path: root/drivers
2007-02-16[PATCH] correct CONFIG_GIGASET_M101 Makefile entryAdrian Bunk
Advanced Mathematics, lesson 1: 101 != 105 ;-) Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-15sata_vsc: use default cache line size if non-zeroNate Dailey
This modifies drivers/ata/sata_vsc.c to only set the cache line size to 0x80 if the default value is zero. Apparently zero isn't allowed due to a bug in the chip, but I've found performance is much better with the (non-zero) default instead of 0x80. [note1: "default" means BIOS-programmed value, in this context -jgarzik] [note2: superfluous braces were removed from the patch -jg] Signed-off-by: Nate Dailey <nate.dailey@stratus.com> Signed-off-by: Jeremy Higdon <jeremy@sgi.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-15sata_nv: handle SError status indicationRobert Hancock
ADMA-capable controllers provide a bit in the status register that appears to indicate that the controller detected an SError condition. Update sata_nv to detect this and trigger error handling in order to handle the fault. Signed-off-by: Robert Hancock <hancockr@shaw.ca> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-15add delay around sl82c105_reset_engine callsOlaf Hering
The hald media changed polling does really confuse things. Noone knows why the delays are needed, but they give us access to the CD. An udelay(50) will give reliable access to the drive, but there is still one (or more) EH reset. The drive works without EH resets with udelay(100). Signed-off-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-15libata: clear TF before IDENTIFYingTejun Heo
Some devices chock if Feature is not clear when IDENTIFY is issued. Set ATA_TFLAG_ISADDR | ATA_TFLAG_DEVICE for IDENTIFY such that whole TF is cleared when reading ID data. Kudos to Art Haas for testing various futile patches over several months and Mark Lord for pointing out the fix. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Art Haas <ahaas@airmail.net> Cc: Mark Lord <mlord@pobox.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-15libata: Add a host flag to indicate lack of IORDY capabilityAlan Cox
This is the first preparation to doing the !IORDY cases properly. Further diffs will then add the needed logic to do it right. Signed-off-by: Alan Cox <alan@redhat.com> Cc: Jeff Garzik <jeff@garzik.org> Cc: Tejun Heo <htejun@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-15sata_promise: new EH conversion for 20619 chips, take 2Mikael Pettersson
This patch updates the sata_promise driver to use new-style libata error handling for 20619 (TX4000) chips. sata_promise already uses new EH for the other chips it supports, so the patch is quite simple: * remove ->phy_reset and ->eng_timeout ops from pdc_pata_ops, and instead bind ->freeze, ->thaw, ->error_handler, and ->post_internal_cmd to existing new EH functions * drop ATA_FLAG_SRST from board_20619's flags * remove now unused pdc_pata_phy_reset() and pdc_eng_timeout() Tested on a TX4000 with both modern working disks and old/quirky disks. Also used a CD-RW drive to test reading and writing CDs. Signed-off-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-15sata_promise: fix missing PATA cable detectionMikael Pettersson
This patch fixes an oversight which caused sata_promise to not perform cable detection on the TX2plus chips' PATA ports. Signed-off-by: Mikael Pettersson <mikpe@it.uu.se> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-14Merge branch 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6Linus Torvalds
* 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6: (94 commits) [PATCH] x86-64: Remove mk_pte_phys() [PATCH] i386: Fix broken CONFIG_COMPAT_VDSO on i386 [PATCH] i386: fix 32-bit ioctls on x64_32 [PATCH] x86: Unify pcspeaker platform device code between i386/x86-64 [PATCH] i386: Remove extern declaration from mm/discontig.c, put in header. [PATCH] i386: Rename cpu_gdt_descr and remove extern declaration from smpboot.c [PATCH] i386: Move mce_disabled to asm/mce.h [PATCH] i386: paravirt unhandled fallthrough [PATCH] x86_64: Wire up compat epoll_pwait [PATCH] x86: Don't require the vDSO for handling a.out signals [PATCH] i386: Fix Cyrix MediaGX detection [PATCH] i386: Fix warning in cpu initialization [PATCH] i386: Fix warning in microcode.c [PATCH] x86: Enable NMI watchdog for AMD Family 0x10 CPUs [PATCH] x86: Add new CPUID bits for AMD Family 10 CPUs in /proc/cpuinfo [PATCH] i386: Remove fastcall in paravirt.[ch] [PATCH] x86-64: Fix wrong gcc check in bitops.h [PATCH] x86-64: survive having no irq mapping for a vector [PATCH] i386: geode configuration fixes [PATCH] i386: add option to show more code in oops reports ...
2007-02-14[PATCH] sysctl: remove insert_at_head from register_sysctlEric W. Biederman
The semantic effect of insert_at_head is that it would allow new registered sysctl entries to override existing sysctl entries of the same name. Which is pain for caching and the proc interface never implemented. I have done an audit and discovered that none of the current users of register_sysctl care as (excpet for directories) they do not register duplicate sysctl entries. So this patch simply removes the support for overriding existing entries in the sys_sysctl interface since no one uses it or cares and it makes future enhancments harder. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: David Howells <dhowells@redhat.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Andi Kleen <ak@muc.de> Cc: Jens Axboe <axboe@kernel.dk> Cc: Corey Minyard <minyard@acm.org> Cc: Neil Brown <neilb@suse.de> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Jan Kara <jack@ucw.cz> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: David Chinner <dgc@sgi.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: C99 convert ctl_tables in drivers/parport/procfs.cEric W. Biederman
Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: register the sysctl number used by the arlan driverEric W. Biederman
Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: "John W. Linville" <linville@tuxdriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: remove sys_sysctl support from drivers/char/rtc.cEric W. Biederman
The real time clock driver was using the binary number reserved for cdroms in the sysctl binary number interface, which is a no-no. So since the sysctl binary interface is wrong remove it. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: remove sys_sysctl support from the hpet timer driverEric W. Biederman
In the binary sysctl interface the hpet driver was claiming to be the cdrom driver. This is a no-no so remove support for the binary interface. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: cdrom: don't set de->ownerEric W. Biederman
There is no need for open files in /proc/sys/XXX to hold a reference count on the module that provides the file to prevent module unload races. While there is code active in the module p->used in the sysctl_table_header is incremented, preventing the sysctl from being unregisted. Once the sysctl is unregistered it cannot be found. Open files are also not a problem as they revalidate the sysctl information and bump p->used before accessing module code. So setting de->owner is unnecessary, makes for a bad example and gets in my way of removing ctl_table->de. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Jens Axboe <jens.axboe@oracle.com> Acked-by: James Bottomley <James.Bottomley@SteelEye.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: cdrom: remove unnecessary insert_at_head flagEric W. Biederman
With unique binary sysctl numbers setting insert_at_head to override other sysctl entries is pointless. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: James Bottomley <James.Bottomley@SteelEye.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: ipmi: remove unnecessary insert_at_head flagEric W. Biederman
With unique sysctl binary numbers setting insert_at_head is pointless. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Corey Minyard <minyard@acm.org> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: mac_hid: remove unnecessary insert_at_head flagEric W. Biederman
With unique sysctl binary numbers setting insert_at_head is pointless. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: md: remove unnecessary insert_at_head flagEric W. Biederman
The sysctls used by the md driver are have unique binary numbers so remove the insert_at_head flag as it serves no useful purpose. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: scsi: remove unnecessary insert_at_head flagEric W. Biederman
Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] scheduled removal of SA_XXX interrupt flags: ata fixAndrew Morton
SA_SHIRQ is going away. Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] Scheduled removal of SA_xxx interrupt flags fixups 2Thomas Gleixner
The obsolete SA_xxx interrupt flags have been used despite the scheduled removal. Fixup the remaining users in -mm. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] Scheduled removal of SA_xxx interrupt flags fixupsThomas Gleixner
The obsolete SA_xxx interrupt flags have been used despite the scheduled removal. Fixup the remaining users. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: Roland Dreier <rolandd@cisco.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Greg KH <greg@kroah.com> Cc: Dave Airlie <airlied@linux.ie> Cc: James Simmons <jsimmons@infradead.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] SPI: atmel_spi driverHaavard Skinnemoen
Driver for the Atmel on-chip SPI master controller. Tested primarily on AVR32/AT32AP7000/ATSTK1000 using mtd_dataflash and the jffs2 filesystem. Should also work fine on various AT91 ARM-based chips like AT91SAM926x and AT91RM9200. Hardware documentation can be found in the AT32AP7000 data sheet, or its AT91 siblings, which can be downloaded from http://www.atmel.com/dyn/products/datasheets.asp?family_id=682 Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] PNX8550 UART driverVitaly Wool
Add UART support for PNX8330/8550/8950 Philips MIPS-based SoCs. Signed-off-by: Vitaly Wool <vitalywool@gmail.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] serial: replace kmalloc+memset with kzallocBurman Yan
2007-02-14[PATCH] serial: make sure UART is powered up when dumping MCTRL statusGeorge G. Davis
Since serial devices are powered down when not in use and some of those devices cannot be accessed when powered down, we need to enable power around calls to get_mcrtl() when dumping port state via uart_line_info(). This resolves hangs observed on some machines while reading serial device registers when a port is powered off. Signed-off-by: George G. Davis <gdavis@mvista.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] serial: trivial code flow simplificationBjorn Helgaas
Return failure immediately, so we don't have to test it twice. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Adam Belay <ambx1@neo.rr.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] 8250 UART backup timerAlex Williamson
The patch below works around a minor bug found in the UART of the remote management card used in many HP ia64 and parisc servers (aka the Diva UARTs). The problem is that the UART does not reassert the THRE interrupt if it has been previously cleared and the IIR THRI bit is re-enabled. This can produce a very annoying failure mode when used as a serial console, allowing a boot/reboot to hang indefinitely until an RX interrupt kicks it into working again (ie. an unattended reboot could stall). To solve this problem, a backup timer is introduced that runs alongside the standard interrupt driven mechanism. This timer wakes up periodically, checks for a hang condition and gets characters moving again. This backup mechanism is only enabled if the UART is detected as having this problem, so systems without these UARTs will have no additional overhead. This version of the patch incorporates previous comments from Pavel and removes races in the bug detection code. The test is now done before the irq linking to prevent races with interrupt handler clearing the THRE interrupt. Short delays and syncs are also added to ensure the device is able to update register state before the result is tested. Aristeu says: this was tested on the following HP machines and solved the problem: rx2600, rx2620, rx1600 and rx1620s. hpa says: I have seen this same bug in soft UART IP from "a major vendor." Signed-off-by: Alex Williamson <alex.williamson@hp.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Russell King <rmk@arm.linux.org.uk> Acked-by: Aristeu Sergio Rozanski Filho <aris@cathedrallabs.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-13Merge branch 'for-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of master.kernel.org:/pub/scm/linux/kernel/git/roland/infiniband: IB/mthca: Always fill MTTs from CPU IB/mthca: Merge MR and FMR space on 64-bit systems IB/mthca: Fix access to MTT and MPT tables on non-cache-coherent CPUs IB/mthca: Give reserved MTTs a separate cache line IB/mthca: Fix reserved MTTs calculation on mem-free HCAs RDMA/cxgb3: Add driver for Chelsio T3 RNIC IB: Remove redundant "_wq" from workqueue names RDMA/cma: Increment port number after close to avoid re-use IB/ehca: Fix memleak on module unloading IB/mthca: Work around gcc bug on sparc64 IPoIB: Connected mode experimental support IB/core: Use ARRAY_SIZE macro for mandatory_table IB/mthca: Use correct structure size in call to memset()
2007-02-13Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: [IPSEC]: Fix the address family to refer encap_family [IPSEC]: changing API of xfrm6_tunnel_register [IPSEC]: make sit use the xfrm4_tunnel_register [IPSEC]: Changing API of xfrm4_tunnel_register. [TCP]: Prevent pseudo garbage in SYN's advertized window [NET_SCHED]: sch_hfsc: replace ASSERT macro by WARN_ON [BRIDGE] br_if: Fix oops in port_carrier_check [NETFILTER]: Clear GSO bits for TCP reset packet [TG3]: Update copyright, version, and reldate. [TG3]: Add some tx timeout debug messages. [TG3]: Use constant for PHY register 0x1e. [TG3]: Power down 5704 serdes transceiver when shutting down. [TG3]: 5906 doesn't need to switch to slower clock. [TG3]: 5722/5756 don't need PHY jitter workaround. [TG3]: Use lower DMA watermark for 5703. [TG3]: Save MSI state before suspend. [XFRM]: Fix IPv4 tunnel mode decapsulation with IPV6=n [IPV6] HASHTABLES: Use appropriate seed for caluculating ehash index.
2007-02-13Merge master.kernel.org:/pub/scm/linux/kernel/git/paulus/powerpcLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/paulus/powerpc: (61 commits) [POWERPC] Use udbg_early_init() on ppc32 [POWERPC] Open Firmware serial port driver [POWERPC] Move MPIC smp routines into mpic.c [POWERPC] Cleanup pseries kexec code [POWERPC] Cleanup pseries smp initialisation code [POWERPC] Consolidate pseries platform header files into pseries.h [POWERPC] 85xx: Drop use of SYNC macro in head_fsl_booke.S [POWERPC] cell: pm_rtas_activat_signals routine cleanup [POWERPC] cell: PPU Oprofile cleanup patch [POWERPC] spufs: avoid accessing kernel memory through mmapped /mem node [POWERPC] spu sched: static timeslicing for SCHED_RR contexts [POWERPC] spu sched: use DECLARE_BITMAP [POWERPC] spu sched: forced preemption at execution [POWERPC] spu sched: update some comments [POWERPC] spu sched: simplity spu_remove_from_active_list [POWERPC] spufs: optimize spu_run [POWERPC] spufs: runqueue simplification [POWERPC] spufs: move prio to spu_context [POWERPC] spufs: state_mutex cleanup [POWERPC] spufs: simplify state_mutex ...
2007-02-14[POWERPC] Open Firmware serial port driverArnd Bergmann
This can be used for serial ports that are connected to an OF platform bus but are not autodetected by the lecacy serial support. It will automatically take over devices that come from the legacy serial detection, which usually is only one device. In some cases, rtas may be set up to use the serial port in the firmware, which allows easier debugging before probing the serial ports. In this case, the "used-by-rtas" property must be set by the firmware. This patch also adds code to the legacy serial driver to check for this. Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-13Merge branch 'i2c-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6Linus Torvalds
* 'i2c-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6: i2c: Stop using i2c_adapter.class_dev i2c: Remove the warning on missing adapter device i2c: Declare more i2c_adapter parent devices i2c: PA Semi SMBus driver i2c-amd8111: Proposed cleanups i2c-parport: Add support for One For All remote JP1 interface i2c-viapro: Add support for the VIA CX700 south bridge i2c: Add IDs to adapters i2c: Update the list of bus IDs i2c: Add driver suspend/resume/shutdown support i2c: completion header cleanups i2c-i801: Document the SMBus unhiding quirk i2c-i801: Spelling fix i2c: Fix typo in SMBus Write Word Data description i2c-piix4: Add support for the ATI SB600 i2c-nforce2: Drop unused reference to pci_dev i2c/vt8231: Remove superfluous initialization i2c-ali1563: Fix device initialization i2c-ali1563: Improve the status messages
2007-02-13Merge master.kernel.org:/pub/scm/linux/kernel/git/wim/linux-2.6-watchdogLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/wim/linux-2.6-watchdog: (23 commits) [WATCHDOG] timers cleanup [WATCHDOG] ib700wdt.c - convert to platform_device part 2 [WATCHDOG] ib700wdt.c - convert to platform_device [WATCHDOG] ib700wdt.c spinlock/WDIOC_SETOPTIONS changes [WATCHDOG] ib700wdt.c small clean-up's [WATCHDOG] ib700wdt.c clean-up init and exit routines [WATCHDOG] ib700_wdt.c stop + set_heartbeat operations [WATCHDOG] show default value for nowayout in module parameter [WATCHDOG] advantechwdt.c - convert to platform_device part 2 [WATCHDOG] advantechwdt.c - convert to platform_device [WATCHDOG] advantechwdt.c - move set_heartbeat to a seperate function [WATCHDOG] advantechwdt.c - cleanup before platform_device patches [WATCHDOG] acquirewdt.c - convert to platform_device part 2 [WATCHDOG] acquirewdt.c - convert to platform_device [WATCHDOG] acquirewdt.c - clean before platform_device patches [WATCHDOG] pcwd_usb.c - get heartbeat from dip switches [WATCHDOG] pcwd.c - e-mail adres update [WATCHDOG] pcwd_usb.c - get heartbeat from dip switches [WATCHDOG] pcwd_usb.c - document includes [WATCHDOG] pcwd_pci.c - spinlock fixes ...
2007-02-13[PATCH] Fix SAK_work workqueue initialization.Eric W. Biederman
Somewhere in the rewrite of the work queues my cleanup of SAK handling got broken. Maybe I didn't retest it properly or possibly the API was changing so fast I missed something. Regardless currently triggering a SAK now generates an ugly BUG_ON and kills the kernel. Thanks to Alexey Dobriyan <adobriyan@openvz.org> for spotting this. This modifies the use of SAK_work to initialize it when the data structure it resides in is initialized, and to simply call schedule_work when we need to generate a SAK. I update both data structures that have a SAK_work member for consistency. All of the old PREPARE_WORK calls that are now gone. If we call schedule_work again before it has processed it has generated the first SAK it will simply ignore the duplicate schedule_work request. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-13Merge ../linux-2.6-watchdog-mmWim Van Sebroeck
2007-02-13i2c: Stop using i2c_adapter.class_devJean Delvare
Stop using i2c_adapter.class_dev, as it is going to be removed soon. Luckily, there are only 4 RTC drivers affected. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Alessandro Zummo <a.zummo@towertech.it>
2007-02-13i2c: Remove the warning on missing adapter deviceJean Delvare
Now that the i2c_adapter migration plan changed and we are going to keep i2c_adapter.dev, it's no longer that urgent to add a proper device to all i2c_adapter drivers. Thus is seems resonable to degrade the warning asking authors to migrate their driver to a debug message. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-02-13i2c: Declare more i2c_adapter parent devicesJean Delvare
Declare the parent device of i2c_adapter devices each time we can easily do so. It makes the i2c_adapter appear at the right place in the device tree, rather than as a platform device. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: Len Brown <len.brown@intel.com> Cc: Jordan Crouse <jordan.crouse@amd.com> Cc: Jody McIntyre <scjody@modernduck.com> Cc: Stefan Richter <stefanr@s5r6.in-berlin.de> Cc: v4l-dvb-maintainer@linuxtv.org Cc: Petr Vandrovec <vandrove@vc.cvut.cz>
2007-02-13i2c: PA Semi SMBus driverOlof Johansson
New driver for the PA Semi SMBus interfaces. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-02-13i2c-amd8111: Proposed cleanupsJean Delvare
Proposed cleanups to the i2c-amd8111 SMBus driver: * Fold long lines. * Add an explicit mask when writing the low byte of a word. * Use I2C_SMBUS_BLOCK_MAX instead of hardcoding 32. * Discard extra blank lines. * Use boolean not instead of bitwise not for bit tests, it's clearer. * Return -EBUSY rather than -1 on I/O resource conflict. * Fix a race on device registration, initialization should be done before the bus is registered. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-02-13i2c-parport: Add support for One For All remote JP1 interfaceJonathan McDowell
This simple patch adds support to i2c-parport for the One For All remote JP1 parallel port interfaces which can be found detailed at: http://www.hifi-remote.com/jp1/hardware.shtml These allow access to the internal configuration EEPROM on various remote controls and there are a variety of Windows tools that make use of this hardware. I have tested this patch with the "simple" parallel port device and a One For All URC-7562 and confirmed that the data read using the eeprom i2c driver matches that returned by the Windows "IR" JP1 tool. Signed-off-by: Jonathan McDowell <noodles@earth.li> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-02-13i2c-viapro: Add support for the VIA CX700 south bridgeJean Delvare
We do not have any documentation for the CX700, but it was reported to work fine. Thanks to Claas Langbehn for testing. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-02-13i2c: Add IDs to adaptersStephen Hemminger
IDs have been defined but not used by most of the I2C adapters. By having a unique ID, clients can check for correct connection during probe. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-02-13i2c: Add driver suspend/resume/shutdown supportDavid Brownell
Driver model updates for the I2C core: - Add new suspend(), resume(), and shutdown() methods. Use them in the standard driver model style; document them. - Minor doc updates to highlight zero-initialized fields in drivers, and the driver model accessors for "clientdata". If any i2c drivers were previously using the old suspend/resume calls in "struct driver", they were getting warning messages ... and will now no longer work. Other than that, this patch changes no behaviors; and it lets I2C drivers use conventional PM and shutdown support. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2007-02-13i2c: completion header cleanupsJean Delvare
i2c-core and i2c-isa use completions without including <linux/completion.h>. Fix it. i2c-powermac includes <linux/completion.h> but doesn't use any completion. Fix it. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Brownell <david-b@pacbell.net>
2007-02-13i2c-i801: Spelling fixJean Delvare
2007-02-13i2c-piix4: Add support for the ATI SB600Jean Delvare
Add support for the ATI SB600 SMBus controller. Signed-off-by: Jean Delvare <khali@linux-fr.org>
