If we have already loaded the firmware/patchram and btbcm_initialize()
is called to re-init the HCI after this then there is no need to get
the USB device-ids and build a firmware-filename out of these.
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
On UART attached devices we do:
1. btbcm_initialize()
2. Setup UART baudrate, etc.
3. btbcm_finalize()
After our previous changes we can now also use btbcm_finalize() from
the btbcm_setup_patchram() function used on USB devices without any
functional changes. This completes unifying the USB and UART paths
as much as possible.
Make btbcm_initialize() get and print the device's local-name on re-init
too, this will make us also print the local-name after loading the
Patch on UART attached devices making things more consistent.
This also removes some code duplication from btbcm_setup_patchram()
and allows more code duplication removal there in a follow-up patch.
Instead of having btbcm_initialize() fill a passed in fw_name buffer
and then have its callers use that to request the firmware + load
it into the HCI, make btbcm_initialize() do this itself the first
time it is called (its get called a second time to reset the HCI
after the firmware has been loaded).
This removes some code duplication and makes it easier for further
patches in this series to try more then 1 firmware filename.
btbcm_finalize() is currently only used by UART attached BCM devices.
Move the setting of the USE_BDADDR_PROPERTY quirk, which we only want
for UART attached devices to hci_bcm in preparation for using
btbcm_finalize() for USB attached devices too.
btbcm_initialize() must either return an error; or fill the passed in
fw_name, otherwise we end up passing uninitialized stack memory to
request_firmware().
Since we have a fallback hw_name of "BCM" not having a known version
in the subver field does not matter, drop the check so that we always
fill the passed in fw_name.
Enable PTP programmable pin.
Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com>
Support 4 PTP programmable pins with only PTP_PF_PEROUT function
for now. The PTP_PF_EXTTS function will be supported in the
future, and it should be implemented separately for Felix and
Ocelot, because of different hardware interrupt implementation
in them.
Since the hardware is not able to support absolute start time,
the periodic clock request only allows start time 0 0. But nsec
could be accepted for PPS case for phase adjustment.
Add wave programming registers definitions for Ocelot platforms.
The timestamp info should be only software timestamp capabilities
if ptp clock does not work.
The Ocelot PTP clock driver had been embedded into ocelot.c driver.
It had supported basic gettime64/settime64/adjtime/adjfine functions
by now which were used by both Ocelot switch and Felix switch.
This patch is to move current ptp clock code out of ocelot.c driver
maintaining as a single ocelot_ptp.c.
For futher new features implementation, the common code could be put
in ocelot_ptp.c and the switch specific code should be in specific
switch driver. The interrupt implementation in SoC is different
between Ocelot and Felix.
Change nfp driver to use globally defined kernel version.
Reported-by: Borislav Petkov <bp@suse.de>
Acked-by: Jakub Kicinski <kuba@kernel.org>
Signed-off-by: Leon Romanovsky <leonro@mellanox.com>
Reviewed-by: Simon Horman <simon.horman@netronome.com>
Use globally defined kernel version instead of custom driver variant.
Get rid of linux/vermagic.h includes, so that MODULE_ARCH_VERMAGIC from
the arch header arch/x86/include/asm/module.h won't be redefined.
In file included from ./include/linux/module.h:30,
from drivers/net/ethernet/3com/3c515.c:56:
./arch/x86/include/asm/module.h:73: warning: "MODULE_ARCH_VERMAGIC"
redefined
73 | # define MODULE_ARCH_VERMAGIC MODULE_PROC_FAMILY
In file included from drivers/net/ethernet/3com/3c515.c:25:
./include/linux/vermagic.h:28: note: this is the location of the
previous definition
28 | #define MODULE_ARCH_VERMAGIC ""
Fixes: 6bba2e89a88c ("net/3com: Delete driver and module versions from 3com drivers")
Co-developed-by: Borislav Petkov <bp@suse.de>
Acked-by: Shannon Nelson <snelson@pensando.io> # ionic
Acked-by: Sebastian Reichel <sre@kernel.org> # power
No need to have parentheses around plain pointer variable or
negation operator. Drop them for good.
Acked-by: Florian Fainelli <f.fainelli@gmail.com>
It's convenient to use get_unligned_beXX() and put_unaligned_beXX() helpers
to get or set MAC instead of open-coded variants.
Conversion to devm_clk_get_optional() makes it explicit that clocks are
optional. This change allows to handle deferred probe in case clocks are
defined, but not yet probed. Due to above changes bail out in error case.
While here, check potential error when enable main clock.
There is nothing which needs a set of OF headers, followed by redundant
OF node ID check. Drop them for good.
When compiled with CONFIG_ACPI=n, ACPI_PTR() will be no-op, and thus
genet_acpi_match table defined, but not used. Compiler is not happy about
such data. Drop ACPI_PTR() for good.
git://git.kernel.org/pub/scm/linux/kernel/git/saeed/linux
Saeed Mahameed says:
mlx5-updates-2020-04-20
This series includes misc updates and clean ups to mlx5 driver:
1) improve some comments from Hu Haowen.
2) Handles errors of netif_set_real_num_{tx,rx}_queues, from Maxim
3) IPsec and FPGA related code cleanup to prepare for ASIC devices
IPsec offloads, from Raed
4) Allow partial mask for tunnel options, from Roi.
A barrier is needed here to ensure that rtl_tx sees the descriptor
changes (DescOwn set) before the updated tp->cur_tx value. Else it may
wrongly assume that the transfer has been finished already. For this
purpose smp_wmb() is sufficient.
No separate barrier is needed for ordering the descriptor changes
with the MMIO doorbell write. The needed barrier is included in
the non-relaxed writel() used by rtl8169_doorbell().
Signed-off-by: Heiner Kallweit <hkallweit1@gmail.com>
Replaced "its" with "it's".
Signed-off-by: Hu Haowen <xianfengting221@163.com>
Signed-off-by: Saeed Mahameed <saeedm@mellanox.com>
Embedded CPU bit doesn't change with PCI resume/suspend.
Hence read it only once while probing the PCI device.
Signed-off-by: Parav Pandit <parav@mellanox.com>
Reviewed-by: Bodong Wang <bodong@mellanox.com>
netif_set_real_num_tx_queues and netif_set_real_num_rx_queues may fail.
Now that mlx5e supports handling errors in the preactivate hook, this
commit leverages that functionality to handle errors from those
functions and roll back all changes on failure.
Signed-off-by: Maxim Mikityanskiy <maximmi@mellanox.com>
Reviewed-by: Tariq Toukan <tariqt@mellanox.com>
We use mapping to save and restore the tunnel options.
Save also the tunnel options mask.
Signed-off-by: Roi Dayan <roid@mellanox.com>
Reviewed-by: Paul Blakey <paulb@mellanox.com>
In notify HW (ring doorbell) flow, we set the bit to request a completion
on the TX descriptor.
When doing so, we should not unset other bits in the same byte.
Currently, this does not fix a real issue, as we still don't have a flow
where both MLX5_WQE_CTRL_CQ_UPDATE and any adjacent bit are set together.
Fixes: 542578c67936 ("net/mlx5e: Move helper functions to a new txrx datapath header")
Fixes: 864b2d715300 ("net/mlx5e: Generalize tx helper functions for different SQ types")
Signed-off-by: Tariq Toukan <tariqt@mellanox.com>
Reviewed-by: Aya Levin <ayal@mellanox.com>
Currently the SA handle is created and managed as part of the common
code for different IPsec supporting HW, this handle is passed to HW
to be used on Rx to identify the SA handle that was used to
return the xfrm state to stack.
The above implementation pose a limitation on managing this handle.
Refactor by moving management of this field to the specific HW code.
Downstream patches will introduce the Connect-X support for IPsec that
will use this handle differently than current implementation.
Signed-off-by: Raed Salem <raeds@mellanox.com>
Reviewed-by: Boris Pismenny <borisp@mellanox.com>
Reviewed-by: Huy Nguyen <huyn@mellanox.com>
The current HW counters are supported only by Innova, split the ipsec
stats group into two groups, one for HW and one for SW. And expose
the HW counters to ethtool only if Innova HW is used for IPsec offload.
Currently the FPGA IPsec is the only hw implementation of the IPsec
acceleration api, and so the mlx5_accel_esp_create_hw_context was
wrongly made to suit this HW api, among other in its parameter list
and some of its parameter endianness.
This implementation might not be suitable for different HW.
Refactor by group and pass all function arguments of
mlx5_accel_esp_create_hw_context in common mlx5_accel_esp_xfrm_attrs
struct field of mlx5_accel_esp_xfrm struct and correct the endianness
according to the HW being called.
The cited commit relies on include <net/geneve.h> being included
implicitly prior to include "en_accel/en_accel.h".
This mandates that all files that needs to include en_accel.h
to redantantly include net/geneve.h.
Include net/geneve.h explicitly at "en_accel/en_accel.h" to avoid
undesired constrain as above.
Fixes: e3cfc7e6b7bd ("net/mlx5e: TX, Add geneve tunnel stateless offload support")
Currently the IPsec acceleration capability function is also used
at IPsec fpga capable device code.
This could cause a future bug as the acceleration layer is agnostic
to the device implementing its API.
Fix by using the IPsec FPGA capability function instead of acceleration
layer capability function in case of FPGA IPsec only related operations.
Downstream patches will add support for Connect-X IPsec, this can avoid
a future bug.
Fix the following coccicheck warning:
drivers/net/ethernet/qlogic/qed/qed_dev.c:4395:2-34: WARNING:
Assignment of 0/1 to bool variable
drivers/net/ethernet/qlogic/qed/qed_dev.c:1975:2-34: WARNING:
Signed-off-by: Jason Yan <yanaijie@huawei.com>
Acked-by: Michal Kalderon <michal.kalderon@marvell.com>
This patch adds trace event support for PF/VF mailbox.
Signed-off-by: Yufeng Mo <moyufeng@huawei.com>
Signed-off-by: Huazhong Tan <tanhuazhong@huawei.com>
This patch adds support for dumping MAC reg in debugfs,
which will be helpful for debugging.
Adds some debug information for failures of processing flow table,
removes the redundant printing when hclge_fd_check_spec() returns
error, and modifies the printing level for FD not enable error.
Signed-off-by: Guojia Liao <liaoguojia@huawei.com>
This patch removes some unnecessary blank lines, redundant
parentheses, and changes one tab to blank in
hclge_dbg_dump_reg_common().
In hclge_set_fd_key_config(), parameter 'stage' should be
as enum HCLGE_FD_STAGE, and in hclge_config_key(), 'tuple_size'
should be type u8, also simplify unsigned int with u32 for 'i'.
struct hclge_mac_vlan_remove_cmd and hclge_mac_vlan_add_cmd are unused.
So removes them from hclge_cmd.h.
proto_support field in struct hclge_fd_cfg shows what protocols
in flow direct table are supported now. It is unnecessary since
checking which one is unsupported will be more efficient,
so this patch removes it.
Since case default has included case 0, so removes this
redundant case 0.
hclge_get_fd_rule_info() is bloated, this patch separates
it into several standalone functions for readability and
maintainability.
Signed-off-by: Jian Shen <shenjian15@huawei.com>
For readability and maintainability, this patch separates the
handling part of each flow type in hclge_fd_check_ether_tuple()
into standalone functions.
An MDIO transaction normally starts with 32 1s as a preamble. However
not all devices requires such a preamble. Add a device tree property
which allows the preamble to be suppressed. This will half the size of
the MDIO transaction, allowing faster transactions. But it should only
be used when all devices on the bus support suppressed preamble.
Suggested-by: Chris Healy <Chris.Healy@zii.aero>
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
MDIO busses typically operate at 2.5MHz. However many devices can
operate at faster speeds. This then allows more MDIO transactions per
second, useful for Ethernet switch statistics, or Ethernet PHY TDR
data. Allow the bus speed to be configured, using the standard
"clock-frequency" property, which i2c busses use to indicate the bus
speed. Before using this property, ensure all devices on the bus do
actually support the requested clock speed.
Measurements of the MDIO bus have shown that driving the MDIO bus
using interrupts is slow. Back to back MDIO transactions take about
90us, with 25us spent performing the transaction, and the remainder of
the time the bus is idle.
Replacing the completion interrupt with polled IO results in back to
back transactions of 40us. The polling loop waiting for the hardware
to complete the transaction takes around 28us. Which suggests
interrupt handling has an overhead of 50us, and polled IO nearly
halves this overhead, and doubles the MDIO performance.
Suggested-by: Chris Heally <cphealy@gmail.com>
Inline rtl8169_make_unusable_by_asic() and simplify it:
- Address field doesn't need to be poisoned because descriptor is
owned by CPU now
- desc->opts1 is set by rtl8169_mark_to_asic() and rtl8169_rx_fill(),
therefore we don't have to preserve any field parts.
rtl8169_mark_as_last_descriptor() has just one user, so inline it.
git://git.kernel.org/pub/scm/linux/kernel/git/jkirsher/next-queue
Jeff Kirsher says:
1GbE Intel Wired LAN Driver Updates 2020-04-19
This series contains updates to e1000e and igc only.
Sasha adds new device IDs supported by the igc driver.
Vitaly fixes the S0ix entry and exit flows in e1000e for TGP and newer
MAC types when a cable is connected.
Andre has the remaining changes in the series, starting with cleanup of
the igc driver of duplicate code. Added a check for
IGC_MAC_STATE_SRC_ADDR flag which is unsupported for MAC filters in igc.
Cleaned up the return values for igc_add_mac_filter(), where the return
value was not being used, so update the function to only return success
or failure. Fix the return value of igc_uc_unsync() as well. Refactor
the igc driver in several functions to help reduce the convoluted logic
and simplify the driver filtering mechanisms. Improve the MAC address
checks when adding a MAC filter. Lastly, improve the log messages
related to MAC address filtering to ease debugging.
Remove casting the values returned by memory allocation function.
Coccinelle emits WARNING: casting value returned by memory allocation
function to struct pointer is useless.
This issue was detected by using the Coccinelle.
Signed-off-by: Aishwarya Ramakrishnan <aishwaryarj100@gmail.com>
