devices. The driver
provides clock implementations for three different types of clock devices on
the AXM55xx device: PLL clock, a clock divider and a clock mux.
Signed-off-by: Anders Berg <anders.berg@lsi.com>
Cc: Mark Rutland <mark.rutland@arm.com>
The MSTP[SC]R registers have clock stop bits, not clock enable bits. The
bit value should thus be inverted in the is_enabled() operation.
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
This patch adds of_clk_get_by_clkspec() helper function, which does only
a struct clk lookup from the clock providers. It is used in the subsequent
patch where parsing of a clock from device tree and the lookup from
providers needed to be split.
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
The IM-PD1 PrimeCells all have pclk assignments though this clock
cannot be controlled, and we need to provide this as a dummy
clock for the PL061 GPIO driver to probe, so let's assign it to
all the cells on the board.
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu
Pull iommu fixes from Joerg Roedel:
"Three fixes for the AMD IOMMU driver:
- fix a locking issue around get_user_pages()
- fix two issues with device aliasing and exclusion range handling"
* tag 'iommu-fixes-v3.15-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu:
iommu/amd: fix enabling exclusion range for an exact device
iommu/amd: Take mmap_sem when calling get_user_pages
iommu/amd: Fix interrupt remapping for aliased devices
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/ibft
Pull iscsi_ibft fix from Konrad Rzeszutek Wilk:
"Fix iBFT regression on Broadcom NICs introduced in 3.2"
* tag 'stable/for-linus-3.15-rc5-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/ibft:
iscsi_ibft: Fix finding Broadcom specific ibft sign
git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas
Pull SH driver fix from Simon Horman:
"Compile drivers/sh/pm_runtime.c if ARCH_SHMOBILE_MULTI
This resolves a regression introduced in v3.14 by commit bf98c1eac1d4
("ARM: Rename ARCH_SHMOBILE to ARCH_SHMOBILE_LEGACY")"
* tag 'renesas-sh-drivers-for-v3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas:
drivers: sh: compile drivers/sh/pm_runtime.c if ARCH_SHMOBILE_MULTI
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media fixes from Mauro Carvalho Chehab:
"Most of the changes are drivers fixes (rtl28xuu, fc2580, ov7670,
davinci, gspca, s5p-fimc and s5c73m3).
There is also a compat32 fix and one infoleak fixup at the media
controller"
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media:
[media] V4L2: fix VIDIOC_CREATE_BUFS in 64- / 32-bit compatibility mode
[media] V4L2: ov7670: fix a wrong index, potentially Oopsing the kernel from user-space
[media] media-device: fix infoleak in ioctl media_enum_entities()
[media] fc2580: fix tuning failure on 32-bit arch
[media] Prefer gspca_sonixb over sn9c102 for all devices
[media] media: davinci: vpfe: make sure all the buffers unmapped and released
[media] staging: media: davinci: vpfe: make sure all the buffers are released
[media] media: davinci: vpbe_display: fix releasing of active buffers
[media] media: davinci: vpif_display: fix releasing of active buffers
[media] media: davinci: vpif_capture: fix releasing of active buffers
[media] s5p-fimc: Fix YUV422P depth
[media] s5c73m3: Add missing rename of v4l2_of_get_next_endpoint() function
[media] rtl28xxu: silence error log about disabled rtl2832_sdr module
[media] rtl28xxu: do not hard depend on staging SDR module
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging driver fixes from Greg KH:
"Here are five staging driver fixes for 3.15-rc6 that resolve some
reported issues. They are for the imx and rtl8723au drivers"
* tag 'staging-3.15-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging:
staging: rtl8723au: Do not reset wdev->iftype in netdev_close()
staging: rtl8723au: Use correct pipe type for USB interrupts
imx-drm: imx-tve: correct DDC property name to 'ddc-i2c-bus'
imx-drm: imx-drm-core: skip components whose parent device is disabled
imx-drm: imx-drm-core: fix imx_drm_encoder_get_mux_id
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI fixes from Bjorn Helgaas:
"These are fixes for an SHPCHP hotplug regression, a "wait for pending
transaction" problem (used in device reset paths), and an email
address update.
PCI device hotplug:
- Fix SHPCHP bus speed mismatch issue (Marcel Apfelbaum)
Miscellaneous:
- Fix pci_wait_for_pending_transaction() (Gavin Shan)
- Update email address (Ben Hutchings)"
* tag 'pci-v3.15-fixes-2' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci:
PCI: Wrong register used to check pending traffic
PCI: shpchp: Check bridge's secondary (not primary) bus speed
PCI: Update my email address
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/random
Pull /dev/random fix from Ted Ts'o:
"This fixes a BUG_ON-causing regression that was introduced during the
last merge window"
* tag 'random_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/random:
random: fix BUG_ON caused by accounting simplification
git://git.linaro.org/people/mike.turquette/linux
Pull clock framework fixes from Mike Turquette:
"Clock framework and driver fixes, all of which fix user-visible
regressions.
As usual most fixes are for platform-specific clock drivers, but there
are also two fixes to the clk core after recent changes to the way
that clock unregistration is handled"
* tag 'clk-fixes-for-linus' of git://git.linaro.org/people/mike.turquette/linux:
clk: tegra: Fix wrong value written to PLLE_AUX
clk: shmobile: clk-mstp: change to using clock-indices
clk: Fix slab corruption in clk_unregister()
clk: Fix double free due to devm_clk_register()
clk: socfpga: fix clock driver for 3.15
clk: divider: Fix best div calculation for power-of-two and table dividers
clk: bcm281xx: don't use unnamed structs or unions
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi
Pull spi fixes from Mark Brown:
"A few core fixes around outlying cases here, nothing that should
affect most users but useful fixes. The diffstat is rather larger
than one might hope due some simple code motion in the fix for
!CONFIG_DMA, the actual meaningful change is much smaller.
- Fix handling of unsupported dual and quad mode support on slave
registration so that drivers that can degrade gracefully do so,
preventing regressions for drivers this is added.
- Fix build in !CONFIG_DMA cases following addition of generic DMA
mapping support.
- Fix error handling for queue creation which due to wider kernel
changes can be triggered more easily.
- A couple of driver specific fixes"
* tag 'spi-v3.15-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi:
spi/pxa2xx: Prevent DMA from transferring too many bytes
spi: core: Don't destroy master queue if we fail to create it
spi: qup: Fix return value checking for pm_runtime_get_sync()
spi: core: Protect DMA code by #ifdef CONFIG_HAS_DMA
spi: core: Ignore unsupported Dual/Quad Transfer Mode bits
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO fixes from Linus Walleij:
- fix a null pointer bug in the ICH6 chipset driver
- fix device tree registration for the mcp23s08 driver
* tag 'gpio-v3.15-3' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio:
gpio: mcp23s08: Bug fix of SPI device tree registration.
gpio: ich: set regs and reglen for i3100 and ich6 chipset
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata
Pull libata fixes from Tejun Heo:
"Mostly device-specific fixes. The only thing which isn't is the fix
for zpodd oops-on-detach bug"
* 'for-3.15-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata:
ahci: imx: PLL clock needs 100us to settle down
ata: pata_at91 only works on sam9
libata: clean up ZPODD when a port is detached
ahci: imx: software workaround for phy reset issue in resume
ahci: imx: add namespace for register enums
ahci: disable DEVSLP for Intel Valleyview
Pull crypto fixes from Herbert Xu:
"This fixes a NULL pointer dereference on allocation failure in caam,
as well as a regression in the ctr mode on s390 that was added with
the recent concurrency fixes"
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6:
crypto: s390 - fix aes,des ctr mode concurrency finding.
crypto: caam - add allocation failure handling in SPRINTFCAT macro
Pull scsi target fixes from Nicholas Bellinger:
"This series include:
- Close race between iser-target network portal shutdown + accepting
new connection logins (sagi)
- Fix free-after-use regression in tcm_fc post conversion to
percpu-ida pre-allocation (nab)
- Explicitly disable Immediate + Unsolicited Data for iser-target
connections when T10-PI is enabled (sagi + nab)
- Allow pi_prot_type + emulate_write_cache attributes to be set to
zero regardless of backend support (andy)
- memory leak fix (mikulas)"
* git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending:
target: fix memory leak on XCOPY
target: Don't allow setting WC emulation if device doesn't support
iscsi-target: Disable Immediate + Unsolicited Data with ISER Protection
tcm_fc: Fix free-after-use regression in ft_free_cmd
iscsi-target: Change BUG_ON to REJECT in iscsit_process_nop_out
Target/iscsi,iser: Avoid accepting transport connections during stop stage
Target/iser: Fix iscsit_accept_np and rdma_cm racy flow
Target/iser: Fix wrong connection requests list addition
target: Allow non-supporting backends to set pi_prot_type to 0
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c fixes from Wolfram Sang:
"Some I2C bugfixes for 3.15. Typical stuff, I'd say"
* 'i2c/for-current' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux:
i2c: rcar: bail out on zero length transfers
i2c: qup: Fix pm_runtime_get_sync usage
i2c: s3c2410: resume race fix
i2c: nomadik: Don't use IS_ERR for devm_ioremap
i2c: designware: Mask all interrupts during i2c controller enable
Pull ACPI and power management fixes from Rafael Wysocki:
"Still fixing regressions (partly by reverting commits that broke
things for people), fixing other stable-candidate bugs and adding some
blacklist entries for ACPI video and _OSI.
Two ACPICA regression fixes (one recent and one for a 3.14 commit), a
fix for an ACPI-related regression in TPM (introduced in 3.14), a
revert of the ACPI AC driver conversion in 3.13 that went wrong for an
unknown reason, two reverts of commits that attempted to remove an old
user space interface in /proc and broke some utilities, in 3.13 too, a
fix for a CPU hotplug bug in the ACPI processor driver (stable
material), two (stable candidate) fixes for intel_pstate and a few new
blacklist entries, mostly for systems that shipped with Windows 8.
Specifics:
- ACPICA fix for a stale pointer access introduced by a recent commit
in the XSDT validation code from Lv Zheng.
- ACPICA fix for the default value of the command line switch to
favor 32-bit FADT addresses (in case there's a conflict between a
64-bit and a 32-bit address). The previous default was that the
32-bit version would take precedence and we tried to change it to
the other way around and it didn't work. From Lv Zheng.
- A TPM commit related to ACPI _DSM in 3.14 caused the driver to
refuse to load if a specific _DSM was missing and that broke resume
from system suspend on Chromebooks that require the TPM hardware to
be restored to a working state during resume by the OS. Restore
the old behavior to load the driver if the _DSM in question is not
present, but prevent it from using the feature the _DSM is for.
- ACPI AC driver conversion in 3.13 broke thermal management on at
least one machine and has to be reverted. From Guenter Roeck.
- Two reverts of 3.13 commits that attempted to remove the old ACPI
battery interface in /proc, but turned out to break some utilities
still using that interface. From Lan Tianyu.
- ACPI processor driver fix to prevent acpi_processor_add() from
modifying the CPU device's .offline field which leads to breakage
if the initial online of the CPU fails. From Igor Mammedov.
- Two intel_pstate fixes, one to take a BayTrail documentation update
into account and one to avoid forcing the maximum P-state on init
which causes CPU PM trouble on systems with P-states coordination
when one of the CPU cores is initialized after an offline/online
cycle triggered by user space. Both stable candidates, from Dirk
Brandewie.
- Fix for the ACPI video DMI blacklist entry for Dell Inspiron 7520
from Aaron Lu.
- Two new ACPI video blacklist entries for machines shipping with
Win8 that need to use native backlight so that it can be controlled
in a usual way (which doesn't work otherwise due bugs in the ACPI
tables) from Hans de Goede.
- Two ACPI _OSI quirks for systems that need them to work correctly
with Linux from Edward Lin and Hans de Goede"
* tag 'pm+acpi-3.15-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
ACPI / video: Revert native brightness quirk for ThinkPad T530
intel_pstate: remove setting P state to MAX on init
ACPICA: Tables: Restore old behavor to favor 32-bit FADT addresses.
ACPI / video: correct DMI tag for Dell Inspiron 7520
intel_pstate: Set turbo VID for BayTrail
ACPI / TPM: Fix resume regression on Chromebooks
ACPI / proc: Do not say when /proc interfaces will be deleted in Kconfig
ACPI / processor: do not mark present at boot but not onlined CPU as onlined
ACPI: Revert "ACPI / AC: convert ACPI ac driver to platform bus"
ACPI / blacklist: Add dmi_enable_osi_linux quirk for Asus EEE PC 1015PX
ACPI: blacklist win8 OSI for Dell Inspiron 7737
ACPI / video: Add use_native_backlight quirks for more systems
ACPI: Revert "ACPI / Battery: Remove battery's proc directory"
ACPI: Revert "ACPI: Remove CONFIG_ACPI_PROCFS_POWER and cm_sbsc.c"
ACPICA: Tables: Fix invalid pointer accesses in acpi_tb_parse_root_table().
git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm
Pull device mapper fixes from Mike Snitzer:
"A dm-crypt fix for a cpu hotplug crash that switches from using
per-cpu data to a mempool allocation (which offers allocation with cpu
locality, and there is no inter-cpu communication on slab allocation).
A couple dm-thinp stable fixes to address "out-of-data-space" issues.
A dm-multipath fix for a LOCKDEP warning introduced in 3.15-rc1"
* tag 'dm-3.15-fixes-2' of git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm:
dm mpath: fix lock order inconsistency in multipath_ioctl
dm thin: add timeout to stop out-of-data-space mode holding IO forever
dm thin: allow metadata commit if pool is in PM_OUT_OF_DATA_SPACE mode
dm crypt: fix cpu hotplug crash by removing per-cpu structure
Pull device tree fixes from Grant Likely:
"Drivercore bugfixes for v3.15
This branch contains bug fixes important to get into v3.15. There is
a fix for modifying properties seen during early boot, a fix for an
incorrect prototype when CONFIG_OF=n, and a couple of corrections to
device tree memory nodes on a few platforms"
* tag 'dt-for-linus' of git://git.secretlab.ca/git/linux:
mips: dts: Fix missing device_type="memory" property in memory nodes
arm: dts: Fix missing device_type="memory" for ste-ccu8540
of: fix CONFIG_OF=n prototype of of_node_full_name()
of: make of_update_property() usable earlier in the boot process
clk-next-zynq
arm: Xilinx Zynq clk patches for v3.16
- Keep debug clocks in bootup state
- Fix email address in si570
Just fix missing ">" in the email.
Pull MIPS fixes from Ralf Baechle:
"MIPS fixes for various loose ends:
- Fix workarounds for R4000 erratum.
- Patch up DEC, Siemens-Nixdorf and Loongson hardware support.
- Wire up renameat2 syscall.
- Delete unused file - it was causing false warnings from maintenance
scripts.
- Revert a patch because it's functionality is now implemented twice
which causes superfluous /proc/cpuinfo output.
- Fix a microMIPS regression"
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus:
MIPS: mm: Fix broken microMIPS kernel regression.
MIPS: Add new AUDIT_ARCH token for the N32 ABI on MIPS64
MIPS: Wire up renameat2 syscall.
MIPS: inst.h: Rename BITFIELD_FIELD to __BITFIELD_FIELD.
MIPS: Remove file missed when removing rm9k support a while ago.
MIPS/loongson2_cpufreq: Fix CPU clock rate setting
MIPS: Loongson: No need to select GENERIC_HARDIRQS_NO__DO_IRQ
MIPS: csum_partial.S CPU_DADDI_WORKAROUNDS bug fix
MIPS: __strncpy_from_user_asm CPU_DADDI_WORKAROUNDS bug fix
MIPS: __delay CPU_DADDI_WORKAROUNDS bug fix
MIPS: DEC/SNI: O32 wrapper stack switching fixes
MIPS: DEC: Bus error handler <asm/cpu-type.h> fixes
MAINTAINERS: TURBOchannel: Update entry
Revert "MIPS: MT: proc: Add support for printing VPE and TC ids"
git://anongit.freedesktop.org/drm-intel into drm-fixes
Intel fixes for regressions, black screens and hangs, for 3.15.
* tag 'drm-intel-fixes-2014-05-16' of git://anongit.freedesktop.org/drm-intel:
drm/i915: Increase WM memory latency values on SNB
drm/i915: restore backlight precision when converting from ACPI
drm/i915: Use the first mode if there is no preferred mode in the EDID
drm/i915/dp: force eDP lane count to max available lanes on BDW
drm/i915/vlv: reset VLV media force wake request register
drm/i915/SDVO: For sysfs link put directory and target in correct order
drm/i915: use lane count and link rate from VBT as minimums for eDP
drm/i915: clean up VBT eDP link param decoding
drm/i915: consider the source max DP lane count too
The commit e783c51 (ahci: imx: software workaround for phy reset issue
in resume) calls imx_sata_phy_reset() to reset phy immediately after
SATA MPLL is enabled. It seems working fine mostly, but fails in some
case as below.
ahci-imx 2200000.sata: failed to reset phy: -110
ahci-imx: probe of 2200000.sata failed with error -110
After talking to the designer, we learnt that when enabling i.MX6Q SATA
MPLL, we need to wait 100us for it to settle down for safety. Add this
required delay to fix above failure.
Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
